    [部分已解决] v853 sdk 编译失败:undefined reference to `sunxi_challenge`
    6
    4976
    • duskmoon
      duskmoon LV 2 最后由 duskmoon 编辑
      2022-08-11 UPDATE:
      官方 SDK 使用的 openwrt 版本略旧,无法使用 ubuntu 22.04 进行编译。降级为 ubuntu 20.04 补足依赖后成功编译,并未再遇到此错误。
      buildroot 无法通过编译,可能也与版本有关,之后再研究吧
      目前的docker:https://github.com/duskmoon314/dev-env
      我在尝试搭建一个 docker image 用于编译 sdk
      日常使用 mac,最近配置了一个 manjaro 用于开发,目标在这上面使用
      docker image 基于 ubuntu:22.04,安装依赖如下:
      apt install -y --no-install-recommends \
          git \
          ssh \
          ca-certificates \
          build-essential \
          iproute2 \
          iputils-ping \
          curl \
          wget \
          neovim \
          subversion \
          libncurses5-dev \
          zlib1g-dev \
          gawk \
          flex \
          quilt \
          libssl-dev \
          xsltproc \
          libxml-parser-perl \
          mercurial \
          bzr \
          ecj \
          cvs \
          unzip \
          lib32z1 \
          lib32z1-dev \
          lib32stdc++6 \
          libstdc++6 \
          python3 \
          python-is-python3 \
          xxd \
          # end of list
      将容器运行并绑定 tina-v853-open 目录后,按照 buildroot 步骤进行编译:
      duskmoon@devenv-container:/host$ ./build.sh config
      ========ACTION List: mk_config ;========
      options :
      All available platform:
         0. android
         1. linux
      Choice [linux]:
      All available linux_dev:
         0. bsp
         1. buildroot
         2. tinyos
         3. openwrt
      Choice [buildroot]:
      All available ic:
         0. v853
      Choice [v853]:
      All available board:
         0. vision
      Choice [vision]:
      All available flash:
         0. default
         1. nor
      Choice [default]:
      INFO: Prepare toolchain ...
      INFO: kernel defconfig: generate /host/kernel/linux-4.9/.config by /host/device/config/chips/v853/configs/vision/linux-4.9/config-4.9
      make: Entering directory '/host/kernel/linux-4.9'
      *** Default configuration is based on '../../../../../device/config/chips/v853/configs/vision/linux-4.9/config-4.9'
      # configuration written to .config
      make: Leaving directory '/host/kernel/linux-4.9'
      make: Entering directory '/host/buildroot/buildroot-201902'
        GEN     /host/out/v853/vision/buildroot/buildroot/Makefile
      Config.in.legacy:1769:warning: choice value used outside its choice group
      /host/buildroot/buildroot-201902/configs/sun8iw21p1_longan_defconfig:33:warning: override: reassigning to symbol BR2_ROOTFS_DEVICE_CREATION_DYNAMIC_EUDEV
      /host/buildroot/buildroot-201902/configs/sun8iw21p1_longan_defconfig:33:warning: override: BR2_ROOTFS_DEVICE_CREATION_DYNAMIC_EUDEV changes choice state
      /host/buildroot/buildroot-201902/configs/sun8iw21p1_longan_defconfig:34:warning: override: reassigning to symbol BR2_SYSTEM_BIN_SH_BASH
      /host/buildroot/buildroot-201902/configs/sun8iw21p1_longan_defconfig:34:warning: override: BR2_SYSTEM_BIN_SH_BASH changes choice state
      /host/buildroot/buildroot-201902/configs/sun8iw21p1_longan_defconfig:35:warning: override: reassigning to symbol BR2_TARGET_GENERIC_GETTY_PORT
      /host/buildroot/buildroot-201902/configs/sun8iw21p1_longan_defconfig:36:warning: override: reassigning to symbol BR2_TARGET_GENERIC_GETTY_BAUDRATE_115200
      /host/buildroot/buildroot-201902/configs/sun8iw21p1_longan_defconfig:36:warning: override: BR2_TARGET_GENERIC_GETTY_BAUDRATE_115200 changes choice state
      /host/buildroot/buildroot-201902/configs/sun8iw21p1_longan_defconfig:37:warning: override: reassigning to symbol BR2_ROOTFS_POST_BUILD_SCRIPT
      /host/buildroot/buildroot-201902/configs/sun8iw21p1_longan_defconfig:38:warning: override: reassigning to symbol BR2_PACKAGE_BUSYBOX_SHOW_OTHERS
      # configuration written to /host/out/v853/vision/buildroot/buildroot/.config
      make: Leaving directory '/host/buildroot/buildroot-201902'
      INFO: buildroot defconfig is sun8iw21p1_longan_defconfig
      INFO: clean buildserver
      Usage:
       kill [options] <pid> [...]
