    求救:Tina T113-s3(MQ-R) DVP摄像头(OV5640)无法生成/dev/video0设备
    5
    5087
      liefyuan LV 3 最后由 编辑
      改了默认串口为uart1,因为uart0占用了csi接口的引脚,显示的错误基本上都没有了,现在就是无法识别到ov5640,OV5640摄像头确认是好的,在正点原子板子上试过的。
      板子是mangopi的MQ-R T113-s3。
      触摸屏没有问题,都是挂载在twi2上面的:
      [    3.449598] vin_csi 5801000.csi: Adding to iommu group 0
      [    3.458434] sunxi-vin-core 5809000.vinc: Adding to iommu group 0
      [    3.466527] [VIN_WARN]get csi isp clk fail
      [    3.471127] [VIN_WARN]get csi isp src clk fail
      [    3.476151] [VIN_WARN]get csi mipi clk fail
      [    3.480842] [VIN_WARN]get csi mipi src clk fail
      [    3.485956] [VIN_WARN]get csi isp clk fail
      [    3.490560] [VIN_WARN]Get isp reset control fail
      [    3.496426] ov5640 2-003c: endpoint node not found
      [    3.501868] ov5640: probe of 2-003c failed with error -22
      [    3.508118] [VIN_ERR]registering ov5640, No such device!
      [    3.514136] [VIN]vinc1 is null
      上电打印信息:
      [    2.390009] [VIN_WARN]sensor_helper_probe: cannot get sensor0_cameravdd supply, setting it to NULL!
      [    2.400196] [VIN_WARN]sensor_helper_probe: cannot get sensor0_iovdd supply, setting it to NULL!
      [    2.409990] [VIN_WARN]sensor_helper_probe: cannot get sensor0_avdd supply, setting it to NULL!
      [    2.419666] [VIN_WARN]sensor_helper_probe: cannot get sensor0_dvdd supply, setting it to NULL!
      [    3.124069] sunxi-i2c sunxi-i2c2: sunxi-i2c2 supply twi not found, using dummy regulator
      [    3.133772] sunxi-i2c sunxi-i2c2: probe success
      [    3.140117] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
      [    3.152419] sunxi-audio-card 203605c.soundspdif: use dummy codec for simple card.
      [    3.160969] debugfs: Directory '2036000.spdif' with parent 'sndspdif' already present!
      [    3.170318] sunxi-audio-card 203605c.soundspdif: snd-soc-dummy-dai <-> 2036000.spdif mapping ok
      [    3.181085] get ehci0-controller wakeup-source is fail.
      [    3.187098] sunxi ehci0-controller don't init wakeup source
      [    3.193415] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0c6e1e0, 0x:c88c9000, irq_no:37
      [    3.205429] [sunxi-ehci0]: Not init ehci0
      [    3.210240] get ohci0-controller wakeup-source is fail.
      [    3.216239] sunxi ohci0-controller don't init wakeup source
      [    3.222513] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0c6e470
      [    3.232184] [sunxi-ohci0]: Not init ohci0
      [    3.238012] get usb_detect_mode is fail, -22
      [    3.242854] get det_vbus is fail, -84
      [    3.246959] get id is fail, -84
      [    3.251382] get ctp_power is fail, -22
      [    3.255654] get ctp_power_ldo_vol is fail, -22
      [    3.260649] sunxi_ctp_startup: ctp_power_io is invalid.
      [    3.266557] get ctp_gesture_wakeup fail, no gesture wakeup
      [    3.272740] gt9xxnew_ts 2-0014: 2-0014 supply ctp not found, using dummy regulator
      [    3.461823] input: gt9xxnew_ts as /devices/virtual/input/input1
      [    3.469793] vin_csi 5801000.csi: Adding to iommu group 0
      [    3.478700] sunxi-vin-core 5809000.vinc: Adding to iommu group 0
      [    3.486738] [VIN_WARN]get csi isp clk fail
      [    3.491338] [VIN_WARN]get csi isp src clk fail
      [    3.496359] [VIN_WARN]get csi mipi clk fail
      [    3.501071] [VIN_WARN]get csi mipi src clk fail
      [    3.506226] [VIN_WARN]get csi isp clk fail
      [    3.510836] [VIN_WARN]Get isp reset control fail
      [    3.517036] ov5640 2-003c: endpoint node not found
      [    3.522495] ov5640: probe of 2-003c failed with error -22
      [    3.528759] [VIN_ERR]registering ov5640, No such device!
