    V831芯片 开机卡在I2C启动中,要近5分钟才能开机,i2c扫地址很慢,差不多5秒钟扫一次
    • R
      RTQQQ LV 5 最后由 编辑
      开机的时候会在i2c上花费大量的时间,开机成功后使用i2cdetect也扫得很慢,求助大家帮忙看看什么原因?
      下面附上board.dts 和启动日志
       * Allwinner Technology CO., Ltd. sun8iw19p1 soc board.
       * soc board support.
      /dts-v1/;
      #include "sun8iw19p1.dtsi"
      	dram: dram {
      		dram_clk = <0x000001e0>;
      		dram_type = <0x00000003>;
      		dram_zq = <0x00003bfb>;
      		dram_odt_en = <0x00000001>;
      		dram_para1 = <0x004310f2>;
      		dram_para2 = <0x02000000>;
      		dram_mr0 = <0x00001c70>;
      		dram_mr1 = <0x00000000>;
      		dram_mr2 = <0x00000018>;
      		dram_mr3 = <0x00000000>;
      		dram_tpr0 = <0x0046190d>;
      		dram_tpr1 = <0x0121210a>;
      		dram_tpr2 = <0x0005403b>;
      		dram_tpr3 = <0x00002006>;
      		dram_tpr4 = <0x05040405>;
      		dram_tpr5 = <0x05050302>;
      		dram_tpr6 = <0x90006644>;
      		dram_tpr7 = <0x42c21590>;
      		dram_tpr8 = <0xd05612c0>;
      		dram_tpr9 = <0x00083def>;
      		dram_tpr10 = <0x00000000>;
      		dram_tpr11 = <0x00210000>;
      		dram_tpr12 = <0x00000055>;
      		dram_tpr13 = <0x00006003>;
      	opp_dvfs_table:opp_dvfs_table {
      		cluster_num = <1>;
      		opp_table_count = <1>;
      		cpu_opp_l_table0: opp_l_table0 {
      			compatible = "allwinner,opp_l_table0";
      			opp_count = <2>;
      			opp-shared;
      			opp00 {
      				opp-hz = /bits/ 64 <600000000>;
      				opp-microvolt = <900000>;
      				axi-bus-divide-ratio = <3>;
      				clock-latency-ns = <2000000>;
      			opp01 {
      				opp-hz = /bits/ 64 <816000000>;
      	soc@03000000 {
      		pinctrl@0300b000 {
      			twi0_pins_a: twi0@0 {
      				allwinner,pins = "PI3", "PI4";
      				allwinner,pname = "twi0_scl", "twi0_sda";
      				allwinner,function = "twi0";
      				allwinner,muxsel = <5>;
      				allwinner,drive = <1>;
      				allwinner,pull = <0>;
      			twi0_pins_b: twi0@1 {
      				allwinner,muxsel = <7>;
      			twi1_pins_a: twi1@0 {
      				allwinner,pins = "PI1", "PI2";
      				allwinner,pname = "twi1_scl", "twi1_sda";
      				allwinner,function = "twi1";
      			twi1_pins_b: twi1@1 {
      			twi2_pins_a: twi2@0 {
      				allwinner,pins = "PH5", "PH6";
      				allwinner,pname = "twi2_scl", "twi2_sda";
      				allwinner,function = "twi2";
      			twi2_pins_b: twi2@1 {
      			spi0_pins_a: spi0@0 {
      				allwinner,pins = "PC0", "PC2", "PC3",
      						"PC5", "PC4";
      				allwinner,pname = "spi0_sclk", "spi0_mosi",
      						  "spi0_miso", "spi0_hold", "spi0_wp";
      				allwinner,function = "spi0";
      				allwinner,muxsel = <4>;
      			spi0_pins_b: spi0@1 {
      				allwinner,pins = "PC1", "PC6";
      				allwinner,pname = "spi0_cs0", "spi0_cs1";
      				allwinner,pull = <1>; 	// only CS should be pulled up
      			spi0_pins_c: spi0@2 {
      				allwinner,pins = "PC0", "PC1", "PC2", "PC3",
      						"PC4", "PC5", "PC6";
      			spi1_pins_a: spi1@0 {
      				allwinner,pins = "PH0", "PH1", "PH2";
      				allwinner,pname = "spi1_sclk", "spi1_mosi",
      						  "spi1_miso";
      			spi1_pins_b: spi1@1 {
      				allwinner,pins = "PH3";
      				allwinner,pname = "spi1_cs0";
      			spi1_pins_c: spi1@2 {
      				allwinner,pins = "PH0", "PH1", "PH2", "PH3";
      			sdc0_pins_a: sdc0@0 {
      				allwinner,pins = "PF0", "PF1", "PF2", "PF3",
      						"PF4", "PF5";
      				allwinner,function = "sdc0";
      				allwinner,muxsel = <2>;
      				allwinner,drive = <3>;
      			sdc0_pins_b: sdc0@1 {
      						"PF4", "PF5";
      			sdc1_pins_a: sdc1@0 {
      				allwinner,pins = "PG0", "PG1", "PG2", "PG3",
      						"PG4", "PG5";
      				allwinner,function = "sdc1";
      			owc0_pins_a: owc0@0 {
      				allwinner,pins = "PH4";
      				allwinner,pname = "owc0";
      				allwinner,function = "owc0";
      			owc0_pins_b: owc0_sleep@0 {
      			pwm0_pins_a: pwm0@0 {
      				allwinner,pins = "PH0";
      				allwinner,pname = "pwm0_positive";
      				allwinner,function = "pwm0";
      			pwm0_pins_b: pwm0@1 {
      			pwm1_pins_a: pwm1@0 {
      				allwinner,pins = "PH1";
      				allwinner,pname = "pwm1_positive";
      				allwinner,function = "pwm1";
      			pwm1_pins_b: pwm1@1 {
      			pwm2_pins_a: pwm2@0 {
      				allwinner,pins = "PH2";
      				allwinner,pname = "pwm2_positive";
      				allwinner,function = "pwm2";
      			pwm2_pins_b: pwm2@1 {
      			pwm3_pins_a: pwm3@0 {
      				allwinner,pname = "pwm3_positive";
      				allwinner,function = "pwm3";
      			pwm3_pins_b: pwm3@1 {
      			pwm4_pins_a: pwm4@0 {
      				allwinner,pname = "pwm4_positive";
      				allwinner,function = "pwm4";
      			pwm4_pins_b: pwm4@1 {
      			// pwm5_pins_a: pwm5@0 {
      			// 	allwinner,pins = "PH5";
      			// 	allwinner,pname = "pwm5_positive";
      			// 	allwinner,function = "pwm5";
      			// 	allwinner,muxsel = <2>;
      			// 	allwinner,drive = <1>;
      			// 	allwinner,pull = <0>;
      			// pwm5_pins_b: pwm5@1 {
      			// 	allwinner,function = "io_disabled";
      			// 	allwinner,muxsel = <7>;
      			//pwm6_pins_a: pwm6@0 {
      			//	allwinner,pins = "PH6";
