    使用D1-H驱动树莓派DSI屏幕
    16
    45
    24694
    • mangogeek
      mangogeek LV 8 最后由 q1215200171 编辑
      续这位仁兄的贴子:https://bbs.aw-ol.com/topic/263
      屏幕链接:https://item.taobao.com/item.htm?id=623507778498
      转接板工程:
      d1-mipi-rpi.zip
      坑1:这个屏幕竟然是1lane,并非2lane。
      坑2:卖家没给具体时序参数,看来得从屏幕上iic配置抓。
      还没详细调时序参数,但初步已有显示。
      软件过几天有空了详细调试后整理上传。
      mangogeek 1 条回复 最后回复 回复 引用 分享 4
      • mangogeek
        mangogeek LV 8 @mangogeek 最后由 编辑
        还是有点偏,改天再抓数据研究😵 不能不过七夕啊对吧
        • tigger
          tigger LV 7 最后由 编辑
          大佬, 是这样改吗?
          只要改 linux-5.4/board.dts, uboot-board.dts 这两个文件就可以了吗?
          为什么我改完之后屏幕没有显示呢?
          • tigger
            tigger LV 7 最后由 编辑
            defaults:
            mtdids  : nand0=nand
            [00.760]ubi0: attaching mtd4
            [01.155]ubi0: scanning is finished
            [01.164]ubi0: attached mtd4 (name "sys", size 251 MiB)
            [01.169]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
            [01.175]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
            [01.182]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
            [01.188]ubi0: good PEBs: 1004, bad PEBs: 0, corrupted PEBs: 0
            [01.193]ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128
            [01.200]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
            [01.208]ubi0: available PEBs: 0, total reserved PEBs: 1004, PEBs reserved for bad PEB handling: 40
            [01.216]sunxi flash init ok
            [01.219]line:714 init_clocks
            __clk_init: clk pll_periph0x2 already initialized
            register fix_factor clk error
            [01.229]drv_disp_init
            request pwm success, pwm2:pwm2:0x2000c00.
            [01.246]drv_disp_init finish
            [01.248]boot_gui_init:start
            [01.251]set disp.dev2_output_type fail. using defval=0
            [01.443]boot_gui_init:finish
            早上看看,uboot都没启动。
            • tigger
              tigger LV 7 最后由 编辑
              defaults:
              mtdids  : nand0=nand
              [00.647]ubi0: attaching mtd4
              [01.042]ubi0: scanning is finished
              [01.052]ubi0: attached mtd4 (name "sys", size 251 MiB)
              [01.057]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
              [01.063]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
              [01.069]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
              [01.076]ubi0: good PEBs: 1004, bad PEBs: 0, corrupted PEBs: 0
              [01.081]ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128
              [01.088]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
              [01.095]ubi0: available PEBs: 0, total reserved PEBs: 1004, PEBs reserved for bad PEB handling: 40
              [01.104]sunxi flash init ok
              [01.107]line:714 init_clocks
              [01.117]drv_disp_init
              [01.134]drv_disp_init finish
              [01.136]boot_gui_init:start
              [01.139]set disp.dev2_output_type fail. using defval=0
              [01.331]boot_gui_init:finish
              [01.743]LCD open finish
              54 bytes read in 0 ms
              [01.904]bmp_name=bootlogo.bmp size 307254
              307254 bytes read in 30 ms (9.8 MiB/s)
              [02.148]Loading Environment from SUNXI_FLASH... OK
              [02.181]out of usb burn from boot: not need burn key
              [02.206]update bootcmd
              [02.228]change working_fdt 0x5eaafda8 to 0x5ea8fda8
              [02.249]update dts
              Android's image name: d1-nezha
              [03.178]
              Starting kernel ...
              [    0.000000] OF: fdt: Ignoring memory range 0x40000000 - 0x40200000
              [    0.000000] Linux version 5.4.61 (cube@ubuntu) (riscv64-unknown-linux-gnu-gcc (C-SKY RISCV Tools V1.8.4 B20200702) 8.1.0, GNU ld (GNU Binutils) 2.32) #37 PREEMPT Sat Aug 21 02:51:22 UTC 2021
              [    0.000000] cma: Reserved 8 MiB at 0x000000005f800000
              [    0.000000] Zone ranges:
              刚刚恢复了一下,正常的启动日志是这样的。
              • tigger
                tigger LV 7 最后由 编辑
                $ git diff nezha/uboot-board.dts
                diff --git a/configs/nezha/uboot-board.dts b/configs/nezha/uboot-board.dts
                index 793dec2..3df96b1 100644
                --- a/configs/nezha/uboot-board.dts
                +++ b/configs/nezha/uboot-board.dts
                @@ -268,10 +268,10 @@
                        lcd_if              = <4>;
                        lcd_x               = <800>;
                -       lcd_y               = <1280>;
                +       lcd_y               = <480>;
                        lcd_width           = <52>;
                        lcd_height          = <52>;
                -       lcd_dclk_freq       = <70>;
                +       lcd_dclk_freq       = <34>;
                        lcd_pwm_used        = <1>;
                        lcd_pwm_ch          = <2>;
                @@ -282,12 +282,12 @@
                        lcd_hbp             = <32>;
                        lcd_ht              = <868>;
                        lcd_hspw            = <4>;
                -       lcd_vbp             = <12>;
                -       lcd_vt              = <1311>;
                +       lcd_vbp             = <10>;
                +       lcd_vt              = <520>;
                        lcd_vspw            = <4>;
                        lcd_dsi_if          = <0>;
                -       lcd_dsi_lane        = <4>;
                +       lcd_dsi_lane        = <1>;
                        lcd_lvds_if         = <0>;
                        lcd_lvds_colordepth = <0>;
                        lcd_lvds_mode       = <0>;
                $ git diff nezha/linux-5.4/board.dts
                diff --git a/configs/nezha/linux-5.4/board.dts b/configs/nezha/linux-5.4/board.dts
                index bfeed6c..de0cacf 100755
                --- a/configs/nezha/linux-5.4/board.dts
                +++ b/configs/nezha/linux-5.4/board.dts
                @@ -1240,26 +1240,33 @@ pull up or pull down(default 0), driver level(default 1), data>
                        lcd_if              = <4>;
                        lcd_x               = <800>;
                -       lcd_y               = <1280>;
                +       lcd_y               = <480>;
                        lcd_width           = <52>;
                        lcd_height          = <52>;
                        lcd_pwm_used        = <1>;
                        lcd_pwm_ch          = <2>;
                        lcd_pwm_freq        = <1000>;
                        lcd_pwm_pol         = <0>;
                        lcd_pwm_max_limit   = <255>;
                        lcd_hbp             = <32>;
                        lcd_ht              = <868>;
                        lcd_hspw            = <4>;
                        lcd_vbp             = <12>;
                -       lcd_vt              = <1311>;
                +       lcd_vt              = <500>;
                        lcd_vspw            = <4>;
                +        lcd_hbp             = <32>;
                +        lcd_ht              = <868>;
                +        lcd_hspw            = <4>;
                +        lcd_vbp             = <10>;
                +        lcd_vt              = <520>;
                +        lcd_vspw            = <4>;
                        lcd_dsi_if          = <0>;
                        lcd_lvds_if         = <0>;
                经过芒果大佬提醒,再查看A20手册,终于把这个树莓派 MIPI DSI屏幕点亮了。
                • tigger
                  tigger LV 7 最后由 编辑
                  烧录文件下载: tina_d1-nezha_uart0.img
                  鼠标设备: /dev/input/event3
                  T 1 条回复 最后回复 回复 引用 分享 0
                  • mangogeek
                    mangogeek LV 8 最后由 编辑
                    按照晕哥的修改方法就可以显示。贴一下我暂时用的参数:
                    	lcd_dclk_freq       = <27>;
                    	lcd_hbp             = <25>;
                    	lcd_ht              = <871>;
                    	lcd_hspw            = <14>;
                    	lcd_vbp             = <40>;
                    	lcd_vt              = <550>;
                    	lcd_vspw            = <4>;
                    如果是默认的sdk 1.0.1,修改完后在uboot启动logo时会报个图片太大的错误,修改下configs目录的bootlogo.bmp就行:
                    bootlogo.zip
                    W T 2 条回复 最后回复 回复 引用 分享 0
                    • U
                      ubuntu LV 7 最后由 编辑
                      不错噢,LVGL快速滑动的时候,CPU占用率35%,保持33FPS。
                      • tigger
                        tigger LV 7 最后由 编辑
                        mangogeek Z 2 条回复 最后回复 回复 引用 分享 0
                        • mangogeek
                          mangogeek LV 8 @tigger 最后由 编辑
                          @tigger 这流畅度可以啊
                          • tigger
                            tigger LV 7 最后由 编辑
                            Qt 整起来。
                            • tigger
                              tigger LV 7 最后由 whycan 编辑
                              QWS_MOUSE_PROTO=IntelliMouse:/dev/input/mice QT_QPA_FONTDIR=/usr/share/fonts/wqy-zenhei/ /usr/lib/qt/examples/widgets/widgets/calculator/calculator -platform linuxfb
                              BedRock mangogeek 2 条回复 最后回复 回复 引用 分享 0
                              • BedRock
                                BedRock LV 6 @tigger 最后由 whycan 编辑
                                @tigger
                                QT 帧率咋样,O不OK😀 😀 😀
                                tigger 1 条回复 最后回复 回复 引用 分享 0
                                • tigger
                                  tigger LV 7 @BedRock 最后由 编辑
                                  @bedrock 我去找到Qt测帧率的app试一试。
                                  • mangogeek
                                    @tigger 这QT,保熟吗?😁
                                    • tigger
                                      tigger LV 7 @mangogeek 最后由 编辑
                                      @mangogeek
                                      【极简操作】使用builroot 2021一键编译生成D1 nezha 系统镜像!
