    有时不能启动
    6388
      Lts52341314 LV 5 最后由 编辑
      有20%的慨率不能启动,都是卡在uboot,提高日志等级后查看打印,基本上是频烦打印[01.505]logical area info: 468 258048 last_lba: 235871时停了
      [52]HELLO! BOOT0 is starting!
      [55]BOOT0 commit : 88480af
      [58]set pll start
      [59]periph0 has been enabled
      [62]set pll end
      [64][pmu]: bus read error
      [66]board init ok
      [68]ZQ value = 0x2f
      [70]get_pmu_exist() = -1
      [72]DRAM BOOT DRIVE INFO: V0.33
      [75]DRAM CLK = 528 MHz
      [77]DRAM Type = 2 (2:DDR2,3:DDR3)
      [80]DRAMC read ODT  off.
      [83]DRAM ODT off.
      [85]ddr_efuse_type: 0xa
      [87]DRAM SIZE =64 M
      [89]dram_tpr4:0x0
      [91]PLL_DDR_CTRL_REG:0xf8002b00
      [94]DRAM_CLK_REG:0xc0000000
      [96][TIMING DEBUG] MR2= 0x0
      [101]DRAM simple test OK.
      [103]dram size =64
      [105]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32
      [110]block from 8 to 32
      [180]Check is correct.
      [182]dma 0x301a8 int is not used yet
      [185]dma 0x301a8 int is free, you do not need to free it again
      [191]Entry_name        = opensbi
      [194]Entry_name        = u-boot
      [198]Entry_name        = dtb
      U-Boot 2018.05-g24521d6-dirty (Aug 22 2022 - 18:22:56 +0800) Allwinner Technology
      [00.211]DRAM:  64 MiB
      [00.213]Relocation Offset is: 01ee7000
      [00.217]secure enable bit: 0
      [00.220]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [00.226]flash init start
      [00.228]workmode = 0,storage type = 0
      [00.232]sunxi-spinand: AW SPINand MTD Layer Version: 1.5 20200407
      [00.238]sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.9 20200306
      [00.247]sunxi-spinand-phy: request spi0 gpio ok
      [00.251]sunxi-spinand-phy: request general tx dma channel ok!
      [00.256]sunxi-spinand-phy: request general rx dma channel ok!
      [00.262]sunxi-spinand-phy: set spic0 clk to 20 Mhz
      [00.266]sunxi-spinand-phy: init spic0 clk ok
      [BCC] 0x4025038 = 0x10000000, [DMA] 0x4025088 = 0x000000e5
      [00.312]sunxi-spinand-phy: not detect any munufacture from id table
      [00.318]sunxi-spinand-phy: get spi-nand Model from fdt fail
      [00.323]sunxi-spinand-phy: get phy info from fdt fail
      [00.328]sunxi-spinand-phy: not detect munufacture from fdt
      [00.333]sunxi-spinand-phy: detect munufacture from id table: Mxic
      [00.339]sunxi-spinand-phy: detect spinand id: ffff12c2 ffffffff
      [00.344]sunxi-spinand-phy: ========== arch info ==========
      [00.350]sunxi-spinand-phy: Model:               MX35LF1GE4AB
      [00.355]sunxi-spinand-phy: Munufacture:         Mxic
      [00.360]sunxi-spinand-phy: DieCntPerChip:       1
      [00.364]sunxi-spinand-phy: BlkCntPerDie:        1024
      [00.369]sunxi-spinand-phy: PageCntPerBlk:       64
      [00.373]sunxi-spinand-phy: SectCntPerPage:      4
      [00.378]sunxi-spinand-phy: OobSizePerPage:      64
      [00.382]sunxi-spinand-phy: BadBlockFlag:        0x1