      			//	allwinner,pname = "pwm6_positive";
      			//	allwinner,function = "pwm6";
      		//	//pwm6_pins_b: pwm6@1 {
      			pwm7_pins_a: pwm7@0 {
      				allwinner,pins = "PH7";
      				allwinner,pname = "pwm7_positive";
      				allwinner,function = "pwm7";
      			pwm7_pins_b: pwm7@1 {
      			pwm8_pins_a: pwm8@0 {
      				allwinner,pins = "PH8";
      				allwinner,pname = "pwm8_positive";
      				allwinner,function = "pwm8";
      			pwm8_pins_b: pwm8@1 {
      			pwm9_pins_a: pwm9@0 {
      				allwinner,pins = "PH9";
      				allwinner,pname = "pwm9_positive";
      				allwinner,function = "pwm9";
      			pwm9_pins_b: pwm9@1 {
      			rgb8_pins_a: rgb8@0 {
      				allwinner,pins = "PD1", "PD2", "PD3", "PD4", "PD5", "PD6",
      						"PD7", "PD8", "PD18", "PD19", "PD20";
      				allwinner,pname = "lcdd3", "lcdd4", "lcdd5", "lcdd6", "lcdd7",
      						"lcdd10", "lcdd11", "lcdd12", "lcdclk", "lcdde",
      							"lcdhsync";
      				allwinner,function = "lcd0";
      			rgb8_pins_b: rgb8@1 {
      				allwinner,pins = "PD1", "PD2","PD3","PD4","PD5","PD6",
      						"PD7","PD8","PD18","PD19","PD20";
      		gpadc:gpadc{
      			channel_num = <1>;
      			channel_select = <0x01>;
      			channel_data_select = <0>;
      			channel_cld_select = <0x01>;
      			channel_chd_select = <0x01>;
      			key_cnt =  <2>;
      			key0_vol = <0>;
      			key0_val = <2>; /* KEY_1 */
      			key1_vol = <160>;
      			key1_val = <3>; /* KEY_2 */
      		uart1: uart@05000400 {
      			device_type = "uart1";
      			reg = <0x0 0x05000400 0x0 0x400>;
      			interrupts = <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&clk_uart1>;
      			pinctrl-0 = <&uart1_pins_a>;
      			pinctrl-1 = <&uart1_pins_b>;
      			uart1_port = <1>;
      			uart1_type = <4>;
      		// uart3: uart@05000c00 {
      		// 	compatible = "allwinner,sun8i-uart";
      		// 	device_type = "uart3";
      		// 	reg = <0x0 0x05000c00 0x0 0x400>;
      		// 	interrupts = <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>;
      		// 	clocks = <&clk_uart3>;
      		// 	pinctrl-names = "default", "sleep";
      		// 	pinctrl-0 = <&uart3_pins_a>;
      		// 	pinctrl-1 = <&uart3_pins_b>;
      		// 	uart3_port = <3>;
      		// 	uart3_type = <4>;
      		// 	status = "okay";
      		twi0: twi@0x05002000{
      			pinctrl-0 = <&twi0_pins_a>;
      			pinctrl-1 = <&twi0_pins_b>;
      			twi_drv_used = <1>;
      			status = "disable";
      		twi1: twi@0x05002400{
      			pinctrl-0 = <&twi1_pins_a>;
      			pinctrl-1 = <&twi1_pins_b>;
      			clock-frequency = <400000>;
      		twi2: twi@0x05002800{
      			pinctrl-0 = <&twi2_pins_a>;
      			pinctrl-1 = <&twi2_pins_b>;
      			clock-frequency = <200000>;
      			ac108@3b{
      				#sound-dai-cells = <0>;
      				compatible = "Allwinner,MicArray_0";
      				reg = <0x3b>;
      				regulator_used = <0x0>;
      				power_voltage = <3300000>;
      				regulator_name = "vcc-3v3";
      				power_gpio_used = <0x0>;
      				reset_gpio_used = <0x0>;
      				twi_bus = <2>;
      				pga_gain = <0x1F>;
      				slot_width = <0x20>;
      				lrck_period = <0x80>;
      				ref_pga_used = <0x1>;
      				ref_pga_gain = <0x10>;
      				ref_channel = <0x3>;
      				debug_mode = <0x0>;
      			ac108@35{
      				compatible = "Allwinner,MicArray_1";
      				reg = <0x35>;
      				twi_bus = <2>;
      				pga_gain = <0x1F>;
      				debug_mode = <0x0>;
      		spi@05010000 {
      			pinctrl-1 = <&spi0_pins_c>;
      			status = "disable";
      			spi_board0 {
      				device_type = "spi_board0";
      				compatible = "m25p80";
      				reg = <0x0>;
      				spi-rx-bus-width = <0x1>;
      				spi-tx-bus-width = <0x1>;
      	//	spi@05011000 {
      	//		#address-cells = <1>;
      	//		#size-cells = <0>;
      	//		reg = <0x0 0x05011000 0x0 0x1000>;
      	//		interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>;
      	//		clocks = <&clk_pll_periph0>, <&clk_spi1>;
      	//		clock-frequency = <200000000>;
      	//		pinctrl-0 = <&spi1_pins_b>;
      	//		pinctrl-1 = <&spi1_pins_c>;
      	//		spi1_cs_number = <2>;
      	//		spi1_cs_bitmap = <3>;
      	//		status = "okay";
      	//		spi_board1 {
      	//			device_type = "spi_board1";
      	//			compatible = "spidev";
      	//			spi-max-frequency = <0x5f5e100>;
      	//			reg = <0x0>;
      	//			spi-rx-bus-width = <0x1>;
      	//			spi-tx-bus-width = <0x1>;
      		vind0:vind@0 {
      			vind0_clk = <270000000>;
      			vind0_isp = <200000000>;
      			actuator0:actuator@0 {
      				device_type = "actuator0";
      				actuator0_slave = <0x18>;
      				actuator0_af_pwdn = <>;
      				status = "disabled";
      			flash0:flash@0 {
      				device_type = "flash0";
      				flash0_type = <2>;
      				flash0_en = <>;
      				flash0_mode = <>;
      				flash0_flvdd = "";
      				flash0_flvdd_vol = <>;
      				device_id = <0>;
      			sensor0:sensor@0 {
      				device_type = "sensor0";
      				// sensor0_mname = "ov9732_mipi";
      				sensor0_mname = "sp2305_mipi";
      				sensor0_twi_cci_id = <1>;
