    运行eye-mpp 中的sample_odet_demo报错
    7
    6481
    • I
      ICpachong LV 5 最后由 编辑
      运行eye-mpp 中的sample_odet_demo报错,帮忙看看需要修改哪里。log如下:
      root@TinaLinux:~# ./sample_odet_demo
      I0101 01:07:26.883501  1217 dup2SeldomUsedFd.c:20]          <dup2SeldomUsedFdInit> gFdLock init
      main line 1879, run start!
      [0xb6f56560]vip_init[104],
      The version of Viplite is: 1.8.0-0-AW-2022-04-21
      [0xb6f56560]gcvip_os_call_kernel[344], fail to ioctl vipcore, command[0]:CMD_INIT, status=-2
      [0xb6f56560]gcvip_os_init[99], fail to call kernel for cmd init, status=-2.
      [0xb6f56560]gcvip_user_init[339], fail to initialize OS, status=-2.
      [0xb6f56560]gcvip_init[3479], failed to user init
      Error: sample_odet_demo/yolov3-tiny_nbg_viplite/main.c: odet_init at 227
      load_vipp_parameters line 137, run start!
      load_vipp_parameters line 211, run finish!
      mpp_init line 219, run start!
      I0101 01:07:26.956034  1217 mpi_sys.c:840]                  <AW_MPI_SYS_SetConf> kfctmpdir is [/tmp]
      >>>>>>>>>>>>>>>>>>>>>>>>>>>>> Media Process Platform<<<<<<<<<<<<<<<<<<<<<<<<<<<<
      modName : MPP-Platform
      tag   : V1.0 Release
      branch: v5-dev
      commit: 4eed413532ad87725895a8cb1ba75e22fc328233
      date  : 20170725
      author: jenkins
      iniparser: cannot open /etc/cedarx.conf
      iniparser: cannot open /vendor/etc/cedarx.conf
      I0101 01:07:26.960326  1217 mpi_sys.c:1280]                 <AW_MPI_SYS_Init> ISP init
      [ISP]>>>>>>>>>>>>>>>>>>>> ISP VERSION INFO <<<<<<<<<<<<<<<<<<<
      IPCORE: ISP600
      branch: libisp-dev
      commit: 14df8348718d093707641fea73eba7db962885f5
      date  : Thu Jul 14 15:40:38 2022 +0800
      I0101 01:07:26.961239  1217 mpi_sys.c:1282]                 <AW_MPI_SYS_Init> ISP init done
      INFO   : cedarc <VeInitialize:1185>: *** ic_version = 0x1302000023010,
      I0101 01:07:26.971323  1217 hwdisplay.c:84]                 <hw_display_init>
      I0101 01:07:26.971831  1217 hwdisplay.c:993]                <hwd_init> (hwd_init 993)
      I0101 01:07:26.972479  1217 hwdisplay.c:1048]               <hwd_init> ret[0][2,0]ch[2]lyl[0] init: enable[0], screenwin[0,0, 0x0], zorder[0], alpha[mode:0, value:0]
      I0101 01:07:26.973121  1217 alsa_interface.c:701]           <alsaOpenMixer> open mixer:hw:0
      I0101 01:07:26.979233  1217 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADC1 ADC2 swap
      I0101 01:07:26.979757  1217 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADC1 volume
      I0101 01:07:26.980278  1217 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADC2 volume
      I0101 01:07:26.980780  1217 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADCDRC
      I0101 01:07:26.981432  1217 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADCHPF
      I0101 01:07:26.981941  1217 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:DAC volume
      I0101 01:07:26.982416  1217 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:DACDRC
      I0101 01:07:26.983530  1217 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:DACHPF
      I0101 01:07:26.983962  1217 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEIN
      I0101 01:07:26.984780  1217 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEINL gain volume
      I0101 01:07:26.985854  1217 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEINR gain volume
      I0101 01:07:26.986367  1217 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEOUT
      I0101 01:07:26.987161  1217 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEOUT Output Select
      I0101 01:07:26.987677  1217 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEOUT volume
