    V851SE 修改为 spi nand flash 无法正常启动
    6775
    • T
      tanlining LV 3 最后由 xiaowenge 编辑
      [23]HELLO! BOOT0 is starting!
      [26]BOOT0 commit : 4b419f21ba
      [114][pmu]: bus read error
      [117]set pll start
      [119]periph0 has been enabled
      [122]set pll end
      [123]board init ok
      [125]DRAM use internal ZQ!!
      [128]ZQ value = 0x2e
      [130]chip id check OK
      [132]POWER SETTING ERROR!
      [134]DRAM BOOT DRIVE INFO: V0.16
      [137]DRAM CLK = 528 MHz
      [140]DRAM Type = 2 (2:DDR2,3:DDR3)
      [143]DRAMC read ODT  off.
      [145]DRAM ODT off.
      [148]DRAM SIZE =64 M
      [150]dram_tpr4:0x0
      [158]DRAM simple test OK.
      [160]rtc standby flag is 0x0, super standby flag is 0x0
      [165]dram size =64
      [168]audio:avcc calibration
      [171]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32
      [176]block from 8 to 32
      [544]Check is correct.
      [547]Entry_name        = optee
      [550]Entry_name        = u-boot
      [558]Entry_name        = dtb
      [561]Jump to second Boot.
      E/TC:0 0 platform_standby_fdt_parse:133 no pmu node
      E/TC:0 0 sunxi_twi_parse_from_dt:121 no pmu node
      U-Boot 2018.05-ga697d75 (Jul 28 2022 - 05:29:47 +0000) Allwinner Technology
      [00.639]CPU:   Allwinner Family
      [00.642]Model: sun8iw21
      I2C:   [I2C-ERROR]:twi_send_clk_9pulse() 147 SDA is still Stuck Low, failed.
      ready
      [00.702]DRAM:  64 MiB
      [00.705]Relocation Offset is: 00ed0000
      [00.738]secure enable bit: 0
      [00.753]smc_tee_inform_fdt failed with: ffff0000
      [I2C-ERROR]:twi_stop() 339 STOP can't sendout!
      [00.763]pmu_axp2101_probe pmic_bus_read fail
      [00.771]bmu_axp2101_probe pmic_bus_read fail
      [00.775]CPU=900 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=24Mhz  MBus=300Mhz
      [00.781]gic: sec monitor mode
      sunxi flash map init
      [00.786]flash init start
      [00.788]workmode = 0,storage type = 0
      [00.796]sunxi-spinand-phy: spinand sample_mode:1 sample_delay:12
      defaults:
      mtdids  : nand0=nand
      [00.952]ubi0: attaching mtd4
      [01.165]ubi0: scanning is finished
      [01.175]ubi0: attached mtd4 (name "sys", size 123 MiB)
      [01.179]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
      [01.186]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
      [01.192]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      [01.198]ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
      [01.203]ubi0: user volume: 7, internal volumes: 1, max. volumes count: 128
      [01.210]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
      [01.218]ubi0: available PEBs: 0, total reserved PEBs: 492, PEBs reserved for bad PEB handling: 20
      [01.226]sunxi flash init ok
      [01.229]line:724 init_clocks
      [01.232]drv_disp_init
      [01.242]drv_disp_init finish
      [01.397]Loading Environment from SUNXI_FLASH... OK
      [01.433]boot_gui_init:start
      [01.461]Get Reserve0 partition number fail!
      [01.468]boot_gui_init:finish
      [01.522]Get bootloader and boot-resource partition number fail!
      [01.530]Item0 (Map) magic is bad
      [01.533]out of usb burn from boot: not need burn key
      [01.559]update bootcmd
      [01.583]change working_fdt 0x41e8fe70 to 0x41e6fe70
      [01.595]## error: update_fdt_dram_para : FDT_ERR_NOTFOUND
      [01.604]update dts
      input addr exceed dram scope
      [03.035]no vendor_boot partition is found
      Android's image name: v851se-perf1
      [03.098]Starting kernel ...
      [    0.000000] Linux version 4.9.191 (tanlining@ubuntu) (gcc version 6.4.1 (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) ) #3 PREEMPT Fri Feb 17 11:57:27 UTC 2023
      [    0.000000] OF: fdt:Machine model: sun8iw21
      [    0.000000] disp reserve base 0x41f13000 ,size 0x384000
      [    0.000000] Memory policy: Data cache writeback
      [    0.000000] free_area_init_node: node 0, pgdat c0a4ecc8, node_mem_map c3f78000
      [    0.000000]   Normal zone: 128 pages used for memmap
      [    0.000000]   Normal zone: 16384 pages, LIFO batch:3
      [    0.000000] CPU: All CPU(s) started in SVC mode.