      [    3.534777] [VIN]vinc1 is null
      这是vin相关的:
      &twi2 {
      	clock-frequency = <400000>;
      	pinctrl-0 = <&twi2_pins_a>;
      	pinctrl-1 = <&twi2_pins_b>;
      	dmas = <&dma 45>, <&dma 45>;
      	dma-names = "tx", "rx";
      	ctp@14 {
      		device_type = "ctp";
      		reg = <0x14>;
      		ctp_name = "gt9xxnew_ts";
      		ctp_twi_id = <0x2>;
      		ctp_twi_addr = <0x14>;
      		ctp_screen_max_x = <0x320>;
      		ctp_screen_max_y = <0x1e0>;
      		ctp_revert_x_flag = <0x0>;
      		ctp_revert_y_flag = <0x0>;
      		ctp_int_port = <&pio PB 3 GPIO_ACTIVE_HIGH>;
      		ctp_wakeup = <&pio PB 2 GPIO_ACTIVE_HIGH>;
      		/*ctp-supply = <&reg_aldo2>;*/
      		/*ctp_power_ldo = <&reg_aldo2>;*/
      		/*ctp_power_ldo_vol = <3300>;*/
      &vind0 {
      	csi_top = <378000000>;
      	csi_isp = <327000000>;
      	status = "okay"; /* enable twi and ver1 spi-nand max freq 30M */
      	actuator0: actuator@5809450 {
      		device_type = "actuator0";
      		actuator0_slave = <0x18>;
      		actuator0_af_pwdn = <>;
      	flash0: flash@5809460 {
      		device_type = "flash0";
      		flash0_type = <2>;
      		flash0_en = <>;
      		flash0_mode = <>;
      		flash0_flvdd = "";
      		flash0_flvdd_vol = <>;
      		device_id = <0>;
      	sensor0: sensor@5809470 {
      		device_type = "sensor0";
      		sensor0_mname = "ov5640";
      		sensor0_twi_cci_id = <2>;
      		sensor0_twi_addr = <0x78>;
      		sensor0_mclk_id = <0>;
      		sensor0_pos = "rear";
      		sensor0_isp_used = <0>;
      		sensor0_fmt = <0>;
      		sensor0_stby_mode = <0>;
      		sensor0_vflip = <>;
      		sensor0_hflip = <>;
      		sensor0_iovdd-supply = <>;
      		sensor0_iovdd_vol = <2800000>;
      		sensor0_avdd-supply = <0>;
      		sensor0_avdd_vol = <2800000>;
      		sensor0_dvdd-supply = <>;
      		sensor0_dvdd_vol = <1200000>;
      		sensor0_power_en = <>;
      		sensor0_reset = <&pio PB 5 GPIO_ACTIVE_LOW>;
              sensor0_pwdn = <&pio PB 4 GPIO_ACTIVE_LOW>;
      		flash_handle = <&flash0>;
      		act_handle = <&actuator0>;
      		sensor0_sm_vs = <>;
      		device_id = <0>;
      		status  = "okay";
      	sensor1:sensor@5809480 {
      		device_type = "sensor1";
      		sensor1_mname = "ov5647";
      		sensor1_twi_cci_id = <3>;
      		sensor1_twi_addr = <0x6c>;
      		sensor1_mclk_id = <1>;
      		sensor1_pos = "front";
      		sensor1_isp_used = <0>;
      		sensor1_fmt = <0>;
      		sensor1_stby_mode = <0>;
      		sensor1_vflip = <0>;
      		sensor1_hflip = <0>;
      		sensor1_iovdd-supply = <>;
      		sensor1_iovdd_vol = <>;
      		sensor1_avdd-supply = <>;
      		sensor1_avdd_vol = <>;
      		sensor1_dvdd-supply = <>;
      		sensor1_dvdd_vol = <>;
      		sensor1_power_en = <>;
      		status	= "disabled";
      	vinc0:vinc@5809000 {
                      device_type = "vinc0";
      		vinc0_csi_sel = <0>;
      		vinc0_mipi_sel = <0xff>;
      		vinc0_isp_sel = <0>;
      		vinc0_isp_tx_ch = <0>;
      		vinc0_tdm_rx_sel = <0xff>;
      		vinc0_rear_sensor_sel = <0>;
      		vinc0_front_sensor_sel = <1>;
      		vinc0_sensor_list = <0>;
      	vinc1:vinc@5809200 {
      		vinc1_csi_sel = <0>;
      		vinc1_mipi_sel = <0xff>;
      		vinc1_isp_sel = <0>;
      		vinc1_isp_tx_ch = <1>;
      		vinc1_tdm_rx_sel = <0xff>;
      		vinc1_rear_sensor_sel = <0>;
      		vinc1_front_sensor_sel = <1>;
      		vinc1_sensor_list = <0>;
      触摸已经调好了,没有问题。
      这是完整的board.dts
      /dts-v1/;
      /memreserve/ 0x41B00000 0x00100000;
      /* DSP used 1MB */
      /*/memreserve/ 0x42000000 0x00100000;*/
      #include "sun8iw20p1.dtsi"
      	model = "sun8iw20";
      	reg_vdd_cpu: vdd-cpu {
      		pwms = <&pwm 3 5000 0>;
      		regulator-name = "vdd_cpu";
      		regulator-ramp-delay = <25>;
      		regulator-always-on;
      		regulator-boot-on;
      	reg_usb1_vbus: usb1-vbus {
      		regulator-name = "usb1-vbus";
      		gpio = <&pio PB 10 GPIO_ACTIVE_HIGH>;
      		enable-active-high;
      &cpu0 {
      	cpu-supply = <&reg_vdd_cpu>;
      &pio {
      	sdc0_pins_a: sdc0@0 {
      				 "PF3", "PF4", "PF5";
      		allwinner,function = "sdc0";
      		allwinner,muxsel = <2>;
      		allwinner,drive = <3>;
      		allwinner,pull = <1>;
      		function = "sdc0";
      		drive-strength = <30>;
      		bias-pull-up;