      				// sensor0_twi_addr = <0x6c>;
      				sensor0_twi_addr = <0x78>;
      				sensor0_mclk_id = <0>;
      				sensor0_pos = "rear";
      				sensor0_isp_used = <1>;
      				sensor0_fmt = <1>;
      				sensor0_stby_mode = <0>;
      				sensor0_vflip = <0>;
      				sensor0_hflip = <0>;
      				sensor0_iovdd-supply = <>;
      				sensor0_iovdd_vol = <1800000>;
      				sensor0_avdd-supply = <>;
      				sensor0_avdd_vol = <2800000>;
      				sensor0_dvdd-supply = <>;
      				sensor0_dvdd_vol = <1200000>;
      				sensor0_power_en = <>;
      				/* board error, we can not use the right config. */
      				sensor0_reset = <&pio PE 16 1 0 1 0>;
      				sensor0_pwdn = <&pio PE 17 1 0 1 0>;
      				status	= "okay";
      			sensor1:sensor@1 {
      				device_type = "sensor1";
      				sensor1_mname = "ov5647";
      				sensor1_twi_cci_id = <0>;
      				sensor1_twi_addr = <0x6c>;
      				sensor1_mclk_id = <1>;
      				sensor1_pos = "front";
      				sensor1_isp_used = <0>;
      				sensor1_fmt = <0>;
      				sensor1_stby_mode = <0>;
      				sensor1_vflip = <0>;
      				sensor1_hflip = <0>;
      				sensor1_iovdd-supply = <>;
      				sensor1_iovdd_vol = <2800000>;
      				sensor1_avdd-supply = <>;
      				sensor1_avdd_vol = <2800000>;
      				sensor1_dvdd-supply = <>;
      				sensor1_dvdd_vol = <1500000>;
      				sensor1_power_en = <>;
      				sensor1_reset = <&pio PI 3 1 0 1 0>;
      				sensor1_pwdn = <&pio PI 4 1 0 1 0>;
      			vinc0:vinc@0 {
      				vinc0_csi_sel = <0>;
      				vinc0_mipi_sel = <0>;
      				vinc0_isp_sel = <0>;
      				vinc0_isp_tx_ch = <0>;
      				vinc0_rear_sensor_sel = <0>;
      				vinc0_front_sensor_sel = <0>;
      				vinc0_sensor_list = <0>;
      			vinc1:vinc@1 {
      				vinc1_csi_sel = <0>;
      				vinc1_mipi_sel = <0>;
      				vinc1_isp_sel = <0>;
      				vinc1_isp_tx_ch = <0>;
      				vinc1_rear_sensor_sel = <0>;
      				vinc1_front_sensor_sel = <0>;
      				vinc1_sensor_list = <0>;
      			vinc2:vinc@2 {
      				vinc2_csi_sel = <0>;
      				vinc2_mipi_sel = <0>;
      				vinc2_isp_sel = <0>;
      				vinc2_isp_tx_ch = <0>;
      				vinc2_rear_sensor_sel = <0>;
      				vinc2_front_sensor_sel = <0>;
      				vinc2_sensor_list = <0>;
      			vinc3:vinc@3 {
      				vinc3_csi_sel = <1>;
      				vinc3_mipi_sel = <0xff>;
      				vinc3_isp_sel = <1>;
      				vinc3_isp_tx_ch = <0>;
      				vinc3_rear_sensor_sel = <1>;
      				vinc3_front_sensor_sel = <1>;
      				vinc3_sensor_list = <0>;
      		s_owc0: s_owc@07040400 {
      			pinctrl-0 = <&owc0_pins_a>;
      			pinctrl-1 = <&owc0_pins_b>;
      		sdc0: sdmmc@04020000 {
      			pinctrl-0 = <&sdc0_pins_a>;
      			bus-width = <4>;
      			// cd-gpios = <&pio PF 6 0 1 3 0xffffffff>;
      			non-removable;
      			card-pwr-gpios;// = <&pio PC 4 1 1 2 0xffffffff>;
      			sunxi-power-save-mode;
      			sunxi-signal-vol-sw-without-pmu;
      			sd-uhs-sdr50;
      			sd-uhs-ddr50;
      			sd-uhs-sdr104;
      			/*sunxi-dis-signal-vol-sw;*/
      			max-frequency = <150000000>;
      			min-frequency = <100000>;
      			cd-used-24M;
      			no-sdio;
      			/*broken-cd;*/
      			ctl-spec-caps = <0x8>;
      		card0_boot_para {
      			card_ctrl = <0x0>;
      			card_high_speed = <0x1>;
      			card_line = <0x4>;
      			time_pwroff_ms = <200>;
      			pinctrl-1 = <&sdc0_pins_b>;
      		sdc1: sdmmc@04021000 {
      			pinctrl-0 = <&sdc1_pins_a>;
      			bus-width = <4>;
      			/*sunxi-power-save-mode;*/
      			/*sd-uhs-sdr12*/
      			/*sd-uhs-sdr25*/
      			/*sd-uhs-sdr50*/
      			/*sd-uhs-sdr104*/
      			cap-sdio-irq;
      			keep-power-in-suspend;
      			ignore-pm-notify;
      			max-frequency = <50000000>;
      		usbc0:usbc0@0{
      			usb_port_type = <0>;
      			usb_detect_type = <0>;
      			usb_detect_mode = <0>;
      			usb_id_gpio;
      			usb_det_vbus_gpio;
      			usb_drv_vbus_gpio;
      			usb_host_init_state = <0>;
      		disp: disp@01000000 {
      			disp_init_enable		= <1>;
      			disp_mode				= <0>;
      			screen0_output_type		= <1>;
      			screen0_output_mode		= <4>;
      			disp_rotation_used 		= <1>;
      			degree0					= <0>;
      			fb0_format				= <8>;
      			fb0_width				= <240>;
      			fb0_height				= <240>;
      			// fb0_height				= <320>;
      			lcd0_backlight			= <50>;
      			lcd0_bright				= <50>;
      			lcd0_contrast			= <50>;
      			lcd0_saturation			= <57>;
      			lcd0_hue				= <50>;
      		lcd0: lcd0@01c0c000 {
      			lcd_used            = <1>;
      			lcd_size			= "1.3";
      			lcd_model_name		= "inv";
      			lcd_driver_name     = "st7789v_cpu";
      			lcd_x               = <240>;
      			lcd_y               = <240>;
      			lcd_width           = <108>;
      			lcd_height          = <64>;
      			lcd_dclk_freq       = <10>;
      			lcd_backlight       = <50>;
      			lcd_pwm_used        = <0>;
      			lcd_pwm_ch          = <1>;
      			lcd_pwm_pol         = <1>;
      			lcd_pwm_max_limit   = <255>;
      			lcd_hbp             = <60>;
      			lcd_ht              = <298>;
      			lcd_hspw            = <30>;
