    请教各位大佬,D1的start.s __start部分是参考哪里怎么实现的? 还有dram.c又是从那里得到的这些数据,最后的mksunxi 也是搞不懂依据在哪
    • baiwen
      100ask LV 6 最后由 编辑
      最近在使用D1s录制RISC-V体系架构与C编程的课程,参考xboot作者的裸机实验(一直联系不到作者本人),目前可以直接烧录在DongshanPI-D1s spinor上运行,但是有几个问题 不明所以,不知道到底是怎么得来的,有懂的大佬能帮忙解析一下么?
      https://github.com/DongshanPI/DongshanPI-D1s_BareMetal/tree/master/source/start.S
      https://github.com/DongshanPI/DongshanPI-D1s_BareMetal/tree/master/source/sys-dram.c
      https://github.com/DongshanPI/DongshanPI-D1s_BareMetal/blob/master/source/tools/mksunxi.c
      #include <string.h>
      #include <stdint.h>
      #include <stdlib.h>
      #if 0
      static inline uint32_t __swab32(uint32_t x)
      	return ( (x<<24) | (x>>24) | \
      		((x & (uint32_t)0x0000ff00UL)<<8) | \
      		((x & (uint32_t)0x00ff0000UL)>>8) );
      #define cpu_to_le32(x)	(__swab32((uint32_t)(x)))
      #define le32_to_cpu(x)	(__swab32((uint32_t)(x)))
      #else
      #define cpu_to_le32(x)	(x)
      #define le32_to_cpu(x)	(x)
      struct boot_head_t {
      	uint32_t instruction;
      	uint8_t magic[8];
      	uint32_t checksum;
      	uint32_t length;
      	uint8_t spl_signature[4];
      	uint32_t fel_script_address;
      	uint32_t fel_uenv_length;
      	uint32_t dt_name_offset;
      	uint32_t reserved1;
      	uint32_t boot_media;
      	uint32_t string_pool[13];
      int main (int argc, char *argv[])
      	struct boot_head_t * h;
      	FILE * fp;
      	char * buffer;
      	int buflen, filelen;
      	uint32_t * p;
      	uint32_t sum;
      	int i, l, loop;
      	if(argc != 2)
      		printf("Usage: mksunxi <bootloader>\n");
      		return -1;
      	fp = fopen(argv[1], "r+b");
      	if(fp == NULL)
      		printf("Open bootloader error\n");
      		return -1;
      	fseek(fp, 0L, SEEK_END);
      	filelen = ftell(fp);
      	fseek(fp, 0L, SEEK_SET);
      	if(filelen <= sizeof(struct boot_head_t))
      		fclose(fp);
      		printf("The size of bootloader too small\n");
      		return -1;
      	buflen = (filelen + 0x2000) & ~(0x2000 - 1);
      	buffer = malloc(buflen);
      	memset(buffer, 0, buflen);
      	if(fread(buffer, 1, filelen, fp) != filelen)
      		printf("Can't read bootloader\n");
      		free(buffer);
      		fclose(fp);
      		return -1;
      	h = (struct boot_head_t *)buffer;
      	p = (uint32_t *)h;
      	l = le32_to_cpu(h->length);
      	h->checksum = cpu_to_le32(0x5F0A6C39);
      	loop = l >> 2;
      	for(i = 0, sum = 0; i < loop; i++)
      		sum += le32_to_cpu(p[i]);
      	h->checksum = cpu_to_le32(sum);
      	if(fwrite(buffer, 1, buflen, fp) != buflen)
      		printf("Write bootloader error\n");
      		free(buffer);
      		fclose(fp);
      		return -1;
      	fclose(fp);
      	printf("The bootloader head has been fixed\n");
        柚木 鉉 LV 9 最后由 YuzukiTsuru 编辑
        首先是 eGON.BT0,这个Magic是BROM读取的,所以要在头部插入eGON.BT0
        这是使用mctl_hal.S和自己写的一个小裸机编译出的bin,mctl_hal.S全志的sdk里开源了,这个小裸机源码如下 6ee6e31c-72ef-47f5-b69f-0976197bb46a-d1-ddr.zip
        这个是对齐后重新计算校验码的,然后填充在固定的位置让BROM读取,全志系列的老传统了,你看_start那里的checksum只是一个占位符0x12345678,mksunxi就是会对齐块设备然后计算校验填入然后修改长度
        https://github.com/YuzukiHD/TinyKasKit/blob/master/sunxiboot/src/bootpack.cpp