      I0101 01:07:26.988190  1217 alsa_interface.c:756]           <alsaOpenMixer> set playback vol_val to value: 27
      I0101 01:07:26.988677  1217 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC1
      I0101 01:07:26.989505  1217 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC1 Input Select
      I0101 01:07:26.990000  1217 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC1 gain volume
      I0101 01:07:26.990471  1217 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC2
      I0101 01:07:26.990960  1217 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC2 Input Select
      I0101 01:07:26.991932  1217 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC2 gain volume
      I0101 01:07:26.992735  1217 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:SPK
      I0101 01:07:26.993681  1217 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:digital volume
      I0101 01:07:26.994238  1217 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:rx sync mode
      I0101 01:07:26.995046  1217 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:tx hub mode
      E0101 01:07:26.995832  1217 alsa_interface.c:970]           <alsaMixerSetAudioCodecHubMode> aec_elem_audio_codec_hub_mode:tx hub mode-1
      E0101 01:07:26.996355  1217 alsa_interface.c:853]           <alsaMixerSetCapPlaySyncMode> aec_elem_sync_mode_switch:rx sync mode-1
      I0101 01:07:26.996936  1217 alsa_interface.c:701]           <alsaOpenMixer> open mixer:hw:1
      I0101 01:07:26.998519  1217 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:loopback debug
      I0101 01:07:26.999007  1217 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:rx sync mode
      I0101 01:07:26.999499  1217 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:tx hub mode
      E0101 01:07:27.000310  1217 alsa_interface.c:993]           <alsaMixerSetDAudio0HubMode> aec_elem_daudio0_hub_mode:tx hub mode-1
      E0101 01:07:27.000856  1217 alsa_interface.c:1016]          <alsaMixerSetDAudio0LoopBackEn> aec_elem_daudio0_loopback_en:loopback debug-1
      E0101 01:07:27.001342  1217 alsa_interface.c:853]           <alsaMixerSetCapPlaySyncMode> aec_elem_sync_mode_switch:rx sync mode-1
      mpp_init line 232, run finish!
      run_project line 1690, run start!
      I0101 01:07:27.002786  1217 hwdisplay.c:1248]               <hwd_get_disp_type> Current the  disp_type:0x0  tv_mode:0x0
      I0101 01:07:27.004058  1217 mpi_vo.c:837]                   <AW_MPI_VO_SetPubAttr> vo interface changed, [0x0, 0x1]->[0x40, 0x1]
      I0101 01:07:27.004617  1217 hwdisplay.c:1486]               <hwd_switch_vo_device> Current the  disp_type:0x0  tv_mode:0x0
      config_vipp_display2_vo line 1430, run start!
      config_vipp_display2_vo line 1453, vipp[4] vir_chn[0] creating.
      [ISP]video device name is vin_video4
      [ISP_ERR]video_init, line: 110,can not get entity by name vin_video4
      [ISP_ERR]isp_video_open, line: 468,error: unable to initialize video device.
      [ISP_ERR]isp_video_open, line: 487,unable to open video device[4]!
      E0101 01:07:27.536814  1217 videoInputHw.c:637]             <videoInputHw_ChnInit> error: isp video can not open, chn[4]!
      E0101 01:07:27.536981  1217 mpi_vi.c:170]                   <AW_MPI_VI_CreateVipp> initialize video input hardware failed!!
      config_vipp_display2_vo line 1459, fatal error! AW_MPI_VI CreateVipp:4 failed
      config_vipp_display2_vo line 1652, run finish!
      npu_worker_thread line 1676, run start!
      npu_config_and_run line 779, run start!
      npu_config_and_run line 802, vipp[0] vir_chn[1] creating.
      [ISP]video device name is vin_video0
      [ISP]open video device[0], detect isp0 success!
