    MangoPi Dual T113 主线内核编译记录
    9
    13
    18490
    • E
      Evlers LV 6 最后由 编辑
      awboot 编译(无需 SPL UBOOT 直接引导内核)
      # 交叉编译器需使用 arm-none-eabi-gcc 以下是我交叉编译器的版本
      gcc version 8.3.1 20190703 (release) [gcc-8-branch revision 273027] (GNU Tools for Arm Embedded Processors 8-2019-q3-update)
      # 下拉 awboot
      git clone https://github.com/szemzoa/awboot
      cd awboot
      # 编译工具
      cd tools
      gcc mksunxi.c -o mksunxi
      # 修改 Makefile 中的 /bin/expr 为 /usr/bin/expr
      	@/usr/bin/expr `/bin/cat .build_revision` + 1 > .build_revision
      # 编译 awboot
      make
      测试 awboot
      xfel write 0x30000 .\awboot.bin
      xfel exec 0x30000
      写入 awboot 到 TF 卡
      • 修改链接地址:arch/arm32/mach-t113s3/link.ld 文件中 ORIGIN = 0x00030000 修改为 ORIGIN = 0x00020000
      • 修改完链接地址后需要清除重新编译make clean all
      • 写入到 TF 卡中:sudo dd if=awboot.bin of=/dev/sdd bs=1024 seek=8
      内核编译
      • 这个是我修改好的主线稳定版内核(带WiFi):Linux-6.0.1
      • 也选择去官网下载内核:kernel
      • 修改 kernel.org 下载的内核源代码:
      # 修改 drivers/clk/sunxi-ng/Kconfig 文件
       config SUN20I_D1_CCU
       	tristate "Support for the Allwinner D1 CCU"
       	default RISCV && ARCH_SUNXI
      -	depends on (RISCV && ARCH_SUNXI) || COMPILE_TEST
      +	depends on (ARCH_SUNXI) || COMPILE_TEST
       config SUN20I_D1_R_CCU
       	tristate "Support for the Allwinner D1 PRCM CCU"
      # 修改 drivers/clk/sunxi-ng/ccu-sun20i-d1.c 文件
       static SUNXI_CCU_MUX_DATA(cpux_clk, "cpux", cpux_parents,
      -			  0x500, 24, 3, CLK_SET_RATE_PARENT);
      +			  0x500, 24, 3, CLK_SET_RATE_PARENT | CLK_IS_CRITICAL);
      # 修改 arch/arm/mach-sunxi/platsmp.c 文件,在末尾添加以下内容
      static int sun8i_t113_smp_boot_secondary(unsigned int cpu,
      				    struct task_struct *idle)
          u32 reg;
          void __iomem *cpucfg_membase = ioremap(0x09010000, 0x10);
          void __iomem *cpuexec_membase[] = {ioremap(0x070005C4, 0x10),ioremap(0x070005C8, 0x10)};
      	if (cpu != 1)
      	spin_lock(&cpu_lock);
      	/* Set CPU boot address */
      	writel(__pa_symbol(secondary_startup),	cpuexec_membase[cpu]);
      	/* Deassert the CPU core reset */
      	reg = readl(cpucfg_membase);
      	writel(reg | BIT(cpu), cpucfg_membase);
      	spin_unlock(&cpu_lock);
      static const struct smp_operations sun8i_t113_smp_ops __initconst = {
      	.smp_boot_secondary	= sun8i_t113_smp_boot_secondary,
      CPU_METHOD_OF_DECLARE(sun8i_t113_smp, "allwinner,sun8iw20p1", &sun8i_t113_smp_ops);
      配置内核
      • 先使用默认配置make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- sunxi_defconfig
      • 再打开内核配置 make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- menuconfig
      • 打开芯片时钟支持:
      > Device Drivers
      	> Common Clock Framework
      		<*>   Clock support for Allwinner SoCs
      			<*>     Support for the Allwinner D1 CCU
      			<*>     Support for the Allwinner D1 PRCM CCU
      添加设备树
      • 将设备树添加到内核 arch/arm/boot/dts/ 目录中:sun8i-t113-mangopi-dual.dts sun8i-t113.dtsi
      • 并在该目录 Makefile 文件中的CONFIG_MACH_SUN8I下添加改设备树文件:
      dtb-$(CONFIG_MACH_SUN8I) += \
      	sun8i-a23-evb.dtb \
      	sun8i-a23-gt90h-v4.dtb \
      	sun8i-a23-inet86dz.dtb \
      	sun8i-v3s-licheepi-zero-dock.dtb \
      	sun8i-v40-bananapi-m2-berry.dtb \
      	sun8i-t113-mangopi-dual.dtb
      编译
      # 编译内核,设备树以及模块
      make -j48 ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- zImage dtbs modules
      # 内核文件
      arch/arm/boot/zImage
      # 设备树文件
      arch/arm/boot/dts/sun8i-t113-mangopi-dual.dtb
      启动日志
      Allwinner T113-loader
      DRAM SIZE = 128M
      DRAM simple test OK.
      CPU freq=1200 MHz
      SD/MMC card at 'sdhci0' controller found
      SD/MMC: Image: Read file zImage addr=45000000
      SD/MMC: dt blob: Read file sun8i-t113-mangopi-dual.dtb addr=41800000
      booting linux...