                                      https://bbs.aw-ol.com/topic/171
                                      就是用韦老师这个 buildroot 勾选Qt5就可以了
                                      # Automatically generated file; DO NOT EDIT.
                                      # Buildroot -g51c4355-dirty Configuration
                                      BR2_HAVE_DOT_CONFIG=y
                                      BR2_HOST_GCC_AT_LEAST_4_9=y
                                      BR2_HOST_GCC_AT_LEAST_5=y
                                      BR2_HOST_GCC_AT_LEAST_6=y
                                      BR2_HOST_GCC_AT_LEAST_7=y
                                      # Target options
                                      BR2_ARCH_IS_64=y
                                      BR2_ARCH_HAS_MMU_MANDATORY=y
                                      # BR2_arcle is not set
                                      # BR2_arceb is not set
                                      # BR2_arm is not set
                                      # BR2_armeb is not set
                                      # BR2_aarch64 is not set
                                      # BR2_aarch64_be is not set
                                      # BR2_csky is not set
                                      # BR2_i386 is not set
                                      # BR2_m68k is not set
                                      # BR2_microblazeel is not set
                                      # BR2_microblazebe is not set
                                      # BR2_mips is not set
                                      # BR2_mipsel is not set
                                      # BR2_mips64 is not set
                                      # BR2_mips64el is not set
                                      # BR2_nds32 is not set
                                      # BR2_nios2 is not set
                                      # BR2_or1k is not set
                                      # BR2_powerpc is not set
                                      # BR2_powerpc64 is not set
                                      # BR2_powerpc64le is not set
                                      BR2_riscv=y
                                      # BR2_s390x is not set
                                      # BR2_sh is not set
                                      # BR2_sparc is not set
                                      # BR2_sparc64 is not set
                                      # BR2_x86_64 is not set
                                      # BR2_xtensa is not set
                                      BR2_ARCH_HAS_TOOLCHAIN_BUILDROOT=y
                                      BR2_ARCH_NEEDS_GCC_AT_LEAST_4_8=y
                                      BR2_ARCH_NEEDS_GCC_AT_LEAST_4_9=y
                                      BR2_ARCH_NEEDS_GCC_AT_LEAST_5=y
                                      BR2_ARCH_NEEDS_GCC_AT_LEAST_6=y
                                      BR2_ARCH_NEEDS_GCC_AT_LEAST_7=y
                                      BR2_ARCH="riscv64"
                                      BR2_ENDIAN="LITTLE"
                                      BR2_GCC_TARGET_ABI="lp64d"
                                      BR2_BINFMT_SUPPORTS_SHARED=y
                                      BR2_READELF_ARCH_NAME="RISC-V"
                                      BR2_BINFMT_ELF=y
                                      BR2_RISCV_ISA_RVI=y
                                      BR2_RISCV_ISA_RVM=y
                                      BR2_RISCV_ISA_RVA=y
                                      BR2_RISCV_ISA_RVF=y
                                      BR2_RISCV_ISA_RVD=y
                                      BR2_riscv_g=y
                                      # BR2_riscv_custom is not set
                                      # BR2_RISCV_32 is not set
                                      BR2_RISCV_64=y
                                      # BR2_RISCV_ABI_LP64 is not set
                                      # BR2_RISCV_ABI_LP64F is not set
                                      BR2_RISCV_ABI_LP64D=y
                                      # Build options
                                      # Commands
                                      BR2_WGET="wget --passive-ftp -nd -t 3"
                                      BR2_SVN="svn --non-interactive"
                                      BR2_BZR="bzr"
                                      BR2_GIT="git"
                                      BR2_CVS="cvs"
                                      BR2_LOCALFILES="cp"
                                      BR2_SCP="scp"
                                      BR2_HG="hg"
                                      BR2_ZCAT="gzip -d -c"
                                      BR2_BZCAT="bzcat"
                                      BR2_XZCAT="xzcat"
                                      BR2_LZCAT="lzip -d -c"
                                      BR2_TAR_OPTIONS=""
                                      BR2_DEFCONFIG="/home/book/Buildroot/guanfang/buildroot-2021.02.1/configs/hifive_unleashed_defconfig"
                                      BR2_DL_DIR="$(TOPDIR)/dl"
                                      BR2_HOST_DIR="$(BASE_DIR)/host"
                                      # Mirrors and Download locations
                                      BR2_PRIMARY_SITE=""
                                      BR2_BACKUP_SITE="http://sources.buildroot.net"
                                      BR2_KERNEL_MIRROR="https://cdn.kernel.org/pub"
                                      BR2_GNU_MIRROR="http://ftpmirror.gnu.org"
                                      BR2_LUAROCKS_MIRROR="http://rocks.moonscript.org"
                                      BR2_CPAN_MIRROR="http://cpan.metacpan.org"
                                      BR2_JLEVEL=0
                                      # BR2_CCACHE is not set
                                      # BR2_ENABLE_DEBUG is not set
                                      BR2_STRIP_strip=y
                                      BR2_STRIP_EXCLUDE_FILES=""
                                      BR2_STRIP_EXCLUDE_DIRS=""
                                      # BR2_OPTIMIZE_0 is not set
                                      # BR2_OPTIMIZE_1 is not set
                                      # BR2_OPTIMIZE_2 is not set
                                      # BR2_OPTIMIZE_3 is not set
                                      # BR2_OPTIMIZE_G is not set
                                      BR2_OPTIMIZE_S=y
                                      # BR2_OPTIMIZE_FAST is not set
                                      # BR2_STATIC_LIBS is not set
                                      BR2_SHARED_LIBS=y
                                      # BR2_SHARED_STATIC_LIBS is not set
                                      BR2_PACKAGE_OVERRIDE_FILE="$(CONFIG_DIR)/local.mk"
                                      BR2_GLOBAL_PATCH_DIR=""
                                      # Advanced
                                      BR2_COMPILER_PARANOID_UNSAFE_PATH=y
                                      # BR2_FORCE_HOST_BUILD is not set
                                      # BR2_REPRODUCIBLE is not set
                                      # BR2_PER_PACKAGE_DIRECTORIES is not set
                                      # Security Hardening Options
                                      # BR2_PIC_PIE is not set
                                      BR2_SSP_NONE=y
                                      # BR2_SSP_REGULAR is not set
                                      # BR2_SSP_STRONG is not set
                                      # BR2_SSP_ALL is not set
                                      BR2_RELRO_NONE=y
                                      # BR2_RELRO_PARTIAL is not set
                                      # BR2_RELRO_FULL is not set
                                      BR2_FORTIFY_SOURCE_NONE=y
                                      # BR2_FORTIFY_SOURCE_1 is not set
                                      # BR2_FORTIFY_SOURCE_2 is not set
                                      # Toolchain
                                      BR2_TOOLCHAIN=y
                                      BR2_TOOLCHAIN_USES_GLIBC=y
                                      # BR2_TOOLCHAIN_BUILDROOT is not set
                                      BR2_TOOLCHAIN_EXTERNAL=y
                                      # Toolchain External Options
                                      BR2_TOOLCHAIN_EXTERNAL_CUSTOM=y
                                      BR2_TOOLCHAIN_EXTERNAL_DOWNLOAD=y
                                      # BR2_TOOLCHAIN_EXTERNAL_PREINSTALLED is not set
                                      BR2_TOOLCHAIN_EXTERNAL_GLIBC=y
                                      BR2_PACKAGE_HAS_TOOLCHAIN_EXTERNAL=y
                                      BR2_PACKAGE_PROVIDES_TOOLCHAIN_EXTERNAL="toolchain-external-custom"
                                      BR2_TOOLCHAIN_EXTERNAL_PREFIX="$(ARCH)-unknown-linux-gnu"
                                      BR2_TOOLCHAIN_EXTERNAL_URL="https://weidongshan.coding.net/p/Tina-D1/d/Toolchain/git/raw/master/riscv64-glibc-gcc-thead_20200702.tar.xz"
                                      BR2_TOOLCHAIN_EXTERNAL_REL_BIN_PATH="bin"
                                      BR2_TOOLCHAIN_EXTERNAL_CUSTOM_PREFIX="$(ARCH)-unknown-linux-gnu"
                                      # BR2_TOOLCHAIN_EXTERNAL_GCC_10 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_GCC_9 is not set
                                      BR2_TOOLCHAIN_EXTERNAL_GCC_8=y
