    第一次调试D1 MIPI DSI 发现一些奇怪问题,也不知道到底是哪里出了问题。。。
    5
    7
    6522
    • baiwen
      100ask LV 6 最后由 编辑
      最近想给D1配一款MIPI显示屏,但是在调试过程中出现了一些很奇怪得现象,因为是第一次接触MIPI显示屏,所以有点不知所以。。
      其中屏幕使用的是 ILI9806E DSI接口分辨率为480x800
      目前认为主要是 屏幕时序不对导致的问题,但是屏厂能提供的资料非常有限,还是需要慢慢排查....
      • 设备树节点定义
      &lcd0 {
              lcd_used            = <1>;
              lcd_driver_name     = "tft08006";
              lcd_backlight       = <100>;
              lcd_if              = <4>;
              lcd_x               = <480>;
              lcd_y               = <800>;
              lcd_width           = <52>;
              lcd_height          = <52>;
              lcd_dclk_freq       = <25>;
              lcd_pwm_used        = <1>;
              lcd_pwm_ch          = <2>;
              lcd_pwm_freq        = <1000>;
              lcd_pwm_pol         = <0>;
              lcd_pwm_max_limit   = <255>;
              lcd_hbp             = <20>;
              lcd_ht              = <835>;
              lcd_hspw            = <10>;
              lcd_vbp             = <20>;
              lcd_vt              = <510>;
              lcd_vspw            = <5>;
              lcd_dsi_if          = <0>;
              lcd_dsi_lane        = <2>;
              lcd_lvds_if         = <0>;
              lcd_lvds_colordepth = <0>;
              lcd_lvds_mode       = <0>;
              lcd_frm             = <0>;
              lcd_hv_clk_phase    = <0>;
              lcd_hv_sync_polarity= <0>;
              lcd_gamma_en        = <0>;
              lcd_bright_curve_en = <0>;
              lcd_cmap_en         = <0>;
              lcd_fsync_en        = <0>;
              lcd_fsync_act_time  = <1000>;
              lcd_fsync_dis_time  = <1000>;
              lcd_fsync_pol       = <0>;
              deu_mode            = <0>;
              lcdgamma4iep        = <22>;
              smart_color         = <90>;
      • 驱动示例定义
      /* drivers/video/sunxi/disp2/disp/lcd/tft08006.c
       * Copyright (c) 2021 Allwinnertech Co., Ltd.
       * tft08006 panel driver
       * it under the terms of the GNU General Public License version 2 as
      #include "tft08006.h"
      static void lcd_power_on(u32 sel);
      static void lcd_power_off(u32 sel);
      static void lcd_bl_open(u32 sel);
      static void lcd_bl_close(u32 sel);
      static void lcd_panel_init(u32 sel);
      static void lcd_panel_exit(u32 sel);
      #define panel_reset(sel, val) sunxi_lcd_gpio_set_value(sel, 0, val)
      static void lcd_cfg_panel_info(struct panel_extend_para *info)
      	u32 i = 0, j = 0;
      	u32 items;
      	u8 lcd_gamma_tbl[][2] = {
      		{0, 0},
      		{15, 15},
      		{30, 30},
      		{45, 45},
      		{60, 60},
      		{75, 75},
      		{90, 90},
      		{105, 105},
      		{120, 120},
      		{135, 135},
      		{150, 150},
      		{165, 165},
      		{180, 180},
      		{195, 195},
      		{210, 210},
      		{225, 225},
      		{240, 240},
      		{255, 255},
      	u32 lcd_cmap_tbl[2][3][4] = {
      		for (j = 0; j < num; j++) {
      			u32 value = 0;
      			value = lcd_gamma_tbl[i][1] +
      				((lcd_gamma_tbl[i + 1][1] - lcd_gamma_tbl[i][1])
      				 * j) / num;
      				(value << 16)