      [    0.000000] Linux version 6.0.1-g75e3c08038b8 (evler@DESKTOP-6BPS301) (arm-linux-gnueabihf-gcc (Ubuntu/Linaro 7.5.0-3ubuntu1~18.04) 7.5.0, GNU ld (GNU Binutils for Ubuntu) 2.30) #1 SMP Fri Oct 14 20:36:14 CST 2022
      [    0.000000] OF: fdt: Machine model: MangoPi MQ-Dual
      [    0.000000] cma: Reserved 72 MiB at 0x43800000
      [    0.000000] Zone ranges:
      [    0.000000]   Normal   [mem 0x0000000040000000-0x0000000047ffffff]
      [    0.000000]   HighMem  empty
      [    0.000000]   node   0: [mem 0x0000000040000000-0x0000000047ffffff]
      [    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x0000000047ffffff]
      [    0.000000] percpu: Embedded 11 pages/cpu s15508 r8192 d21356 u45056
      [    0.000000] Kernel command line: mem=128M cma=72M root=/dev/mmcblk0p2 init=/sbin/init rootwait console=tty0 console=ttyS5,115200
      [    0.000000] Memory: 43384K/131072K available (7168K kernel code, 942K rwdata, 2104K rodata, 1024K init, 266K bss, 13960K reserved, 73728K cma-reserved, 0K highmem)
      [    0.000000] rcu: Hierarchical RCU implementation.
      [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=2.
      [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
      [    0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
      [    0.000013] Switching to timer-based delay loop, resolution 41ns
      [    0.000189] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
      [    0.000686] Console: colour dummy device 80x30
      [    0.000998] printk: console [tty0] enabled
      [    0.001042] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      [    0.001071] pid_max: default: 32768 minimum: 301
      [    0.001240] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.001276] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.001835] CPU: Testing write buffer coherency: ok
      [    0.002166] /cpus/cpu@0 missing clock-frequency property
      [    0.002215] /cpus/cpu@1 missing clock-frequency property
      [    0.002237] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      [    0.003020] Setting up static identity map for 0x40100000 - 0x40100060
      [    0.003193] rcu: Hierarchical SRCU implementation.
      [    0.003213] rcu:     Max phase no-delay instances is 1000.
      [    0.003749] smp: Bringing up secondary CPUs ...
      [    0.004454] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      [    0.004581] smp: Brought up 1 node, 2 CPUs
      [    0.004622] SMP: Total of 2 processors activated (96.00 BogoMIPS).
      [    0.004638] CPU: All CPU(s) started in SVC mode.
      [    0.005159] devtmpfs: initialized
      [    0.009273] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
      [    0.009513] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.009556] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
      [    0.011856] pinctrl core: initialized pinctrl subsystem
      [    0.013201] NET: Registered PF_NETLINK/PF_ROUTE protocol family
      [    0.014339] DMA: preallocated 256 KiB pool for atomic coherent allocations
      [    0.015229] thermal_sys: Registered thermal governor 'step_wise'
      [    0.015529] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
      [    0.015578] hw-breakpoint: maximum watchpoint size is 8 bytes.
      [    0.023287] platform 5460000.tcon-top: Fixing up cyclic dependency with 5200000.mixer
      [    0.023396] platform 5460000.tcon-top: Fixing up cyclic dependency with 5100000.mixer
      [    0.023705] platform 5461000.lcd-controller: Fixing up cyclic dependency with 5460000.tcon-top
      [    0.024089] platform 5470000.lcd-controller: Fixing up cyclic dependency with 5604000.tv-encoder
      [    0.024169] platform 5470000.lcd-controller: Fixing up cyclic dependency with 5460000.tcon-top
      [    0.025007] platform 7090000.rtc: Fixing up cyclic dependency with 7010000.clock-controller
      [    0.035143] SCSI subsystem initialized
      [    0.035656] usbcore: registered new interface driver usbfs
      [    0.035715] usbcore: registered new interface driver hub
      [    0.035764] usbcore: registered new device driver usb
      [    0.035998] mc: Linux media interface: v0.10
      [    0.036059] videodev: Linux video capture interface: v2.00
      [    0.036145] pps_core: LinuxPPS API ver. 1 registered
      [    0.036162] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
      [    0.036192] PTP clock support registered
      [    0.036650] Advanced Linux Sound Architecture Driver Initialized.
      [    0.037823] clocksource: Switched to clocksource arch_sys_counter
      [    0.045181] NET: Registered PF_INET protocol family
      [    0.045408] IP idents hash table entries: 2048 (order: 2, 16384 bytes, linear)
      [    0.045967] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
      [    0.046019] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
      [    0.046044] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.046076] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
      [    0.046105] TCP: Hash tables configured (established 1024 bind 1024)
      [    0.046201] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    0.046248] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    0.046434] NET: Registered PF_UNIX/PF_LOCAL protocol family
      [    0.047125] RPC: Registered named UNIX socket transport module.
      [    0.047166] RPC: Registered udp transport module.
      [    0.047180] RPC: Registered tcp transport module.