                                      # BR2_TOOLCHAIN_EXTERNAL_GCC_7 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_GCC_6 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_GCC_5 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_GCC_4_9 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_GCC_4_8 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_GCC_4_7 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_GCC_4_6 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_GCC_4_5 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_GCC_4_4 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_GCC_4_3 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_GCC_OLD is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_5_10 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_5_9 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_5_8 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_5_7 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_5_6 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_5_5 is not set
                                      BR2_TOOLCHAIN_EXTERNAL_HEADERS_5_4=y
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_5_3 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_5_2 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_5_1 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_5_0 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_20 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_19 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_18 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_17 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_16 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_15 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_14 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_13 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_12 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_11 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_10 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_9 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_8 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_7 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_6 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_5 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_4 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_3 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_2 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_1 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_4_0 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_19 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_18 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_17 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_16 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_15 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_14 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_13 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_12 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_11 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_10 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_9 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_8 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_7 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_6 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_5 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_4 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_3 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_2 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_1 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_3_0 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_HEADERS_REALLY_OLD is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_CUSTOM_UCLIBC is not set
                                      BR2_TOOLCHAIN_EXTERNAL_CUSTOM_GLIBC=y
                                      # BR2_TOOLCHAIN_EXTERNAL_CUSTOM_MUSL is not set
                                      BR2_TOOLCHAIN_EXTERNAL_HAS_SSP=y
                                      BR2_TOOLCHAIN_EXTERNAL_HAS_SSP_STRONG=y
                                      BR2_TOOLCHAIN_EXTERNAL_INET_RPC=y
                                      BR2_TOOLCHAIN_EXTERNAL_CXX=y
                                      # BR2_TOOLCHAIN_EXTERNAL_DLANG is not set
                                      BR2_TOOLCHAIN_EXTERNAL_FORTRAN=y
                                      BR2_TOOLCHAIN_EXTERNAL_OPENMP=y
                                      # BR2_TOOLCHAIN_EXTERNAL_GDB_SERVER_COPY is not set
                                      # Toolchain Generic Options
                                      BR2_TOOLCHAIN_SUPPORTS_ALWAYS_LOCKFREE_ATOMIC_INTS=y
                                      BR2_TOOLCHAIN_SUPPORTS_VARIADIC_MI_THUNK=y
                                      BR2_TOOLCHAIN_HAS_NATIVE_RPC=y
                                      BR2_USE_WCHAR=y
                                      BR2_ENABLE_LOCALE=y
                                      BR2_INSTALL_LIBSTDCPP=y
                                      BR2_TOOLCHAIN_HAS_FORTRAN=y
                                      BR2_TOOLCHAIN_HAS_THREADS=y
                                      BR2_TOOLCHAIN_HAS_THREADS_DEBUG=y
                                      BR2_TOOLCHAIN_HAS_THREADS_NPTL=y
                                      BR2_TOOLCHAIN_HAS_SSP=y
                                      BR2_TOOLCHAIN_HAS_SSP_STRONG=y
                                      BR2_TOOLCHAIN_HAS_UCONTEXT=y
                                      BR2_TOOLCHAIN_HAS_OPENMP=y
                                      BR2_TOOLCHAIN_SUPPORTS_PIE=y
                                      # BR2_TOOLCHAIN_GLIBC_GCONV_LIBS_COPY is not set
                                      BR2_TOOLCHAIN_EXTRA_LIBS="lib64xthead lib64vxthead"
                                      BR2_TOOLCHAIN_HAS_FULL_GETTEXT=y
                                      BR2_USE_MMU=y
                                      BR2_TARGET_OPTIMIZATION="-Os -pipe -mcmodel=medany -mabi=lp64d -march=rv64gcxthead"
                                      BR2_TARGET_LDFLAGS=""
                                      # BR2_ECLIPSE_REGISTER is not set
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_0=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_1=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_2=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_3=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_4=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_5=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_6=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_7=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_8=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_9=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_10=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_11=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_12=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_13=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_14=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_15=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_16=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_17=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_18=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_19=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_0=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_1=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_2=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_3=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_4=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_5=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_6=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_7=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_8=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_9=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_10=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_11=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_12=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_13=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_14=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_15=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_16=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_17=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_18=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_19=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_20=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_5_0=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_5_1=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_5_2=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_5_3=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST_5_4=y
                                      BR2_TOOLCHAIN_HEADERS_AT_LEAST="5.4"
                                      BR2_TOOLCHAIN_GCC_AT_LEAST_4_3=y
                                      BR2_TOOLCHAIN_GCC_AT_LEAST_4_4=y
                                      BR2_TOOLCHAIN_GCC_AT_LEAST_4_5=y
                                      BR2_TOOLCHAIN_GCC_AT_LEAST_4_6=y
                                      BR2_TOOLCHAIN_GCC_AT_LEAST_4_7=y
                                      BR2_TOOLCHAIN_GCC_AT_LEAST_4_8=y
                                      BR2_TOOLCHAIN_GCC_AT_LEAST_4_9=y
                                      BR2_TOOLCHAIN_GCC_AT_LEAST_5=y
                                      BR2_TOOLCHAIN_GCC_AT_LEAST_6=y
                                      BR2_TOOLCHAIN_GCC_AT_LEAST_7=y
                                      BR2_TOOLCHAIN_GCC_AT_LEAST_8=y
                                      BR2_TOOLCHAIN_GCC_AT_LEAST="8"
                                      BR2_TOOLCHAIN_HAS_MNAN_OPTION=y
                                      BR2_TOOLCHAIN_HAS_SYNC_1=y
                                      BR2_TOOLCHAIN_HAS_SYNC_2=y
                                      BR2_TOOLCHAIN_HAS_SYNC_4=y
                                      BR2_TOOLCHAIN_HAS_SYNC_8=y
                                      BR2_TOOLCHAIN_HAS_LIBATOMIC=y
                                      BR2_TOOLCHAIN_HAS_ATOMIC=y