      		power-source = <3300>;
      	sdc0_pins_b: sdc0@1 {
      		function = "sdc0";
      		bias-pull-up;
      		power-source = <1800>;
      	sdc0_pins_c: sdc0@2 {
      		function = "gpio_in";
      	/* TODO: add jtag pin */
      	sdc0_pins_d: sdc0@3 {
      		pins = "PF2", "PF4";
      		function = "uart0";
      		drive-strength = <10>;
      		bias-pull-up;
      	sdc0_pins_e: sdc0@4 {
      		pins = "PF0", "PF1", "PF3",
      			"PF5";
      		function = "jtag";
      		bias-pull-up;
      	sdc1_pins_a: sdc1@0 {
      		pins = "PG0", "PG1", "PG2",
      		       "PG3", "PG4", "PG5";
      		function = "sdc1";
      		bias-pull-up;
      	sdc1_pins_b: sdc1@1 {
      	sdc2_pins_a: sdc2@0 {
      				 "PC5", "PC6", "PC7";
      		allwinner,function = "sdc2";
      		allwinner,muxsel = <3>;
      		function = "sdc2";
      		bias-pull-up;
      	sdc2_pins_b: sdc2@1 {
      	wlan_pins_a:wlan@0 {
      		pins = "PG11";
      		function = "clk_fanout1";
              // uart0_pins_a: uart0_pins@0 {  /* For mangopi board */
              //         pins = "PE2", "PE3";
              //         function = "uart0";
              //         drive-strength = <10>;
              //         bias-pull-up;
              // uart0_pins_b: uart0_pins@1 {  /* For mangopi board */
              //         function = "gpio_in";
      	uart1_pins_a: uart1_pins@0 {  // For EVB1 board
      		pins = "PG6", "PG7";
      		function = "uart1";
      		bias-pull-up;
      	uart1_pins_b: uart1_pins {  // For EVB1 board
      		pins = "PC0", "PC1";
      		function = "uart2";
      		bias-pull-up;
      		pins = "PD10", "PD11";
      		function = "uart3";
      		muxsel = <5>;
      		bias-pull-up;
      	twi0_pins_a: twi0@0 {
      		function = "twi0";
      	twi0_pins_b: twi0@1 {
      	twi1_pins_a: twi1@0 {
      		pins = "PB4", "PB5";
      		function = "twi1";
      	twi1_pins_b: twi1@1 {
      	twi2_pins_a: twi2@0 {
      			pins = "PE12", "PE13";
      			function = "twi2";
      	twi2_pins_b: twi2@1 {
      	twi3_pins_a: twi3@0 {
      		pins = "PE6", "PE7";
      		function = "twi3";
      	twi3_pins_b: twi3@1 {
      	gmac_pins_a: gmac@0 {
      		       "PE4", "PE5", "PE6", "PE7",
      		       "PE8", "PE9", "PE10", "PE11",
      		       "PE12", "PE13", "PE14", "PE15";
      		function = "gmac0";
      	gmac_pins_b: gmac@1 {
      	dmic_pins_a: dmic@0 {
      		function = "dmic";
      		drive-strength = <20>;
      		bias-disable;
      	dmic_pins_b: dmic@1 {
      		function = "io_disabled";
      		bias-disable;
      	daudio0_pins_a: daudio0@0 {
      		function = "i2s0";
      		bias-disable;
      		bias-disable;
      	daudio1_pins_a: daudio1@0 {
      		function = "i2s1";
      		bias-disable;
      	daudio1_pins_b: daudio1_sleep@0 {
      		bias-disable;
      	daudio2_pins_a: daudio2@0 {
      		pins = "PF6", "PF3", "PF5";
      		function = "i2s2";
      		bias-disable;
      	daudio2_pins_b: daudio2@1 {
      		/* I2S_PIN: DOUT0 */
      		pins = "PF1";
      		function = "i2s2_dout";
      		bias-disable;
      	daudio2_pins_c: daudio2@2 {
      		/* I2S_PIN: DIN0 */
      		pins = "PF0";
      		function = "i2s2_din";
      		bias-disable;
      		pins = "PF6", "PF3", "PF5", "PF1", "PF0";
      		bias-disable;
      	spdif_pins_a: spdif@0 {
      		/* SPDIF_PIN: SPDIF_OUT */
      		pins = "PG18";
      		function = "spdif";
      		bias-disable;
      	spdif_pins_b: spdif_sleep@0 {
      		pins = "PG18";
      		bias-disable;
      	spi0_pins_a: spi0@0 {
      		function = "spi0";
      		muxsel = <2>;
      	spi0_pins_b: spi0@1 {
      		pins = "PC3", "PC7", "PC6";
      		function = "spi0";
      		muxsel = <2>;
      	spi0_pins_c: spi0@2 {
      		muxsel = <0>;
      	spi1_pins_a: spi1@0 {
      		function = "spi1";
      	spi1_pins_b: spi1@1 {
      		function = "spi1";
      	spi1_pins_c: spi1@2 {
      	ledc_pins_a: ledc@0 {
      		pins = "PC0";
      		function = "ledc";
      	ledc_pins_b: ledc@1 {
      		pins = "PC0";
      	pwm0_pin_a: pwm0@0 {
      		pins = "PD16";
      		function = "pwm0";
      		bias-pull-up;
      	pwm0_pin_b: pwm0@1 {
      		pins = "PD16";
      		bias-disable;
      	pwm2_pin_a: pwm2@0 {
      		pins = "PD18";
      		function = "pwm2";
      		bias-pull-up;
      	pwm2_pin_b: pwm2@1 {