      [    0.047192] RPC: Registered tcp NFSv4.1 backchannel transport module.
      [    0.048343] Initialise system trusted keyrings
      [    0.048634] workingset: timestamp_bits=30 max_order=15 bucket_order=0
      [    0.053533] NFS: Registering the id_resolver key type
      [    0.053617] Key type id_resolver registered
      [    0.053634] Key type id_legacy registered
      [    0.053689] Key type asymmetric registered
      [    0.053705] Asymmetric key parser 'x509' registered
      [    0.053840] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
      [    0.053866] io scheduler mq-deadline registered
      [    0.053879] io scheduler kyber registered
      [    0.112158] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
      [    0.121805] CAN device driver interface
      [    0.122573] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [    0.122600] ehci-platform: EHCI generic platform driver
      [    0.122740] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [    0.122778] ohci-platform: OHCI generic platform driver
      [    0.125187] sun6i-rtc 7090000.rtc: registered as rtc0
      [    0.125338] sun6i-rtc 7090000.rtc: setting system clock to 1970-01-02T00:10:37 UTC (87037)
      [    0.125500] sun6i-rtc 7090000.rtc: RTC enabled
      [    0.125852] i2c_dev: i2c /dev entries driver
      [    0.127617] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
      [    0.128870] sun8i-ce 3040000.crypto: Set mod clock to 300000000 (300 Mhz) from 400000000 (400 Mhz)
      [    0.129231] sun8i-ce 3040000.crypto: will run requests pump with realtime priority
      [    0.129586] sun8i-ce 3040000.crypto: will run requests pump with realtime priority
      [    0.129826] sun8i-ce 3040000.crypto: will run requests pump with realtime priority
      [    0.130039] sun8i-ce 3040000.crypto: will run requests pump with realtime priority
      [    0.130195] sun8i-ce 3040000.crypto: Register cbc(aes)
      [    0.130230] sun8i-ce 3040000.crypto: Register ecb(aes)
      [    0.130249] sun8i-ce 3040000.crypto: Register cbc(des3_ede)
      [    0.130268] sun8i-ce 3040000.crypto: Register ecb(des3_ede)
      [    0.130307] sun8i-ce 3040000.crypto: CryptoEngine Die ID 0
      [    0.131201] usbcore: registered new interface driver usbhid
      [    0.131233] usbhid: USB HID core driver
      [    0.133879] NET: Registered PF_PACKET protocol family
      [    0.133934] can: controller area network core
      [    0.134023] NET: Registered PF_CAN protocol family
      [    0.134045] can: raw protocol
      [    0.134058] can: broadcast manager protocol
      [    0.134075] can: netlink gateway - max_hops=1
      [    0.134293] Key type dns_resolver registered
      [    0.134448] Registering SWP/SWPB emulation handler
      [    0.134555] Loading compiled-in X.509 certificates
      [    0.152533] sun20i-d1-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
      [    0.174214] 2500400.serial: ttyS1 at MMIO 0x2500400 (irq = 231, base_baud = 1500000) is a 16550A
      [    0.195942] 2501400.serial: ttyS5 at MMIO 0x2501400 (irq = 232, base_baud = 1500000) is a 16550A
      [    1.049330] printk: console [ttyS5] enabled
      [    1.055564] phy phy-4100400.phy.0: Changing dr_mode to 1
      [    1.056783] usb_phy_generic usb_phy_generic.1.auto: dummy supplies not allowed for exclusive requests
      [    1.060995] ehci-platform 4101000.usb: EHCI Host Controller
      [    1.070724] musb-hdrc musb-hdrc.2.auto: MUSB HDRC host driver
      [    1.075755] ehci-platform 4101000.usb: new USB bus registered, assigned bus number 1
      [    1.081516] musb-hdrc musb-hdrc.2.auto: new USB bus registered, assigned bus number 2
      [    1.090282] ehci-platform 4200000.usb: EHCI Host Controller
      [    1.097935] hub 2-0:1.0: USB hub found
      [    1.104550] ohci-platform 4200400.usb: Generic Platform OHCI controller
      [    1.106450] hub 2-0:1.0: 1 port detected
      [    1.117184] ehci-platform 4101000.usb: irq 233, io mem 0x04101000
      [    1.123361] ehci-platform 4200000.usb: new USB bus registered, assigned bus number 3
      [    1.127942] ohci-platform 4200400.usb: new USB bus registered, assigned bus number 4
      [    1.140803] ehci-platform 4200000.usb: irq 235, io mem 0x04200000
      [    1.147129] sunxi-mmc 4020000.mmc: Got CD GPIO
      [    1.148376] ehci-platform 4101000.usb: USB 2.0 started, EHCI 1.00
      [    1.157972] ohci-platform 4200400.usb: irq 237, io mem 0x04200400
      [    1.159104] ALSA device list:
      [    1.167091]   No soundcards found.
