    D1在linux上支持RGB显示屏问题求助
    8
    22
    18448
      suncw LV 4 最后由 编辑
      使用tina-d1-h linux系统,想调试RGB显示屏,配置完成后,显示屏黑屏(背光是外接的所以是有背光的)
      把调试信息打开,发现有报错(disp 1 not support lcd output),不知道是不是这个原因导致黑屏的。求助一下帮忙看看这是什么问题,谢谢
      配置:
      &disp {
      	/*VCC-LCD*/
      	/*VCC-DSI*/
      	/*VCC-PD*/
      &lcd0 {
      	lcd_used            = <1>;
      	lcd_driver_name     = "default_panel";
      	lcd_if              = <0>;
              lcd_hv_if           = <0>;
      	lcd_x               = <800>;
      	lcd_y               = <480>;
      	lcd_width           = <108>;
      	lcd_height          = <65>;
      	lcd_dclk_freq       = <25>;
      	lcd_hbp             = <12>;
      	lcd_ht              = <816>;
      	lcd_hspw            = <4>;
      	lcd_vbp             = <12>;
      	lcd_vt              = <496>;
      	lcd_vspw            = <4>;
      	lcd_frm             = <1>;
      	lcd_hv_clk_phase    = <0>;
      	lcd_hv_sync_polarity= <0>;
      	lcd_gamma_en        = <0>;
      	lcd_bright_curve_en = <0>;
              lcd_power          = "vcc-lcd";
              lcd_pin_power      = "vcc-pd";
      	pinctrl-0 = <&rgb18_pins_a>;
      	pinctrl-1 = <&rgb18_pins_b>;
      启动信息:
      [214]HELLO! BOOT0 is starting!
      [217]BOOT0 commit : 88480af
      [219]set pll start
      [221]fix vccio detect value:0xc0
      [224]periph0 has been enabled
      [227]set pll end
      [229][pmu]: bus read error
      [231]board init ok
      [233]get_pmu_exist() = -1
      [236]ddr_efuse_type: 0x0
      [238]trefi:7.8ms
      [240][AUTO DEBUG] single rank and full DQ!
      [244]ddr_efuse_type: 0x0
      [247]trefi:7.8ms
      [249][AUTO DEBUG] rank 0 row = 15
      [252][AUTO DEBUG] rank 0 bank = 8
      [255][AUTO DEBUG] rank 0 page size = 2 KB
      [259]DRAM BOOT DRIVE INFO: V0.33
      [262]DRAM CLK = 792 MHz
      [265]DRAM Type = 3 (2:DDR2,3:DDR3)
      [268]DRAMC ZQ value: 0x7b7bfb
      [271]DRAM ODT value: 0x42.
      [273]ddr_efuse_type: 0x0
      [276]DRAM SIZE =512 M
      [278]dram_tpr4:0x0
      [280]PLL_DDR_CTRL_REG:0xf8004100
      [283]DRAM_CLK_REG:0xc0000000
      [286][TIMING DEBUG] MR2= 0x18
      [290]DRAM simple test OK.
      [292]dram size =512
      [294]card no is 0
      [296]sdcard 0 line count 4
      [298][mmc]: mmc driver ver 2021-04-2 16:45
      [308][mmc]: Wrong media type 0x0
      [311][mmc]: ***Try SD card 0***
      [331][mmc]: HSSDR52/SDR25 4 bit
      [334][mmc]: 50000000 Hz
      [336][mmc]: 30436 MB
      [338][mmc]: ***SD/MMC 0 init OK!!!***
      [388]Loading boot-pkg Succeed(index=0).
      [391]Entry_name        = opensbi
      [395]Entry_name        = u-boot
      [398]Entry_name        = dtb
      [401]mmc not para
      [402]Jump to second Boot.
      OpenSBI auto-t113-linux-V0.8-2-g053d088
              |_|
      Platform Max HARTs     : 1
      Current Hart           : 0
      Runtime SBI Version    : 0.2
      MIDELEG : 0x0000000000000222
      MEDELEG : 0x000000000000b1ff
      PMP3    : 0x0000000000020000-0x0000000000027fff (A,
      U-Boot 2018.05-g24521d6 (Feb 11 2022 - 08:52:39 +0000) Allwinner Technology
      [00.488]DRAM:  512 MiB
      [00.490]Relocation Offset is: 1dee7000
      [00.494]secure enable bit: 0
      [00.497]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [00.503]flash init start
      [00.505]workmode = 0,storage type = 1
      [00.508][mmc]: mmc driver ver uboot2018:2021-11-19 15:38:00
      [00.514][mmc]: get sdc_type fail and use default host:tm1.
      [00.520][mmc]: can't find node "mmc0",will add new node
      [00.525][mmc]: fdt err returned <no error>
      [00.529][mmc]: Using default timing para
      [00.532][mmc]: SUNXI SDMMC Controller Version:0x50310
      [00.559][mmc]: card_caps:0x3000000a
      [00.562][mmc]: host_caps:0x3000003f
      [00.567]sunxi flash init ok
      [00.570]line:703 init_clocks
      [00.573]drv_disp_init
      [00.584]drv_disp_init finish
      [00.587]boot_gui_init:start
      [00.590]set disp.dev2_output_type fail. using defval=0
      [00.595]LCD open finish
      [00.597]boot_gui_init:finish
      [00.616]bmp_name=bootlogo.bmp size 3072054
      3072054 bytes read in 129 ms (22.7 MiB/s)
      no support big size bmp[800x1280] on fb[800x480]
      [00.758]show bmp on fb failed !-1
      [00.770]Loading Environment from SUNXI_FLASH... OK
      [00.790]out of usb burn from boot: not need burn key
      [00.816]Item0 (Map) magic is bad
      [00.819]the secure storage item0 copy0 magic is bad
      [00.845]Item0 (Map) magic is bad
      [00.848]the secure storage item0 copy1 magic is bad
      [00.852]Item0 (Map) magic is bad
      root_partition is rootfs
      set root to /dev/mmcblk0p5
      [00.865]update part info
      [00.868]update bootcmd
      [00.871]change working_fdt 0x5eaa6da0 to 0x5ea86da0
      [00.900]update dts
      noncached_alloc(): addr = 0x5eb12b40
      noncached_alloc(): addr = 0x5eb12b80
      noncached_alloc(): addr = 0x5ec8a040
      noncached_alloc(): addr = 0x5ec8a880
      phy_mode=rgmii, phy_interface=7
      gmac: *** using ephy_clk ***
      eth0
      Warning: eth0 (eth0) using random MAC address - c2:f2:aa:b9:99:b2
      dsp0:gpio init config fail
      dsp0:sharespace config fail
      dsp0 version is r528-tina-v1.0.0-release-37-g735b6b4-dirty
      DSP0 start ok, img length 254860, booting from 0x400660
      [04.194]no vendor_boot partition is found
      Android's image name: d1-h-nezha
      Detect comp gzip
      [04.447]
      Starting kernel ...