      			lcd_vbp             = <250>;
      			lcd_vt              = <265>;
      			lcd_vspw            = <2>;
      			lcd_if              = <1>;
      			lcd_frm             = <2>;
      			lcd_cpu_mode        = <1>;
      			lcd_cpu_te          = <0>;
      			lcd_cpu_if	        = <14>;
      			lcdgamma4iep        = <22>;
      			lcd_gamma_en        = <0>;
      			lcd_cmap_en         = <0>;
      			lcd_bright_curve_en = <0>;
      			lcd_rb_swap			= <0>;
      			lcd_gpio_0 = <&pio PH 5 1 0 3 0>; /* rst */
      			lcd_gpio_1 = <&pio PD 21 1 0 3 0>; /* cs */
      			pinctrl-0 = <&rgb8_pins_a>;
      			pinctrl-1 = <&rgb8_pins_b>;
      		daudio0:daudio@0x05090000 {
      			mclk_div = <0x0>;
      			frametype = <0x00>;
      			tdm_config = <0x01>;
      			sign_extend = <0x00>;
      			tx_data_mode = <0x00>;
      			rx_data_mode = <0x00>;
      			msb_lsb_first = <0x00>;
      			pcm_lrck_period = <0x80>;
      			slot_width_select = <0x20>;
      			asrc_function_en = <0x00>;
      			daudio_master =  <0x04>;
      			signal_inversion =  <0x01>;
      			audio_format =  <0x01>;
      		daudio1:daudio@0x05091000 {
      			mclk_div = <0x01>;
      			frametype = <0x00>;
      		codec:codec@0x05096000 {
      			pa_level = <0x1>;
      			main_gain = <0x17>;
      			adcdrc_cfg = <0x00>;
      			adchpf_cfg = <0x01>;
      			dacdrc_cfg = <0x01>;
      			dachpf_cfg = <0x00>;
      			digital_vol = <0x00>;
      			lineout_vol = <0x1f>;
      			pa_msleep_time = <0xa0>;
      			/* gpio-spk = <&pio PH 14 1 1 1 1>; */
      		sndcodec:sound@0 {
      		snddaudio0:sound@1 {
      			sunxi,snddaudio-codec = "ac108.2-003b";
      			sunxi,snddaudio-codec-dai = "ac108-pcm0";
      			sunxi,cpudai-controller = <&daudio0>;
      		snddaudio1:sound@2 {
      	//wlan:wlan {
      	//	compatible = "allwinner,sunxi-wlan";
      	//	clocks = <&clk_losc_out>;
      	//	wlan_busnum = <1>;
      	//	wlan_usbnum = <3>;
      	//	wakeup_source = <0>;
      //		/* wlan_power-supply = <&reg_dcdc1>; */
      //		/* io_regulator-supply = <&reg_dcdc5>; */
      //		/* wlan_power_vol = <3300000>; */
      //		/* io_regulator_vol = <3300000>; */
      //		/* wlan_en; */
      //		wlan_regon = <&pio PH 4 1 0 1 0>;
      //		/* wlan_hostwake = <&pio PG 7 0 0 1 0>; */
      //		wlan_hostwake;
      //		status = "okay";
      以及启动日志
      [32]HELLO! BOOT0 is starting!
      [35]BOOT0 commit : e3b2a9e
      [38]board init start
      [40]set pll start
      [42]set pll end
      [44][pmu]: bus read error
      [46][pmu]: bus read error
      [49]board init ok
      [51]chip id check OK
      [52]DRAM BOOT DRIVE INFO: V0.41
      [56]DRAM CLK = 528 MHz
      [58]DRAM Type = 2 (2:DDR2,3:DDR3)
      [61]DRAMC read ODT  off.
      [63]DRAM ODT off.
      [66]DRAM SIZE =64 M
      [72]DRAM simple test OK.
      [74]rtc standby flag is 0x0, super standby flag is 0x0
      [79]dram size =64
      [82]card no is 0
      [83]sdcard 0 line count 4
      [86][mmc]: mmc driver ver 2020-01-08 17:05
      [90][mmc]: sdc0 spd mode error, 2
      [93][mmc]: set f_max to 50M, set f_max_ddr to 25M
      [98][mmc]: mmc 0 bias 0
      [106][mmc]: Wrong media type 0x0
      [109][mmc]: ***Try SD card 0***
      [119][mmc]: HSSDR52/SDR25 4 bit
      [122][mmc]: 50000000 Hz
      [125][mmc]: 7680 MB
      [127][mmc]: ***SD/MMC 0 init OK!!!***
      [190]Loading boot-pkg Succeed(index=0).
      [194]Entry_name        = optee
      [197]Entry_name        = u-boot
      [203]Entry_name        = dtb
      [206]Jump to second Boot.
      MESSAGE: [0x0] TEE-CORE: OP-TEE version: sun8iw19p1_v0.6.0-14-gf6954e7 #1 2019年 11月 21日 星期四 01:34:42 UTC arm
      ERROR:   [0x0] TEE-CORE:platform_standby_fdt_parse:126: no pmu node
      ERROR:   [0x0] TEE-CORE:sunxi_twi_parse_from_dt:84: no pmu node
      U-Boot 2018.05-00008-g384031a (Jan 16 2020 - 14:12:41 +0800) Allwinner Technology
      [00.278]CPU:   Allwinner Family
      [00.280]Model: sun8iw19
      I2C:   ready
      [00.285]DRAM:  64 MiB
      [00.288]Relocation Offset is: f9f46000
      [00.309]secure enable bit: 0
      [00.312]pmu_axp152_probe pmic_bus_read fail
      [00.316]pmu_axp2101_probe pmic_bus_read fail
      [00.320]bmu_axp152_probe pmic_bus_read fail
      [00.323]bmu_axp2101_probe pmic_bus_read fail
      [00.327]CPU=816 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=132Mhz
      [00.334]gic: sec monitor mode
      [00.336]flash init start
      [00.339]workmode = 0,storage type = 1
      [00.342]MMC:     0
      [00.343]get mem for descripter OK !
      card_caps:0x3000000a
      host_caps:0x3000003f
      [00.375]sunxi flash init ok
      [00.379]Loading Environment from SUNXI_FLASH... OK
      [00.406]update dts
      root_partition is rootfs
      set root to /dev/mmcblk0p4
      [00.436]update part info
      [00.462]update bootcmd
      [00.464]No ethernet found.
      ## Booting kernel from Legacy Image at 45000000 ...
         Image Name:   ARM OpenWrt Linux-4.9.118
         Image Type:   ARM Linux Kernel Image (uncompressed)
         Data Size:    2956008 Bytes = 2.8 MiB
         Load Address: 40008000
         Entry Point:  40008000
      [01.856]Starting kernel ...