      [    1.171251] sunxi-mmc 4021000.mmc: allocated mmc-pwrseq
      [    1.176832] hub 1-0:1.0: USB hub found
      [    1.177242] sunxi-mmc 4020000.mmc: initialized, max. request size: 2048 KB, uses new timings mode
      [    1.180665] ehci-platform 4200000.usb: USB 2.0 started, EHCI 1.00
      [    1.195722] hub 1-0:1.0: 1 port detected
      [    1.200970] hub 3-0:1.0: USB hub found
      [    1.204802] hub 3-0:1.0: 1 port detected
      [    1.212314] sunxi-mmc 4021000.mmc: initialized, max. request size: 2048 KB, uses new timings mode
      [    1.229522] sunxi-mmc 4021000.mmc: card claims to support voltages below defined range
      [    1.232548] hub 4-0:1.0: USB hub found
      [    1.241326] hub 4-0:1.0: 1 port detected
      [    1.257235] mmc1: new high speed SDIO card at address 0001
      [    1.284358] mmc0: new high speed SDHC card at address aaaa
      [    1.290803] mmcblk0: mmc0:aaaa SL32G 29.7 GiB
      [    1.300997]  mmcblk0: p1 p2
      [    1.307944] ohci-platform 4101400.usb: Generic Platform OHCI controller
      [    1.314620] ohci-platform 4101400.usb: new USB bus registered, assigned bus number 5
      [    1.322709] ohci-platform 4101400.usb: irq 236, io mem 0x04101400
      [    1.402615] hub 5-0:1.0: USB hub found
      [    1.406430] hub 5-0:1.0: 1 port detected
      [    1.443652] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: disabled.
      [    1.452694] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [    1.467648] devtmpfs: mounted
      [    1.471630] Freeing unused kernel image (initmem) memory: 1024K
      [    1.478021] Run /sbin/init as init process
      [    1.840340] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: disabled.
      Starting syslogd: OK
      Starting klogd: OK
      Running sysctl: OK
      Starting mdev... OK
      [    2.771703] cfg80211: Loading compiled-in X.509 certificates for regulatory database
      [    2.815733] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
      Initializing random number generator: OK
      Saving random seed: [    5.777828] random: crng init done
      OK
      Starting system message bus: done
      Starting network: OK
      Starting WiFi: Successfully initialized wpa_supplicant
      OK
      udhcpc: started, v1.35.0
      udhcpc: broadcasting discover
      Starting sshd: OK
      Welcome to MangoPi Dual
      buildroot login: root
      [root@buildroot]:~$ udhcpc: broadcasting discover
      udhcpc: broadcasting select for 192.168.10.211, server 192.168.10.251
      udhcpc: lease of 192.168.10.211 obtained from 192.168.10.251, lease time 43200
      deleting routers
      adding dns 192.168.10.251
      [root@buildroot]:~$ free -h
                    total        used        free      shared  buff/cache   available
      Mem:         115.4M       12.7M       79.8M       60.0K       22.8M       97.0M
      Swap:             0           0           0
      [root@buildroot]:~$ df -h
      /dev/root                29.0G     21.8M     27.4G   0% /
      devtmpfs                 21.2M         0     21.2M   0% /dev
      tmpfs                    57.7M         0     57.7M   0% /dev/shm
      tmpfs                    57.7M     32.0K     57.7M   0% /tmp
      tmpfs                    57.7M     28.0K     57.7M   0% /run
      [root@buildroot]:~$ uname -a
      Linux buildroot 6.0.1-g75e3c08038b8 #1 SMP Fri Oct 14 20:36:14 CST 2022 armv7l GNU/Linux
      [root@buildroot]:~$ iperf3 -s
      warning: this system does not seem to support IPv6 - trying IPv4
      Server listening on 5201 (test #1)
      Accepted connection from 192.168.10.246, port 8252
      [  5] local 192.168.10.211 port 5201 connected to 192.168.10.246 port 8254
      [ ID] Interval           Transfer     Bitrate
      [  5]   0.00-1.00   sec  3.92 MBytes  32.9 Mbits/sec
      [  5]   1.00-2.00   sec  5.59 MBytes  46.9 Mbits/sec
      [  5]   2.00-3.00   sec  5.49 MBytes  46.1 Mbits/sec
      [  5]   3.00-4.00   sec  5.69 MBytes  47.7 Mbits/sec
      [  5]   4.00-5.00   sec  5.76 MBytes  48.3 Mbits/sec
      [  5]   5.00-6.00   sec  5.72 MBytes  48.0 Mbits/sec
      [  5]   6.00-7.00   sec  5.79 MBytes  48.5 Mbits/sec
      [  5]   7.00-8.00   sec  5.54 MBytes  46.5 Mbits/sec
      [  5]   8.00-9.00   sec  5.48 MBytes  45.9 Mbits/sec
      [  5]   9.00-10.00  sec  5.70 MBytes  47.8 Mbits/sec
      [  5]  10.00-10.04  sec   239 KBytes  48.0 Mbits/sec
      [  5]   0.00-10.04  sec  54.9 MBytes  45.9 Mbits/sec                  receiver
      Server listening on 5201 (test #2)
      给 TF 卡分区以及跟文件系统的制作等,这里就不再讲解,可以参考我写的另一篇帖子:MQ-Quad H616 主线内核编译调试记录(u-boot、kernel、buildroot)
      X S 2 条回复 最后回复 回复 引用 分享 5
      • ftwtwzy
        ftwtwzy LV 6 最后由 编辑
        主线,主线😊
        • Referenced by  ftwtwzy ftwtwzy
        • X
          xiaok LV 3 @evler 最后由 编辑
          X 1 条回复 最后回复 回复 引用 分享 0
          • X
            xiaok LV 3 @xiaok 最后由 编辑
            • baiwen
              100ask LV 6 最后由 编辑