      [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16256
      [    0.000000] Kernel command line: ubi.mtd=sys earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=ubi0_4 rootfstype=ubifs, rw init=/pseudo_init partitions=mbr@ubi0_0:boot-res@ubi0_1:env@ubi0_2:boot@ubi0_3:rootfs@ubi0_4:rootfs_data@ubi0_5:UDISK@ubi0_6: cma= snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun8iw21p1 boot_type=5 androidboot.boot_type=5 gpt=1 uboot_message=2018.05-ga697d75(07/28/2022-05:29:47) mbr_offset=1032192 disp_reserve=3686400,0x41f13000 bootreason=button aw-ubi-spinand.ubootblks=24 androidboot.dramsize=64
      [    0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
      [    0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
      [    0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
      [    0.000000] Memory: 51112K/65536K available (6144K kernel code, 318K rwdata, 1368K rodata, 1024K init, 167K bss, 14424K reserved, 0K cma-reserved, 0K highmem)
      [    0.000000]     vmalloc : 0xc4800000 - 0xff800000   ( 944 MB)
      [    0.000000]     lowmem  : 0xc0000000 - 0xc4000000   (  64 MB)
      [    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      [    0.000000]       .text : 0xc0008000 - 0xc0700000   (7136 kB)
      [    0.000000]       .init : 0xc0900000 - 0xc0a00000   (1024 kB)
      [    0.000000]       .data : 0xc0a00000 - 0xc0a4fb88   ( 319 kB)
      [    0.000000]        .bss : 0xc0a4fb88 - 0xc0a79948   ( 168 kB)
      [    0.000000] sunxi_parse_sdm_info failed: -1
      [    0.000008] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
      [    0.000023] Switching to timer-based delay loop, resolution 41ns
      [    0.000203] Console: colour dummy device 80x30
      [    0.000235] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      [    0.000251] pid_max: default: 32768 minimum: 301
      [    0.000455] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
      [    0.000468] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
      [    0.001063] CPU: Testing write buffer coherency: ok
      [    0.001697] Setting up static identity map for 0x40100000 - 0x40100058
      [    0.003443] devtmpfs: initialized
      [    0.038833] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
      [    0.039483] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.039519] futex hash table entries: 256 (order: -1, 3072 bytes)
      [    0.039670] atomic64_test: passed
      [    0.039685] pinctrl core: initialized pinctrl subsystem
      [    0.040814] NET: Registered protocol family 16
      [    0.041591] DMA: preallocated 256 KiB pool for atomic coherent allocations
      [    0.043001] dump_class_init,857, success
      [    0.069499] cpuidle: using governor menu
      [    0.070860] platform 2010000.iommu: iova_base: 0x48400000
      [    0.071446] sunxi iommu: irq = 22
      [    0.093083] sun8iw21p1-pinctrl pio: initialized sunXi PIO driver
      [    0.096254] iommu: Adding device npu to group 0
      [    0.098404] iommu: Adding device 1c0e000.ve to group 0
      [    0.112094] iommu: Adding device 5410000.g2d to group 0
      [    0.113230] iommu: Adding device 5000000.disp to group 0
      [    0.125014] iommu: Adding device 5908000.tdm to group 0
      [    0.125772] iommu: Adding device 5900000.isp to group 0
      [    0.126820] iommu: Adding device 58ffffc.isp to group 0
      [    0.127800] iommu: Adding device 58ffff8.isp to group 0
      [    0.128560] iommu: Adding device 58ffff4.isp to group 0
      [    0.129203] iommu: Adding device 5800800.vind:isp@4 to group 0
      [    0.130660] iommu: Adding device 5910000.scaler to group 0
      [    0.131353] iommu: Adding device 590fffc.scaler to group 0
      [    0.131966] iommu: Adding device 590fff8.scaler to group 0
      [    0.132602] iommu: Adding device 590fff4.scaler to group 0
      [    0.133349] iommu: Adding device 5910400.scaler to group 0
      [    0.134022] iommu: Adding device 59103fc.scaler to group 0
      [    0.134665] iommu: Adding device 59103f8.scaler to group 0
      [    0.135352] iommu: Adding device 59103f4.scaler to group 0
      [    0.136265] iommu: Adding device 5910800.scaler to group 0
      [    0.136902] iommu: Adding device 59107fc.scaler to group 0
      [    0.137501] iommu: Adding device 59107f8.scaler to group 0
      [    0.138127] iommu: Adding device 59107f4.scaler to group 0
      [    0.138846] iommu: Adding device 5910c00.scaler to group 0
      [    0.139518] iommu: Adding device 5910bfc.scaler to group 0
      [    0.140419] iommu: Adding device 5910bf8.scaler to group 0
      [    0.141103] iommu: Adding device 5910bf4.scaler to group 0
      [    0.142506] iommu: Adding device vinc0 to group 0
      [    0.143429] iommu: Adding device vinc4 to group 0
      [    0.144330] iommu: Adding device vinc8 to group 0
      [    0.145241] iommu: Adding device vinc12 to group 0
      [    0.189219] pwm module init!
      [    0.198012] sunxi-pm debug v3.10
      [    0.199817] SCSI subsystem initialized
      [    0.201037] usbcore: registered new interface driver usbfs
      [    0.201272] usbcore: registered new interface driver hub
      [    0.201459] usbcore: registered new device driver usb
      [    0.202023] sunxi_i2c_adap_init()2748 - init
      [    0.202560] sunxi_i2c_probe()2443 - [i2c1] twi_drv_used = 0
      [    0.202579] sunxi_i2c_probe()2450 - [i2c1] twi_pkt_interval = 0
      [    0.202648] twi_regulator_request()647 - [i2c1] regulator not found(isn't configured in dts)!
      [    0.202657] twi_request_gpio()463 - [i2c1] init name: (null)
      [    0.204878] media: Linux media interface: v0.10
      [    0.205100] Linux video capture interface: v2.00
      [    0.206843] ion_parse_dt_heap_common: id 0 type 0 name sys_user align 1000
      [    0.207254] ion_parse_dt_heap_common: id 4 type 4 name cma align 1000
      [    0.209172] Advanced Linux Sound Architecture Driver Initialized.
      [    0.210969] Bluetooth: Core ver 2.22
      [    0.211173] NET: Registered protocol family 31
      [    0.211186] Bluetooth: HCI device and connection manager initialized
      [    0.211214] Bluetooth: HCI socket layer initialized
      [    0.211229] Bluetooth: L2CAP socket layer initialized
      [    0.211292] Bluetooth: SCO socket layer initialized
      [    0.214227] clocksource: Switched to clocksource arch_sys_counter
      [    0.247625] get androidboot.mode fail
      [    0.250034] NET: Registered protocol family 2
      [    0.264618] TCP established hash table entries: 16 (order: -6, 64 bytes)
      [    0.264640] TCP bind hash table entries: 16 (order: -6, 64 bytes)
      [    0.264650] TCP: Hash tables configured (established 16 bind 16)
      [    0.264727] UDP hash table entries: 256 (order: 0, 4096 bytes)
      [    0.264753] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
      [    0.265000] NET: Registered protocol family 1
      [    0.265346] sun8iw21p1-pinctrl pio: can not get func[mux=7] on pin PC0
      [    0.265366] sun8iw21p1-pinctrl pio: can not get func[mux=7] on pin PC1
      [    0.265381] sun8iw21p1-pinctrl pio: can not get func[mux=7] on pin PC2
      [    0.265395] sun8iw21p1-pinctrl pio: can not get func[mux=7] on pin PC3
      [    0.265409] sun8iw21p1-pinctrl pio: can not get func[mux=7] on pin PC4
      [    0.265424] sun8iw21p1-pinctrl pio: can not get func[mux=7] on pin PC5
      [    0.265710] sunxi_spi_probe()2250 - [spi0] SPI DBI INTERFACE
      [    0.265723] sunxi_spi_probe()2259 - [spi0] SPI MASTER MODE
      [    0.265803] sunxi_spi_resource_get()1917 - sample_mode:1 sample_delay:12
      [    0.265827] spi0 supply spi not found, using dummy regulator
      [    0.265921] sunxi_spi_request_gpio()1883 - [spi0] Pinctrl init spi0
      [    0.266015] sunxi_spi_clk_init()1954 - [spi0] mclk 100000000
      [    0.267243] sunxi_spi_probe()2339 - [spi0]: driver probe succeed, base c4868000, irq 294
      [    0.271741] sunxi_sid_driver_init+0x0/0x10 complete comp.
