    麻雀开发板,spinand烧录问题,PhoenixSuit识别不到设备
    10445
      wjp2547532 LV 6 最后由 编辑
      自己焊接了一个nand到开发板,上电后设备管理器里可以正常识别设备,但是PhoenixSuit软件显示无设备连接,nand型号也在支持的列表里22222.png 11111.jpg
      哪里没搞对,可以指导一下么
        是不是全志官方的驱动?
        W 1 条回复 最后回复 回复 引用 分享 0
          wjp2547532 LV 6 @whycan 最后由 编辑
          @whycan 是的
            whycan晕哥 LV 9 @wjp2547532 最后由 编辑
            @wjp2547532
            怎么识别不到的?
            W 3 条回复 最后回复 回复 引用 分享 0
              wjp2547532 LV 6 @whycan 最后由 xiaowenge 编辑
              @whycan
              无设备连接
                @whycan 对PhoenixSuit的版本没啥要求吧?
                  wjp2547532 LV 6 @whycan 最后由 whycan 编辑
                  @whycan 晕哥,现在PhoenixSuit可以识别到设备(我下载了APST,打开APST的时候就能识别到设备,不知道为啥),但是烧写失败
                  24242]fes begin commit:27369ab
                  [24244]set pll start
                  [24247]periph0 has been enabled
                  [24250]set pll end
                  [24251][pmu]: bus read error
                  [24254]board init ok
                  [24256]beign to init dram
                  [24258]ZQ value = 0x2f***********
                  [24261]get_pmu_exist() = -1
                  [24264]ddr_efuse_type: 0xa
                  [24267][AUTO DEBUG] single rank and full DQ!
                  [24271]ddr_efuse_type: 0xa
                  [24274][AUTO DEBUG] rank 0 row = 13
                  [24277][AUTO DEBUG] rank 0 bank = 4
                  [24281][AUTO DEBUG] rank 0 page size = 2 KB
                  [24285]DRAM BOOT DRIVE INFO: V0.24
                  [24288]DRAM CLK = 528 MHz
                  [24290]DRAM Type = 2 (2:DDR2,3:DDR3)
                  [24294]DRAMC read ODT  off.
                  [24296]DRAM ODT off.
                  [24298]ddr_efuse_type: 0xa
                  [24301]DRAM SIZE =64 M
                  [24305]DRAM simple test OK.
                  [24308]init dram ok
                  U-Boot 2018.05-g0a88ac9-config-dirty (Nov 10 2022 - 09:43:39 +0800) Allwinner Technology
                  [27.334]DRAM:  64 MiB
                  [27.339]Relocation Offset is: 01ef0000
                  [27.368]secure enable bit: 0
                  [27.372]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
                  [27.378]flash init start
                  [27.381]workmode = 16,storage type = 0
                  try card 2
                  set card number 2
                  get card number 2
                  [27.388][mmc]: mmc driver ver uboot2018:2021-04-16 14:23:00-1
                  [27.398][mmc]: get sdc_type fail and use default host:tm4.
                  [27.428][mmc]: Is not Boot mode!
                  [27.431][mmc]: SUNXI SDMMC Controller Version:0x50310
                  [27.442][mmc]: ************Try SD card 2************
                  [27.447][mmc]: mmc 2 cmd timeout 100 status 100
                  [27.451][mmc]: smc 2 err, cmd 8,  RTO
                  [27.455][mmc]: mmc 2 close bus gating and reset
                  [27.460][mmc]: mmc 2 cmd timeout 100 status 100
                  [27.464][mmc]: smc 2 err, cmd 55,  RTO
                  [27.468][mmc]: mmc 2 close bus gating and reset
                  [27.472][mmc]: ************Try MMC card 2************
                  [27.481][mmc]: mmc 2 cmd timeout 100 status 100
                  [27.485][mmc]: smc 2 err, cmd 1,  RTO
                  [27.488][mmc]: mmc 2 close bus gating and reset
                  [27.492][mmc]: Card did not respond to voltage select!
                  [27.497][mmc]: ************SD/MMC 2 init error!************
                  [27.503][mmc]: mmc init product failed
                  MMC init failed
                  try emmc fail
                  [27.518]sunxi-spinand: AW SPINand MTD Layer Version: 1.5 20200407
                  [27.524]sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.9 20200306
                  [27.584]sunxi-spinand-phy: request spi0 gpio ok
                  [27.588]sunxi-spinand-phy: request general tx dma channel ok!
                  [27.593]sunxi-spinand-phy: request general rx dma channel ok!