              @evler 在 MangoPi Dual T113 主线内核编译记录 中说:
              神奇,使用百问网的t113 pro开发板,不管改不改内核设备树里面的 uart接口,都是boot启动不了 内核,明天再排查排查🤒
              ftwtwzy 1 条回复 最后回复 回复 引用 分享 0
              • ftwtwzy
                ftwtwzy LV 6 @baiwen 最后由 编辑
                @allwinnertech 在 MangoPi Dual T113 主线内核编译记录 中说:
                看看这个,希望能用到
                https://whycan.com/t_9231.html
                baiwen 1 条回复 最后回复 回复 引用 分享 0
                • baiwen
                  100ask LV 6 @ftwtwzy 最后由 编辑
                  @ftwtwzy 好的,谢谢
                  Q 1 条回复 最后回复 回复 引用 分享 0
                  • Q
                    qq978815410 LV 3 @baiwen 最后由 编辑
                    @baiwen 大佬,有弄出来吗?我用你们百问网的板子也是这个问题,启动不了内核?nand型号是MX35LF1GE4AB
                      duanzhh LV 5 最后由 编辑
                      大佬 ,yyds
                        duanzhh LV 5 最后由 编辑
                        @evler 大佬你好哈!我拉了你的https://github.com/Evlers/linux_kernel_t113.git然后使用mangopi_dual_t113_defconfig配置文件,设备树中加了uart3配置;启动方式使用:uboot + linux6.0.1+buildroot rootfs;但是出现了奇怪的现象:CPU1: failed to come online cpu1启动失败; 请教大佬有什么什么思路提供?十分感谢😂 启动log如下:
                        U-Boot 2018.05 (Mar 21 2023 - 08:00:44 +0000) Allwinner Technology
                        [00.336]CPU:   Allwinner Family
                        [00.339]Model: sun8iw20
                        [00.341]DRAM:  128 MiB
                        [00.344]Relocation Offset is: 04ec5000
                        [00.371]secure enable bit: 0
                        [00.384]smc_tee_inform_fdt failed with: -65536[00.388]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
                        [00.394]gic: sec monitor mode
                        [00.397]flash init start
                        [00.399]workmode = 0,storage type = 2
                        [00.402][mmc]: mmc driver ver uboot2018:2021-09-07 19:43:00
                        [00.409][mmc]: SUNXI SDMMC Controller Version:0x50310
                        [00.437][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 4
                        [00.443]sunxi flash init ok
                        [00.446]line:703 init_clocks
                        [00.449]drv_disp_init
                        [00.463]drv_disp_init finish
                        [00.466]boot_gui_init:start
                        [00.469]set disp.dev2_output_type fail. using defval=0
                        [00.475]boot_gui_init:finish
                        [00.494]bmp_name=bootlogo.bmp size 1152054
                        1152054 bytes read in 47 ms (23.4 MiB/s)
                        [00.655]LCD open finish
                        [00.657]Loading Environment from SUNXI_FLASH... OK
                        [00.685]Item0 (Map) magic is bad
                        [00.688]the secure storage item0 copy0 magic is bad
                        [00.696]Item0 (Map) magic is bad
                        [00.699]the secure storage item0 copy1 magic is bad
                        [00.704]Item0 (Map) magic is bad
                        [00.710]secure storage read widevine fail with:-1
                        [00.717]secure storage read ec_key fail with:-1
                        [00.724]secure storage read ec_cert1 fail with:-1
                        [00.732]secure storage read ec_cert2 fail with:-1
                        [00.739]secure storage read ec_cert3 fail with:-1
                        [00.746]secure storage read rsa_key fail with:-1
                        [00.754]secure storage read rsa_cert1 fail with:-1
                        [00.761]secure storage read rsa_cert2 fail with:-1
                        [00.769]secure storage read rsa_cert3 fail with:-1
                        [00.774]usb burn from boot
                        delay time 0
                        weak:otg_phy_config
                        [00.785]usb prepare ok
                        [00.992]usb sof ok
                        [00.993]usb probe ok
                        [00.995]usb setup ok
                        set address 0x40
                        set address 0x40 ok
                        try to update
                        [04.000]do_burn_from_boot usb : have no handshake
                        List file under ULI/factory
                        [04.023]update part info
                        [04.026]update bootcmd
                        [04.044]replace fdt from raw partition(dtb) success
                        [04.049][mmc]: no mmc-hs400-1_8v!
                        [04.052][mmc]: no mmc-hs200-1_8v!
                        [04.055][mmc]: get max-frequency ok 50000000 Hz
                        [04.061]## error: update_fdt_dram_para : FDT_ERR_NOTFOUND
                        [04.068]update dts
                        [07.313]no vendor_boot partition is found
                        ## Transferring control to Linux (at address 40008000)...
                        ## Linux machid: 00000000, FDT addr: 41800000
                        [07.337]Starting kernel ...