      [00.387]sunxi-spinand-phy: OperationOpt:        0x7
      [00.391]sunxi-spinand-phy: MaxEraseTimes:       65000
      [00.396]sunxi-spinand-phy: EccFlag:             0x2
      [00.401]sunxi-spinand-phy: EccType:             4
      [00.405]sunxi-spinand-phy: EccProtectedType:    3
      [00.410]sunxi-spinand-phy: ========================================
      [00.416]sunxi-spinand-phy:
      [00.418]sunxi-spinand-phy: ========== physical info ==========
      [00.424]sunxi-spinand-phy: TotalSize:    128 M
      [00.428]sunxi-spinand-phy: SectorSize:   512 B
      [00.432]sunxi-spinand-phy: PageSize:     2 K
      [00.436]sunxi-spinand-phy: BlockSize:    128 K
      [00.440]sunxi-spinand-phy: OOBSize:      64 B
      [00.444]sunxi-spinand-phy: ========================================
      [00.450]sunxi-spinand-phy:
      [00.453]sunxi-spinand-phy: ========== logical info ==========
      [00.458]sunxi-spinand-phy: TotalSize:    128 M
      [00.462]sunxi-spinand-phy: SectorSize:   512 B
      [00.466]sunxi-spinand-phy: PageSize:     4 K
      [00.470]sunxi-spinand-phy: BlockSize:    256 K
      [00.475]sunxi-spinand-phy: OOBSize:      128 B
      [00.479]sunxi-spinand-phy: ========================================
      [00.485]sunxi-spinand-phy: MX35LF1GE4AB reset rx bit width to 1
      [00.491]sunxi-spinand-phy: MX35LF1GE4AB reset tx bit width to 1
      [00.496]sunxi-spinand-phy: set spic0 clk to 100 Mhz
      [00.501]sunxi-spinand-phy: block lock register: 0x00
      [00.506]sunxi-spinand-phy: feature register: 0x11
      [00.510]sunxi-spinand-phy: sunxi physic nand init end
      [00.515]mtdparts: mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,-(sys)
      defaults:
      mtdids  : nand0=nand
      [00.566]MTD info (4)
      [00.568]pagesize: 0x1000
      [00.570]blksize: 0x40000
      [00.572]num  offset     bytes      name
      [00.576]0    0x00000000 0x00100000 boot0
      [00.579]1    0x00100000 0x00300000 uboot
      [00.583]2    0x00400000 0x00100000 secure_storage
      [00.587]3    0x00500000 0x07b00000 sys
      [00.591]ubi attach the last part of mtd device: NO.3
      [00.701]ubi0: attaching mtd4
      [00.877]ubi0: scanning is finished
      [00.885]ubi0: attached mtd4 (name "sys", size 123 MiB)
      [00.890]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
      [00.896]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
      [00.902]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      [00.909]ubi0: good PEBs: 489, bad PEBs: 3, corrupted PEBs: 0
      [00.914]ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128
      [00.921]ubi0: max/mean erase counter: 3/1, WL threshold: 4096, image sequence number: 0
      [00.928]ubi0: available PEBs: 0, total reserved PEBs: 489, PEBs reserved for bad PEB handling: 17
      [00.937]sunxi flash init ok
      [00.939]line:703 init_clocks
      [00.943]init_clocks:finish
      [00.945]drv_disp_init
      [00.954]get flash lcd idx 0
      [00.963]HDMI 2.0 driver init start!
