    【V853开发板试用】V853编译烧录疑难杂症汇总篇
    6
    5153
    • aldfaaa
      whycan矿工-小叶 LV 7 最后由 xiaowenge 编辑
      • 不要使用过去编译D1s的ubu14.04进行编译.
        会出现找不到__NR_renameat2的值.
      • 官方文档提供的ubu20.04虚拟机在win11上运行可能存在问题, 输入密码登陆后无显示并卡死. win7实测正常.
      • 找不到mkimage
      UIMAGE  arch/arm/boot/uImage
      "mkimage" command not found - U-Boot images will not be built
      make[1]: *** [arch/arm/boot/Makefile:93: arch/arm/boot/uImage] Error 1
      make: *** [arch/arm/Makefile:331: uImage] Error 2
      可以find . -name "mkimage" |xargs ls -lh,
      然后选一个可以执行的,
      export PATH=$PWD/brandy/brandy-2.0/u-boot-2018/tools:$PATH
      • 找不到/编不出mconf
        find一下, 进入相应目录, make clean, 然后再重新make
      W 1 条回复 最后回复 回复 引用 分享 0
        woodfor LV 3 @aldfaaa 最后由 编辑
        编译过tina-d1-h的ubu14.04编译V853只出现了找不到mkimage的问题,修改后,编译成功
        • aldfaaa
          whycan矿工-小叶 LV 7 最后由 编辑
          官方文档提供的ubu20.04虚拟机(后称, 官方虚拟机)执行pack出现
          fsbuild: No such file or directory
          这是全志的闭源打包工具, 位于: tina-v853-open/tools/pack/pctools/linux/fsbuild200目录下, readelf -h可见
          $ readelf -h fsbuild
          ELF Header:
            Magic:   7f 45 4c 46 01 01 01 00 00 00 00 00 00 00 00 00
            Class:                             ELF32
            Data:                              2's complement, little endian
            Version:                           1 (current)
            OS/ABI:                            UNIX - System V
            ABI Version:                       0
            Type:                              EXEC (Executable file)
            Machine:                           Intel 80386
            Version:                           0x1
            Entry point address:               0x8048870
            Start of program headers:          52 (bytes into file)
            Start of section headers:          33856 (bytes into file)
            Flags:                             0x0
            Size of this header:               52 (bytes)
            Size of program headers:           32 (bytes)
            Number of program headers:         8
            Size of section headers:           40 (bytes)
            Number of section headers:         38
            Section header string table index: 35
          居然是个32位程序, 遂参考Ubuntu-64位系统运行32位程序的方法:
          sudo apt-get install libc6:i386 libncurses5:i386 libstdc++6:i386 zlib1g:i386
          sudo dpkg --add-architecture i386
          Tina 终(
            YterAA LV 7 最后由 编辑
            这就更新虚拟机(不是
            • Referenced by  aldfaaa aldfaaa
            • Referenced by  Y yanmingjian
              yelong98 LV 7 最后由 编辑
              Begin Parse sys_partion.fex
              Add partion boot.fex BOOT_FEX00000000
              FilePath: boot.fex
              FileLength=375800Add partion rootfs.fex ROOTFS_FEX000000
              FilePath: rootfs.fex
              FileLength=3a0000Add partion usr.fex USR_FEX000000000
              Add partion very usr.fex USR_FEX000000000
              FilePath: usr.fex
              FileLength=1a0000Add partion env_nor.fex ENV_NOR_FEX00000
              Add partion very env_nor.fex ENV_NOR_FEX00000
              FilePath: env_nor.fex
              FileLength=20000Add partion bootlogo.fex BOOTLOGO_FEX0000
              Add partion very bootlogo.fex BOOTLOGO_FEX0000
              FilePath: bootlogo.fex
              FileLength=4b036The file config.fex length = 0
              BuildImg 400
              Dragon execute image.cfg Failed ! ArgCnt = 3, 400
              pack finish
              请问Dragon execute image.cfg Failed ! 这里是什么错误?用的ubuntu18.04
              Y 1 条回复 最后回复 回复 引用 分享 0
                yelong98 LV 7 @yelong98 最后由 编辑
                @yelong98 在 【V853开发板试用】V853编译烧录疑难杂症汇总篇 中说:
                FilePath: boot.fex
                FilePath: usr.fex
                BuildImg 400
                pack finish
                已经排除了32位程序兼容问题,按照帖子指示安装了对应的支持包,还是一样的错误,可以看到有image.cfg文件存在,说明是dragon处理的问题,有遇到的老铁,指点一下