                        [07.339][mmc]: mmc exit start
                        [07.358][mmc]: mmc 2 exit ok
                        [    0.000000] Linux version 6.0.1-gd7d8c971c9c5-dirty (dzh@compile) (arm-none-linux-gnueabihf-gcc (GNU Toolchain for the A-profile Architecture 10.3-2021.07 (arm-10.29)) 10.3.1 20210621, GNU ld (GNU Toolchain for the A-profile Architecture 10.3-2021.07 (arm-10.29)) 2.36.1.20210621) #4 SMP Mon Apr 24 10:54:04 UTC 2023
                        [    0.000000] cma: Reserved 16 MiB at 0x47000000
                        [    0.000000] pcpu-alloc: s15508 r8192 d21356 u45056 alloc=11*4096
                        [    0.000000] Kernel command line: earlycon=sunxi-uart,0x02500C00 clk_ignore_unused initcall_debug=0 console=ttyS3,115200 loglevel=8 root=/dev/mmcblk2p5 init=/init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:dtb@mmcblk0p6:dsp0@mmcblk0p7:private@mmcblk0p8:UDISK@mmcblk0p9 cma=16M snum= mac_addr= wifi_mac= bt_mac= specialstr= replace_fdt=dtb:raw gpt=1 androidboot.hardware=sun8iw20p1 boot_type=2 androidboot.boot_type=2 gpt=1 uboot_message=2018.05(03/21/2023-08:00:44) disp_reserve=2457600,0x448ee000 androidboot.dramsize=128
                        [    0.000000] Unknown kernel command line parameters "partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:dtb@mmcblk0p6:dsp0@mmcblk0p7:private@mmcblk0p8:UDISK@mmcblk0p9 snum= mac_addr= wifi_mac= bt_mac= specialstr= replace_fdt=dtb:raw boot_type=2 uboot_message=2018.05(03/21/2023-08:00:44) disp_reserve=2457600,0x448ee000", will be passed to user space.
                        [    0.000000] Memory: 97312K/131072K available (8192K kernel code, 942K rwdata, 2100K rodata, 1024K init, 263K bss, 17376K reserved, 16384K cma-reserved, 0K highmem)
                        [    0.000000] rcu:     RCU event tracing is enabled.
                        [    0.000014] Switching to timer-based delay loop, resolution 41ns
                        [    0.000220] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
                        [    0.000808] Console: colour dummy device 80x30
                        [    0.000855] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
                        [    0.000872] pid_max: default: 32768 minimum: 301
                        [    0.001043] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
                        [    0.001060] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
                        [    0.001653] CPU: Testing write buffer coherency: ok
                        [    0.001985] /cpus/cpu@0 missing clock-frequency property
                        [    0.002019] /cpus/cpu@1 missing clock-frequency property
                        [    0.002031] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
                        [    0.002915] Setting up static identity map for 0x40100000 - 0x40100060
                        [    0.003075] rcu: Hierarchical SRCU implementation.
                        [    0.003081] rcu:     Max phase no-delay instances is 1000.
                        [    0.003672] smp: Bringing up secondary CPUs ...
                        [    1.040373] CPU1: failed to come online
                        [    1.040455] smp: Brought up 1 node, 1 CPU
                        [    1.040466] SMP: Total of 1 processors activated (48.00 BogoMIPS).
                        [    1.040474] CPU: All CPU(s) started in SVC mode.
                        [    1.040991] devtmpfs: initialized
                        [    1.045887] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
                        [    1.046098] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
                        [    1.046121] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
                        [    1.046780] pinctrl core: initialized pinctrl subsystem
                        [    1.048133] NET: Registered PF_NETLINK/PF_ROUTE protocol family
                        [    1.049097] DMA: preallocated 256 KiB pool for atomic coherent allocations
                        [    1.049984] thermal_sys: Registered thermal governor 'step_wise'
                        [    1.050300] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
                        [    1.050313] hw-breakpoint: maximum watchpoint size is 8 bytes.
                        [    1.059372] platform 5460000.tcon-top: Fixing up cyclic dependency with 5200000.mixer
                        [    1.059460] platform 5460000.tcon-top: Fixing up cyclic dependency with 5100000.mixer
                        [    1.059772] platform 5461000.lcd-controller: Fixing up cyclic dependency with 5460000.tcon-top
                        [    1.060184] platform 5470000.lcd-controller: Fixing up cyclic dependency with 5604000.tv-encoder
                        [    1.060246] platform 5470000.lcd-controller: Fixing up cyclic dependency with 5460000.tcon-top
                        [    1.061241] platform 7090000.rtc: Fixing up cyclic dependency with 7010000.clock-controller
                        [    1.072642] SCSI subsystem initialized
                        [    1.072982] libata version 3.00 loaded.
                        [    1.073187] usbcore: registered new interface driver usbfs
                        [    1.073230] usbcore: registered new interface driver hub
                        [    1.073274] usbcore: registered new device driver usb
                        [    1.073491] mc: Linux media interface: v0.10
                        [    1.073537] videodev: Linux video capture interface: v2.00
                        [    1.073620] pps_core: LinuxPPS API ver. 1 registered
                        [    1.073626] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
                        [    1.073642] PTP clock support registered
                        [    1.074104] Advanced Linux Sound Architecture Driver Initialized.