      		pins = "PD18";
      		function = "gpio_out";
      	pwm7_pin_a: pwm7@0 {
      		pins = "PD22";
      		function = "pwm7";
      		bias-pull-up;
      	pwm7_pin_b: pwm7@1 {
      		pins = "PD22";
      	s_cir0_pins_a: s_cir@0 {
      		pins = "PB7";
      		function = "ir";
      		bias-pull-up;
      	s_cir0_pins_b: s_cir@1 {
      		pins = "PB7";
      	ir1_pins_a: ir1@0 {
      		pins = "PB0";
      		function = "ir";
      		bias-pull-up;
      	ir1_pins_b: ir1@1 {
      		pins = "PB0";
      // &uart0 {
      // 	pinctrl-names = "default", "sleep";
      // 	pinctrl-0 = <&uart0_pins_a>;
      // 	pinctrl-1 = <&uart0_pins_b>;
      // 	status = "okay";
      &uart1 {
      	pinctrl-0 = <&uart1_pins_a>;
      	pinctrl-1 = <&uart1_pins_b>;
      &uart2 {
      	pinctrl-0 = <&uart2_pins_a>;
      	pinctrl-1 = <&uart2_pins_b>;
      &uart3 {
      	pinctrl-0 = <&uart3_pins_a>;
      	pinctrl-1 = <&uart3_pins_a>;
      &soc {
      	card0_boot_para@2 {
      		reg = <0x0 0x2 0x0 0x0>;
      		card_ctrl = <0x0>;
      		card_high_speed = <0x1>;
      		card_line = <0x4>;
      		pinctrl-0 = <&sdc0_pins_a>;
      	card2_boot_para@3 {
      		reg = <0x0 0x3 0x0 0x0>;
      		card_ctrl = <0x2>;
      		card_line = <0x4>;
      		pinctrl-0 = <&sdc2_pins_a>;
      		/*sdc_ex_dly_used = <0x2>;*/
      		sdc_io_1v8 = <0x1>;
      		/*sdc_type = "tm4";*/
      		sdc_ex_dly_used = <2>;
      		/*sdc_tm4_win_th = <8>;*/
      	rfkill: rfkill@0 {
      		chip_en;
      		power_en;
      		pinctrl-0 = <&wlan_pins_a>;
      		pinctrl-names = "default";
      		status        = "okay";
      		wlan: wlan@0 {
      			clock-names = "32k-fanout1";
      			wlan_busnum    = <0x1>;
      			/*interrupt-parent = <&pio>;
      			wakeup-source;
      		bt: bt@0 {
      			/*bt_power_num = <0x01>;*/
      			/*bt_io_vol = <3300000>;*/
      			/*bt_power_vol = <330000>;*/
      			bt_rst_n      = <&pio PG 15 GPIO_ACTIVE_LOW>;
      	btlpm: btlpm@0 {
      		uart_index  = <0x1>;
      		bt_wake     = <&pio PG 14 GPIO_ACTIVE_HIGH>;
      		bt_hostwake = <&pio PG 13 GPIO_ACTIVE_HIGH>;
      	addr_mgt: addr_mgt@0 {
      		type_addr_wifi = <0x0>;
      		type_addr_bt   = <0x0>;
      		type_addr_eth  = <0x0>;
      		status         = "okay";
      &sdc2 {
      	non-removable;
      	bus-width = <4>;
      	mmc-ddr-1_8v;
      	mmc-hs200-1_8v;
      	no-sdio;
      	no-sd;
      	ctl-spec-caps = <0x308>;
      	cap-mmc-highspeed;
      	sunxi-power-save-mode;
      	sunxi-dis-signal-vol-sw;
      	mmc-bootpart-noacc;
      	max-frequency = <150000000>;
      	/*emmc io vol 3.3v*/
      	/*emmc io vol 1.8v*/
      &sdc0 {
      	bus-width = <4>;
      	cd-gpios = <&pio PF 6 (GPIO_ACTIVE_LOW | GPIO_PULL_UP)>; /* mangopi */
      	/*non-removable;*/
      	/*broken-cd;*/
      	/*cd-inverted;*/
      	/*data3-detect;*/
      	/*cd-used-24M;*/
      	cap-sd-highspeed;
      	/*sd-uhs-sdr50;*/
      	/*sd-uhs-ddr50;*/
      	/*sd-uhs-sdr104;*/
      	no-sdio;
      	no-mmc;
      	/*sunxi-dis-signal-vol-sw;*/
      	ctl-spec-caps = <0x8>;
      &sdc1 {
      	bus-width = <4>;
      	no-mmc;
      	no-sd;
      	cap-sd-highspeed;
      	/*sd-uhs-sdr12*/
      	/*sd-uhs-sdr25;*/
      	/*sd-uhs-sdr50;*/
      	/*sd-uhs-ddr50;*/
      	/*sd-uhs-sdr104;*/
      	/*sunxi-power-save-mode;*/
      	cap-sdio-irq;
      	keep-power-in-suspend;
      	ignore-pm-notify;
      tvd configuration
                             mode,mean enable)
      &tvd {
      	tvd_sw          = <1>;
      	tvd_interface   = <0>;
      	tvd_format      = <0>;
      	tvd_system      = <1>;
      	tvd_row         = <1>;
      	tvd_column      = <1>;
      	tvd_channel0_en = <1>;
      	tvd_channel1_en = <0>;
      	tvd_channel2_en = <0>;
      	tvd_channel3_en = <0>;
      	/*tvd_power0      = "dc1sw"*/
      	/*tvd_power1      = "eldo3"*/
      &tvd0 {
      /* Audio Driver modules */
      &sunxi_rpaf_dsp0 {
      &codec {
      	mic1gain 	= <0x1F>;
      	mic2gain 	= <0x1F>;
      	mic3gain 	= <0x1F>;
      	adcdrc_cfg 	= <0x0>;
      	adchpf_cfg 	= <0x1>;
      	dacdrc_cfg 	= <0x0>;
      	dachpf_cfg 	= <0x0>;
      	/* Volume about */
      	digital_vol 	= <0x00>;
      	lineout_vol 	= <0x1a>;
      	headphonegain	= <0x03>;
      	/* Pa enabled about */
      	pa_level 	= <0x01>;
      	pa_pwr_level 	= <0x01>;
