    T113 longan 无法挂载rootfs,ubifs
      as86455011 LV 2 最后由 as86455011 编辑
      SDK是T113 longan
      编译时选 longan auto_nand
      ubifs是自带的buildroot编译的
      这个是t113-longan/device/config/chips/t113/configs/evb1_auto_nand/longan/sys_partition.fex
      [partition_start]
      [partition]
          name         = boot-resource
          size         = 34438
          user_type    = 0x8000
      [partition]
          name         = env
          size         = 2048
          downloadfile = "env.fex"
          user_type    = 0x8000
      [partition]
          name         = env-redund
          size         = 2048
          user_type    = 0x8000
      [partition]
          name         = boot
          size         = 35200
          downloadfile = "boot.fex"
          user_type    = 0x8000
      [partition]
          name         = rootfs
          size         = 65536
          downloadfile = "rootfs-ubifs.fex"
          user_type    = 0x8000
      [partition]
          name         = dsp0
          size         = 2048
          downloadfile = "dsp0.fex"
          user_type    = 0x8000
      [partition]
          name         = private
          size         = 2048
          ;downloadfile = ""
          user_type    = 0x8000
      [partition]
          name         = UDISK
          user_type    = 0x8100
      内核log
      [29]HELLO! BOOT0 is starting!
      [32]BOOT0 commit : 5224261
      [34]set pll start
      [36]fix vccio detect value:0xc0
      [43]periph0 has been enabled
      [46]set pll end
      [48][pmu]: bus read error
      [50]board init ok
      [52]enable_jtag
      [54]ZQ value = 0x30
      [56]get_pmu_exist() = -1
      [58]DRAM BOOT DRIVE INFO: V0.32
      [61]DRAM CLK = 792 MHz
      [63]DRAM Type = 3 (2:DDR2,3:DDR3)
      [67]DRAMC read ODT  off.
      [69]DRAM ODT value: 0x42.
      [72]ddr_efuse_type: 0xa
      [74]mark_id: 0x60
      [76]DRAM SIZE =128 M
      [78]PLL_DDR_CTRL_REG:0xf8004100
      [81]DRAM_CLK_REG:0xc0000000
      [84][TIMING DEBUG] MR2= 0x18
      [91]DRAM simple test OK.
      [94]rtc standby flag is 0x0, super standby flag is 0x0
      [99]dram size =128
      [101]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32
      [107]block from 8 to 32
      [242]Check is correct.
      [244]dma 0x29c4c int is not used yet
      [248]dma 0x29c4c int is free, you do not need to free it again
      [254]Entry_name        = u-boot
      [261]Entry_name        = optee
      [265]Entry_name        = dtb
      [268]Jump to second Boot.
      U-Boot 2018.05-g5b4bafa (Oct 18 2021 - 01:53:36 +0000) Allwinner Technology
      CTRL-A Z for help | 115200 8N1 | NOR | Minicom 2.8 | VT102 | 脱机 | ttyUSB0                                                           [00.324]CPU:   Allwinner Family
      [00.327]Model: sun8iw20
      [00.329]DRAM:  128 MiB
      [00.332]Relocation Offset is: 04ec6000
      [00.359]secure enable bit: 0
      [00.361]smc_tee_inform_fdt failed with: -65526[00.365]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [00.372]gic: sec monitor mode
      [00.375]flash init start
      [00.377]workmode = 0,storage type = 0
      [BCC] 0x4025038 = 0x10000000, [DMA] 0x4025088 = 0x000000e5
      [00.423]sunxi-spinand-phy: not detect any munufacture from id table
      [00.430]sunxi-spinand-phy: get spi-nand Model from fdt fail
      [00.435]sunxi-spinand-phy: get phy info from fdt fail
      defaults:
      mtdids  : nand0=nand
      [00.553]ubi0: attaching mtd4
      [00.779]ubi0: scanning is finished
      [00.788]ubi0: attached mtd4 (name "sys", size 123 MiB)
      [00.793]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
      [00.799]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
      [00.805]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      [00.812]ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
      [00.817]ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128
      [00.824]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