                                      # System configuration
                                      BR2_ROOTFS_SKELETON_DEFAULT=y
                                      # BR2_ROOTFS_SKELETON_CUSTOM is not set
                                      BR2_TARGET_GENERIC_HOSTNAME="buildroot"
                                      BR2_TARGET_GENERIC_ISSUE="Welcome to Buildroot"
                                      BR2_TARGET_GENERIC_PASSWD_SHA256=y
                                      # BR2_TARGET_GENERIC_PASSWD_SHA512 is not set
                                      BR2_TARGET_GENERIC_PASSWD_METHOD="sha-256"
                                      BR2_INIT_BUSYBOX=y
                                      # BR2_INIT_SYSV is not set
                                      # BR2_INIT_OPENRC is not set
                                      # BR2_INIT_SYSTEMD is not set
                                      # BR2_INIT_NONE is not set
                                      # BR2_ROOTFS_DEVICE_CREATION_STATIC is not set
                                      # BR2_ROOTFS_DEVICE_CREATION_DYNAMIC_DEVTMPFS is not set
                                      # BR2_ROOTFS_DEVICE_CREATION_DYNAMIC_MDEV is not set
                                      BR2_ROOTFS_DEVICE_CREATION_DYNAMIC_EUDEV=y
                                      BR2_ROOTFS_DEVICE_TABLE="system/device_table.txt"
                                      # BR2_ROOTFS_DEVICE_TABLE_SUPPORTS_EXTENDED_ATTRIBUTES is not set
                                      # BR2_ROOTFS_MERGED_USR is not set
                                      BR2_TARGET_ENABLE_ROOT_LOGIN=y
                                      BR2_TARGET_GENERIC_ROOT_PASSWD=""
                                      BR2_SYSTEM_BIN_SH_BUSYBOX=y
                                      # bash, dash, mksh, zsh need BR2_PACKAGE_BUSYBOX_SHOW_OTHERS
                                      # BR2_SYSTEM_BIN_SH_NONE is not set
                                      BR2_TARGET_GENERIC_GETTY=y
                                      BR2_TARGET_GENERIC_GETTY_PORT="ttyS0"
                                      BR2_TARGET_GENERIC_GETTY_BAUDRATE_KEEP=y
                                      # BR2_TARGET_GENERIC_GETTY_BAUDRATE_9600 is not set
                                      # BR2_TARGET_GENERIC_GETTY_BAUDRATE_19200 is not set
                                      # BR2_TARGET_GENERIC_GETTY_BAUDRATE_38400 is not set
                                      # BR2_TARGET_GENERIC_GETTY_BAUDRATE_57600 is not set
                                      # BR2_TARGET_GENERIC_GETTY_BAUDRATE_115200 is not set
                                      BR2_TARGET_GENERIC_GETTY_BAUDRATE="0"
                                      BR2_TARGET_GENERIC_GETTY_TERM="vt100"
                                      BR2_TARGET_GENERIC_GETTY_OPTIONS=""
                                      BR2_TARGET_GENERIC_REMOUNT_ROOTFS_RW=y
                                      BR2_SYSTEM_DHCP="eth0"
                                      BR2_SYSTEM_DEFAULT_PATH="/bin:/sbin:/usr/bin:/usr/sbin"
                                      BR2_ENABLE_LOCALE_PURGE=y
                                      BR2_ENABLE_LOCALE_WHITELIST="C en_US"
                                      BR2_GENERATE_LOCALE=""
                                      # BR2_SYSTEM_ENABLE_NLS is not set
                                      # BR2_TARGET_TZ_INFO is not set
                                      BR2_ROOTFS_USERS_TABLES=""
                                      BR2_ROOTFS_OVERLAY=""
                                      BR2_ROOTFS_POST_BUILD_SCRIPT="board/Neza/d1/post-build.sh"
                                      BR2_ROOTFS_POST_FAKEROOT_SCRIPT=""
                                      BR2_ROOTFS_POST_IMAGE_SCRIPT="support/scripts/genimage.sh"
                                      BR2_ROOTFS_POST_SCRIPT_ARGS="-c board/Neza/d1/genimage.cfg"
                                      # Kernel
                                      BR2_LINUX_KERNEL=y
                                      # BR2_LINUX_KERNEL_LATEST_VERSION is not set
                                      # BR2_LINUX_KERNEL_LATEST_CIP_VERSION is not set
                                      # BR2_LINUX_KERNEL_LATEST_CIP_RT_VERSION is not set
                                      # BR2_LINUX_KERNEL_CUSTOM_VERSION is not set
                                      # BR2_LINUX_KERNEL_CUSTOM_TARBALL is not set
                                      BR2_LINUX_KERNEL_CUSTOM_GIT=y
                                      # BR2_LINUX_KERNEL_CUSTOM_HG is not set
                                      # BR2_LINUX_KERNEL_CUSTOM_SVN is not set
                                      BR2_LINUX_KERNEL_CUSTOM_REPO_URL="https://gitee.com/weidongshan/NezaD1-linuxkernel.git"
                                      BR2_LINUX_KERNEL_CUSTOM_REPO_VERSION="origin/master"
                                      BR2_LINUX_KERNEL_VERSION="origin/master"
                                      BR2_LINUX_KERNEL_PATCH=""
                                      BR2_LINUX_KERNEL_USE_DEFCONFIG=y
                                      # BR2_LINUX_KERNEL_USE_ARCH_DEFAULT_CONFIG is not set
                                      # BR2_LINUX_KERNEL_USE_CUSTOM_CONFIG is not set
                                      BR2_LINUX_KERNEL_DEFCONFIG="sun20iw1p1_d1"
                                      BR2_LINUX_KERNEL_CONFIG_FRAGMENT_FILES=""
                                      BR2_LINUX_KERNEL_CUSTOM_LOGO_PATH=""
                                      BR2_LINUX_KERNEL_IMAGE=y
                                      # BR2_LINUX_KERNEL_IMAGEGZ is not set
                                      # BR2_LINUX_KERNEL_VMLINUX is not set
                                      # BR2_LINUX_KERNEL_IMAGE_TARGET_CUSTOM is not set
                                      BR2_LINUX_KERNEL_GZIP=y
                                      # BR2_LINUX_KERNEL_LZ4 is not set
                                      # BR2_LINUX_KERNEL_LZMA is not set
                                      # BR2_LINUX_KERNEL_LZO is not set
                                      # BR2_LINUX_KERNEL_XZ is not set
                                      # BR2_LINUX_KERNEL_ZSTD is not set
                                      BR2_LINUX_KERNEL_DTS_SUPPORT=y
                                      # BR2_LINUX_KERNEL_DTB_IS_SELF_BUILT is not set
                                      BR2_LINUX_KERNEL_INTREE_DTS_NAME="board"
                                      BR2_LINUX_KERNEL_CUSTOM_DTS_PATH=""
                                      # BR2_LINUX_KERNEL_DTB_KEEP_DIRNAME is not set
                                      # BR2_LINUX_KERNEL_DTB_OVERLAY_SUPPORT is not set
                                      # BR2_LINUX_KERNEL_INSTALL_TARGET is not set
                                      BR2_LINUX_KERNEL_NEEDS_HOST_OPENSSL=y
                                      BR2_LINUX_KERNEL_NEEDS_HOST_LIBELF=y
                                      # Linux Kernel Extensions
                                      # BR2_LINUX_KERNEL_EXT_RTAI is not set
                                      # BR2_LINUX_KERNEL_EXT_EV3DEV_LINUX_DRIVERS is not set
                                      # BR2_LINUX_KERNEL_EXT_FBTFT is not set
                                      # BR2_LINUX_KERNEL_EXT_AUFS is not set
                                      # Linux Kernel Tools
                                      # BR2_PACKAGE_LINUX_TOOLS_CPUPOWER is not set
                                      # BR2_PACKAGE_LINUX_TOOLS_GPIO is not set
                                      # BR2_PACKAGE_LINUX_TOOLS_IIO is not set
                                      # BR2_PACKAGE_LINUX_TOOLS_PCI is not set
                                      # BR2_PACKAGE_LINUX_TOOLS_PERF is not set
                                      # selftests needs BR2_PACKAGE_BUSYBOX_SHOW_OTHERS and a toolchain w/ dynamic library
                                      # BR2_PACKAGE_LINUX_TOOLS_TMON is not set
                                      # Target packages
                                      BR2_PACKAGE_BUSYBOX=y
                                      BR2_PACKAGE_BUSYBOX_CONFIG="package/busybox/busybox.config"
                                      BR2_PACKAGE_BUSYBOX_CONFIG_FRAGMENT_FILES=""
                                      # BR2_PACKAGE_BUSYBOX_SHOW_OTHERS is not set
                                      # BR2_PACKAGE_BUSYBOX_INDIVIDUAL_BINARIES is not set
                                      # BR2_PACKAGE_BUSYBOX_WATCHDOG is not set
                                      BR2_PACKAGE_SKELETON=y
                                      BR2_PACKAGE_HAS_SKELETON=y
                                      BR2_PACKAGE_PROVIDES_SKELETON="skeleton-init-sysv"
                                      BR2_PACKAGE_SKELETON_INIT_COMMON=y
                                      BR2_PACKAGE_SKELETON_INIT_SYSV=y
                                      # Audio and video applications
                                      # BR2_PACKAGE_ALSA_UTILS is not set
                                      # BR2_PACKAGE_ATEST is not set
                                      # BR2_PACKAGE_AUMIX is not set
                                      # BR2_PACKAGE_BLUEZ_ALSA is not set
                                      # BR2_PACKAGE_DVBLAST is not set
                                      # BR2_PACKAGE_DVDAUTHOR is not set
                                      # BR2_PACKAGE_DVDRW_TOOLS is not set
                                      # BR2_PACKAGE_ESPEAK is not set
                                      # BR2_PACKAGE_FAAD2 is not set
                                      BR2_PACKAGE_FFMPEG_ARCH_SUPPORTS=y
                                      # BR2_PACKAGE_FFMPEG is not set
                                      # BR2_PACKAGE_FLAC is not set
                                      # BR2_PACKAGE_FLITE is not set