      Options:
       <pid> [...]            send signal to every <pid> listed
       -<signal>, -s, --signal <signal>
                              specify the <signal> to be sent
       -q, --queue <value>    integer value to be sent with the signal
       -l, --list=[<signal>]  list all signal names, or convert one to a name
       -L, --table            list all signal names in a nice table
       -h, --help     display this help and exit
       -V, --version  output version information and exit
      For more details see kill(1).
      INFO: prepare_buildserver
      ========ACTION List: build_linuxdev;========
      options :
      INFO: build linuxdev ...
      INFO: chip: sun8iw21p1
      INFO: platform: linux
      INFO: kernel: linux-4.9
      INFO: board: vision
      INFO: output: /host/out/v853/vision/buildroot
      INFO: don't build dtbo ...
      INFO: build arisc
      INFO: build_bootloader: brandy_path= /host/brandy/brandy-2.0
      grep: /host/brandy/brandy-2.0/spl/Makefile: No such file or directory
      build for sun8iw21p1_defconfig ...
      arch/arm/cpu/armv7/spare_head.o:(.data.uboot_spare_head+0x508): undefined reference to `sunxi_challenge'
      make: *** [Makefile:1480: u-boot] Error 1
      ERROR: build brandy Failed
      INFO: build_bootloader failed
      执行命令都不是 root 用户,映射到系统的可以 sudo 的用户的
      openwrt 也是类似的错误
      希望有人帮忙看看我漏了什么 orz
        YterAA LV 7 最后由 编辑
        buildroot不支持 ubuntu:22.04,只有 openwrt支持,buildroot最高支持ubuntu18.04
        duskmoon 1 条回复 最后回复 回复 引用 分享 0
        • duskmoon
          duskmoon LV 2 @YterAA 最后由 编辑
          @yteraa 在 v853 sdk 编译失败:undefined reference to &#x60;sunxi_challenge&#x60; 中说:
          啊这,我换 ubuntu 20.04 试试
          不过 openwrt 也会报 sunxi_challenge 的问题……
          • duskmoon
            duskmoon LV 2 @duskmoon 最后由 duskmoon 编辑
            18.04 和 20.04 也有同样的错误,我觉得问题似乎不在于 ubuntu 版本
              柚木 鉉 LV 9 最后由 YuzukiTsuru 编辑
              docker 的问题,sunxi_challenge是从urandom里出来的一个随机码,Makefile把@删了就可以了
              CLEAN_FILES += board/sunxi/sunxi_challenge.c
              board/sunxi/sunxi_challenge.c:
              	echo "  prepare sunxi_challenge..."
              	dd if=/dev/urandom of=sunxi_challenge bs=128 count=1 > /dev/null 2>&1
              	xxd -c 8 -i sunxi_challenge > board/sunxi/sunxi_challenge.c
              	sed -i '/^unsigned/i __attribute__((__used__))' board/sunxi/sunxi_challenge.c
              	rm sunxi_challenge
              prepare: board/sunxi/sunxi_challenge.c
                limesea LV 2 @YuzukiTsuru 最后由 编辑
