    【系统更新】更新多媒体中间件,在Tina D1上支持gstreamer
    tina d1 sdk
    5
    10
    5759
      DOT小文哥 LV 8 最后由 xiaowenge 编辑
      基于D1_Tina_Open V1.0.1版本更新对gstreamer的支持:
      1、Tina升级gstreamer主包及其各插件包到1.16.3版本,支持RV架构;
      2、gstreamer显示插件sunxifbsink支持g2d硬件旋转;
      3、更新多媒体中间件。
      详见全志客户服务平台:全志客户服务平台
        houxiaoni LV 5 最后由 编辑
        修改内核disp相关参数,旋转fb上UI的显示后,sunxifbsink显示异常问题
        H 1 条回复 最后回复 回复 引用 分享 0
          houxiaoni LV 5 @houxiaoni 最后由 xiaowenge 编辑
          上图参数实现旋转fb以达到旋转UI的目的,但此修改会导致sunxifbsink中获取到的视频层信息也随之改变,所以需要重置视频层的分辨率为屏幕物理分辨率,改动如下图所示:
          • tigger
            tigger LV 7 最后由 编辑
            隐藏有点深, 终于看到了.
            • cube_work
              cube_work LV 5 最后由 编辑
              cube@ubuntu:/opt/D1/package$ patch -p1 < /mnt/hgfs/D/work2/D1_open_tina_multimedia_update_0730/0001-libatomic_ops-upgraded-version-from-v        7.4.8-to-v7.6.8.patch
              patching file libs/libatomic_ops/Makefile
              cube@ubuntu:/opt/D1/package$ patch -p1 < /mnt/hgfs/D/work2/D1_open_tina_multimedia_update_0730/0002-alsa-plugins-resolving-compilation-er        rors.patch
              patching file libs/alsa-plugins/Makefile
              cube@ubuntu:/opt/D1/package$ patch -p1 < /mnt/hgfs/D/work2/D1_open_tina_multimedia_update_0730/0003-libv4l-upgraded-version-from-v1.10.0-        to-v1.20.0.patch
              patching file libs/libv4l/Makefile
              patching file libs/libv4l/patches/020-add-missing-includes-and-libs.patch
              patching file libs/libv4l/patches/020-add-missing-includes.patch
              patching file libs/libv4l/patches/030-dont-call-getsubopt.patch
              cube@ubuntu:/opt/D1/package$ patch -p1 < /mnt/hgfs/D/work2/D1_open_tina_multimedia_update_0730/0004-multimedia-update-gstreamer-from-1.14        .4-to-1.16.3-fo.patch
              patching file allwinner/tina_multimedia/libcedarc/openmax/vdec/inc/omx_vdec_config.h
              patching file multimedia/gst1-libav/Makefile
              patching file multimedia/gst1-omx/Makefile
              patching file multimedia/gst1-omx/patches/0001-gst-omx-adapter-omx-to-Cedarc.patch
              patching file multimedia/gst1-omx/patches/0002-gst-omx-support-YV12-format.patch
              patching file multimedia/gst1-omx/patches/0003-encode-re-allocate-buffers-to-support-omx-video-enco.patch (renamed from multimedia/gst1-o        mx/patches/0004-encode-re-allocate-buffers-to-support-omx-video-enco.patch)
              patching file multimedia/gst1-omx/patches/0003-gst-omx-fix-vital-error-for-failing-to-load-omx-plug.patch
              patching file multimedia/gst1-omx/patches/0004-gstomx-drop-20-frames.patch (renamed from multimedia/gst1-omx/patches/0005-gstomx-drop-20-        frames.patch)
              patching file multimedia/gst1-omx/patches/0005-omx-modify-dec-to-adapt-changed-resolution-video.patch (renamed from multimedia/gst1-omx/p        atches/0006-omx-modify-dec-to-adapt-changed-resolution-video.patch)
              patching file multimedia/gst1-omx/patches/0006-gst-omx-omx-fix-green-bottom-of-video-playbacking.patch (renamed from multimedia/gst1-omx/        patches/0008-gst-omx-omx-fix-green-bottom-of-video-playbacking.patch)
              patching file multimedia/gst1-omx/patches/0007-add-byte-stream-property-to-enable-nalu-when-use-omx.patch (renamed from multimedia/gst1-o        mx/patches/0009-add-byte-stream-property-to-enable-nalu-when-use-omx.patch)
              patching file multimedia/gst1-omx/patches/0007-gstreamer-gst-omx-support-external-openmax-and-HEVC.patch
              patching file multimedia/gst1-plugins-aw/Makefile
              Hunk #1 succeeded at 81 (offset -25 lines).