      [00.831]ubi0: available PEBs: 0, total reserved PEBs: 492, PEBs reserved for bad PEB handling: 20
      [00.840]sunxi flash init ok
      [00.842]line:703 init_clocks
      [00.845]drv_disp_init
      [00.860]drv_disp_init finish
      [00.862]boot_gui_init:start
      [00.865]set disp.dev2_output_type fail. using defval=0
      [00.871]boot_gui_init:finish
      [01.052]LCD open finish
      [01.135]bmp_name=bootlogo.bmp size 1152138
      1152138 bytes read in 129 ms (8.5 MiB/s)
      [01.508]Loading Environment from SUNXI_FLASH... OK
      [01.544]Item0 (Map) magic is bad
      [01.550]secure storage read widevine fail with:-1
      [01.557]secure storage read ec_key fail with:-1
      [01.565]secure storage read ec_cert1 fail with:-1
      [01.572]secure storage read ec_cert2 fail with:-1
      [01.580]secure storage read ec_cert3 fail with:-1
      [01.587]secure storage read rsa_key fail with:-1
      [01.594]secure storage read rsa_cert1 fail with:-1
      [01.602]secure storage read rsa_cert2 fail with:-1
      [01.610]secure storage read rsa_cert3 fail with:-1
      [01.614]usb burn from boot
      delay time 0
      weak:otg_phy_config
      [01.625]usb prepare ok
      [01.923]usb sof ok
      [01.925]usb probe ok
      [01.927]usb setup ok
      set address 0x34
      set address 0x34 ok
      set address 0x34
      set address 0x34 ok
      set address 0x34
      set address 0x34 ok
      try to update
      [04.932]do_burn_from_boot usb : have no handshake
      List file under ULI/factory
      [04.965]update bootcmd
      [04.990]change working_fdt 0x44885e70 to 0x44865e70
      [05.007]update dts
      [09.865]no vendor_boot partition is found
      [09.884]Starting kernel ...
      [    0.000000] Linux version 5.4.61 (sysdwa@SYSDWA-LINUX) (arm-linux-gnueabi-gcc (Linaro GCC 5.3-2016.05) 5.3.1 20160412, GNU ld (Lina
      ro_Binutils-2016.05) 2.25.0 Linaro 2016_02) #1 SMP PREEMPT Fri Aug 19 08:36:11 CST 2022
      [    0.000000] cma: Reserved 8 MiB at 0x47800000
      [    0.000000] percpu: Embedded 15 pages/cpu s30464 r8192 d22784 u61440
      [    0.000000] pcpu-alloc: s30464 r8192 d22784 u61440 alloc=15*4096
      [    0.000000] Kernel command line: ubi.mtd=sys earlycon=uart8250,mmio32,0x05000000 clk_ignore_unused initcall_debug=0 console=ttyS3,1
      15200 loglevel=8 root=ubi0_5 rootfstype=ubifs,rw init=/init partitions=mbr@ubi0_0:boot-resource@ubi0_1:env@ubi0_2:env-redund@ubi0_3:bo
      ot@ubi0_4:rootfs@ubi0_5:dsp0@ubi0_6:private@ubi0_7:UDISK@ubi0_8: cma=8M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboo
      t.hardware=sun8iw20p1 boot_type=5 androidboot.boot_type=5 gpt=1 uboot_message=2018.05-g5b4bafa(10/18/2021-01:53:36) disp_reserve=24576
      00,0x44909000 aw-ubi-spinand.ubootblks=24 androidboot.dramsize=128
      [    0.000000] Memory: 99872K/131072K available (6144K kernel code, 387K rwdata, 1936K rodata, 1024K init, 152K bss, 23008K reserved,
      8192K cma-reserved)
      [    0.000000] random: get_random_bytes called from start_kernel+0x254/0x3cc with crng_init=0
      [    0.000019] Switching to timer-based delay loop, resolution 41ns
      [    0.000358] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
      [    0.001043] Console: colour dummy device 80x30
      [    0.001088] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      [    0.001103] pid_max: default: 32768 minimum: 301
      [    0.001876] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.001892] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.004995] CPU: Testing write buffer coherency: ok
      [    0.006245] /cpus/cpu@0 missing clock-frequency property
      [    0.006272] /cpus/cpu@1 missing clock-frequency property
      [    0.006283] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      [    0.008051] Setting up static identity map for 0x40100000 - 0x40100060
      [    0.008366] rcu: Hierarchical SRCU implementation.