      [    0.273077] workingset: timestamp_bits=29 max_order=14 bucket_order=0
      [    0.291491] squashfs: version 4.0 (2009/01/31) Phillip Lougher
      [    0.292100] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
      [    0.295217] io scheduler noop registered
      [    0.295237] io scheduler deadline registered
      [    0.295583] io scheduler cfq registered (default)
      [    0.296922] [DISP]disp_module_init
      [    0.298526] [DISP] parser_disp_init_para,line:1306:
      [    0.298541] of_property_read disp_init.disp_init_enable fail
      [    0.299095] lcd 0, driver_name ,  panel_name default_lcd
      [    0.299111] lcd 0, driver_name ,  panel_name he0801a068
      [    0.299119] lcd 0, driver_name ,  panel_name inet_dsi_panel
      [    0.299127] lcd 0, driver_name ,  panel_name lq101r1sx03
      [    0.299134] lcd 0, driver_name ,  panel_name WilliamLcd
      [    0.299142] lcd 0, driver_name ,  panel_name bp101wx1
      [    0.299150] lcd 0, driver_name ,  panel_name k101im2qa04
      [    0.299157] lcd 0, driver_name ,  panel_name t050k589
      [    0.299165] lcd 0, driver_name ,  panel_name kd080d24
      [    0.299172] lcd 0, driver_name ,  panel_name super_lcd_driver
      [    0.300570] [DISP]disp_module_init finish
      [    0.303992] uart0 supply uart not found, using dummy regulator
      [    0.305072] uart0: ttyS0 at MMIO 0x2500000 (irq = 289, base_baud = 1500000) is a SUNXI
      [    0.305113] sw_console_setup()2050 - console setup baud 115200 parity n bits 8, flow n
      [    1.413479] console [ttyS0] enabled
      [    1.418461] misc dump reg init
      [    1.423333] sunxi-wlan soc@03000000:wlan@0: wlan_busnum (1)
      [    1.429927] sunxi-wlan soc@03000000:wlan@0: wlan_power_num (-1)
      [    1.436655] sunxi-wlan soc@03000000:wlan@0: Missing wlan_io_regulator.
      [    1.443992] sunxi-wlan soc@03000000:wlan@0: io_regulator_name ((null))
      [    1.451450] sunxi-wlan soc@03000000:wlan@0: request pincrtl handle for device [soc@03000000:wlan@0] failed
      [    1.462404] sunxi-wlan soc@03000000:wlan@0: wlan_regon gpio=134  mul-sel=1  pull=1  drv_level=2  data=0
      [    1.473045] sunxi-wlan soc@03000000:wlan@0: get gpio chip_en failed
      [    1.480132] sunxi-wlan soc@03000000:wlan@0: wlan_hostwake gpio=135  mul-sel=14  pull=1  drv_level=2  data=0
      [    1.491219] sunxi-wlan soc@03000000:wlan@0: clk_name ()
      [    1.498822] sunxi-spinand: AW SPINand MTD Layer Version: 2.4 20220106
      [    1.506567] sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.11 20211125
      [    1.514532] sunxi-spinand-phy: detect munufacture from id table: Mxic
      [    1.521773] sunxi-spinand-phy: detect spinand id: ffff12c2 ffffffff
      [    1.528864] sunxi-spinand-phy: ========== arch info ==========
      [    1.535541] sunxi-spinand-phy: Model:               MX35LF1GE4AB
      [    1.542290] sunxi-spinand-phy: Munufacture:         Mxic
      [    1.548292] sunxi-spinand-phy: DieCntPerChip:       1
      [    1.553965] sunxi-spinand-phy: BlkCntPerDie:        1024
      [    1.559957] sunxi-spinand-phy: PageCntPerBlk:       64
      [    1.565740] sunxi-spinand-phy: SectCntPerPage:      4
      [    1.571412] sunxi-spinand-phy: OobSizePerPage:      64
      [    1.577190] sunxi-spinand-phy: BadBlockFlag:        0x1
      [    1.583056] sunxi-spinand-phy: OperationOpt:        0x7
      [    1.588931] sunxi-spinand-phy: MaxEraseTimes:       65000
      [    1.595004] sunxi-spinand-phy: EccFlag:             0x2
      [    1.600869] sunxi-spinand-phy: EccType:             4
      [    1.606551] sunxi-spinand-phy: EccProtectedType:    3
      [    1.612222] sunxi-spinand-phy: ========================================
      [    1.619660] sunxi-spinand-phy:
      [    1.623184] sunxi-spinand-phy: ========== physical info ==========
      [    1.630134] sunxi-spinand-phy: TotalSize:    128 M
      [    1.635522] sunxi-spinand-phy: SectorSize:   512 B
      [    1.640901] sunxi-spinand-phy: PageSize:     2 K
      [    1.646094] sunxi-spinand-phy: BlockSize:    128 K
      [    1.651473] sunxi-spinand-phy: OOBSize:      64 B
      [    1.656763] sunxi-spinand-phy: ========================================
      [    1.664192] sunxi-spinand-phy:
      [    1.667725] sunxi-spinand-phy: ========== logical info ==========
      [    1.674578] sunxi-spinand-phy: TotalSize:    128 M
      [    1.679957] sunxi-spinand-phy: SectorSize:   512 B
      [    1.685345] sunxi-spinand-phy: PageSize:     4 K
      [    1.690529] sunxi-spinand-phy: BlockSize:    256 K
      [    1.695916] sunxi-spinand-phy: OOBSize:      128 B
      [    1.701294] sunxi-spinand-phy: ========================================
      [    1.708817] sunxi-spinand-phy: block lock register: 0x00
      [    1.714891] sunxi-spinand-phy: feature register: 0x11
      [    1.720568] sunxi-spinand-phy: sunxi physic nand init end
      [    1.728866] sunxipart: failed to parse sunxi_gpt!