              Hunk #2 succeeded at 119 with fuzz 2 (offset -27 lines).
              patching file multimedia/gst1-plugins-bad/Makefile
              patching file multimedia/gst1-plugins-bad/patches--bk/0001-disable-fdkaac-to-avoid-compile-error-temporarily.patch (renamed from multimed        ia/gst1-plugins-bad/patches/0001-disable-fdkaac-to-avoid-compile-error-temporarily.patch)
              patching file multimedia/gst1-plugins-bad/patches--bk/0002-waylandsink-resize-window-and-position.patch (renamed from multimedia/gst1-plu        gins-bad/patches/0002-waylandsink-resize-window-and-position.patch)
              patching file multimedia/gst1-plugins-bad/patches--bk/0003-waylandsink-fix-waylandsink-not-support-YV12-src.patch (renamed from multimedi        a/gst1-plugins-bad/patches/0003-waylandsink-fix-waylandsink-not-support-YV12-src.patch)
              patching file multimedia/gst1-plugins-bad/patches--bk/0004-waylandsink-add-linux-dmabuf.patch (renamed from multimedia/gst1-plugins-bad/p        atches/0004-waylandsink-add-linux-dmabuf.patch)
              patching file multimedia/gst1-plugins-bad/patches--bk/0005-waylandsink-fix-compile-error-for-viewporter-src-fil.patch (renamed from multi        media/gst1-plugins-bad/patches/0005-waylandsink-fix-compile-error-for-viewporter-src-fil.patch)
              patching file multimedia/gst1-plugins-bad/patches--bk/0006-waylandsink-wayland-support-zero-copy-decoding.patch (renamed from multimedia/        gst1-plugins-bad/patches/0006-waylandsink-wayland-support-zero-copy-decoding.patch)
              patching file multimedia/gst1-plugins-bad/patches--bk/0007-wayland-add-crop-and-resize-width-and-height-when-no.patch (renamed from multi        media/gst1-plugins-bad/patches/0007-wayland-add-crop-and-resize-width-and-height-when-no.patch)
              patching file multimedia/gst1-plugins-bad/patches--bk/0008-wayland-add-waylandsink-initial-window-position.patch (renamed from multimedia        /gst1-plugins-bad/patches/0008-wayland-add-waylandsink-initial-window-position.patch)
              patching file multimedia/gst1-plugins-bad/patches--bk/0009-wayland-add-waylandsink-vflip-and-hflip-function.patch (renamed from multimedi        a/gst1-plugins-bad/patches/0009-wayland-add-waylandsink-vflip-and-hflip-function.patch)
              patching file multimedia/gst1-plugins-bad/patches--bk/0010-wayland-fix-waylandsink-crash-by-a-silly-mistake.patch (renamed from multimedi        a/gst1-plugins-bad/patches/0010-wayland-fix-waylandsink-crash-by-a-silly-mistake.patch)
              patching file multimedia/gst1-plugins-bad/patches--bk/0011-wayland-fix-display-position-not-correct.patch (renamed from multimedia/gst1-p        lugins-bad/patches/0011-wayland-fix-display-position-not-correct.patch)
              patching file multimedia/gst1-plugins-bad/patches/0001-fix-compile-error.patch (renamed from multimedia/gst1-plugins-bad/patches/0013-fix        -compile-error.patch)
              patching file multimedia/gst1-plugins-bad/patches/0002-introspection.m4-prefix-pkgconfig-paths-with-PKG_CON.patch (renamed from multimedi        a/gst1-plugins-bad/patches/0014-introspection.m4-prefix-pkgconfig-paths-with-PKG_CON.patch)
              patching file multimedia/gst1-plugins-bad/patches/0003-mssdemux-support-playready-decrypt.patch (renamed from multimedia/gst1-plugins-bad        /patches/0016-mssdemux-support-playready-decrypt.patch)
              patching file multimedia/gst1-plugins-bad/patches/0004-avoid-including-sys-poll.h-directly.patch (renamed from multimedia/gst1-plugins-ba        d/patches/0017-avoid-including-sys-poll.h-directly.patch)
              patching file multimedia/gst1-plugins-bad/patches/0005-fix-maybe-uninitialized-warnings-when-compiling-with.patch (renamed from multimedi        a/gst1-plugins-bad/patches/0018-fix-maybe-uninitialized-warnings-when-compiling-with.patch)
              patching file multimedia/gst1-plugins-bad/patches/0012-fix-the-compile-err-when-update-openssl-to-1.1.0i.patch
              patching file multimedia/gst1-plugins-bad/patches/0015-Makefile.am-don-t-hardcode-libtool-name-when-running.patch
              patching file multimedia/gst1-plugins-base/Makefile
              patching file multimedia/gst1-plugins-base/patches/0001-no-translations.patch
              patching file multimedia/gst1-plugins-base/patches/0002-alsa-NOT-let-alsa-select-params-automaticaly-thus-fi.patch