      [    0.009539] smp: Bringing up secondary CPUs ...
      [    0.011785] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      [    0.011945] smp: Brought up 1 node, 2 CPUs
      [    0.011963] SMP: Total of 2 processors activated (96.00 BogoMIPS).
      [    0.011970] CPU: All CPU(s) started in SVC mode.
      [    0.014332] devtmpfs: initialized
      [    0.178454] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
      [    0.180799] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.180829] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
      [    0.181363] pinctrl core: initialized pinctrl subsystem
      [    0.188803] NET: Registered protocol family 16
      [    0.191522] DMA: preallocated 256 KiB pool for atomic coherent allocations
      [    0.362824] rtc_ccu: sunxi ccu init OK
      [    0.377175] ccu: sunxi ccu init OK
      [    0.379033] r_ccu: sunxi ccu init OK
      [    0.588362] iommu: Default domain type: Translated
      [    0.589061] sunxi iommu: irq = 24
      [    0.599562] SCSI subsystem initialized
      [    0.601789] usbcore: registered new interface driver usbfs
      [    0.602306] usbcore: registered new interface driver hub
      [    0.603053] usbcore: registered new device driver usb
      [    0.616141] pwm module init!
      [    0.622195] input: sunxi-keyboard as /devices/virtual/input/input0
      [    0.625770] clocksource: Switched to clocksource arch_sys_counter
      [    0.695242] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
      [    0.782052] NET: Registered protocol family 2
      [    0.786110] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
      [    0.786193] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.786245] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
      [    0.786268] TCP: Hash tables configured (established 1024 bind 1024)
      [    0.786706] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    0.786766] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    0.787521] NET: Registered protocol family 1
      [    0.789794] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
      [    0.792008] spi spi0: spi0 supply spi not found, using dummy regulator
      [    0.793271] sunxi_spi_resource_get()2151 - [spi0] SPI MASTER MODE
      [    0.793562] sunxi_spi_resource_get()2189 - Failed to get sample mode
      [    0.793575] sunxi_spi_resource_get()2194 - Failed to get sample delay
      [    0.793585] sunxi_spi_resource_get()2198 - sample_mode:-1431633921 sample_delay:-1431633921
      [    0.793646] sunxi_spi_clk_init()2240 - [spi0] mclk 100000000
      [    0.797561] sunxi_spi_probe()2653 - [spi0]: driver probe succeed, base c8821000, irq 41
      [    0.804580] workingset: timestamp_bits=30 max_order=15 bucket_order=0
      [    0.890809] ntfs: driver 2.1.32 [Flags: R/W].
      [    0.896163] NET: Registered protocol family 38
      [    0.896629] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
      [    0.896645] io scheduler mq-deadline registered
      [    0.896653] io scheduler kyber registered
      [    0.899288] atomic64_test: passed
      [    0.909107] [DISP]disp_module_init
      [    0.911386] disp 5000000.disp: Adding to iommu group 0
      [    0.914021] [DISP] disp_init,line:2386:
      [    0.914027] smooth display screen:0 type:1 mode:4
      [    0.934532] display_fb_request,fb_id:0
      [    0.943751] Freeing logo buffer memory: 2400K
      [    0.947986] disp_al_manager_apply ouput_type:1
      [    0.948763] [DISP]disp_module_init finish
      [    0.949491] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
      [    0.952062] sunxi_sid_init()551 - insmod ok
      [    0.954108] pwm-regulator: supplied by regulator-dummy
      [    0.959614] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
      [    0.960406] uart uart3: get regulator failed
      [    0.960430] uart uart3: uart3 supply uart not found, using dummy regulator
      [    0.962009] uart3: ttyS3 at MMIO 0x2500c00 (irq = 34, base_baud = 1500000) is a SUNXI
      [    0.962044] sw_console_setup()1784 - console setup baud 115200 parity n bits 8, flow n
      [    1.783070] printk: console [ttyS3] enabled
      [    1.791853] misc dump reg init
      [    1.804891] sunxi-spinand: AW SPINand MTD Layer Version: 2.0 20201228
      [    1.812206] sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.10 20200306
      [    1.820248] sunxi-spinand-phy: not detect any munufacture from id table
      [    1.827704] sunxi-spinand-phy: get spi-nand Model from fdt fail
      [    1.834343] sunxi-spinand-phy: get phy info from fdt fail