      				+ (value << 8) + value;
      	info->lcd_gamma_tbl[255] = (lcd_gamma_tbl[items - 1][1] << 16) +
      				   (lcd_gamma_tbl[items - 1][1] << 8)
      				   + lcd_gamma_tbl[items - 1][1];
      static s32 lcd_open_flow(u32 sel)
      	LCD_OPEN_FUNC(sel, lcd_power_on, 10);
      	LCD_OPEN_FUNC(sel, lcd_panel_init, 10);
      	LCD_OPEN_FUNC(sel, sunxi_lcd_tcon_enable, 50);
      	LCD_OPEN_FUNC(sel, lcd_bl_open, 0);
      static s32 lcd_close_flow(u32 sel)
      	LCD_CLOSE_FUNC(sel, lcd_bl_close, 0);
      	LCD_CLOSE_FUNC(sel, sunxi_lcd_tcon_disable, 0);
      	LCD_CLOSE_FUNC(sel, lcd_panel_exit, 200);
      	LCD_CLOSE_FUNC(sel, lcd_power_off, 500);
      	panel_reset(sel, 1);
      	sunxi_lcd_delay_ms(10);
      	panel_reset(sel, 0);
      	sunxi_lcd_delay_ms(5);
      	sunxi_lcd_pin_cfg(sel, 1);
      	sunxi_lcd_pin_cfg(sel, 0);
      	sunxi_lcd_delay_ms(20);
      	sunxi_lcd_pwm_enable(sel);
      	sunxi_lcd_pwm_disable(sel);
      #define REGFLAG_DELAY 0XFC
      #define REGFLAG_END_OF_TABLE 0xFD /* END OF REGISTERS MARKER */
      struct LCM_setting_table {
      	u8 cmd;
      	u32 count;
      	u8 para_list[32];
      static struct LCM_setting_table lcm_tft08006_setting[] = {
      	{0xFF, 3, {0x98, 0x81, 0x03} },
      	{0x01, 1, {0x00} },
      	{0x02, 1, {0x00} },
      	{0x03, 1, {0x53} },
      	{0x04, 1, {0x53} },
      	{0x05, 1, {0x13} },
      	{0x06, 1, {0x04} },
      	{0x07, 1, {0x02} },
      	{0x08, 1, {0x02} },
      	{0x09, 1, {0x00} },
      	{0x0a, 1, {0x00} },
      	{0x0b, 1, {0x00} },
      	{0x0c, 1, {0x00} },
      	{0x0d, 1, {0x00} },
      	{0x0e, 1, {0x00} },
      	{0x0f, 1, {0x00} },
      	{0x10, 1, {0x00} },
      	{0x11, 1, {0x00} },
      	{0x12, 1, {0x00} },
      	{0x13, 1, {0x00} },
      	{0x14, 1, {0x00} },
      	{0x15, 1, {0x00} },
      	{0x16, 1, {0x00} },
      	{0x17, 1, {0x00} },
      	{0x18, 1, {0x00} },
      	{0x19, 1, {0x00} },
      	{0x1a, 1, {0x00} },
      	{0x1b, 1, {0x00} },
      	{0x1c, 1, {0x00} },
      	{0x1d, 1, {0x00} },
      	{0x1e, 1, {0xc0} },
      	{0x1f, 1, {0x80} },
      	{0x20, 1, {0x02} },
      	{0x21, 1, {0x09} },
      	{0x22, 1, {0x00} },
      	{0x23, 1, {0x00} },
      	{0x24, 1, {0x00} },
      	{0x25, 1, {0x00} },
      	{0x26, 1, {0x00} },
      	{0x27, 1, {0x00} },
      	{0x28, 1, {0x55} },
      	{0x29, 1, {0x03} },
      	{0x2a, 1, {0x00} },
      	{0x2b, 1, {0x00} },
      	{0x2c, 1, {0x00} },
      	{0x2d, 1, {0x00} },
      	{0x2e, 1, {0x00} },
      	{0x2f, 1, {0x00} },
      	{0x30, 1, {0x00} },
      	{0x31, 1, {0x00} },
      	{0x32, 1, {0x00} },
      	{0x33, 1, {0x00} },
      	{0x34, 1, {0x00} },
      	{0x35, 1, {0x00} },
      	{0x36, 1, {0x00} },
      	{0x37, 1, {0x00} },
      	{0x38, 1, {0x3C} },
      	{0x39, 1, {0x00} },
      	{0x3a, 1, {0x00} },
      	{0x3b, 1, {0x00} },
      	{0x3c, 1, {0x00} },
      	{0x3d, 1, {0x00} },
      	{0x3e, 1, {0x00} },
      	{0x3f, 1, {0x00} },
      	{0x40, 1, {0x00} },
      	{0x41, 1, {0x00} },
      	{0x42, 1, {0x00} },
      	{0x43, 1, {0x00} },
      	{0x44, 1, {0x00} },
      	{0x50, 1, {0x01} },
      	{0x51, 1, {0x23} },
      	{0x52, 1, {0x45} },
      	{0x53, 1, {0x67} },
