    D1s鸿蒙
      Lts52341314 LV 5 最后由 编辑
      用https://gitee.com/allwinnertech-d1/device_sunxi代码测试了d1s跑鸿蒙,结果运行内存不足
      [32]HELLO! BOOT0 is starting!
      [35]BOOT0 commit : 1f94615
      [37]set pll start
      [39]periph0 has been enabled
      [42]set pll end
      [43][pmu]: bus read error
      [46]board init ok
      [48]ZQ value = 0x2f***********
      [50]get_pmu_exist() = -1
      [53]ddr_efuse_type: 0xa
      [56][AUTO DEBUG] single rank and full DQ!
      [60]ddr_efuse_type: 0xa
      [62][AUTO DEBUG] rank 0 row = 13
      [65][AUTO DEBUG] rank 0 bank = 4
      [68][AUTO DEBUG] rank 0 page size = 2 KB
      [72]DRAM BOOT DRIVE INFO: V0.24
      [75]DRAM CLK = 528 MHz
      [77]DRAM Type = 2 (2:DDR2,3:DDR3)
      [80]DRAMC read ODT  off.
      [83]DRAM ODT off.
      [85]ddr_efuse_type: 0xa
      [87]DRAM SIZE =64 M
      [91]DRAM simple test OK.
      [93]dram size =64
      [95]card no is 0
      [96]sdcard 0 line count 4
      [99][mmc]: mmc driver ver 2021-04-2 16:45
      [108][mmc]: Wrong media type 0x0
      [111][mmc]: ***Try SD card 0***
      [119][mmc]: HSSDR52/SDR25 4 bit
      [122][mmc]: 50000000 Hz
      [125][mmc]: 29544 MB
      [126][mmc]: ***SD/MMC 0 init OK!!!***
      [176]Loading boot-pkg Succeed(index=0).
      [179]Entry_name        = opensbi
      [182]Entry_name        = u-boot
      [186]Entry_name        = dtb
      [189]mmc not para
      [191]Jump to second Boot.
      OpenSBI v0.6
              |_|
      Platform Max HARTs     : 1
      Current Hart           : 0
      Runtime SBI Version    : 0.2
      MIDELEG : 0x0000000000000222
      MEDELEG : 0x000000000000b1ff
      PMP0    : 0x0000000040000000-0
      U-Boot 2018.05-g24521d6-dirty (Sep 06 2022 - 13:24:19 +0800) Allwinner Technology
      [00.257]DRAM:  64 MiB
      [00.259]Relocation Offset is: 01ee7000
      [00.264]secure enable bit: 0
      [00.267]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [00.273]flash init start
      [00.275]workmode = 0,storage type = 1
      [00.278][mmc]: mmc driver ver uboot2018:2021-11-19 15:38:00
      [00.284][mmc]: get sdc_type fail and use default host:tm1.
      [00.290][mmc]: can't find node "mmc0",will add new node
      [00.295][mmc]: fdt err returned <no error>
      [00.299][mmc]: Using default timing para
      [00.302][mmc]: SUNXI SDMMC Controller Version:0x50310
      [00.320][mmc]: card_caps:0x3000000a
      [00.323][mmc]: host_caps:0x3000003f
      [00.326]sunxi flash init ok
      [00.329]line:703 init_clocks
      [00.332]drv_disp_init
      [00.349]drv_disp_init finish
      [00.351]boot_gui_init:start
      [00.354]set disp.dev2_output_type fail. using defval=0
      ili9xxx panel init
      ili9xxx panel id 00000000
      [00.506]boot_gui_init:finish
      [00.522]bmp_name=bootlogo.bmp size 460854
      460854 bytes read in 21 ms (20.9 MiB/s)
      [00.559]Loading Environment from SUNXI_FLASH... OK
      [00.579]out of usb burn from boot: not need burn key
      [00.605]Item0 (Map) magic is bad
      [00.608]the secure storage item0 copy0 magic is bad
      [00.634]Item0 (Map) magic is bad
      [00.637]the secure storage item0 copy1 magic is bad
      [00.642]Item0 (Map) magic is bad
      root_partition is rootfs
      set root to /dev/mmcblk0p5
      [00.655]update part info
      [00.658]update bootcmd
      [00.660]change working_fdt 0x42aa6da0 to 0x42a86da0
      [00.691]update dts
      noncached_alloc(): addr = 0x42ba9080
      noncached_alloc(): addr = 0x42ba90c0
      noncached_alloc(): addr = 0x42ba9100
      noncached_alloc(): addr = 0x42ba9940
      geth_sys_init fail!
      [00.711]Board Net Initialization Failed
      [00.714]No ethernet found.
      [00.827]LCD open finish
      [02.109]no vendor_boot partition is found
      Android's image name: d1-nezha
      Detect comp none
      [02.127]
      Starting kernel ...
      [02.130][mmc]: MMC Device 2 not found
      [02.134][mmc]: mmc 2 not find, so not exit
      [    0.000000] OF: fdt: Ignoring memory range 0x40000000 - 0x40200000
      [    0.000000] Linux version 5.4.61 (lts@lts-VirtualBox) (riscv64-unknown-linux-gnu-gcc (C-SKY RISCV Tools V1.8.4 B20200702) 8.1.0, GNU ld (GNU Binutils) 2.32) #1 PREEMPT Wed Sep 7 20:05:48 CST 2022
      [    0.000000] Zone ranges:
      [    0.000000]   DMA32    [mem 0x0000000040200000-0x0000000043ffffff]
      [    0.000000]   node   0: [mem 0x0000000040200000-0x0000000043ffffff]
      [    0.000000] Initmem setup node 0 [mem 0x0000000040200000-0x0000000043ffffff]
      [    0.000000] On node 0 totalpages: 15872
      [    0.000000]   DMA32 zone: 217 pages used for memmap
      [    0.000000]   DMA32 zone: 15872 pages, LIFO batch:3
      [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 15655
      [    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x02500400 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p5 rw init=/init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:dsp0@mmcblk0p6:recovery@mmcblk0p7:UDISK@mmcblk0p8 cma=0M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.hardware=sun20iw1p1 boot_type=1 androidboot.boot_type=1 gpt=1 uboot_message=2018.05-g24521d6-dirty(09/06/2022-13:24:19) mbr_offse
      [    0.000000] Dentry cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
      [    0.000000] Inode-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
      [    0.000000] Memory: 51580K/63488K available (5732K kernel code, 649K rwdata, 2033K rodata, 188K init, 272K bss, 11908K reserved, 0K cma-reserved)
      [    0.000007] sched_clock: 64 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
      [    0.000025] riscv_timer_clockevent depends on broadcast, but no broadcast function available
      [    0.000360] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
      [    0.001021] Console: colour dummy device 80x25
      [    0.001066] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      [    0.001087] pid_max: default: 32768 minimum: 301
      [    0.001272] Mount-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
      [    0.001295] Mountpoint-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
      [    0.003314] ASID allocator initialised with 65536 entries
      [    0.003514] rcu: Hierarchical SRCU implementation.
      [    0.004248] devtmpfs: initialized
      [    0.019298] random: get_random_u32 called from bucket_table_alloc.isra.31+0x4e/0x15e with crng_init=0
      [    0.020403] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.020436] futex hash table entries: 256 (order: 0, 6144 bytes, linear)
      [    0.020607] pinctrl core: initialized pinctrl subsystem
      [    0.022086] NET: Registered protocol family 16
      [    0.022970] DMA: preallocated 256 KiB pool for atomic allocations
      [    0.023796] cpuidle: using governor menu
      [    0.070039] rtc_ccu: sunxi ccu init OK
      [    0.078344] clock: sunxi ccu init OK
      [    0.079479] clock: sunxi ccu init OK
      [    0.115131] iommu: Default domain type: Translated
      [    0.115335] sunxi iommu: irq = 4
      [    0.116589] SCSI subsystem initialized
      [    0.116956] usbcore: registered new interface driver usbfs
      [    0.117046] usbcore: registered new interface driver hub
      [    0.117162] usbcore: registered new device driver usb
      [    0.117348] mc: Linux media interface: v0.10
      [    0.117423] videodev: Linux video capture interface: v2.00
      [    0.118629] sunxi-msgbox-amp 3003000.msgbox: invalid resource
      [    0.119343] Advanced Linux Sound Architecture Driver Initialized.
      [    0.119993] pwm module init!