      [    1.840415] sunxi-spinand-phy: not detect munufacture from fdt
      [    1.847173] sunxi-spinand-phy: detect munufacture from id table: Winbond
      [    1.854693] sunxi-spinand-phy: detect spinand id: ff21aaef ffffffff
      [    1.861749] sunxi-spinand-phy: ========== arch info ==========
      [    1.868347] sunxi-spinand-phy: Model:               W25N01GVZEIG
      [    1.875086] sunxi-spinand-phy: Munufacture:         Winbond
      [    1.881349] sunxi-spinand-phy: DieCntPerChip:       1
      [    1.887024] sunxi-spinand-phy: BlkCntPerDie:        1024
      [    1.892980] sunxi-spinand-phy: PageCntPerBlk:       64
      [    1.898751] sunxi-spinand-phy: SectCntPerPage:      4
      [    1.904415] sunxi-spinand-phy: OobSizePerPage:      64
      [    1.910186] sunxi-spinand-phy: BadBlockFlag:        0x0
      [    1.916056] sunxi-spinand-phy: OperationOpt:        0x7
      [    1.921913] sunxi-spinand-phy: MaxEraseTimes:       65000
      [    1.927976] sunxi-spinand-phy: EccFlag:             0x0
      [    1.933835] sunxi-spinand-phy: EccType:             2
      [    1.939508] sunxi-spinand-phy: EccProtectedType:    3
      [    1.945171] sunxi-spinand-phy: ========================================
      [    1.952597] sunxi-spinand-phy:
      [    1.956131] sunxi-spinand-phy: ========== physical info ==========
      [    1.963062] sunxi-spinand-phy: TotalSize:    128 M
      [    1.968444] sunxi-spinand-phy: SectorSize:   512 B
      [    1.973815] sunxi-spinand-phy: PageSize:     2 K
      [    1.979003] sunxi-spinand-phy: BlockSize:    128 K
      [    1.984375] sunxi-spinand-phy: OOBSize:      64 B
      [    1.989667] sunxi-spinand-phy: ========================================
      [    1.997096] sunxi-spinand-phy:
      [    2.000615] sunxi-spinand-phy: ========== logical info ==========
      [    2.007458] sunxi-spinand-phy: TotalSize:    128 M
      [    2.012829] sunxi-spinand-phy: SectorSize:   512 B
      [    2.018209] sunxi-spinand-phy: PageSize:     4 K
      [    2.023385] sunxi-spinand-phy: BlockSize:    256 K
      [    2.028766] sunxi-spinand-phy: OOBSize:      128 B
      [    2.034136] sunxi-spinand-phy: ========================================
      [    2.041723] sunxi-spinand-phy: block lock register: 0x00
      [    2.047913] sunxi-spinand-phy: feature register: 0x19
      [    2.053681] sunxi-spinand-phy: sunxi physic nand init end
      [    2.061396] Creating 4 MTD partitions on "sunxi_mtd_nand":
      [    2.067643] 0x000000000000-0x000000100000 : "boot0"
      [    2.078654] 0x000000100000-0x000000400000 : "uboot"
      [    2.087897] random: fast init done
      [    2.134973] 0x000000400000-0x000000500000 : "secure_storage"
      [    2.158430] 0x000000500000-0x000008000000 : "sys"
      [    2.632389] random: crng init done
      [    4.046864] libphy: Fixed MDIO Bus: probed
      [    4.054349] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
      [    4.066572] sunxi gmac driver's version: 1.0.0
      [    4.072642] gmac-power0: NULL
      [    4.076029] gmac-power1: NULL
      [    4.079357] gmac-power2: NULL
      [    4.089341] Failed to alloc md5
      [    4.092879] eth0: Use random mac address
      [    4.098173] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [    4.105504] sunxi-ehci: EHCI SUNXI driver
      [    4.110674] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [    4.117727] sunxi-ohci: OHCI SUNXI driver
      [    4.123698] usbcore: registered new interface driver uas
      [    4.130232] usbcore: registered new interface driver usb-storage
      [    4.137370] usbcore: registered new interface driver ums-alauda
      [    4.144275] usbcore: registered new interface driver ums-cypress
      [    4.151331] usbcore: registered new interface driver ums-datafab
      [    4.158377] usbcore: registered new interface driver ums_eneub6250
      [    4.165579] usbcore: registered new interface driver ums-freecom
      [    4.172612] usbcore: registered new interface driver ums-isd200
      [    4.179579] usbcore: registered new interface driver ums-jumpshot
      [    4.186717] usbcore: registered new interface driver ums-karma
      [    4.193522] usbcore: registered new interface driver ums-onetouch
      [    4.200892] usbcore: registered new interface driver ums-realtek
      [    4.207954] usbcore: registered new interface driver ums-sddr09
      [    4.214871] usbcore: registered new interface driver ums-sddr55
      [    4.221815] usbcore: registered new interface driver ums-usbat
      [    4.231445] ts probe start
      [    4.233842] input: 2009c00.rtp as /devices/platform/soc@3000000/2009c00.rtp/input/input1
