    V853怎么配置单目摄像头?
    • N
      Negro LV 5 最后由 编辑
      V853做的板子,buildroot系统,要适配一个gc2503 4land的单目摄像头,,看了文档都是双目的,弄了好久没有弄出图像来,不知道怎么搞了,求指导。以下是做过的操作:
      1、DTS的vind节点如下:
                    vind0:vind@0 {
      			vind0_clk = <200000000>;
      	                 csi2:csi@2 {
                                    pinctrl-0 = <&ncsi_pins_a>;
                                    pinctrl-1 = <&ncsi_pins_b>;
                                    status = "disabled";
      		/*offline mode*/
                   tdm0:tdm@0 {
                       work_mode = <1>;
                   isp00:isp@0 {
                       work_mode = <1>;
                   scaler00:scaler@0 {
                       work_mode = <1>;
                   scaler10:scaler@4 {
                       work_mode = <1>;
                   scaler20:scaler@8 {
                       work_mode = <1>;
                   scaler30:scaler@12 {
                       work_mode = <1>;
      			actuator0:actuator@0 {
      				device_type = "actuator0";
      				actuator0_slave = <0x18>;
      				actuator0_af_pwdn = <>;
      			flash0:flash@0 {
      				device_type = "flash0";
      				flash0_type = <2>;
      				flash0_en = <>;
      				flash0_mode = <>;
      				flash0_flvdd = "";
      				flash0_flvdd_vol = <>;
      			sensor0:sensor@0 {
      				device_type = "sensor0";
      				sensor0_mname = "gc2053_mipi";
      				sensor0_twi_cci_id = <1>;
      				sensor0_twi_addr = <0x6e>;
      				sensor0_mclk_id = <0>;
      				sensor0_pos = "rear";
      				sensor0_isp_used = <1>;
      				sensor0_fmt = <1>;
      				sensor0_stby_mode = <0>;
      				sensor0_vflip = <0>;
      				sensor0_hflip = <0>;
      				sensor0_iovdd-supply = <&reg_bldo1>;
      				sensor0_iovdd_vol = <1800000>;
      				sensor0_avdd-supply = <&reg_bldo2>;
      				sensor0_avdd_vol = <2800000>;
      				sensor0_dvdd-supply = <&reg_dldo2>;
      				sensor0_dvdd_vol = <1200000>;
      				sensor0_power_en = <>;
      				sensor0_reset = <&pio PA 18 1 0 1 0>;
      				sensor0_pwdn = <&pio PA 19 1 0 1 0>;
      				sensor0_sm_hs = <>;
      				sensor0_sm_vs = <>;
      				flash_handle = <&flash0>;
      				act_handle = <&actuator0>;
      				status	= "okay";
      			/* sensor1:sensor@1 {
      			 *     device_type = "sensor1";
      			 *     sensor1_mname = "gc2053_mipi_2";
      			 *     sensor1_twi_cci_id = <0>;
      			 *     sensor1_twi_addr = <0x7f>;
      			 *     sensor1_mclk_id = <1>;
      			 *     sensor1_pos = "front";
      			 *     sensor1_isp_used = <1>;
      			 *     sensor1_fmt = <1>;
      			 *     sensor1_stby_mode = <0>;
      			 *     sensor1_vflip = <0>;
      			 *     sensor1_hflip = <0>;
      			 *     sensor1_iovdd-supply = <&reg_aldo2>;
      			 *     sensor1_iovdd_vol = <1800000>;
      			 *     sensor1_avdd-supply = <&reg_bldo2>;
      			 *     sensor1_avdd_vol = <2800000>;
      			 *     sensor1_dvdd-supply = <&reg_dldo2>;
      			 *     sensor1_dvdd_vol = <1200000>;
      			 *     sensor1_power_en = <>;
      			 *     sensor1_reset = <&pio PA 20 1 0 1 0>;
      			 *     sensor1_pwdn = <&pio PA 21 1 0 1 0>;
      			 *     sensor1_sm_hs = <>;
      			 *     sensor1_sm_vs = <>;
      			 *     flash_handle = <>;
      			 *     act_handle = <>;
      			 *     status	= "okay";
      			vinc00:vinc@0 {
      				vinc0_csi_sel = <0>;
      				vinc0_mipi_sel = <0>;
      				vinc0_isp_sel = <0>;
      				vinc0_isp_tx_ch = <0>;
      				vinc0_tdm_rx_sel = <0>;
      				vinc0_rear_sensor_sel = <0>;
      				vinc0_front_sensor_sel = <0>;
      				vinc0_sensor_list = <0>;
      				work_mode = <0x1>;
      			vinc01:vinc@1 {
