    我也来试一试编译 A33 android sdk,编译环境Ubuntu18.04,make版本v4.1
    a33 android
    5473
    • cube_work
      cube_work LV 5 最后由 编辑
      cube@ubuntu:/opt/a33/a33_android_sdk/android$ lunch
      You're building on Linux
      Lunch menu... pick a combo:
           1. aosp_arm-eng
           2. aosp_x86-eng
           3. aosp_mips-eng
           4. vbox_x86-eng
           5. aosp_hammerhead-userdebug
           6. aosp_mako-userdebug
           7. vstar-eng
           8. vstar-user
           9. astar_y3-eng
           10. astar_y3-user
           11. aosp_manta-userdebug
           12. aosp_deb-userdebug
           13. aosp_grouper-userdebug
           14. aosp_tilapia-userdebug
           15. aosp_flo-userdebug
           16. mini_x86-userdebug
           17. mini_mips-userdebug
           18. mini_armv7a_neon-userdebug
      Which would you like? [aosp_arm-eng] 7
      build/core/config.mk:365: *** Error: could not find jdk tools.jar, please install JDK6, which you can download from java.sun.com.  Stop.
      ** Don't have a product spec for: 'vstar'
      ** Do you have the right repo manifest?
      出师不利, 开局就暴击, A33 android sdk 编译出现 jdk 相关错误的问题。
      • cube_work
        1. 下载 jdk-6u45-linux-x64.bin,解压到 /usr/java/ 目录
        2. 导出环境变量:
        export ANDROID_JAVA_HOME="/usr/java/jdk1.6.0_45"
        export JAVA_HOME="/usr/java/jdk1.6.0_45"
        搞定:
             1. aosp_arm-eng
             2. aosp_x86-eng
             3. aosp_mips-eng
             4. vbox_x86-eng
             7. vstar-eng
             8. vstar-user
             9. astar_y3-eng
             10. astar_y3-user
        PLATFORM_VERSION_CODENAME=REL
        PLATFORM_VERSION=4.4.2
        TARGET_PRODUCT=vstar
        TARGET_BUILD_VARIANT=eng
        TARGET_BUILD_TYPE=release
        TARGET_BUILD_APPS=
        TARGET_ARCH=arm
        TARGET_ARCH_VARIANT=armv7-a-neon
        TARGET_CPU_VARIANT=cortex-a7
        HOST_ARCH=x86
        HOST_OS=linux
        HOST_OS_EXTRA=Linux-5.4.0-80-generic-x86_64-with-Ubuntu-18.04-bionic
        HOST_BUILD_TYPE=release
        BUILD_ID=KVT49L
        OUT_DIR=out
        • cube_work
          cube@ubuntu:/opt/a33/a33_android_sdk/android$ make
          build/core/main.mk:45: ********************************************************************************
          build/core/main.mk:46: *  You are using version 4.1 of make.
          build/core/main.mk:47: *  Android can only be built by versions 3.81 and 3.82.
          build/core/main.mk:48: *  see https://source.android.com/source/download.html
          build/core/main.mk:49: ********************************************************************************
          build/core/main.mk:50: *** stopping.  Stop.
          修改 build/core/main.mk
          ifeq (,$(findstring CYGWIN,$(shell uname -sm)))
          ifeq (0,$(shell expr $$(echo $(MAKE_VERSION) | sed "s/[^0-9\.].*//") = 3.81))
          ifeq (0,$(shell expr $$(echo $(MAKE_VERSION) | sed "s/[^0-9\.].*//") = 3.82))
          ifeq (0,$(shell expr $$(echo $(MAKE_VERSION) | sed "s/[^0-9\.].*//") = 4.1))
          插入一行
          • cube_work
            make 出现错误:
            including ./sdk/hierarchyviewer/src/Android.mk ...
            including ./sdk/monitor/Android.mk ...
            including ./sdk/sdklauncher/Android.mk ...
            including ./system/core/Android.mk ...
            including ./system/extras/Android.mk ...
            including ./system/media/audio_route/Android.mk ...
            including ./system/media/audio_utils/Android.mk ...
            including ./system/media/camera/src/Android.mk ...
            including ./system/media/camera/tests/Android.mk ...
            including ./system/netd/Android.mk ...
            including ./system/security/keystore-engine/Android.mk ...
            including ./system/security/keystore/Android.mk ...
            including ./system/security/softkeymaster/Android.mk ...
            including ./system/vold/Android.mk ...
            including ./tools/external/fat32lib/Android.mk ...
