    使用F1C200S TINA3.5 SPINAND 在windows下的PhoenixSuit V1.19烧写固件 卡在7%
    4249
    • Q
      qinhao4832 LV 5 最后由 编辑
      使用F1C200S TINA3.5 SPINAND 在windows下的PhoenixSuit V1.19烧写固件 卡在7%。最终提示失败。
      已经有按照tina的文档,修改sys_config.fex,make menuconfig,make kernel_menuconfig。
      环境是:
      SPINAN型号:W25N01G
      tina3.5
      u-boot-2014.07
      linux-3.10
      以下是烧录的时候,日志的头尾两端。
      [0]beign to init dram
      [23]init dram ok
      U-Boot 2014.07 (Jul 31 2018 - 14:59:19) Allwinner Technology
      uboot commit : 6604446f7bddb8fe53f2b993100929f92a5f4d6e
      i2c_init: by cpux
      [I2C-DEBUG]:i2c_set_clock() 354
      [I2C-ERROR]:twi_send_clk_9pulse() 136 SDA is still Stuck Low, failed.
      i2c_init ok
      [2.642]pmbus:   ready
      axp: get node[/soc/pmu0] error
      axp_probe error
      [2.649]PMU: cpux 408 Mhz,AXI=408 Mhz
      PLL6=600 Mhz,AHB1=200 Mhz, APB1=100Mhz
      DRAM:  32 MiB
      [2.658]fdt addr: 0x809e77a0
      [2.660]gd->fdt_size: 0xc360
      Relocation Offset is: 01524000
      int sunxi_dma_init---
      irq enable
      [2.730]flash init start
      workmode = 16,storage type = 3
      try card 1
      [2.736][mmc]: mmc driver ver 2018-6-1 17:39:00
      SUNXI SD/MMC: 1
      [2.753][mmc]: ************Try SD card 1************
      [mmc]: mmc 1 cmd 8 timeout, err 100
      [mmc]: smc 1 err, cmd 8,  RTO
      [mmc]: mmc 1 close bus gating and reset
      [mmc]: mmc 1 mmc cmd 8 err 0x00000100
      [2.771][mmc]: mmc send if cond failed
      [mmc]: mmc 1 cmd 55 timeout, err 100
      [mmc]: smc 1 err, cmd 55,  RTO
      [mmc]: mmc 1 mmc cmd 55 err 0x00000100
      [2.789][mmc]: send app cmd failed
      [2.792][mmc]: ************Try MMC card 1************
      [mmc]: mmc 1 cmd 1 timeout, err 100
      [mmc]: smc 1 err, cmd 1,  RTO
      [mmc]: mmc 1 mmc cmd 1 err 0x00000100
      [2.814][mmc]: read op condition failed
      [2.817][mmc]: mmc send op cond failed
      Card did not respond to voltage select!
      [2.824][mmc]: ************SD/MMC 1 init error!!!************
      [2.830][mmc]: mmc_init_boot: mmc int fail
      [2.833][mmc]: mmc_init: mmc init fail, err -17
      MMC init failed
      try emmc fail
      [2.840]NAND_UbootProbe start...
      [2.843]NB1 : enter phy init
      [2.846]nand_physic_init
      [2.850]nand0: get node offset error
      [2.853]init nctri NAND PIORequest error!
      [2.857]nand_physic_init, init nctri error
      [2.861]nand_physic_init init_parameter error
      [2.865]nand_physic_init error -1
      [2.868]SpiNandHwInit: Start Nand Hardware initializing Jun  9 2018 19:05:34.....
      [2.875]uboot: nand version: 3 6008 20180610 1300
      [2.892]request spi gpio  ok!
      irq enable
      [2.897]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x81db8c7c
      [2.905]request general tx dma channel ok!
      [2.908]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x81db8c9c
      [2.916]request general rx dma channel ok!
