    A40I AP问题
      MasterLu LV 5 最后由 编辑
      A40I 用的RTL8723bu模块
      问题描述:AP模式不设置密码时可以连接上,设置密码后无法连接上。
      下面是启动hostapd时的log
      M 1 条回复 最后回复 回复 引用 分享 0
        MasterLu LV 5 @MasterLu 最后由 编辑
        @masterlu
        random: Trying to read entropy from /dev/random
        Configuration file: /etc/hostapd.conf
        nl80211: Supported cipher 00-0f-ac:1
        nl80211: Supported cipher 00-0f-ac:5
        nl80211: Supported cipher 00-0f-ac:2
        nl80211: Supported cipher 00-0f-ac:4
        nl80211: Using driver-based off-channel TX
        nl80211: key_mgmt=0xd0f enc=0xf auth=0x7 flags=0x800d8c0 rrm_flags=0x0 probe_resp_offloads=0x0 max_stations=0 max_remain_on_chan=5000 max_scan_ssids=9
        nl80211: interface wlan0 in phy phy0
        nl80211: Set mode ifindex 7 iftype 3 (AP)
        nl80211: Setup AP(wlan0) - device_ap_sme=1 use_monitor=0
        nl80211: Subscribe to mgmt frames with AP handle 0x1dfbdd0 (device SME)
        nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1dfbdd0 match=04 multicast=0
        nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1dfbdd0 match=0501 multicast=0
        nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1dfbdd0 match=0503 multicast=0
        nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1dfbdd0 match=0504 multicast=0
        nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1dfbdd0 match=06 multicast=0
        nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1dfbdd0 match=08 multicast=0
        nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1dfbdd0 match=09 multicast=0
        nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1dfbdd0 match=0a multicast=0
        nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1dfbdd0 match=11 multicast=0
        nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1dfbdd0 match=7f multicast=0
        nl80211: Register frame type=0xb0 (WLAN_FC_STYPE_AUTH) nl_handle=0x1dfbdd0 match= multicast=0
        nl80211: Enable Probe Request reporting nl_preq=0x1e00ea0
        nl80211: Register frame type=0x40 (WLAN_FC_STYPE_PROBE_REQ) nl_handle=0x1e00ea0 match= multicast=0
        rfkill: Cannot open RFKILL control device
        nl80211: RFKILL status not available
        nl80211: Add own interface ifindex 7 (ifidx_reason -1)
        nl80211: if_indices[16]: 7(-1)
        phy: phy0
        BSS count 1, BSSID mask 00:00:00:00:00:00 (0 bits)
        nl80211: No channel number found for frequency 5920 MHz
        nl80211: No channel number found for frequency 5940 MHz
        nl80211: Regulatory information - country=00
        nl80211: 2402-2472 @ 40 MHz 20 mBm
        nl80211: 2457-2482 @ 40 MHz 20 mBm (no IR)
        nl80211: 2474-2494 @ 20 MHz 20 mBm (no OFDM) (no IR)
        nl80211: 5170-5250 @ 80 MHz 20 mBm (no IR)
        nl80211: 5735-5835 @ 80 MHz 20 mBm (no IR)
        nl80211: 57240-63720 @ 2160 MHz 0 mBm
        nl80211: Added 802.11b mode based on 802.11g information
        nl80211: Mode IEEE 802.11g: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 2467[NO_IR] 2472[NO_IR] 2484[DISABLED]
        nl80211: Mode IEEE 802.11a: 5170[DISABLED] 5180[DISABLED] 5190[DISABLED] 5200[DISABLED] 5210[DISABLED] 5220[DISABLED] 5230[DISABLED] 5240[DISABLED] 5260[DISABLED] 5280[DISABLED] 5300[DISABLED] 5320[DISABLED] 5500[DISABLED]
        nl80211: Mode IEEE 802.11b: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 2467[NO_IR] 2472[NO_IR] 2484[DISABLED]
        Allowed channel: mode=1 chan=1 freq=2412 MHz max_tx_power=20 dBm