      [01.859]mmc 2 not find, so not exit
      [    0.000000] Linux version 4.9.118 (tina@ubuntu) (gcc version 6.4.1 (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) ) #10 PREEMPT Mon Nov 14 07:15:06 UTC 2022
      [    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d
      [    0.000000] OF: fdt:Machine model: sun8iw19
      [    0.000000] ion_mem_reserve: err format for ion reserve list!
      [    0.000000] Memory policy: Data cache writeback
      [    0.000000] free_area_init_node: node 0, pgdat c04c4058, node_mem_map c3f79000
      [    0.000000]   Normal zone: 128 pages used for memmap
      [    0.000000]   Normal zone: 16384 pages, LIFO batch:3
      [    0.000000] CPU: All CPU(s) started in SVC mode.
      [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16256
      [    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x05000000 initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p4 rootwait init=/pseudo_init rdinit=/sbin/rdinit partitions=boot-res@mmcblk0p1:env@mmcblk0p2:boot@mmcblk0p3:rootfs@mmcblk0p4:UDISK@mmcblk0p5 cma=0 mac_addr= wifi_mac= bt_mac= selinux= specialstr= coherent_pool=16K ion_carveout_list= androidboot.mode=normal androidboot.hardware=sun8iw19p1 boot_type=1 androidboot.boot_type=1 gpt=1 uboot_message=2018.05-00008-g384031a(01/16/2020-14:12:41) mbr_offset=1032192 bootreason=unknow
      [    0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
      [    0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
      [    0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
      [    0.000000] Memory: 59552K/65536K available (3120K kernel code, 235K rwdata, 1200K rodata, 136K init, 129K bss, 5984K reserved, 0K cma-reserved)
      [    0.000000]     vmalloc : 0xc4800000 - 0xff800000   ( 944 MB)
      [    0.000000]     lowmem  : 0xc0000000 - 0xc4000000   (  64 MB)
      [    0.000000]     modules : 0xbf800000 - 0xc0000000   (   8 MB)
      [    0.000000]       .text : 0xc0008000 - 0xc0314240   (3121 kB)
      [    0.000000]       .init : 0xc0468000 - 0xc048a000   ( 136 kB)
      [    0.000000]       .data : 0xc048a000 - 0xc04c4c58   ( 236 kB)
      [    0.000000]        .bss : 0xc04c4c58 - 0xc04e5244   ( 130 kB)
      [    0.000021] Switching to timer-based delay loop, resolution 41ns
      [    0.000158] Console: colour dummy device 80x30
      [    0.000185] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      [    0.000200] pid_max: default: 32768 minimum: 301
      [    0.000371] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
      [    0.000383] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
      [    0.000976] CPU: Testing write buffer coherency: ok
      [    0.001247] Setting up static identity map for 0x400081c0 - 0x4000820c
      [    0.002684] devtmpfs: initialized
      [    0.030493] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
      [    0.030831] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.030856] futex hash table entries: 256 (order: -1, 3072 bytes)
      [    0.031013] atomic64_test: passed
      [    0.031025] pinctrl core: initialized pinctrl subsystem
      [    0.031904] NET: Registered protocol family 16
      [    0.032475] DMA: preallocated 16 KiB pool for atomic coherent allocations
      [    0.033888] dump_class_init,857, success
      [    0.035231] sunxi iommu: irq = 23
      [    0.041077] sun8iw19p1-r-pinctrl r_pio: initialized sunXi PIO driver
      [    0.056831] use hosc , set rate 1000000
      [    0.056860] sun8iw19p1-pinctrl pio: initialized sunXi PIO driver
      [    0.059076] iommu: Adding device 1c0e000.ve to group 0
      [    0.060828] iommu: Adding device 2300000.eise to group 0
      [    0.068299] iommu: Adding device 1000000.disp to group 0
      [    0.070078] iommu: Adding device 1480000.g2d to group 0
      [    0.070652] iommu: Adding device 2400000.nna to group 0
      [    0.074375] iommu: Adding device csi0 to group 0
      [    0.075663] iommu: Adding device csi1 to group 0
      [    0.076962] iommu: Adding device 2100000.isp to group 0
      [    0.077545] iommu: Adding device 2104000.scaler to group 0
      [    0.077927] iommu: Adding device 2104400.scaler to group 0
      [    0.078272] iommu: Adding device 2104800.scaler to group 0
      [    0.078773] iommu: Adding device 2104c00.scaler to group 0
      [    0.080373] iommu: Adding device vinc0 to group 0
      [    0.081121] iommu: Adding device vinc1 to group 0
      [    0.131316] pwm module init!
      [    0.135165] SCSI subsystem initialized
      [    0.135564] usbcore: registered new interface driver usbfs
      [    0.135655] usbcore: registered new interface driver hub
      [    0.138244] usbcore: registered new device driver usb
      [    0.138521] sunxi_i2c_adap_init()2551 - init
      [    0.139109] sunxi_i2c_probe()2288 - [i2c1] twi_drv_used = 1
      [    0.139124] sunxi_i2c_probe()2292 - [i2c1] twi_pkt_interval = 0
      [    0.139144] twi1 supply twi not found, using dummy regulator
      [    0.139246] twi_request_gpio()455 - [i2c1] init name: twi1
      [    0.139566] sunxi_i2c_dma_request()1125 - [i2c1] using dma0chan0 (tx) and dma0chan1 (rx)for DMA transfers
      [    0.139676] sun8iw19p1-pinctrl pio: expect_func as:twi2, but muxsel(5) is func:uart2
      [    0.139695] sun8iw19p1-pinctrl pio: expect_func as:twi2, but muxsel(5) is func:uart2
      [    0.140346] sunxi_i2c_probe()2288 - [i2c2] twi_drv_used = 0
      [    0.140361] sunxi_i2c_probe()2292 - [i2c2] twi_pkt_interval = 0
      [    0.140380] twi2 supply twi not found, using dummy regulator
      [    0.140475] twi_request_gpio()455 - [i2c2] init name: twi2
      [    0.141853] media: Linux media interface: v0.10
      [    0.142008] Linux video capture interface: v2.00
      [    0.143268] ion_parse_dt_heap_common: id 0 type 0 name sys_user align 1000
      [    0.143523] ion_parse_dt_heap_common: id 1 type 1 name sys_contig align 1000
      [    0.143740] ion_parse_dt_heap_common: id 4 type 4 name cma align 1000
      [    0.145030] Advanced Linux Sound Architecture Driver Initialized.