      [    0.122770] clocksource: Switched to clocksource riscv_clocksource
      [    0.135744] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
      [    0.154036] thermal_sys: Registered thermal governor 'step_wise'
      [    0.154042] thermal_sys: Registered thermal governor 'user_space'
      [    0.154625] NET: Registered protocol family 2
      [    0.155527] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
      [    0.155571] TCP established hash table entries: 512 (order: 0, 4096 bytes, linear)
      [    0.155590] TCP bind hash table entries: 512 (order: 0, 4096 bytes, linear)
      [    0.155605] TCP: Hash tables configured (established 512 bind 512)
      [    0.155789] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    0.155837] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    0.156095] NET: Registered protocol family 1
      [    0.158902] Initialise system trusted keyrings
      [    0.159182] workingset: timestamp_bits=62 max_order=14 bucket_order=0
      [    0.166902] squashfs: version 4.0 (2009/01/31) Phillip Lougher
      [    0.187777] Key type asymmetric registered
      [    0.187796] Asymmetric key parser 'x509' registered
      [    0.187890] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
      [    0.187904] io scheduler mq-deadline registered
      [    0.187914] io scheduler kyber registered
      [    0.187936] atomic64_test: passed
      [    0.189313] [DISP]disp_module_init
      [    0.190000] disp 5000000.disp: Adding to iommu group 0
      [    0.190746] [DISP] disp_init,line:2385:
      [    0.190752] smooth display screen:0 type:1 mode:4
      [    0.234090] [DISP] disp_init_hdmi,line:1047:
      [    0.234095] dont support hdmi
      [    0.234518] display_fb_request,fb_id:0
      [    0.242692] disp_al_manager_apply ouput_type:1
      [    0.242930] [DISP] lcd_clk_config,line:731:
      [    0.242944] disp 0, clk: pll(120000000),clk(120000000),dclk(20000000) dsi_rate(120000000)
      [    0.242944]      clk real:pll(288000000),clk(288000000),dclk(48000000) dsi_rate(0)
      [    0.243403] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
      [    0.244460] [DISP]disp_module_init finish
      [    0.245407] sunxi_sid_init()506 - insmod ok
      [    0.246037] pwm-regulator: supplied by regulator-dummy
      [    0.254611] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
      [    0.255097] uart uart1: get regulator failed
      [    0.255128] uart uart1: uart1 supply uart not found, using dummy regulator
      [    0.255559] uart1: ttyS0 at MMIO 0x2500400 (irq = 19, base_baud = 1500000) is a SUNXI
      [    0.255592] sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n
      [    0.976944] printk: console [ttyS0] enabled
      [    0.982449] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
      [    0.993934] uart uart3: get regulator failed
      [    0.998718] uart uart3: uart3 supply uart not found, using dummy regulator
      [    1.006814] uart3: ttyS1 at MMIO 0x2500c00 (irq = 21, base_baud = 1500000) is a SUNXI
      [    1.016123] sun8iw20-pinctrl 2000000.pinctrl: unsupported function uart2 on pin PE6
      [    1.024740] sun8iw20-pinctrl 2000000.pinctrl: unsupported function uart2 on pin PE7
      [    1.033701] uart uart4: get regulator failed
      [    1.038484] uart uart4: uart4 supply uart not found, using dummy regulator
      [    1.046673] sun8iw20-pinctrl 2000000.pinctrl: unsupported function uart2 on pin PE6
      [    1.055345] sun8iw20-pinctrl 2000000.pinctrl: unsupported function uart2 on pin PE7
      [    1.064017] sw_uart_select_gpio_state()1255 - UART4 pinctrl_lookup_state(default) failed! return ffffffffffffffed
      [    1.075616] uart4: ttyS2 at MMIO 0x2501000 (irq = 22, base_baud = 1500000) is a SUNXI
      [    1.084946] sun8iw20-pinctrl 2000000.pinctrl: unsupported function uart2 on pin PE6
      [    1.093566] sun8iw20-pinctrl 2000000.pinctrl: unsupported function uart2 on pin PE7
      [    1.102475] uart uart5: get regulator failed
      [    1.107312] uart uart5: uart5 supply uart not found, using dummy regulator
      [    1.115414] sun8iw20-pinctrl 2000000.pinctrl: unsupported function uart2 on pin PE6
      [    1.124028] sun8iw20-pinctrl 2000000.pinctrl: unsupported function uart2 on pin PE7
      [    1.132658] sw_uart_select_gpio_state()1255 - UART5 pinctrl_lookup_state(default) failed! return ffffffffffffffed
      [    1.144252] uart5: ttyS3 at MMIO 0x2501400 (irq = 23, base_baud = 1500000) is a SUNXI
      [    1.154282] misc dump reg init
      [    1.158628] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
      [    1.165892] sunxi-rfkill soc@3000000:rfkill@0: devm_pinctrl_get() failed!
      [    1.173511] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
      [    1.180801] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
      [    1.188221] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
      [    1.194764] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
      [    1.201677] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
      [    1.209410] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=131 assert=1
      [    1.217283] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
      [    1.225423] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
      [    1.233125] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
      [    1.239853] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
      [    1.247482] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=210 assert=0
      [    1.255675] [ADDR_MGT] addr_mgt_probe: module version: v1.0.9
      [    1.263444] [ADDR_MGT] addr_mgt_probe: success.
      [    1.269921] libphy: Fixed MDIO Bus: probed
      [    1.274959] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [    1.282241] sunxi-ehci: EHCI SUNXI driver
      [    1.287372] get ehci1-controller wakeup-source is fail.
      [    1.293410] sunxi ehci1-controller don't init wakeup source
      [    1.299638] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xffffffe000893ce0, 0x:ffffffd004079000, irq_no:31
      [    1.313194] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply drvvbus not found, using dummy regulator
      [    1.325803] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
      [    1.333088] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
      [    1.343009] sunxi-ehci 4200000.ehci1-controller: irq 49, io mem 0x04200000
      [    1.372822] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
      [    1.381745] hub 1-0:1.0: USB hub found
      [    1.386081] hub 1-0:1.0: 1 port detected
      [    1.391378] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [    1.398401] sunxi-ohci: OHCI SUNXI driver
      [    1.403571] get ohci1-controller wakeup-source is fail.
      [    1.409524] sunxi ohci1-controller don't init wakeup source
      [    1.415802] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xffffffe000894820
      [    1.426258] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply drvvbus not found, using dummy regulator
      [    1.438882] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
      [    1.446178] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
      [    1.456056] sunxi-ohci 4200400.ohci1-controller: irq 50, io mem 0x04200400
      [    1.537862] hub 2-0:1.0: USB hub found
      [    1.542109] hub 2-0:1.0: 1 port detected
      [    1.547760] usbcore: registered new interface driver uas
      [    1.553973] usbcore: registered new interface driver usb-storage
      [    1.560755] usbcore: registered new interface driver ums-alauda
      [    1.567559] usbcore: registered new interface driver ums-cypress
      [    1.574396] usbcore: registered new interface driver ums-datafab
      [    1.581167] usbcore: registered new interface driver ums_eneub6250
      [    1.588199] usbcore: registered new interface driver ums-freecom
      [    1.595031] usbcore: registered new interface driver ums-isd200
      [    1.601701] usbcore: registered new interface driver ums-jumpshot
      [    1.608627] usbcore: registered new interface driver ums-karma
      [    1.615341] usbcore: registered new interface driver ums-onetouch
      [    1.622239] usbcore: registered new interface driver ums-realtek
      [    1.629076] usbcore: registered new interface driver ums-sddr09
      [    1.635808] usbcore: registered new interface driver ums-sddr55
      [    1.642482] usbcore: registered new interface driver ums-usbat
      [    1.649860] sunxi_gpadc_init,1968, success
      [    1.656904] sunxi-rtc 7090000.rtc: registered as rtc0
      [    1.662668] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:31:00 UTC (1860)
      [    1.671866] sunxi-rtc 7090000.rtc: sunxi rtc probed
      [    1.677751] i2c /dev entries driver
      [    1.681754] IR NEC protocol handler initialized
      [    1.687583] sunxi cedar version 1.1
      [    1.691770] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
      [    1.698079] VE: install start!!!
      [    1.698079]
      [    1.703666] VE: cedar-ve the get irq is 6
      [    1.703666]
      [    1.710055] VE: ve_debug_proc_info:(____ptrval____), data:(____ptrval____), lock:(____ptrval____)
      [    1.710055]
      [    1.721656] VE: install end!!!
      [    1.721656]
      [    1.728220] sunxi-wdt 6011000.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
      [    1.740351] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.19 2021-03-24 19:50)
      [    1.750386] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
      [    1.756615] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
      [    1.762963] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
      [    1.769369] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
      [    1.775800] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
      [    1.782303] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
      [    1.788834] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
      [    1.795364] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
      [    1.802404] sunxi-mmc 4020000.sdmmc: Got CD GPIO
      [    1.807820] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
      [    1.814498] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.825656] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
      [    1.845810] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.870261] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
      [    1.875994] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.888301] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.19 2021-03-24 19:50)
      [    1.898503] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
      [    1.904770] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
      [    1.911139] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
      [    1.917608] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.929190] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
      [    1.935634] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
      [    1.942138] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
      [    1.948785] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
      [    1.955364] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
      [    1.961945] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
      [    1.971021] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.983198] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.994531] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [    2.003841] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.015441] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.039769] sunxi-mmc 4021000.sdmmc: detmode:manually by software
      [    2.047655] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [    2.055063] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
      [    2.066066] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [    2.072992] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.085014] sunxi_led_probe()1715 - start
      [    2.089697] sunxi_get_str_of_property()1560 - failed to get the string of propname led_regulator!
      [    2.099738] sunxi_register_led_classdev()1448 - led_classdev start
      [    2.108055] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.119698] mmc0: host does not support reading read-only switch, assuming write-enable
      [    2.132445] sunxi_led_probe()1820 - finish
      [    2.137785] usbcore: registered new interface driver usbhid
      [    2.144125] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [    2.155734] usbhid: USB HID core driver
      [    2.160154] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [    2.171813] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    2.179458] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    2.187059] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    2.194666] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    2.201411] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    2.212733] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
      [    2.224808] usbcore: registered new interface driver snd-usb-audio
      [    2.235146] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
      [    2.246314] mmc0: new high speed SDHC card at address 1234
      [    2.253948] mmcblk0: mmc0:1234 SA32G 28.9 GiB
      [    2.260475] sunxi-daudio 2034000.daudio: regulator missing or invalid
      [    2.271976] [AUDIOCODEC][sunxi_codec_parse_params][2094]:digital_vol:0, lineout_vol:26, mic1gain:19, mic2gain:19 pa_msleep:120, pa_level:1, pa_pwr_level:1
      [    2.271976]
      [    2.272189]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
      [    2.294211] [AUDIOCODEC][sunxi_codec_parse_params][2130]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
      [    2.305642] [AUDIOCODEC][sunxi_internal_codec_probe][2266]:codec probe finished
      [    2.318432] sid_rd_ver_reg()254 - ver >= 4, soc ver:5
      [    2.324219] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
      [    2.334063] [SNDCODEC][sunxi_card_init][583]:card init finished
      [    2.343280] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
      [    2.354762] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input0
      [    2.367075] [SNDCODEC][sunxi_card_dev_probe][832]:register card finished
      [    2.375463] sunxi-rpaf-dsp soc@3000000:rpaf-dsp@203034c: register device finished!
      [    2.384032] sunxi-rpaf-dsp soc@3000000:rpaf-dsp@203034c: [rpaf_dsp0] probe finished!
      [    2.393185] rpmsg_hifi 3003000.msgbox.sunxi,dsp-msgbox.514.258: id:sunxi,dsp-msgbox new channel: 0x202 -> 0x102!