            No private recovery resources for TARGET_DEVICE vstar
            build/core/main.mk:945: *** missing 'endif'.  Stop.
            解决方案:
            在 build/core/main.mk 945 行插入: endif
            正在愉快地编译:
            host C: libcrypto-host <= external/openssl/crypto/des/rpc_enc.c
            host C: libcrypto-host <= external/openssl/crypto/des/set_key.c
            host C: libcrypto-host <= external/openssl/crypto/des/str2key.c
            host C: libcrypto-host <= external/openssl/crypto/des/xcbc_enc.c
            host C: libcrypto-host <= external/openssl/crypto/dh/dh_ameth.c
            host C: libcrypto-host <= external/openssl/crypto/dh/dh_asn1.c
            host C: libcrypto-host <= external/openssl/crypto/dh/dh_check.c
            external/openssl/crypto/dh/dh_ameth.c:500:2: warning: missing initializer [-Wmissing-field-initializers]
            external/openssl/crypto/dh/dh_ameth.c:500:2: warning: (near initialization for 'dh_asn1_meth.old_priv_decode') [-Wmissing-field-initializers]
            host C: libcrypto-host <= external/openssl/crypto/dh/dh_depr.c
            host C: libcrypto-host <= external/openssl/crypto/dh/dh_err.c
            host C: libcrypto-host <= external/openssl/crypto/dh/dh_gen.c
            host C: libcrypto-host <= external/openssl/crypto/dh/dh_key.c
            host C: libcrypto-host <= external/openssl/crypto/dh/dh_lib.c
            host C: libcrypto-host <= external/openssl/crypto/dh/dh_pmeth.c
            host C: libcrypto-host <= external/openssl/crypto/dsa/dsa_ameth.c
            host C: libcrypto-host <= external/openssl/crypto/dsa/dsa_asn1.c
            host C: libcrypto-host <= external/openssl/crypto/dsa/dsa_depr.c
            host C: libcrypto-host <= external/openssl/crypto/dsa/dsa_err.c
            external/openssl/crypto/dsa/dsa_ameth.c:650:3: warning: missing initializer [-Wmissing-field-initializers]
            external/openssl/crypto/dsa/dsa_ameth.c:650:3: warning: (near initialization for 'dsa_asn1_meths[0].pem_str') [-Wmissing-field-initializers]
            external/openssl/crypto/dsa/dsa_ameth.c:656:3: warning: missing initializer [-Wmissing-field-initializers]
            external/openssl/crypto/dsa/dsa_ameth.c:656:3: warning: (near initialization for 'dsa_asn1_meths[1].pem_str') [-Wmissing-field-initializers]
            external/openssl/crypto/dsa/dsa_ameth.c:662:3: warning: missing initializer [-Wmissing-field-initializers]
            external/openssl/crypto/dsa/dsa_ameth.c:662:3: warning: (near initialization for 'dsa_asn1_meths[2].pem_str') [-Wmissing-field-initializers]
            external/openssl/crypto/dsa/dsa_ameth.c:668:3: warning: missing initializer [-Wmissing-field-initializers]
            external/openssl/crypto/dsa/dsa_ameth.c:668:3: warning: (near initialization for 'dsa_asn1_meths[3].pem_str') [-Wmissing-field-initializers]
            external/openssl/crypto/dsa/dsa_ameth.c:702:3: warning: missing initializer [-Wmissing-field-initializers]
            external/openssl/crypto/dsa/dsa_ameth.c:702:3: warning: (near initialization for 'dsa_asn1_meths[4].item_verify') [-Wmissing-field-initializers]
            host C: libcrypto-host <= external/openssl/crypto/dsa/dsa_gen.c
            host C: libcrypto-host <= external/openssl/crypto/dsa/dsa_key.c
            host C: libcrypto-host <= external/openssl/crypto/dsa/dsa_lib.c
            host C: libcrypto-host <= external/openssl/crypto/dsa/dsa_ossl.c
            host C: libcrypto-host <= external/openssl/crypto/dsa/dsa_pmeth.c
            host C: libcrypto-host <= external/openssl/crypto/dsa/dsa_prn.c
            • cube_work
              编译成功:
              aapt: warning: **** string 'wimax_settings_summary' has no default or required localization for 'zu_ZA' in packages/apps/Settings/res
              aapt: warning: **** string 'wimax_settings_summary' has no default or required localization for 'am_ET' in packages/apps/Settings/res
              aapt: warning: **** string 'wimax_settings_summary' has no default or required localization for 'hi_IN' in packages/apps/Settings/res
              aapt: warning: **** string 'wimax_settings_summary' has no default or required localization for 'en_XA' in packages/apps/Settings/res
