    F1C500 跑 tina 挂了, 请问这是什么问题?
    tina f1c500
    5878
      yixiuge LV 5 最后由 编辑
      [0]HELLO! BOOT0 is starting!
      [2]boot0 commit : 80628dcde5dc4ecdc757a9e782c58d7cf1abf959
      [60]dram size =32
      [62]Reg pull reg_val=0x00000000,read=0x00000010
      [66]Succeed in reading toc file head.
      [69]The size of toc is 00054000.
      [127]Reg pull reg_val=0x00000000,read=0x00000010
      [136]Ready to disable icache.
      [138]Jump to secend Boot.
      U-Boot 2014.07 (Jul 05 2022 - 11:58:37) Allwinner Technology
      uboot commit : f1592db8c49aaedd6895f7e0f90caa123f0a3d5a
      i2c_init: by cpux
      [I2C-DEBUG]:i2c_set_clock() 354
      [I2C-ERROR]:twi_send_clk_9pulse() 136 SDA is still Stuck Low, failed.
      i2c_init ok
      [0.187]pmbus:   ready
      axp: get node[/soc/pmu0] error
      axp_probe error
      [0.193]PMU: cpux 408 Mhz,AXI=408 Mhz
      PLL6=600 Mhz,AHB1=200 Mhz, APB1=100Mhz
      key value = 4294967295, fel_key = [256,426]
      DRAM:  32 MiB
      Relocation Offset is: 01580000
      int sunxi_dma_init---
      irq enable
      workmode = 0,storage type = 3
      [0.260]spinor:   0
      flash size =0x4000 sectors
      sunxi spinor is initing...int sunxi_dma_init---
      irq enable
      sunxi_dma_install_int ok
      OK
      spinor id:0x1840ef
      spi_freq = 40000000
      [0.278]sunxi flash init ok
      spinor read: start 0x3e0, sector 0x20
      used mbr [0], count = 8
      spinor read: start 0x800, sector 0x200
      env size is 256
      env partition is too small!
      can't enabled backup env functions
      logo addr = 0x81f00000
      spinor read: start 0x400, sector 0x400
      sunxi_read_bootlogo: read bootlogo partition successful
      do not find fastboot status flag
      --------fastboot partitions--------
      -total partitions:8-
      -name-        -start-       -size-
      bootlogo    : 4000          80000
      env         : 84000         20000
      boot        : a4000         280000
      rootfs      : 324000        340000
      rootfs_data : 664000        80000
      misc        : 6e4000        10000
      private     : 6f4000        10000
      UDISK       : 704000        0
      spinor read: start 0x3b00, sector 0x4
      ## error: update_fdt_dram_para : FDT_ERR_NOTFOUND
      PowerBus = 0( 2:vBus 3:acBus other: not exist)
      no battery exist
      sunxi_bmp_logo_display
      spinor read: start 0x900, sector 0x40
      spinor read: start 0x940, sector 0x1376
      ## Booting kernel from Legacy Image at 80007fc0 ...
         Image Name:   ARM OpenWrt Linux-3.10.65
         Image Type:   ARM Linux Kernel Image (uncompressed)
         Data Size:    2583056 Bytes = 2.5 MiB
         Load Address: 80008000
         Entry Point:  80008000
         XIP Kernel Image ... OK
         reserving fdt memory region: addr=81000000 size=10000
         Using Device Tree in place at 81000000, end 8100f25f
      Starting kernel ...
      [    0.000000] Initializing cgroup subsys cpuset
      [    0.000000] Initializing cgroup subsys cpuacct
      [    0.000000] Linux version 3.10.65 (yixiuge@ubuntu) (gcc version 6.4.1 (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) ) #241 Wed Jul 6 02:28:57 UTC 2022
      [    0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
      [    0.000000] CPU: VIVT data cache, VIVT instruction cache
      [    0.000000] Machine: Allwinner A1X (Device Tree), model: sun3iw1p1
      [    0.000000] bootconsole [earlycon0] enabled
      [    0.000000] cma: CMA: failed to reserve 32 MiB
      [    0.000000] Memory policy: ECC disabled, Data cache writeback
      [    0.000000] On node 0 totalpages: 8192
      [    0.000000] free_area_init_node: node 0, pgdat c0542acc, node_mem_map c0570000
      [    0.000000]   Normal zone: 64 pages used for memmap
      [    0.000000]   Normal zone: 8192 pages, LIFO batch:0
      [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 8128
      [    0.000000] Kernel command line: enforcing=1 earlyprintk=sunxi-uart,0x01c25400 initcall_debug=0 console=ttyS1,115200 loglevel=8 root=/dev/mtdblock4 init=/pseudo_init rdinit=/rdinit partitions=bootlogo@mtdblock1:env@mtdblock2:boot@mtdblock3:rootfs@mtdblock4:rootfs_data@mtdblock5:misc@mtdblock6:private@mtdblock7:UDISK@mtdblock8 cma=32M fb_base=0x81f00000 androidboot.serialno=<NULL> boot_type=3
      [    0.000000] PID hash table entries: 128 (order: -3, 512 bytes)
      [    0.000000] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
      [    0.000000] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
      [    0.000000] Memory: 32MB = 32MB total
      [    0.000000] Memory: 26764k/26764k available, 6004k reserved, 0K highmem
      [    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
      [    0.000000]     vmalloc : 0xc2800000 - 0xff000000   ( 968 MB)
      [    0.000000]     lowmem  : 0xc0000000 - 0xc2000000   (  32 MB)
      [    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
      [    0.000000]       .text : 0xc0008000 - 0xc043ff84   (4320 kB)
      [    0.000000]       .init : 0xc0440000 - 0xc045df74   ( 120 kB)
      [    0.000000]       .data : 0xc045e000 - 0xc05433e8   ( 917 kB)
      [    0.000000]        .bss : 0xc05433e8 - 0xc056fbe0   ( 178 kB)
      [    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
      [    0.000000] NR_IRQS:256
      [    0.000000] of_sunxi_clocks_init : sunxi_clk_base[0xf1c20000]
      [    0.000000] pll_cpu-set_default_rate=552000000 success!