                                      # BR2_PACKAGE_FLUID_SOUNDFONT is not set
                                      # BR2_PACKAGE_FLUIDSYNTH is not set
                                      # BR2_PACKAGE_GMRENDER_RESURRECT is not set
                                      # BR2_PACKAGE_GSTREAMER1 is not set
                                      # BR2_PACKAGE_JACK1 is not set
                                      # BR2_PACKAGE_JACK2 is not set
                                      BR2_PACKAGE_KODI_ARCH_SUPPORTS=y
                                      # kodi needs python w/ .py modules, a uClibc or glibc toolchain w/ C++, threads, wchar, dynamic library, gcc >= 4.8
                                      # kodi needs an OpenGL EGL backend with OpenGL support
                                      # BR2_PACKAGE_LAME is not set
                                      # BR2_PACKAGE_MADPLAY is not set
                                      # BR2_PACKAGE_MIMIC is not set
                                      # BR2_PACKAGE_MINIMODEM is not set
                                      # miraclecast needs systemd and a glibc toolchain w/ threads and wchar
                                      # BR2_PACKAGE_MJPEGTOOLS is not set
                                      # BR2_PACKAGE_MODPLUGTOOLS is not set
                                      # BR2_PACKAGE_MOTION is not set
                                      # BR2_PACKAGE_MPD is not set
                                      # BR2_PACKAGE_MPD_MPC is not set
                                      # BR2_PACKAGE_MPG123 is not set
                                      # BR2_PACKAGE_MPV is not set
                                      # BR2_PACKAGE_MULTICAT is not set
                                      # BR2_PACKAGE_MUSEPACK is not set
                                      # BR2_PACKAGE_NCMPC is not set
                                      # BR2_PACKAGE_OPUS_TOOLS is not set
                                      BR2_PACKAGE_PULSEAUDIO_HAS_ATOMIC=y
                                      # BR2_PACKAGE_PULSEAUDIO is not set
                                      # BR2_PACKAGE_SOX is not set
                                      # BR2_PACKAGE_SQUEEZELITE is not set
                                      # BR2_PACKAGE_TSTOOLS is not set
                                      # BR2_PACKAGE_TWOLAME is not set
                                      # BR2_PACKAGE_UDPXY is not set
                                      # BR2_PACKAGE_UPMPDCLI is not set
                                      # BR2_PACKAGE_V4L2GRAB is not set
                                      # BR2_PACKAGE_V4L2LOOPBACK is not set
                                      # BR2_PACKAGE_VLC is not set
                                      # BR2_PACKAGE_VORBIS_TOOLS is not set
                                      # BR2_PACKAGE_WAVPACK is not set
                                      # BR2_PACKAGE_YAVTA is not set
                                      # BR2_PACKAGE_YMPD is not set
                                      # Compressors and decompressors
                                      # BR2_PACKAGE_BROTLI is not set
                                      # BR2_PACKAGE_BZIP2 is not set
                                      # BR2_PACKAGE_LRZIP is not set
                                      # BR2_PACKAGE_LZIP is not set
                                      # BR2_PACKAGE_LZOP is not set
                                      # BR2_PACKAGE_P7ZIP is not set
                                      # BR2_PACKAGE_PIGZ is not set
                                      # BR2_PACKAGE_PIXZ is not set
                                      # BR2_PACKAGE_UNRAR is not set
                                      # BR2_PACKAGE_XZ is not set
                                      # BR2_PACKAGE_ZIP is not set
                                      # BR2_PACKAGE_ZSTD is not set
                                      # Debugging, profiling and benchmark
                                      # BR2_PACKAGE_BABELTRACE2 is not set
                                      # BR2_PACKAGE_BLKTRACE is not set
                                      # BR2_PACKAGE_BONNIE is not set
                                      # BR2_PACKAGE_CACHE_CALIBRATOR is not set
                                      # clinfo needs an OpenCL provider
                                      # BR2_PACKAGE_COREMARK is not set
                                      # BR2_PACKAGE_COREMARK_PRO is not set
                                      # dacapo needs OpenJDK
                                      # BR2_PACKAGE_DHRYSTONE is not set
                                      # BR2_PACKAGE_DIEHARDER is not set
                                      # BR2_PACKAGE_DMALLOC is not set
                                      # BR2_PACKAGE_DROPWATCH is not set
                                      # BR2_PACKAGE_DSTAT is not set
                                      # BR2_PACKAGE_DT is not set
                                      # BR2_PACKAGE_DUMA is not set
                                      # BR2_PACKAGE_FIO is not set
                                      BR2_PACKAGE_GDB_ARCH_SUPPORTS=y
                                      # BR2_PACKAGE_GDB is not set
                                      # BR2_PACKAGE_IOZONE is not set
                                      # BR2_PACKAGE_KTAP is not set
                                      # BR2_PACKAGE_KYUA is not set
                                      # BR2_PACKAGE_LATENCYTOP is not set
                                      # BR2_PACKAGE_LMBENCH is not set
                                      BR2_PACKAGE_LTP_TESTSUITE_ARCH_SUPPORTS=y
                                      # BR2_PACKAGE_LTP_TESTSUITE is not set
                                      # BR2_PACKAGE_LTTNG_BABELTRACE is not set
                                      # BR2_PACKAGE_LTTNG_MODULES is not set
                                      # BR2_PACKAGE_LTTNG_TOOLS is not set
                                      # BR2_PACKAGE_MEMSTAT is not set
                                      # BR2_PACKAGE_NETPERF is not set
                                      # BR2_PACKAGE_NETSNIFF_NG is not set
                                      # BR2_PACKAGE_NMON is not set
                                      # BR2_PACKAGE_PAX_UTILS is not set
                                      # BR2_PACKAGE_PV is not set
                                      # BR2_PACKAGE_RAMSMP is not set
                                      # BR2_PACKAGE_RAMSPEED is not set
                                      # BR2_PACKAGE_SPIDEV_TEST is not set
                                      # BR2_PACKAGE_STRACE is not set
                                      # BR2_PACKAGE_STRESS is not set
                                      # BR2_PACKAGE_STRESS_NG is not set
                                      # sysdig needs a glibc or uclibc toolchain w/ C++, threads, gcc >= 4.8, dynamic library, a Linux kernel, and luajit or lua 5.1 to be built
                                      # BR2_PACKAGE_TINYMEMBENCH is not set
                                      # BR2_PACKAGE_TRACE_CMD is not set
                                      # BR2_PACKAGE_UCLIBC_NG_TEST is not set
                                      BR2_PACKAGE_VALGRIND_ARCH_SUPPORTS=y
                                      # BR2_PACKAGE_VALGRIND is not set
                                      # BR2_PACKAGE_VMTOUCH is not set
                                      # BR2_PACKAGE_WHETSTONE is not set
                                      # Development tools
                                      # BR2_PACKAGE_BINUTILS is not set
                                      # BR2_PACKAGE_BITWISE is not set
                                      # BR2_PACKAGE_BSDIFF is not set
                                      # BR2_PACKAGE_CHECK is not set
                                      # BR2_PACKAGE_CPPUNIT is not set
                                      # BR2_PACKAGE_CUKINIA is not set
                                      # BR2_PACKAGE_CUNIT is not set
                                      # BR2_PACKAGE_CVS is not set
                                      # BR2_PACKAGE_CXXTEST is not set
                                      # BR2_PACKAGE_FLEX is not set
                                      # BR2_PACKAGE_GETTEXT is not set
                                      BR2_PACKAGE_PROVIDES_HOST_GETTEXT="host-gettext-tiny"
                                      # BR2_PACKAGE_GIT is not set
                                      # BR2_PACKAGE_GIT_CRYPT is not set
                                      # BR2_PACKAGE_GPERF is not set
                                      # BR2_PACKAGE_JO is not set
                                      # BR2_PACKAGE_JQ is not set
                                      # BR2_PACKAGE_LIBTOOL is not set
                                      # BR2_PACKAGE_MAKE is not set
                                      # BR2_PACKAGE_PKGCONF is not set
                                      # BR2_PACKAGE_SUBVERSION is not set
                                      # BR2_PACKAGE_TREE is not set
                                      # Filesystem and flash utilities
                                      # BR2_PACKAGE_ABOOTIMG is not set
                                      # BR2_PACKAGE_AUFS_UTIL is not set
                                      # BR2_PACKAGE_AUTOFS is not set
                                      # BR2_PACKAGE_BTRFS_PROGS is not set
                                      # BR2_PACKAGE_CIFS_UTILS is not set
                                      # BR2_PACKAGE_CPIO is not set
                                      # BR2_PACKAGE_CRAMFS is not set
                                      # BR2_PACKAGE_CURLFTPFS is not set
                                      # BR2_PACKAGE_DAVFS2 is not set
