    100ASK百问网 D1s/T113-s3开发板 适配ov5640
    6
    7
    10301
    • N
      NULL037 LV 7 最后由 NULL037 编辑
      本实验采用百问网的100ASK_T113-PRO Base V1.1 ,链接:韦东山全志T113开发板
      D1s也可以参考进行修改并适配。
      本实验所需的文件(含tina根文件系统、SD镜像、设备树、内核配置文件)供大家对比参考:source.zip
      1.硬件配置
      查看百问网提供的T113开发板原理图100ASK_T113-Pro_Base-SCH.pdf
      通过查看到第3页的摄像头原理图
      ①将PE引脚使用跳线帽连接至CSI引脚。
      ②根据所使用的摄像头,利用跳线帽,使AVDD、DVDD、DIOVDD选择不同的电压
      我所使用的是ov5640,使用2.8V的AVDD、1.5V的DVDD、2.8V的DIOVDD
      ③根据摄像头的引脚信息,上接至T113开发板的DVP接口
      2.修改设备树
      注意:T113中的网口和CSI接口复用,注意设备树中网口的PE的复用功能需要修改为CSI的PE的复用功能。
      文件名:sun8iw20p1-t113-100ask-t113-pro.dts
      文件目录:buildroot_100ask_t113-pro/buildroot/output/build/linux-origin_master/arch/arm/boot/dts/
      &vind0 {
      	csi_top = <378000000>;
      	csi_isp = <327000000>;
      	status = "okay"; /* enable twi and ver1 spi-nand max freq 30M */
      	actuator0: actuator@5809450 {
      		device_type = "actuator0";
      		actuator0_slave = <0x18>;
      		actuator0_af_pwdn = <>;
      	flash0: flash@5809460 {
      		device_type = "flash0";
      		flash0_type = <2>;
      		flash0_en = <>;
      		flash0_mode = <>;
      		flash0_flvdd = "";
      		flash0_flvdd_vol = <>;
      		device_id = <0>;
      	sensor0: sensor@5809470 {
      		device_type = "sensor0";
      		sensor0_mname = "ov5640";
      		sensor0_twi_cci_id = <2>;
      		sensor0_twi_addr = <0x78>;
      		sensor0_mclk_id = <0>;
      		sensor0_pos = "rear";
      		sensor0_isp_used = <0>;
      		sensor0_fmt = <0>;
      		sensor0_stby_mode = <0>;
      		sensor0_vflip = <0>;
      		sensor0_hflip = <0>;
      		sensor0_iovdd-supply = <>;
      		sensor0_iovdd_vol = <1800000>;
      		sensor0_avdd-supply = <>;
      		sensor0_avdd_vol = <2800000>;
      		sensor0_dvdd-supply = <>;
      		sensor0_dvdd_vol = <1500000>;
      		sensor0_power_en = <>;
      		sensor0_reset = <>;
      		//sensor0_reset = <&pio PE 15 GPIO_ACTIVE_LOW>;
      		//sensor0_pwdn = <&pio PE 14 GPIO_ACTIVE_LOW>;
      		//sensor0_reset = <&pio PE 13 GPIO_ACTIVE_LOW>;
      		sensor0_pwdn = <>;
      		sensor0_sm_vs = <>;
      		flash_handle = <&flash0>;
      		act_handle = <&actuator0>;
      		device_id = <0>;
      		status  = "okay";
      	sensor1:sensor@5809480 {
      		device_type = "sensor1";
      		sensor1_mname = "ov5647";
      		sensor1_twi_cci_id = <3>;
      		sensor1_twi_addr = <0x6c>;
      		sensor1_mclk_id = <1>;
      		sensor1_pos = "front";
      		sensor1_isp_used = <0>;
      		sensor1_fmt = <0>;
      		sensor1_stby_mode = <0>;
      		sensor1_vflip = <0>;
      		sensor1_hflip = <0>;
      		sensor1_iovdd-supply = <>;
      		sensor1_iovdd_vol = <>;
      		sensor1_avdd-supply = <>;
      		sensor1_avdd_vol = <>;
      		sensor1_dvdd-supply = <>;
      		sensor1_dvdd_vol = <>;
      		sensor1_power_en = <>;
      		status	= "disabled";
      	vinc0:vinc@5809000 {
      		vinc0_csi_sel = <0>;
      		vinc0_mipi_sel = <0xff>;
      		vinc0_isp_sel = <0>;
      		vinc0_isp_tx_ch = <0>;
      		vinc0_tdm_rx_sel = <0xff>;
      		vinc0_rear_sensor_sel = <0>;
      		vinc0_front_sensor_sel = <0>;