      [    0.000000] pll_video-set_default_rate=297000000 success!
      [    0.000000] pll_ddr-set_default_rate=312000000 success!
      [    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
      [    0.000000] Console: colour dummy device 80x30
      [    0.005324] Calibrating delay loop... 275.25 BogoMIPS (lpj=1376256)
      [    0.075248] pid_max: default: 32768 minimum: 301
      [    0.080428] Mount-cache hash table entries: 512
      [    0.086418] CPU: Testing write buffer coherency: ok
      [    0.092210] Setting up static identity map for 0xc0340870 - 0xc03408c8
      [    0.101460] devtmpfs: initialized
      [    0.106951] pinctrl core: initialized pinctrl subsystem
      [    0.112813] NET: Registered protocol family 16
      [    0.117979] DMA: failed to allocate 256 KiB pool for atomic coherent allocation
      [    0.126039] dump_class_init,844, success
      [    0.135071] sun3iw1p1-pinctrl pio: initialized sunXi PIO driver
      [    0.158846] bio: create slab <bio-0> at 0
      [    0.164281] pwm module init!
      [    0.169086] SCSI subsystem initialized
      [    0.173379] usbcore: registered new interface driver usbfs
      [    0.179158] usbcore: registered new interface driver hub
      [    0.185033] usbcore: registered new device driver usb
      [    0.196223] Linux video capture interface: v2.00
      [    0.201551] Advanced Linux Sound Architecture Driver Initialized.
      [    0.209725] cfg80211: Calling CRDA to update world regulatory domain
      [    0.217223] Switching to clocksource sun3i high-res couter
      [    0.242461] get det_vbus is fail, 84
      [    0.247922] NET: Registered protocol family 2
      [    0.254586] TCP established hash table entries: 512 (order: 0, 4096 bytes)
      [    0.261700] TCP bind hash table entries: 512 (order: -1, 2048 bytes)
      [    0.268362] TCP: Hash tables configured (established 512 bind 512)
      [    0.274916] TCP: reno registered
      [    0.278314] UDP hash table entries: 256 (order: 0, 4096 bytes)
      [    0.284426] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
      [    0.291488] NET: Registered protocol family 1
      [    0.309535] squashfs: version 4.0 (2009/01/31) Phillip Lougher
      [    0.316196] jffs2: version 2.2. © 2001-2006 Red Hat, Inc.
      [    0.322636] msgmni has been set to 52
      [    0.329752] io scheduler noop registered
      [    0.334046] io scheduler cfq registered (default)
      [    0.338922] [pm]aw_pm_init!
      [    0.342196] [pm]valid
      [    0.344684] [pm]valid
      [    0.347410] [DISP]disp_module_init
      [    0.353777] /soc/lcd0@01c0c000: could not find phandle
      [    0.413103] pll_freq=297000000HZ, lcd_dclk_freq=33000000HZ, clk_div=9
      [    0.420517] num_screens=1
      [    0.423395] screen_id=0
      [    0.425974] para->mclk[MOD_CLK_LCD1CH0]=0xc180c300
      [    0.430924] para->mclk[MOD_CLK_LCD1CH1]=0xc180c400
      [    0.435925] disp tv init
      [    0.438595] tcon_clk=0xc180c300, tcon_clk_parent=0x0
      [    0.443767] tcon_clk=0xc180c300, tcon_clk_parent=0xc18043c0
      [    0.449516] tve_clk=0xc180c400, tve_clk_parent=0xc18043c0
      [    0.455115] disp al tv init
      [    0.460785] fetch script datadisp.screen2_output_type fail
      [    0.466877] fetch script datadisp.screen2_output_mode fail
      [    0.475252] fetch script datadisp.fb2_format fail
      [    0.480440] fetch script datadisp.fb2_scaler_mode_enable fail
      [    0.486748] fetch script datadisp.fb2_width fail
      [    0.491838] fetch script datadisp.fb2_height fail
      [    0.496800] disp_malloc fail, size=0x2ee000
      [    0.501139] disp_malloc fail!