      	pa_msleep_time 	= <0x78>;
      	/* gpio-spk	= <&pio PF 2 GPIO_ACTIVE_HIGH>;*/
      	/* CMA config about */
      	playback_cma	= <128>;
      	capture_cma	= <256>;
      	/* regulator about */
      &sndcodec {
      	hp_detect_case	= <0x00>;
      	jack_enable	= <0x01>;
      &dummy_cpudai {
      &dmic {
      &dmic_codec {
      &sounddmic {
       * tdm_config		0 --> pcm
       *			1 --> i2s
       * mclk_div		0 --> not output
       * pinctrl_used		0 --> I2S/PCM use for internal
      &daudio0 {
      	mclk_div 	= <0x01>;
      	frametype 	= <0x00>;
      	tdm_config 	= <0x01>;
      	sign_extend 	= <0x00>;
      	msb_lsb_first 	= <0x00>;
      	pcm_lrck_period = <0x80>;
      	slot_width_select = <0x20>;
      	pinctrl_used	= <0x0>;
      &sounddaudio0 {
      		/* sound-dai = <&ac108>; */
      &daudio1 {
      	mclk_div 	= <0x01>;
      	frametype 	= <0x00>;
      	pinctrl-0       = <&daudio1_pins_a>;
      	pinctrl-1       = <&daudio1_pins_b>;
      &sounddaudio1 {
      &daudio2 {
      	mclk_div 	= <0x01>;
      	frametype 	= <0x00>;
      	tx_data_mode 	= <0x00>;
      	rx_data_mode 	= <0x00>;
      	asrc_function_en  = <0x00>;
      	pinctrl_used	= <0x1>;
      	daudio_type	= <0x0>;
      &sounddaudio2 {
      	status = "disabled"; /* mangopi */
      &spdif {
      &soundspdif {
      &usbc0 {
      	device_type = "usbc0";
      	usb_port_type = <0x0>;
      	usb_detect_type = <0x0>;
      /*	usb_detect_mode = <0>;
      	usb_id_gpio = <&pio PB 8 GPIO_ACTIVE_HIGH>;
      	enable-active-high;
      	usb_det_vbus_gpio = <&pio PB 9 GPIO_ACTIVE_HIGH>; */
      	usb_wakeup_suspend = <0>;
      	usb_serial_unique = <0>;
      	rndis_wceis = <1>;
      &ehci0 {
      &ohci0 {
      &usbc1 {
      	device_type = "usbc1";
          usb_port_type = <0x01>;
          usb_detect_type = <0x1>;
      	usb_regulator_io = "nocare";
      &ehci1 {
      &ohci1 {
      &twi0 {
      	pinctrl-0 = <&twi0_pins_a>;
      	pinctrl-1 = <&twi0_pins_b>;
      	eeprom@50 {
      		compatible = "atmel,24c16";
      		reg = <0x50>;
      &twi1 {
      	pinctrl-0 = <&twi1_pins_a>;
      	pinctrl-1 = <&twi1_pins_b>;
      &twi2 {
      	/* pcf8574-usage:
      	 * pin set:
      	 * interrupt set:
      	/*pcf8574: gpio@38 {
      		compatible = "nxp,pcf8574";
      		reg = <0x38>;
      		gpio_base = <2020>;
      		gpio-controller;
      		#gpio-cells = <2>;
      		interrupt-controller;
      		#interrupt-cells = <2>;
      	ctp@14 {
      		reg = <0x14>;
      		ctp_twi_id = <0x2>;
      	// ov5640@78 {
      	// 	compatible = "ovti,ov2640";
      	// 	reg = <0x78>;
      	// 	pinctrl-names = "default";
      	// 	pinctrl-0 = <>
      &twi3 {
      	pinctrl-0 = <&twi3_pins_a>;
      	pinctrl-1 = <&twi3_pins_b>;
      &gmac0 {
      	phy-mode = "rgmii";
      	use_ephy25m = <1>;
      	pinctrl-0 = <&gmac_pins_a>;
      	pinctrl-1 = <&gmac_pins_b>;
      	phy-rst = <&pio PE 16 GPIO_ACTIVE_HIGH>;
      	tx-delay = <3>; //2~4
      	rx-delay = <0>;
      &spi0 {
      	pinctrl-1 = <&spi0_pins_c>;
      	spi_slave_mode = <0>;
      	spi0_cs_number = <1>;
          spi0_cs_bitmap = <1>;
      	spi-nand@0 {
      		compatible = "spi-nand";
      		spi-max-frequency=<100000000>;
      		reg = <0x0>;
      		spi-rx-bus-width=<0x01>;
      		spi-tx-bus-width=<0x01>;
      		status="okay";
      	spi-nor@0 {
      		compatible = "jedec,spi-nor";
      		spi-max-frequency=<30000000>;
      		reg = <0x0>;
      		status="disabled";
      &spi1 {
      	pinctrl-1 = <&spi1_pins_c>;
      	spi_board1@0 {
      		device_type = "spi_board1";
      		compatible = "rohm,dh2228fv";
      		reg = <0x0>;
      		spi-rx-bus-width = <0x4>;
      		spi-tx-bus-width = <0x4>;
      &ledc {
      	pinctrl-0 = <&ledc_pins_a>;
      	pinctrl-1 = <&ledc_pins_b>;
      	led_count = <12>;
      	output_mode = "GRB";
      	reset_ns = <84>;
      	t1h_ns = <800>;
      	t1l_ns = <320>;
      	t0h_ns = <300>;
      	t0l_ns = <800>;
      	wait_time0_ns = <84>;
      	wait_time1_ns = <84>;
      	wait_data_time_ns = <600000>;
      &keyboard0 {
      	key0 = <210 0x160>;
      	wakeup-source;
      disp init configuration
      screenx_output_type   (0:none; 1:lcd; 2:tv; 5:vdpo)
      set fbX_height to lcd_x)
      				   (0:none; 1:lcd; 2:tv;)
                         in display.