      [    1.734176] Creating 4 MTD partitions on "sunxi_mtd_nand":
      [    1.740433] 0x000000000000-0x000000100000 : "boot0"
      [    1.749413] 0x000000100000-0x000000400000 : "uboot"
      [    1.757153] random: fast init done
      [    1.765135] 0x000000400000-0x000000500000 : "secure_storage"
      [    1.775318] 0x000000500000-0x000008000000 : "sys"
      [    1.996715] random: crng init done
      [    2.082572] libphy: Fixed MDIO Bus: probed
      [    2.088741] sunxi gmac driver's version: 2.0.2
      [    2.096309] Failed to alloc md5
      [    2.099857] eth0: Use random mac address
      [    2.104817] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [    2.112581] get ehci0-controller, regulator_io is no nocare
      [    2.119246] get ehci0-controller wakeup-source is fail.
      [    2.125405] sunxi ehci0-controller don't init wakeup source
      [    2.131679] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0a6eeb0, 0x:c4879000, irq_no:130
      [    2.143930] [sunxi-ehci0]: Not init ehci0
      [    2.148974] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [    2.156567] get ohci0-controller, regulator_io is no nocare
      [    2.162833] get ohci0-controller wakeup-source is fail.
      [    2.168978] sunxi ohci0-controller don't init wakeup source
      [    2.175421] [sunxi-ohci0]: probe, pdev->name: 4101000.ohci0-controller, sunxi_ohci: 0xc0a6f0d4
      [    2.185185] [sunxi-ohci0]: Not init ohci0
      [    2.190361] usbcore: registered new interface driver uas
      [    2.196850] usbcore: registered new interface driver usb-storage
      [    2.203901] usbcore: registered new interface driver ums-alauda
      [    2.210825] usbcore: registered new interface driver ums-cypress
      [    2.217923] usbcore: registered new interface driver ums-datafab
      [    2.225102] usbcore: registered new interface driver ums_eneub6250
      [    2.232336] usbcore: registered new interface driver ums-freecom
      [    2.239366] usbcore: registered new interface driver ums-isd200
      [    2.246387] usbcore: registered new interface driver ums-jumpshot
      [    2.253543] usbcore: registered new interface driver ums-karma
      [    2.260436] usbcore: registered new interface driver ums-onetouch
      [    2.267722] usbcore: registered new interface driver ums-realtek
      [    2.274834] usbcore: registered new interface driver ums-sddr09
      [    2.281784] usbcore: registered new interface driver ums-sddr55
      [    2.288714] usbcore: registered new interface driver ums-usbat
      [    2.295578] usb_serial_number:20080411
      [    2.300730] sunxi_gpadc_init,1949, success
      [    2.306221] sunxi_gpadc_setup: get channel scan data failed
      [    2.313764] input: sunxi-gpadc0 as /devices/virtual/input/input0
      [    2.323210] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
      [    2.330486] sunxi-rtc rtc: RTC enabled
      [    2.334925] fix to cold boot, save boot reason
      [    2.340332] i2c /dev entries driver
      [    2.345084] sunxi cedar version 0.1
      [    2.349162] VE: install start!!!
      [    2.349162]
      [    2.354891] VE: cedar-ve the get irq is 291
      [    2.359702] VE: regs_csi = c48a3000
      [    2.364392] VE: get debugfs_mpp_root is NULL, please check mpp
      [    2.364392]
      [    2.372618] VE: sunxi ve debug register driver failed, maybe ok, please check
      [    2.372618]
      [    2.382554] VE: ve_proc_mgr: flag = 1
      [    2.382554]
      [    2.388439] VE: install end!!!
      [    2.388439]
      [    2.394010] google_vp9: sunxi google vp9 version 0.1
      [    2.403109] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
      [    2.412863] Bluetooth: HCI UART driver ver 2.2.d448471.20181218-163903
      [    2.420423] Bluetooth: HCI UART protocol H4 registered
      [    2.426340] Bluetooth: HCI H4 protocol initialized
      [    2.431977] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 01.00.07
      [    2.439849] bt_fdi debugfs_init
      [    2.448003] cpuidle: enable-method property 'psci' found operations
      [    2.457969] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.59 2022-4-21 13:40)
      [    2.467505] sunxi-mmc sdc0: ***ctl-spec-caps*** 8
      [    2.472848] sunxi-mmc sdc0: No vmmc regulator found
      [    2.478467] sunxi-mmc sdc0: No vqmmc regulator found
      [    2.484048] sunxi-mmc sdc0: No vdmmc regulator found
      [    2.489677] sunxi-mmc sdc0: No vd33sw regulator found
      [    2.495441] sunxi-mmc sdc0: No vd18sw regulator found
      [    2.501118] sunxi-mmc sdc0: No vq33sw regulator found
      [    2.506830] sunxi-mmc sdc0: No vq18sw regulator found
      [    2.513042] sunxi-mmc sdc0: set host busy
      [    2.517742] sunxi-mmc sdc0: Got CD GPIO
      [    2.522577] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.533089] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
      [    2.564257] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.604502] sunxi-mmc sdc0: detmode:gpio irq
      [    2.609591] sun8iw21p1-pinctrl pio: expect_func as:io_disabled, but muxsel(7) is func:uart3
      [    2.619044] sun8iw21p1-pinctrl pio: expect_func as:io_disabled, but muxsel(7) is func:uart3
      [    2.628452] sun8iw21p1-pinctrl pio: expect_func as:io_disabled, but muxsel(7) is func:uart3
      [    2.637856] sun8iw21p1-pinctrl pio: expect_func as:io_disabled, but muxsel(7) is func:uart3
      [    2.647258] sun8iw21p1-pinctrl pio: expect_func as:io_disabled, but muxsel(7) is func:uart3
      [    2.656672] sun8iw21p1-pinctrl pio: expect_func as:io_disabled, but muxsel(7) is func:uart3
      [    2.666341] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.59 2022-4-21 13:40)
      [    2.675346] sunxi-mmc sdc1: ***ctl-spec-caps*** 8
      [    2.680680] sunxi-mmc sdc1: No vmmc regulator found
      [    2.686198] sunxi-mmc sdc1: No vqmmc regulator found
      [    2.691777] sunxi-mmc sdc1: No vdmmc regulator found
      [    2.697368] sunxi-mmc sdc1: No vd33sw regulator found
      [    2.703043] sunxi-mmc sdc1: No vd18sw regulator found
      [    2.708729] sunxi-mmc sdc1: No vq33sw regulator found
