    【DIY教程】D1哪吒开发板改成HDMI输出
      DOT小文哥 LV 8 最后由 编辑
      D1哪吒开发板自带的固件和官方释放的Tina D1 v1.0.1 SDK默认都是mipi显示输出,如果需要改成HDMI输出,按场景需求,有以下三种方法:
      1.开发板直接命令行切换
      这种方法仅限本次开机,重启设备知乎又会重新加载DTS,变回mipi输出
      命令:
      cd /sys/kernel/debug/dispdbg
      echo disp0 > name; echo switch1 > command; echo 4 10 0 0 0x4 0x101 0 0 0 8 > param; echo 1 > start;
      此时开发板会改成HDMI输出,使用命令cat colorbar可以进行测试是否切换成功了:
      echo 1 > /sys/class/disp/disp/attr/colorbar
      详见D1在线文档:https://d1.docs.aw-ol.com/study/study_5connect/#hdmi
      2.烧HDMI固件
      烧写官方提供的HDMI输出固件,就会变成HDMI输出,每次开机都是
      详见:https://d1.docs.aw-ol.com/source/3_getimg/
      固件下载地址:https://www.aw-ol.com/downloads/resources/44
      3.修改源码
      如果想自己制作一个HDMI输出的固件,可以按照如下方法修改源码
      (1)修改DTS文件,uboot的dts和内核的dts都要改
      tina/device/config/chips/d1/configs/nezha$ git diff .
      diff --git a/configs/nezha/linux-5.4/board.dts b/configs/nezha/linux-5.4/board.dts
      index bfeed6c..1cef004 100755
      --- a/configs/nezha/linux-5.4/board.dts
      +++ b/configs/nezha/linux-5.4/board.dts
      @@ -1128,30 +1128,25 @@ chn_cfg_mode     : Hardware DE channel allocation config. 0:single display with
      -       screen0_output_type      = <1>;
      -       screen0_output_mode      = <4>;
      -       screen1_output_type      = <3>;
      -       screen1_output_mode      = <10>;
      -       screen1_output_format    = <0>;
      -       screen1_output_bits      = <0>;
      -       screen1_output_eotf      = <4>;
      -       screen1_output_cs        = <257>;
      -       screen1_output_dvi_hdmi  = <2>;
      -       screen1_output_range     = <2>;
      -       screen1_output_scan      = <0>;
      -       screen1_output_aspect_ratio = <8>;
      -       dev0_output_type         = <1>;
      -       dev0_output_mode         = <4>;
      +    screen0_output_type      = <3>;
      +    screen0_output_mode      = <10>;
      +    screen0_output_format    = <0>;
      +    screen0_output_bits      = <0>;
      +    screen0_output_eotf      = <4>;
      +    screen0_output_cs        = <257>;
      +    screen0_output_dvi_hdmi  = <2>;
      +    screen0_output_range     = <2>;
      +    screen0_output_scan      = <0>;
      +    screen0_output_aspect_ratio = <8>;
      +    screen1_output_type      = <1>;
      +    screen1_output_mode      = <4>;
      +    dev0_output_type         = <4>;
      +    dev0_output_mode         = <10>;
      -       dev0_do_hpd              = <0>;
      -       dev1_output_type         = <4>;
      -       dev1_output_mode         = <10>;
      -       dev1_screen_id           = <1>;
      -       dev1_do_hpd              = <1>;
      +       dev0_do_hpd              = <1>;
      diff --git a/configs/nezha/uboot-board.dts b/configs/nezha/uboot-board.dts
      old mode 100644
      new mode 100755
      index 793dec2..a5c99a2
      --- a/configs/nezha/uboot-board.dts
      +++ b/configs/nezha/uboot-board.dts
      @@ -214,30 +214,25 @@
      (2)重新编译uboot
      因为单独make编译的时候默认是不编译ubootd的,所以需要编译一下uboot
      //进入uboot代码路径
      cboot
      //单独编译uboot,编完uboot文件会自动复制到方案下,不用管它
      muboot
      //重新编译打包
      make -j64
      pack
      (3)改掉启动logo(可选)
      sdk自带的启动logo是适配mipi屏幕的,在HDMI屏幕上显示会异常,所以建议改掉原SDK自带那个哪吒的启动logo,改成了linux小企鹅,大家可以把tina/device/config/chips/d1/configs/nezha/config 下面的bootlogo.bmp文件替换成下面这个文件:
      bootlogo.7z
      完成以上几步之后,插上HDMI并启动开发板,显示器上就会输出linux小企鹅的logo了
        DOT小文哥 LV 8 最后由 xiaowenge 编辑
        fdf0e760-7b81-42ad-851a-f4f133ea9f5c-image.png 。
          cloud_d1 LV 3 @xiaowenge 最后由 编辑
          @xiaowenge 可以了,赞