      I0101 01:07:27.538473  1220 media_debug.c:45]               <getDictByConfPath> MPP_DEDIA_DEBUG_FILE_PATH=(null)
      I0101 01:07:27.538810  1220 videoInputHw.c:1015]            <videoInputHw_SetChnAttr> ViCh[0], user set disable Encpp
      [ISP_ERR]isp_ir_reset, line: 639,isp0 device is NULL!
      run_project line 1748, fatal error! isp switch wdr[0] fail[-1].
      [ISP]video0 fd[10] ve_online_en=0, dma_buf_num=0
      [ISP]open isp device[0] success!
      [ISP_WARN]open /mnt/extsd/isp0_1920_1088_30_ctx_saved.bin failed, err:No such file or directory.
      [ISP]prefer isp config: [gc2053_mipi], 1920x1088, 30, 0, 0
      [ISP_WARN]cannot find gc2053_mipi_1920_1088_30_0_0 isp config, use gc2053_mipi_1920_1088_20_0_0 -> [gc2053_mipi_isp600_20220511_164617_vlc4_day]
      I0101 01:07:27.849592  1220 VideoVirVi_Component.c:1160]    <VideoViComponentInit> VideoVirvi component Init! thread_id[0xb6986d50]
      I0101 01:07:27.849816  1222 videoInputHw.c:4787]            <VideoInputHw_CapThread> loop VideoInputHw_CapThread vipp_id = 0, buf_num=5.
      [ISP_ERR]isp_stat_process_buffer, line: 268,AEWB: stats error, skipping buffer.
      I0101 01:07:28.043595  1220 hwdisplay.c:1121]               <hwd_layer_request_hlay> hlay:5, zorder=5, cnt:2
      I0101 01:07:28.043795  1220 mpi_vo.c:1038]                  <AW_MPI_VO_SetVideoLayerAttr> ch[1]lyl[1]:dispRect changed, [0, 0, 320x240]->[0, 0, 0x0]
      I0101 01:07:28.043898  1220 hwdisplay.c:409]                <hwd_layer_set_rect> ch[1]lyl[1]: screen_win[0,0, 0x0]
      npu_config_and_run line 912, create vo channel[0] success!
      [ISP_WARN]gc2053_mipi get sensor_temp failed: Invalid argument (22).
      [ISP_ERR]isp_sync_debug_info, line: 747,VIDIOC_VIN_ISP_GET_INFO error!
      [ISP]video device name is vin_video12
      [ISP]open video device[12], detect isp0 success!
      save_raw_picture line 758, virAddr[0]=[0xb69aa000], length=[173056].
      save_raw_picture line 758, virAddr[1]=[0xb69d4400], length=[86528].
      save_raw_picture line 765, store raw frame in file[/mnt/sdcard/pic[0-416x416].nv12].
      Usage:
          nbg_name input_data1 input_data2...
      Segmentation fault (core dumped)
        WhycanService LV 8 最后由 编辑
        @icpachong 在 运行eye-mpp 中的sample_odet_demo报错 中说:
        Usage:
        调用npu时候错误,检查模型文件缓存文件的路径是否正确是否
        I 2 条回复 最后回复 回复 引用 分享 0
        • I
          ICpachong LV 5 @WhycanService 最后由 编辑
          @whycanservice
          如果这里不改的话会报如下错误
          npu_config_and_run line 808, fatal error! AW_MPI_VI CreateVipp:8 failed
          • I
            @whycanservice 模型文件的路径是正确的。
            请问您运行过这个例程吗?需要做哪些修改?
            N 1 条回复 最后回复 回复 引用 分享 0
            • N
              NULL037 LV 7 @ICpachong 最后由 编辑
              @icpachong 您好,请问您解决了吗?
              I 1 条回复 最后回复 回复 引用 分享 0
              • I
                ICpachong LV 5 @NULL037 最后由 编辑
                @null037 可以确定这个例程有问题,经过修改程序可以运行了,但是还有问题待修复。
                还是希望AW能发布经过测试的例程,避免大家无谓的踩坑。
                F 1 条回复 最后回复 回复 引用 分享 0
                • F
                  feidedao LV 3 @ICpachong 最后由 编辑
                  @icpachong 请问怎么更改才能正常运行呢