      [    0.504611] Unable to handle kernel paging request at virtual address 0005dfc0
      [    0.512052] pgd = c0004000
      [    0.515013] [0005dfc0] *pgd=00000000
      [    0.518761] Internal error: Oops: 805 [#1] ARM
      [    0.523361] Modules linked in:
      [    0.526571] CPU: 0 PID: 1 Comm: swapper Not tainted 3.10.65 #241
      [    0.532764] task: c1832000 ti: c1834000 task.ti: c1834000
      [    0.538356] PC is at memcpy+0x244/0x330
      [    0.542343] LR is at 0xadc8ff9e
      [    0.545632] pc : [<c0125564>]    lr : [<adc8ff9e>]    psr: 20000013
      [    0.545632] sp : c1835c40  ip : ff9eaec8  fp : c1835d7c
      [    0.557455] r10: 000000ef  r9 : ff9dacc8  r8 : ff99a8c7
      [    0.562851] r7 : ff97a6c6  r6 : ff96a5c7  r5 : ff94a2c4  r4 : ff93a2c4
      [    0.569566] r3 : ff9ca7c2  r2 : 00000460  r1 : c2854b58  r0 : 0005dfc0
      [    0.576284] Flags: nzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
      [    0.583792] Control: 0005317f  Table: 80004000  DAC: 00000017
      [    0.589711]
      [    0.589711] PC: 0xc01254e4:
      [    0.594224] 54e4  cafffff9 e2411003 eaffffba e252201c ba00001f e92d03e0 f5d1f000 e2522060
      [    0.602714] 5504  f5d1f01c ba000002 f5d1f03c f5d1f05c f5d1f07c e8b100f0 e1a0382e e2522020
      [    0.611198] 5524  e8b15300 e1833804 e1a04824 e1844805 e1a05825 e1855806 e1a06826 e1866807
      [    0.619683] 5544  e1a07827 e1877808 e1a08828 e1888809 e1a09829 e189980c e1a0c82c e18cc80e
      [    0.628169] 5564  e8a013f8 aaffffe9 e3720060 aaffffe8 e8bd03e0 e212c01c 0a000005 e1a0382e
      [    0.636653] 5584  e491e004 e25cc004 e183380e e4803004 cafffff9 e2411002 eaffff8e e252201c
      [    0.645138] 55a4  ba00001f e92d03e0 f5d1f000 e2522060 f5d1f01c ba000002 f5d1f03c f5d1f05c
      [    0.653624] 55c4  f5d1f07c e8b100f0 e1a03c2e e2522020 e8b15300 e1833404 e1a04c24 e1844405
      [    0.662111]
      [    0.662111] SP: 0xc1835bc0:
      [    0.666624] 5bc0  c0542acc 81f00000 c1835bfc c1835bd8 c006e17c c006d4e4 c0125564 20000013
      [    0.675109] 5be0  ffffffff c1835c2c c1835d7c c1835bf8 c000f4b8 c000a1a0 0005dfc0 c2854b58
      [    0.683593] 5c00  00000460 ff9ca7c2 ff93a2c4 ff94a2c4 ff96a5c7 ff97a6c6 ff99a8c7 ff9dacc8
      [    0.692077] 5c20  000000ef c1835d7c ff9eaec8 c1835c40 adc8ff9e c0125564 20000013 ffffffff
      [    0.700560] 5c40  0005dfc0 c1835d88 000001e0 0004b036 00000000 0005dfc0 c18f0800 c0157d94
      [    0.709043] 5c60  c0477658 00000000 00000001 00000140 00000140 000000f0 c280a000 c280a036
      [    0.717527] 5c80  000001e0 00000320 00000000 00000320 c000a314 00000000 00000000 00000000
      [    0.726009] 5ca0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
      [    0.734492]
      [    0.734492] IP: 0xff9eae48:
      [    0.739005] ae48  ******** ******** ******** ******** ******** ******** ******** ********
      [    0.747498] ae68  ******** ******** ******** ******** ******** ******** ******** ********
      [    0.755982] ae88  ******** ******** ******** ******** ******** ******** ******** ********
      [    0.764465] aea8  ******** ******** ******** ******** ******** ******** ******** ********
      [    0.772949] aec8  ******** ******** ******** ******** ******** ******** ******** ********
      [    0.781432] aee8  ******** ******** ******** ******** ******** ******** ******** ********
      [    0.789915] af08  ******** ******** ******** ******** ******** ******** ******** ********
      [    0.798399] af28  ******** ******** ******** ******** ******** ******** ******** ********
      [    0.806885]
      [    0.806885] FP: 0xc1835cfc:
      [    0.811397] 5cfc  000001e0 ffffffff 00000000 00000000 00000320 000001e0 00000000 00000000
      [    0.819881] 5d1c  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
      [    0.828362] 5d3c  00000320 000001e0 00000000 00000000 00000000 00000000 c05551f8 00000000
      [    0.836843] 5d5c  00000000 c0555468 c0555470 c0555468 00000004 c1835ddc c1835d80 c0158b04
      [    0.845326] 5d7c  c0157614 c0555470 00000001 00000000 00000000 00000002 00000320 000001e0
      [    0.853810] 5d9c  00000320 000001e0 00000000 00000000 00000000 c0154334 c05551f8 c185f800
      [    0.862292] 5dbc  c185f810 c0478d4c 00000000 c0459d50 00000000 c1835dfc c1835de0 c0155d44
      [    0.870776] 5ddc  c01580ac c185f810 c0558ac4 00000000 c0478d4c c1835e0c c1835e00 c01a3d8c
      [    0.879262]
      [    0.879262] R1: 0xc2854ad8:
      [    0.883774] 4ad8  2376ff0e 2073ff0d 2173ff0b 2372ff0b 2273ff0b 2272ff0b 2170ff0b 206fff0a
      [    0.892262] 4af8  2170ff0c 2170ff0c 206dff0c 206cff0c 206cff0d 206cff0d 206aff0d 1f6aff0d
      [    0.900750] 4b18  1f6aff0d 216aff0d 1f68ff0d 1e65ff0b 1e65ff0a 1f66ff0a 6c94ff0b a7c2ff62
      [    0.909238] 4b38  a2c4ff9c a2c4ff93 a5c7ff94 a6c6ff96 a8c7ff97 acc8ff99 aec8ff9d adc8ff9e
      [    0.917726] 4b58  adc8ff9f b1cbff9f b1ccffa3 b1ccffa3 b4ceffa5 b2ccffa8 b3ceffa6 b8cdffa7
      [    0.926214] 4b78  bbcfffad bcd0ffb0 bed2ffb1 bed0ffb3 bfd1ffb3 c1d3ffb4 c3d5ffb6 c5d5ffb8
      [    0.934701] 4b98  c8d9ffbb c9daffbf cbdcffc0 c8d8ffc2 cad9ffbf ccdbffc1 cddcffc3 cedeffc4
      [    0.943189] 4bb8  d0e0ffc3 d0e0ffc4 d0e0ffc4 d2e3ffc4 d1e3ffc8 d3e4ffc8 d1e2ffca d0e0ffc8
      [    0.951680]
      [    0.951680] R3: 0xff9ca742:
      [    0.956192] a740  ******** ******** ******** ******** ******** ******** ******** ********
      [    0.964675] a760  ******** ******** ******** ******** ******** ******** ******** ********
      [    0.973158] a780  ******** ******** ******** ******** ******** ******** ******** ********
      [    0.981642] a7a0  ******** ******** ******** ******** ******** ******** ******** ********
      [    0.990126] a7c0  ******** ******** ******** ******** ******** ******** ******** ********