      [04.450][mmc]: MMC Device 2 not found
      [04.453][mmc]: mmc 2 not find, so not exit
      ** 531 printk messages dropped **
      [    0.207704] of_property_read_u32_array lcd0.lcd_hv_syuv_seq fail
      [    0.207925] [DISP] disp_sys_script_get_item,line:214:
      [    0.207930] of_property_read_u32_array lcd0.lcd_hv_syuv_fdly fail
      [    0.208350] [DISP] disp_sys_script_get_item,line:214:
      [    0.208355] of_property_read_u32_array lcd0.lcd_cmap_en fail
      [    0.208558] [DISP] disp_sys_script_get_item,line:214:
      [    0.208563] of_property_read_u32_array lcd0.lcd_xtal_freq fail
      [    0.208786] [DISP] disp_sys_script_get_item,line:222:
      [    0.208791] of_property_read_string lcd0.lcd_size fail
      [    0.209006] [DISP] disp_sys_script_get_item,line:222:
      [    0.209010] of_property_read_string lcd0.lcd_model_name fail
      [    0.209218] [DISP] lcd_clk_init,line:493:
      [    0.209221] lcd 0 clk init
      [    0.209463] [DISP] disp_init_hdmi,line:1052:
      [    0.209467] disp_init_hdmi
      [    0.209490] [DISP] disp_init_mgr,line:2933:
      [    0.209494] disp_init_mgr
      [    0.209507] [DISP] disp_init_mgr,line:2968:
      [    0.209512] mgr 0, 0x(____ptrval____)
      [    0.209526] [DISP] disp_init_mgr,line:2968:
      [    0.209529] mgr 1, 0x(____ptrval____)
      [    0.209541] [DISP] disp_init_lyr,line:758:
      [    0.209543] disp_init_lyr
      [    0.209584] [DISP] disp_init_enhance,line:701:
      [    0.209587] disp_init_enhance
      [    0.209599] [DISP] disp_init_smbl,line:396:
      [    0.209601] disp_init_smbl
      [    0.209619] [DISP] disp_init_connections,line:447:
      [    0.209622] disp_init_connections
      [    0.209632] [DISP] disp_get_layer_1,line:136:
      [    0.209636] disp0 layer0: 0,0,0
      [    0.209645] [DISP] disp_get_layer_1,line:136:
      [    0.209649] disp0 layer1: 0,0,1
      [    0.209657] [DISP] disp_get_layer_1,line:136:
      [    0.209662] disp0 layer2: 0,0,2
      [    0.209670] [DISP] disp_get_layer_1,line:136:
      [    0.209674] disp0 layer3: 0,0,3
      [    0.209682] [DISP] disp_get_layer_1,line:136:
      [    0.209687] disp0 layer4: 0,1,0
      [    0.209695] [DISP] disp_get_layer_1,line:136:
      [    0.209699] disp0 layer5: 0,1,1
      [    0.209708] [DISP] disp_get_layer_1,line:136:
      [    0.209712] disp0 layer6: 0,1,2
      [    0.209721] [DISP] disp_get_layer_1,line:136:
      [    0.209725] disp0 layer7: 0,1,3
      [    0.209735] [DISP] disp_device_set_manager,line:23:
      [    0.209738] device 0, mgr 0
      [    0.209747] [DISP] disp_get_smbl,line:37:
      [    0.209750] get smbl0 ok
      [    0.209760] [DISP] disp_get_layer_1,line:136:
      [    0.209765] disp1 layer8: 1,0,0
      [    0.209773] [DISP] disp_get_layer_1,line:136:
      [    0.209778] disp1 layer9: 1,0,1
      [    0.209787] [DISP] disp_get_layer_1,line:136:
      [    0.209791] disp1 layer10: 1,0,2
      [    0.209800] [DISP] disp_get_layer_1,line:136:
      [    0.209804] disp1 layer11: 1,0,3
      [    0.209813] [DISP] disp_get_smbl,line:37:
      [    0.209816] get smbl1 ok
      [    0.210016] [DISP] disp_lcd_set_panel_funs,line:2446:
      [    0.210024] lcd 0, driver_name default_panel,  panel_name default_lcd
      [    0.210038] [DISP] disp_get_lcd,line:88:
      [    0.210041] disp 1 not support lcd output
      [    0.210048] [DISP] disp_lcd_set_panel_funs,line:2446:
      [    0.210053] lcd 0, driver_name default_panel,  panel_name he0801a068
      [    0.210061] [DISP] disp_get_lcd,line:88:
      [    0.210064] disp 1 not support lcd output
      [    0.210071] [DISP] disp_lcd_set_panel_funs,line:2446:
      [    0.210076] lcd 0, driver_name default_panel,  panel_name inet_dsi_panel
      [    0.210084] [DISP] disp_get_lcd,line:88:
      [    0.210086] disp 1 not support lcd output
      [    0.210094] [DISP] disp_lcd_set_panel_funs,line:2446:
      [    0.210098] lcd 0, driver_name default_panel,  panel_name lq101r1sx03
      [    0.210106] [DISP] disp_get_lcd,line:88:
      [    0.210109] disp 1 not support lcd output
      [    0.210117] [DISP] disp_lcd_set_panel_funs,line:2446:
      [    0.210121] lcd 0, driver_name default_panel,  panel_name WilliamLcd
      [    0.210129] [DISP] disp_get_lcd,line:88:
      [    0.210131] disp 1 not support lcd output
      [    0.210139] [DISP] disp_lcd_set_panel_funs,line:2446:
      [    0.210144] lcd 0, driver_name default_panel,  panel_name CC08021801_310_800X1280
      [    0.210152] [DISP] disp_get_lcd,line:88:
      [    0.210154] disp 1 not support lcd output
      [    0.210162] [DISP] disp_lcd_set_panel_funs,line:2446:
      [    0.210166] lcd 0, driver_name default_panel,  panel_name tft08006
      [    0.210174] [DISP] disp_get_lcd,line:88:
      [    0.210177] disp 1 not support lcd output
      [    0.210184] [DISP] disp_lcd_set_panel_funs,line:2446:
      [    0.210189] lcd 0, driver_name default_panel,  panel_name bp101wx1
      [    0.210197] [DISP] disp_get_lcd,line:88:
      [    0.210199] disp 1 not support lcd output
      [    0.210207] [DISP] disp_lcd_set_panel_funs,line:2446:
      [    0.210211] lcd 0, driver_name default_panel,  panel_name k101im2qa04
      [    0.210219] [DISP] disp_get_lcd,line:88:
      [    0.210222] disp 1 not support lcd output
      [    0.210230] [DISP] disp_lcd_set_panel_funs,line:2446:
      [    0.210234] lcd 0, driver_name default_panel,  panel_name fx070
      [    0.210241] [DISP] disp_get_lcd,line:88:
      [    0.210244] disp 1 not support lcd output
      [    0.210252] [DISP] disp_lcd_set_panel_funs,line:2446:
      [    0.210256] lcd 0, driver_name default_panel,  panel_name K080_IM2HYL802R_800X1280
      [    0.210264] [DISP] disp_get_lcd,line:88:
      [    0.210267] disp 1 not support lcd output