      [    2.404807] rpmsg_hifi 3003000.msgbox.sunxi,dsp-msgbox.514.258: rpmsg hifi[0] client driver is probed
      [    2.416802] NET: Registered protocol family 10
      [    2.423276] Segment Routing with IPv6
      [    2.427553] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
      [    2.435168] NET: Registered protocol family 17
      [    2.441109] Loading compiled-in X.509 certificates
      [    2.449424] HDMI2.0 module init end
      [    2.481545] twi twi1: twi1 supply twi not found, using dummy regulator
      [    2.496970] pcf857x 1-0020: probed
      [    2.506744] sunxi_i2c_probe()2262 - [i2c1] probe success
      [    2.517892] debugfs: Directory '2031000.dmic' with parent 'snddmic' already present!
      [    2.528324] sunxi-audio-card 2031060.sounddmic: dmic-hifi <-> 2031000.dmic mapping ok
      [    2.538641] sunxi-audio-card 20340a0.sounddaudio2: use dummy codec for simple card.
      [    2.547586] debugfs: Directory '2034000.daudio' with parent 'snddaudio2' already present!
      [    2.558555] sunxi-audio-card 20340a0.sounddaudio2: snd-soc-dummy-dai <-> 2034000.daudio mapping ok
      [    2.570069] get ehci0-controller wakeup-source is fail.
      [    2.576073] sunxi ehci0-controller don't init wakeup source
      [    2.582297] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xffffffe000893920, 0x:ffffffd00491a000, irq_no:2e
      [    2.595813] [sunxi-ehci0]: Not init ehci0
      [    2.600871] get ohci0-controller wakeup-source is fail.
      [    2.606881] sunxi ohci0-controller don't init wakeup source
      [    2.613145] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xffffffe000894460
      [    2.623550] [sunxi-ohci0]: Not init ohci0
      [    2.629174] get id is fail, -84
      [    2.633265] ft5x06 driver init
      [    2.636821] get ctp_power is fail, -22
      [    2.641040] get ctp_power_ldo_vol is fail, -22
      [    2.646063] sunxi_ctp_startup: ctp_power_io is invalid.
      [    2.651940] get ctp_gesture_wakeup fail, no gesture wakeup
      [    2.658116] i2c 1-0038: 1-0038 supply ctp not found, using dummy regulator
      [    2.666106] info.ctp_used:1
      [    2.669222] info.twi_id:1
      [    2.672134] info.screen_max_x:320
      [    2.675877] info.screen_max_y:480
      [    2.679568] info.revert_x_flag:1
      [    2.683186] info.revert_y_flag:0
      [    2.686780] info.exchange_x_y_flag:1
      [    2.690759] info.irq_gpio_number:38
      [    2.694667] info.wakeup_gpio_number:33
      [    2.699180] ft5x06 1-0038: probe for ft5x06 i2c
      [    2.706347] input: generic ft5x06 (11) as /devices/platform/soc@3000000/twi1/i2c-1/1-0038/input/input1
      [    2.717230] ft5x06 1-0038: ft5x06 initialized in irq IRQF_TRIGGER_FALLING
      [    2.726172] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
      [    2.735913] clk: Not disabling unused clocks
      [    2.740686] ALSA device list:
      [    2.744079] cfg80211: failed to load regulatory.db
      [    2.749475]   #0: audiocodec
      [    2.752686]   #1: snddmic
      [    2.755688]   #2: snddaudio2
      [    2.758916] alloc_fd: slot 0 not NULL!
      [    2.769396] VFS: Mounted root (squashfs filesystem) readonly on device 179:5.
      [    2.781305] devtmpfs: mounted
      [    2.784965] Freeing unused kernel memory: 188K
      [    2.789922] This architecture does not have kernel memory protection.
      [    2.797230] Run /init as init process
      [    3.052075] [SNDCODEC][sunxi_check_hs_detect_status][191]:plugin --> switch:1
      [    3.063368] [pid=1][device.c:59][Init][ERROR] Mount selinuxfs failed. No such file or directory
      [    3.115203] [pid=1][param_service.c:82][Init][INFO] LoadDefaultParams proterty success /system/etc/ohos.para
      [    3.128664] [pid=1][trigger_manager.c:241][Init][ERROR] Command array size must positive load_persist_props_action
      [    3.140366] [pid=1][trigger_manager.c:241][Init][ERROR] Command array size must positive firmware_mounts_complete
      [    3.152010] [pid=1][trigger_manager.c:241][Init][ERROR] Command array size must positive early-fs
      [    3.162087] [pid=1][trigger_manager.c:241][Init][ERROR] Command array size must positive late-fs
      [    3.171995] [pid=1][trigger_manager.c:241][Init][ERROR] Command array size must positive post-fs-data
      [    3.182434] [pid=1][trigger_manager.c:241][Init][ERROR] Command array size must positive param:sys.sysctl.tcp_def_init_rwnd=*
      [    3.195744] [pid=1][init_read_cfg.c:110][Init][INFO] ReadCfgs :/system/etc/init/accountmgr.cfg from /system/etc/init success.
      [    3.209192] [pid=1][init_read_cfg.c:110][Init][INFO] ReadCfgs :/system/etc/init/appspawn.cfg from /system/etc/init success.
      [    3.222296] [pid=1][init_read_cfg.c:110][Init][INFO] ReadCfgs :/system/etc/init/audio_policy.cfg from /system/etc/init success.
      [    3.235904] [pid=1][init_read_cfg.c:110][Init][INFO] ReadCfgs :/system/etc/init/bytrace.cfg from /system/etc/init success.
      [    3.249074] [pid=1][init_service_manager.c:680][Init][INFO] This config does not contain service array.
      [    3.260386] [pid=1][init_read_cfg.c:110][Init][INFO] ReadCfgs :/system/etc/init/camera_service.cfg from /system/etc/init success.
      [    3.274193] [pid=1][init_read_cfg.c:110][Init][INFO] ReadCfgs :/system/etc/init/deviceauth_service.cfg from /system/etc/init success.
      [    3.288376] [pid=1][init_read_cfg.c:110][Init][INFO] ReadCfgs :/system/etc/init/distributed_data.cfg from /system/etc/init success.
      [    3.302597] [pid=1][init_read_cfg.c:110][Init][INFO] ReadCfgs :/system/etc/init/distributedpermission_service.cfg from /system/etc/init success.
      [    3.317765] [pid=1][init_read_cfg.c:110][Init][INFO] ReadCfgs :/system/etc/init/distributedsched.cfg from /system/etc/init success.
      [    3.331748] [pid=1][init_read_cfg.c:110][Init][INFO] ReadCfgs :/system/etc/init/faultloggerd64.cfg from /system/etc/init success.
      [    3.345559] [pid=1][init_read_cfg.c:110][Init][INFO] ReadCfgs :/system/etc/init/foundation.cfg from /system/etc/init success.
      [    3.359426] [pid=1][init_read_cfg.c:110][Init][INFO] ReadCfgs :/system/etc/init/graphic.cfg from /system/etc/init success.
      [    3.372326] [pid=1][init_read_cfg.c:110][Init][INFO] ReadCfgs :/system/etc/init/hdf_devmgr.cfg from /system/etc/init success.
      [    3.385618] [pid=1][init_read_cfg.c:110][Init][INFO] ReadCfgs :/system/etc/init/hdf_peripheral.cfg from /system/etc/init success.
      [    3.399064] [pid=1][init_service_manager.c:680][Init][INFO] This config does not contain service array.
      [    3.409950] [pid=1][init_read_cfg.c:110][Init][INFO] ReadCfgs :/system/etc/init/hilogd.cfg from /system/etc/init success.
      [    3.423675] [pid=1][init_read_cfg.c:110][Init][INFO] ReadCfgs :/system/etc/init/hiview.cfg from /system/etc/init success.
      [    3.437051] [pid=1][init_read_cfg.c:110][Init][INFO] ReadCfgs :/system/etc/init/huks_service.cfg from /system/etc/init success.
      [    3.450896] [pid=1][init_read_cfg.c:110][Init][INFO] ReadCfgs :/system/etc/init/inputmethodservice.cfg from /system/etc/init success.
      [    3.465174] [pid=1][init_read_cfg.c:110][Init][INFO] ReadCfgs :/system/etc/init/installs.cfg from /system/etc/init success.
      [    3.478335] [pid=1][init_read_cfg.c:110][Init][INFO] ReadCfgs :/system/etc/init/lmks.cfg from /system/etc/init success.
      [    3.491173] [pid=1][init_read_cfg.c:110][Init][INFO] ReadCfgs :/system/etc/init/media_service.cfg from /system/etc/init success.
      [    3.504878] [pid=1][init_read_cfg.c:110][Init][INFO] ReadCfgs :/system/etc/init/medialibrary_service.cfg from /system/etc/init success.
      [    3.518968] [pid=1][init_read_cfg.c:110][Init][INFO] ReadCfgs :/system/etc/init/pulseaudio.cfg from /system/etc/init success.
      [    3.532610] [pid=1][init_read_cfg.c:110][Init][INFO] ReadCfgs :/system/etc/init/samgr_L2.cfg from /system/etc/init success.
      [    3.545770] [pid=1][init_read_cfg.c:110][Init][INFO] ReadCfgs :/system/etc/init/softbus_server.cfg from /system/etc/init success.
      [    3.559564] [pid=1][init_read_cfg.c:110][Init][INFO] ReadCfgs :/system/etc/init/telephony.cfg from /system/etc/init success.
      [    3.573131] [pid=1][init_read_cfg.c:110][Init][INFO] ReadCfgs :/system/etc/init/timeservice.cfg from /system/etc/init success.
      [    3.586662] [pid=1][init_read_cfg.c:110][Init][INFO] ReadCfgs :/system/etc/init/weston.cfg from /system/etc/init success.
      [    3.600753] [pid=1][init_read_cfg.c:110][Init][INFO] ReadCfgs :/system/etc/init/wifi_hal_service.cfg from /system/etc/init success.
      [    3.614797] [pid=1][init_read_cfg.c:110][Init][INFO] ReadCfgs :/system/etc/init/wifi_standard.cfg from /system/etc/init success.
      [    3.628702] [pid=1][init_read_cfg.c:132][Init][INFO] Parse init config file done.
