    【全志T113-S3_100ask】使用内核驱动点灯(控制继电器)
      giao LV 6 最后由 编辑
      背景
      开发板上没有led灯,且没用其他引出的GPIO,所以就借rgb屏幕的引脚来点个灯(不过分吧@狗头),实现控制继电器。
      (一)寻找合适的GPIO
      看了好久的原理图,怕与其他功能冲突,所以就使用了 PD13 作为本次实验的引脚。
      该引脚除了作为rgb屏幕的功能外,好像没其他作用了,好,就它了。
      (二)跳线
      焊接飞线接到继电器上。
      (三)修改设备树
      参考开发文档
      Documentation/devicetree/bindings/leds/leds-gpio.txt
      LEDs connected to GPIO lines
      Required properties:
      - compatible : should be "gpio-leds".
      Each LED is represented as a sub-node of the gpio-leds device.  Each
      node's name represents the name of the corresponding LED.
      LED sub-node properties:
      - gpios :  Should specify the LED's GPIO, see "gpios property" in
        Documentation/devicetree/bindings/gpio/gpio.txt.  Active low LEDs should be
        indicated using flags in the GPIO specifier.
      - function :  (optional)
        see Documentation/devicetree/bindings/leds/common.txt
      - color :  (optional)
      - label :  (optional)
        see Documentation/devicetree/bindings/leds/common.txt (deprecated)
      - linux,default-trigger :  (optional)
      - default-state:  (optional) The initial state of the LED.
      - retain-state-suspended: (optional) The suspend state can be retained.Such
        as charge-led gpio.
      - retain-state-shutdown: (optional) Retain the state of the LED on shutdown.
        Useful in BMC systems, for example when the BMC is rebooted while the host
        remains up.
      - panic-indicator : (optional)
      Examples:
      #include <dt-bindings/gpio/gpio.h>
      #include <dt-bindings/leds/common.h>
      leds {
              compatible = "gpio-leds";
              led0 {
                      gpios = <&mcu_pio 0 GPIO_ACTIVE_LOW>;
                      linux,default-trigger = "disk-activity";
                      function = LED_FUNCTION_DISK;
              led1 {
                      gpios = <&mcu_pio 1 GPIO_ACTIVE_HIGH>;
                      /* Keep LED on if BIOS detected hardware fault */
                      default-state = "keep";
                      function = LED_FUNCTION_FAULT;
      run-control {
              led0 {
                      gpios = <&mpc8572 6 GPIO_ACTIVE_HIGH>;
                      color = <LED_COLOR_ID_RED>;
                      default-state = "off";
              led1 {
                      gpios = <&mpc8572 7 GPIO_ACTIVE_HIGH>;
                      color = <LED_COLOR_ID_GREEN>;
                      default-state = "on";
      leds {
              led0 {
                      gpios = <&gpio1 2 GPIO_ACTIVE_HIGH>;
                      linux,default-trigger = "max8903-charger-charging";
                      retain-state-suspended;
                      function = LED_FUNCTION_CHARGE;
      简单来说就是指定 compatible = “gpio-leds” 就好了
      在根节点下添加:
      dtsleds {
       	led0 {
      	 	label = "red";
      	  	gpios = <&pio PD 13 GPIO_ACTIVE_HIGH>;
      实例:
      (四)使能内核的LED驱动
      路径参考:
      Symbol: LEDS_GPIO [=y]        │
       │ Type  : tristate        │
       │ Prompt: LED Support for GPIO connected LEDs        │
       │   Location:        │
       │     -> Device Drivers        │
       │       -> LED Support (NEW_LEDS [=y])        │
       │   Defined at drivers/leds/Kconfig:307        │
       │   Depends on: NEW_LEDS [=y] && LEDS_CLASS [=y] && (GPIOLIB [=y] || COMPILE_TEST [=n])                        │
       │   Selected by [n]:        │
       │   - PCENGINES_APU2 [=n] && X86 && X86_PLATFORM_DEVICES [=n] && INPUT [=y] && INPUT_KEYBOARD [=y] && \        │
       │ GPIOLIB [=y] && LEDS_CLASS [=y]
      然后编译烧写系统。
      (五)测试验证
      1、寻找设备树,在 /proc/device-tree 下
      2、点亮
      在 /sys/class/leds/red 下可以找到相关的属性
      下面使 brightness 属性为 1 .即可点亮
      echo 1 > /sys/class/leds/red/brightness
      继电器接通!!
      关闭的话,使用以下命令即可
      echo 0 > /sys/class/leds/red/brightness
      至此测试完毕
      原文链接:https://blog.csdn.net/qq_46079439/article/details/126131219
      作者@第四维度