      				vinc1_csi_sel = <1>;
      				vinc1_mipi_sel = <1>;
      				vinc1_isp_sel = <1>;
      				vinc1_isp_tx_ch = <0>;
      				vinc1_tdm_rx_sel = <1>;
      				vinc1_rear_sensor_sel = <1>;
      				vinc1_front_sensor_sel = <1>;
      				vinc1_sensor_list = <0>;
      			vinc02:vinc@2 {
      				vinc2_csi_sel = <2>;
      				vinc2_mipi_sel = <0xff>;
      				vinc2_isp_sel = <2>;
      				vinc2_isp_tx_ch = <2>;
      				vinc2_tdm_rx_sel = <2>;
      				vinc2_rear_sensor_sel = <0>;
      				vinc2_front_sensor_sel = <0>;
      				vinc2_sensor_list = <0>;
      			vinc03:vinc@3 {
      				vinc3_csi_sel = <0>;
      				vinc3_mipi_sel = <0xff>;
      				vinc3_isp_sel = <0>;
      				vinc3_isp_tx_ch = <0>;
      				vinc3_tdm_rx_sel = <0>;
      				vinc3_rear_sensor_sel = <1>;
      				vinc3_front_sensor_sel = <1>;
      				vinc3_sensor_list = <0>;
      			vinc10:vinc@4 {
      				vinc4_csi_sel = <0>;
      				vinc4_mipi_sel = <0>;
      				vinc4_isp_sel = <0>;
      				vinc4_isp_tx_ch = <0>;
      				vinc4_tdm_rx_sel = <0>;
      				vinc4_rear_sensor_sel = <0>;
      				vinc4_front_sensor_sel = <0>;
      				vinc4_sensor_list = <0>;
      				work_mode = <0x1>;
      			vinc11:vinc@5 {
      				vinc5_csi_sel = <1>;
      				vinc5_mipi_sel = <1>;
      				vinc5_isp_sel = <1>;
      				vinc5_isp_tx_ch = <0>;
      				vinc5_tdm_rx_sel = <1>;
      				vinc5_rear_sensor_sel = <1>;
      				vinc5_front_sensor_sel = <1>;
      				vinc5_sensor_list = <0>;
      			vinc12:vinc@6 {
      				vinc6_csi_sel = <2>;
      				vinc6_mipi_sel = <0xff>;
      				vinc6_isp_sel = <0>;
      				vinc6_isp_tx_ch = <0>;
      				vinc6_tdm_rx_sel = <0>;
      				vinc6_rear_sensor_sel = <0>;
      				vinc6_front_sensor_sel = <0>;
      				vinc6_sensor_list = <0>;
      			vinc13:vinc@7 {
      				vinc7_csi_sel = <2>;
      				vinc7_mipi_sel = <0xff>;
      				vinc7_isp_sel = <0>;
      				vinc7_isp_tx_ch = <0>;
      				vinc7_tdm_rx_sel = <0>;
      				vinc7_rear_sensor_sel = <0>;
      				vinc7_front_sensor_sel = <0>;
      				vinc7_sensor_list = <0>;
      			vinc20:vinc@8 {
      				vinc8_csi_sel = <0>;
      				vinc8_mipi_sel = <0>;
      				vinc8_isp_sel = <0>;
      				vinc8_isp_tx_ch = <0>;
      				vinc8_tdm_rx_sel = <0>;
      				vinc8_rear_sensor_sel = <0>;
      				vinc8_front_sensor_sel = <0>;
      				vinc8_sensor_list = <0>;
      				work_mode = <1>;
      			vinc21:vinc@9 {
      				vinc9_csi_sel = <2>;
      				vinc9_mipi_sel = <0xff>;
      				vinc9_isp_sel = <0>;
      				vinc9_isp_tx_ch = <0>;
      				vinc9_tdm_rx_sel = <0>;
      				vinc9_rear_sensor_sel = <0>;
      				vinc9_front_sensor_sel = <0>;
      				vinc9_sensor_list = <0>;
      			vinc22:vinc@10 {
      				vinc10_csi_sel = <2>;
      				vinc10_mipi_sel = <0xff>;
      				vinc10_isp_sel = <0>;
      				vinc10_isp_tx_ch = <0>;
      				vinc10_tdm_rx_sel = <0>;
      				vinc10_rear_sensor_sel = <0>;
      				vinc10_front_sensor_sel = <0>;
      				vinc10_sensor_list = <0>;
      			vinc23:vinc@11 {
      				vinc11_csi_sel = <2>;
      				vinc11_mipi_sel = <0xff>;
      				vinc11_isp_sel = <0>;
      				vinc11_isp_tx_ch = <0>;
      				vinc11_tdm_rx_sel = <0>;
      				vinc11_rear_sensor_sel = <0>;
      				vinc11_front_sensor_sel = <0>;
      				vinc11_sensor_list = <0>;
      			vinc30:vinc@12 {
      				vinc12_csi_sel = <0>;
      				vinc12_mipi_sel = <0x0>;
      				vinc12_isp_sel = <0>;
      				vinc12_isp_tx_ch = <0>;
      				vinc12_tdm_rx_sel = <0>;
      				vinc12_rear_sensor_sel = <0>;
      				vinc12_front_sensor_sel = <0>;
      				vinc12_sensor_list = <0>;
      				work_mode = <0x1>;