      [    0.210275] [DISP] disp_lcd_set_panel_funs,line:2446:
      [    0.210279] lcd 0, driver_name default_panel,  panel_name K101_IM2BYL02_L_800X1280
      [    0.210287] [DISP] disp_get_lcd,line:88:
      [    0.210290] disp 1 not support lcd output
      [    0.210298] [DISP] disp_lcd_set_panel_funs,line:2446:
      [    0.210302] lcd 0, driver_name default_panel,  panel_name super_lcd_driver
      [    0.210310] [DISP] disp_get_lcd,line:88:
      [    0.210313] disp 1 not support lcd output
      [    0.210321] [DISP] fb_init,line:2291:
      [    0.210323] [DISP] fb_init
      [    0.210337] [DISP] disp_boot_para_parse,line:1172:
      [    0.210341] [DISP] fb_base:0x0
      [    0.210367] [DISP] disp_fb_to_var,line:400:
      [    0.210375] fmt0 para: 32bpp, a(24,8),r(16,8),g(8,8),b(0,8)
      [    0.210387] display_fb_request,fb_id:0
      [    0.213431] [DISP] __disp_ion_alloc_coherent,line:1555:
      [    0.213438] ion map kernel, vaddr=0x(____ptrval____)
      [    0.213545] [DISP] fb_map_video_memory,line:115:
      [    0.213552] fb_map_video_memory(reserve),va=0x(____ptrval____), pa=0x(____ptrval____) size:0x2ee000
      [    0.220867] [DISP] Fb_map_kernel_logo,line:1806:
      [    0.220870] Fb_map_kernel_logo failed!
      [    0.225751] Freeing logo buffer memory: 1500K
      [    0.225767] [DISP] var_to_disp_fb,line:521:
      [    0.225775] format0,para:32bpp,a(24,8),r(16,8),g(8,8),b(0,8)
      [    0.225785] [DISP] disp_mgr_set_layer_config,line:1597:
      [    0.225788] mgr0, config 1 layers
      [    0.225797] [DISP] disp_mgr_set_layer_config,line:1604:
      [    0.225810] layer:ch1, layer0, format=0, size=<800,480>, crop=<0,0,800,480>,frame=<800,480>, en=1 addr[0xffc00000,0x0,0x0> alpha=<0,255>
      [    0.225823] [DISP] disp_get_layer,line:103:
      [    0.225827] 0,1,0, name=mgr0 chn1 lyr0
      [    0.225838] [DISP] disp_lyr_save_and_dirty_check,line:528:
      [    0.225849] layer:ch1, layer0, format=0, size=<800,480>, crop=<0,0,800,480>,frame=<800,480>, en=1 addr[0xffc00000,0x0,0x0>
      [    0.225859] [DISP] disp_mgr_apply,line:2442:
      [    0.225861] mgr 0 apply
      [    0.225873] [DISP] bsp_disp_shadow_protect,line:719:
      [    0.225877] sel=0, protect:1,  cnt=1
      [    0.225890] [DISP] de_al_lyr_apply,line:485:
      [    0.225894] ch0 z 0 dis
      [    0.225902] [DISP] de_al_lyr_apply,line:485:
      [    0.225905] ch1 z 0 en
      [    0.225913] [DISP] de_al_lyr_apply,line:488:
      [    0.225916] pipe0 z 1 en
      [    0.225923] [DISP] de_al_lyr_apply,line:488:
      [    0.225926] pipe1 z 0 dis
      [    0.225935] [DISP] de_al_lyr_apply,line:503:
      [    0.225937] format[0]=0
      [    0.225957] [DISP] de_calc_overlay_scaler_para,line:178:
      [    0.225960] ovl_rect[0]=<0,0>
      [    0.225968] [DISP] de_calc_overlay_scaler_para,line:180:
      [    0.225973] bld_rect[0]=<0,0,0,0>
      [    0.225981] [DISP] de_calc_ovl_coord,line:389:
      [    0.225984] half_shift_xy=<20000,18,0>
      [    0.225993] [DISP] de_calc_ovl_coord,line:389:
      [    0.225996] half_shift_xy=<20000,18,0>
      [    0.226004] [DISP] de_rtmx_calc_chnrect,line:1982:
      [    0.226007] layernum=4, i=0
      [    0.226015] [DISP] de_rtmx_calc_chnrect,line:1984:
      [    0.226018] crop=<0,0,800,480>
      [    0.226026] [DISP] de_rtmx_calc_chnrect,line:1986:
      [    0.226030] layer=<0,0,800,480>
      [    0.226038] [DISP] de_rtmx_calc_chnrect,line:1995:
      [    0.226042] ovl_rect=<0,0,800,480>
      [    0.226050] [DISP] de_rtmx_calc_chnrect,line:1997:
      [    0.226054] bld_rect=<0,0,800,480>
      [    0.226061] [DISP] de_calc_overlay_scaler_para,line:178:
      [    0.226065] ovl_rect[1]=<800,480>
      [    0.226072] [DISP] de_calc_overlay_scaler_para,line:180:
      [    0.226077] bld_rect[1]=<0,0,800,480>
      [    0.226085] [DISP] de_calc_overlay_scaler_para,line:187:
      [    0.226092] fmt[0]=0, ovlw[0]=0,ovlh[0]=0, bld_rect[0].w=0, bld_rect[0].h=0
      [    0.226103] [DISP] de_vsu_set_para,line:274:
      [    0.226109] sel0, ch 0, en=0, in<0x0>,out<0x0>
      [    0.226132] [DISP] de_al_lyr_apply,line:713:
      [    0.226137] sel=0, pipe_rect[0]=<0,0,800,480>
      [    0.226146] [DISP] de_rtmx_set_route,line:1792:
      [    0.226151] sel0, pno0, zorder1, route:0x0
      [    0.226159] [DISP] de_rtmx_set_route,line:1796:
      [    0.226164] addr=0x(____ptrval____), reg=0x1
      [    0.226172] [DISP] de_al_lyr_apply,line:713:
      [    0.226177] sel=0, pipe_rect[1]=<0,0,0,0>
      [    0.226185] [DISP] de_rtmx_set_route,line:1792:
      [    0.226190] sel0, pno1, zorder0, route:0x1
      [    0.226197] [DISP] de_rtmx_set_route,line:1796:
      [    0.226201] addr=0x(____ptrval____), reg=0x1
      [    0.226236] [DISP] de_enhance_apply,line:204:
      [    0.226240] disp 0, en=0, sharp=0
      [    0.226256] [DISP] de_peak_enable,line:123:
      [    0.226260] sel=0, chno=0, en=0
      [    0.226274] [DISP] bsp_disp_shadow_protect,line:719:
      [    0.226278] sel=0, protect:0,  cnt=0
      [    0.226576] [DISP] disp_mgr_sw_enable,line:2645:
      [    0.226581] mgr 0 enable
      [    0.226593] [DISP] disp_mgr_clk_enable,line:1055:
      [    0.226596] set DE rate to 300000000
      [    0.226618] [DISP] disp_mgr_clk_enable,line:1071:
      [    0.226621] mgr 0 clk enable
      [    0.226643] [DISP] disp_mgr_sw_enable,line:2693:
      [    0.226648] output res: 800 x 480, cs=0, range=1, interlace=0
      [    0.226664] [DISP] disp_mgr_apply,line:2442:
      [    0.226666] mgr 0 apply
      [    0.226676] [DISP] bsp_disp_shadow_protect,line:719:
      [    0.226680] sel=0, protect:1,  cnt=1
      [    0.226689] disp_al_manager_apply ouput_type:1
      [    0.226698] [DISP] de_dcsc_apply,line:74:
      [    0.226703] sel=0, in_fmt=0, mode=0, out_fmt=0, mode=0, range=1