      [    0.998610] a7e0  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.007093] a800  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.015577] a820  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.024060] a840  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.032545]
      [    1.032545] R4: 0xff93a244:
      [    1.037058] a244  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.045541] a264  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.054025] a284  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.062509] a2a4  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.070992] a2c4  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.079475] a2e4  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.087958] a304  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.096441] a324  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.104927]
      [    1.104927] R5: 0xff94a244:
      [    1.109439] a244  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.117922] a264  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.126405] a284  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.134889] a2a4  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.143372] a2c4  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.151856] a2e4  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.160340] a304  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.168824] a324  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.177310]
      [    1.177310] R6: 0xff96a547:
      [    1.181822] a544  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.190306] a564  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.198789] a584  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.207272] a5a4  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.215756] a5c4  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.224239] a5e4  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.232723] a604  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.241206] a624  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.249690] a644  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.258176]
      [    1.258176] R7: 0xff97a646:
      [    1.262689] a644  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.271171] a664  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.279655] a684  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.288138] a6a4  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.296622] a6c4  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.305105] a6e4  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.313589] a704  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.322072] a724  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.330555] a744  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.339041]
      [    1.339041] R8: 0xff99a847:
      [    1.343553] a844  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.352037] a864  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.360521] a884  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.369004] a8a4  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.377487] a8c4  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.385970] a8e4  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.394453] a904  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.402937] a924  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.411422] a944  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.419908]
      [    1.419908] R9: 0xff9dac48:
      [    1.424421] ac48  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.432904] ac68  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.441388] ac88  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.449871] aca8  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.458355] acc8  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.466838] ace8  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.475323] ad08  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.483807] ad28  ******** ******** ******** ******** ******** ******** ******** ********
      [    1.492299] Process swapper (pid: 1, stack limit = 0xc18341b8)
      [    1.498311] Stack: (0xc1835c40 to 0xc1836000)
      [    1.502843] 5c40: 0005dfc0 c1835d88 000001e0 0004b036 00000000 0005dfc0 c18f0800 c0157d94
      [    1.511245] 5c60: c0477658 00000000 00000001 00000140 00000140 000000f0 c280a000 c280a036
      [    1.519646] 5c80: 000001e0 00000320 00000000 00000320 c000a314 00000000 00000000 00000000
      [    1.528045] 5ca0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
      [    1.536445] 5cc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
      [    1.544846] 5ce0: 00000000 00000000 ff000001 00000000 00000000 00000000 00000320 000001e0
      [    1.553246] 5d00: ffffffff 00000000 00000000 00000320 000001e0 00000000 00000000 00000000
      [    1.561646] 5d20: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000320
      [    1.570046] 5d40: 000001e0 00000000 00000000 00000000 00000000 c05551f8 00000000 00000000
      [    1.578449] 5d60: c0555468 c0555470 c0555468 00000004 c1835ddc c1835d80 c0158b04 c0157614
      [    1.586851] 5d80: c0555470 00000001 00000000 00000000 00000002 00000320 000001e0 00000320
      [    1.595253] 5da0: 000001e0 00000000 00000000 00000000 c0154334 c05551f8 c185f800 c185f810
      [    1.603655] 5dc0: c0478d4c 00000000 c0459d50 00000000 c1835dfc c1835de0 c0155d44 c01580ac
      [    1.612058] 5de0: c185f810 c0558ac4 00000000 c0478d4c c1835e0c c1835e00 c01a3d8c c0155be4
      [    1.620462] 5e00: c1835e34 c1835e10 c01a2b60 c01a3d80 c185f810 c185f844 c0478d4c 00000000
      [    1.628865] 5e20: 00000000 c0459d50 c1835e54 c1835e38 c01a2cb4 c01a2a2c 00000000 c0478d4c
      [    1.637268] 5e40: c01a2c60 00000000 c1835e7c c1835e58 c01a11b0 c01a2c70 c1823f4c c185c870