              patching file multimedia/gst1-plugins-base/patches/0002-introspection.m4-prefix-pkgconfig-paths-with-PKG_CON.patch (renamed from multimed        ia/gst1-plugins-base/patches/0004-introspection.m4-prefix-pkgconfig-paths-with-PKG_CON.patch)
              patching file multimedia/gst1-plugins-base/patches/0003-Makefile.am-don-t-hardcode-libtool-name-when-running.patch
              patching file multimedia/gst1-plugins-base/patches/0003-gstreamer-gl.pc.in-don-t-append-GL_CFLAGS-to-CFLAGS.patch (renamed from multimedi        a/gst1-plugins-base/patches/0005-gstreamer-gl.pc.in-don-t-append-GL_CFLAGS-to-CFLAGS.patch)
              patching file multimedia/gst1-plugins-base/patches/0004-Makefile.am-prefix-calls-to-pkg-config-with-PKG_CONF.patch (renamed from multimed        ia/gst1-plugins-base/patches/0006-Makefile.am-prefix-calls-to-pkg-config-with-PKG_CONF.patch)
              patching file multimedia/gst1-plugins-base/patches/0005-riff-add-missing-include-directories-when-calling-in.patch (renamed from multimed        ia/gst1-plugins-base/patches/0007-riff-add-missing-include-directories-when-calling-in.patch)
              patching file multimedia/gst1-plugins-base/patches/0006-ssaparse-enhance-SSA-text-lines-parsing.patch (renamed from multimedia/gst1-plugi        ns-base/patches/0008-ssaparse-enhance-SSA-text-lines-parsing.patch)
              patching file multimedia/gst1-plugins-base/patches/0007-glimagesink-Downrank-to-marginal.patch (renamed from multimedia/gst1-plugins-base        /patches/0010-glimagesink-Downrank-to-marginal.patch)
              patching file multimedia/gst1-plugins-base/patches/0008-glimagesink-wayland-initial-window-position.patch (renamed from multimedia/gst1-p        lugins-base/patches/0011-glimagesink-wayland-initial-window-position.patch)
              patching file multimedia/gst1-plugins-base/patches/0009-get-caps-from-src-pad-when-query-caps.patch (renamed from multimedia/gst1-plugins        -base/patches/0012-get-caps-from-src-pad-when-query-caps.patch)
              patching file multimedia/gst1-plugins-base/patches/0009-rtsp-drop-incorrect-reference-to-gstreamer-sdp-in-Ma.patch
              patching file multimedia/gst1-plugins-base/patches/0010-Add-lvchostif-to-link-when-using-lEGL-on-rpi.patch (renamed from multimedia/gst1-        plugins-base/patches/0013-Add-lvchostif-to-link-when-using-lEGL-on-rpi.patch)
              patching file multimedia/gst1-plugins-base/patches/0011-make-gio_unix_2_0-dependency-configurable.patch (renamed from multimedia/gst1-plu        gins-base/patches/0014-make-gio_unix_2_0-dependency-configurable.patch)
              patching file multimedia/gst1-plugins-good/Makefile
              patching file multimedia/gst1-plugins-good/patches/0001-no-translations.patch
              patching file multimedia/gst1-plugins-good/patches/0002-gstrtpmp4gpay-set-dafault-value-for-MPEG4-without-co.patch
              patching file multimedia/gst1-plugins-good/patches/0003-introspection.m4-prefix-pkgconfig-paths-with-PKG_CON.patch
              patching file multimedia/gst1-plugins-good/patches/0004-add-pause-and-resume-to-mute-camera.patch
              patching file multimedia/gst1-plugins-good/patches/0005-matroskamux-set-final-total-duration.patch
              patching file multimedia/gst1-plugins-good/patches/0006-qtdemux-support-playready-decrypt.patch
              patching file multimedia/gst1-plugins-good/patches/0007-avoid-including-sys-poll.h-directly.patch
              patching file multimedia/gst1-plugins-good/patches/0008-ensure-valid-sentinal-for-gst_structure_get.patch
              patching file multimedia/gst1-plugins-ugly/Makefile
              patching file multimedia/gstreamer1/Makefile
              patching file multimedia/gstreamer1/patches/0001-no-translations.patch
              这个算patch成功吗?
              • cube_work
                发现patch之后,与压缩包有很多不同,看来直接文件夹替换算了?
                H 2 条回复 最后回复 回复 引用 分享 0
                  houxiaoni LV 5 @cube_work 最后由 编辑
                  @cube_work patch是成功的
                    @cube_work 上面的patch只有一个是修改了这个目录里面的头文件,其他的patch并不作用在这个目录,而是package下面的multimedia目录,还有dl目录。
                      @cube_work 可以直接替换,没有问题
                      X 1 条回复 最后回复 回复 引用 分享 0
                      • X
                        xiaochusheng LV 5 @houxiaoni 最后由 编辑
