    编译成功,打包时Dragon execute image.cfg Failed !
      yelong98 LV 7 最后由 xiaowenge 编辑
      Add partion boot.fex BOOT_FEX00000000
      FilePath: boot.fex
      FileLength=375800Add partion rootfs.fex ROOTFS_FEX000000
      FilePath: rootfs.fex
      FileLength=3a0000Add partion usr.fex USR_FEX000000000
      Add partion very usr.fex USR_FEX000000000
      FilePath: usr.fex
      FileLength=1a0000Add partion env_nor.fex ENV_NOR_FEX00000
      Add partion very env_nor.fex ENV_NOR_FEX00000
      FilePath: env_nor.fex
      FileLength=20000Add partion bootlogo.fex BOOTLOGO_FEX0000
      Add partion very bootlogo.fex BOOTLOGO_FEX0000
      FilePath: bootlogo.fex
      FileLength=4b036The file config.fex length = 0
      BuildImg 400
      Dragon execute image.cfg Failed ! ArgCnt = 3, 400
      pack finish
      请问Dragon execute image.cfg Failed ! 这里是什么错误?用的ubuntu18.04
      已经排除了32位程序兼容问题,按照帖子指示安装了对应的支持包,还是一样的错误,可以看到有image.cfg文件存在,说明是dragon处理的问题,有遇到的老铁,指点一下
      R 1 条回复 最后回复 回复 引用 分享 1
        repo sync 检查一下sdk对不对
        • R
          remindA LV 3 @yelong98 最后由 编辑
          @yelong98 解决了吗