      [    1.645673] 5e60: c18cde14 c0478d4c c18cdde0 c0533e60 c1835e8c c1835e80 c01a2610 c01a1138
      [    1.654076] 5e80: c1835ebc c1835e90 c01a2240 c01a2600 c03f4533 c045de44 c1835ebc c0478d4c
      [    1.662479] 5ea0: c03f4533 00000000 c045de44 00000000 c1835ee4 c1835ec0 c01a3264 c01a2108
      [    1.670882] 5ec0: c0554f80 c03f4533 00000000 c045de44 00000000 c0459d50 c1835ef4 c1835ee8
      [    1.679285] 5ee0: c01a42ec c01a31cc c1835f1c c1835ef8 c044d3f0 c01a42b0 c03f4533 c01a31cc
      [    1.687689] 5f00: c1835f1c c1834000 c044d314 c0543400 c1835f5c c1835f20 c000a4d4 c044d324
      [    1.696091] 5f20: 00000006 00000006 0000005c c05c0149 c003b8a0 00000007 c0543400 0000005c
      [    1.704494] 5f40: c045de44 c0459d48 c0459d50 00000000 c1835f94 c1835f60 c0440c0c c000a3c8
      [    1.712895] 5f60: 00000006 00000006 c04404d0 00000000 00000000 c033b5fc 00000000 00000000
      [    1.721297] 5f80: 00000000 00000000 c1835fac c1835f98 c033b60c c0440a78 00000000 c033b5fc
      [    1.729698] 5fa0: 00000000 c1835fb0 c000f930 c033b60c 00000000 00000000 00000000 00000000
      [    1.738099] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
      [    1.746499] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
      [    1.754879] Backtrace:
      [    1.757515] [<c0157604>] (Display_Fb_Request+0x0/0x814) from [<c0158b04>] (Fb_Init+0xa68/0xc24)
      [    1.766459] [<c015809c>] (Fb_Init+0x0/0xc24) from [<c0155d44>] (disp_probe+0x170/0x1f0)
      [    1.774703] [<c0155bd4>] (disp_probe+0x0/0x1f0) from [<c01a3d8c>] (platform_drv_probe+0x1c/0x20)
      [    1.783706]  r7:c0478d4c r6:00000000 r5:c0558ac4 r4:c185f810
      [    1.789611] [<c01a3d70>] (platform_drv_probe+0x0/0x20) from [<c01a2b60>] (driver_probe_device+0x144/0x1f8)
      [    1.799513] [<c01a2a1c>] (driver_probe_device+0x0/0x1f8) from [<c01a2cb4>] (__driver_attach+0x54/0x94)
      [    1.809041]  r9:c0459d50 r8:00000000 r7:00000000 r6:c0478d4c r5:c185f844
      r4:c185f810
      [    1.817254] [<c01a2c60>] (__driver_attach+0x0/0x94) from [<c01a11b0>] (bus_for_each_dev+0x88/0x98)
      [    1.826429]  r7:00000000 r6:c01a2c60 r5:c0478d4c r4:00000000
      [    1.832326] [<c01a1128>] (bus_for_each_dev+0x0/0x98) from [<c01a2610>] (driver_attach+0x20/0x28)
      [    1.841325]  r6:c0533e60 r5:c18cdde0 r4:c0478d4c
      [    1.846153] [<c01a25f0>] (driver_attach+0x0/0x28) from [<c01a2240>] (bus_add_driver+0x148/0x220)
      [    1.855175] [<c01a20f8>] (bus_add_driver+0x0/0x220) from [<c01a3264>] (driver_register+0xa8/0x124)
      [    1.864349]  r8:00000000 r7:c045de44 r6:00000000 r5:c03f4533 r4:c0478d4c
      [    1.871325] [<c01a31bc>] (driver_register+0x0/0x124) from [<c01a42ec>] (platform_driver_register+0x4c/0x60)
      [    1.881293]  r9:c0459d50 r8:00000000 r7:c045de44 r6:00000000 r5:c03f4533
      r4:c0554f80
      [    1.889530] [<c01a42a0>] (platform_driver_register+0x0/0x60) from [<c044d3f0>] (disp_module_init+0xdc/0x128)
      [    1.899616] [<c044d314>] (disp_module_init+0x0/0x128) from [<c000a4d4>] (do_one_initcall+0x11c/0x148)
      [    1.909055]  r6:c0543400 r5:c044d314 r4:c1834000
      [    1.913890] [<c000a3b8>] (do_one_initcall+0x0/0x148) from [<c0440c0c>] (kernel_init_freeable+0x1a4/0x1e4)
      [    1.923711] [<c0440a68>] (kernel_init_freeable+0x0/0x1e4) from [<c033b60c>] (kernel_init+0x10/0xe8)
      [    1.932973]  r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c033b5fc
      r4:00000000
      [    1.941200] [<c033b5fc>] (kernel_init+0x0/0xe8) from [<c000f930>] (ret_from_fork+0x14/0x24)
      [    1.949759]  r5:c033b5fc r4:00000000
      [    1.953514] Code: e1a09829 e189980c e1a0c82c e18cc80e (e8a013f8)
      [    1.959971] ---[ end trace 4c9adbe59771339d ]---
      [    1.964864] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
      [    1.964864]
        YterAA LV 7 最后由 编辑
        disp的de问题
        Y 1 条回复 最后回复 回复 引用 分享 0
          yixiuge LV 5 @YterAA 最后由 编辑
          @yteraa
          那怎么改呢?
            yixiuge LV 5 @yixiuge 最后由 编辑
            @yixiuge
            思来想去, 感觉CMA内存配置太多了:
            CONFIG_CLKSRC_OF=y
            CONFIG_CLONE_BACKWARDS=y
            CONFIG_CMA=y
            CONFIG_CMA_ALIGNMENT=8
            CONFIG_CMA_AREAS=7
            # CONFIG_CMA_DEBUG is not set
            CONFIG_CMA_SIZE_MBYTES=16
            # CONFIG_CMA_SIZE_SEL_MAX is not set
            CONFIG_CMA_SIZE_SEL_MBYTES=y
            16M 字节
              @yixiuge
              配成 1M / 4M / 8M 一番折腾半小时, 问题依旧.
                yixiuge LV 5 @yixiuge 最后由 yixiuge 编辑
                @yixiuge
                看了一下启动日志, 感觉白改了.
                CMA 仍然(居然)是32M
                  yixiuge LV 5 最后由 编辑
                  问题可能来自 env 文件, 果然发现了32M的踪影:
                  enforcing=1
                  initcall_debug=0
                  nor_root=/dev/mtdblock4
                  nand_root=/dev/nandd
                  mmc_root=/dev/mmcblk0p7
                  init=/sbin/init
                  rdinit=/rdinit
                  loglevel=8
                  cma=32M
                  verify=no
                  rootdelay=5
                  改成 4M, 一切正常:
                  [60]dram size =32
                  7
                  i2c_init: by cpux
                  i2c_init ok
                  [0.187]pmbus:   ready
                  axp_probe error
                  DRAM:  32 MiB
                  irq enable
                  [0.259]spinor:   0
                  irq enable
                  OK
                  spinor id:0x1840ef
                  spi_freq = 40000000
                  [0.277]sunxi flash init ok
                  env size is 256
                  env         : 84000         20000
                  boot        : a4000         280000
                  misc        : 6e4000        10000
                  UDISK       : 704000        0
                  no battery exist
                  Starting kernel ...
