    V851s 烧录后不能启动(spi nand存储介质)请大佬帮忙看看
      luorenzhen LV 3 最后由 编辑
      [Rx][14:59:26.813] [159]HELLO! BOOT0 is starting!
      [162]BOOT0 commit : 4b419f21ba
      [Rx][14:59:26.955] [250][pmu]: bus read error
      [252]set pll start
      [254]periph0 has been enabled
      [257]set pll end
      [259]board init ok
      [261]DRAM use internal ZQ!!
      [263]ZQ value = 0x2f
      [266]chip id check OK
      [268]POWER SETTING ERROR!
      [270]DRAM BOOT DRIVE INFO: V0.16
      [273]DRAM CLK = 528 MHz
      [275]DRAM Type = 2 (2:DDR2,3:DDR3)
      [279]DRAMC read ODT  off.
      [281]DRAM ODT off.
      [284]DRAM SIZE =64 M
      [286]dram_tpr4:0x0
      [293]DRAM simple test OK.
      [296]rtc standby flag is 0x0, super standby flag is 0x0
      [301]dram size =64
      [304]audio:avcc calibration
      [306]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32
      [312]block from 8 to 32
      [Rx][14:59:27.346] [682]Check is correct.
      [684]Entry_name        = optee
      [687]Entry_name        = u-boot
      [696]Entry_name        = dtb
      [699]Jump to second Boot.
      [Rx][14:59:27.367] M/TC: OP-TEE version: 15ee1539b (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Tue Mar 29 06:48:41 UTC 2022 arm
      [Rx][14:59:27.390] E/TC:0 0 platform_standby_fdt_parse:133 no pmu node
      [Rx][14:59:27.399] E/TC:0 0 sunxi_twi_parse_from_dt:121 no pmu node
      [Rx][14:59:27.427]
      U-Boot 2018.05-ga697d75 (Jul 28 2022 - 05:29:47 +0000) Allwinner Technology
      [00.776]CPU:   Allwinner Family
      [00.779]Model: sun8iw21
      I2C:
      [I2C-ERROR]:twi_send_clk_9pulse() 147 SDA is still Stuck Low, failed.
      ready
      [00.839]DRAM:  64 MiB
      [00.843]Relocation Offset is: 00ed0000
      [Rx][14:59:27.507] [00.87
      6]secure enable bit: 0
      [00.890]smc_tee_inform_fdt failed with: ffff0000
      [I2C-ERROR]:twi_stop() 339 STOP can't sendout!
      [00.900]pmu_axp2101_probe pmic_bus_read fail
      [00.908]bmu_axp2101_probe pmic_bus_read fail
      [00.912]CPU=900 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=24Mhz  MBus=300Mhz
      [00.918]gic: sec monitor mode
      sunxi flash map init
      [00.923]flash init start
      [00.925]workmode = 0,storage type = 0
      [00.933]sunxi-spinand-phy: spinand sample_mode:1 sample_delay:1b
      device nand0 , # parts = 4
       #: name		size		offset		mask_flags
       0: boot0               0x00100000	0x00000000	1
       1: uboot               0x00300000	0x00100000	1
       2: secure_storage      0x00100000	0x00400000	1
       3: sys                 0x07b00000	0x00500000	0
      defaults:
      mtdids  : nand0=nand
      [Rx][14:59:27.722] [01.090]ubi0: attaching mtd4
      [Rx][14:59:27.953] [01.304]ubi0: scanning is finished
      [01.313]ubi0
      : attached mtd4 (name "sys", size 123 MiB)
      [01.318]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
      [01.324]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
      [01.330]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      [01.337]ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
      [01.342]ubi0: user volume: 7, internal volumes: 1, max. volumes count: 128
      [01.349]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
      [01.356]ubi0: available PEBs: 0, total reserved PEBs: 492, PEBs reserved for bad PEB handling: 20
      [01.365]sunxi flash init ok
      [01.367]line:724 init_clocks
      [01.371]drv_disp_init
      [01.380]drv_disp_init finish
      [Rx][14:59:28.174] [01.536]Loading Environment from SUNXI_FLASH... [01.540]o
      ffset 0x3b58 with sects 0x200 over volume env [0x3b58 0x3d50)
      [01.546]get partno from nand_mbr failed: offset 0x3b58 sects 512
      *** Warning - read failed, using default environment
      Failed (-5)
      [01.558]boot_gui_init:start
      [Rx][14:59:28.235] partno erro : can't find partition Reserve0
      [01.586]Get Reserve0 partition number fail!
      [01.593]boot_gui_init:finish
      [Rx][14:59:28.251] partno erro : can't find parti
      tion bootloader
      [01.625]bmp_name=bootlogo.bmp size 38454
      38454 bytes read in 5 ms (7.3 MiB/s)
      [01.641]sunxi-spinand: check valid secure storage failed with 16 back
      [01.647]sunxi-spinand: nand secure storage check page 0 fail
      [01.652]sunxi-spinand: check secure storage failed with -22
      [01.658]get secure storage map err
      [01.661]out of usb burn from boot: not need burn key
      [Rx][14:59:28.325] [01.688]update bootcmd
      [Rx][14:59:28.381] [01.712]change working_fdt 0x41e8fe70 to 0x41e6fe70
      [01.723]## error: update_fdt_dram_para : FDT_ERR_NOTFOUND
      [01.732]update dts
      Hit any key to stop autoboot:  2
      ## Error: "distro_bootcmd" not defined
        WhycanService LV 8 最后由 编辑
        看下分区表,感觉分区表有问题
        J 1 条回复 最后回复 回复 引用 分享 0
          jeffrey LV 2 @WhycanService 最后由 编辑
          @whycanservice 請問這個問題有解掉嗎? 我這邊也碰到一樣的問題...