      [2.920]SPI nand ID: 21aaef 0
      [2.922][SCAN_DBG] NandTwoPlaneOp: 1, DriverTwoPlaneOPCfg: 1, 0xffbfffff
      [2.929]nand : get id number_ctl from script:0x55aaaa55
      [2.934]_UpdateExtAccessFreqPara: no para.
      [2.938]PHY_Scan_DelayMode: right delay mode 0x0
      [2.942]PHY_Scan_DelayMode: right delay mode 0x800
      _get_spic_clk_v1: sclk0=0x64
      [2.949]PHY_Scan_DelayMode: right delay mode,clk 50 MHz, SPI_TCR = 0x00000984, bit[13]=0,bit[11]=1
      [2.958]physic_info_read start!!
      [2.961]physic_info_get_offset start!!
      [2.966]physic_info_get_one_copy start!!
      [2.970]block 13 page 48
      [2.972]block 13 page 49
      [2.974]block 13 page 50
      [2.977]block 13 page 51
      [2.979]block 13 page 52
      [2.981]block 13 page 53
      [2.983]block 13 page 54
      [2.986]block 13 page 55
      [2.988]block 13 page 56
      [2.990]block 13 page 57
      [2.992]block 13 page 58
      [2.994]block 13 page 59
      [2.997]block 13 page 60
      [2.999]block 13 page 61
      [3.001]block 13 page 62
      [3.003]block 13 page 63
      [3.006]physic info copy is ok
      [3.009]
      [3.010][SCAN_DBG] ==============Nand Architecture Parameter==============
      [3.016][SCAN_DBG]    Nand Chip ID:         0xff21aaef 0xffffffff
      [3.022][SCAN_DBG]    Nand Chip Count:      0x1
      [3.026][SCAN_DBG]    Nand Chip Connect:    0x1
      [3.030][SCAN_DBG]    Sector Count Of Page: 0x4
      [3.035][SCAN_DBG]    Page Count Of Block:  0x40
      [3.039][SCAN_DBG]    Block Count Of Die:   0x400
      [3.043][SCAN_DBG]    Plane Count Of Die:   0x1
      [3.048][SCAN_DBG]    Die Count Of Chip:    0x1
      [3.052][SCAN_DBG]    Bank Count Of Chip:   0x1
      [3.056][SCAN_DBG]    Optional Operation:   0x60
      [3.060][SCAN_DBG]    Access Frequence:     0x0
      [3.065][SCAN_DBG] =======================================================
      [3.092]secure storage updata ok!
      [3.095]nand secure storage ok: 58,59
      [3.099]NB1 : nand phy init ok
      [3.101]NB1 : enter phy Exit
      nand release dma:81db8c7c
      nand release dma:0
      sunxi dma exit
      [3.109]NAND_UbootProbe end: 0x0
      nand found
      read mbr copy[0] failed
      read mbr copy[1] failed
      read mbr copy[2] failed
      read mbr copy[3] failed
      [3.122]flash init end
      [3.124]try to burn key
      [3.129]inter uboot shell
      work mode=0x10
      run usb efex
      delay time 2500
      irq enable
      sunxi_dma_install_int ok
      usb init ok
      set address 0xd
      set address 0xd
      SUNXI_EFEX_ERASE_TAG
      erase_flag = 0x0
      FEX_CMD_fes_verify_status
      FEX_CMD_fes_verify last err=0
      the 0 mbr table is ok
      the 1 mbr table is ok
      the 2 mbr table is ok
      the 3 mbr table is ok
      total mbr part 8
      part[0] name      :bootlogo
      part[0] classname :DISK
      part[0] addrlo    :0x2000
      part[0] lenlo     :0x800
      part[0] user_type :32768
      part[0] keydata   :0
      part[0] ro        :0
      part[1] name      :env
      part[1] classname :DISK
      part[1] addrlo    :0x2800
      part[1] lenlo     :0x200
      part[1] user_type :32768
      part[1] keydata   :0
      part[1] ro        :0
      part[2] name      :boot
      part[2] classname :DISK