      [    2.714416] sunxi-mmc sdc1: No vq18sw regulator found
      [    2.720667] sunxi-mmc sdc1: set host busy
      [    2.725309] mmc:failed to get gpios
      [    2.729670] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.740167] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
      [    2.774257] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.814293] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    2.824605] sunxi-mmc sdc1: detmode:manually by software
      [    2.826238] usbcore: registered new interface driver usbhid
      [    2.826242] usbhid: USB HID core driver
      [    2.830324] [sound 1158][DAUDIO snd_sunxi_regulator_init] regulator missing or invalid
      [    2.832449] sunxi-snd-mach soc@03000000:codec_mach: sunxi-snd-codec <-> soc@03000000:codec_plat mapping ok
      [    2.835565] sunxi-snd-mach soc@03000000:daudio0_mach: snd-soc-dummy-dai <-> 2032000.daudio0_plat mapping ok
      [    2.851758] NET: Registered protocol family 10
      [    2.854072] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
      [    2.855767] NET: Registered protocol family 17
      [    2.855809] NET: Registered protocol family 15
      [    2.856149] Bluetooth: RFCOMM TTY layer initialized
      [    2.856171] Bluetooth: RFCOMM socket layer initialized
      [    2.856200] Bluetooth: RFCOMM ver 1.11
      [    2.857545] Registering SWP/SWPB emulation handler
      [    2.945898] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
      [    2.952546] ubi0: attaching mtd3
      [    2.956258] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
      [    2.956322] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.964618] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.976528] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    2.987381] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    2.993305] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    2.999208] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    2.999239] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    3.000326] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    3.000400] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
      [    3.032769] sunxi-mmc sdc1: sdc set ios:clk 300000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    3.055390] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
      [    3.062477] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
      [    3.068518] sunxi-mmc sdc1: sdc set ios:clk 300000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    3.082955] sunxi-mmc sdc1: sdc set ios:clk 300000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    3.096979] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    3.103958] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    3.110985] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    3.117992] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    3.123908] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    3.135952] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    3.146912] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
      [    3.174274] sunxi-mmc sdc1: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    3.215876] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
      [    3.223496] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
      [    3.229526] sunxi-mmc sdc1: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    3.244146] sunxi-mmc sdc1: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    3.258530] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    3.266079] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    3.273595] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    3.281135] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    3.287066] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    3.298988] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    3.310183] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
      [    3.344266] sunxi-mmc sdc1: sdc set ios:clk 100000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    3.387486] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
      [    3.396701] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
      [    3.402724] sunxi-mmc sdc1: sdc set ios:clk 100000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    3.417968] sunxi-mmc sdc1: sdc set ios:clk 100000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    3.433910] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    3.443067] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    3.452224] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    3.461407] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
      [    3.467361] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    3.536495] ubi0: scanning is finished
      [    3.551714] ubi0: attached mtd3 (name "sys", size 123 MiB)
      [    3.558002] ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
      [    3.565775] ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
      [    3.573404] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      [    3.581372] ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
      [    3.588171] ubi0: user volume: 7, internal volumes: 1, max. volumes count: 128
      [    3.596336] ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
      [    3.605751] ubi0: available PEBs: 10, total reserved PEBs: 482, PEBs reserved for bad PEB handling: 10
      [    3.616234] ubi0: background thread "ubi_bgt0d" started, PID 693
      [    3.623562] get det_vbus is fail, 84
      [    3.627794] get id is fail, 84
      [    3.632325] sunxi-rtc rtc: setting system clock to 1970-01-01 00:00:07 UTC (7)
      [    3.641602] clk: Not disabling unused clocks
      [    3.646529] ALSA device list:
      [    3.649863]   #0: audiocodec
      [    3.653110]   #1: snddaudio0
      [    3.660272] List of all partitions:
      [    3.664574] 1f00            1024 mtdblock0  (driver?)
      [    3.670267] 1f01            3072 mtdblock1  (driver?)
      [    3.676025] 1f02            1024 mtdblock2  (driver?)
      [    3.681705] 1f03          125952 mtdblock3  (driver?)