      [    0.148460] G2D: rcq version initialized.major:251
      [    0.149377] clocksource: Switched to clocksource arch_sys_counter
      [    0.171664] udc_init,0
      [    0.171839] NET: Registered protocol family 2
      [    0.172678] TCP established hash table entries: 16 (order: -6, 64 bytes)
      [    0.172696] TCP bind hash table entries: 16 (order: -6, 64 bytes)
      [    0.172707] TCP: Hash tables configured (established 16 bind 16)
      [    0.172773] UDP hash table entries: 256 (order: 0, 4096 bytes)
      [    0.172795] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
      [    0.172965] NET: Registered protocol family 1
      [    0.175841] workingset: timestamp_bits=30 max_order=14 bucket_order=0
      [    0.192585] squashfs: version 4.0 (2009/01/31) Phillip Lougher
      [    0.193368] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
      [    0.195961] NET: Registered protocol family 38
      [    0.196010] io scheduler noop registered
      [    0.196020] io scheduler deadline registered
      [    0.196314] io scheduler cfq registered (default)
      [    0.197268] [DISP]disp_module_init
      [    0.230897] [DISP] Fb_copy_boot_fb,line:1503:
      [    0.230912] no boot_fb0
      [    0.233732] [DISP] disp_sys_pwm_config,line:618:
      [    0.233744] disp_sys_pwm_Config, handle is NULL!
      [    0.233755] [DISP] disp_sys_pwm_set_polarity,line:636:
      [    0.233761] disp_sys_pwm_Set_Polarity, handle is NULL!
      [    0.235155] [DISP]disp_module_init finish
      [    0.237427] uart uart0: get regulator failed
      [    0.237457] uart0 supply uart not found, using dummy regulator
      [    0.237658] uart uart0: uart0 error to get fifo size property
      [    0.237720] uart0: ttyS0 at MMIO 0x5000000 (irq = 294, base_baud = 1500000) is a SUNXI
      [    0.237748] sw_console_setup()1830 - console setup baud 115200 parity n bits 8, flow n
      [    0.365017] [ST7789V LCD INFO] LINE:0208-->LCD_panel_init:
      [    0.365026] [ST7789V LCD INFO] LINE:0225-->lcd_panel_st7789v_init:
      [    0.861362] [DISP] disp_lcd_pwm_enable,line:959:
      [    0.861363] pwm device hdl is NULL
      [    0.861375] [DISP] disp_device_attached_and_enable,line:221:
      [    0.861376] attached ok, mgr0<-->dev0
      [    0.861387] [DISP] disp_device_attached_and_enable,line:224:
      [    0.861388] type:1,mode:0,fmt:rgb,bits:8bits,eotf:4,cs:0 dvi_hdmi:2, range:2 scan:0 ratio:8
      [    1.189520] console [ttyS0] enabled
      [    1.194231] uart uart1: get regulator failed
      [    1.199052] uart1 supply uart not found, using dummy regulator
      [    1.206043] uart uart1: uart1 error to get fifo size property
      [    1.212682] uart1: ttyS1 at MMIO 0x5000400 (irq = 295, base_baud = 1500000) is a SUNXI
      [    1.222683] misc dump reg init
      [    1.228568] libphy: Fixed MDIO Bus: probed
      [    1.234332] sun8iw19p1-pinctrl pio: expect_func as:gmac0, but muxsel(5) is func:ephy
      [    1.243476] sun8iw19p1-pinctrl pio: pin PD1 already requested by soc@03000000:lcd0@01c0c000; cannot claim for 5020000.eth
      [    1.256042] sun8iw19p1-pinctrl pio: pin-97 (5020000.eth) status -22
      [    1.263162] sun8iw19p1-pinctrl pio: could not request pin 97 (PD1) from group PD1  on device pio
      [    1.273105] sunxi-gmac 5020000.eth: Error applying setting, reverse things back
      [    1.281392] sunxi-gmac: probe of 5020000.eth failed with error -22
      [    1.288604] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [    1.296392] get drv_vbus is fail, 84
      [    1.300483] get ehci0-controller, regulator_io is no nocare
      [    1.306794] get ehci0-controller wakeup-source is fail.
      [    1.312883] sunxi ehci0-controller don't init wakeup source
      [    1.319160] [sunxi-ehci0]: probe, pdev->name: 5101000.ehci0-controller, sunxi_ehci: 0xc04df698, 0x:c48dd000, irq_no:12c
      [    1.331450] sunxi-ehci 5101000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
      [    1.341723] sunxi-ehci 5101000.ehci0-controller: new USB bus registered, assigned bus number 1
      [    1.351614] sunxi-ehci 5101000.ehci0-controller: irq 300, io mem 0xc3057800
      [    1.389404] sunxi-ehci 5101000.ehci0-controller: USB 0.0 started, EHCI 1.00
      [    1.398309] hub 1-0:1.0: USB hub found
      [    1.402829] hub 1-0:1.0: 1 port detected
      [    1.407589] [ehci0-controller]: sunxi_usb_disable_ehci
      [    1.413423] [sunxi-ehci0]: remove, pdev->name: 5101000.ehci0-controller, sunxi_ehci: 0xc04df698
      [    1.423284] sunxi-ehci 5101000.ehci0-controller: remove, state 1
      [    1.430133] usb usb1: USB disconnect, device number 1
      [    1.436562] sunxi-ehci 5101000.ehci0-controller: USB bus 1 deregistered
      [    1.444798] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [    1.452270] get drv_vbus is fail, 84
      [    1.456334] get ohci0-controller, regulator_io is no nocare
      [    1.462697] get ohci0-controller wakeup-source is fail.
      [    1.468736] sunxi ohci0-controller don't init wakeup source
      [    1.475224] [sunxi-ohci0]: probe, pdev->name: 5101000.ohci0-controller, sunxi_ohci: 0xc04dee48
      [    1.485042] sunxi-ohci 5101000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
      [    1.494911] sunxi-ohci 5101000.ohci0-controller: new USB bus registered, assigned bus number 1
      [    1.504663] sunxi-ohci 5101000.ohci0-controller: irq 301, io mem 0xc3057c00
      [    1.584438] hub 1-0:1.0: USB hub found
      [    1.588904] hub 1-0:1.0: 1 port detected
      [    1.593693] [ohci0-controller]: sunxi_usb_disable_ohci
      [    1.599522] [sunxi-ohci0]: remove, pdev->name: 5101000.ohci0-controller, sunxi_ohci: 0xc04dee48
      [    1.609326] sunxi-ohci 5101000.ohci0-controller: remove, state 1
      [    1.616186] usb usb1: USB disconnect, device number 1
      [    1.622684] sunxi-ohci 5101000.ohci0-controller: USB bus 1 deregistered
      [    1.631043] usbcore: registered new interface driver uas
      [    1.637380] usbcore: registered new interface driver usb-storage
      [    1.644406] usbcore: registered new interface driver ums-alauda
      [    1.651430] usbcore: registered new interface driver ums-cypress
      [    1.658395] usbcore: registered new interface driver ums-datafab
      [    1.665384] usbcore: registered new interface driver ums_eneub6250
      [    1.672613] usbcore: registered new interface driver ums-freecom
      [    1.679699] usbcore: registered new interface driver ums-isd200
      [    1.686602] usbcore: registered new interface driver ums-jumpshot
      [    1.693696] usbcore: registered new interface driver ums-karma
      [    1.700562] usbcore: registered new interface driver ums-onetouch
      [    1.707707] usbcore: registered new interface driver ums-realtek
      [    1.714720] usbcore: registered new interface driver ums-sddr09
      [    1.721668] usbcore: registered new interface driver ums-sddr55
      [    1.728599] usbcore: registered new interface driver ums-usbat
      [    1.735346] usb_serial_number:20080411
      [    1.739984] sunxi_gpadc_init,1831, success
      [    1.745081] sunxi_gpadc_setup: get channel scan data failed
      [    1.752110] input: sunxi-gpadc0 as /devices/virtual/input/input0
      [    1.760284] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
      [    1.767240] sunxi-rtc rtc: RTC enabled
      [    1.772192] i2c /dev entries driver
      [    1.776804] sunxi cedar version 0.1
      [    1.781176] VE: install start!!!