      part[2] addrlo    :0x2a00
      part[2] lenlo     :0x3000
      part[2] user_type :32768
      part[2] keydata   :0
      part[2] ro        :0
      part[3] name      :rootfs
      part[3] classname :DISK
      part[3] addrlo    :0x5a00
      part[3] lenlo     :0x15c70
      part[3] user_type :32768
      part[3] keydata   :0
      part[3] ro        :0
      part[4] name      :rootfs_data
      part[4] classname :DISK
      part[4] addrlo    :0x1b670
      part[4] lenlo     :0xc800
      part[4] user_type :32768
      part[4] keydata   :0
      part[4] ro        :0
      part[5] name      :misc
      part[5] classname :DISK
      part[5] addrlo    :0x27e70
      part[5] lenlo     :0x200
      part[5] user_type :32768
      part[5] keydata   :0
      part[5] ro        :0
      part[6] name      :private
      part[6] classname :DISK
      part[6] addrlo    :0x28070
      part[6] lenlo     :0x200
      part[6] user_type :32768
      part[6] keydata   :0
      part[6] ro        :0
      part[7] name      :UDISK
      part[7] classname :DISK
      part[7] addrlo    :0x28270
      part[7] lenlo     :0x0
      part[7] user_type :33024
      part[7] keydata   :0
      part[7] ro        :0
      total part: 9
      mbr 0, 2000, 8000
      bootlogo 1, 800, 8000
      env 2, 200, 8000
      boot 3, 3000, 8000
      rootfs 4, 15c70, 8000
      rootfs_data 5, c800, 8000
      misc 6, 200, 8000
      private 7, 200, 8000
      UDISK 8, 0, 8100
      [7.326]erase_flag = 0
      [7.328]NB1 : enter phy init
      [7.330]SpiNandHwInit: Start Nand Hardware initializing Jun  9 2018 19:05:34.....
      [7.337]uboot: nand version: 3 6008 20180610 1300
      [7.354]request spi gpio  ok!
      [7.357]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x81db8c9c
      [7.364]request general tx dma channel ok!
      [7.368]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x81db8cbc
      [7.375]request general rx dma channel ok!
      [7.379]SPI nand ID: 21aaef 0
      [7.382][SCAN_DBG] NandTwoPlaneOp: 1, DriverTwoPlaneOPCfg: 1, 0xffbfffff
      [7.388]nand : get id number_ctl from script:0x55aaaa55
      [7.393]_UpdateExtAccessFreqPara: no para.
      [7.397]PHY_Scan_DelayMode: right delay mode 0x0
      [7.402]PHY_Scan_DelayMode: right delay mode 0x800
      [7.409]PHY_Scan_DelayMode: right delay mode,clk 50 MHz, SPI_TCR = 0x00000984, bit[13]=0,bit[11]=1
      [7.417]physic_info_read start!!
      [7.420]physic_info_read already!!
      [7.423]
      [7.424][SCAN_DBG] ==============Nand Architecture Parameter==============
      [7.431][SCAN_DBG]    Nand Chip ID:         0xff21aaef 0xffffffff
      [7.437][SCAN_DBG]    Nand Chip Count:      0x1
      [7.441][SCAN_DBG]    Nand Chip Connect:    0x1
      [7.445][SCAN_DBG]    Sector Count Of Page: 0x4
      [7.449][SCAN_DBG]    Page Count Of Block:  0x40
      [7.454][SCAN_DBG]    Block Count Of Die:   0x400
      [7.458][SCAN_DBG]    Plane Count Of Die:   0x1
      [7.462][SCAN_DBG]    Die Count Of Chip:    0x1
      [7.466][SCAN_DBG]    Bank Count Of Chip:   0x1
      [7.471][SCAN_DBG]    Optional Operation:   0x60
      [7.475][SCAN_DBG]    Access Frequence:     0x0
      [7.479][SCAN_DBG] =======================================================
      [7.507]secure storage updata ok!
