    成功修复 T113 因为 make -j7 出现的编译错误
    • cube_work
      cube_work LV 5 最后由 编辑
      running CONFIG_SHELL=/bin/bash /bin/bash ./configure --target=arm-openwrt-linux --host=arm-openwrt-linux --build=x86_64-linux-gnu --program-prefix= --program-suffix= --prefix=/usr --exec-prefix=/usr --bindir=/usr/bin --sbindir=/usr/sbin --libexecdir=/usr/lib --sysconfdir=/etc --datadir=/usr/share --localstatedir=/var --mandir=/usr/man --infodir=/usr/info --disable-nls --disable-python --disable-debug --without-debug --disable-resmgr --enable-aload --enable-mixer --enable-pcm --enable-rawmidi --enable-hwdep --enable-seq --enable-ucm --enable-topology --enable-alisp --with-versioned=no build_alias=x86_64-linux-gnu host_alias=arm-openwrt-linux target_alias=arm-openwrt-linux CC=arm-openwrt-linux-gnueabi-gcc CFLAGS=-Os -pipe -march=armv7-a -mtune=cortex-a7 -mfpu=neon -fno-caller-saves -Wno-unused-result -mfloat-abi=hard  -fPIC -D_FORTIFY_SOURCE=2 -Wl,-z,now -Wl,-z,relro -fpic  LDFLAGS=-L/opt/D1/tina_d1_open_v2_debug6_t113/out/t113-nezha/staging_dir/target/usr/lib -L/opt/D1/tina_d1_open_v2_debug6_t113/out/t113-nezha/staging_dir/target/lib -L/opt/D1/tina_d1_open_v2_debug6_t113/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-glibc/toolchain/usr/lib -L/opt/D1/tina_d1_open_v2_debug6_t113/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-glibc/toolchain/lib -specs=/opt/D1/tina_d1_open_v2_debug6_t113/build/hardened-ld-pie.specs -znow -zrelro -ldl  LIBS= CPPFLAGS=-I/opt/D1/tina_d1_open_v2_debug6_t113/out/t113-nezha/staging_dir/target/usr/include -I/opt/D1/tina_d1_open_v2_debug6_t113/out/t113-nezha/staging_dir/target/include -I/opt/D1/tina_d1_open_v2_debug6_t113/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-glibc/toolchain/usr/include -I/opt/D1/tina_d1_open_v2_debug6_t113/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-glibc/toolchain/include  --no-create --no-recursion
      configure: WARNING: unrecognized options: --disable-nls, --disable-debug
      configure: loading site script /opt/D1/tina_d1_open_v2_debug6_t113/build/site/arm
      checking build system type... x86_64-pc-linux-gnu
      checking host system type... arm-openwrt-linux-gnu
      ./configure: line 2339: AM_INIT_AUTOMAKE: command not found
      ./configure: line 2341: syntax error near unexpected token `INSTALL_M4,'
      ./configure: line 2341: `AM_CONDITIONAL(INSTALL_M4, test -n "${ACLOCAL}")'
      Makefile:314: recipe for target 'config.status' failed
      make[3]: *** [config.status] Error 2
      make[3]: Leaving directory '/opt/D1/tina_d1_open_v2_debug6_t113/out/t113-nezha/compile_dir/target/alsa-lib-1.1.4.1'
      Makefile:120: recipe for target '/opt/D1/tina_d1_open_v2_debug6_t113/out/t113-nezha/compile_dir/target/alsa-lib-1.1.4.1/.built' failed
      make[2]: *** [/opt/D1/tina_d1_open_v2_debug6_t113/out/t113-nezha/compile_dir/target/alsa-lib-1.1.4.1/.built] Error 2
      make[2]: Leaving directory '/opt/D1/tina_d1_open_v2_debug6_t113/package/libs/alsa-lib'
      package/Makefile:192: recipe for target 'package/libs/alsa-lib/compile' failed
      make[1]: *** [package/libs/alsa-lib/compile] Error 2
      make[1]: Leaving directory '/opt/D1/tina_d1_open_v2_debug6_t113'
      /opt/D1/tina_d1_open_v2_debug6_t113/build/toplevel.mk:304: recipe for target 'package/libs/alsa-lib/compile' failed
      make: *** [package/libs/alsa-lib/compile] Error 2
      #### make failed to build some targets (5 seconds) ####
      然后怎么 make 都是炸了,修复的办法:
      rm out/t113-nezha/compile_dir/target/alsa-lib-1.1.4.1 -rf
      make package/libs/alsa-lib/compile