      			vinc31:vinc@13 {
      				vinc13_csi_sel = <2>;
      				vinc13_mipi_sel = <0xff>;
      				vinc13_isp_sel = <0>;
      				vinc13_isp_tx_ch = <0>;
      				vinc13_tdm_rx_sel = <0>;
      				vinc13_rear_sensor_sel = <0>;
      				vinc13_front_sensor_sel = <0>;
      				vinc13_sensor_list = <0>;
      			vinc32:vinc@14 {
      				vinc14_csi_sel = <2>;
      				vinc14_mipi_sel = <0xff>;
      				vinc14_isp_sel = <0>;
      				vinc14_isp_tx_ch = <0>;
      				vinc14_tdm_rx_sel = <0>;
      				vinc14_rear_sensor_sel = <0>;
      				vinc14_front_sensor_sel = <0>;
      				vinc14_sensor_list = <0>;
      			vinc33:vinc@15 {
      				vinc15_csi_sel = <2>;
      				vinc15_mipi_sel = <0xff>;
      				vinc15_isp_sel = <0>;
      				vinc15_isp_tx_ch = <0>;
      				vinc15_tdm_rx_sel = <0>;
      				vinc15_rear_sensor_sel = <0>;
      				vinc15_front_sensor_sel = <0>;
      				vinc15_sensor_list = <0>;
      2、将模块放到板上insmod。可以出来/dev/video0节点
      Octops:/server/camera# ls
      csi_test_mplane          v4l2_demo                videobuf2-v4l2.ko
      da380.ko                 videobuf2-core.ko        vin_io.ko
      gc2053_mipi.ko           videobuf2-dma-contig.ko  vin_v4l2.ko
      ism.sh                   videobuf2-memops.ko
      Octops:/server/camera# cat ism.sh
      insmod videobuf2-core.ko
      insmod videobuf2-memops.ko
      insmod videobuf2-dma-contig.ko
      insmod videobuf2-v4l2.ko
      insmod vin_io.ko
      insmod gc2053_mipi.ko
      insmod  vin_v4l2.ko
      Octops:/server/camera# ./ism.sh
      [   90.451429] [VIN_WARN]sensor_helper_probe: cannot get sensor0_cameravdd supply, setting it to NULL!
      Octops:/server/camera# ls -l /dev/video0
      crw-rw----    1 root     video      81,   0 Jan  1 01:51 /dev/video0
      3、执行csi_test_mplane如下:
      Octops:/server/camera# ./csi_test_mplane
      open /dev/video0 fd = 3
      resolution got from sensor = 640*480 num_planes = 3
      VIDIOC_STREAMON ok
      file length = 307200 76800 76800
      file start = 0xb6eee000 0xb6edb000 0xb6ec8000
      Got signal 11, exiting ...
      [   36.265546] [VIN_ERR]scaler0 channel ID nember is lost!!!
      Octops:/server/camera# ./csi_test_mplane 0 0 1920 1080 /server 1 20000 60 0
      resolution got from sensor = 1920*1080 num_planes = 3
      VIDIOC_STREAMON ok
      please select the video device: 0-video0 1-video1 ......
      please select the camera: 0-dev0 1-dev1 ......
      please input the resolution: width height......
      1920
      1080
      please input the frame saving path......
      /server
      please input the test mode: 0~3......
      please input the test_cnt: >=1......
      20
      VIDIOC_STREAMON ok
      [  107.543269] [VIN_ERR]scaler0 channel ID nember is lost!!!
      VIDIOC_STREAMOFF ok
      mode 1 test done at the 0 time!!
      time cost 1.221462(s)
      4、i2cdetect测试,发现器件地址对不上
      Octops:/server/camera# i2cdetect -y 1
           0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
      00:          -- -- -- -- -- -- -- -- -- -- -- -- --
      10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
      20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
      30: -- -- -- -- -- -- -- UU -- -- -- -- -- -- -- --
      40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
      50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
      60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
      70: -- -- -- -- -- -- -- --
      问题:
      1、想确认下,4land的摄像头,需要专门指定4land吗?怎么指定?
      2、出现了video设备是可以说明硬件通了,只需要做软件的调试吗?
      3、为什么器件地址会变为原来的一半?
      4、有什么办法可以实时预览摄像头吗?
      vincent1 1 条回复 最后回复 回复 引用 分享 0
      • vincent1
        Shy LV 6 @Negro 最后由 编辑