      		vinc0_sensor_list = <0>;
      	vinc1:vinc@5809200 {
      		vinc1_csi_sel = <0>;
      		vinc1_mipi_sel = <0xff>;
      		vinc1_isp_sel = <0>;
      		vinc1_isp_tx_ch = <1>;
      		vinc1_tdm_rx_sel = <0xff>;
      		vinc1_rear_sensor_sel = <0>;
      		vinc1_front_sensor_sel = <1>;
      		vinc1_sensor_list = <0>;
      文件名:sun8iw20p1.dtsi
      	vind0: vind@5800800 {
      			#address-cells = <2>;
      			#size-cells = <2>;
      			ranges;
      			device_id = <0>;
      			csi_top = <336000000>;
      				<0x0 0x05800000 0x0 0x800>;
      			clocks = <&ccu CLK_CSI_TOP>, <&ccu CLK_PLL_VIDEO1_2X>,
      				<&ccu CLK_CSI0_MCLK>, <&dcxo24M>, <&ccu CLK_PLL_VIDEO1>,
      				<&ccu CLK_BUS_CSI>, <&ccu CLK_MBUS_CSI>;
      					"csi_bus", "csi_mbus";
      			resets = <&ccu RST_BUS_CSI>;
      			reset-names = "csi_ret";
      			pinctrl-names = "mclk0-default", "mclk0-sleep";
      			pinctrl-0 = <&csi_mclk0_pins_a>;
      			pinctrl-1 = <&csi_mclk0_pins_b>;
      			csi0: csi@5801000{
      				reg = <0x0 0x05801000 0x0 0x1000>;
      				interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>;
      				pinctrl-0 = <&csi0_pins_a>;
      				pinctrl-1 = <&csi0_pins_b>;
      				device_id = <0>;
      				iommus = <&mmu_aw 1 1>;
      			isp0: isp@5809410 {
      				reg = <0x0 0x05809410 0x0 0x10>;
      				device_id = <0xfe>;
      			isp1: isp@5809420 {
      				reg = <0x0 0x05809420 0x0 0x10>;
      				device_id = <0xff>;
      			scaler0: scaler@5809430 {
      				reg = <0x0 0x05809430 0x0 0x10>;
      				device_id = <0xfe>;
      			scaler1: scaler@5809440 {
      				reg = <0x0 0x05809440 0x0 0x10>;
      				device_id = <0xff>;
      				reg = <0x0 0x05809450 0x0 0x10>;
      				reg = <0x0 0x05809460 0x0 0x10>;
      				flash0_type = <2>;
      				flash0_en = <>;
      				flash0_mode = <>;
      				flash0_flvdd = "";
      				device_id = <0>;
      				sensor0_fmt = <0>;
      				sensor0_iovdd_vol = <>;
      				sensor0_avdd_vol = <>;
      				sensor0_dvdd_vol = <>;
      				sensor0_reset = <&pio PE 9 GPIO_ACTIVE_LOW>;
      				sensor0_pwdn = <&pio PE 8 GPIO_ACTIVE_LOW>;
      				sensor0_sm_vs = <>;
      				device_id = <0>;
      				status	= "okay";
      			sensor1: sensor@5809480 {
      				reg = <0x0 0x05809480 0x0 0x10>;
      				sensor1_fmt = <0>;
      				sensor1_sm_vs = <>;
      				flash_handle = <>;
      				act_handle = <>;
      				device_id = <1>;
      				status	= "okay";
      			vinc0: vinc@5809000 {
      				device_type = "vinc0";
      				interrupts = <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>;
      				device_id = <0>;
      			vinc1: vinc@5809200 {
      				device_type = "vinc1";
      				reg = <0x0 0x05809200 0x0 0x200>;
      				interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>;
      				vinc1_isp_sel = <1>;
      				vinc1_front_sensor_sel = <0>;
      				device_id = <1>;
      3.修改内核配置
      在buildroot目录下,输入
      make linux-menuconfig
      进入内核配置界面中的下面目录:
      │ -> Device Drivers
      │ -> Multimedia support
      对于Media USB Adapters:
      对于V4L platform devices:
      对于SUNXI platform devices:
      对于Memory-to-memory multimedia devices:
      修改完成后,保存并退出。
      4.重新编译和烧写
      在buildroot目录下执行
      make linux-rebuild
      执行完成后,再打包生成SD卡镜像,输入
      make -j4
      5.使用tina的根文件系统启动
      将烧录到sd卡的t113系统挂载到ubuntu中 使用 df -h 查看分区
      进入分区
      cd /media/book/dd79b15c-ce3f-4d2d-8a75-437303b2df61/
      拷贝lib中的驱动到桌面备用
      sudo cp -rf lib/modules/5.4.61 ~/Desktop
      删除全部文件
      sudo rm -rf *
      将source文件夹中的tina_rootfs目录下的rootfs.img拷贝到Ubuntu中,解压tina系统
      unsquashfs  rootfs.img
      拷贝tina系统中的文件到当前目录
      sudo cp /home/book/squashfs-root/* ./ -rfd
      进入lib/modules目录下删除5.4.61文件夹
      cd lib/modules/
      sudo rm -rf 5.4.61
      将5.4.61文件夹拷贝回去
      sudo cp ~/Desktop/5.4.61/ ./ -rf
      从虚拟机中弹出SD卡。
      6.使用camerademo测试
      将SD卡插入T113开发板,上电启动。启动界面如下:
      进入sunxi-vin目录:
      cd /lib/modules/5.4.61/kernel/drivers/media/platform/sunxi-vin/
      装载vin_io.ko驱动
      进入sensor目录:
      cdcd modules/sensor/
      装载ov5640.ko驱动:
      insmod ov5640.ko
      回到sunxi-vin目录:
      装载vin_v4l2.ko驱动:
      insmod vin_v4l2.ko
      注意:上述大部分打印信息为我调试时加的打印,与自带驱动无关,全志自带的驱动程序是正常。
      插入U盘或无系统的TF卡将获取到的图片提取出来查看。
      挂载U盘。
      mount /dev/sda1 /mnt/
      使用camerademo拍摄照片,存放到U盘内
      camerademo NV21 640 480 30 bmp  /mnt 5
      卸载U盘分区
      umount /mnt/
      拔下u盘,插入电脑中,即可查看到刚刚在T113开发板上使用ov5640拍摄的5张照片
      H Z N 3 条回复 最后回复 回复 引用 分享 2
      • mangogeek
        mangogeek LV 8 最后由 编辑
        @null037 在 100ASK百问网 D1s/T113-s3开发板 适配ov5640 中说:
        强烈建议光速适配下MQ-R😊
          hameyou LV 4 @NULL037 最后由 编辑
          @null037 按照配置,MQ-R 板子已出图
            z15612417860 LV 4 @NULL037 最后由 编辑
            @null037 本身就是tina系统的话,应该怎么适配呢
            • N
              NULL037 LV 7 @NULL037 最后由 编辑
              @null037 Tina测试镜像:tina_t113-100ask_uart3.img
              W 1 条回复 最后回复 回复 引用 分享 0
                liuyongli1983 LV 2 最后由 编辑
                V851S是不是也是一样的方法呢
                  WHATfuckt113 LV 2 @NULL037 最后由 编辑
                  @null037
                  刷以上固件,ov5640接对应条线帽,加载驱动报错如下:
                  [ 34.164204] [VIN_WARN]sensor_helper_probe: cannot get sensor0_cameravdd supply, setting it to NULL!
                  [ 34.174365] [VIN_WARN]sensor_helper_probe: cannot get sensor0_iovdd supply, setting it to NULL!
                  [ 34.184079] [VIN_WARN]sensor_helper_probe: cannot get sensor0_avdd supply, setting it to NULL!
                  [ 34.193696] [VIN_WARN]sensor_helper_probe: cannot get sensor0_dvdd supply, setting it to NULL!
                  [ 50.450703] vin_v4l2: Unknown symbol vb2_dma_contig_clear_max_seg_size (err -2)
                  [ 50.459006] vin_v4l2: Unknown symbol vb2_dma_contig_set_max_seg_size (err -2)
                  [ 50.466975] vin_v4l2: Unknown symbol vb2_dma_contig_memops (err -2)
                  [ 131.504440] vin_v4l2: Unknown symbol vb2_dma_contig_clear_max_seg_size (err -2)
                  [ 131.512768] vin_v4l2: Unknown symbol vb2_dma_contig_set_max_seg_size (err -2)
                  [ 131.520774] vin_v4l2: Unknown symbol vb2_dma_contig_memops (err -2)
