    禁用spi0就进不了系统了 这个要怎么设置? 求帮忙
    9
    6060
      zcxhappy LV 5 最后由 编辑
      sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      Bluetooth: RFCOMM TTY layer initialized
      Bluetooth: RFCOMM socket layer initialized
      Bluetooth: RFCOMM ver 1.11
      sunxi-i2c sunxi-i2c2: sunxi-i2c2 supply twi not found, using dummy regulator
      sunxi-i2c sunxi-i2c2: probe success
      [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xffffffe0006f1fa8, 0x:ffffffd0040f1000, irq_no:2e
      [sunxi-ehci0]: Not init ehci0
      [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xffffffe0006f2370
      [sunxi-ohci0]: Not init ohci0
      OF: fdt: not creating '/sys/firmware/fdt': CRC check failed
      random: fast init done
      mmc1: host does not support reading read-only switch, assuming write-enable
      alloc_fd: slot 0 not NULL!
      VFS: Cannot open root device "mmcblk0p5" or unknown-block(0,0): error -6
      Please append a correct "root=" boot option; here are the available partitions:
      sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
      CPU: 0 PID: 1 Comm: swapper Not tainted 5.4.61 #197
      Call Trace:
      [<ffffffe000026130>] walk_stackframe+0x0/0x98
      [<ffffffe0000262e8>] show_stack+0x2a/0x34
      [<ffffffe00049fab4>] dump_stack+0x20/0x28
      [<ffffffe00002a6f0>] panic+0xec/0x272
      [<ffffffe000000ef6>] mount_block_root+0x214/0x27a
      [<ffffffe000000fe2>] mount_root+0x86/0x90
      [<ffffffe000001134>] prepare_namespace+0x148/0x152
      [<ffffffe000000b58>] kernel_init_freeable+0x166/0x198
      [<ffffffe0004b0684>] kernel_init+0x12/0xee
      [<ffffffe000024e9c>] ret_from_exception+0x0/0xc
      ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
      &spi0 {
      	// pinctrl-0 = <&spi0_pins_a &spi0_pins_b>;
      	// pinctrl-1 = <&spi0_pins_c>;
      	spi_slave_mode = <0>;
      	spi0_cs_number = <1>;
          spi0_cs_bitmap = <1>;
      	status = "disabled";
      	spi-nand@0 {
      		compatible = "spi-nand";
      		// spi-max-frequency=<100000000>;
      		// reg = <0x0>;
      		// spi-rx-bus-width=<0x01>;
      		// spi-tx-bus-width=<0x01>;
      		// status="okay";
              spi-max-frequency=<0x5F5E100>;
      		reg = <0x0>;
      		spi-rx-bus-width=<0x04>;
      		spi-tx-bus-width=<0x04>;
      		status="disabled";
        chengwei_peng LV 6 @zcxhappy 最后由 编辑
        @zcxhappy 你的板子上flash是spi nand?
        Z 1 条回复 最后回复 回复 引用 分享 0
          zcxhappy LV 5 @chengwei_peng 最后由 编辑
          @chengwei_peng 用的是sdc0的sd卡启动,没有用到spi;因为wifi用的是sdc2跟spi0有冲突所以想把spi0给禁用,结果进不了系统。
            WhycanService LV 8 最后由 编辑
            配置mmcblk0为mmcblk1,在env.cfg里修改
              zcxhappy LV 5 @WhycanService 最后由 编辑
              @whycanservice 我修改了device/config/chips/d1s/configs/default/env.cfg中的mmc_root=/dev/mmcblk1p5 重新编译发现Kernel command line没有变化依旧是
              然后我在make kernel_menuconfig
              Boot options  --->
                  Built-in command line usage (Always use the default kernel command string)
              填上env.cfg 的参数
              earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mmcblk1p5 init=/pseudo_init partitions=boot-resource@mmcblk1p1:env@mmcblk1p2:env-redund@mmcblk1p3:boot@mmcblk1p4:rootfs@mmcblk1p5:dsp0@mmcblk1p6:recovery@mmcblk1p7:rootfs_data@mmcblk1p8:UDISK@mmcblk1p9 cma= snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.hardware=sun20iw1p1 boot_type=1 androidboot.boot_type=1 gpt=1
              重新编译
              还是进不了系统
              以下是打印日志:
              sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
              sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
              sunxi-mmc 4020000.sdmmc: No vmmc regulator found
              sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
              sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
              sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
              sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
              sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
              sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
              sunxi-mmc 4022000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
              sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
              sunxi-mmc 4020000.sdmmc: Got CD GPIO
              sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
              sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
              sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
              sunxi-mmc 4020000.sdmmc: detmode:gpio irq
              ashmem: initialized
              exFAT: Version 1.3.0
              Segment Routing with IPv6
              VFS: Cannot open root device "mmcblk1p5" or unknown-block(0,0): error -6
              CPU: 0 PID: 1 Comm: swapper Not tainted 5.4.61 #202
              Call Trace:
              [<ffffffe0004a081c>] dump_stack+0x20/0x28
              [<ffffffe0004b13ec>] kernel_init+0x12/0xee
              是不是哪里配置错了 或许还需要修改其他的配置?
                WhycanService LV 8 @zcxhappy 最后由 WhycanService 编辑
                @zcxhappy 看到了,不是这个问题,是sd卡的驱动没有挂上,看上去没有找到卡
                  @whycanservice
                  spi0的status = "okay";就可以进入系统其他没改动,请问要修改哪个驱动?
                    lyscut LV 5 最后由 编辑
                    是不是分区号不对?
                      zcxhappy LV 5 @lyscut 最后由 编辑
                      @lyscut 要在哪里设置呢?
                      • Referenced by  S shanhai8372