                        [    1.075410] clocksource: Switched to clocksource arch_sys_counter
                        [    1.084034] NET: Registered PF_INET protocol family
                        [    1.084250] IP idents hash table entries: 2048 (order: 2, 16384 bytes, linear)
                        [    1.084872] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
                        [    1.084902] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
                        [    1.084914] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
                        [    1.084933] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
                        [    1.084955] TCP: Hash tables configured (established 1024 bind 1024)
                        [    1.085042] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
                        [    1.085078] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
                        [    1.085247] NET: Registered PF_UNIX/PF_LOCAL protocol family
                        [    1.086082] RPC: Registered named UNIX socket transport module.
                        [    1.086095] RPC: Registered udp transport module.
                        [    1.086099] RPC: Registered tcp transport module.
                        [    1.086103] RPC: Registered tcp NFSv4.1 backchannel transport module.
                        [    1.087195] Initialise system trusted keyrings
                        [    1.087600] workingset: timestamp_bits=30 max_order=15 bucket_order=0
                        [    1.093369] NFS: Registering the id_resolver key type
                        [    1.093445] Key type id_resolver registered
                        [    1.093450] Key type id_legacy registered
                        [    1.093495] Key type asymmetric registered
                        [    1.093501] Asymmetric key parser 'x509' registered
                        [    1.093644] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
                        [    1.093653] io scheduler mq-deadline registered
                        [    1.093659] io scheduler kyber registered
                        [    1.161629] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
                        [    1.173166] CAN device driver interface
                        [    1.173999] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
                        [    1.174008] ehci-platform: EHCI generic platform driver
                        [    1.174170] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
                        [    1.174188] ohci-platform: OHCI generic platform driver
                        [    1.177381] sun6i-rtc 7090000.rtc: registered as rtc0
                        [    1.177505] sun6i-rtc 7090000.rtc: setting system clock to 1970-01-02T02:16:51 UTC (94611)
                        [    1.177648] sun6i-rtc 7090000.rtc: RTC enabled
                        [    1.178010] i2c_dev: i2c /dev entries driver
                        [    1.180267] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
                        [    1.181614] sun8i-ce 3040000.crypto: Set mod clock to 300000000 (300 Mhz) from 400000000 (400 Mhz)
                        [    1.182182] sun8i-ce 3040000.crypto: will run requests pump with realtime priority
                        [    1.182528] sun8i-ce 3040000.crypto: will run requests pump with realtime priority
                        [    1.182722] sun8i-ce 3040000.crypto: will run requests pump with realtime priority
                        [    1.182898] sun8i-ce 3040000.crypto: will run requests pump with realtime priority
                        [    1.183026] sun8i-ce 3040000.crypto: Register cbc(aes)
                        [    1.183048] sun8i-ce 3040000.crypto: Register ecb(aes)
                        [    1.183058] sun8i-ce 3040000.crypto: Register cbc(des3_ede)
                        [    1.183068] sun8i-ce 3040000.crypto: Register ecb(des3_ede)
                        [    1.183101] sun8i-ce 3040000.crypto: CryptoEngine Die ID 0
                        [    1.184076] usbcore: registered new interface driver usbhid
                        [    1.184087] usbhid: USB HID core driver
                        [    1.187146] NET: Registered PF_PACKET protocol family
                        [    1.187175] can: controller area network core
                        [    1.187252] NET: Registered PF_CAN protocol family
                        [    1.187260] can: raw protocol
                        [    1.187267] can: broadcast manager protocol
                        [    1.187276] can: netlink gateway - max_hops=1
                        [    1.187471] Key type dns_resolver registered
                        [    1.187623] Registering SWP/SWPB emulation handler
                        [    1.187832] Loading compiled-in X.509 certificates
                        [    1.208135] sun20i-d1-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
                        [    1.209548] printk: console [ttyS3] disabled
                        [    1.230007] 2500c00.serial: ttyS3 at MMIO 0x2500c00 (irq = 231, base_baud = 1500000) is a 16550A
                        [    2.178859] printk: console [ttyS3] enabled
                        [    2.204847] 2501400.serial: ttyS5 at MMIO 0x2501400 (irq = 232, base_baud = 1500000) is a 16550A
                        [    2.215167] usb_phy_generic usb_phy_generic.1.auto: dummy supplies not allowed for exclusive requests
                        [    2.225071] musb-hdrc musb-hdrc.2.auto: MUSB HDRC host driver
                        [    2.230897] musb-hdrc musb-hdrc.2.auto: new USB bus registered, assigned bus number 1
                        [    2.239740] hub 1-0:1.0: USB hub found
                        [    2.243541] hub 1-0:1.0: 1 port detected
                        [    2.253220] ehci-platform 4200000.usb: EHCI Host Controller
                        [    2.258914] ehci-platform 4200000.usb: new USB bus registered, assigned bus number 2
                        [    2.272228] clk: Not disabling unused clocks
                        [    2.276598] ALSA device list:
                        [    2.279570]   No soundcards found.
