    Allwiner D1 RISCV board default SD could not Boot
    • K
      KazuTakatashi LV 2 最后由 q1215200171 编辑
      Linux does not Boot!!
      Allwiner D1 RISCV board.
      How to fix this problem?
      partdata hi 0x0
      partdata lo 0x4059c
      sparse: bad magic
      [7210.789]successed in writting part dsp0
      [7210.794]fill gap start: volume dsp0 sects 0x1ed
      [7210.882]fill gap end: volume dsp0
      origin_verify value = 413a5c54, active_verify value = 413a5c54
      [7210.917]successed in verify part dsp0
      [7210.921]successed in download part dsp0
      [7210.924]begin to download part rootfs
      partdata hi 0x0
      partdata lo 0xede29000
      sparse: bad magic
      [7423.777]successed in writting part rootfs
      [7423.782]fill gap start: volume rootfs sects 0x890eb8
      [9125.436]fill gap end: volume rootfs
      [9125.443]ubi0 warning: ubi_io_read: error -22 while reading 225280 bytes from PEB 2135278096:36864, read only 0 bytes, retry
      [9125.454]ubi0 warning: ubi_io_read: error -22 while reading 225280 bytes from PEB 2135278096:36864, read only 0 bytes, retry
      [9125.465]ubi0 warning: ubi_io_read: error -22 while reading 225280 bytes from PEB 2135278096:36864, read only 0 bytes, retry
      [9125.476]ubi0 error: ubi_io_read: error -22 while reading 225280 bytes from PEB 2135278096:36864, read 0 bytes
      read err ffffffea
      sunxi sprite: read flash error when verify
      origin_verify value = be3b030e, active_verify value = 0
      origin checksum=be3b030e, active checksum=0
      sunxi sprite: part ROOTFS_FEX000000VROOTFS_FEX00000 verify error
      line:765 sunxi sprite err: sunxi_sprite_deal_part, download private failed
      sunxi sprite error : download part error
      sprite_test - do a sprite test
      Usage:
      sprite_test NULL
      gb2047 1 条回复 最后回复 回复 引用 分享 0
        WhycanService LV 8 最后由 编辑
        Reflash the firmware
        • gb2047
          mm LV 5 @KazuTakatashi 最后由 编辑
          @kazutakatashi how do you programm the sd card?