      [    3.637584] [pid=1][main.c:110][Init][INFO] main, entering wait.
      [    3.644463] [pid=1][trigger_processor.c:52][Init][INFO] Waiting to exec trigger pre-init
      [    3.653594] [pid=1][param_service.c:242][Init][INFO] StartParamService.
      [    3.661404] [pid=1][trigger_processor.c:52][Init][INFO] Waiting to exec trigger init
      [    3.670295] [pid=1][trigger_manager.c:267][Init][INFO] ExecuteTrigger trigger pre-init
      [    3.679291] [pid=1][trigger_processor.c:52][Init][INFO] Waiting to exec trigger post-init
      [    3.689762] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.ueventd value: running
      [    3.701656] [pid=68][init_service.c:200][Init][INFO] service->name is ueventd
      [    3.710272] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.ueventd success
      [    3.723930] [pid=1][trigger_processor.c:75][Init][INFO] ExecuteQueueWork 1
      [    3.764901] [pid=1][trigger_manager.c:267][Init][INFO] ExecuteTrigger trigger init
      [    3.776259] [pid=1][init_cmds.c:875][Init][ERROR] DoWrite: write to file /proc/sys/net/ipv4/ping_group_range failed: 22
      [    3.804636] [pid=1][init_cmds.c:664][Init][ERROR] DoMount, failed for cgroup none /dev/memcg memory, err 19.
      [    3.823526] [pid=1][init_cmds.c:441][Init][ERROR] DoChown, failed for system system /dev/memcg/tasks, err 2.
      [    3.853208] [pid=1][init_cmds.c:441][Init][ERROR] DoChown, failed for system system /dev/memcg/memory.oom_control, err 2.
      [    3.873218] [pid=1][init_cmds.c:441][Init][ERROR] DoChown, failed for system system /dev/memcg/cgroup.event_control, err 2.
      [    3.903284] [pid=1][init_cmds.c:441][Init][ERROR] DoChown, failed for system system /dev/memcg/memory.pressure_level, err 2.
      [    3.923067] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0755 /dev/memcg/tasks, err 2.
      [    3.943093] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0755 /dev/memcg/memory.oom_control, err 2.
      [    3.973022] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0755 /dev/memcg/cgroup.event_control, err 2.
      [    3.993018] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0755 /dev/memcg/memory.pressure_level, err 2.
      [    4.023140] [pid=1][init_cmds.c:664][Init][ERROR] DoMount, failed for cgroup none /dev/cpuset cpuset, err 19.
      [    4.043620] [pid=1][init_cmds.c:441][Init][ERROR] DoChown, failed for system system /dev/cpuset/tasks, err 2.
      [    4.063442] [pid=1][init_cmds.c:441][Init][ERROR] DoChown, failed for system system /dev/cpuset/background/tasks, err 2.
      [    4.093180] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0755 /dev/cpuset/tasks, err 2.
      [    4.113063] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0755 /dev/cpuset/background/tasks, err 2.
      [    4.133638] [pid=1][init_cmds.c:664][Init][ERROR] DoMount, failed for cgroup none /dev/cpuctl cpu, err 19.
      [    4.153619] [pid=1][init_cmds.c:441][Init][ERROR] DoChown, failed for system system /dev/cpuctl/tasks, err 2.
      [    4.183438] [pid=1][init_cmds.c:441][Init][ERROR] DoChown, failed for system system /dev/cpuctl/background/tasks, err 2.
      [    4.203068] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0755 /dev/cpuctl/tasks, err 2.
      [    4.233153] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0755 /dev/cpuctl/background/tasks, err 2.
      [    4.253571] [pid=1][init_cmds.c:664][Init][ERROR] DoMount, failed for cgroup none /dev/freezer freezer, err 19.
      [    4.273901] [pid=1][init_cmds.c:441][Init][ERROR] DoChown, failed for system system /dev/freezer/frozen/tasks, err 2.
      [    4.303436] [pid=1][init_cmds.c:441][Init][ERROR] DoChown, failed for system system /dev/freezer/thawed/tasks, err 2.
      [    4.323116] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0755 /dev/freezer/frozen/tasks, err 2.
      [    4.353153] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0755 /dev/freezer/thawed/tasks, err 2.
      [    4.373219] [pid=1][init_cmds.c:468][Init][ERROR] DoMkDir, failed for /data/sadata_de, err 30.
      [    4.392989] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 755 /data/sadata_de, err 2.
      [    4.413251] [pid=1][init_cmds.c:441][Init][ERROR] DoChown, failed for system system /data/sadata_de, err 2.
      [    4.433065] [pid=1][init_cmds.c:468][Init][ERROR] DoMkDir, failed for /data/sadata_de/samgr, err 2.
      [    4.453072] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 755 /data/sadata_de/samgr, err 2.
      [    4.473178] [pid=1][init_cmds.c:441][Init][ERROR] DoChown, failed for system system /data/sadata_de/samgr, err 2.
      [    4.506505] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.samgr value: running
      [    4.518413] [pid=73][init_service.c:200][Init][INFO] service->name is samgr
      [    4.544327] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.samgr success
      [    4.593055] [pid=1][trigger_processor.c:75][Init][INFO] ExecuteQueueWork 2
      [    4.600802] [pid=1][trigger_manager.c:267][Init][INFO] ExecuteTrigger trigger post-init
      [    4.628788] [pid=1][trigger_processor.c:208][Init][INFO] DoTriggerExec trigger early-fs
      [    4.640506] [pid=1][trigger_processor.c:208][Init][INFO] DoTriggerExec trigger post-fs
      [    4.649943] [pid=1][trigger_processor.c:208][Init][INFO] DoTriggerExec trigger late-fs
      [    4.659082] [pid=1][trigger_processor.c:208][Init][INFO] DoTriggerExec trigger post-fs-data
      [    4.671841] [pid=1][trigger_processor.c:208][Init][INFO] DoTriggerExec trigger load_persist_props_action
      [    4.682714] [pid=1][trigger_processor.c:208][Init][INFO] DoTriggerExec trigger firmware_mounts_complete
      [    4.695124] [pid=1][trigger_processor.c:208][Init][INFO] DoTriggerExec trigger boot
      [    4.706466] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/buffer_size_kb, err 2.
      [    4.745779] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/saved_cmdlines_size, err 2.
      [    4.758921] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/trace, err 2.
      [    4.802725] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/trace_clock, err 2.
      [    4.815079] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0222 /sys/kernel/debug/tracing/trace_marker, err 2.
      [    4.828951] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/tracing_on, err 2.
      [    4.875715] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/binder/binder_lock/enable, err 2.
      [    4.890198] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/binder/binder_locked/enable, err 2.
      [    4.906395] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/binder/binder_unlock/enable, err 2.
      [    4.958642] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/binder/binder_transaction/enable, err 2.
      [    4.973773] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/binder/binder_transaction_received/enable, err 2.
      [    4.991891] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/binder/binder_transaction_alloc_buf/enable, err 2.
      [    5.042253] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/cgroup/enable, err 2.
      [    5.055509] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/cpufreq_interactive/enable, err 2.
      [    5.072088] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/dma_fence/enable, err 2.
      [    5.123962] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/fence/enable, err 2.
      [    5.137134] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/i2c/enable, err 2.
      [    5.150066] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/i2c/i2c_read/enable, err 2.
      [    5.164417] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/i2c/i2c_write/enable, err 2.
      [    5.182540] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/i2c/i2c_result/enable, err 2.
      [    5.217883] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/i2c/i2c_reply/enable, err 2.
      [    5.234305] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/i2c/smbus_read/enable, err 2.
      [    5.282067] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/i2c/smbus_write/enable, err 2.
      [    5.296173] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/i2c/smbus_result/enable, err 2.
      [    5.311820] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/i2c/smbus_reply/enable, err 2.
      [    5.365791] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/kmem/rss_stat/enable, err 2.
      [    5.379702] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/kmem/ion_heap_grow/enable, err 2.
      [    5.394085] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/kmem/ion_heap_shrink/enable, err 2.
      [    5.410194] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/lowmemorykiller/enable, err 2.
      [    5.451546] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/lowmemorykiller/lowmemory_kill/enable, err 2.
      [    5.468148] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/mm_event/mm_event_record/enable, err 2.
      [    5.511645] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/oom/oom_score_adj_update/enable, err 2.
      [    5.528264] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/power/cpu_frequency/enable, err 2.
      [    5.575187] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/power/cpu_idle/enable, err 2.
      [    5.589195] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/power/clock_set_rate/enable, err 2.
      [    5.604057] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/power/cpu_frequency_limits/enable, err 2.
      [    5.620896] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/power/gpu_frequency/enable, err 2.
      [    5.676115] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/sched/sched_switch/enable, err 2.
      [    5.690512] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/sched/sched_wakeup/enable, err 2.
      [    5.704894] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/sched/sched_blocked_reason/enable, err 2.
      [    5.722132] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/sched/sched_cpu_hotplug/enable, err 2.
      [    5.778696] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/sched/sched_pi_setprio/enable, err 2.
      [    5.793479] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/sched/sched_process_exit/enable, err 2.
      [    5.808481] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/sched/sched_waking/enable, err 2.
      [    5.857790] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/signal/signal_generate/enable, err 2.
      [    5.872577] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/signal/signal_deliver/enable, err 2.
      [    5.888752] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/sync/enable, err 2.
      [    5.936066] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/task/task_rename/enable, err 2.
      [    5.950269] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/task/task_newtask/enable, err 2.
      [    5.967213] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/vmscan/mm_vmscan_direct_reclaim_begin/enable, err 2.
      [    6.018937] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/vmscan/mm_vmscan_direct_reclaim_end/enable, err 2.
      [    6.036329] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/vmscan/mm_vmscan_kswapd_wake/enable, err 2.
      [    6.081195] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/vmscan/mm_vmscan_kswapd_sleep/enable, err 2.
      [    6.098618] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/block/block_rq_issue/enable, err 2.
      [    6.145246] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/block/block_rq_complete/enable, err 2.
      [    6.160129] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/ext4/ext4_da_write_begin/enable, err 2.
      [    6.176907] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/ext4/ext4_da_write_end/enable, err 2.