      	{0x54, 1, {0x89} },
      	{0x55, 1, {0xab} },
      	{0x56, 1, {0x01} },
      	{0x57, 1, {0x23} },
      	{0x58, 1, {0x45} },
      	{0x59, 1, {0x67} },
      	{0x5a, 1, {0x89} },
      	{0x5b, 1, {0xab} },
      	{0x5c, 1, {0xcd} },
      	{0x5d, 1, {0xef} },
      	{0x5e, 1, {0x01} },
      	{0x5f, 1, {0x08} },
      	{0x60, 1, {0x02} },
      	{0x61, 1, {0x02} },
      	{0x62, 1, {0x0A} },
      	{0x63, 1, {0x15} },
      	{0x64, 1, {0x14} },
      	{0x65, 1, {0x02} },
      	{0x66, 1, {0x11} },
      	{0x67, 1, {0x10} },
      	{0x68, 1, {0x02} },
      	{0x69, 1, {0x0F} },
      	{0x6a, 1, {0x0E} },
      	{0x6b, 1, {0x02} },
      	{0x6c, 1, {0x0D} },
      	{0x6d, 1, {0x0C} },
      	{0x6e, 1, {0x06} },
      	{0x6f, 1, {0x02} },
      	{0x70, 1, {0x02} },
      	{0x71, 1, {0x02} },
      	{0x72, 1, {0x02} },
      	{0x73, 1, {0x02} },
      	{0x74, 1, {0x02} },
      	{0x75, 1, {0x06} },
      	{0x76, 1, {0x02} },
      	{0x77, 1, {0x02} },
      	{0x78, 1, {0x0A} },
      	{0x79, 1, {0x15} },
      	{0x7a, 1, {0x14} },
      	{0x7b, 1, {0x02} },
      	{0x7c, 1, {0x10} },
      	{0x7d, 1, {0x11} },
      	{0x7e, 1, {0x02} },
      	{0x7f, 1, {0x0C} },
      	{0x80, 1, {0x0D} },
      	{0x81, 1, {0x02} },
      	{0x82, 1, {0x0E} },
      	{0x83, 1, {0x0F} },
      	{0x84, 1, {0x08} },
      	{0x85, 1, {0x02} },
      	{0x86, 1, {0x02} },
      	{0x87, 1, {0x02} },
      	{0x88, 1, {0x02} },
      	{0x89, 1, {0x02} },
      	{0x8A, 1, {0x02} },
      	{0xFF, 3, {0x98, 0x81, 0x04} },
      //	{0x2D, 1, {0xFF} },   //BIST
      //	{0x2F, 1, {0x01} },   //BIST
      	{0x6C, 1, {0x15} },
      	{0x6E, 1, {0x30} },
      	{0x6F, 1, {0x37} },   //3VSP    3VSN
      	{0x8D, 1, {0x1F} },
      	{0x87, 1, {0xBA} },
      	{0x26, 1, {0x76} },
      	{0xB2, 1, {0xD1} },
      	{0xB5, 1, {0x07} },
      	{0x35, 1, {0x17} },
      	{0x33, 1, {0x14} },
      	{0x31, 1, {0x75} },
      	{0x3A, 1, {0x85} },
      	{0x3B, 1, {0x98} },
      	{0x38, 1, {0x01} },
      	{0x39, 1, {0x00} },
      	{0x7A, 1, {0x10} },
      	{0xFF, 3, {0x98, 0x81, 0x01} },
      	{0x22, 1, {0x0A} },
      	{0x31, 1, {0x00} },
      	{0x50, 1, {0xCF} },     //5.2V
      	{0x51, 1, {0xCA} },     //-5.2V
      	{0x53, 1, {0x45} },     //45   41
      	{0x55, 1, {0x48} },
      	{0x60, 1, {0x28} },
      	{0x2E, 1, {0xC8} },
      	{0x34, 1, {0x01} },
      	//{0x56, 1, {0x00} },
      	{0xA0, 1, {0x00} },		//VP255	Gamma P
      	{0xA1, 1, {0x08} },               //VP251
      	{0xA2, 1, {0x18} },               //VP247
      	{0xA3, 1, {0x15} },              //VP243
      	{0xA4, 1, {0x19} },               //VP239
      	{0xA5, 1, {0x2D} },               //VP231
      	{0xA6, 1, {0x21} },               //VP219
      	{0xA7, 1, {0x23} },               //VP203
      	{0xA8, 1, {0x74} },               //VP175
      	{0xA9, 1, {0x1C} },               //VP144
      	{0xAA, 1, {0x26} },               //VP111
      	{0xAB, 1, {0x64} },               //VP80
      	{0xAC, 1, {0x1A} },               //VP52
      	{0xAD, 1, {0x1C} },               //VP36
      	{0xAE, 1, {0x50} },               //VP24
      	{0xAF, 1, {0x25} },               //VP16
      	{0xB0, 1, {0x2A} },               //VP12