      [7.510]nand secure storage ok: 58,59
      [7.513]NB1 : nand phy init ok
      [7.516]uboot_start_block 8 uboot_next_block 58.
      [7.520]check nand version start.
      [7.523]Current nand driver version is ff 0 3 1
      [7.528]Media version is valid in block 8, version info is ff 0 3 1
      [7.534]nand driver version match ok in block 8.
      [7.538]nand version = 0
      [7.540]has cleared the boot blocks.
      [7.548]NAND_Uboot_Erase
      [7.550]NB1 : enter phy Exit
      nand release dma:81db8c9c
      nand release dma:0
      not need erase flash
      sunxi_sprite_erase_flash, erase_flag=0
      private part exist
      NAND_UbootInit
      [7.565]NAND_UbootInit start
      [7.567]NB1: enter NAND_LogicInit
      [7.570]SpiNandHwInit: Start Nand Hardware initializing Jun  9 2018 19:05:34.....
      [7.578]uboot: nand version: 3 6008 20180610 1300
      [7.594]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x81db8c9c
      [7.602]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x81db8cbc
      [7.633]not burn nand partition table!
      [7.637][ND]not enough block:479,878!!
      [7.640][NE]build phy partition 0 error!
      [7.644][NE]build all phy partition fail!
      [7.764][NE]not find mbr table!!!!
      [7.767]NB1: nand_info_init fail
      [7.770]NAND_UbootInit end: 0xfffffffb
      NAND_UbootExit
      [19.204]PHY_PageReadSpare bad flag: bank 0x0  block 0x3f8  page 0x0
      [19.210][PHY_DBG] Find a bad block (NO. 0x3f8) in the Die 0x0
      [19.216]PHY_PageReadSpare bad flag: bank 0x0  block 0x3f9  page 0x0
      [19.222][PHY_DBG] Find a bad block (NO. 0x3f9) in the Die 0x0
      [19.227]PHY_PageReadSpare bad flag: bank 0x0  block 0x3fa  page 0x0
      [19.233][PHY_DBG] Find a bad block (NO. 0x3fa) in the Die 0x0
      [19.239]PHY_PageReadSpare bad flag: bank 0x0  block 0x3fb  page 0x0
      [19.245][PHY_DBG] Find a bad block (NO. 0x3fb) in the Die 0x0
      [19.251]PHY_PageReadSpare bad flag: bank 0x0  block 0x3fc  page 0x0
      [19.257][PHY_DBG] Find a bad block (NO. 0x3fc) in the Die 0x0
      [19.262]PHY_PageReadSpare bad flag: bank 0x0  block 0x3fd  page 0x0
      [19.268][PHY_DBG] Find a bad block (NO. 0x3fd) in the Die 0x0
      [19.274]PHY_PageReadSpare bad flag: bank 0x0  block 0x3fe  page 0x0
      [19.280][PHY_DBG] Find a bad block (NO. 0x3fe) in the Die 0x0
      [19.286]PHY_PageReadSpare bad flag: bank 0x0  block 0x3ff  page 0x0
      [19.292][PHY_DBG] Find a bad block (NO. 0x3ff) in the Die 0x0
      [19.297][NE]not find mbr table!!!!
      [19.301]NB1: nand_info_init fail
      [19.304]NAND_UbootInit end: 0xfffffffb
      sunxi sprite init fail when downlaod mbr
        WhycanService LV 8 最后由 编辑
        看log是坏块过多导致的
        Q 1 条回复 最后回复 回复 引用 分享 0
        • Q
          qinhao4832 LV 5 @WhycanService 最后由 编辑
          @whycanservice 应该不是 好像全是识别成坏块。spinand 都换了3颗了,都是一样的现象。
            WhycanService LV 8 @qinhao4832 最后由 编辑
            @qinhao4832 驱动是否支持这个物料
              zhc18954242710 LV 1 最后由 编辑
              你好 有解决嘛?