      [    6.222848]
      [    6.222848] insmod_device_driver
      [    6.222848]
      [    6.229919] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/ext4/ext4_es_lookup_extent_enter/enable, err 2.
      [    6.245654] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/ext4/ext4_es_lookup_extent_exit/enable, err 2.
      [    6.263127] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/ext4/ext4_load_inode/enable, err 2.
      [    6.318664] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/ext4/ext4_sync_file_enter/enable, err 2.
      [    6.333733] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/ext4/ext4_sync_file_exit/enable, err 2.
      [    6.348734] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/f2fs/f2fs_get_data_block/enable, err 2.
      [    6.366160] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/f2fs/f2fs_iget/enable, err 2.
      [    6.403021] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/f2fs/f2fs_sync_file_enter/enable, err 2.
      [    6.418089] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/f2fs/f2fs_sync_file_exit/enable, err 2.
      [    6.434546] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/f2fs/f2fs_write_begin/enable, err 2.
      [    6.482559] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/f2fs/f2fs_write_end/enable, err 2.
      [    6.497054] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/filemap/mm_filemap_add_to_page_cache/enable, err 2.
      [    6.545822] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/events/filemap/mm_filemap_delete_from_page_cache/enable, err 2.
      [    6.562499] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/options/overwrite, err 2.
      [    6.577395] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/options/print-tgid, err 2.
      [    6.607248] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/options/record-tgid, err 2.
      [    6.644087] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/per_cpu/cpu0/trace, err 2.
      [    6.657184] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/per_cpu/cpu1/trace, err 2.
      [    6.700382] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/per_cpu/cpu2/trace, err 2.
      [    6.713419] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/per_cpu/cpu3/trace, err 2.
      [    6.728301] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/per_cpu/cpu4/trace, err 2.
      [    6.754044] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/per_cpu/cpu5/trace, err 2.
      [    6.769363] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/per_cpu/cpu6/trace, err 2.
      [    6.830684] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/per_cpu/cpu7/trace, err 2.
      [    6.843775] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/per_cpu/cpu8/trace, err 2.
      [    6.856802] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/per_cpu/cpu9/trace, err 2.
      [    6.869862] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/per_cpu/cpu10/trace, err 2.
      [    6.883742] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/per_cpu/cpu11/trace, err 2.
      [    6.909555] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/per_cpu/cpu12/trace, err 2.
      [    6.924486] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/per_cpu/cpu13/trace, err 2.
      [    6.980445] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/per_cpu/cpu14/trace, err 2.
      [    6.993615] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 0666 /sys/kernel/debug/tracing/per_cpu/cpu15/trace, err 2.
      [    7.006697] [pid=1][trigger_processor.c:75][Init][INFO] ExecuteQueueWork 3
      [    7.014499] [pid=1][trigger_manager.c:267][Init][INFO] ExecuteTrigger trigger early-fs
      [    7.024054] [pid=1][trigger_processor.c:75][Init][INFO] ExecuteQueueWork 4
      [    7.037347] [pid=1][trigger_manager.c:267][Init][INFO] ExecuteTrigger trigger post-fs
      [    7.085124] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.udevd_service value: running
      [    7.097689] [pid=74][init_service.c:200][Init][INFO] service->name is udevd_service
      [    7.106833] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.udevd_service success
      [    7.150827] [pid=1][init_cmds.c:330][Init][INFO] Sleeping 1 second(s)
      [    7.525579] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.multimodalinputservice value: running
      [    7.539096] [pid=75][init_service.c:200][Init][INFO] service->name is multimodalinputservice
      [    7.549207] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.multimodalinputservice success
      [    7.594845] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.mmi_uinput_service value: running
      [    7.607865] [pid=76][init_service.c:200][Init][INFO] service->name is mmi_uinput_service
      [    7.650563] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.mmi_uinput_service success
      [    7.691468] [pid=1][init_cmds.c:330][Init][INFO] Sleeping 2 second(s)
      [    8.140925] random: fast init done
      [    8.205979] random: samgr: uninitialized urandom read (4 bytes read)
      [    8.554706] random: multimodalinput: uninitialized urandom read (4 bytes read)
      [    9.723031] [pid=1][init_cmds.c:468][Init][ERROR] DoMkDir, failed for /data/weston, err 30.
      [    9.732467] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 777 /data/weston, err 2.
      [    9.746305] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.weston value: running
      [    9.758103] [pid=84][init_service.c:200][Init][INFO] service->name is weston
      [    9.766810] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.weston success
      [    9.777683] [pid=1][trigger_processor.c:208][Init][INFO] DoTriggerExec trigger weston_start
      [    9.807111] [pid=1][init_cmds.c:330][Init][INFO] Sleeping 2 second(s)
      [   10.608326] [pid=1][trigger_processor.c:75][Init][INFO] ExecuteQueueWork 5
      [   10.619768] [pid=1][trigger_manager.c:267][Init][INFO] ExecuteTrigger trigger late-fs
      [   10.657059] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.appspawn value: running
      [   10.669205] [pid=87][init_service.c:200][Init][INFO] service->name is appspawn
      [   10.678993] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.appspawn success
      [   10.804262] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.dps_service value: running
      [   10.898359] [pid=88][init_service.c:200][Init][INFO] service->name is dps_service
      [   11.180719] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.dps_service success
      [   13.903546] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.installs value: running
      [   13.968557] [pid=90][init_service.c:200][Init][INFO] service->name is installs
      [   15.360639] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.installs success
      [   17.557365] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.lmks value: running
      [   17.926641] [pid=93][init_service.c:200][Init][INFO] service->name is lmks
      [   18.318432] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.lmks success
      [   18.468541] [pid=1][trigger_processor.c:75][Init][INFO] ExecuteQueueWork 6
      [   18.476355] [pid=1][trigger_manager.c:267][Init][INFO] ExecuteTrigger trigger post-fs-data
      [   18.486308] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.accountmgr value: running
      [   18.498936] [pid=94][init_service.c:200][Init][INFO] service->name is accountmgr
      [   18.507776] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.accountmgr success
      [   18.520549] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.deviceauth_service value: running
      [   18.566634] [pid=95][init_service.c:200][Init][INFO] service->name is deviceauth_service
      [   19.142354] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.deviceauth_service success
      [   19.498767] random: installs: uninitialized urandom read (4 bytes read)
      [   19.509770] random: dps_service: uninitialized urandom read (4 bytes read)
      [   19.534062] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.distributedsched value: running
      [   19.583723] [pid=100][init_service.c:200][Init][INFO] service->name is distributedsched
      [   19.608892] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.distributedsched success
      [   19.690734] [pid=1][init_cmds.c:468][Init][ERROR] DoMkDir, failed for /data/log/faultlog/ 0770 system system, err 2.
      [   19.776774] [pid=1][init_cmds.c:468][Init][ERROR] DoMkDir, failed for /data/log/faultlog/temp/ 0770 system system, err 2.
      [   19.839842] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.faultloggerd value: running
      [   19.852731] [pid=102][init_service.c:200][Init][INFO] service->name is faultloggerd
      [   19.996794] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.faultloggerd success
      [   20.068166] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.hdf_devmgr value: running
      [   20.083994] [pid=104][init_service.c:200][Init][INFO] service->name is hdf_devmgr
      [   20.125990] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.hdf_devmgr success
      [   20.571335] [pid=1][init_cmds.c:441][Init][ERROR] DoChown, failed for system system /dev/dev_mgr, err 2.
      [   20.693176] [pid=1][init_cmds.c:441][Init][ERROR] DoChown, failed for system system /dev/hdf_disp, err 2.
      [   20.736223] [pid=1][init_cmds.c:441][Init][ERROR] DoChown, failed for system system /dev/hdf_input_host, err 2.
      [   20.796764] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/platform/soc@3000000/2000000.pinctrl/gpiochip0 changed
      [   20.813272] [pid=1][init_cmds.c:441][Init][ERROR] DoChown, failed for system system /dev/hdf_input_event1, err 2.
      [   20.839165] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/platform/soc@3000000/2030340.sound/sound/card0/input0/event0 changed
      [   20.857798] [pid=1][init_cmds.c:441][Init][ERROR] DoChown, failed for system system /dev/hdf_input_event2, err 2.
      [   20.888620] [pid=1][init_cmds.c:441][Init][ERROR] DoChown, failed for system system /dev/hdf_input_event3, err 2.
      [   20.902203] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/platform/soc@3000000/2030340.sound/sound/card0/pcmC0D0c changed
      [   20.963306] [pid=1][init_cmds.c:441][Init][ERROR] DoChown, failed for system system /dev/hdf_input_event4, err 2.
      [   20.985068] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/platform/soc@3000000/2030340.sound/sound/card0/pcmC0D0p changed
      [   21.032324] [pid=1][init_cmds.c:441][Init][ERROR] DoChown, failed for system system /dev/hdf_input_event5, err 2.
      [   21.060614] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/platform/soc@3000000/2030340.sound/sound/card0/controlC0 changed
      [   21.078576] [pid=1][init_cmds.c:441][Init][ERROR] DoChown, failed for system system /dev/hdf_input_event6, err 2.
      [   21.145282] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/platform/soc@3000000/2031060.sounddmic/sound/card1/pcmC1D0c changed
      [   21.164243] [pid=1][init_cmds.c:441][Init][ERROR] DoChown, failed for system system /dev/hdf_sensor_manager_ap, err 2.
      [   21.187709] [pid=1][init_cmds.c:441][Init][ERROR] DoChown, failed for system system /dev/hdf_misc_vibrator, err 2.
      [   21.199535] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/platform/soc@3000000/2031060.sounddmic/sound/card1/controlC1 changed
      [   21.263275] [pid=1][init_cmds.c:441][Init][ERROR] DoChown, failed for system system /dev/hdf_audio_render, err 2.
      [   21.293046] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/platform/soc@3000000/20340a0.sounddaudio2/sound/card2/pcmC2D0c changed
      [   21.327099] [pid=1][init_cmds.c:441][Init][ERROR] DoChown, failed for system system /dev/hdf_audio_capture, err 2.