                                      # BR2_PACKAGE_DOSFSTOOLS is not set
                                      BR2_PACKAGE_E2FSPROGS=y
                                      BR2_PACKAGE_E2FSPROGS_DEBUGFS=y
                                      BR2_PACKAGE_E2FSPROGS_E2IMAGE=y
                                      BR2_PACKAGE_E2FSPROGS_E4DEFRAG=y
                                      BR2_PACKAGE_E2FSPROGS_FSCK=y
                                      BR2_PACKAGE_E2FSPROGS_FUSE2FS=y
                                      BR2_PACKAGE_E2FSPROGS_RESIZE2FS=y
                                      # BR2_PACKAGE_E2TOOLS is not set
                                      # BR2_PACKAGE_ECRYPTFS_UTILS is not set
                                      # BR2_PACKAGE_EROFS_UTILS is not set
                                      # BR2_PACKAGE_EXFAT is not set
                                      # BR2_PACKAGE_EXFAT_UTILS is not set
                                      # BR2_PACKAGE_EXFATPROGS is not set
                                      # BR2_PACKAGE_F2FS_TOOLS is not set
                                      # BR2_PACKAGE_FLASHBENCH is not set
                                      # BR2_PACKAGE_FSCRYPTCTL is not set
                                      # BR2_PACKAGE_FUSE_OVERLAYFS is not set
                                      # BR2_PACKAGE_FWUP is not set
                                      # BR2_PACKAGE_GENEXT2FS is not set
                                      # BR2_PACKAGE_GENPART is not set
                                      # BR2_PACKAGE_GENROMFS is not set
                                      # BR2_PACKAGE_IMX_USB_LOADER is not set
                                      # BR2_PACKAGE_MMC_UTILS is not set
                                      # BR2_PACKAGE_MTD is not set
                                      # BR2_PACKAGE_MTOOLS is not set
                                      # BR2_PACKAGE_NFS_UTILS is not set
                                      # BR2_PACKAGE_NILFS_UTILS is not set
                                      # BR2_PACKAGE_NTFS_3G is not set
                                      # BR2_PACKAGE_SP_OOPS_EXTRACT is not set
                                      # BR2_PACKAGE_SQUASHFS is not set
                                      # BR2_PACKAGE_SSHFS is not set
                                      # BR2_PACKAGE_UDFTOOLS is not set
                                      # BR2_PACKAGE_UNIONFS is not set
                                      # BR2_PACKAGE_XFSPROGS is not set
                                      # Fonts, cursors, icons, sounds and themes
                                      # Cursors
                                      # BR2_PACKAGE_COMIX_CURSORS is not set
                                      # BR2_PACKAGE_OBSIDIAN_CURSORS is not set
                                      # Fonts
                                      # BR2_PACKAGE_BITSTREAM_VERA is not set
                                      # BR2_PACKAGE_CANTARELL is not set
                                      BR2_PACKAGE_DEJAVU=y
                                      BR2_PACKAGE_DEJAVU_MONO=y
                                      BR2_PACKAGE_DEJAVU_SANS=y
                                      BR2_PACKAGE_DEJAVU_SERIF=y
                                      BR2_PACKAGE_DEJAVU_SANS_CONDENSED=y
                                      BR2_PACKAGE_DEJAVU_SERIF_CONDENSED=y
                                      BR2_PACKAGE_FONT_AWESOME=y
                                      # BR2_PACKAGE_GHOSTSCRIPT_FONTS is not set
                                      # BR2_PACKAGE_INCONSOLATA is not set
                                      # BR2_PACKAGE_LIBERATION is not set
                                      BR2_PACKAGE_WQY_ZENHEI=y
                                      # Icons
                                      # BR2_PACKAGE_GOOGLE_MATERIAL_DESIGN_ICONS is not set
                                      # BR2_PACKAGE_HICOLOR_ICON_THEME is not set
                                      # Sounds
                                      # BR2_PACKAGE_SOUND_THEME_BOREALIS is not set
                                      # BR2_PACKAGE_SOUND_THEME_FREEDESKTOP is not set
                                      # Themes
                                      # Games
                                      # BR2_PACKAGE_ASCII_INVADERS is not set
                                      # BR2_PACKAGE_CHOCOLATE_DOOM is not set
                                      # BR2_PACKAGE_FLARE_ENGINE is not set
                                      # BR2_PACKAGE_FROTZ is not set
                                      # BR2_PACKAGE_GNUCHESS is not set
                                      # BR2_PACKAGE_LBREAKOUT2 is not set
                                      # BR2_PACKAGE_LTRIS is not set
                                      # minetest needs X11 and an OpenGL provider
                                      # BR2_PACKAGE_OPENTYRIAN is not set
                                      # BR2_PACKAGE_PRBOOM is not set
                                      # BR2_PACKAGE_SL is not set
                                      # solarus needs OpenGL and a toolchain w/ C++, gcc >= 4.9, NPTL, dynamic library, and luajit or lua 5.1
                                      # BR2_PACKAGE_STELLA is not set
                                      # BR2_PACKAGE_XORCURSES is not set
                                      # Graphic libraries and applications (graphic/text)
                                      # Graphic applications
                                      # cage needs udev, mesa3d w/ EGL and GLES support
                                      # cog needs wpewebkit and a toolchain w/ threads
                                      # BR2_PACKAGE_FSWEBCAM is not set
                                      # BR2_PACKAGE_GHOSTSCRIPT is not set
                                      # glmark2 needs an OpenGL or an openGL ES and EGL backend
                                      # glslsandbox-player needs a toolchain w/ threads and an openGL ES and EGL driver
                                      # BR2_PACKAGE_GNUPLOT is not set
                                      # BR2_PACKAGE_JHEAD is not set
                                      # BR2_PACKAGE_LIBVA_UTILS is not set
                                      BR2_PACKAGE_NETSURF_ARCH_SUPPORTS=y
                                      # BR2_PACKAGE_NETSURF is not set
                                      # BR2_PACKAGE_PNGQUANT is not set
                                      # BR2_PACKAGE_RRDTOOL is not set
                                      # stellarium needs Qt5 and an OpenGL provider
                                      # BR2_PACKAGE_TESSERACT_OCR is not set
                                      # Graphic libraries
                                      # BR2_PACKAGE_CEGUI is not set
                                      # BR2_PACKAGE_DIRECTFB is not set
                                      BR2_PACKAGE_FB_TEST_APP=y
                                      # BR2_PACKAGE_FBDUMP is not set
                                      # BR2_PACKAGE_FBGRAB is not set
                                      # BR2_PACKAGE_FBTERM is not set
                                      # BR2_PACKAGE_FBV is not set
                                      # BR2_PACKAGE_FREERDP is not set
                                      # BR2_PACKAGE_GRAPHICSMAGICK is not set
                                      # BR2_PACKAGE_IMAGEMAGICK is not set
                                      # BR2_PACKAGE_LINUX_FUSION is not set
                                      # BR2_PACKAGE_MESA3D is not set
                                      # BR2_PACKAGE_OCRAD is not set
                                      # ogre needs X11 and an OpenGL provider
                                      # BR2_PACKAGE_PSPLASH is not set
                                      # BR2_PACKAGE_SDL is not set
                                      # BR2_PACKAGE_SDL2 is not set
                                      # Other GUIs
                                      BR2_PACKAGE_QT5=y
                                      BR2_PACKAGE_QT5BASE=y
                                      BR2_PACKAGE_QT5BASE_CUSTOM_CONF_OPTS=""
                                      BR2_PACKAGE_QT5BASE_CONFIG_FILE=""
                                      # BR2_PACKAGE_QT5BASE_EXAMPLES is not set
                                      BR2_PACKAGE_QT5BASE_NETWORK=y
                                      BR2_PACKAGE_QT5BASE_CONCURRENT=y
                                      BR2_PACKAGE_QT5BASE_SQL=y
                                      # BR2_PACKAGE_QT5BASE_MYSQL is not set
                                      # BR2_PACKAGE_QT5BASE_PSQL is not set
                                      BR2_PACKAGE_QT5BASE_SQLITE_NONE=y
                                      # BR2_PACKAGE_QT5BASE_SQLITE_QT is not set
                                      # BR2_PACKAGE_QT5BASE_SQLITE_SYSTEM is not set
                                      BR2_PACKAGE_QT5BASE_TEST=y
                                      BR2_PACKAGE_QT5BASE_XML=y
                                      BR2_PACKAGE_QT5BASE_GUI=y
                                      BR2_PACKAGE_QT5BASE_WIDGETS=y
                                      # OpenGL support needs an OpenGL-capable backend
                                      BR2_PACKAGE_QT5BASE_LINUXFB=y
                                      # directfb backend available if directfb is enabled
                                      # X.org XCB backend available if X.org is enabled
                                      # eglfs backend available if OpenGL and EGL are enabled
                                      BR2_PACKAGE_QT5BASE_DEFAULT_QPA=""
                                      BR2_PACKAGE_QT5BASE_PRINTSUPPORT=y
                                      # BR2_PACKAGE_QT5BASE_FONTCONFIG is not set