      [    4.247687] ts probe success
      [    4.248569] sunxi_gpadc_init,2137, success
      [    4.258171] sunxi-rtc 7090000.rtc: errata__fix_alarm_day_reg_default_value(): ALARM0_DAY_REG=0, set it to 1
      [    4.274526] sunxi-rtc 7090000.rtc: registered as rtc0
      [    4.280377] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:00:12 UTC (12)
      [    4.289530] sunxi-rtc 7090000.rtc: sunxi rtc probed
      [    4.295865] i2c /dev entries driver
      [    4.300116] IR NEC protocol handler initialized
      [    4.305204] IR RC5(x/sz) protocol handler initialized
      [    4.312129] sunxi_ir_startup: get ir protocol failed
      [    4.312156] (NULL device *): deviceless supply  not found, using dummy regulator
      [    4.326566] Registered IR keymap rc_map_sunxi
      [    4.332347] rc rc0: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0
      [    4.342216] input: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0/s_cir_rx
      [    4.354200] sunxi cedar version 1.1
      [    4.358785] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
      [    4.365174] VE: sunxi_cedar_probe power-domain init!!!
      [    4.370967] VE: install start!!!
      [    4.370967]
      [    4.377615] VE: cedar-ve the get irq is 42
      [    4.377615]
      [    4.384933] VE: ve_debug_proc_info:711050c9, data:64923f4d, lock:484aed11
      [    4.384933]
      [    4.394251] VE: install end!!!
      [    4.394251]
      [    4.399353] VE: sunxi_cedar_probe
      [    4.406543] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
      [    4.424059] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-05-24 16:10)
      [    4.434198] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
      [    4.440433] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
      [    4.446796] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
      [    4.453243] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
      [    4.459700] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
      [    4.466253] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
      [    4.472797] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
      [    4.479358] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
      [    4.487683] sunxi-mmc 4020000.sdmmc: Got CD GPIO
      [    4.493533] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
      [    4.501104] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    4.512299] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
      [    4.532467] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    4.557540] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
      [    4.565455] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
      [    4.577210] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-05-24 16:10)
      [    4.587346] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
      [    4.593558] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
      [    4.599929] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
      [    4.606389] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
      [    4.612836] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
      [    4.619390] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
      [    4.625944] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
      [    4.632487] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
      [    4.639300] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
      [    4.651250] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    4.662449] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [    4.682614] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    4.706944] sunxi-mmc 4021000.sdmmc: detmode:manually by software
      [    4.716493] usbcore: registered new interface driver usbhid
      [    4.722753] usbhid: USB HID core driver
      [    4.727105] exFAT: Version 1.3.0
      [    4.730747] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    4.746050] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    4.749343] NET: Registered protocol family 10
      [    4.762786] sunxi-mmc 4021000.sdmmc: card claims to support voltages below defined range
      [    4.765892] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    4.777422] Segment Routing with IPv6
      [    4.788835] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
      [    4.805428] NET: Registered protocol family 17
      [    4.810628] NET: Registered protocol family 15
      [    4.816107] Registering SWP/SWPB emulation handler
      [    4.829997] HDMI 2.0 driver init start!