      [    3.687531] No filesystem could mount root, tried:  ubifs
      [    3.693611] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
      [    3.702903] CPU: 0 PID: 1 Comm: swapper Not tainted 4.9.191 #3
      [    3.709451] Hardware name: sun8iw21
      [    3.713401] [<c010d3cc>] (unwind_backtrace) from [<c010a51c>] (show_stack+0x10/0x14)
      [    3.722112] [<c010a51c>] (show_stack) from [<c016ff58>] (panic+0xac/0x2b0)
      [    3.729846] [<c016ff58>] (panic) from [<c0901270>] (mount_block_root+0x208/0x2f4)
      [    3.738260] [<c0901270>] (mount_block_root) from [<c0901450>] (prepare_namespace+0x84/0x178)
      [    3.747747] [<c0901450>] (prepare_namespace) from [<c0900e80>] (kernel_init_freeable+0x11c/0x178)
      [    3.757724] [<c0900e80>] (kernel_init_freeable) from [<c0649f90>] (kernel_init+0x8/0x108)
      [    3.766921] [<c0649f90>] (kernel_init) from [<c0106ca8>] (ret_from_fork+0x14/0x2c)
      [    3.775432] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
      [    3.785593] sunxi dump enabled
      [    3.789017] dump regs done
      [    3.792091] flush cache done
      [    3.795341] crashdump enter
      哪位大神知道是什么问题,帮忙指点迷津,谢谢。
        nand 识别到了,但是没有ubifs的配置层
          WhycanService LV 8 最后由 编辑
          # CONFIG_LOCALVERSION_AUTO is not set
          CONFIG_SYSVIPC=y
          # CONFIG_FHANDLE is not set
          CONFIG_NO_HZ=y
          CONFIG_HIGH_RES_TIMERS=y
          CONFIG_BSD_PROCESS_ACCT=y
          CONFIG_BSD_PROCESS_ACCT_V3=y
          CONFIG_LOG_BUF_SHIFT=14
          CONFIG_CC_OPTIMIZE_FOR_SIZE=y
          # CONFIG_SYSFS_SYSCALL is not set
          # CONFIG_AIO is not set
          CONFIG_EMBEDDED=y
          # CONFIG_SLUB_DEBUG is not set
          # CONFIG_COMPAT_BRK is not set
          CONFIG_JUMP_LABEL=y
          CONFIG_CC_STACKPROTECTOR_REGULAR=y
          CONFIG_MODULES=y
          CONFIG_MODULE_UNLOAD=y
          # CONFIG_BLK_DEV_BSG is not set
          CONFIG_ARCH_SUNXI=y
          CONFIG_ARCH_SUN8IW21=y
          CONFIG_EVB_PLATFORM=y
          CONFIG_SUNXI_SOC_NAME="sun8iw21"
          CONFIG_SWP_EMULATE=y
          # CONFIG_VDSO is not set
          CONFIG_ARM_PSCI=y
          CONFIG_PREEMPT=y
          CONFIG_AEABI=y
          CONFIG_OABI_COMPAT=y
          CONFIG_HIGHMEM=y
          # CONFIG_COMPACTION is not set
          CONFIG_CMA=y
          CONFIG_ARM_FLUSH_CONSOLE_ON_RESTART=y
          CONFIG_USE_OF=y
          # CONFIG_ATAGS is not set
          CONFIG_CMDLINE="earlyprintk=sunxi-uart,0x05000000 loglevel=8 initcall_debug=1 console=ttyS0 init=/init"
          CONFIG_CPU_FREQ=y
          CONFIG_CPU_FREQ_GOV_POWERSAVE=y
          CONFIG_CPU_FREQ_GOV_USERSPACE=y
          CONFIG_CPU_FREQ_GOV_ONDEMAND=y
          CONFIG_CPU_FREQ_GOV_CONSERVATIVE=y
          CONFIG_CPU_FREQ_GOV_INTERACTIVE=y
          CONFIG_CPUFREQ_DT=y
          CONFIG_ARM_ALLWINNER_SUN50I_CPUFREQ_NVMEM=y
          CONFIG_CPU_IDLE=y
          CONFIG_ARM_CPUIDLE=y
          CONFIG_SUNXI_CPU0IDLE=y
          CONFIG_VFP=y
          CONFIG_NEON=y
          # CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS is not set
          CONFIG_PM_WAKELOCKS=y
          CONFIG_PM_DEBUG=y
          CONFIG_PM_ADVANCED_DEBUG=y
          CONFIG_NET=y
          CONFIG_PACKET=y
          CONFIG_PACKET_DIAG=y
          CONFIG_UNIX=y
          CONFIG_UNIX_DIAG=y
          CONFIG_NET_KEY=y
          CONFIG_INET=y
          CONFIG_IP_MULTICAST=y
          CONFIG_IP_ADVANCED_ROUTER=y
          CONFIG_IP_PING=y
          CONFIG_IP_FIB_TRIE_STATS=y
          CONFIG_IP_MULTIPLE_TABLES=y
          CONFIG_IP_ROUTE_MULTIPATH=y
          CONFIG_IP_ROUTE_VERBOSE=y
          CONFIG_IP_MROUTE=y
          CONFIG_IP_MROUTE_MULTIPLE_TABLES=y
          CONFIG_IPV6_MULTIPLE_TABLES=y
          CONFIG_IPV6_SUBTREES=y
          CONFIG_IPV6_MROUTE=y
          CONFIG_BT=y
          CONFIG_BT_RFCOMM=y
          CONFIG_BT_RFCOMM_TTY=y
          # CONFIG_BT_HS is not set
          # CONFIG_BT_LE is not set
          CONFIG_XR_BT_LPM=y
          CONFIG_XR_BT_FDI=y
          CONFIG_BT_HCIUART=y
          CONFIG_BT_HCIUART_H4=y
          CONFIG_HFP_OVER_PCM=y
          CONFIG_CFG80211=y
          CONFIG_RFKILL=y
          CONFIG_RFKILL_GPIO=y
          CONFIG_UEVENT_HELPER_PATH="/sbin/hotplug"
          CONFIG_DEVTMPFS=y
          CONFIG_DEVTMPFS_MOUNT=y
          CONFIG_SUNXI_MBUS=y
          CONFIG_MTD=y
          CONFIG_MTD_BLOCK=y
          CONFIG_MTD_CFI=y