              aapt: warning: **** string 'wimax_settings_summary' has no default or required localization for 'ar_XB' in packages/apps/Settings/res
              aapt: warning: **** string 'wimax_settings_summary' has no default or required localization for 'fr_CA' in packages/apps/Settings/res
              aapt: warning: **** string 'wimax_settings_summary' has no default or required localization for 'xlarge' in packages/apps/Settings/res
              aapt: warning: **** string 'wimax_settings_summary' has no default or required localization for 'hdpi' in packages/apps/Settings/res
              aapt: warning: **** string 'wimax_settings_summary' has no default or required localization for 'xhdpi' in packages/apps/Settings/res
              aapt: warning: **** string 'wimax_settings_summary' has no default or required localization for 'large' in packages/apps/Settings/res
              aapt: warning: **** string 'wimax_settings_summary' has no default or required localization for 'nodpi' in packages/apps/Settings/res
              Install: out/target/product/vstar/system/app/Gallery2.apk
              Install: out/target/product/vstar/system/priv-app/Settings.apk
              target Symbolic: libwebviewchromium (out/target/product/vstar/symbols/system/lib/libwebviewchromium.so)
              target Strip: libwebviewchromium (out/target/product/vstar/obj/lib/libwebviewchromium.so)
              Install: out/target/product/vstar/system/lib/libwebviewchromium.so
              Install: out/target/product/vstar/system/framework/webviewchromium.jar
              Install: out/target/product/vstar/fake_packages/webview-timestamp
              build/tools/generate-notice-files.py  out/target/product/vstar/obj/NOTICE.txt  out/target/product/vstar/obj/NOTICE.html "Notices for files contained in the filesystem images in this directory:" out/target/product/vstar/obj/NOTICE_FILES/src
              Combining NOTICE files into HTML
              Combining NOTICE files into text
              Installed file list: out/target/product/vstar/installed-files.txt
              Target system fs image: out/target/product/vstar/obj/PACKAGING/systemimage_intermediates/system.img
              Running:  mkuserimg.sh -s out/target/product/vstar/system out/target/product/vstar/obj/PACKAGING/systemimage_intermediates/system.img ext4 system 805306368 out/target/product/vstar/root/file_contexts
              + echo 'in mkuserimg.sh PATH=out/host/linux-x86/bin/:/usr/java/jdk1.6.0_45/bin:/usr/local/gnu-mcu-eclipse/riscv-none-gcc/7.2.0-4-20180606-1631/bin/:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/opt/a33/a33_android_sdk/android/out/host/linux-x86/bin:/opt/a33/a33_android_sdk/android/prebuilts/gcc/linux-x86/arm/arm-linux-androideabi-4.7/bin:/opt/a33/a33_android_sdk/android/prebuilts/gcc/linux-x86/arm/arm-eabi-4.7/bin:/opt/a33/a33_android_sdk/android/prebuilts/gcc/linux-x86/mips/mipsel-linux-android-4.7/bin:/opt/a33/a33_android_sdk/android/development/emulator/qtools:/opt/a33/a33_android_sdk/android/prebuilts/gcc/linux-x86/arm/arm-linux-androideabi-4.7/bin:/opt/a33/a33_android_sdk/android/prebuilts/gcc/linux-x86/arm/arm-eabi-4.7/bin:/opt/a33/a33_android_sdk/android/development/scripts:/opt/a33/a33_android_sdk/android/prebuilts/devtools/tools:'
              + ENABLE_SPARSE_IMAGE=
              + '[' -s = -s ']'
              + ENABLE_SPARSE_IMAGE=-s
              + shift
              + '[' 6 -ne 5 -a 6 -ne 6 ']'
              + SRC_DIR=out/target/product/vstar/system
              + '[' '!' -d out/target/product/vstar/system ']'
              + OUTPUT_FILE=out/target/product/vstar/obj/PACKAGING/systemimage_intermediates/system.img
              + EXT_VARIANT=ext4
              + MOUNT_POINT=system
              + SIZE=805306368
              + FC=out/target/product/vstar/root/file_contexts
              + case $EXT_VARIANT in
              + '[' -z system ']'
              + '[' -z 805306368 ']'
              + '[' -n out/target/product/vstar/root/file_contexts ']'
              + FCOPT='-S out/target/product/vstar/root/file_contexts'