      [    4.834333] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [    4.835948] boot_hdmi=false
      [    4.846066] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [    4.849109] ERROR: can not get hdmi_cts_compatibility
      [    4.861404] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
      [    4.879467] ERROR: pinctrl_get for HDMI2.0 DDC fail
      [    4.885899] mmc1: new high speed SDIO card at address 0001
      [    4.887853] HDMI2.0 module init end
      [    5.014299] sun8iw20-pinctrl 2000000.pinctrl: pin PE13 already requested by 2000000.pinctrl:141; cannot claim for 2502800.twi
      [    5.027074] sun8iw20-pinctrl 2000000.pinctrl: pin-141 (2502800.twi) status -22
      [    5.035182] sun8iw20-pinctrl 2000000.pinctrl: could not request pin 141 (PE13) from group PE13  on device 2000000.pinctrl
      [    5.047511] i2c 2502800.twi: Error applying setting, reverse things back
      [    5.055535] i2c: probe of 2502800.twi failed with error -22
      [    5.067793] get ehci0-controller wakeup-source is fail.
      [    5.074109] sunxi ehci0-controller don't init wakeup source
      [    5.080408] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0b7ebf8, 0x:c8865000, irq_no:38
      [    5.092441] [sunxi-ehci0]: Not init ehci0
      [    5.097852] get ohci0-controller wakeup-source is fail.
      [    5.104220] sunxi ohci0-controller don't init wakeup source
      [    5.110522] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0b7ee88
      [    5.120199] [sunxi-ohci0]: Not init ohci0
      [    5.125573] get ehci1-controller wakeup-source is fail.
      [    5.131876] sunxi ehci1-controller don't init wakeup source
      [    5.138181] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0b7f118, 0x:c886f000, irq_no:3a
      [    5.151594] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
      [    5.166243] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
      [    5.173701] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
      [    5.184347] sunxi-ehci 4200000.ehci1-controller: irq 58, io mem 0x04200000
      [    5.215788] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
      [    5.229717] hub 1-0:1.0: USB hub found
      [    5.234222] hub 1-0:1.0: 1 port detected
      [    5.242806] get ohci1-controller wakeup-source is fail.
      [    5.249171] sunxi ohci1-controller don't init wakeup source
      [    5.255459] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0b7f3a8
      [    5.266619] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
      [    5.280129] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
      [    5.287580] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
      [    5.298190] sunxi-ohci 4200400.ohci1-controller: irq 59, io mem 0x04200400
      [    5.385494] hub 2-0:1.0: USB hub found
      [    5.390096] hub 2-0:1.0: 1 port detected
      [    5.400381] ubi0: attaching mtd3
      [    5.875701] ubi0: scanning is finished
      [    5.923574] ubi0: attached mtd3 (name "sys", size 123 MiB)
      [    5.929813] ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
      [    5.937555] ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
      [    5.945183] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      [    5.953009] ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
      [    5.959760] ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128
      [    5.967886] ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
      [    5.977313] ubi0: available PEBs: 0, total reserved PEBs: 492, PEBs reserved for bad PEB handling: 20
      [    5.987697] ubi0: background thread "ubi_bgt0d" started, PID 942
      [    5.989303] sun8iw20-pinctrl 2000000.pinctrl: pin PB6 already requested by 2500c00.uart; cannot claim for 2000000.pinctrl:38
      [    6.007089] sun8iw20-pinctrl 2000000.pinctrl: pin-38 (2000000.pinctrl:38) status -22
      [    6.015843] ERR: id gpio_request failed
      [    6.023110] clk: Not disabling unused clocks
      [    6.028059] alloc_fd: slot 0 not NULL!