        Allowed channel: mode=1 chan=2 freq=2417 MHz max_tx_power=20 dBm
        Allowed channel: mode=1 chan=3 freq=2422 MHz max_tx_power=20 dBm
        Allowed channel: mode=1 chan=4 freq=2427 MHz max_tx_power=20 dBm
        Allowed channel: mode=1 chan=5 freq=2432 MHz max_tx_power=20 dBm
        Allowed channel: mode=1 chan=6 freq=2437 MHz max_tx_power=20 dBm
        Allowed channel: mode=1 chan=7 freq=2442 MHz max_tx_power=20 dBm
        Allowed channel: mode=1 chan=8 freq=2447 MHz max_tx_power=20 dBm
        Allowed channel: mode=1 chan=9 freq=2452 MHz max_tx_power=20 dBm
        Allowed channel: mode=1 chan=10 freq=2457 MHz max_tx_power=20 dBm
        Allowed channel: mode=1 chan=11 freq=2462 MHz max_tx_power=20 dBm
        Allowed channel: mode=0 chan=1 freq=2412 MHz max_tx_power=20 dBm
        Allowed channel: mode=0 chan=2 freq=2417 MHz max_tx_power=20 dBm
        Allowed channel: mode=0 chan=3 freq=2422 MHz max_tx_power=20 dBm
        Allowed channel: mode=0 chan=4 freq=2427 MHz max_tx_power=20 dBm
        Allowed channel: mode=0 chan=5 freq=2432 MHz max_tx_power=20 dBm
        Allowed channel: mode=0 chan=6 freq=2437 MHz max_tx_power=20 dBm
        Allowed channel: mode=0 chan=7 freq=2442 MHz max_tx_power=20 dBm
        Allowed channel: mode=0 chan=8 freq=2447 MHz max_tx_power=20 dBm
        Allowed channel: mode=0 chan=9 freq=2452 MHz max_tx_power=20 dBm
        Allowed channel: mode=0 chan=10 freq=2457 MHz max_tx_power=20 dBm
        Allowed channel: mode=0 chan=11 freq=2462 MHz max_tx_power=20 dBm
        Completing interface initialization
        Mode: IEEE 802.11g Channel: 3 Frequency: 2422 MHz
        DFS 0 channels required radar detection
        nl80211: Set freq 2422 (ht_enabled=0, vht_enabled=0, he_enabled=0, bandwidth=20 MHz, cf1=2422 MHz, cf2=0 MHz)
        • freq=2422
        • he_enabled=0
        • vht_enabled=0
        • ht_enabled=0
        • channel_type=0
          RATE[0] rate=10 flags=0x1
          RATE[1] rate=20 flags=0x1
          RATE[2] rate=55 flags=0x1
          RATE[3] rate=110 flags=0x1
          RATE[4] rate=60 flags=0x0
          RATE[5] rate=90 flags=0x0
          RATE[6] rate=120 flags=0x0
          RATE[7] rate=180 flags=0x0
          RATE[8] rate=240 flags=0x0
          RATE[9] rate=360 flags=0x0
          RATE[10] rate=480 flags=0x0
          RATE[11] rate=540 flags=0x0
          hostapd_setup_bss(hapd=0x1dfb060 (wlan0), first=1)
          nl80211: flush -> DEL_STATION wlan0 (all)
          Using interface wlan0 with hwaddr f0:c8:14:7b:5a:4b and ssid "hostapd_test"
          Deriving WPA PSK based on passphrase
          SSID - hexdump_ascii(len=12):
          68 6f 73 74 61 70 64 5f 74 65 73 74 hostapd_test
          PSK (ASCII passphrase) - hexdump_ascii(len=8): [REMOVED]
          PSK (from passphrase) - hexdump(len=32): [REMOVED]
          random: Got 20/20 random bytes
          Get randomness: len=32 entropy=0
          GMK - hexdump(len=32): [REMOVED]
          Key Counter - hexdump(len=32): [REMOVED]
          WPA: Delay group state machine start until Beacon frames have been configured
          nl80211: Set beacon (beacon_set=0)
          nl80211: Beacon head - hexdump(len=63): 80 00 00 00 ff ff ff ff ff ff f0 c8 14 7b 5a 4b f0 c8 14 7b 5a 4b 00 00 00 00 00 00 00 00 00 00 64 00 11 04 00 0c 68 6f 73 74 61 70 64 5f 74 65 73 74 01 08 82 84 8b 96 0c 12 18 24 03 01 03
          nl80211: Beacon tail - hexdump(len=35): 2a 01 04 32 04 30 48 60 6c 30 18 01 00 00 0f ac 02 02 00 00 0f ac 04 00 0f ac 02 01 00 00 0f ac 02 00 00