      &disp {
      	disp_rotation_used		 = <1>;
      	degree0					 = <0>;
      	/*VCC-LCD*/
      	/*VCC-DSI*/
      	/*VCC-PD*/
      ;lcd0 configuration
      ;Pin setting for gpio:
      ;fsync setting, pulse to csi
      &lcd0 {
      	lcd_used            = <1>;            // 启用lcd
      	lcd_driver_name     = "default_lcd";  // 使用 default_lcd 驱动
      	lcd_backlight       = <50>;
      	lcd_if              = <0>;            // 0:rgb 4:dsi
      	// Part 1
      	lcd_x               = <800>;          // 宽度
      	lcd_y               = <480>;		  // 高度
      	lcd_width           = <108>;          // 屏幕物理宽度,单位 mm
      	lcd_height          = <65>;           // 屏幕物理高度,单位 mm
      	// Part 2
      	lcd_pwm_used        = <1>;            // 启用背光 PWM
      	lcd_pwm_ch          = <7>;            // 使用 PWM 通道 7
      	lcd_pwm_freq        = <5000>;         // PWM 频率,单位 Hz
      	lcd_pwm_pol         = <0>;            // 背光 PWM 的极性
      	lcd_pwm_max_limit   = <255>;          // 背光 PWM 的最大值(<=255)
      	// Part 3
      	lcd_dclk_freq       = <22>;           // 屏幕时钟,单位 MHz
      	lcd_ht              = <928>;          // hsync total cycle(pixel)
      	lcd_hbp             = <88>;           // hsync back porch(pixel) + hsync plus width(pixel);
      	lcd_hspw            = <48>;           // hsync plus width(pixel)
      	lcd_vt              = <525>;          // vsync total cycle(line)
      	lcd_vbp             = <32>;           // vsync back porch(line) + vysnc plus width(line)
      	lcd_vspw            = <1>;            // vsync plus width(pixel)
      	// Part 4
      	lcd_lvds_if         = <0>;
      	lcd_lvds_colordepth = <1>;
      	lcd_lvds_mode       = <0>;
      	lcd_frm             = <0>;            // 0:关闭; 1:启用rgb666抖动; 2:启用rgb656抖动
      	lcd_gamma_en        = <0>;
      	lcd_bright_curve_en = <0>;
      	lcd_cmap_en         = <0>;
      	deu_mode            = <0>;
      	lcdgamma4iep        = <22>;
      	smart_color         = <90>;
      	// Part 5
      	pinctrl-0 = <&rgb18_pins_a>;
      	pinctrl-1 = <&rgb18_pins_b>;
      &pwm0 {
      	pinctrl-0 = <&pwm0_pin_a>;
      	pinctrl-1 = <&pwm0_pin_b>;
      &pwm2 {
      	pinctrl-0 = <&pwm2_pin_a>;
      	pinctrl-1 = <&pwm2_pin_b>;
      &pwm7 {
      	pinctrl-0 = <&pwm7_pin_a>;
      	pinctrl-1 = <&pwm7_pin_b>;
      &rtp {
      	allwinner,ts-attached;
      &tpadc {
      	key_cnt = <5>;
      	key1 = <420 115>;
      	key2 = <870 114>;
      	key3 = <1290 119>;
      	key4 = <1630 373>;
      	key5 = <1950 28>;
      &gpadc {
      	channel_num = <1>;
      	channel_select = <0x01>;
      	channel_data_select = <0>;
      	channel_cld_select = <0x01>;
      	channel_chd_select = <0>;
      	channel0_compare_lowdata = <1600000>;
      	key_cnt = <5>;
      	key0_vol = <210>;
      	key0_val = <0x19c>;
      	key1_vol = <410>;
      	key1_val = <0x197>;
      	key2_vol = <590>;
      	key2_val = <158>;
      	key3_vol = <750>;
      	key3_val = <28>;
      	key4_vol = <880>;
      	key4_val = <28>;
      	wakeup-source;
      &s_cir0 {
      	pinctrl-0 = <&s_cir0_pins_a>;
      	pinctrl-1 = <&s_cir0_pins_b>;
      	ir_protocol_used		= <0>;
      	ir_addr_code0			= <0x0>;
      &ir1 {
      	pinctrl-0 = <&ir1_pins_a>;
      	pinctrl-1 = <&ir1_pins_b>;
      &vind0 {
      		flash0_type = <2>;
      		flash0_en = <>;
      		flash0_mode = <>;
      		flash0_flvdd = "";
      		device_id = <0>;
      		sensor0_fmt = <0>;
      		sensor0_vflip = <>;
      		sensor0_hflip = <>;
      		sensor0_sm_vs = <>;
      		device_id = <0>;
      		status  = "okay";
      		sensor1_fmt = <0>;
      这是内核配置:
      # Multimedia core support
      CONFIG_MEDIA_CAMERA_SUPPORT=y
      # CONFIG_MEDIA_ANALOG_TV_SUPPORT is not set
      CONFIG_MEDIA_DIGITAL_TV_SUPPORT=y
      # CONFIG_MEDIA_RADIO_SUPPORT is not set
      # CONFIG_MEDIA_SDR_SUPPORT is not set
      # CONFIG_MEDIA_CEC_SUPPORT is not set
      CONFIG_MEDIA_CONTROLLER=y