      [   21.423011] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/platform/soc@3000000/20340a0.sounddaudio2/sound/card2/pcmC2D0p changed
      [   21.443178] [pid=1][init_cmds.c:441][Init][ERROR] DoChown, failed for system system /dev/hdf_audio_control, err 2.
      [   21.502948] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/platform/soc@3000000/20340a0.sounddaudio2/sound/card2/controlC2 changed
      [   21.521827] [pid=1][init_cmds.c:441][Init][ERROR] DoChown, failed for system system /dev/hdf_audio_codec_dev0, err 2.
      [   21.598611] [pid=1][init_cmds.c:441][Init][ERROR] DoChown, failed for system system /dev/hdf_audio_smartpa_dev0, err 2.
      [   21.613966] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/platform/soc@3000000/2500400.uart/tty/ttyS0 changed
      [   21.641842] [pid=1][init_cmds.c:441][Init][ERROR] DoChown, failed for system system /dev/hdf_dsoftbus, err 2.
      [   21.656678] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/platform/soc@3000000/2500c00.uart/tty/ttyS1 changed
      [   21.670125] [pid=1][init_cmds.c:468][Init][ERROR] DoMkDir, failed for /data/log/ 0770 system log, err 30.
      [   21.721689] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/platform/soc@3000000/2501000.uart/tty/ttyS2 changed
      [   21.753019] [pid=1][init_cmds.c:468][Init][ERROR] DoMkDir, failed for /data/log/hilog/ 0750 logd log, err 2.
      [   21.783000] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/platform/soc@3000000/2501400.uart/tty/ttyS3 changed
      [   21.806238] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.hilogd value: running
      [   21.824915] [pid=105][init_service.c:200][Init][INFO] service->name is hilogd
      [   21.873032] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/platform/soc@3000000/twi1/i2c-1/1-0020/gpiochip1 changed
      [   21.894324] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.hilogd success
      [   21.982992] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/platform/soc@3000000/twi1/i2c-1/1-0038/input/input1/event1 changed
      [   22.000489] [pid=1][init_cmds.c:468][Init][ERROR] DoMkDir, failed for /data/log/ 0770 system log, err 30.
      [   22.048505] random: hdf_devmgr: uninitialized urandom read (4 bytes read)
      [   22.059002] [pid=1][init_cmds.c:468][Init][ERROR] DoMkDir, failed for /data/log/faultlog/ 0770 system system, err 2.
      [   22.092963] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/platform/soc@3000000/twi1/i2c-1/i2c-dev/i2c-1 changed
      [   22.170123] [pid=1][init_cmds.c:468][Init][ERROR] DoMkDir, failed for /data/log/faultlog/temp/ 0770 system system, err 2.
      [   22.257269] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/platform/soc@3000000/4020000.sdmmc/mmc_host/mmc0/mmc0:1234/block/mmcblk0 changed
      [   22.302957] [pid=1][init_cmds.c:468][Init][ERROR] DoMkDir, failed for /data/log/faultlog/faultlogger/ 0770 system system, err 2.
      [   22.338930] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/platform/soc@3000000/4020000.sdmmc/mmc_host/mmc0/mmc0:1234/block/mmcblk0/mmcblk0p1 changed
      [   22.395304] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.hiview value: running
      [   22.551234] [pid=108][init_service.c:200][Init][INFO] service->name is hiview
      [   22.563318] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.hiview success
      [   22.691486] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/platform/soc@3000000/4020000.sdmmc/mmc_host/mmc0/mmc0:1234/block/mmcblk0/mmcblk0p2 changed
      [   22.766871] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.huks_service value: running
      [   22.779361] [pid=118][init_service.c:200][Init][INFO] service->name is huks_service
      [   22.841094] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.huks_service success
      [   22.864102] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/platform/soc@3000000/4020000.sdmmc/mmc_host/mmc0/mmc0:1234/block/mmcblk0/mmcblk0p3 changed
      [   22.959096] [pid=1][init_cmds.c:1011][Init][ERROR] DoRm: unlink /data/data/.pulse_dir/runtime/pid failed: 2.
      [   22.999810] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/platform/soc@3000000/4020000.sdmmc/mmc_host/mmc0/mmc0:1234/block/mmcblk0/mmcblk0p4 changed
      [   23.019769] [pid=1][init_cmds.c:468][Init][ERROR] DoMkDir, failed for /data/data/.pulse_dir, err 2.
      [   23.220279] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 777 /data/data/.pulse_dir, err 2.
      [   23.232227] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/platform/soc@3000000/4020000.sdmmc/mmc_host/mmc0/mmc0:1234/block/mmcblk0/mmcblk0p5 changed
      [   23.254618] [pid=1][init_cmds.c:441][Init][ERROR] DoChown, failed for system shell /data/data/.pulse_dir, err 2.
      [   23.317167] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/platform/soc@3000000/4020000.sdmmc/mmc_host/mmc0/mmc0:1234/block/mmcblk0/mmcblk0p6 changed
      [   23.376863] [pid=1][init_cmds.c:468][Init][ERROR] DoMkDir, failed for /data/data/.pulse_dir/runtime, err 2.
      [   23.403333] random: deviceauth_serv: uninitialized urandom read (4 bytes read)
      [   23.412988] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 777 /data/data/.pulse_dir/runtime, err 2.
      [   23.426505] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/platform/soc@3000000/4020000.sdmmc/mmc_host/mmc0/mmc0:1234/block/mmcblk0/mmcblk0p7 changed
      [   23.454734] [pid=1][init_cmds.c:441][Init][ERROR] DoChown, failed for system shell /data/data/.pulse_dir/runtime, err 2.
      [   23.486458] [pid=1][init_cmds.c:468][Init][ERROR] DoMkDir, failed for /data/data/.pulse_dir/state, err 2.
      [   23.502237] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/platform/soc@3000000/4020000.sdmmc/mmc_host/mmc0/mmc0:1234/block/mmcblk0/mmcblk0p8 changed
      [   23.633256] [pid=1][init_cmds.c:514][Init][ERROR] DoChmod, failed for 777 /data/data/.pulse_dir/state, err 2.
      [   23.644724] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/platform/soc@3000000/4200000.ehci1-controller/usb1 changed
      [   23.658925] [pid=1][init_cmds.c:441][Init][ERROR] DoChown, failed for system shell /data/data/.pulse_dir/state, err 2.
      [   23.671127] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/platform/soc@3000000/4200400.ohci1-controller/usb2 changed
      [   23.689194] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.pulseaudio value: running
      [   23.701478] [pid=126][init_service.c:200][Init][INFO] service->name is pulseaudio
      [   23.762637] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.pulseaudio success
      [   23.773202] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/platform/soc@3000000/5000000.disp/graphics/fb0 changed
      [   23.788951] [pid=1][trigger_processor.c:208][Init][INFO] DoTriggerExec trigger audio_policy_start
      [   23.843203] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/platform/soc@3000000/6011000.watchdog/misc/watchdog changed
      [   23.858231] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.softbus_server value: running
      [   23.923710] [pid=128][init_service.c:200][Init][INFO] service->name is softbus_server
      [   23.932978] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/platform/soc@3000000/6011000.watchdog/watchdog/watchdog0 changed
      [   23.951790] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.softbus_server success
      [   24.004585] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/platform/soc@3000000/7090000.rtc/rtc/rtc0 changed
      [   24.020886] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.wifi_hal_service value: running
      [   24.082240] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/cedar_ve/cedar_dev changed
      [   24.095390] [pid=129][init_service.c:200][Init][INFO] service->name is wifi_hal_service
      [   24.109507] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.wifi_hal_service success
      [   24.170393] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/disp/disp changed
      [   24.331754] [pid=1][init_cmds.c:468][Init][ERROR] DoMkDir, failed for /data/dhcp, err 30.
      [   24.343189] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.wifi_manager_service value: running
      [   24.360058] [pid=130][init_service.c:200][Init][INFO] service->name is wifi_manager_service
      [   24.369732] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/hdmi/hdmi changed
      [   24.493093] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.wifi_manager_service success
      [   24.543139] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/mem/full changed
      [   24.585179] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/mem/kmsg changed
      [   24.603672] [pid=1][trigger_processor.c:75][Init][INFO] ExecuteQueueWork 7
      [   24.661674] [pid=1][trigger_manager.c:267][Init][INFO] ExecuteTrigger trigger load_persist_props_action
      [   24.672376] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/mem/mem changed
      [   24.770871] [pid=1][trigger_processor.c:75][Init][INFO] ExecuteQueueWork 8
      [   24.782266] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/mem/null changed
      [   24.794718] [pid=1][trigger_manager.c:267][Init][INFO] ExecuteTrigger trigger firmware_mounts_complete
      [   24.874862] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/mem/random changed
      [   24.897728] [pid=1][trigger_processor.c:75][Init][INFO] ExecuteQueueWork 9
      [   24.936539] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/mem/urandom changed
      [   24.984458] [pid=1][trigger_manager.c:267][Init][INFO] ExecuteTrigger trigger boot
      [   24.993110] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/mem/zero changed
      [   25.009312] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.camera_service value: running
      [   25.071888] [pid=132][init_service.c:200][Init][INFO] service->name is camera_service
      [   25.082177] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/misc/binder changed
      [   25.122182] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.camera_service success
      [   25.184665] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/misc/cpu_dma_latency changed
      [   25.236722] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.distributeddata value: running
      [   25.249719] [pid=133][init_service.c:200][Init][INFO] service->name is distributeddata
      [   25.319240] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/misc/hwbinder changed
      [   25.370442] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.distributeddata success
      [   25.406397] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/misc/ion changed
      [   25.432927] [pid=1][init_cmds.c:441][Init][ERROR] DoChown, failed for radio system /sys/power/wake_lock, err 2.
      [   25.489624] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/misc/rpaf-dsp0 changed
      [   25.502198] [pid=1][init_cmds.c:441][Init][ERROR] DoChown, failed for radio system /sys/power/wake_unlock, err 2.