                  [    0.000000] Linux version 3.10.65 (whycan@ubuntu) (gcc version 6.4.1 (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) ) #244 Wed Jul 6 03:35:16 UTC 2022
                  [    0.000000] cma: CMA: reserved 4 MiB at 81c00000
                  [    0.000000] Kernel command line: enforcing=1 earlyprintk=sunxi-uart,0x01c25400 initcall_debug=0 console=ttyS1,115200 loglevel=8 root=/dev/mtdblock4 init=/pseudo_init rdinit=/rdinit partitions=bootlogo@mtdblock1:env@mtdblock2:boot@mtdblock3:rootfs@mtdblock4:rootfs_data@mtdblock5:misc@mtdblock6:private@mtdblock7:UDISK@mtdblock8 cma=4M fb_base=0x81f00000 androidboot.serialno=<NULL> boot_type=3
                  [    0.000000] Memory: 22660k/22660k available, 10108k reserved, 0K highmem
                  [    0.005240] Calibrating delay loop... 275.25 BogoMIPS (lpj=1376256)
                  [    0.075335] pid_max: default: 32768 minimum: 301
                  [    0.080426] Mount-cache hash table entries: 512
                  [    0.086330] CPU: Testing write buffer coherency: ok
                  [    0.092016] Setting up static identity map for 0xc0340870 - 0xc03408c8
                  [    0.101175] devtmpfs: initialized
                  [    0.106609] pinctrl core: initialized pinctrl subsystem
                  [    0.113284] NET: Registered protocol family 16
                  [    0.121081] DMA: preallocated 256 KiB pool for atomic coherent allocations
                  [    0.128650] dump_class_init,844, success
                  [    0.137578] sun3iw1p1-pinctrl pio: initialized sunXi PIO driver
                  [    0.161252] bio: create slab <bio-0> at 0
                  [    0.166611] pwm module init!
                  [    0.171352] SCSI subsystem initialized
                  [    0.175576] usbcore: registered new interface driver usbfs
                  [    0.181250] usbcore: registered new interface driver hub
                  [    0.187048] usbcore: registered new device driver usb
                  [    0.198124] Linux video capture interface: v2.00
                  [    0.203466] Advanced Linux Sound Architecture Driver Initialized.
                  [    0.211194] cfg80211: Calling CRDA to update world regulatory domain
                  [    0.218592] Switching to clocksource sun3i high-res couter
                  [    0.243830] get det_vbus is fail, 84
                  [    0.249228] NET: Registered protocol family 2
                  [    0.255822] TCP established hash table entries: 512 (order: 0, 4096 bytes)
                  [    0.262810] TCP bind hash table entries: 512 (order: -1, 2048 bytes)
                  [    0.269354] TCP: Hash tables configured (established 512 bind 512)
                  [    0.275790] TCP: reno registered
                  [    0.279128] UDP hash table entries: 256 (order: 0, 4096 bytes)
                  [    0.285133] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
                  [    0.292082] NET: Registered protocol family 1
                  [    0.310031] squashfs: version 4.0 (2009/01/31) Phillip Lougher
                  [    0.316588] jffs2: version 2.2. © 2001-2006 Red Hat, Inc.
                  [    0.322928] msgmni has been set to 52
                  [    0.330054] io scheduler noop registered
                  [    0.334163] io scheduler cfq registered (default)
                  [    0.339056] [pm]aw_pm_init!
                  [    0.342287] [pm]valid
                  [    0.344727] [pm]valid
                  [    0.347415] [DISP]disp_module_init
                  [    0.353598] /soc/lcd0@01c0c000: could not find phandle
                  [    0.414365] pll_freq=297000000HZ, lcd_dclk_freq=33000000HZ, clk_div=9
                  [    0.421624] num_screens=1
                  [    0.424461] screen_id=0
                  [    0.426997] para->mclk[MOD_CLK_LCD1CH0]=0xc140c340
                  [    0.431858] para->mclk[MOD_CLK_LCD1CH1]=0xc140c440
                  [    0.436772] disp tv init
                  [    0.439395] tcon_clk=0xc140c340, tcon_clk_parent=0x0
                  [    0.444470] tcon_clk=0xc140c340, tcon_clk_parent=0xc1404400
                  [    0.450115] tve_clk=0xc140c440, tve_clk_parent=0xc1404400
                  [    0.455613] disp al tv init
                  [    0.461225] fetch script datadisp.screen2_output_type fail
                  [    0.467215] fetch script datadisp.screen2_output_mode fail
                  [    0.475493] fetch script datadisp.fb2_format fail
                  [    0.480579] fetch script datadisp.fb2_scaler_mode_enable fail
                  [    0.486782] fetch script datadisp.fb2_width fail
                  [    0.491790] fetch script datadisp.fb2_height fail
                  [    0.511438] [DISP] Fb_map_kernel_logo,line:561:    this is not a bmp picture
                  [    0.523077] [DISP]disp_module_init finish
                  [    0.541423] uart1: ttyS1 at MMIO 0x1c25400 (irq = 104) is a SUNXI
                  [    0.547750] sw_console_setup()1324 - console setup baud 115200 parity n bits 8, flow n
                  [    0.555824] console [ttyS1] enabled, bootconsole disabled
                  [    0.568378] misc dump reg init
                  [    0.573053] sunxi-wlan wlan: wlan_busnum (0)
                  [    0.577938] sunxi-wlan wlan: wlan_power_num (0)
                  [    0.582983] sunxi-wlan wlan: Missing wlan_io_regulator.
                  [    0.588840] sunxi-wlan wlan: io_regulator_name ((null))
                  [    0.594714] sunxi-wlan wlan: request pincrtl handle for device [wlan] failed
                  [    0.602652] /soc/wlan: could not find phandle
                  [    0.607558] sunxi-wlan wlan: get gpio wlan_regon failed
                  [    0.613409] sunxi-wlan wlan: wlan_hostwake gpio=117  mul-sel=6  pull=-1  drv_level=-1  data=1
                  [    0.622989] sunxi-wlan wlan: Missing clocks.
