    V853 虚拟机编译失败,使用buildroot
    4026
      lyscut LV 5 最后由 编辑
      如题,今天刚按照文档拉取的源码,尝试编译失败。Log 如下:
      allwinner@allwinner-VirtualBox:~/tina-V85x$ ./build.sh
      ========ACTION List: build_linuxdev;========
      options :
      INFO: build linuxdev ...
      INFO: chip: sun8iw21p1
      INFO: platform: linux
      INFO: kernel: linux-4.9
      INFO: board: vision
      INFO: output: /home/allwinner/tina-V85x/out/v853/vision/buildroot
      INFO: don't build dtbo ...
      INFO: build arisc
      INFO: build_bootloader: brandy_path= /home/allwinner/tina-V85x/brandy/brandy-2.0
      INFO: skip build brandy.
      INFO: build kernel ...
      INFO: Prepare toolchain ...
      Building kernel
      /home/allwinner/tina-V85x/kernel/linux-4.9/output/lib/modules/4.9.191
        CHK     include/config/kernel.release
        CHK     include/generated/uapi/linux/version.h
        CHK     include/generated/utsrelease.h
        CHK     scripts/mod/devicetable-offsets.h
        CHK     include/generated/timeconst.h
        CHK     include/generated/bounds.h
        CHK     include/generated/asm-offsets.h
        CALL    scripts/checksyscalls.sh
        CHK     include/generated/compile.h
        DTC     arch/arm/boot/dts/board.dtb
        Kernel: arch/arm/boot/Image is ready
        Building modules, stage 2.
        MODPOST 27 modules
        Kernel: arch/arm/boot/zImage is ready
        Kernel: arch/arm/boot/uImage is ready
      'arch/arm/boot/Image' -> 'output/bImage'
      'arch/arm/boot/uImage' -> 'output/uImage'
      'arch/arm/boot/zImage' -> 'output/zImage'
      Copy rootfs.cpio.gz for arm
      Building modules
      [GPU]: No GPU type is configured in /home/allwinner/tina-V85x/kernel/linux-4.9/.config.
      INFO: build dts ...
      removed '/home/allwinner/tina-V85x/out/v853/vision/buildroot/.board.dtb.d.dtc.tmp'
      removed '/home/allwinner/tina-V85x/out/v853/vision/buildroot/.board.dtb.dts.tmp'
      '/home/allwinner/tina-V85x/kernel/linux-4.9/arch/arm/boot/dts/.board.dtb.d.dtc.tmp' -> '/home/allwinner/tina-V85x/out/v853/vision/buildroot/.board.dtb.d.dtc.tmp'
      '/home/allwinner/tina-V85x/kernel/linux-4.9/arch/arm/boot/dts/.board.dtb.dts.tmp' -> '/home/allwinner/tina-V85x/out/v853/vision/buildroot/.board.dtb.dts.tmp'
      INFO: build rootfs ...
      INFO: build buildroot ...
      make: Entering directory '/home/allwinner/tina-V85x/buildroot/buildroot-201902'
      >>> host-libglib2 2.56.3 Building
      PATH="/home/allwinner/tina-V85x/out/v853/vision/buildroot/buildroot/host/bin:/home/allwinner/tina-V85x/out/v853/vision/buildroot/buildroot/host/sbin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin" PKG_CONFIG="/home/allwinner/tina-V85x/out/v853/vision/buildroot/buildroot/host/bin/pkg-config" PKG_CONFIG_SYSROOT_DIR="/" PKG_CONFIG_ALLOW_SYSTEM_CFLAGS=1 PKG_CONFIG_ALLOW_SYSTEM_LIBS=1 PKG_CONFIG_LIBDIR="/home/allwinner/tina-V85x/out/v853/vision/buildroot/buildroot/host/lib/pkgconfig:/home/allwinner/tina-V85x/out/v853/vision/buildroot/buildroot/host/share/pkgconfig"  /usr/bin/make -j16  -C /home/allwinner/tina-V85x/out/v853/vision/buildroot/buildroot/build/host-libglib2-2.56.3/
      /usr/bin/make  all-recursive
      Making all in .
      make[4]: Nothing to be done for 'all-am'.
      Making all in m4macros
      /usr/bin/make  all-am
      make[5]: Nothing to be done for 'all-am'.
      Making all in glib
      Making all in libcharset
      make[7]: Nothing to be done for 'all-am'.
      Making all in update-pcre
      Making all in .
      make[6]: Nothing to be done for 'all-am'.
      Making all in gmodule
      Making all in gthread
      Making all in gobject
      Making all in .