      [   25.532867] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/misc/sunxi-reg changed
      [   25.657221] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.foundation value: running
      [   25.695564] [pid=134][init_service.c:200][Init][INFO] service->name is foundation
      [   25.704225] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/misc/sunxi-wlan changed
      [   25.739534] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.foundation success
      [   25.844307] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/misc/sunxi_soc_info changed
      [   25.893254] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.inputmethod_service value: running
      [   25.906415] [pid=135][init_service.c:200][Init][INFO] service->name is inputmethod_service
      [   25.925276] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/misc/ubi_ctrl changed
      [   26.005931] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.inputmethod_service success
      [   26.046649] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/misc/vndbinder changed
      [   26.151283] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.media_service value: running
      [   26.170416] [pid=136][init_service.c:200][Init][INFO] service->name is media_service
      [   26.179427] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/sound/timer changed
      [   26.295990] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.media_service success
      [   26.306781] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/sunxi_pwm_char_class/sunxi_pwm0 changed
      [   26.321604] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.medialibrary_service value: running
      [   26.356481] [pid=137][init_service.c:200][Init][INFO] service->name is medialibrary_service
      [   26.366117] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/console changed
      [   26.380561] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.medialibrary_service success
      [   26.459846] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/ptmx changed
      [   26.479183] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.telephony_sa value: running
      [   26.496291] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/ptyp0 changed
      [   26.508142] [pid=139][init_service.c:200][Init][INFO] service->name is telephony_sa
      [   26.692050] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/ptyp1 changed
      [   26.728706] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.telephony_sa success
      [   26.743561] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.time_service value: running
      [   26.755058] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/ptyp2 changed
      [   26.766848] [pid=140][init_service.c:200][Init][INFO] service->name is time_service
      [   26.776618] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/ptyp3 changed
      [   26.831787] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.time_service success
      [   26.846857] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/ptyp4 changed
      [   26.917529] [pid=1][trigger_checker.c:230][Init][ERROR]
      [   26.925024] [pid=1][trigger_manager.c:267][Init][INFO] ExecuteTrigger trigger boot && param:ro.debuggable=1
      [   26.984825] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/ptyp5 changed
      [   27.234348] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.console value: running
      [   27.249891] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/ptyp6 changed
      [   27.275361] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.console success
      [   27.294430] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/ptyp7 changed
      [   27.332286] [pid=1][trigger_processor.c:75][Init][INFO] ExecuteQueueWork 10
      [   27.340268] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/ptyp8 changed
      [   27.354770] [pid=1][trigger_manager.c:267][Init][INFO] ExecuteTrigger trigger weston_start
      [   27.369496] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/ptyp9 changed
      [   27.530023] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.bootanimation value: running
      [   27.542538] [pid=142][init_service.c:200][Init][INFO] service->name is bootanimation
      [   27.555024] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/ptypa changed
      [   27.567100] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.bootanimation success
      [   27.610556] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/ptypb changed
      [   27.622430] [pid=1][trigger_processor.c:75][Init][INFO] ExecuteQueueWork 11
      [   27.631175] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/ptypc changed
      [   27.645223] [pid=1][trigger_manager.c:267][Init][INFO] ExecuteTrigger trigger audio_policy_start
      [   27.739592] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/ptypd changed
      [   27.750735] [pid=141][init_service.c:200][Init][INFO] service->name is console
      [   27.800000] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.audio_policy value: running
      [   27.816111] [pid=143][init_service.c:200][Init][INFO] service->name is audio_policy
      [   27.826804] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/ptype changed
      [   27.897828] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.audio_policy success
      [   27.908570] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/ptypf changed
      [   27.920998] [pid=1][trigger_processor.c:75][Init][INFO] ExecuteQueueWork 12
      [   27.969984] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty changed
      [   28.099267] [pid=1][init_signal_handler.c:75][Init][ERROR] Child process 74 exit with code : 0
      [   28.439956] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty0 changed
      [   28.467149] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty1 changed
      [   28.480185] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty10 changed
      [   28.806171] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty11 changed
      [   28.846900] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty12 changed
      [   28.866644] [pid=1][init_signal_handler.c:79][Init][INFO] SigHandler, SIGCHLD received, sigPID = 74.
      [   28.982568] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty13 changed
      [   29.030984] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.udevd_service value: stopped
      [   29.046121] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty14 changed
      [   29.057227] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.udevd_service success
      [   29.070653] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty15 changed
      [   29.195240] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.udevd_service value: running
      [   29.207836] [pid=144][init_service.c:200][Init][INFO] service->name is udevd_service
      [   29.216854] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty16 changed
      [   29.310875] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.udevd_service success
      [   29.326265] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty17 changed
      [   29.370583] [pid=1][init_signal_handler.c:75][Init][ERROR] Child process 84 exit with code : 1
      [   29.384010] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty18 changed
      [   29.457789] [pid=1][init_signal_handler.c:79][Init][INFO] SigHandler, SIGCHLD received, sigPID = 84.
      [   29.468194] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty19 changed
      [   29.642953] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.weston value: stopped
      [   29.663004] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty2 changed
      [   29.678921] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.weston success
      [   29.798148] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty20 changed
      [   29.983084] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty21 changed
      [   30.009379] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty22 changed
      [   30.549735] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.weston value: running
      [   30.783351] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty23 changed
      [   30.829280] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty24 changed
      [   30.875280] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty25 changed
      [   31.000894] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty26 changed
      [   31.012194] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty27 changed
      [   31.023627] [pid=145][init_service.c:200][Init][INFO] service->name is weston
      [   31.203482] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.weston success
      [   31.218623] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty28 changed
      [   31.284021] [pid=1][init_signal_handler.c:75][Init][ERROR] Child process 85 exit with code : 0
      [   31.294824] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty29 changed
      [   31.327027] [pid=1][init_signal_handler.c:79][Init][INFO] SigHandler, SIGCHLD received, sigPID = 85.
      [   31.463095] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty3 changed
      [   31.483139] [pid=1][init_signal_handler.c:75][Init][ERROR] Child process 86 exit with code : 0
      [   31.527913] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty30 changed
      [   31.585508] [pid=1][init_signal_handler.c:79][Init][INFO] SigHandler, SIGCHLD received, sigPID = 86.
      [   31.712974] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty31 changed
      [   31.749112] [pid=1][init_signal_handler.c:75][Init][ERROR] Child process 102 exit with code : 0
      [   31.763344] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty32 changed
      [   31.774099] [pid=1][init_signal_handler.c:79][Init][INFO] SigHandler, SIGCHLD received, sigPID = 102.
      [   31.787782] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty33 changed
      [   31.863629] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.faultloggerd value: stopped
      [   31.876646] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty34 changed
      [   31.925786] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.faultloggerd success
      [   32.048583] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty35 changed
      [   32.060095] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.faultloggerd value: running
      [   32.074170] [pid=146][init_service.c:200][Init][INFO] service->name is faultloggerd
      [   32.116170] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty36 changed
      [   32.127456] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.faultloggerd success
      [   32.204298] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty37 changed
      [   32.215117] [pid=1][init_signal_handler.c:75][Init][ERROR] Child process 129 exit with code : 255
      [   32.228649] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty38 changed
      [   32.241411] [pid=1][init_signal_handler.c:79][Init][INFO] SigHandler, SIGCHLD received, sigPID = 129.
      [   32.305590] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty39 changed
      [   32.339268] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.wifi_hal_service value: stopped
      [   32.352025] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty4 changed
      [   32.393146] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.wifi_hal_service success
      [   32.491388] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty40 changed
      [   32.503101] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.wifi_hal_service value: running
      [   32.519296] [pid=147][init_service.c:200][Init][INFO] service->name is wifi_hal_service
      [   32.528535] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty41 changed
      [   32.566013] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.wifi_hal_service success
      [   32.651372] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty42 changed
      [   32.662524] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty43 changed
      [   32.823503] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty44 changed
      [   32.897927] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty45 changed
      [   33.086733] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty46 changed
      [   33.131015] usb1-vbus: disabling
      [   33.167218] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty47 changed
      [   33.274587] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty48 changed
      [   33.312395] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty49 changed
      [   33.467778] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty5 changed
      [   33.480607] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty50 changed
      [   33.576305] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty51 changed
      [   33.600167] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty52 changed
      [   33.750439] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty53 changed
      [   33.858005] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty54 changed
      [   33.923385] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty55 changed
      [   34.084501] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty56 changed
      [   34.141206] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty57 changed
      [   34.344454] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty58 changed
      [   34.355266] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty59 changed
      [   34.412976] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty6 changed
      [   34.511861] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty60 changed
      [   34.524062] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty61 changed
      [   34.574803] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty62 changed
      [   34.726271] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty63 changed
      [   34.743148] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty7 changed
      [   34.775144] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty8 changed
      [   34.793926] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/tty9 changed
      [   39.075828] [pid=1][init_signal_handler.c:75][Init][ERROR] Child process 127 exit with code : 0
      [   39.193625] [pid=1][init_signal_handler.c:79][Init][INFO] SigHandler, SIGCHLD received, sigPID = 127.