                  [    0.627801] sunxi-wlan wlan: clk_name ((null))
                  [    0.632770] sunxi-wlan wlan: clk not config
                  [    0.637843] lradc_battery_probe:lradc_battery_probe ++++++
                  [    0.643941] lradc_battery_dts_parse:lradc_battery_dts_parse ++++++
                  [    0.650913] key base: f1c23400
                  [    0.654496] irq num: 114 !
                  [    0.657504] battery_data_hw_init:battery_data_hw_init ++++++
                  [    0.663837] lradc_battery_probe:lradc_battery_probe ------
                  [    0.672520] spi spi0: master is unqueued, this is deprecated
                  [    0.680222] m25p80 spi0.0: found w25q128, expected m25p64
                  [    0.686355] m25p80 spi0.0: w25q128 (16384 Kbytes) - fast mode
                  [    0.697241] 9 sunxipart partitions found on MTD device (null)
                  [    0.703638] Creating 9 MTD partitions on "(null)":
                  [    0.709044] 0x000000000000-0x000000080000 : "uboot"
                  [    0.716616] 0x000000080000-0x000000100000 : "bootlogo"
                  [    0.724402] 0x000000100000-0x000000120000 : "env"
                  [    0.731402] 0x000000120000-0x0000003a0000 : "boot"
                  [    0.738613] 0x0000003a0000-0x0000006e0000 : "rootfs"
                  [    0.746125] 0x0000006e0000-0x000000760000 : "rootfs_data"
                  [    0.753945] 0x000000760000-0x000000770000 : "misc"
                  [    0.761355] 0x000000770000-0x000000780000 : "private"
                  [    0.768963] 0x000000780000-0x000001000000 : "UDISK"
                  [    0.776772] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
                  [    0.785561] /soc/usbc0@0: could not find phandle
                  [    0.790710] get regulator_io is no nocare
                  [    0.795447] sunxi_hcd_host0 1c13000.otghci0-controller: sunxi_hcd host driver
                  [    0.803396] sunxi_hcd_host0 1c13000.otghci0-controller: new USB bus registered, assigned bus number 1
                  [    0.815359] hub 1-0:1.0: USB hub found
                  [    0.819583] hub 1-0:1.0: 1 port detected
                  [    0.824578] wrn: hcd is not enable, need not stop hcd
                  [    0.830948] sunxi_keyboard_startup: keyboard has no clk.
                  [    0.837525] input: sunxi-keyboard as /devices/virtual/input/input0
                  [    0.845555] rtc-pcf8563 0-0051: chip found, driver version 0.4.3
                  [    0.852626] sunxi_i2c_do_xfer()928 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x51)
                  [    0.861893] rtc-pcf8563 0-0051: pcf8563_get_datetime: read error
                  [    0.869161] rtc-pcf8563 0-0051: rtc core: registered rtc-pcf8563 as rtc0
                  [    0.876819] sunxi cedar version 0.1
                  [    0.880949] VE: install start!!!
                  [    0.880949]
                  [    0.886418] cedar_ve: cedar-ve the get irq is 103
                  [    0.892247] VE: install end!!!
                  [    0.892247]
                  [    0.899089] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v0.91 2018-5-29 14:19) Compiled in Jul  6 2022 at 03:29:35
                  [    0.911583] sunxi-mmc sdc0: Can't get vmmc regulator string
                  [    0.917896] sunxi-mmc sdc0: Can't get vqmmc regulator string
                  [    0.924190] sunxi-mmc sdc0: Can't get vdmmc regulator string
                  [    0.930532] sunxi-mmc sdc0: Failed getting OCR mask: 0
                  [    0.937748] sunxi-mmc sdc0: ***set host ocr***
                  [    0.943086] sunxi-mmc sdc0: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
                  [    0.964393] sunxi-mmc sdc0: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                  [    0.994550] sunxi-mmc sdc0: base:0xf1c0f000 irq:107
                  [    1.000011] sunxi-mmc sdc0: smc 0 p0 err, cmd 52, RTO !!
                  [    1.006869] sunxi-mmc sdc0: smc 0 p0 err, cmd 52, RTO !!
                  [    1.012861] sunxi-mmc sdc0: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                  [    1.027373] failed to get gpio-spk and gpio_num
                  [    1.035925] sunxi-internal-codec 1c23c00.codec: ASoC: DAPM unknown pin HPOUTR
                  [    1.043927] sunxi-internal-codec 1c23c00.codec: ASoC: DAPM unknown pin HPOUTL
                  [    1.051944] sunxi-internal-codec 1c23c00.codec: ASoC: DAPM unknown pin SPKL
                  [    1.059724] sunxi-internal-codec 1c23c00.codec: ASoC: DAPM unknown pin SPKR
                  [    1.067487] sunxi-codec-machine sound.2: ASoC: DAPM unknown pin External Speaker
                  [    1.076825] sunxi-mmc sdc0: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                  [    1.087837] sunxi-internal-cpudai 1c23c00.cpudai0-controller: ASoC: pcm constructor failed: -12
                  [    1.097587] sunxi-codec-machine sound.2: ASoC: can't create pcm SUNXI-CODEC :-12
                  [    1.105852] sunxi-codec-machine sound.2: ASoC: failed to instantiate card -12
                  [    1.114171] snd_soc_register_card failed -12
                  [    1.119130] sunxi-codec-machine: probe of sound.2 failed with error -12
                  [    1.127276] ipip: IPv4 over IPv4 tunneling driver
                  [    1.133619] gre: GRE over IPv4 demultiplexor driver
                  [    1.139169] ip_gre: GRE over IPv4 tunneling driver
                  [    1.146527] sunxi-mmc sdc0: smc 0 p0 err, cmd 8, RTO !!
                  [    1.153280] sunxi-mmc sdc0: smc 0 p0 err, cmd 5, RTO !!
                  [    1.160092] sunxi-mmc sdc0: smc 0 p0 err, cmd 5, RTO !!