      [    0.226727] [DISP] de_al_lyr_apply,line:485:
      [    0.226730] ch0 z 0 dis
      [    0.226738] [DISP] de_al_lyr_apply,line:485:
      [    0.226742] ch1 z 0 en
      [    0.226749] [DISP] de_al_lyr_apply,line:488:
      [    0.226752] pipe0 z 1 en
      [    0.226759] [DISP] de_al_lyr_apply,line:488:
      [    0.226762] pipe1 z 0 dis
      [    0.226771] [DISP] de_al_lyr_apply,line:503:
      [    0.226773] format[0]=0
      [    0.226791] [DISP] de_calc_overlay_scaler_para,line:178:
      [    0.226795] ovl_rect[0]=<0,0>
      [    0.226804] [DISP] de_calc_overlay_scaler_para,line:180:
      [    0.226808] bld_rect[0]=<0,0,0,0>
      [    0.226816] [DISP] de_calc_ovl_coord,line:389:
      [    0.226820] half_shift_xy=<20000,18,0>
      [    0.226828] [DISP] de_calc_ovl_coord,line:389:
      [    0.226832] half_shift_xy=<20000,18,0>
      [    0.226839] [DISP] de_rtmx_calc_chnrect,line:1982:
      [    0.226842] layernum=4, i=0
      [    0.226850] [DISP] de_rtmx_calc_chnrect,line:1984:
      [    0.226854] crop=<0,0,800,480>
      [    0.226861] [DISP] de_rtmx_calc_chnrect,line:1986:
      [    0.226865] layer=<0,0,800,480>
      [    0.226873] [DISP] de_rtmx_calc_chnrect,line:1995:
      [    0.226877] ovl_rect=<0,0,800,480>
      [    0.226885] [DISP] de_rtmx_calc_chnrect,line:1997:
      [    0.226889] bld_rect=<0,0,800,480>
      [    0.226896] [DISP] de_calc_overlay_scaler_para,line:178:
      [    0.226900] ovl_rect[1]=<800,480>
      [    0.226907] [DISP] de_calc_overlay_scaler_para,line:180:
      [    0.226912] bld_rect[1]=<0,0,800,480>
      [    0.226920] [DISP] de_calc_overlay_scaler_para,line:187:
      [    0.226927] fmt[0]=0, ovlw[0]=0,ovlh[0]=0, bld_rect[0].w=0, bld_rect[0].h=0
      [    0.226938] [DISP] de_vsu_set_para,line:274:
      [    0.226943] sel0, ch 0, en=0, in<0x0>,out<0x0>
      [    0.226974] [DISP] de_al_lyr_apply,line:713:
      [    0.226979] sel=0, pipe_rect[0]=<0,0,800,480>
      [    0.226988] [DISP] de_rtmx_set_route,line:1792:
      [    0.226993] sel0, pno0, zorder1, route:0x0
      [    0.227001] [DISP] de_rtmx_set_route,line:1796:
      [    0.227006] addr=0x(____ptrval____), reg=0x1
      [    0.227014] [DISP] de_al_lyr_apply,line:713:
      [    0.227019] sel=0, pipe_rect[1]=<0,0,0,0>
      [    0.227027] [DISP] de_rtmx_set_route,line:1792:
      [    0.227031] sel0, pno1, zorder0, route:0x1
      [    0.227039] [DISP] de_rtmx_set_route,line:1796:
      [    0.227043] addr=0x(____ptrval____), reg=0x1
      [    0.227060] [DISP] bsp_disp_shadow_protect,line:719:
      [    0.227064] sel=0, protect:0,  cnt=0
      [    0.227076] [DISP] disp_enhance_apply,line:126:
      [    0.227079] disp_enhance_apply, screen 0
      [    0.227087] [DISP] bsp_disp_shadow_protect,line:719:
      [    0.227091] sel=0, protect:1,  cnt=1
      [    0.227099] [DISP] de_dcsc_apply,line:74:
      [    0.227105] sel=0, in_fmt=0, mode=0, out_fmt=0, mode=0, range=1
      [    0.227117] [DISP] de_enhance_apply,line:204:
      [    0.227122] disp 0, en=0, sharp=0
      [    0.227135] [DISP] de_peak_enable,line:123:
      [    0.227139] sel=0, chno=0, en=0
      [    0.227152] [DISP] bsp_disp_shadow_protect,line:719:
      [    0.227155] sel=0, protect:0,  cnt=0
      [    0.227172] [DISP] disp_enhance_apply,line:126:
      [    0.227175] disp_enhance_apply, screen 0
      [    0.227184] [DISP] bsp_disp_shadow_protect,line:719:
      [    0.227187] sel=0, protect:1,  cnt=1
      [    0.227195] [DISP] de_dcsc_apply,line:74:
      [    0.227200] sel=0, in_fmt=0, mode=0, out_fmt=0, mode=0, range=1
      [    0.227211] [DISP] de_enhance_apply,line:204:
      [    0.227215] disp 0, en=1, sharp=0
      [    0.227224] [DISP] de_peak_enable,line:123:
      [    0.227228] sel=0, chno=0, en=0
      [    0.227240] [DISP] bsp_disp_shadow_protect,line:719:
      [    0.227244] sel=0, protect:0,  cnt=0
      [    0.227255] panel->lcd_dclk_freq:25 panel->lcd_dclk_freq:25 tcon_div 11
      [    0.227278] [DISP] lcd_clk_config,line:732:
      [    0.227289] disp 0, clk: pll(275000000),clk(275000000),dclk(25000000) dsi_rate(275000000)
      [    0.227289]      clk real:pll(288000000),clk(288000000),dclk(26181818) dsi_rate(0)
      [    0.227310] panel->lcd_dclk_freq:25 panel->lcd_dclk_freq:25 tcon_div 11
      [    0.227318] [DISP] cal_real_frame_period,line:647:
      [    0.227322] lcd frame period:15458666
      [    0.227333] [DISP] disp_sys_register_irq,line:113:
      [    0.227340] disp_sys_register_irq, irqNo=30, Handler=0x(____ptrval____), pArg=0x(____ptrval____)
      [    0.227397] [DISP] disp_init,line:2441:
      [    0.227400] disp_init finish
      [    0.227476] [DISP] disp_probe,line:3118:
      [    0.227479] [DISP]disp_probe finish
      [    0.227874] [DISP]disp_module_init finish
      [    0.228725] sunxi_sid_init()551 - insmod ok
      [    0.229240] pwm-regulator: supplied by regulator-dummy
      [    0.235965] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
      [    0.236534] uart uart0: get regulator failed
      [    0.236561] uart uart0: uart0 supply uart not found, using dummy regulator
      [    0.236871] uart0: ttyS0 at MMIO 0x2500000 (irq = 18, base_baud = 1500000) is a SUNXI
      [    0.236895] sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n
      [    1.734767] printk: console [ttyS0] enabled
      [    1.740254] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
      [    1.751653] uart uart1: get regulator failed
      [    1.756429] uart uart1: uart1 supply uart not found, using dummy regulator
      [    1.764492] uart1: ttyS1 at MMIO 0x2500400 (irq = 19, base_baud = 1500000) is a SUNXI
      [    1.774325] misc dump reg init
      [    1.778557] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
      [    1.785804] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