      [00.967]drv_disp_init finish
      [00.970]boot_gui_init:start
      [00.973]set disp.dev2_output_type fail. using defval=0
      [00.978]disp 0, clk: pll(120000000),clk(120000000),dclk(20000000) dsi_rate(120000000)
           clk real:pll(288000000),clk(288000000),dclk(24000000) dsi_rate(0)
      ili9xxx panel init
      ili9xxx panel id 00000000
      [01.138]switch device: sel=0, type=1, mode=4, format=0, bits=0, eotf=4, cs=260
      [01.145]boot_gui_init:finish
      [01.148]logical area info: 468 258048 last_lba: 235871
      [01.159]logical area info: 468 258048 last_lba: 235871
      [01.163]MTD info (4)
      [01.165]pagesize: 0x1000
      [01.167]blksize: 0x40000
      [01.170]num  offset     bytes      name
      [01.173]0    0x00000000 0x00100000 boot0
      [01.177]1    0x00100000 0x00300000 uboot
      [01.181]2    0x00400000 0x00100000 secure_storage
      [01.185]3    0x00500000 0x07b00000 sys
      [01.189]MBR info (unalign):
      [01.191]partno   addr       sects      type       name
      [01.196]0        0x00000000 0x00000800 0x00000001 mbr
      [01.201]1        0x00000800 0x000001f8 0x00008000 boot-resource
      [01.206]2        0x000009f8 0x000001f8 0x00008000 env
      [01.211]3        0x00000bf0 0x000001f8 0x00008000 env-redund
      [01.216]4        0x00000de8 0x00005000 0x00008000 boot
      [01.221]5        0x00005de8 0x0000e600 0x00008000 rootfs
      [01.226]6        0x000143e8 0x00005780 0x00008000 recovery
      [01.231]7        0x00019b68 0x00002800 0x00008000 rootfs_data
      [01.237]8        0x0001c368 0x0001d0a0 0x00000000 UDISK
      [01.242]ubi attach the last part of mtd device: NO.3
      [01.247]MBR info (align):
      [01.249]partno   addr       sects      type       name
      [01.254]0        0x00002800 0x000009d8 0x00000001 mbr
      [01.258]1        0x000031d8 0x000001f8 0x00008000 boot-resource
      [01.264]2        0x000033d0 0x000001f8 0x00008000 env
      [01.269]3        0x000035c8 0x000001f8 0x00008000 env-redund
      [01.274]4        0x000037c0 0x000050b8 0x00008000 boot
      [01.279]5        0x00008878 0x0000e658 0x00008000 rootfs
      [01.284]6        0x00016ed0 0x00005898 0x00008000 recovery
      [01.289]7        0x0001c768 0x00002958 0x00008000 rootfs_data
      [01.295]8        0x0001f0c0 0x0001d0a0 0x00000000 UDISK
      [01.306]logical area info: 468 258048 last_lba: 235871
      [01.317]logical area info: 468 258048 last_lba: 235871
      [01.327]logical area info: 468 258048 last_lba: 235871
      [01.338]logical area info: 468 258048 last_lba: 235871
      [01.349]logical area info: 468 258048 last_lba: 235871
      [01.360]logical area info: 468 258048 last_lba: 235871
      [01.371]logical area info: 468 258048 last_lba: 235871
      [01.381]logical area info: 468 258048 last_lba: 235871
      [01.392]logical area info: 468 258048 last_lba: 235871
      [01.403]logical area info: 468 258048 last_lba: 235871
      [01.414]logical area info: 468 258048 last_lba: 235871
      [01.425]logical area info: 468 258048 last_lba: 235871
      [01.435]logical area info: 468 258048 last_lba: 235871
      [01.446]logical area inf[01.449]LCD open finish
      [01.460]logical area info: 468 258048 last_lba: 235871
      [01.471]logical area info: 468 258048 last_lba: 235871
      [01.482]logical area info: 468 258048 last_lba: 235871
      [01.494]logical area info: 468 258048 last_lba: 235871
        YterAA LV 7 最后由 编辑
        有没有尝试更换一下 SPI NAND 储存器,可能是储存器坏块了
          Lts52341314 LV 5 @YterAA 最后由 编辑
          @yteraa 试过,和demo板上的交换试过,在demo板上始终是好的,在我的板子上就会有问题
          Y whycan 2 条回复 最后回复 回复 引用 分享 0
            YterAA LV 7 @Lts52341314 最后由 编辑
            @lts52341314 芯片换一下看看,如果还有问题那可能是板子设计问题了
              whycan晕哥 LV 9 @Lts52341314 最后由 编辑
              @lts52341314
              遇事不决,先查电源.
                Lts52341314 LV 5 @whycan 最后由 编辑
                @whycan 电压看过和demo板一样,会是电源不稳定吗
                  @lts52341314
                  注意电源波纹,以及峰值电流下电压会不会被拉低。
                    @whycan VCC-IO有一点锯齿,正常吗
                      ① 电源旁边并一个 大电容 + 0.01uF小电容
                      ② 降低SPI 速率到 5Mhz左右
                      先酱紫试一试
                        @whycan 试了加滤波电容,没有好,不过在DC-DC的反馈电阻上并一个小电容好了,现在不能启动的概率变低了
