    求助,自己做的V536H板子无法下载程序
    代码下载问题专区
    7608
    • jinxiangwzh
      jinxiangwzh LV 7 最后由 编辑
      界面移植卡在这个位置,看不到log输出,请问怎么排查问题,另外请问除了使用USB下载程序外,还有哪几种方式可以下载?
        whycan晕哥 LV 9 @jinxiangwzh 最后由 编辑
        @jinxiangwzh
        接上串口线看日志
        • jinxiangwzh
          jinxiangwzh LV 7 @whycan 最后由 编辑
          @whycan 一次代码没刷过可以打印日志吗?接着串口USART0呢 没打印,难道串口也有问题吗
            @jinxiangwzh
            可以看到为什么烧不进去
              DOT小文哥 LV 8 最后由 编辑
              还有debugview也可以看下
              jinxiangwzh 2 条回复 最后回复 回复 引用 分享 0
              • jinxiangwzh
                jinxiangwzh LV 7 @xiaowenge 最后由 编辑
                • jinxiangwzh
                  @xiaowenge [7504] 大哥 帮忙看看,用你说的工具打印的
                  [7504] current adb path:  D:\platform-tools\
                  [7504] ****************load:
                  [7504] ImgDecode64.dll
                  [7504]
                  [7504] ImgDecode32.dll
                  [7504]
                  [7504] m_FesParser.SetImagePath .\LiveProcMan.cpp 362 113
                  [7504] no use interface !
                  [7504] m_FesParser.SetInterface .\LiveProcMan.cpp 371 249 2
                  [7504] Initial .\LiveProcMan.cpp 244 InitialFesParser failed 249
                  [7504] Read key value from registry failed.
                  [7504] Img_OpenItem now!
                  [7504] Img_OpenItem[PXTOOLSB][XXXXXXXXXXXXXXXX]
                  [7504] Closing image now!
                  [7504] CloseImage OK
                  [7504] The spec_tool.fex file is spec_tool_no.fex.
                  [7504] The spec_tool  file is not exist.
                  [7504] ImageTools64 .\image\ASuitImage.cpp 572 0
                  [7504] Img_OpenItem[12345678][1234567890DLINFO]
                  [7504] D:\platform-tools\adb.exe devices
                  [7504] No deivce Attached!!!!!!!!!!!!
                  [7504] IN 1
                  [7504] PnpFelIn  current m_tools_if is NULL
                  [7504] **************************************
                  [7504] *********global_info_entry***********
                  [7504] ********* before Fel2Fes *********
                  [7504] ********* pFel2FesParam->extend = 0xefe8da00 *********
                  [7504] ***************************************
                  [7504] ********ToolEntry_fel************
                  [7504] PANIC : enter fel choose mode
                  [7504] fel other=0x20a4b0
                  [7504] OS SourceCodePage = 936
                  [7504] WRN: fail in LoadPluginCenter, f(IniLanPlg)L45
                  [7504] WRN: f(exist_multiple_lang_tips)L94, Fail to init plg of iniLan, "Please update LiveSuit"
                  [7504] user choose to erase=1
                  [7504] Img_OpenItem[FES     ][FES_1-0000000000]
                  [7504] down file length = a580.
                  [7504] magic eGON.BT0
                  [7504] ?髝? it is fes1
                  [7504] down and run fes1 at addr 0x28000
                  [7504] Clear dram log OK.
                  [7504] DOWN FES1_dram OK
                  [7504] RUN fes1 OK.
                  [7504] INFO: try to down and run fes2
                  [7504] Img_OpenItem[12345678][UBOOT_0000000000]
                  [7504] fes2 size 0x198000
                  [7504] uboot down and run addr 0x43100000
                  [7504] dtb_syscfg_base 0x43300000
                  • jinxiangwzh
                    左边是开发板的正常log,右边是我们板子的log,请问这是什么问题?我们板子更改了RAM和emmc,请问是不是跟这个有关系?需要做哪些适配
                    • jinxiangwzh
                      @whycan 哥 帮我看看log呗
                        @jinxiangwzh
                        DDR芯片是同一个型号吗?
                        • jinxiangwzh
                          @whycan 不是 换了,固件配置是不是需要修改?