      [    1.793117] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
      [    1.800510] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
      [    1.807041] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
      [    1.813972] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
      [    1.821692] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=204 assert=1
      [    1.829511] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
      [    1.837635] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
      [    1.845281] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
      [    1.852041] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
      [    1.859543] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=210 assert=0
      [    1.867677] [ADDR_MGT] addr_mgt_probe: module version: v1.0.10
      [    1.875303] [ADDR_MGT] addr_mgt_probe: success.
      [    1.881636] libphy: Fixed MDIO Bus: probed
      [    1.886207] CAN device driver interface
      [    1.891612] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
      [    1.902918] sunxi gmac driver's version: 1.0.0
      [    1.908023] gmac-power0: NULL
      [    1.911372] gmac-power1: NULL
      [    1.914676] gmac-power2: NULL
      [    1.919193] Failed to alloc md5
      [    1.922785] eth0: Use random mac address
      [    1.927486] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [    1.934854] sunxi-ehci: EHCI SUNXI driver
      [    1.939838] get ehci1-controller wakeup-source is fail.
      [    1.945854] sunxi ehci1-controller don't init wakeup source
      [    1.952148] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xffffffe00094f758, 0x:ffffffd00407a000, irq_no:31
      [    1.965705] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply drvvbus not found, using dummy regulator
      [    1.978268] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
      [    1.990484] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
      [    1.997745] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
      [    2.007563] sunxi-ehci 4200000.ehci1-controller: irq 49, io mem 0x04200000
      [    2.040727] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
      [    2.049386] hub 1-0:1.0: USB hub found
      [    2.053680] hub 1-0:1.0: 1 port detected
      [    2.058791] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [    2.065779] sunxi-ohci: OHCI SUNXI driver
      [    2.070863] get ohci1-controller wakeup-source is fail.
      [    2.076798] sunxi ohci1-controller don't init wakeup source
      [    2.083051] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xffffffe0009502b0
      [    2.093473] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply drvvbus not found, using dummy regulator
      [    2.105983] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
      [    2.118191] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
      [    2.125460] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
      [    2.135234] sunxi-ohci 4200400.ohci1-controller: irq 50, io mem 0x04200400
      [    2.215617] hub 2-0:1.0: USB hub found
      [    2.219848] hub 2-0:1.0: 1 port detected
      [    2.225240] usbcore: registered new interface driver uas
      [    2.231404] usbcore: registered new interface driver usb-storage
      [    2.238161] usbcore: registered new interface driver ums-alauda
      [    2.244900] usbcore: registered new interface driver ums-cypress
      [    2.251704] usbcore: registered new interface driver ums-datafab
      [    2.258456] usbcore: registered new interface driver ums_eneub6250
      [    2.265449] usbcore: registered new interface driver ums-freecom
      [    2.272256] usbcore: registered new interface driver ums-isd200
      [    2.278918] usbcore: registered new interface driver ums-jumpshot
      [    2.285817] usbcore: registered new interface driver ums-karma
      [    2.292421] usbcore: registered new interface driver ums-onetouch
      [    2.299288] usbcore: registered new interface driver ums-realtek
      [    2.306090] usbcore: registered new interface driver ums-sddr09
      [    2.312796] usbcore: registered new interface driver ums-sddr55
      [    2.319466] usbcore: registered new interface driver ums-usbat
      [    2.326554] sunxi_gpadc_init,2151, success
      [    2.332060] sunxi-rtc 7090000.rtc: errata__fix_alarm_day_reg_default_value(): ALARM0_DAY_REG=0, set it to 1
      [    2.344249] sunxi-rtc 7090000.rtc: registered as rtc0
      [    2.349996] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:00:06 UTC (6)
      [    2.358913] sunxi-rtc 7090000.rtc: sunxi rtc probed
      [    2.364836] i2c /dev entries driver
      [    2.368843] IR NEC protocol handler initialized
      [    2.374586] sunxi cedar version 1.1
      [    2.378723] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
      [    2.385009] VE: install start!!!
      [    2.385009]
      [    2.390468] VE: cedar-ve the get irq is 6
      [    2.390468]
      [    2.396849] VE: ve_debug_proc_info:(____ptrval____), data:(____ptrval____), lock:(____ptrval____)
      [    2.396849]
      [    2.408428] VE: install end!!!
      [    2.408428]
      [    2.413495] VE: sunxi_cedar_probe
      [    2.418723] sunxi-wdt 6011000.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
      [    2.427858] Bluetooth: HCI UART driver ver 2.3
      [    2.432856] Bluetooth: HCI UART protocol H4 registered
      [    2.438582] Bluetooth: HCI UART protocol BCSP registered
      [    2.444523] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 1.0.10
      [    2.451786] [XR_BT_LPM] bluesleep_probe: bt_wake polarity: 1
      [    2.458150] [XR_BT_LPM] bluesleep_probe: host_wake polarity: 1
      [    2.464724] [XR_BT_LPM] bluesleep_probe: wakeup source is disabled!