              + MAKE_EXT4FS_CMD='make_ext4fs -s -S out/target/product/vstar/root/file_contexts -l 805306368 -a system out/target/product/vstar/obj/PACKAGING/systemimage_intermediates/system.img out/target/product/vstar/system'
              + echo make_ext4fs -s -S out/target/product/vstar/root/file_contexts -l 805306368 -a system out/target/product/vstar/obj/PACKAGING/systemimage_intermediates/system.img out/target/product/vstar/system
              + make_ext4fs -s -S out/target/product/vstar/root/file_contexts -l 805306368 -a system out/target/product/vstar/obj/PACKAGING/systemimage_intermediates/system.img out/target/product/vstar/system
              Creating filesystem with parameters:
                  Block size: 4096
                  Blocks per group: 32768
                  Inodes per group: 8192
                  Inode size: 256
                  Journal blocks: 3072
                  Label:
                  Blocks: 196608
                  Block groups: 6
                  Reserved block group size: 47
              Created filesystem with 1596/49152 inodes and 87533/196608 blocks
              + '[' 0 -ne 0 ']'
              Install system fs image: out/target/product/vstar/system.img
              out/target/product/vstar/system.img+out/target/product/vstar/obj/PACKAGING/recovery_patch_intermediates/recovery_from_boot.p maxsize=822163584 blocksize=4224 total=349827018 reserve=8308608
              打包成功:
              cube@ubuntu:/opt/a33/a33_android_sdk/android$ pack
              copying tools file
              copying configs file
              copying boot resource
              copying boot file
              packing for android
              normal
              /opt/a33/a33_android_sdk/lichee/tools/pack/pctools/linux/eDragonEx/
              /opt/a33/a33_android_sdk/lichee/tools/pack/out
              Begin Parse sys_partion.fex
              FilePath: boot-resource.fex
              FileLength=4bec00Add partion env.fex ENV_FEX000000000
              FilePath: env.fex
              FilePath: boot.fex
              FileLength=b09000Add partion system.fex SYSTEM_FEX000000
              Add partion very system.fex SYSTEM_FEX000000
              FilePath: system.fex
              FileLength=14b64864Add partion recovery.fex RECOVERY_FEX0000
              Add partion very recovery.fex RECOVERY_FEX0000
              FilePath: recovery.fex
              FileLength=dd1000Add partion diskfs.fex DISKFS_FEX000000
              Add partion very diskfs.fex DISKFS_FEX000000
              FilePath: diskfs.fex
              FileLength=200sys_config.fex Len: 0xf8df
              config.fex Len: 0x9c24
              split_xxxx.fex Len: 0x200
              sys_partition.fex Len: 0xf0a
              boot0_nand.fex Len: 0x8000
              boot0_sdcard.fex Len: 0x8000
              u-boot.fex Len: 0xbc000
              fes1.fex Len: 0x1fc0
              usbtool.fex Len: 0x20600
              aultools.fex Len: 0x25d92
              aultls32.fex Len: 0x2295a
              cardtool.fex Len: 0x14000
              cardscript.fex Len: 0x6ea
              sunxi_mbr.fex Len: 0x10000
              dlinfo.fex Len: 0x4000
              arisc.fex Len: 0x2ed88
              boot-resource.fex Len: 0x4bec00
              Vboot-resource.fex Len: 0x4
              env.fex Len: 0x20000
              Venv.fex Len: 0x4
              boot.fex Len: 0xb09000
              Vboot.fex Len: 0x4
              system.fex Len: 0x14b64864
              Vsystem.fex Len: 0x4
              recovery.fex Len: 0xdd1000
              Vrecovery.fex Len: 0x4
              diskfs.fex Len: 0x200
              Vdiskfs.fex Len: 0x4
              BuildImg 0
              /opt/a33/a33_android_sdk/lichee/tools/pack/sun8iw5p1_android_vstar.img
              pack finish
              K 1 条回复 最后回复 回复 引用 分享 0
              • K
                kelsey LV 6 @cube_work 最后由 编辑
                @cube_work
                绝世好文,跟着一步一步果然OK了,这里也学到了一点👏 👏 👏
                1、下载 jdk-6u45-linux-x64.bin,解压到 /usr/java/ 目录这个操作
                需要在把 jdk-6u45-linux-x64.bin 解压到 /usr/java/ 目录之后,在 /usr/java/ 目录下执行
                sudo ./jdk-6u45-linux-x64.bin
                之后在 /usr/java/ 路径下既可看到 jdk-6u45-linux-x64的文件夹,
                2、之后再执行
                设置环境变量
                这里再附上下载的jdk-6u45-linux-x64.bin
