    T113 Tina 自带的LVGL8 G2D Test运行报错
    9
    8039
    • F
      fantasya LV 4 最后由 编辑
      使用的是芒果提供的Tina系统,lv_example下所有的包全部勾选了,然后编译运行会报错
      已经修改资源的路径,加了一些printf查看config
      下面是运行日志
      root@TinaLinux:/# lv_g2d_test 0 0 0 0
      use double buffer
      use g2d
      use g2d rotate
      use lv g2d debug
      use lv g2d fill
      use lv g2d blit
      use lv g2d blend
      use lv g2d scale
      lv_g2d_test 0 5 0 1
      one num is rotate, range is 0~3
      tow num is gif, range is 0~11, 11 is no show gif
      three num is bmp, range is 0~2, 2 is no show bmp
      four num is png, range is 0~3, 3 is no show png
      wh=800x480, vwh=800x480, bpp=32, rotated=0
      Segmentation fault
      root@TinaLinux:/# ls /mnt/UDISK/lv_g2d_test/
      root@TinaLinux:/# ls /dev/
      bus              i2c-2            mmcblk0p6        sunxi-reg
      by-name          input            mmcblk0p7        sunxi-wlan
      cedar_dev        ion              mmcblk0p8        tty
      console          kmsg             null             ttyS3
      cpu_dma_latency  mmcblk0          ptmx             ubi_ctrl
      disp             mmcblk0p1        pts              udmabuf
      fb0              mmcblk0p2        random           urandom
      full             mmcblk0p3        rfkill           usb-ffs
      g2d              mmcblk0p4        shm              zero
      gpiochip0        mmcblk0p5        snd
      int main(int argc, char *argv[]) {
      #ifdef USE_SUNXIFB_DOUBLE_BUFFER
          printf("use double buffer\n");
      #ifdef USE_SUNXIFB_G2D
          printf("use g2d\n");
      #ifdef USE_SUNXIFB_G2D_ROTATE
          printf("use g2d rotate\n");
      #ifdef LV_USE_SUNXIFB_DEBUG
          printf("use lv g2d debug\n");
      #ifdef LV_USE_SUNXIFB_G2D_FILL
          printf("use lv g2d fill\n");
      #ifdef LV_USE_SUNXIFB_G2D_BLIT
          printf("use lv g2d blit\n");
      * 列表
      #ifdef LV_USE_SUNXIFB_G2D_BLEND
          printf("use lv g2d blend\n");
      #ifdef LV_USE_SUNXIFB_G2D_SCALE
          printf("use lv g2d scale\n");
          lv_disp_drv_t disp_drv;
          lv_disp_draw_buf_t disp_buf;
          lv_indev_drv_t indev_drv;
          uint32_t rotated = LV_DISP_ROT_NONE;
          uint32_t gif_index = 5, bmp_index = 0, png_index = 1;
          char *gif_path[] = { "A:/mnt/UDISK/lv_g2d_test/240x320.gif",
                  "A:/mnt/UDISK/lv_g2d_test/313x235.gif",
                  "A:/mnt/UDISK/lv_g2d_test/320x480.gif",
                  "A:/mnt/UDISK/lv_g2d_test/409x409.gif",
                  "A:/mnt/UDISK/lv_g2d_test/658x494.gif",
                  "A:/mnt/UDISK/lv_g2d_test/800x480.gif",
                  "A:/mnt/UDISK/lv_g2d_test/800x600.gif",
                  "A:/mnt/UDISK/lv_g2d_test/800x1280.gif",
                  "A:/mnt/UDISK/lv_g2d_test/1280x720.gif",
                  "A:/mnt/UDISK/lv_g2d_test/1280x800.gif",
                  "A:/mnt/UDISK/lv_g2d_test/1920x1080.gif",
                  "A:/mnt/UDISK/lv_g2d_test/no.gif" };
          char *bmp_path[] = { "A:/mnt/UDISK/lv_g2d_test/512x352.bmp",
                  "A:/mnt/UDISK/lv_g2d_test/800x480.bmp",
                  "A:/mnt/UDISK/lv_g2d_test/no.bmp" };
          char *png_path[] = { "A:/mnt/UDISK/lv_g2d_test/47x48.png",
                  "A:/mnt/UDISK/lv_g2d_test/225x111.png",
                  "A:/mnt/UDISK/lv_g2d_test/241x148.png",
                  "A:/mnt/UDISK/lv_g2d_test/no.png"};
      M N 2 条回复 最后回复 回复 引用 分享 0
        memory LV 7 @fantasya 最后由 编辑
        @fantasya 在 T113 Tina 自带的LVGL8 G2D Test运行报错 中说:
        Segmentation fault
        我的也出现一样的问题,请问楼主解决了吗?
        T 1 条回复 最后回复 回复 引用 分享 0
        • N
          name_10____231 LV 3 @fantasya 最后由 编辑
          @fantasya 楼主解决了吗?我也是这个问题,但是lv_examples可以正常运行,另外按照V853的教程移植lv_100ask_2048运行也是段错误😟 关键是教程里的路径跟T113 Tina的路径不一至,也不知道具体哪里的问题 😟
          H B 2 条回复 最后回复 回复 引用 分享 0
            huerli LV 3 @name_10____231 最后由 编辑
            @name_10____231
            解决了吗,同问
            • B
              barsonsss LV 3 最后由 编辑
              问一下楼主解决了吗
              • B
                barsonsss LV 3 @name_10____231 最后由 编辑
                @name_10____231 您好,问一下现在解决了吗,我也遇到这个问题了
                • Moved from Linux by  xiaowenge xiaowenge
                • T
                  tivon LV 6 @memory 最后由 编辑
                  @memory 请问解决的吗,我也遇到了。
                  • T
                    tivon LV 6 最后由 编辑
                    已经解决,设备树中 &disp , fb0_buffer_num= <2>; 就可以了
                    J 1 条回复 最后回复 回复 引用 分享 0
                      jiwmu LV 2 @tivon 最后由 编辑
                      @tivon 感谢帮助!