      	{0xB1, 1, {0x4C} },              //VP8
      	{0xB2, 1, {0x5D} },               //VP4
      	{0xB3, 1, {0x23} },               //VP0
      	{0xC0, 1, {0x00} },	//VN255 GAMMA N
      	{0xC1, 1, {0x1B} },              //VN251
      	{0xC2, 1, {0x27} },              //VN247
      	{0xC3, 1, {0x13} },              //VN243
      	{0xC4, 1, {0x16} },              //VN239
      	{0xC5, 1, {0x28} },              //VN231
      	{0xC6, 1, {0x1E} },              //VN219
      	{0xC7, 1, {0x20} },              //VN203
      	{0xC8, 1, {0x7D} },              //VN175
      	{0xC9, 1, {0x19} },              //VN144
      	{0xCA, 1, {0x27} },              //VN111
      	{0xCB, 1, {0x65} },              //VN80
      	{0xCC, 1, {0x1D} },              //VN52
      	{0xCD, 1, {0x1D} },              //VN36
      	{0xCE, 1, {0x52} },              //VN24
      	{0xCF, 1, {0x26} },              //VN16
      	{0xD0, 1, {0x2C} },              //VN12
      	{0xD1, 1, {0x4E} },              //VN8
      	{0xD2, 1, {0x59} },              //VN4
      	{0xD3, 1, {0x23} },              //VN0
      	//{0xFF, 3, {0x98, 0x81, 0x04} },
      	//{0x2F, 1, {0x01} },
      	{0xFF, 3, {0x98, 0x81, 0x00} },
      	{0x35, 1, {0x00} },
      	{0x11, 0, {}},
      	{REGFLAG_DELAY, REGFLAG_DELAY, {120}},
      	{0x29, 0, {}},
      	{REGFLAG_DELAY, REGFLAG_DELAY, {20}},
      	{REGFLAG_END_OF_TABLE, REGFLAG_END_OF_TABLE, {}}
      	__u32 i;
      	sunxi_lcd_dsi_clk_enable(sel);
      	for (i = 0;; i++) {
      		if (lcm_tft08006_setting[i].count == REGFLAG_END_OF_TABLE)
      			break;
      		else if (lcm_tft08006_setting[i].count == REGFLAG_DELAY) {
      			sunxi_lcd_delay_ms(lcm_tft08006_setting[i].para_list[0]);
      		} else {
      			dsi_gen_wr(sel, lcm_tft08006_setting[i].cmd,
      				   lcm_tft08006_setting[i].para_list,
      				   lcm_tft08006_setting[i].count);
      		/* break; */
      	sunxi_lcd_dsi_dcs_write_0para(sel, 0x10);
      	sunxi_lcd_delay_ms(80);
      	sunxi_lcd_dsi_dcs_write_0para(sel, 0x28);
      	sunxi_lcd_delay_ms(50);
      /*sel: 0:lcd0; 1:lcd1*/
      static s32 lcd_user_defined_func(u32 sel, u32 para1, u32 para2, u32 para3)
      struct __lcd_panel tft08006_panel = {
      	/* panel driver name, must mach the name of
      	 * lcd_drv_name in sys_config.fex
      	.name = "tft08006",
      	.func = {
      		.cfg_panel_info = lcd_cfg_panel_info,
      		.cfg_open_flow = lcd_open_flow,
      		.cfg_close_flow = lcd_close_flow,
      		.lcd_user_defined_func = lcd_user_defined_func,
      • aozima
        aozima LV 7 最后由 编辑
        把MIPI的时钟线用示波器测一下看看有没有输出
          whycan晕哥 LV 9 最后由 whycan 编辑
          我前面驱动mipi屏也出现这个问题,后来发现是排线拔插次数多废了,换一根新排线就好了。
            dream LV 6 最后由 编辑
            没遇到过,坐等结论。
            • mangogeek
              mangogeek LV 8 最后由 编辑
              gamma偏差太大,导致液晶“极化”
              • baiwen
                100ask LV 6 最后由 编辑
                • 亮屏成功,这个时钟和时序真的是离谱,错一个都不行,试了两天,自己粗心误把HBP认为HeightBP,另外接下来我们将提供 带电容触摸版本 以及 不带电容触摸版本,可直接连接到 MangoPI MQ-Pro AW-OL NeZha公板,T113等版本,为大家提供一个高性价比的双LANE 480x800的MIPI屏模块。
                D 1 条回复 最后回复 回复 引用 分享 0
                  dream LV 6 @baiwen 最后由 编辑
                  @allwinnertech 666