                                      # BR2_PACKAGE_QT5BASE_HARFBUZZ is not set
                                      BR2_PACKAGE_QT5BASE_GIF=y
                                      BR2_PACKAGE_QT5BASE_JPEG=y
                                      BR2_PACKAGE_QT5BASE_PNG=y
                                      BR2_PACKAGE_QT5BASE_SYSLOG=y
                                      # BR2_PACKAGE_QT5BASE_DBUS is not set
                                      # BR2_PACKAGE_QT5BASE_ICU is not set
                                      BR2_PACKAGE_QT5BASE_TSLIB=y
                                      BR2_PACKAGE_QT5CHARTS=y
                                      # BR2_PACKAGE_QT5COAP is not set
                                      # qt5connectivity needs neard and/or bluez5_utils
                                      # BR2_PACKAGE_QT5ENGINIO is not set
                                      # BR2_PACKAGE_QT5IMAGEFORMATS is not set
                                      # BR2_PACKAGE_QT5KNX is not set
                                      # BR2_PACKAGE_QT5LOCATION is not set
                                      BR2_PACKAGE_QT5MQTT=y
                                      # BR2_PACKAGE_QT5MULTIMEDIA is not set
                                      # BR2_PACKAGE_QT5REMOTEOBJECTS is not set
                                      # BR2_PACKAGE_QT5SENSORS is not set
                                      # BR2_PACKAGE_QT5SERIALBUS is not set
                                      BR2_PACKAGE_QT5SERIALPORT=y
                                      BR2_PACKAGE_QT5SVG=y
                                      # BR2_PACKAGE_QT5TOOLS is not set
                                      # qt5wayland needs an OpenGL-capable backend
                                      # BR2_PACKAGE_QT5WEBCHANNEL is not set
                                      BR2_PACKAGE_QT5WEBSOCKETS=y
                                      # qt5webview needs qt5webengine module
                                      BR2_PACKAGE_QT5XMLPATTERNS=y
                                      # QT libraries and helper libraries
                                      # BR2_PACKAGE_CUTELYST is not set
                                      # BR2_PACKAGE_KF5 is not set
                                      BR2_PACKAGE_QEXTSERIALPORT=y
                                      BR2_PACKAGE_QJSON=y
                                      # BR2_PACKAGE_QUAZIP is not set
                                      BR2_PACKAGE_QWT=y
                                      # BR2_PACKAGE_QWT_SVG is not set
                                      # BR2_PACKAGE_QWT_MATHML is not set
                                      # BR2_PACKAGE_TEKUI is not set
                                      # BR2_PACKAGE_WESTON is not set
                                      # BR2_PACKAGE_XORG7 is not set
                                      # BR2_PACKAGE_APITRACE is not set
                                      # vte needs an OpenGL or an OpenGL-EGL/wayland backend
                                      # BR2_PACKAGE_XKEYBOARD_CONFIG is not set
                                      # Hardware handling
                                      # Firmware
                                      # BR2_PACKAGE_ARMBIAN_FIRMWARE is not set
                                      # BR2_PACKAGE_B43_FIRMWARE is not set
                                      # BR2_PACKAGE_LINUX_FIRMWARE is not set
                                      # BR2_PACKAGE_MURATA_CYW_FW is not set
                                      # BR2_PACKAGE_ODROIDC2_FIRMWARE is not set
                                      # BR2_PACKAGE_QCOM_DB410C_FIRMWARE is not set
                                      # BR2_PACKAGE_RCW_SMARC_SAL28 is not set
                                      # BR2_PACKAGE_UX500_FIRMWARE is not set
                                      # BR2_PACKAGE_WILC1000_FIRMWARE is not set
                                      # BR2_PACKAGE_WILINK_BT_FIRMWARE is not set
                                      # BR2_PACKAGE_ZD1211_FIRMWARE is not set
                                      # BR2_PACKAGE_18XX_TI_UTILS is not set
                                      # BR2_PACKAGE_ACPICA is not set
                                      # BR2_PACKAGE_ACPID is not set
                                      # BR2_PACKAGE_ACPITOOL is not set
                                      # BR2_PACKAGE_AER_INJECT is not set
                                      # BR2_PACKAGE_ALTERA_STAPL is not set
                                      # BR2_PACKAGE_APCUPSD is not set
                                      # BR2_PACKAGE_AVRDUDE is not set
                                      # BR2_PACKAGE_BCACHE_TOOLS is not set
                                      # BR2_PACKAGE_BRICKD is not set
                                      # BR2_PACKAGE_BRLTTY is not set
                                      # BR2_PACKAGE_CC_TOOL is not set
                                      # BR2_PACKAGE_CDRKIT is not set
                                      # BR2_PACKAGE_CRYPTSETUP is not set
                                      # BR2_PACKAGE_CWIID is not set
                                      # BR2_PACKAGE_DAHDI_LINUX is not set
                                      # BR2_PACKAGE_DAHDI_TOOLS is not set
                                      # BR2_PACKAGE_DBUS is not set
                                      # BR2_PACKAGE_DFU_UTIL is not set
                                      # BR2_PACKAGE_DMRAID is not set
                                      # BR2_PACKAGE_DT_UTILS is not set
                                      # BR2_PACKAGE_DTV_SCAN_TABLES is not set
                                      # BR2_PACKAGE_DUMP1090 is not set
                                      # BR2_PACKAGE_DVB_APPS is not set
                                      # BR2_PACKAGE_DVBSNOOP is not set
                                      # BR2_PACKAGE_EDID_DECODE is not set
                                      # edid-decode needs a toolchain w/ C++, gcc >= 4.7
                                      BR2_PACKAGE_EUDEV=y
                                      BR2_PACKAGE_PROVIDES_UDEV="eudev"
                                      # BR2_PACKAGE_EUDEV_RULES_GEN is not set
                                      BR2_PACKAGE_EUDEV_ENABLE_HWDB=y
                                      # BR2_PACKAGE_EVEMU is not set
                                      BR2_PACKAGE_EVTEST=y
                                      # BR2_PACKAGE_FAN_CTRL is not set
                                      # BR2_PACKAGE_FCONFIG is not set
                                      BR2_PACKAGE_FLASHROM_ARCH_SUPPORTS=y
                                      # BR2_PACKAGE_FLASHROM is not set
                                      # BR2_PACKAGE_FMTOOLS is not set
                                      # BR2_PACKAGE_FXLOAD is not set
                                      # BR2_PACKAGE_GPM is not set
                                      # BR2_PACKAGE_GPSD is not set
                                      # BR2_PACKAGE_GPTFDISK is not set
                                      # BR2_PACKAGE_GVFS is not set
                                      # BR2_PACKAGE_HWDATA is not set
                                      # BR2_PACKAGE_HWLOC is not set
                                      # BR2_PACKAGE_INPUT_EVENT_DAEMON is not set
                                      # BR2_PACKAGE_IOSTAT is not set
                                      # BR2_PACKAGE_IPMITOOL is not set
                                      # BR2_PACKAGE_IRDA_UTILS is not set
                                      # BR2_PACKAGE_KBD is not set
                                      # BR2_PACKAGE_LCDPROC is not set
                                      # BR2_PACKAGE_LIBIEC61850 is not set
                                      # BR2_PACKAGE_LIBUBOOTENV is not set
                                      # BR2_PACKAGE_LIBUIO is not set
                                      # BR2_PACKAGE_LINUX_BACKPORTS is not set
                                      # BR2_PACKAGE_LINUX_SERIAL_TEST is not set
                                      # BR2_PACKAGE_LINUXCONSOLETOOLS is not set
                                      # BR2_PACKAGE_LIRC_TOOLS is not set
                                      # BR2_PACKAGE_LM_SENSORS is not set
                                      # BR2_PACKAGE_LSHW is not set
                                      # BR2_PACKAGE_LSSCSI is not set
                                      # BR2_PACKAGE_LSUIO is not set
                                      # BR2_PACKAGE_LUKSMETA is not set
                                      # BR2_PACKAGE_LVM2 is not set
                                      # BR2_PACKAGE_MBPFAN is not set
                                      # BR2_PACKAGE_MDADM is not set
                                      # BR2_PACKAGE_MDEVD is not set
                                      # BR2_PACKAGE_MEMTESTER is not set
                                      # BR2_PACKAGE_MEMTOOL is not set
                                      # BR2_PACKAGE_MINICOM is not set
                                      # BR2_PACKAGE_NANOCOM is not set
                                      # BR2_PACKAGE_NEARD is not set
                                      # BR2_PACKAGE_NVIDIA_MODPROBE is not set
                                      # BR2_PACKAGE_NVME is not set
                                      # BR2_PACKAGE_OFONO is not set
                                      # BR2_PACKAGE_OPEN2300 is not set
                                      # BR2_PACKAGE_OPENFPGALOADER is not set
                                      # BR2_PACKAGE_OPENIPMI is not set
                                      # BR2_PACKAGE_OPENOCD is not set
                                      # BR2_PACKAGE_PARTED is not set
                                      # BR2_PACKAGE_PCIUTILS is not set