          CONFIG_MTD_CFI_INTELEXT=y
          CONFIG_MTD_CFI_AMDSTD=y
          CONFIG_MTD_COMPLEX_MAPPINGS=y
          CONFIG_MTD_PHYSMAP_OF=y
          CONFIG_MTD_NAND_IDS=y
          CONFIG_AW_MTD_SPINAND=y
          CONFIG_MTD_UBI_BLOCK=y
          CONFIG_SUNXI_RFKILL=y
          CONFIG_SCSI=y
          CONFIG_BLK_DEV_SD=y
          CONFIG_NETDEVICES=y
          CONFIG_SUNXI_GMAC=y
          CONFIG_NET_VENDOR_AURORA=y
          # CONFIG_USB_NET_DRIVERS is not set
          # CONFIG_WLAN_VENDOR_ADMTEK is not set
          # CONFIG_WLAN_VENDOR_ATH is not set
          # CONFIG_WLAN_VENDOR_ATMEL is not set
          # CONFIG_WLAN_VENDOR_BROADCOM is not set
          # CONFIG_WLAN_VENDOR_CISCO is not set
          # CONFIG_WLAN_VENDOR_INTEL is not set
          # CONFIG_WLAN_VENDOR_INTERSIL is not set
          # CONFIG_WLAN_VENDOR_MARVELL is not set
          # CONFIG_WLAN_VENDOR_MEDIATEK is not set
          # CONFIG_WLAN_VENDOR_RALINK is not set
          # CONFIG_WLAN_VENDOR_REALTEK is not set
          # CONFIG_WLAN_VENDOR_RSI is not set
          # CONFIG_WLAN_VENDOR_ST is not set
          # CONFIG_WLAN_VENDOR_TI is not set
          # CONFIG_WLAN_VENDOR_ZYDAS is not set
          CONFIG_XR829_WLAN=m
          CONFIG_ISDN=y
          # CONFIG_INPUT_MOUSEDEV is not set
          CONFIG_INPUT_EVDEV=y
          # CONFIG_INPUT_SENSORINIT is not set
          # CONFIG_INPUT_KEYBOARD is not set
          # CONFIG_INPUT_MOUSE is not set
          CONFIG_INPUT_TOUCHSCREEN=y
          # CONFIG_TOUCHSCREEN_PROPERTIES is not set
          CONFIG_TOUCHSCREEN_FT6236=y
          # CONFIG_TOUCHSCREEN_GT82X is not set
          # CONFIG_TOUCHSCREEN_IT7257_TS is not set
          # CONFIG_TOUCHSCREEN_GSLX680NEW is not set
          # CONFIG_TOUCHSCREEN_FT5X16_TS is not set
          # CONFIG_TOUCHSCREEN_GT9XX_TS is not set
          # CONFIG_TOUCHSCREEN_TLSC6X_TS is not set
          CONFIG_INPUT_MISC=y
          CONFIG_SUNXI_WIEGAND=y
          CONFIG_INPUT_SENSOR=y
          # CONFIG_SENSORS_BMA250 is not set
          # CONFIG_SENSORS_SC7A30 is not set
          # CONFIG_SENSORS_MMA7660 is not set
          # CONFIG_SENSORS_MIR3DA is not set
          # CONFIG_SENSORS_MXC622X is not set
          # CONFIG_SENSORS_MMA8452 is not set
          # CONFIG_SENSORS_MMA865X is not set
          # CONFIG_SENSORS_MC32X0 is not set
          CONFIG_SENSORS_GPADC=y
          CONFIG_KEY_GPIO=y
          # CONFIG_SENSORS_DA380 is not set
          # CONFIG_SERIO is not set
          # CONFIG_LEGACY_PTYS is not set
          # CONFIG_DEVMEM is not set
          # CONFIG_DEVKMEM is not set
          # CONFIG_HW_RANDOM is not set
          # CONFIG_SUNXI_SYS_INFO is not set
          CONFIG_SUNXI_G2D=y
          CONFIG_SUNXI_G2D_MIXER=y
          CONFIG_SUNXI_G2D_ROTATE=y
          CONFIG_SUNXI_NNA_VIP=y
          CONFIG_I2C=y
          CONFIG_I2C_CHARDEV=y
          CONFIG_I2C_SUNXI=y
          CONFIG_SPI=y
          CONFIG_SPI_SUNXI=y
          CONFIG_GPIOLIB=y
          CONFIG_GPIO_SYSFS=y
          CONFIG_POWER_SUPPLY=y
          CONFIG_AXP2101_POWER=y
          CONFIG_THERMAL=y
          CONFIG_THERMAL_GOV_USER_SPACE=y
          CONFIG_THERMAL_GOV_POWER_ALLOCATOR=y
          CONFIG_CPU_THERMAL=y
          CONFIG_THERMAL_EMULATION=y
          CONFIG_SUNXI_THERMAL_NG=y
          CONFIG_WATCHDOG=y
          CONFIG_SUNXI_WATCHDOG=y
          CONFIG_MFD_AXP2101_I2C=y
          CONFIG_MFD_SYSCON=y
          CONFIG_REGULATOR=y
          CONFIG_REGULATOR_FIXED_VOLTAGE=y
          CONFIG_REGULATOR_VIRTUAL_CONSUMER=y
          CONFIG_REGULATOR_AXP2101=y
          CONFIG_MEDIA_SUPPORT=y
          CONFIG_MEDIA_CAMERA_SUPPORT=y
          CONFIG_MEDIA_CONTROLLER=y
          CONFIG_VIDEO_V4L2_SUBDEV_API=y
          CONFIG_V4L_PLATFORM_DRIVERS=y
          CONFIG_VIDEO_SUNXI_VIN=m
          # CONFIG_CSI_CCI is not set
          CONFIG_VIN_IOMMU=y
          CONFIG_D3D=y
          CONFIG_D3D_COMPRESS_EN=y
          # CONFIG_WDR is not set
          CONFIG_SENSOR_GC2053_MIPI=m
          # CONFIG_MEDIA_SUBDRV_AUTOSELECT is not set
          CONFIG_FB=y
          CONFIG_DISP2_SUNXI=y
          CONFIG_SUNXI_DISP2_FB_HW_ROTATION_SUPPORT=y
          CONFIG_DISP2_SUNXI_DEBUG=y
          CONFIG_LCD_SUPPORT_D310T9362V1_MIPI=y
          # CONFIG_LCD_SUPPORT_HE0801A068 is not set
          # CONFIG_LCD_SUPPORT_WILLIAMLCD is not set
          # CONFIG_LCD_SUPPORT_LQ101R1SX03 is not set
          # CONFIG_LCD_SUPPORT_INET_DSI_PANEL is not set