      [    2.464724]
      [    2.473389] [XR_BT_LPM] bluesleep_probe: uart_index(1)
      [    2.482126] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
      [    2.492090] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
      [    2.498255] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
      [    2.504599] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
      [    2.511024] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
      [    2.517428] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
      [    2.523948] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
      [    2.530450] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
      [    2.536970] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
      [    2.543913] sunxi-mmc 4020000.sdmmc: Got CD GPIO
      [    2.549411] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
      [    2.556087] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.567218] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
      [    2.587356] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.611715] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
      [    2.617408] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.629639] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
      [    2.639700] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
      [    2.645935] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
      [    2.652318] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
      [    2.658751] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.670321] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
      [    2.676750] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
      [    2.683372] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
      [    2.689907] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
      [    2.696472] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
      [    2.703054] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
      [    2.711751] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.724310] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.735478] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [    2.744398] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.755980] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.780254] sunxi-mmc 4021000.sdmmc: detmode:manually by software
      [    2.787848] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.799898] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
      [    2.811264] sunxi_led_probe()1749 - start
      [    2.815847] sunxi_get_str_of_property()1595 - failed to get the string of propname led_regulator!
      [    2.825840] sunxi_register_led_classdev()1483 - led_classdev start
      [    2.832807] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.848651] sunxi_led_probe()1845 - finish
      [    2.853300] mmc0: host does not support reading read-only switch, assuming write-enable
      [    2.862948] usbcore: registered new interface driver usbhid
      [    2.869236] usbhid: USB HID core driver
      [    2.873594] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [    2.885072] sunxi-mmc 4021000.sdmmc: card claims to support voltages below defined range
      [    2.894234] rpmsg_client_dsp_standby 3003000.msgbox.sunxi,dsp-power-msgbox.512.256: new channel: 0x200 -> 0x100!
      [    2.905742] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [    2.919494] usbcore: registered new interface driver snd-usb-audio
      [    2.927219] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
      [    2.941648] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
      [    2.952776] mmc0: new high speed SDHC card at address aaaa
      [    2.960290] sunxi-daudio 2034000.daudio: regulator missing or invalid
      [    2.968775] mmcblk0: mmc0:aaaa SD32G 29.7 GiB
      [    2.974547] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [    2.986462] [AUDIOCODEC][sunxi_codec_parse_params][2412]:digital_vol:0, lineout_vol:26, mic1gain:19, mic2gain:19 pa_msleep:120, pa_level:1, pa_pwr_level:1
      [    2.986462]
      [    3.003697] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [    3.015387] [AUDIOCODEC][sunxi_codec_parse_params][2448]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
      [    3.026554] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
      [    3.040173] [AUDIOCODEC][sunxi_internal_codec_probe][2609]:codec probe finished
      [    3.049759] mmc1: new high speed SDIO card at address 0001
      [    3.057182]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
      [    3.062714] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
      [    3.075475] [SNDCODEC][sunxi_card_init][583]:card init finished
      [    3.084262] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
      [    3.095455] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input1
      [    3.107515] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
      [    3.115697] sunxi-rpaf-dsp soc@3000000:rpaf-dsp@203034c: register device finished!
      [    3.124206] sunxi-rpaf-dsp soc@3000000:rpaf-dsp@203034c: [rpaf_dsp0] probe finished!
      [    3.133246] rpmsg_hifi 3003000.msgbox.sunxi,dsp-msgbox.514.258: id:sunxi,dsp-msgbox new channel: 0x202 -> 0x102!
      [    3.144780] rpmsg_hifi 3003000.msgbox.sunxi,dsp-msgbox.514.258: rpmsg hifi[0] client driver is probed
      [    3.156629] NET: Registered protocol family 10
      [    3.163027] Segment Routing with IPv6
      [    3.167298] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
      [    3.174718] NET: Registered protocol family 17
      [    3.179749] can: controller area network core (rev 20170425 abi 9)
      [    3.186811] NET: Registered protocol family 29
      [    3.191831] can: raw protocol (rev 20170425)
      [    3.196591] can: broadcast manager protocol (rev 20170425 t)
      [    3.202939] can: netlink gateway (rev 20190810) max_hops=1
      [    3.209346] Bluetooth: RFCOMM TTY layer initialized
      [    3.214891] Bluetooth: RFCOMM socket layer initialized
      [    3.220644] Bluetooth: RFCOMM ver 1.11
      [    3.225834] Loading compiled-in X.509 certificates
      [    3.233419] HDMI 2.0 driver init start!
      [    3.237714] [DISP] disp_boot_para_parse,line:1172:
      [    3.237718] [DISP] boot_disp:0x104
      [    3.246910] boot_hdmi=false
      [    3.250093] ERROR: pinctrl_get for HDMI2.0 DDC fail
      [    3.256886] [DISP] bsp_disp_set_hdmi_func,line:1340:
      [    3.256890] registered!!
      [    3.265551] HDMI2.0 module init end
      [    3.294388] sunxi-i2c sunxi-i2c2: sunxi-i2c2 supply twi not found, using dummy regulator
      [    3.320955] sunxi-i2c sunxi-i2c2: Bus error
      [    3.325691] sunxi-i2c sunxi-i2c2: engine-mode: bus state: 0x0, isn't idle
      [    3.333256] sunxi-i2c sunxi-i2c2: STOP failed!
      [    3.338242] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x38)
      [    3.345889] pcf857x: probe of 2-0038 failed with error -22
      [    3.352066] sunxi-i2c sunxi-i2c2: probe success
      [    3.361261] debugfs: Directory '2031000.dmic' with parent 'snddmic' already present!
      [    3.371390] sunxi-audio-card 2031060.sounddmic: dmic-hifi <-> 2031000.dmic mapping ok
      [    3.381519] debugfs: Directory '2034000.daudio' with parent 'sndhdmi' already present!
      [    3.392125] sunxi-audio-card 20340a0.sounddaudio2: 20340a4.hdmiaudio <-> 2034000.daudio mapping ok
      [    3.403386] get ehci0-controller wakeup-source is fail.
      [    3.409313] sunxi ehci0-controller don't init wakeup source
      [    3.415578] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xffffffe00094f390, 0x:ffffffd004bf6000, irq_no:2e
      [    3.429093] [sunxi-ehci0]: Not init ehci0
      [    3.434086] get ohci0-controller wakeup-source is fail.
      [    3.440020] sunxi ohci0-controller don't init wakeup source
      [    3.446302] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xffffffe00094fee8
      [    3.456702] [sunxi-ohci0]: Not init ohci0
      [    3.463360] cfg80211: Loading compiled-in X.509 certificates for regulatory database
      [    3.474207] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
      [    3.481792] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
      [    3.491467] clk: Not disabling unused clocks
      [    3.496235] ALSA device list:
      [    3.499538]   #0: audiocodec
      [    3.502871] cfg80211: failed to load regulatory.db
      [    3.508281]   #1: snddmic
      [    3.511266]   #2: sndhdmi
      [    3.514195] alloc_fd: slot 0 not NULL!