                        [    2.284167] ohci-platform 4200400.usb: Generic Platform OHCI controller
                        [    2.290866] ohci-platform 4200400.usb: new USB bus registered, assigned bus number 3
                        [    2.303754] sunxi-mmc 4021000.mmc: allocated mmc-pwrseq
                        [    2.309379] sunxi-mmc 4020000.mmc: Got CD GPIO
                        [    2.314452] ehci-platform 4200000.usb: irq 236, io mem 0x04200000
                        [    2.320988] ohci-platform 4200400.usb: irq 238, io mem 0x04200400
                        [    2.333396] sunxi-mmc 4021000.mmc: initialized, max. request size: 2048 KB, uses new timings mode
                        [    2.342661] sunxi-mmc 4022000.mmc: initialized, max. request size: 2048 KB, uses new timings mode
                        [    2.351779] ehci-platform 4200000.usb: USB 2.0 started, EHCI 1.00
                        [    2.358612] sunxi-mmc 4020000.mmc: initialized, max. request size: 2048 KB, uses new timings mode
                        [    2.368826] hub 2-0:1.0: USB hub found
                        [    2.372769] hub 2-0:1.0: 1 port detected
                        [    2.400219] hub 3-0:1.0: USB hub found
                        [    2.404026] hub 3-0:1.0: 1 port detected
                        [    2.627342] mmc2: new DDR MMC card at address 0001
                        [    2.633091] mmcblk2: mmc2:0001 AT20S1 112 MiB
                        [    2.646550]  mmcblk2: p1 p2 p3 p4 p5 p6 p7 p8 p9
                        [    2.653100] mmcblk2boot0: mmc2:0001 AT20S1 128 KiB
                        [    2.659816] mmcblk2boot1: mmc2:0001 AT20S1 128 KiB
                        [    3.285511] phy phy-4100400.phy.0: Changing dr_mode to 1
                        [    3.290867] ehci-platform 4101000.usb: EHCI Host Controller
                        [    3.296491] ehci-platform 4101000.usb: new USB bus registered, assigned bus number 4
                        [    3.304505] ehci-platform 4101000.usb: irq 235, io mem 0x04101000
                        [    3.335408] ehci-platform 4101000.usb: USB 2.0 started, EHCI 1.00
                        [    3.342324] hub 4-0:1.0: USB hub found
                        [    3.346195] hub 4-0:1.0: 1 port detected
                        [    3.515485] ohci-platform 4101400.usb: Generic Platform OHCI controller
                        [    3.522134] ohci-platform 4101400.usb: new USB bus registered, assigned bus number 5
                        [    3.530098] ohci-platform 4101400.usb: irq 237, io mem 0x04101400
                        [    3.610201] hub 5-0:1.0: USB hub found
                        [    3.614005] hub 5-0:1.0: 1 port detected
                        [    3.642633] EXT4-fs (mmcblk2p5): mounted filesystem with ordered data mode. Quota mode: disabled.
                        [    3.651666] VFS: Mounted root (ext4 filesystem) readonly on device 179:5.
                        [    3.659363] devtmpfs: mounted
                        [    3.663679] Freeing unused kernel image (initmem) memory: 1024K
                        [    3.669884] Run /init as init process
                        [    3.673552]   with arguments:
                        [    3.676533]     /init
                        [    3.678804]   with environment:
                        [    3.681941]     HOME=/
                        [    3.684298]     TERM=linux
                        [    3.687035]     partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:dtb@mmcblk0p6:dsp0@mmcblk0p7:private@mmcblk0p8:UDISK@mmcblk0p9
                        [    3.703104]     snum=
                        [    3.705383]     mac_addr=
                        [    3.708001]     wifi_mac=
                        [    3.710618]     bt_mac=
                        [    3.713061]     specialstr=
                        [    3.715871]     replace_fdt=dtb:raw
                        [    3.719356]     boot_type=2
                        [    3.722146]     uboot_message=2018.05(03/21/2023-08:00:44)
                        [    3.727637]     disp_reserve=2457600,0x448ee000
                        [    3.853901] EXT4-fs (mmcblk2p5): re-mounted. Quota mode: disabled.
                        Starting klogd: OK
                        Populating /dev using udev: [    3.979556] udevd[101]: starting version 3.2.7
                        [    9.105398] random: crng init done
                        [    9.129299] udevd[101]: specified group 'input' unknown
                        [    9.135470] udevd[101]: specified group 'kvm' unknown
                        [    9.163026] udevd[102]: starting eudev-3.2.7
                        与主线linux内核启动log对比:
                        T 1 条回复 最后回复 回复 引用 分享 0
                          soso90 LV 7 @evler 最后由 编辑
                          @evler 话说硬件解码方面支持了没。。。还是只是跑起了linux而已。。。
                          • Referenced by  Q qmycy
                          • O
                            oneofzero LV 3 最后由 编辑
                            楼主,能支持一下LCD吗?
                            • T
                              TangSky LV 2 @duanzhh 最后由 编辑
                              @duanzhh 你好,请问你后面解决了吗?方便说下是什么原因吗?我也碰到了此问题
                              • Referenced by  F f_Endman