      [   40.675306] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/ttyp0 changed
      [   40.690485] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/ttyp1 changed
      [   40.797866] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/ttyp2 changed
      [   40.859099] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/ttyp3 changed
      [   40.908818] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/ttyp4 changed
      [   40.919588] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/ttyp5 changed
      [   41.055282] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/ttyp6 changed
      [   41.066051] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/ttyp7 changed
      [   41.116615] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/ttyp8 changed
      [   41.199354] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/ttyp9 changed
      [   41.257398] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/ttypa changed
      [   41.290821] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/ttypb changed
      [   41.394949] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/ttypc changed
      [   41.479307] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/ttypd changed
      [   41.528559] [pid=68][ueventd_device_handler.c:290][Init][INFO] Device /devices/virtual/tty/ttype changed
      [   48.522915] dps_service invoked oom-killer: gfp_mask=0x82cc0(GFP_KERNEL|__GFP_NOWARN|__GFP_NOMEMALLOC), order=0, oom_score_adj=0
      [   48.535873] CPU: 0 PID: 101 Comm: dps_service Not tainted 5.4.61 #1
      [   48.542893] Call Trace:
      [   48.545636] [<ffffffe0000313ce>] walk_stackframe+0x0/0xa0
      [   48.551656] [<ffffffe0000315b0>] show_stack+0x2a/0x34
      [   48.557371] [<ffffffe0005ad632>] dump_stack+0x20/0x28
      [   48.563063] [<ffffffe00008da3e>] dump_header+0x48/0x1a4
      [   48.568893] [<ffffffe00008d308>] oom_kill_process+0x2d8/0x2da
      [   48.575342] [<ffffffe00008d776>] out_of_memory+0x92/0x2b8
      [   48.581375] [<ffffffe0000b7e6c>] __alloc_pages_slowpath+0x6c6/0x79a
      [   48.588406] [<ffffffe0000b8082>] __alloc_pages_nodemask+0x142/0x174
      [   48.595435] [<ffffffe0000bafa8>] new_slab+0x290/0x2e2
      [   48.601070] [<ffffffe0000bbef8>] ___slab_alloc.isra.99.constprop.104+0x14a/0x33a
      [   48.609413] [<ffffffe0000bc0fe>] __slab_alloc.isra.100.constprop.103+0x16/0x24
      [   48.617517] [<ffffffe0000bc85a>] __kmalloc_track_caller+0x112/0x1ee
      [   48.624554] [<ffffffe000492c44>] __kmalloc_reserve.isra.57+0x2c/0x70
      [   48.631644] [<ffffffe000492cf6>] __alloc_skb+0x6e/0x14a
      [   48.638449] [<ffffffe000495f06>] alloc_skb_with_frags+0x48/0x15e
      [   48.645220] [<ffffffe00048ff8a>] sock_alloc_send_pskb+0x166/0x186
      [   48.652031] [<ffffffe00053772c>] unix_dgram_sendmsg+0xdc/0x57e
      [   48.668466] [<ffffffe00048c77e>] sock_write_iter+0x88/0xc8
      [   48.674658] [<ffffffe0000c1f30>] do_iter_readv_writev+0x11a/0x166
      [   48.681458] [<ffffffe0000c2f6a>] do_iter_write+0x6e/0x126
      [   48.697436] [<ffffffe0000c30ac>] vfs_writev+0x6c/0xa0
      [   48.703184] [<ffffffe0000c312e>] do_writev+0x4e/0xa2
      [   48.708726] [<ffffffe0000c3d80>] sys_writev+0xe/0x16
      [   48.724162] [<ffffffe00003000a>] ret_from_syscall+0x0/0xe
      [   48.730185] Mem-Info:
      [   48.732727] active_anon:4906 inactive_anon:5 isolated_anon:0
      [   48.732727]  active_file:227 inactive_file:238 isolated_file:0
      [   48.732727]  unevictable:0 dirty:0 writeback:0 unstable:0
      [   48.732727]  slab_reclaimable:767 slab_unreclaimable:3240
      [   48.732727]  mapped:228 shmem:15 pagetables:322 bounce:0
      [   48.732727]  free:1176 free_pcp:0 free_cma:0
      [   48.778112] Node 0 active_anon:19624kB inactive_anon:20kB active_file:908kB inactive_file:952kB unevictable:0kB isolated(anon):0kB isolated(file):0kB mapped:912kB dirty:0kB writeback:0kB shmem:60kB writeback_tmp:0kB unstable:0kB all_unreclaimable? no
      [   48.812882] DMA32 free:4704kB min:5004kB low:5228kB high:5452kB active_anon:19624kB inactive_anon:20kB active_file:908kB inactive_file:952kB unevictable:0kB writepending:0kB present:63488kB managed:51768kB mlocked:0kB kernel_stack:1680kB pagetables:1288kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
      [   48.853187] lowmem_reserve[]: 0 0 0
      [   48.857092] DMA32: 548*4kB (UME) 154*8kB (UME) 46*16kB (UME) 17*32kB (UM) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 4704kB
      [   48.871232] Free pages count per migrate typeat order:     0      1      2      3      4      5      6      7      8      9     10
      [   48.886881] zone    DMA32, type    Unmovable     19      4      4      2      0      0      0      0      0      0      0
      [   48.931259] zone    DMA32, type      Movable    461    138     39     15      0      0      0      0      0      0      0
      [   48.943835] zone    DMA32, type  Reclaimable     35     12      3      0      0      0      0      0      0      0      0
      [   48.956224] zone    DMA32, type          CMA      0      0      0      0      0      0      0      0      0      0      0
      [   48.968611] zone    DMA32, type   HighAtomic      0      0      0      0      0      0      0      0      0      0      0
      [   48.981041] zone    DMA32, type      Isolate      0      0      0      0      0      0      0      0      0      0      0
      [   48.993415] 506 total pagecache pages
      [   48.997497] 15872 pages RAM
      [   49.000605] 0 pages HighMem/MovableOnly
      [   49.004910] 2930 pages reserved
      [   49.008407] 0 pages cma reserved
      [   49.012000] Tasks state (memory values in pages):
      [   49.017271] [  pid  ]   uid  tgid total_vm      rss pgtables_bytes swapents oom_score_adj name
      [   49.026933] [     68]     0    68      262       38    28672        0             0 ueventd
      [   49.036289] [     73]  1000    73     2671      281    49152        0             0 samgr
      [   49.045449] [     75]  1000    75     2789      222    49152        0             0 multimodalinput
      [   49.055576] [     76]     0    76      782       84    32768        0             0 uinput_inject
      [   49.065510] [     87]     0    87     5217      480    73728        0             0 appspawn
      [   49.075030] [     88]  1000    88     7683      716    86016        0             0 dps_service
      [   49.084781] [     90]     0    90     2385      194    49152        0             0 installs
      [   49.094230] [     93]     0    93      712      113    32768        0             0 lmks
      [   49.103290] [     94]  1000    94     2901      299    49152        0             0 accountmgr
      [   49.112929] [     95]  1000    95     2953      237    45056        0             0 deviceauth_serv
      [   49.123053] [    100]  1000   100     3123      333    53248        0             0 distributedsche
      [   49.133178] [    104]     0   104     2273      197    45056        0             0 hdf_devmgr
      [   49.142818] [    105]  1036   105     1013      291    32768        0             0 hilogd
      [   49.152038] [    108]  1000   108     2726      112    40960        0             0 hiview
      [   49.161291] [    109]     0   109     1939      170    36864        0             0 hdf_devhost
      [   49.171086] [    111]     0   111     1939      108    36864        0             0 hdf_devhost
      [   49.182973] [    113]     0   113     1939      108    36864        0             0 hdf_devhost
      [   49.230319] [    114]     0   114     1939      108    32768        0             0 hdf_devhost
      [   49.240089] [    115]     0   115     1939      108    36864        0             0 hdf_devhost
      [   49.249828] [    116]     0   116     1939      173    36864        0             0 hdf_devhost
      [   49.259567] [    117]     0   117     1939      107    36864        0             0 hdf_devhost
      [   49.269589] [    118]  1000   118     2318      191    45056        0             0 sa_main
      [   49.278971] [    119]     0   119     1939      108    36864        0             0 hdf_devhost
      [   49.288746] [    120]     0   120     1939      108    32768        0             0 hdf_devhost
      [   49.299798] [    121]     0   121     1939      109    36864        0             0 hdf_devhost
      [   49.341308] [    126]  1000   126     2318      194    36864        0             0 sa_main
      [   49.350846] [    128]  1000   128     2318      192    36864        0             0 sa_main
      [   49.360290] [    130]     0   130     2318      191    36864        0             0 sa_main
      [   49.369656] [    132]  1047   132     2318      194    40960        0             0 sa_main
      [   49.379011] [    133]  1000   133     2318      192    45056        0             0 sa_main
      [   49.388361] [    134]  1000   134     2318      185    36864        0             0 sa_main
      [   49.397713] [    135]  1000   135     2318      176    32768        0             0 sa_main
      [   49.407197] [    136]  1000   136     2171       77    40960        0             0 sa_main
      [   49.416575] [    137]     0   137     2164       75    32768        0             0 sa_main
      [   49.425929] [    138]     0   138      823      129    24576        0             0 sleep
      [   49.435086] [    139]  1000   139     2171       75    36864        0             0 sa_main
      [   49.444436] [    140]  1000   140     2318      172    36864        0             0 sa_main
      [   49.453836] [    141]     0   141      783      125    28672        0             0 sh
      [   49.462669] [    142]     0   142     1081       54    32768        0             0 bootanimation
      [   49.472608] [    143]  1000   143     1246       78    28672        0             0 sa_main
      [   49.481962] [    144]     0   144      786      102    24576        0             0 udevd
      [   49.491118] [    145]     0   145     1441       79    28672        0             0 weston
      [   49.500370] [    146]     0   146      706      124    24576        0             0 faultloggerd
      [   49.510206] [    147]     0   147      742       63    24576        0             0 wifi_hal_servic
      [   49.520330] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),task=dps_service,pid=88,uid=1000
      [   49.530202] Out of memory: Killed process 88 (dps_service) total-vm:30732kB, anon-rss:2484kB, file-rss:380kB, shmem-rss:0kB, UID:1000 pgtables:84kB oom_score_adj:0
      [   49.550674] oom_reaper: reaped process 88 (dps_service), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
      [   50.161848] [pid=1][init_signal_handler.c:71][Init][ERROR] Child process 88 exit with signal: 9
      [   50.371063] [pid=1][init_signal_handler.c:79][Init][INFO] SigHandler, SIGCHLD received, sigPID = 88.
      [   50.469387] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.dps_service value: stopped
      [   50.487380] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.dps_service success
      [   50.535680] [pid=1][param_service.c:263][Init][INFO] SystemWriteParam name init.svc.dps_service value: running
      [   50.586740] [pid=148][init_service.c:200][Init][INFO] service->name is dps_service
      [   50.661144] [pid=1][trigger_processor.c:165][Init][INFO] PostParamTrigger init.svc.dps_service success
        DOT小文哥 LV 8 最后由 编辑
        这个D1的鸿蒙,应该是L3级别的,在D1-H哪吒(1G/2G DDR)上跑可以,但是D1s 内置的64M DDR,差得略多了,可能要大改才能跑起来