      [    1.781176]
      [    1.786632] cedar_ve: cedar-ve the get irq is 291
      [    1.792160] VE: line 1811 set the sram data
      [    1.792160]
      [    1.799051] VE: ve_debug_proc_info:c04e1910, data:c39dc000, lock:c04e1998
      [    1.799051]
      [    1.808636] VE: install end!!!
      [    1.808636]
      [    1.814235] google_vp9: sunxi google vp9 version 0.1
      [    1.821052] sunxi-wdt 30090a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
      [    1.832030] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.37 2019-12-4 9:48)
      [    1.841276] sunxi-mmc sdc0: ***ctl-spec-caps*** 8
      [    1.846618] sunxi-mmc sdc0: No vmmc regulator found
      [    1.852207] sunxi-mmc sdc0: No vqmmc regulator found
      [    1.857801] sunxi-mmc sdc0: No vdmmc regulator found
      [    1.863501] sunxi-mmc sdc0: No vd33sw regulator found
      [    1.869200] sunxi-mmc sdc0: No vd18sw regulator found
      [    1.874930] sunxi-mmc sdc0: No vq33sw regulator found
      [    1.880660] sunxi-mmc sdc0: No vq18sw regulator found
      [    1.886369] sunxi-mmc sdc0: Cann't get uart0 pinstate,check if needed
      [    1.893642] sunxi-mmc sdc0: Cann't get sleep pinstate,check if needed
      [    1.901385] sunxi-mmc sdc0: set host busy
      [    1.905993] mmc:failed to get gpios
      [    1.909963] sunxi-mmc sdc0: min-frequency:100000
      [    1.915444] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.925931] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
      [    1.959409] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.999409] sunxi-mmc sdc0: detmode:alway in(non removable)
      [    1.999437] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.007828] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.030842] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.041992] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.37 2019-12-4 9:48)
      [    2.042136] sunxi-mmc sdc1: No vmmc regulator found
      [    2.042143] sunxi-mmc sdc1: No vqmmc regulator found
      [    2.042148] sunxi-mmc sdc1: No vdmmc regulator found
      [    2.042153] sunxi-mmc sdc1: No vd33sw regulator found
      [    2.042159] sunxi-mmc sdc1: No vd18sw regulator found
      [    2.042164] sunxi-mmc sdc1: No vq33sw regulator found
      [    2.042170] sunxi-mmc sdc1: No vq18sw regulator found
      [    2.042187] sunxi-mmc sdc1: Cann't get uart0 pinstate,check if needed
      [    2.042602] sunxi-mmc sdc1: set host busy
      [    2.042665] mmc:failed to get gpios
      [    2.042941] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.042972] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
      [    2.074373] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.103395] sunxi-mmc sdc1: detmode:manually by software
      [    2.148820] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.162856] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
      [    2.169704] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
      [    2.175748] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.187427] usbcore: registered new interface driver usbhid
      [    2.187430] usbhid: USB HID core driver
      [    2.187812] mostcore: init()
      [    2.206705] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.219587] sunxi-mmc sdc1: smc 1 p1 err, cmd 8, RTO !!
      [    2.225503] mmc0: host does not support reading read-only switch, assuming write-enable
      [    2.235393] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    2.241320] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [    2.252002] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    2.257917] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    2.263825] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    2.269741] sunxi-mmc sdc1: smc 1 p1 err, cmd 55, RTO !!
      [    2.275749] sunxi-mmc sdc1: smc 1 p1 err, cmd 55, RTO !!
      [    2.281757] sunxi-mmc sdc1: smc 1 p1 err, cmd 55, RTO !!
      [    2.287752] sunxi-mmc sdc1: smc 1 p1 err, cmd 55, RTO !!
      [    2.287783] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.293855] sunxi-mmc sdc1: smc 1 p1 err, cmd 1, RTO !!
      [    2.293887] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    2.322023] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [    2.333043] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
      [    2.343986] mmc0: new high speed SDHC card at address 0001
      [    2.351023] mmcblk0: mmc0:0001 ASTC 7.50 GiB
      [    2.359857]  mmcblk0: p1 p2 p3 p4 p5
      [    2.567299] random: fast init done
      [    7.209398] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x3b)
      [   12.249393] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x3b)
      [   17.289395] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x3b)
      [   22.329394] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x3b)
      [   27.369395] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x3b)
      [   32.409396] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x3b)
      [   37.449390] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x3b)
      [   42.489388] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x3b)
      [   47.529400] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x3b)
      [   52.569388] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x3b)
      [   57.609388] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x3b)
      [   62.649396] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x3b)
      [   67.689388] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x3b)
      [   72.729388] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x3b)
      [   77.769387] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x3b)
      [   82.809388] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x3b)
      [   87.849387] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x3b)
      [   92.889388] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x3b)
      [   97.929388] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x3b)
      [  102.969387] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x3b)
      [  106.015423] random: crng init done
      [  108.009389] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x3b)
      [  113.049394] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x3b)
      [  118.089388] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x3b)
      [  123.129388] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x3b)
      [  128.169388] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x3b)
      [  128.177044] ac108 2-003b: ref_cfg.ref_channel:0x3, set ref_pga_gain:16
      [  133.209388] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x3b)
      [  138.249387] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x3b)
      [  143.289387] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x3b)
      [  148.329387] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x3b)
      [  153.369387] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x3b)
      [  158.409388] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x3b)
      [  163.449388] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x3b)
      [  168.489387] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x3b)
      [  173.609387] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x3b)
      [  178.649387] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x3b)
      [  178.657072] ac108 2-003b: i2c probe succeed.