      [    6.037284] UBIFS (ubi0:5): Mounting in unauthenticated mode
      [    6.043657] UBIFS error (ubi0:5 pid 1): ubifs_read_superblock: min. I/O unit mismatch: 2048 in superblock, 4096 real
      [    6.055535] UBIFS error (ubi0:5 pid 1): ubifs_read_superblock: bad superblock, error 1
      [    6.064596]  magic          0x6101831
      [    6.068717]  crc            0xbe1aa07d
      [    6.072920]  node_type      6 (superblock node)
      [    6.078048]  group_type     0 (no node group)
      [    6.082932]  sqnum          3771
      [    6.086577]  len            4096
      [    6.090195]  key_hash       0 (R5)
      [    6.094005]  key_fmt        0 (simple)
      [    6.098237]  flags          0x0
      [    6.101756]  big_lpt        0
      [    6.105079]  space_fixup    0
      [    6.108420]  min_io_size    2048
      [    6.112045]  leb_size       129024
      [    6.115869]  leb_cnt        131
      [    6.119388]  max_leb_cnt    2048
      [    6.123003]  max_bud_bytes  8388608
      [    6.126923]  log_lebs       5
      [    6.130257]  lpt_lebs       2
      [    6.133580]  orph_lebs      1
      [    6.136916]  jhead_cnt      1
      [    6.140239]  fanout         8
      [    6.143562]  lsave_cnt      256
      [    6.147107]  default_compr  1
      [    6.150431]  rp_size        0
      [    6.153754]  rp_uid         0
      [    6.157090]  rp_gid         0
      [    6.160414]  fmt_version    4
      [    6.163747]  time_gran      1000000000
      [    6.167963]  UUID           945D534F-21AA-464F-B9A9-E1F18A5944DD
      [    6.177025] VFS: Cannot open root device "ubi0_5" or unknown-block(0,0): error -19
      [    6.185522] Please append a correct "root=" boot option; here are the available partitions:
      [    6.195069] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
      [    6.204347] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 5.4.61 #1
      [    6.210984] Hardware name: Generic DT based system
      [    6.216378] [<c010e1a8>] (unwind_backtrace) from [<c010a900>] (show_stack+0x10/0x14)
      [    6.225072] [<c010a900>] (show_stack) from [<c05efa78>] (dump_stack+0x7c/0x98)
      [    6.233180] [<c05efa78>] (dump_stack) from [<c01196e4>] (panic+0x100/0x3d4)
      [    6.240998] [<c01196e4>] (panic) from [<c0a012a8>] (mount_block_root+0x288/0x334)
      [    6.249397] [<c0a012a8>] (mount_block_root) from [<c0a0145c>] (prepare_namespace+0x84/0x178)
      [    6.258869] [<c0a0145c>] (prepare_namespace) from [<c0604290>] (kernel_init+0x8/0x10c)
      [    6.267757] [<c0604290>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
      [    6.276249] Exception stack(0xc704dfb0 to 0xc704dff8)
      [    6.281915] dfa0:                                     00000000 00000000 00000000 00000000
      [    6.291091] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
      [    6.300265] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000
      [    6.307692] CPU0: stopping
      [    6.310730] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.4.61 #1
      [    6.317367] Hardware name: Generic DT based system
      [    6.322748] [<c010e1a8>] (unwind_backtrace) from [<c010a900>] (show_stack+0x10/0x14)
      [    6.331440] [<c010a900>] (show_stack) from [<c05efa78>] (dump_stack+0x7c/0x98)
      [    6.339545] [<c05efa78>] (dump_stack) from [<c010c548>] (handle_IPI+0xc0/0x168)