      [    3.523274] VFS: Mounted root (squashfs filesystem) readonly on device 179:5.
      [    3.534149] devtmpfs: mounted
      [    3.537619] Freeing unused kernel memory: 184K
      [    3.542696] This architecture does not have kernel memory protection.
      [    3.549894] Run /sbin/init as init process
      [    3.811857] [SNDCODEC][sunxi_check_hs_detect_status][191]:plugin --> switch:3
      [    3.889433] [SNDCODEC][jack_interrupt][370]:KEY tempdata: 17
      [    3.895745] [SNDCODEC][jack_interrupt][436]:tempdata:0x11,Key data err:
      [    4.219882] init: Console is alive
      [    4.224052] init: - watchdog -
      [    4.227598] init: - preinit -
      formating /dev/by-name/UDISK to ext4
      /etc/preinit: line 1: mkfs.ext4: not found
      [    5.358700] mount_root: mounting /dev/root
      [    5.364253] mount_root: loading kmods from internal overlay
      [    5.474169] random: procd: uninitialized urandom read (4 bytes read)
      [    5.500017] block: attempting to load /etc/config/fstab
      [    5.526938] block: extroot: device not present, retrying in 5 seconds
      [    7.150720] hdmi_hpd_sys_config_release
      [    7.160721]
      [    7.160721] insmod_device_driver
      [    7.160721]
      [    7.167892] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
      [   10.594919] block: extroot: cannot find device UDISK
      [   10.612063] procd: - early -
      [   10.615413] procd: - watchdog -
      [   10.671122] random: procd: uninitialized urandom read (4 bytes read)
      [   10.981013] procd: - watchdog -
      [   10.984798] procd: - ubus -
      [   10.988535] procd (1): /proc/116/oom_adj is deprecated, please use /proc/116/oom_score_adj instead.
      [   11.068513] random: ubusd: uninitialized urandom read (4 bytes read)
      [   11.246577] random: ubusd: uninitialized urandom read (4 bytes read)
      [   11.286636] procd: - init -
      [   12.477355] fuse: init (API version 7.31)
      [   12.685716] file system registered
      [   12.772576] configfs-gadget 4100000.udc-controller: failed to start g1: -19
      [   12.837805] usbcore: registered new interface driver uvcvideo
      [   12.882353] USB Video Class driver (1.1.1)
      [   13.101534] read descriptors
      [   13.133479] read strings
      [   13.291513] sunxi_set_cur_vol_work()397 WARN: get power supply failed
      [   13.377959] android_work: sent uevent USB_STATE=CONNECTED
      [   13.414404] configfs-gadget gadget: high-speed config #1: c
      [   13.420803] android_work: sent uevent USB_STATE=CONFIGURED
      [   15.401733] random: fast init done
      [   15.492396] ======== XRADIO WIFI OPEN ========
      [   15.500337] [XRADIO] Driver Label:XR_V02.16.85_P2P_HT40_01.31
      [   15.507499] [XRADIO] Allocated hw_priv @ (____ptrval____)
      [   15.515489] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
      [   15.533721] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
      [   15.739268] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
      [   15.835544] [XRADIO] Detect SDIO card 1
      [   17.920833] sunxi-rfkill soc@3000000:rfkill@0: wlan power off success
      [   18.028171] [XRADIO] Remove SDIO card 1
      [   18.042495] [SBUS_ERR] sdio probe timeout!
      [   18.047060] [XRADIO_ERR] sbus_sdio_init failed
      [   18.053185] xradio_core_init failed (-110)!
      [   18.137002] xt_time: kernel timezone is -0000
      [   18.153490] Error: Driver 'gt9xxnew_ts' is already registered, aborting...
      [   19.388542] ======== XRADIO WIFI OPEN ========
      [   19.394124] [XRADIO] Driver Label:XR_V02.16.85_P2P_HT40_01.31
      [   19.400962] [XRADIO] Allocated hw_priv @ (____ptrval____)
      [   19.410838] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
      [   19.436461] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
      [   19.654877] [XRADIO] Detect SDIO card 1
      [   21.680935] sunxi-rfkill soc@3000000:rfkill@0: wlan power off success
      [   21.788199] [XRADIO] Remove SDIO card 1
      [   21.802525] [SBUS_ERR] sdio probe timeout!
      [   21.807088] [XRADIO_ERR] sbus_sdio_init failed
      [   21.813224] xradio_core_init failed (-110)!
      kmodloader done
      [   24.474555] [SNDCODEC][sunxi_card_hw_params][620]:stream_flag: 0
      [   33.760754] usb1-vbus: disabling
      root@TinaLinux:/#
      root@TinaLinux:/#
        YterAA LV 7 最后由 编辑
        看这一部分:
        时钟基本正常,请问是什么 RGB 屏幕,是否需要 SPI、I2C 初始化?
        也可以尝试这个 LCD 配置
        	lcd_if              = <0>;
        	lcd_x               = <800>;
        	lcd_y               = <480>;
        	lcd_width           = <150>;
        	lcd_height          = <94>;
        	lcd_dclk_freq       = <48>;
        	lcd_pwm_used        = <1>;
        	lcd_pwm_ch          = <7>;
        	lcd_pwm_freq        = <10000>;
        	lcd_pwm_pol         = <1>;
        	lcd_hbp             = <55>;
        	lcd_ht              = <1240>;
        	lcd_hspw            = <20>;
        	lcd_vbp             = <35>;
        	lcd_vt              = <650>;
        	lcd_vspw            = <10>;
        	lcd_lvds_if         = <0>;
        	lcd_lvds_colordepth = <1>;
        	lcd_lvds_mode       = <0>;
        	lcd_frm             = <0>;
        	lcd_gamma_en        = <0>;
        	lcd_cmap_en         = <0>;
        	deu_mode            = <0>;
        	lcdgamma4iep        = <22>;
        	smart_color         = <90>;
        S 2 条回复 最后回复 回复 引用 分享 0
          示波器看下 PCLK/DE/VSYNC/HSYNC 这几组引脚是否正常。
            suncw LV 4 @YterAA 最后由 编辑
            @yteraa
            使用的ST7262,不需要初始化的屏
            使用这些设备树配置后屏幕有显示了,但是屏幕一直都是白、红、绿、蓝、黑纯色在不停的换,期间还伴随这闪屏,怀疑是测试模式,因此去修改了echo X > /sys/class/disp/disp/attr/colorbar,发现只有闪屏的频率发生了变化,其余的没有变化
            请问知道这是什么原因吗?