      CONFIG_MEDIA_CONTROLLER_DVB=y
      CONFIG_VIDEO_DEV=y
      CONFIG_VIDEO_V4L2_SUBDEV_API=y
      CONFIG_VIDEO_V4L2=y
      CONFIG_VIDEO_V4L2_I2C=y
      CONFIG_VIDEO_ADV_DEBUG=y
      # CONFIG_VIDEO_FIXED_MINOR_RANGES is not set
      CONFIG_V4L2_MEM2MEM_DEV=y
      CONFIG_V4L2_FWNODE=y
      CONFIG_DVB_CORE=y
      # CONFIG_DVB_MMAP is not set
      CONFIG_DVB_NET=y
      CONFIG_DVB_MAX_ADAPTERS=16
      # CONFIG_DVB_DYNAMIC_MINORS is not set
      # CONFIG_DVB_DEMUX_SECTION_LOSS_LOG is not set
      # CONFIG_DVB_ULE_DEBUG is not set
      # Webcam, TV (analog/digital) USB devices
      # CONFIG_VIDEO_EM28XX is not set
      CONFIG_V4L_PLATFORM_DRIVERS=y
      # CONFIG_VIDEO_CADENCE is not set
      # CONFIG_VIDEO_ASPEED is not set
      CONFIG_VIDEO_MUX=y
      # CONFIG_VIDEO_XILINX is not set
      # CONFIG_VIDEO_SUN4I_CSI is not set
      # CONFIG_VIDEO_SUN6I_CSI is not set
      CONFIG_VIDEO_SUNXI_TVD=y
      CONFIG_SUNXI_PLATFORM_DRIVERS=y
      CONFIG_VIDEO_SUNXI_VIN=y
      CONFIG_CSI_VIN=y
      CONFIG_ENABLE_SENSOR_FLIP_OPTION=y
      CONFIG_CSI_CCI=y
      # CONFIG_CCI is not set
      CONFIG_CCI_TO_TWI=y
      CONFIG_FLASH=y
      # CONFIG_ACTUATOR is not set
      # CONFIG_SENSOR_LIST is not set
      CONFIG_BUF_AUTO_UPDATE=y
      CONFIG_VIN_LOG=y
      # CONFIG_PIPELINE_RESET is not set
      # CONFIG_MULTI_FRAME is not set
      # CONFIG_SUPPORT_ISP_TDM is not set
      # CONFIG_DISPPLAY_SYNC is not set
      CONFIG_VIN_IOMMU=y
      # CONFIG_D3D is not set
      CONFIG_WDR=y
      CONFIG_WDR_COMPRESS_EN=y
      CONFIG_SAME_I2C=y
      # CONFIG_SENSOR_POWER is not set
      CONFIG_V4L_MEM2MEM_DRIVERS=y
      CONFIG_VIDEO_MEM2MEM_DEINTERLACE=y
      CONFIG_VIDEO_SH_VEU=y
      # CONFIG_V4L_TEST_DRIVERS is not set
      # CONFIG_DVB_PLATFORM_DRIVERS is not set
      # Supported MMC/SDIO adapters
      # CONFIG_SMS_SDIO_DRV is not set
      # CONFIG_CYPRESS_FIRMWARE is not set
      CONFIG_VIDEOBUF2_CORE=y
      CONFIG_VIDEOBUF2_V4L2=y
      CONFIG_VIDEOBUF2_MEMOPS=y
      CONFIG_VIDEOBUF2_DMA_CONTIG=y
      CONFIG_VIDEOBUF2_VMALLOC=y
      • Q
        qqqlb LV 7 最后由 编辑
        问个题外的,楼主你的触摸屏的延长线哪里买的
          chengwei_peng LV 6 @liefyuan 最后由 编辑
          @liefyuan 你的ov5640的驱动都还没有正常加载吧?同时发现你dts中的sensor配置乱七八糟的,官方发布的SDK只需要修改sensor name和I2C配置、供电就可以了。
            修改了一下board.dts文件中摄像头设备树:
            &vind0 {
            		sensor0_fmt = <0>;
            		sensor0_vflip = <0>;
            		sensor0_hflip = <0>;
            		sensor0_iovdd_vol = <>;
            		sensor0_avdd-supply = <>;
            		sensor0_avdd_vol = <>;
            		sensor0_dvdd_vol = <>;
            		sensor0_sm_vs = <>;
            		device_id = <0>;
            		status  = "okay";
            	vinc0: vinc@5809000 {
            		interrupts = <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>;
            		vinc0_front_sensor_sel = <0>;
            		device_id = <0>;
            		iommus = <&mmu_aw 1 1>;
            还是识别不出来:
            [    3.282172] get ctp_gesture_wakeup fail, no gesture wakeup
            [    3.288343] gt9xxnew_ts 2-0014: 2-0014 supply ctp not found, using dummy regulator
            [    3.481837] input: gt9xxnew_ts as /devices/virtual/input/input1
            [    3.489803] vin_csi 5801000.csi: Adding to iommu group 0
            [    3.496961] sunxi-vin-core 5809000.vinc: Adding to iommu group 0
            [    3.505032] [VIN_WARN]get csi isp clk fail
            [    3.509630] [VIN_WARN]get csi isp src clk fail
            [    3.514654] [VIN_WARN]get csi mipi clk fail
            [    3.519368] [VIN_WARN]get csi mipi src clk fail
            [    3.524528] [VIN_WARN]get csi isp clk fail
            [    3.529139] [VIN_WARN]Get isp reset control fail
            [    3.535348] ov5640 2-003c: endpoint node not found
            [    3.540781] ov5640: probe of 2-003c failed with error -22
            [    3.547061] [VIN_ERR]registering ov5640, No such device!