                  [    1.166036] TCP: cubic registered
                  [    1.169720] Initializing XFRM netlink socket
                  [    1.174605] NET: Registered protocol family 17
                  [    1.179577] sunxi-mmc sdc0: smc 0 p0 err, cmd 5, RTO !!
                  [    1.185576] NET: Registered protocol family 15
                  [    1.190552] sunxi-mmc sdc0: smc 0 p0 err, cmd 5, RTO !!
                  [    1.196911] VFP support v0.3: not present
                  [    1.202330] sunxi-mmc sdc0: smc 0 p0 err, cmd 55, RTO !!
                  [    1.208781] [LCD]lcd_module_init
                  [    1.212432] sunxi-mmc sdc0: smc 0 p0 err, cmd 55, RTO !!
                  [    1.219326] sunxi-mmc sdc0: smc 0 p0 err, cmd 55, RTO !!
                  [    1.226585] sunxi-mmc sdc0: smc 0 p0 err, cmd 55, RTO !!
                  [    1.232912] sunxi-mmc sdc0: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                  [    1.245673] enhance_en=1
                  [    1.248546] matrixresult:(0x0, 0x3c4, 0x0, 0x0)
                  [    1.253713] pll_freq=297000000HZ, lcd_dclk_freq=33000000HZ, clk_div=9
                  [    1.260996] clk_div=9
                  [    1.263525] AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                  [    1.269174] AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                  [    1.274811] AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                  [    1.280408] AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                  [    1.286033] AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                  [    1.291629] AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                  [    1.297252] AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                  [    1.304229] sunxi-mmc sdc0: smc 0 p0 err, cmd 1, RTO !!
                  [    1.310270] sunxi-mmc sdc0: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
                  [    1.320962] [LCD]open, step 0 finish
                  [    1.364369] [LCD]open, step 1 finish
                  [    1.424349] [LCD]open, step 2 finish
                  [    1.534780] [LCD]open, step 3 finish
                  [    1.544867] [LCD]lcd_module_init finish
                  [    1.549664] usb_serial_number:20080411
                  [    1.554561] file system registered
                  [    1.561012] android_usb gadget: Mass Storage Function, version: 2009/09/11
                  [    1.568795] android_usb gadget: Number of LUNs=3
                  [    1.573932]  lun0: LUN: removable file: (no medium)
                  [    1.579440]  lun1: LUN: removable file: (no medium)
                  [    1.584904]  lun2: LUN: removable file: (no medium)
                  [    1.591230] android_usb gadget: android_usb ready
                  [    1.597044] sunxi_i2c_do_xfer()928 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x51)
                  [    1.606318] rtc-pcf8563 0-0051: pcf8563_get_datetime: read error
                  [    1.613025] rtc-pcf8563 0-0051: hctosys: unable to read the hardware clock
                  [    1.620975] ALSA device list:
                  [    1.624373]   No soundcards found.
                  [    1.643819] VFS: Mounted root (squashfs filesystem) readonly on device 31:4.
                  [    1.661693] devtmpfs: mounted
                  [    1.666154] Freeing unused kernel memory: 116K (c0440000 - c045d000)
                  mount: mounting pstore on /sys/fs/pstore failed: No such file or directory
                  -- run rc.preboot --
                  -- set volume --
                  Failed to open mixer
                  -- play music --
                  -- end --
                  failed to open for pcm 0,0
                  [    4.264325]
                  [    4.264325] insmod_device_driver
                  [    4.264325]
                  [    4.271463] device_chose finished 77!
                  -- run rc.final --
                  insmod F1C200s-board
                  -- wifi connect --
                  insmod wifi kernel module --------------------
                  insmod: can't insert '/lib/modules/3.10.65/xradio_wlan.ko': No such file or directory
                  start wpa_supplicant ------------------------
                  [    5.515719] android_usb: already disabled
                  [    5.571478] adb_open
                  [    5.575308] adb_bind_config
                  [    5.828309] android_work: sent uevent USB_STATE=CONNECTED
                  [    5.916425] android_usb gadget: high-speed config #1: android
                  [    5.932047] android_work: sent uevent USB_STATE=CONFIGURED
                  Line 6: Invalid passphrase length 6 (expected: 8..63) '******"'.
                  Line 6: failed to parse psk '"******"'.
                  Line 7: failed to parse network block.
                  Failed to read or parse configuration '/etc/wpa_supplicant.conf'.
                  start udhcpc ----------------
                  -- end --
                  udhcpc: SIOCGIFINDEX: No such device
                  root@TinaLinux:/#
                  root@TinaLinux:/#
                  root@TinaLinux:/#
                  root@TinaLinux:/#
                    yixiuge LV 5 最后由 编辑
                    root@TinaLinux:/# cat /proc/meminfo
                    MemTotal:          26872 kB
                    MemFree:           14840 kB
                    Buffers:            1444 kB
                    Cached:             2128 kB
                    SwapCached:            0 kB
                    Active:             1640 kB
                    Inactive:           2160 kB
                    Active(anon):        236 kB
                    Inactive(anon):       20 kB
                    Active(file):       1404 kB
                    Inactive(file):     2140 kB
                    Unevictable:           0 kB
                    Mlocked:               0 kB
                    SwapTotal:             0 kB
                    SwapFree:              0 kB
                    Dirty:                 0 kB
                    Writeback:             0 kB
                    AnonPages:           240 kB
                    Mapped:              596 kB
                    Shmem:                28 kB
                    Slab:               4020 kB
                    SReclaimable:        832 kB
                    SUnreclaim:         3188 kB
                    KernelStack:         312 kB
                    PageTables:           80 kB
                    NFS_Unstable:          0 kB
                    Bounce:                0 kB
                    WritebackTmp:          0 kB
                    CommitLimit:       13436 kB
                    Committed_AS:       1292 kB
                    VmallocTotal:     991232 kB
                    VmallocUsed:        4160 kB
                    VmallocChunk:     745392 kB
                    剩下还挺多的
