    请问D1 SDK 的gstreamer默认可以编译成功?
      memory LV 7 最后由 编辑
      cc1: warning: /opt/D1/prebuilt/gcc/linux-x86/riscv/toolchain-thead-glibc/riscv64-glibc-gcc-thead_20200702/usr/include: No suc                       h file or directory [-Wmissing-include-dirs]
        CC       libgstomx_la-gstomxmjpegenc.lo
      gstomxmjpegenc.c: In function 'gst_omx_mjpeg_enc_class_init':
      gstomxmjpegenc.c:57:3: warning: implicit declaration of function 'printf' [-Wimplicit-function-declaration]
         printf("mjpeg class init!\n");
      gstomxmjpegenc.c:57:3: warning: incompatible implicit declaration of built-in function 'printf'
      gstomxmjpegenc.c:57:3: note: include '<stdio.h>' or provide a declaration of 'printf'
      gstomxmjpegenc.c:28:1:
      +#include <stdio.h>
      gstomxmjpegenc.c: In function 'gst_omx_mjpeg_enc_set_format':
      gstomxmjpegenc.c:111:19: warning: variable 's' set but not used [-Wunused-but-set-variable]
           GstStructure *s;
      gstomxmjpegenc.c:144:1: warning: label 'unsupported_level' defined but not used [-Wunused-label]
       unsupported_level:
      gstomxmjpegenc.c:139:1: warning: label 'unsupported_profile' defined but not used [-Wunused-label]
       unsupported_profile:
      gstomxmjpegenc.c: In function 'gst_omx_mjpeg_enc_get_caps':
      gstomxmjpegenc.c:158:18: warning: unused variable 'level' [-Wunused-variable]
         guint profile, level;
      gstomxmjpegenc.c:158:9: warning: unused variable 'profile' [-Wunused-variable]
        CCLD     libgstomx.la
      gcc: error: unrecognized argument in option '-mcmodel=medany'
      gcc: note: valid arguments to '-mcmodel=' are: 32 kernel large medium small; did you mean 'medium'?
      gcc: error: unrecognized argument in option '-mabi=lp64d'
      gcc: note: valid arguments to '-mabi=' are: ms sysv
      Makefile:724: recipe for target 'libgstomx.la' failed
      make[6]: *** [libgstomx.la] Error 1
      make[6]: Leaving directory '/opt/D1/out/d1-nezha/compile_dir/target/gst-omx-1.16.3/omx'
      Makefile:527: recipe for target 'all-recursive' failed
      make[5]: *** [all-recursive] Error 1
      make[5]: Leaving directory '/opt/D1/out/d1-nezha/compile_dir/target/gst-omx-1.16.3'
      Makefile:459: recipe for target 'all' failed
      make[4]: *** [all] Error 2
      make[4]: Leaving directory '/opt/D1/out/d1-nezha/compile_dir/target/gst-omx-1.16.3'
      Makefile:109: recipe for target '/opt/D1/out/d1-nezha/compile_dir/target/gst-omx-1.16.3/.built' failed
      make[3]: *** [/opt/D1/out/d1-nezha/compile_dir/target/gst-omx-1.16.3/.built] Error 2
      make[3]: Leaving directory '/opt/D1/package/multimedia/gst1-omx'
      package/Makefile:192: recipe for target 'package/multimedia/gst1-omx/compile' failed
      make[2]: *** [package/multimedia/gst1-omx/compile] Error 2
      make[2]: Leaving directory '/opt/D1'
      package/Makefile:189: recipe for target '/opt/D1/out/d1-nezha/staging_dir/target/stamp/.package_compile' failed
      make[1]: *** [/opt/D1/out/d1-nezha/staging_dir/target/stamp/.package_compile] Error 2
      make[1]: Leaving directory '/opt/D1'
      /opt/D1/build/toplevel.mk:304: recipe for target 'world' failed
      make: *** [world] Error 2
      [1]+  Done                    $T/tools/build/buildserver --path $T
      #### make failed to build some targets (12:02 (mm:ss)) ####
      随便勾选了几个而已
      H U 2 条回复 最后回复 回复 引用 分享 0
        houxiaoni LV 5 @memory 最后由 编辑
        @memory Allwinner > Select cedarx configuration options > Add for openmax support 选上试一下
        • U
          Uccccc LV 4 @memory 最后由 编辑
          @memory 大佬麻烦问一下解决这个问题了吗