      [  183.689394] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x35)
      [  188.729388] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x35)
      [  193.769387] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x35)
      [  198.809387] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x35)
      [  203.849387] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x35)
      [  208.889387] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x35)
      [  213.929394] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x35)
      [  218.969395] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x35)
      [  224.009387] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x35)
      [  229.049387] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x35)
      [  234.089393] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x35)
      [  239.129387] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x35)
      [  244.169386] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x35)
      [  249.209387] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x35)
      [  254.249386] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x35)
      [  259.289387] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x35)
      [  264.329387] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x35)
      [  269.369387] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x35)
      [  274.409387] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x35)
      [  279.449393] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x35)
      [  284.489387] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x35)
      [  289.529387] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x35)
      [  294.569386] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x35)
      [  299.609386] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x35)
      [  304.649386] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x35)
      [  304.657043] ac108 2-0035: ref_cfg.ref_channel:0x3, set ref_pga_gain:16
      [  309.689390] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x35)
      [  314.729387] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x35)
      [  319.769387] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x35)
      [  324.809387] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x35)
      [  329.849386] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x35)
      [  334.889386] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x35)
      [  339.929386] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x35)
      [  344.969393] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x35)
      [  350.089386] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x35)
      [  355.129386] sunxi_i2c_do_xfer()1935 - [i2c2] xfer timeout (dev addr:0x35)
      [  355.137066] ac108 2-0035: i2c probe succeed.
      [  355.142563] --->sunxi_daudio_dev_probe<--- strat.
      [  355.148024] sunxi-daudio daudio0: regulator missing or invalid
      [  355.154915] --->sunxi_daudio_dev_probe<--- end.
      [  355.160826] digital_vol:0, lineout_vol:31, main_gain:23, pa_msleep:160, pa_level:1
      [  355.169597] adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:1, dachpf:0
      [  355.176277] sunxi-internal-codec codec: [sunxi_internal_codec_probe] codec probe finished.
      [  355.187775] NET: Registered protocol family 10
      [  355.194629] NET: Registered protocol family 17
      [  355.199995] NET: Registered protocol family 15
      [  355.205769] Registering SWP/SWPB emulation handler
      [  355.217662] get det_vbus is fail, 84
      [  355.221886] get id is fail, 84
      [  355.226226] sunxi-rtc rtc: setting system clock to 1970-01-01 00:17:11 UTC (1031)
      [  355.235888] snddaudio snddaudio0: codec: ac108.2-003b, codec_dai: ac108-pcm0.
      [  355.244523] snddaudio snddaudio0: ac108-pcm0 <-> daudio0 mapping ok
      [  355.253138] ALSA device list:
      [  355.256518]   #0: sndac108.2-003b
      ^[  355.262964] EXT4-fs (mmcblk0p4): couldn't mount as ext3 due to feature incompatibilities
      [  355.282456] EXT4-fs (mmcblk0p4): mounted filesystem without journal. Opts: (null)
      [  355.291283] VFS: Mounted root (ext4 filesystem) readonly on device 179:4.
      [  355.299228] Freeing unused kernel memory: 136K
      [  355.304318] This architecture does not have kernel memory protection.
      [  355.491611] EXT4-fs (mmcblk0p4): warning: mounting unchecked fs, running e2fsck is recommended
      [  355.507586] EXT4-fs error (device mmcblk0p4): ext4_has_uninit_itable:3049: comm mount: Inode table for bg 0 marked as needing zeroing
      [  355.525377] EXT4-fs (mmcblk0p4): Remounting filesystem read-only
      [  355.532191] EXT4-fs (mmcblk0p4): re-mounted. Opts: block_validity,delalloc,barrier,user_xattr
      [  355.771252] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
      ------run rc.final file-----
      Load mpp modules
      [  355.979330] [sensor_power_err]fetch sensor0_phase from device_tree failed
      [  356.053679] [VIN_ERR]registering sp2305_mipi, No such device!
      Initializing random number generator... done.
      Starting network...
      [  356.381921] get wifi_sdc_id failed
      [  356.516050] get wifi_sdc_id failed
      insmod: can't insert '/lib/modules/4.9.118/8189fs.ko': Operation not permitted
      ifconfig: SIOCGIFFLAGS: No such device
      Line 6: Invalid passphrase length 0 (expected: 8..63) '"'.
      Line 6: failed to parse psk '""'.
      Line 7: failed to parse network block.
      Failed to read or parse configuration '/etc/wpa_supplicant.conf'.
      udhcpc: SIOCGIFINDEX: No such device
      Starting telnetd: OK
      enable android usb
      [  358.666454] file system registered
      [  358.677955] Mass Storage Function, version: 2009/09/11
      [  358.683941] LUN: removable file: (no medium)
      [  358.721450] read descriptors
      [  358.724713] read strings
      [  359.289398]
      [  359.289398] insmod_device_driver
      [  359.289398]
      [  359.296639] device_chose finished 124!
      sh: write error: Resource busy
      generate key
      Public key portion is:
      ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCKj6mtQSsizfGZRzCkxmXH05+mWT8NdT33msREbe2rwjCTryHxXyNzITB8dYtumpvQg7TvBhOSBqQ4nnTxmryoKlYAVpKOt3IVYtzWR3MVb/PjMHvZOi+whtJ3a+pekCrdnsv8zYhp0Kh7tUnPA1vRwzxEPRn9GfxrNuRioVhF0pGlEpiGzZc+z39HIZJfuS82JYxJvthCaHtJnAm3IYIdFaGKGQhaTZ2RG0K17Hmpxr8MHJPVOqcNNIOQm0884HMQJjK765CdPgj13ePpVkihIyYruntvJsCIWnILou7DRc4Ns2syMj9GSqf97eDXpEfBI8PtUeXb7CM7lf/u/9xX root@YuzukiIRC
      Fingerprint: md5 db:94:52:29:18:2d:16:90:cc:05:75:6d:24:d7:d1:84
      Start dropbear: OK
      Starting ntpd: done
      ------run profile file-----
        _    _                       _        ____   _____
       | |  | | Powered by OpenWRT  | |      / __ \ / ____|
       | |  | |_ __  _   _ ___  ___ | | __ _| |  | | (___
       | |  | | '_ \| | | / __|/ _ \| |/ _` | |  | |\___ \
       | |__| | | | | |_| \__ \ (_) | | (_| | |__| |____) |
        \____/|_| |_|\__,_|___/\___/|_|\__,_|\____/|_____/
       Yuzuki UnusolaOS (v1.0, Tina: 5C1C9C53)
      root@YuzukiIRC:/# w
        WhycanService LV 8 最后由 编辑
        sunxi.zip
        尝试替换一下驱动
        R 1 条回复 最后回复 回复 引用 分享 0
        • R
          RTQQQ LV 5 @WhycanService 最后由 编辑
          @whycanservice 很奏效,药到病除😊
