    D1开发板配的gt911不能使用, 请问是怎么回事呢?
    5
    11
    9659
      memory LV 7 最后由 编辑
      [   15.011435] xt_time: kernel timezone is -0000
      [   15.041535] Error: Driver 'gt9xxnew_ts' is already registered, aborting...
      [   16.741410] ieee80211_do_open: vif_type=2, p2p=0, ch=3, addr=dc:eb:d6:cd:9a:dc
      root@TinaLinux:/# lsmod
      fuse                  152450  0
      ipt_REJECT              2647  0
      iptable_filter          1759  0
      uvcvideo              128408  0
      videobuf2_memops        1796  1 videobuf2_vmalloc
      videobuf2_vmalloc       7423  1 uvcvideo
      xr829                 844456  0
      xt_LOG                  1639  0
      xt_TCPMSS               4060  0
      xt_comment              1156  0
      xt_limit                2725  0
      xt_mac                  1338  0
      xt_mark                 1472  0
      xt_multiport            2489  0
      xt_time                 3573  0
      root@TinaLinux:/# modprobe gt9xxnew_ts
      [  233.026639] Error: Driver 'gt9xxnew_ts' is already registered, aborting...
      1 module could not be probed
      - gt9xxnew_ts
      root@TinaLinux:/#
      实际上这个 package 是使能了:
      # CONFIG_PACKAGE_kmod-touchscreen-gslx680new is not set
      # CONFIG_PACKAGE_kmod-touchscreen-gt82x is not set
      CONFIG_PACKAGE_kmod-touchscreen-gt9xxnew=y
      # CONFIG_PACKAGE_kmod-touchscreen-tlsc6x is not set
      • BedRock
        BedRock LV 6 最后由 编辑
        还需要在dts 中修改一处:
        目录: d1-tina-open/device/config/chips/d1/configs/nezha/linux/board.dts
                        device_type = "ctp";
                        reg = <0x14>;
        #              此处使能
        -               status = "disabled";
        +               status = "okay";
        #             此处更改触摸方向,实测y触摸方向相反
        -               ctp_revert_y_flag = <0x0>;
        +               ctp_revert_y_flag = <0x1>;
                        ctp_int_port = <&pio PG 14 GPIO_ACTIVE_HIGH>;
                        ctp_wakeup = <&pio PG 15 GPIO_ACTIVE_HIGH>;
        M 1 条回复 最后回复 回复 引用 分享 0
          memory LV 7 @BedRock 最后由 编辑
          @bedrock 感谢大佬, 搞定
          先按楼上修改 device/config/chips/d1/configs/nezha/linux-5.4/board.dts
          然后 make;pack;
          另外自己再编译一个 evtest 进去:
          https://elinux.org/images/9/93/Evtest.c
          root@TinaLinux:/# /mnt/exUDISK/evtest /dev/input/event2
          Input driver version is 1.0.1
          Input device ID: bus 0x18 vendor 0xdead product 0xbeef version 0x28bb
          Input device name: "gt9xxnew_ts"
          Supported events:
            Event type 0 (Sync)
            Event type 1 (Key)
              Event code 116 (Power)
              Event code 227 (?)
              Event code 228 (?)
              Event code 229 (?)
              Event code 230 (?)
              Event code 231 (?)
              Event code 232 (?)
              Event code 233 (?)
              Event code 234 (?)
              Event code 330 (Touch)
            Event type 3 (Absolute)
              Event code 48 (?)
                Value      0
                Min        0
                Max      255
              Event code 50 (?)
                Value      0
                Min        0
                Max      255
              Event code 53 (?)
                Value      0
                Min        0
                Max      800
              Event code 54 (?)
                Value      0
                Min        0
                Max     1280
              Event code 57 (?)
                Value      0
                Min        0
                Max      255
          Testing ... (interrupt to exit)
          Event: time 1270.677369, type 1 (Key), code 330 (Touch), value 1
          Event: time 1270.677369, type 3 (Absolute), code 53 (?), value 5
          Event: time 1270.677369, type 3 (Absolute), code 54 (?), value 22
          Event: time 1270.677369, type 3 (Absolute), code 48 (?), value 11
          Event: time 1270.677369, type 3 (Absolute), code 50 (?), value 11
          Event: time 1270.677369, type 3 (Absolute), code 57 (?), value 0
          Event: time 1270.677369, -------------- Config Sync ------------
          Event: time 1270.677369, -------------- Report Sync ------------
          Event: time 1270.687591, type 3 (Absolute), code 53 (?), value 5
          Event: time 1270.687591, type 3 (Absolute), code 54 (?), value 22
          Event: time 1270.687591, type 3 (Absolute), code 48 (?), value 11
          Event: time 1270.687591, type 3 (Absolute), code 50 (?), value 11
          Event: time 1270.687591, type 3 (Absolute), code 57 (?), value 0
          Event: time 1270.687591, -------------- Config Sync ------------
          Event: time 1270.687591, -------------- Report Sync ------------
          Event: time 1270.697845, type 3 (Absolute), code 53 (?), value 5
          Event: time 1270.697845, type 3 (Absolute), code 54 (?), value 22
          Event: time 1270.697845, type 3 (Absolute), code 48 (?), value 11
          Event: time 1270.697845, type 3 (Absolute), code 50 (?), value 11
          Event: time 1270.697845, type 3 (Absolute), code 57 (?), value 0
          Event: time 1270.697845, -------------- Config Sync ------------
          Event: time 1270.697845, -------------- Report Sync ------------
            memory LV 7 最后由 编辑
            把 evtest 复制到 target/allwinner/d1-nezha/base-files/usr/bin
            然后 make;pack; 生成的 img 就自带了 evtest
            BedRock 1 条回复 最后回复 回复 引用 分享 0
            • BedRock
              BedRock LV 6 @memory 最后由 编辑
              @memory Tina里有个测试命令getevent 就可以同时看到 目前接入的 设备,并进行设备的测试😀 😀 😀 😀
                @bedrock 又get新知识了
                J 2 条回复 最后回复 回复 引用 分享 0
                  Justyu666 LV 5 @memory 最后由 编辑
                  @memory 在 D1开发板配的gt911不能使用, 请问是怎么回事呢? 中说:
                  @bedrock 又get新知识了
                  亲,请教一下,电容触摸( GT911 )的源码是在哪个目录的呢?配置流程是?多谢……
                    @bedrock 又get新知识了
                      Haitun_CZR LV 3 @memory 最后由 编辑
                      @memory 大佬,要怎么另外编译呢?
                        whycan晕哥 LV 9 @CZR1711 最后由 编辑
                        @czr1711 在 D1开发板配的gt911不能使用, 请问是怎么回事呢? 中说:
                        驱动源码:linux-5.4/drivers/input/touchscreen/gt9xxnew/
                        make kernel_menuconfig 开启 CONFIG_TOUCHSCREEN_GT9XXNEW_TS
                          Haitun_CZR LV 3 @whycan 最后由 编辑
                          @whycan 我想问的是evtest这个怎么单独编译呢?