            &lcd0 {
            	lcd_if              = <0>;
            	lcd_x               = <800>;
            	lcd_y               = <480>;
            	lcd_width           = <800>;
            	lcd_height          = <480>;
            	lcd_pwm_used        = <1>;
            	lcd_pwm_ch          = <7>;
            	lcd_pwm_pol         = <1>;
            	lcd_hbp             = <8>;
            	lcd_ht              = <816>;
            	lcd_hspw            = <4>;
            	lcd_vbp             = <8>;
            	lcd_vt              = <496>;
            	lcd_vspw            = <4>;
            	lcd_lvds_if         = <0>;
            	lcd_frm             = <0>;
            	lcd_gamma_en        = <0>;
            	lcd_cmap_en         = <0>;
            	deu_mode            = <0>;
            	smart_color         = <90>;
              suncw LV 4 @whycan 最后由 编辑
              @whycan
              HS VS没有信号
              应该是使用错了驱动,安装楼上的lcd_driver_name修改后不是黑屏了
                @yteraa
                大佬,求助一下,用了default_lcd驱动后屏幕有显示了,但是显示不正常
                我查了一下显示屏的参数,都是按照手册中配置的,没发现有错误,但是还是显示不正常
                请问有没有什么调试方法或者建议🙏
                Y 1 条回复 最后回复 回复 引用 分享 0
                  YterAA LV 7 @suncw 最后由 编辑
                  @suncw 拍照看看啥样的
                  S 1 条回复 最后回复 回复 引用 分享 0
                    @yteraa
                    这是开机默认的效果
                    这是随便修改一个colorbar后的效果(echo 2 > /sys/class/disp/disp/attr/colorbar)
                      YterAA LV 7 最后由 编辑
                      对照手册检查这部分的参数
                      	lcd_hbp             = <8>;
                      	lcd_ht              = <816>;
                      	lcd_hspw            = <4>;
                      	lcd_vbp             = <8>;
                      	lcd_vt              = <496>;
                      	lcd_vspw            = <4>;
                        @yteraa
                        我对照了一下手册,lcd_hbp和lcd_vbp有点问题,修改后显示屏没有明显变化,还是之前的效果。
                        请问我修改后对照的参数有问题吗?
                        lcd_hbp:hsync back porch(pixel) + hsync plus width(pixel);   =Thbp+Thw = 8+4 = 12
                        lcd_ht: hsync total cycle(pixel)                                                = Th = 816
                        lcd_hspw:hsync plus width(pixel)                                            = Thw = 4
                        lcd_vbp:vsync back porch(line) + vysnc plus width(line)        = Tvbp +Tvw = 8+4 = 12
                        lcd_vt:vysnc total cycle(line)                                                   = Tv = 496
                        lcd_vspw: vysnc plus width(pixel)                                           = Tvw = 4
                        K 1 条回复 最后回复 回复 引用 分享 0
                          @yteraa
                          大佬,现在显示屏一直显示纯色,而且很有规律,请问会不会是进入了什么测试模式?咱们这款CPU有类似的功能吗?
                            @suncw RGB屏幕可能自带测试模式,参数不对就会进入测试模式,colorbar的显示也不对,感觉还是在测试模式
                              @yteraa
                              哦哦哦,这样呀,那我们再查一查配置的参数看看哪里有问题吧
                                lovexulu LV 8 @suncw 最后由 编辑
                                @suncw
                                &lcd0 {
                                lcd_if              = <0>;
                                lcd_x               = <800>;
                                lcd_y               = <480>;
                                lcd_width           = <800>;
                                lcd_height          = <480>;
                                lcd_pwm_used        = <1>;
                                lcd_pwm_ch          = <7>;
                                lcd_pwm_pol         = <1>;
                                lcd_hbp             = <16>;
                                lcd_ht              = <832>;
                                lcd_hspw            = <8>;
                                lcd_vbp             = <10>;
                                lcd_vt              = <500>;
                                lcd_vspw            = <4>;
                                //lcd_lvds_if         = <0>;
                                //lcd_lvds_colordepth = <1>;
                                //lcd_lvds_mode       = <0>;
                                lcd_frm             = <0>;
                                lcd_gamma_en        = <0>;
                                lcd_cmap_en         = <0>;
                                deu_mode            = <0>;
                                smart_color         = <90>;
                                不知道你的原理图是否是输出24bit RGB 如果是的 请将引脚改为 rgb24_pins_a/b
                                按照 你原始的配置数据 dclk !=25 约24.2左右
                                注释掉 lvds相关的参数,一般用不到。
                                  suncw LV 4 @lovexulu 最后由 编辑
                                  @lovexulu
                                  原理图输出18bit RGB (RGB666)
                                  时钟是稍微差了一点,但是也在范围内,我往上调了一点现象还是一样,也是自测模式
                                  lvds是也注释了,也没有效果。。。。
                                  测了一下信号,时钟是正常的,其余的DE/VSYNC/HSYNC都没有信号。。。。
                                    @whycan
                                    大佬,RGB显示屏配置完后,时钟是正常的,其余的DE/VSYNC/HSYNC都没有信号
                                    已经检查了屏幕是参数配置,没发现什么问题
                                    请问有没有什么怀疑点,或者调试方向?求指点🙏
                                      whycan晕哥 LV 9 @suncw 最后由 编辑
                                      @suncw
                                      确认这个屏是 800x480 吗? 有没有厂家提供的手册?怎么看起来像 480x272?
                                        @whycan
                                        确认了一下,是800*480的,相关参数配置也是按照手册里进行的配置,附附件是厂家提供的手册,再麻烦帮忙看一下,多谢
                                        ST7262_V0.6a_202003.pdf
                                        • F
                                          fanchcn LV 3 最后由 编辑
                                          问下楼主这个屏幕有没有调试出来,我这边也在用这个屏幕,现象一样?
                                          • K
                                            koupoo LV 3 @suncw 最后由 编辑
                                            @suncw
                                            从手册的时序图和参数表分析,这些参数设置对的
                                            lcd_hbp           = <8>;
                                            lcd_ht              = <816>;
                                            lcd_hspw         = <4>;
                                            lcd_vbp           = <8>;
                                            lcd_vt               = <496>;
                                            lcd_vspw          = <4>;
                                            芯片规格书中的Thbp(即lcd_hbp)已将包含Thw(即lcd_hspw), 所以lcd_hbp = Thbp = 12
                                            how0723 1 条回复 最后回复 回复 引用 分享 0
                                            • how0723
                                              how0723 LV 5 @koupoo 最后由 编辑
                                              @koupoo bd151cd3-0a57-4e77-8edb-6f4457c481c9-image.png 这样吗?
                                                tinaq LV 2 最后由 编辑
                                                楼主解决了吗,想知道如何在rgb屏幕上打印console终端调试信息