      [    6.347750] [<c010c548>] (handle_IPI) from [<c030d140>] (gic_handle_irq+0x70/0x78)
      [    6.356248] [<c030d140>] (gic_handle_irq) from [<c01021cc>] (__irq_svc+0x6c/0xa8)
      [    6.364641] Exception stack(0xc0b01f40 to 0xc0b01f88)
      [    6.370310] 1f40: 000715e4 c76b9374 00000000 c0114be0 00000001 c0b00000 c0b03be4 c0b03c20
      [    6.379487] 1f60: 00000000 c77ff600 c0a2a0c0 00000000 c0b6b8b0 c0b01f90 c0107ff8 c0107ffc
      [    6.388659] 1f80: 60000113 ffffffff
      [    6.392576] [<c01021cc>] (__irq_svc) from [<c0107ffc>] (arch_cpu_idle+0x2c/0x38)
      [    6.400880] [<c0107ffc>] (arch_cpu_idle) from [<c013e2c0>] (do_idle+0xb8/0x120)
      [    6.409083] [<c013e2c0>] (do_idle) from [<c013e5bc>] (cpu_startup_entry+0x18/0x1c)
      [    6.417582] [<c013e5bc>] (cpu_startup_entry) from [<c0a00c6c>] (start_kernel+0x340/0x3cc)
      [    6.426761] [<c0a00c6c>] (start_kernel) from [<00000000>] (0x0)
      [    6.433417] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
      /t113-longan/device/config/chips/t113/configs/evb1_auto_nand/longan/env.cfg
      #kernel command arguments
      initcall_debug=0
      console=ttyS3,115200
      nand_root=ubi0_5
      mmc_root=/dev/mmcblk0p5
      mtd_name=sys
      rootfstype=ubifs,rw
      init=/init
      loglevel=8
      cma=8M
      mac=
      wifi_mac=
      bt_mac=
      specialstr=
      keybox_list=widevine,ec_key,ec_cert1,ec_cert2,ec_cert3,rsa_key,rsa_cert1,rsa_cert2,rsa_cert3
      dsp0_partition=dsp0
      #set kernel cmdline if boot.img or recovery.img has no cmdline we will use this
      setargs_nand=setenv bootargs ubi.mtd=${mtd_name} earlycon=${earlycon} clk_ignore_unused initcall_debug=${initcall_debug} console=${console} loglevel=${loglevel} root=${nand_root} rootfstype=${rootfstype} init=${init} partitions=${partitions} cma=${cma} snum=${snum} mac_addr=${mac} wifi_mac=${wifi_mac} bt_mac=${bt_mac} specialstr=${specialstr} gpt=1
      setargs_nand_ubi=setenv bootargs ubi.mtd=${mtd_name} earlycon=${earlycon} clk_ignore_unused initcall_debug=${initcall_debug} console=${console} loglevel=${loglevel} root=${nand_root} rootfstype=${rootfstype} init=${init} partitions=${partitions} cma=${cma} snum=${snum} mac_addr=${mac} wifi_mac=${wifi_mac} bt_mac=${bt_mac} specialstr=${specialstr} gpt=1
      setargs_mmc=setenv  bootargs earlycon=${earlycon} clk_ignore_unused initcall_debug=${initcall_debug} console=${console} loglevel=${loglevel} root=${mmc_root}  init=${init} partitions=${partitions} cma=${cma} snum=${snum} mac_addr=${mac} wifi_mac=${wifi_mac} bt_mac=${bt_mac} specialstr=${specialstr} gpt=1
      #nand command syntax: sunxi_flash read address partition_name read_bytes
      #0x4007f800 = 0x40080000(kernel entry) - 0x800(boot.img header 2k)
      boot_dsp0=sunxi_flash read 43000000 ${dsp0_partition};bootr 43000000 0 0
      boot_normal=sunxi_flash read 43000000 boot;bootm 43000000
      boot_recovery=sunxi_flash read 43000000 recovery;bootm 43000000
      boot_fastboot=fastboot
      #uboot system env config
      bootdelay=3
      #default nand boot
      bootcmd=run setargs_nand boot_dsp0 boot_normal
      不知道忽略了什么地方,请大家指点一下
      Z 1 条回复 最后回复 回复 引用 分享 0
        zx2125 LV 2 @as86455011 最后由 编辑
        @as86455011 请问一下最后怎么解决的?
          zx2125 LV 2 @zx2125 最后由 编辑
          @zx2125 问题已解决,需要把设备树中spi-nand节点下的spi-rx-bus-width 和spi-tx-bus-width改成1。