                  [27.599]sunxi-spinand-phy: set spic0 clk to 20 Mhz
                  [27.603]sunxi-spinand-phy: init spic0 clk ok
                  [27.607]sunxi-spinand-phy: not detect any munufacture from id table
                  [27.623]sunxi-spinand-phy: get spi-nand Model from fdt fail
                  [27.628]sunxi-spinand-phy: get phy info from fdt fail
                  [27.633]sunxi-spinand-phy: not detect munufacture from fdt
                  [27.638]sunxi-spinand-phy: detect munufacture from id table: Winbond
                  [27.644]sunxi-spinand-phy: detect spinand id: ff21aaef ffffffff
                  [27.649]sunxi-spinand-phy: ========== arch info ==========
                  [27.655]sunxi-spinand-phy: Model:               W25N01GVZEIG
                  [27.660]sunxi-spinand-phy: Munufacture:         Winbond
                  [27.665]sunxi-spinand-phy: DieCntPerChip:       1
                  [27.669]sunxi-spinand-phy: BlkCntPerDie:        1024
                  [27.674]sunxi-spinand-phy: PageCntPerBlk:       64
                  [27.679]sunxi-spinand-phy: SectCntPerPage:      4
                  [27.683]sunxi-spinand-phy: OobSizePerPage:      64
                  [27.688]sunxi-spinand-phy: BadBlockFlag:        0x0
                  [27.692]sunxi-spinand-phy: OperationOpt:        0x7
                  [27.697]sunxi-spinand-phy: MaxEraseTimes:       65000
                  [27.701]sunxi-spinand-phy: EccFlag:             0x0
                  [27.706]sunxi-spinand-phy: EccType:             2
                  [27.711]sunxi-spinand-phy: EccProtectedType:    3
                  [27.715]sunxi-spinand-phy: ========================================
                  [27.721]sunxi-spinand-phy:
                  [27.723]sunxi-spinand-phy: ========== physical info ==========
                  [27.729]sunxi-spinand-phy: TotalSize:    128 M
                  [27.733]sunxi-spinand-phy: SectorSize:   512 B
                  [27.737]sunxi-spinand-phy: PageSize:     2 K
                  [27.741]sunxi-spinand-phy: BlockSize:    128 K
                  [27.745]sunxi-spinand-phy: OOBSize:      64 B
                  [27.750]sunxi-spinand-phy: ========================================
                  [27.755]sunxi-spinand-phy:
                  [27.758]sunxi-spinand-phy: ========== logical info ==========
                  [27.763]sunxi-spinand-phy: TotalSize:    128 M
                  [27.768]sunxi-spinand-phy: SectorSize:   512 B
                  [27.772]sunxi-spinand-phy: PageSize:     4 K
                  [27.776]sunxi-spinand-phy: BlockSize:    256 K
                  [27.780]sunxi-spinand-phy: OOBSize:      128 B
                  [27.784]sunxi-spinand-phy: ========================================
                  [27.800]sunxi-spinand-phy: W25N01GVZEIG reset rx bit width to 1
                  [27.805]sunxi-spinand-phy: W25N01GVZEIG reset tx bit width to 1
                  [27.811]sunxi-spinand-phy: set spic0 clk to 100 Mhz
                  [27.815]sunxi-spinand-phy: block lock register: 0x00
                  [27.820]sunxi-spinand-phy: feature register: 0x19
                  [27.825]sunxi-spinand-phy: sunxi physic nand init end
                  [27.834]Loading Environment from SUNXI_FLASH... OK
                  [27.842]try to burn key
                  [27.846]out of usb burn from boot: not need burn key
                  sunxi work mode=0x10
                  run usb efex
                  delay time 2500
                  weak:otg_phy_config
                  usb init ok
                  set address 0xa
                  set address 0xa ok
                  set address 0xb
                  set address 0xb ok
                  晕哥帮忙看一下可能是啥原因,我做的烧写包有问题么?
                    @wjp2547532
                    试一试这个固件: (8.8寸长条形烧录固件)tina_t113-whycanpij_uart3.img
                      @whycan 这个固件也不行,D1s可以用这个固件?晕哥,你那里有现成的D1s麻雀的spi-nand的固件么,我想先验证一下烧写有没有问题
                        whycan晕哥 LV 9 @wjp2547532 最后由 whycan 编辑
                        @wjp2547532
                        D1s SPI NAND 固件: tina_d1s-whycanpij_uart3(HSD088测试固件).img
                        原理图: https://oshwhub.com/GloomyGhost/34e1fe88b79f49b891df150db9c34cc4
                          @whycan 好的晕哥,谢谢,我去试一下
                          K 1 条回复 最后回复 回复 引用 分享 0
                          • K
                            kelsey LV 6 @wjp2547532 最后由 编辑
                            @wjp2547532 烧录的log目前是所有的log了吗?已经烧录的进度目前是卡在了多少呢
                              wjp2547532 LV 6 @kelsey 最后由 编辑
                              @kelsey 已经可以烧录了,应该是PC端驱动的问题,换了一台电脑重新安装软件后可以识别设备并烧录了,谢谢大佬关心