          # CONFIG_LCD_SUPPORT_BP101WX1_206 is not set
          # CONFIG_LCD_SUPPORT_K101IM2QA04 is not set
          # CONFIG_LCD_SUPPORT_T050K589 is not set
          # CONFIG_LCD_SUPPORT_KD080D24 is not set
          CONFIG_SOUND=y
          CONFIG_SND=y
          CONFIG_SND_SOC=y
          CONFIG_SND_SOC_SUNXI_AAUDIO=y
          CONFIG_SND_SOC_SUNXI_DAUDIO=y
          CONFIG_SND_SOC_SUNXI_COMPONENTS=y
          CONFIG_SND_SOC_SUNXI_RXSYNC=y
          CONFIG_USB=y
          CONFIG_USB_EHCI_HCD=y
          CONFIG_USB_OHCI_HCD=y
          CONFIG_USB_SUNXI_HCD=y
          CONFIG_USB_SUNXI_HCI=y
          CONFIG_USB_SUNXI_EHCI0=y
          CONFIG_USB_SUNXI_EHCI1=y
          CONFIG_USB_SUNXI_OHCI0=y
          CONFIG_USB_SUNXI_OHCI1=y
          CONFIG_USB_STORAGE=y
          CONFIG_USB_STORAGE_REALTEK=y
          CONFIG_USB_STORAGE_DATAFAB=y
          CONFIG_USB_STORAGE_FREECOM=y
          CONFIG_USB_STORAGE_ISD200=y
          CONFIG_USB_STORAGE_USBAT=y
          CONFIG_USB_STORAGE_SDDR09=y
          CONFIG_USB_STORAGE_SDDR55=y
          CONFIG_USB_STORAGE_JUMPSHOT=y
          CONFIG_USB_STORAGE_ALAUDA=y
          CONFIG_USB_STORAGE_ONETOUCH=y
          CONFIG_USB_STORAGE_KARMA=y
          CONFIG_USB_STORAGE_CYPRESS_ATACB=y
          CONFIG_USB_STORAGE_ENE_UB6250=y
          CONFIG_USB_UAS=y
          CONFIG_USB_GADGET=y
          CONFIG_USB_SUNXI_UDC0=y
          CONFIG_USB_CONFIGFS=y
          CONFIG_USB_CONFIGFS_MASS_STORAGE=y
          CONFIG_USB_CONFIGFS_F_FS=y
          CONFIG_USB_CONFIGFS_UEVENT=y
          CONFIG_USB_CONFIGFS_F_HID=y
          CONFIG_USB_SUNXI_USB=y
          CONFIG_USB_SUNXI_USB_MANAGER=y
          CONFIG_USB_SUNXI_USB_DEBUG=y
          CONFIG_USB_SUNXI_USB_ADB=y
          CONFIG_MMC=y
          CONFIG_MMC_SUNXI=y
          CONFIG_RTC_CLASS=y
          CONFIG_RTC_DRV_SUNXI=y
          CONFIG_SUNXI_BOOTUP_EXTEND=y
          CONFIG_SUNXI_RTC_BOOTCOUNT=y
          CONFIG_DMADEVICES=y
          CONFIG_DMA_SUNXI=y
          CONFIG_STAGING=y
          CONFIG_ION=y
          CONFIG_ION_SUNXI=y
          # CONFIG_COMMON_CLK_DEBUG is not set
          # CONFIG_ARM_ARCH_TIMER_EVTSTREAM is not set
          CONFIG_MAILBOX=y
          CONFIG_SUNXI_MBOX=y
          CONFIG_SUNXI_RV32_STANBY=y
          CONFIG_SUNXI_IOMMU=y
          CONFIG_SUNXI_RPROC=y
          CONFIG_SUNXI_MSGBOX=y
          CONFIG_SUNXI_RPMSG_E907=y
          CONFIG_SUNXI_RPMSG_SPEEDTEST=y
          CONFIG_SUNXI_RPMSG_HEARBEAT=y
          CONFIG_RPMSG_CTRL=y
          CONFIG_RPMSG_NOTIFY=y
          CONFIG_RPMSG_VIRTIO=y
          CONFIG_PWM=y
          CONFIG_PWM_SUNXI_GROUP=y
          CONFIG_ANDROID=y
          CONFIG_NVMEM=y
          CONFIG_NVMEM_SUN50I_SID=y
          CONFIG_SUNXI_MPP=y
          CONFIG_EXT4_FS=y
          # CONFIG_FILE_LOCKING is not set
          # CONFIG_DNOTIFY is not set
          # CONFIG_INOTIFY_USER is not set
          CONFIG_OVERLAY_FS=y
          CONFIG_MSDOS_FS=y
          CONFIG_VFAT_FS=y
          CONFIG_FAT_DEFAULT_UTF8=y
          CONFIG_TMPFS=y
          CONFIG_TMPFS_POSIX_ACL=y
          CONFIG_JFFS2_FS=y
          CONFIG_JFFS2_SUMMARY=y
          CONFIG_JFFS2_FS_XATTR=y
          # CONFIG_JFFS2_FS_POSIX_ACL is not set
          # CONFIG_JFFS2_FS_SECURITY is not set
          CONFIG_JFFS2_COMPRESSION_OPTIONS=y
          # CONFIG_JFFS2_ZLIB is not set
          CONFIG_UBIFS_FS=y
          CONFIG_SQUASHFS=y
          CONFIG_SQUASHFS_LZ4=y
          CONFIG_SQUASHFS_LZO=y
          CONFIG_SQUASHFS_XZ=y
          CONFIG_SQUASHFS_ZSTD=y
          # CONFIG_NETWORK_FILESYSTEMS is not set
          CONFIG_NLS_CODEPAGE_437=y
          CONFIG_NLS_ISO8859_1=y
          CONFIG_PRINTK_TIME=y
          CONFIG_FRAME_WARN=2048
          CONFIG_DEBUG_FS=y
          CONFIG_DEBUG_VM=y
          # CONFIG_SCHED_DEBUG is not set
          CONFIG_DEBUG_MUTEXES=y
          CONFIG_STACKTRACE=y
          # CONFIG_FTRACE is not set
          CONFIG_ATOMIC64_SELFTEST=y
          CONFIG_SUNXI_DUMP=y
          T 1 条回复 最后回复 回复 引用 分享 0
          • T
            tanlining LV 3 @WhycanService 最后由 编辑
            @whycanservice WechatIMG90.jpeg WechatIMG91.jpeg WechatIMG92.jpeg WechatIMG93.jpeg 麻烦帮忙看下哪里配错了或者漏配了谢谢!!!!
              WhycanService LV 8 @tanlining 最后由 编辑
              @tanlining 直接拿我的config替换吧
              • T
                @whycanservice 好的 我试一下
                  away123456 LV 4 @tanlining 最后由 编辑
                  @tanlining 兄弟,这个问题你是怎么解决的呀,求助