      Making all in tests
      Making all in gio
      Making all in gdbus-2.0/codegen
      Making all in xdgmime
      Making all in inotify
      Making all in .
        CC       libgio_2_0_la-gdbusauth.lo
        CC       libgio_2_0_la-gdbusmessage.lo
        CC       libgio_2_0_la-ghttpproxy.lo
        CC       libgio_2_0_la-glocalfile.lo
        CC       libgio_2_0_la-glocalfileenumerator.lo
        CC       libgio_2_0_la-glocalfileinfo.lo
        CC       libgio_2_0_la-glocalfileinputstream.lo
        CC       libgio_2_0_la-glocalfilemonitor.lo
        CC       libgio_2_0_la-glocalfileoutputstream.lo
        CC       libgio_2_0_la-glocalfileiostream.lo
        CC       libgio_2_0_la-glocalvfs.lo
        CC       libgio_2_0_la-gsocks4proxy.lo
        CC       libgio_2_0_la-gsocks4aproxy.lo
        CC       libgio_2_0_la-gsocks5proxy.lo
        CC       libgio_2_0_la-thumbnail-verify.lo
        CC       libgio_2_0_la-gdesktopappinfo.lo
        CC       libgio_2_0_la-gcontenttype.lo
      glocalfilemonitor.c:332:1: warning: 'is_basename' defined but not used [-Wunused-function]
        332 | is_basename (const gchar *name)
      gdbusmessage.c: In function 'parse_value_from_blob':
      gdbusmessage.c:1712:29: warning: variable 'item' set but not used [-Wunused-but-set-variable]
       1712 |                   GVariant *item;
      gdbusmessage.c: In function 'append_value_to_blob':
      gdbusmessage.c:2326:24: warning: unused variable 'end' [-Wunused-variable]
       2326 |           const gchar *end;
        CC       libgio_2_0_la-gfiledescriptorbased.lo
        CC       libgio_2_0_la-gunixconnection.lo
        CC       libgio_2_0_la-gunixcredentialsmessage.lo
        CC       libgio_2_0_la-gunixfdlist.lo
        CC       libgio_2_0_la-gunixfdmessage.lo
      gdesktopappinfo.c: In function 'desktop_key_get_name':
      gdesktopappinfo.c:410:1: warning: control reaches end of non-void function [-Wreturn-type]
        410 | }
      At top level:
      gdesktopappinfo.c:4517:1: warning: 'app_info_has_action' defined but not used [-Wunused-function]
       4517 | app_info_has_action (GDesktopAppInfo *info,
        CC       libgio_2_0_la-gunixmount.lo
        CC       libgio_2_0_la-gunixmounts.lo
        CC       libgio_2_0_la-gunixsocketaddress.lo
        CC       libgio_2_0_la-gunixvolume.lo
      gdbusauth.c: In function '_g_dbus_auth_run_server':
      gdbusauth.c:1302:11: error: '%s' directive argument is null [-Werror=format-overflow=]
       1302 |           debug_print ("SERVER: WaitingForBegin, read '%s'", line);
        CC       libgio_2_0_la-gunixvolumemonitor.lo
      cc1: some warnings being treated as errors
      make[6]: *** [Makefile:3633: libgio_2_0_la-gdbusauth.lo] Error 1
      make[6]: *** Waiting for unfinished jobs....
      gdbusmessage.c: In function 'g_dbus_message_to_blob':
      gdbusmessage.c:2702:30: error: '%s' directive argument is null [-Werror=format-overflow=]
       2702 |       tupled_signature_str = g_strdup_printf ("(%s)", signature_str);
      make[6]: *** [Makefile:3682: libgio_2_0_la-gdbusmessage.lo] Error 1
      make[5]: *** [Makefile:4471: all-recursive] Error 1
      make[4]: *** [Makefile:2049: all] Error 2
      make[3]: *** [Makefile:1272: all-recursive] Error 1
      make[2]: *** [Makefile:893: all] Error 2
      make[1]: *** [package/pkg-generic.mk:241: /home/allwinner/tina-V85x/out/v853/vision/buildroot/buildroot/build/host-libglib2-2.56.3/.stamp_built] Error 2
      make: *** [Makefile:96: _all] Error 2
      make: Leaving directory '/home/allwinner/tina-V85x/buildroot/buildroot-201902'
      ERROR: build buildroot Failed
      INFO: build_buildroot_rootfs failed
        buildroot暂时还不支持Ubuntu20.04,后续新版本会支持
          lyscut LV 5 @YuzukiTsuru 最后由 编辑
          所以用 OpenWrt的那套就可以是吗?
            lyscut LV 5 @lyscut 最后由 编辑
            OpenWrt编译成功,感谢大佬