            [    3.553072] [VIN]vinc1 is null
            检测一下twi2:
            root@TinaLinux:/# i2cdetect -r -y 2
                 0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f[   54.824048] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x3)
            00:          [   54.836025] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x4)
            -- [   54.844682] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x5)
            -- [   54.852541] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x6)
            -- [   54.860239] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x7)
            -- [   54.868087] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x8)
            -- [   54.875834] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x9)
            -- [   54.883681] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0xa)
            -- [   54.891383] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0xb)
            -- [   54.899259] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0xc)
            -- [   54.906986] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0xd)
            -- [   54.914835] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0xe)
            -- [   54.922575] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0xf)
            -- [   54.930413] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x10)
            10: [   54.938256] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x11)
            -- [   54.946718] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x12)
            -- [   54.954545] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x13)
            -- -- UU [   54.962535] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x15)
            -- [   54.970826] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x16)
            -- [   54.978822] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x17)
            -- [   54.986731] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x18)
            -- [   54.994696] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x19)
            -- [   55.002636] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x1a)
            -- [   55.010581] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x1b)
            -- [   55.018499] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x1c)
            -- [   55.026460] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x1d)
            -- [   55.034387] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x1e)
            -- [   55.042367] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x1f)
            -- [   55.050271] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x20)
            20: [   55.058255] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x21)
            -- [   55.066336] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x22)
            -- [   55.074257] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x23)
            -- [   55.082110] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x24)
            -- [   55.090020] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x25)
            -- [   55.097940] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x26)
            -- [   55.105815] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x27)
            -- [   55.113658] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x28)
            -- [   55.121588] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x29)
            -- [   55.129446] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x2a)
            -- [   55.137367] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x2b)
            -- [   55.145219] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x2c)
            -- [   55.153160] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x2d)
            -- [   55.160974] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x2e)
            -- [   55.168954] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x2f)
            -- [   55.176780] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x30)
            30: [   55.184736] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x31)
            -- [   55.193067] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x32)
            -- [   55.200995] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x33)
            -- [   55.208838] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x34)
            -- [   55.216787] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x35)
            -- [   55.224659] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x36)
            -- [   55.232561] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x37)
            -- [   55.240402] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x38)
            -- -- [   55.249135] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x39)
            -- [   55.257044] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x3a)
            -- [   55.265065] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x3b)
            -- [   55.272997] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x3c)
            -- [   55.280979] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x3d)
            -- [   55.288888] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x3e)
            -- [   55.300106] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x3f)
            -- [   55.308076] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x40)
            40: [   55.316033] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x41)
            -- [   55.324132] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x42)
            -- [   55.332082] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x43)
            -- [   55.339879] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x44)
            -- -- [   55.352152] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x45)
            -- [   55.360282] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x46)
            -- [   55.368419] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x47)
            -- [   55.376354] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x48)
            -- [   55.384355] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x49)
            -- [   55.392276] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x4a)
            -- [   55.400230] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x4b)
            -- [   55.408181] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x4c)
            -- [   55.416142] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x4d)
            -- [   55.424060] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x4e)
            -- [   55.432039] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x4f)
            -- [   55.439945] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x50)
            50: [   55.447902] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x51)
            -- [   55.455990] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x52)
            -- -- [   55.463976] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x53)
            -- [   55.472029] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x54)
            -- [   55.479979] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x55)
            -- [   55.487938] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x56)
            -- [   55.495928] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x57)
            -- [   55.503856] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x58)
            -- [   55.511822] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x59)
            -- [   55.519709] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x5a)
            -- [   55.527702] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x5b)
            -- [   55.535611] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x5c)
            -- [   55.543571] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x5d)
            -- [   55.551468] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x5e)
            -- [   55.559440] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x5f)
            -- [   55.567404] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x60)
            60: [   55.575348] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x61)
            -- [   55.583464] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x62)
            -- [   55.591380] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x63)
            -- [   55.599221] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x64)
            -- [   55.607176] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x65)
            -- [   55.615037] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x66)
            -- [   55.622938] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x67)
            -- [   55.630767] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x68)
            -- [   55.638706] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x69)
            -- [   55.646597] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x6a)
            -- [   55.654491] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x6b)
            -- [   55.662334] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x6c)
            -- [   55.670262] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x6d)
            -- [   55.678121] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x6e)
            -- [   55.686038] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x6f)
            -- [   55.693914] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x70)
            70: [   55.701841] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x71)
            -- [   55.710176] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x72)
            -- [   55.718109] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x73)
            -- [   55.725955] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x74)
            -- [   55.733927] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x75)
            -- [   55.741765] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x76)
            -- [   55.749673] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x77)
            G 1 条回复 最后回复 回复 引用 分享 0
            • G
              gonboy LV 5 @liefyuan 最后由 编辑
              @liefyuan 同样的问题, 楼主解决了没? 如何解决的?