          nl80211: ifindex=7
          nl80211: beacon_int=100
          nl80211: beacon_rate=0
          nl80211: rate_type=0
          nl80211: dtim_period=2
          nl80211: ssid=hostapd_test
        • beacon_int=100
        • dtim_period=2
          nl80211: hidden SSID not in use
          nl80211: privacy=2
          nl80211: auth_algs=0x3
          nl80211: wpa_version=0x2
          nl80211: key_mgmt_suites=0x2
          nl80211: pairwise_ciphers=0x18
          nl80211: group_cipher=0x8
          wlan0: Deauthenticate all stations at BSS start
          nl80211: sta_remove -> DEL_STATION wlan0 ff:ff:ff:ff:ff:ff --> -22 (Invalid argument)
          WPA: Start group state machine to set initial keys
          WPA: group state machine entering state GTK_INIT (VLAN-ID 0)
          GTK - hexdump(len=32): [REMOVED]
          WPA: group state machine entering state SETKEYSDONE (VLAN-ID 0)
          wpa_driver_nl80211_set_key: ifindex=7 (wlan0) alg=2 addr=0x8560c key_idx=1 set_tx=1 seq_len=0 key_len=32 key_flag=0x1a
          nl80211: NEW_KEY
          nl80211: KEY_DATA - hexdump(len=32): [REMOVED]
          broadcast key
          nl80211: NL80211_CMD_SET_KEY - default key
          nl80211: Set wlan0 operstate 0->1 (UP)
          netlink: Operstate: ifindex=7 linkmode=-1 (no change), operstate=6 (IF_OPER_UP)
          nl80211: TX queue param set: queue=0 aifs=1 cw_min=3 cw_max=7 burst_time=15 --> res=-95
          Failed to set TX queue parameters for queue 0.
          nl80211: TX queue param set: queue=1 aifs=1 cw_min=7 cw_max=15 burst_time=30 --> res=-95
          Failed to set TX queue parameters for queue 1.
          nl80211: TX queue param set: queue=2 aifs=3 cw_min=15 cw_max=63 burst_time=0 --> res=-95
          Failed to set TX queue parameters for queue 2.
          nl80211: TX queue param set: queue=3 aifs=7 cw_min=15 cw_max=1023 burst_time=0 --> res=-95
          Failed to set TX queue parameters for queue 3.
          wlan0: interface state UNINITIALIZED->ENABLED
          wlan0: AP-ENABLED
          wlan0: Setup of interface done.
          ctrl_iface not configured!
          RTM_NEWLINK: ifi_index=7 ifname=wlan0 operstate=6 linkmode=0 ifi_family=0 ifi_flags=0x11043 ([UP][RUNNING][LOWER_UP])
          nl80211: Event message available
          nl80211: Drv Event 19 (NL80211_CMD_NEW_STATION) received for wlan0
          nl80211: New station 78:62:56:c1:26:31
          nl80211: Assoc Req IEs - hexdump(len=0): [NULL]
          wlan0: Event ASSOC (0) received
          wlan0: STA 78:62:56:c1:26:31 IEEE 802.11: associated
          STA did not include WPS/RSN/WPA IE in (Re)AssocReq
          New STA
          ap_sta_add: register ap_handle_timer timeout for 78:62:56:c1:26:31 (300 seconds - ap_max_inactivity)
          No WPA/RSN IE from STA
          nl80211: sta_remove -> DEL_STATION wlan0 78:62:56:c1:26:31 --> 0 (Success)
          nl80211: Set STA flags - ifname=wlan0 addr=78:62:56:c1:26:31 total_flags=0x0 flags_or=0x0 flags_and=0xfffffff1 authorized=0
          ap_free_sta: cancel ap_handle_timer for 78:62:56:c1:26:31
          nl80211: Drv Event 20 (NL80211_CMD_DEL_STATION) received for wlan0
          nl80211: Delete station 78:62:56:c1:26:31
          wlan0: Event DISASSOC (1) received
          wlan0: STA 78:62:56:c1:26:31 IEEE 802.11: disassociated
          Disassociation notification for unknown STA 78:62:56:c1:26:31
          New STA
          New STA
          New STA
        • Moved from Linux by  q1215200171 q1215200171