                                      # BR2_PACKAGE_PDBG is not set
                                      # BR2_PACKAGE_PICOCOM is not set
                                      # BR2_PACKAGE_POWERTOP is not set
                                      # BR2_PACKAGE_PPS_TOOLS is not set
                                      # BR2_PACKAGE_PULSEVIEW is not set
                                      # BR2_PACKAGE_RASPI_GPIO is not set
                                      # BR2_PACKAGE_READ_EDID is not set
                                      # BR2_PACKAGE_RNG_TOOLS is not set
                                      # BR2_PACKAGE_RS485CONF is not set
                                      # BR2_PACKAGE_RTC_TOOLS is not set
                                      # BR2_PACKAGE_RTL8188EU is not set
                                      # BR2_PACKAGE_RTL8189FS is not set
                                      # BR2_PACKAGE_RTL8723BS is not set
                                      # BR2_PACKAGE_RTL8723BU is not set
                                      # BR2_PACKAGE_RTL8821AU is not set
                                      # BR2_PACKAGE_SANE_BACKENDS is not set
                                      # BR2_PACKAGE_SDPARM is not set
                                      # BR2_PACKAGE_SETSERIAL is not set
                                      # BR2_PACKAGE_SG3_UTILS is not set
                                      # BR2_PACKAGE_SIGROK_CLI is not set
                                      # BR2_PACKAGE_SISPMCTL is not set
                                      # BR2_PACKAGE_SMARTMONTOOLS is not set
                                      # BR2_PACKAGE_SMSTOOLS3 is not set
                                      # BR2_PACKAGE_SPI_TOOLS is not set
                                      # BR2_PACKAGE_SREDIRD is not set
                                      # BR2_PACKAGE_STATSERIAL is not set
                                      # BR2_PACKAGE_STM32FLASH is not set
                                      # BR2_PACKAGE_SYSSTAT is not set
                                      # targetcli-fb depends on Python
                                      # ti-sgx-um needs the ti-sgx-km driver
                                      # BR2_PACKAGE_TI_UIM is not set
                                      # BR2_PACKAGE_TI_UTILS is not set
                                      # BR2_PACKAGE_TIO is not set
                                      # BR2_PACKAGE_TRIGGERHAPPY is not set
                                      # BR2_PACKAGE_UBOOT_TOOLS is not set
                                      # BR2_PACKAGE_UBUS is not set
                                      # BR2_PACKAGE_UCCP420WLAN is not set
                                      BR2_PACKAGE_HAS_UDEV=y
                                      # BR2_PACKAGE_UDISKS is not set
                                      # BR2_PACKAGE_UHUBCTL is not set
                                      # BR2_PACKAGE_UMTPRD is not set
                                      # BR2_PACKAGE_UPOWER is not set
                                      # BR2_PACKAGE_USB_MODESWITCH is not set
                                      # BR2_PACKAGE_USB_MODESWITCH_DATA is not set
                                      # BR2_PACKAGE_USBMOUNT is not set
                                      # BR2_PACKAGE_USBUTILS is not set
                                      # BR2_PACKAGE_W_SCAN is not set
                                      # BR2_PACKAGE_WIPE is not set
                                      # BR2_PACKAGE_XORRISO is not set
                                      # BR2_PACKAGE_XR819_XRADIO is not set
                                      # Interpreter languages and scripting
                                      # BR2_PACKAGE_4TH is not set
                                      # BR2_PACKAGE_ENSCRIPT is not set
                                      BR2_PACKAGE_HOST_ERLANG_ARCH_SUPPORTS=y
                                      # BR2_PACKAGE_EXECLINE is not set
                                      # BR2_PACKAGE_FICL is not set
                                      # BR2_PACKAGE_HASERL is not set
                                      # BR2_PACKAGE_JIMTCL is not set
                                      BR2_PACKAGE_LUA=y
                                      BR2_PACKAGE_PROVIDES_LUAINTERPRETER="lua"
                                      # BR2_PACKAGE_LUA_5_1 is not set
                                      # BR2_PACKAGE_LUA_5_3 is not set
                                      BR2_PACKAGE_LUA_5_4=y
                                      # BR2_PACKAGE_LUA_32BITS is not set
                                      # BR2_PACKAGE_LUA_EDITING_NONE is not set
                                      # BR2_PACKAGE_LUA_READLINE is not set
                                      BR2_PACKAGE_LUA_LINENOISE=y
                                      BR2_PACKAGE_HAS_LUAINTERPRETER=y
                                      BR2_PACKAGE_LUAINTERPRETER_ABI_VERSION="5.4"
                                      BR2_PACKAGE_LUAINTERPRETER_ABI_VERSION_5_4=y
                                      BR2_PACKAGE_PROVIDES_HOST_LUAINTERPRETER="host-lua"
                                      # Lua libraries/modules
                                      # BR2_PACKAGE_ARGPARSE is not set
                                      # BR2_PACKAGE_CGILUA is not set
                                      # BR2_PACKAGE_COPAS is not set
                                      # BR2_PACKAGE_COXPCALL is not set
                                      # BR2_PACKAGE_DADO is not set
                                      # easydbus needs a toolchain w/ wchar, threads, Lua <= 5.3
                                      # BR2_PACKAGE_LBASE64 is not set
                                      # ljlinenoise needs LuaJIT
                                      # ljsyscall needs LuaJIT
                                      # BR2_PACKAGE_LPEG is not set
                                      # BR2_PACKAGE_LPTY is not set
                                      # BR2_PACKAGE_LRANDOM is not set
                                      # BR2_PACKAGE_LSQLITE3 is not set
                                      # BR2_PACKAGE_LUA_BASEXX is not set
                                      # BR2_PACKAGE_LUA_BINARYHEAP is not set
                                      # BR2_PACKAGE_LUA_BIT32 is not set
                                      # BR2_PACKAGE_LUA_CJSON is not set
                                      # BR2_PACKAGE_LUA_COAT is not set
                                      # lua-coatpersistent needs lsqlite3 or luasql-sqlite3
                                      # BR2_PACKAGE_LUA_CODEGEN is not set
                                      # BR2_PACKAGE_LUA_CQUEUES is not set
                                      # BR2_PACKAGE_LUA_CSNAPPY is not set
                                      # BR2_PACKAGE_LUA_CURL is not set
                                      # BR2_PACKAGE_LUA_DATAFILE is not set
                                      # BR2_PACKAGE_LUA_EV is not set
                                      # BR2_PACKAGE_LUA_FIFO is not set
                                      # lua-flu needs a toolchain w/ threads, dynamic library, Lua <= 5.3
                                      # BR2_PACKAGE_LUA_GD is not set
                                      # BR2_PACKAGE_LUA_HTTP is not set
                                      # BR2_PACKAGE_LUA_ICONV is not set
                                      # BR2_PACKAGE_LUA_LIVR is not set
                                      # BR2_PACKAGE_LUA_LIVR_EXTRA is not set
                                      # BR2_PACKAGE_LUA_LPEG_PATTERNS is not set
                                      # BR2_PACKAGE_LUA_LUNITX is not set
                                      # BR2_PACKAGE_LUA_LYAML is not set
                                      # BR2_PACKAGE_LUA_MARKDOWN is not set
                                      # BR2_PACKAGE_LUA_MESSAGEPACK is not set
                                      # lua-msgpack-native needs Lua 5.1 or LuaJIT
                                      # BR2_PACKAGE_LUA_PERIPHERY is not set
                                      # BR2_PACKAGE_LUA_RESTY_HTTP is not set
                                      # BR2_PACKAGE_LUA_ROTAS is not set
                                      # BR2_PACKAGE_LUA_SAILOR is not set
                                      # lua-sdl2 needs a toolchain w/ dynamic library, Lua <= 5.3
                                      # BR2_PACKAGE_LUA_SILVA is not set
                                      # BR2_PACKAGE_LUA_STD_DEBUG is not set
                                      # BR2_PACKAGE_LUA_STD_NORMALIZE is not set
                                      # BR2_PACKAGE_LUA_STDLIB is not set
                                      # BR2_PACKAGE_LUA_TESTMORE is not set
                                      # BR2_PACKAGE_LUA_UTF8 is not set
                                      # BR2_PACKAGE_LUA_VALUA is not set
                                      # luabitop needs Lua 5.1
                                      # BR2_PACKAGE_LUADBI is not set
                                      # BR2_PACKAGE_LUADBI_SQLITE3 is not set
                                      # BR2_PACKAGE_LUAEXPAT is not set
                                      # BR2_PACKAGE_LUAEXPATUTILS is not set
                                      # BR2_PACKAGE_LUAFILESYSTEM is not set
                                      # BR2_PACKAGE_LUAJSON is not set
                                      # lualdap needs a toolchain w/ wchar, dynamic library, Lua <= 5.3
                                      # BR2_PACKAGE_LUALOGGING is not set
                                      # BR2_PACKAGE_LUAOSSL is not set
                                      # BR2_PACKAGE_LUAPOSIX is not set
                                      # BR2_PACKAGE_LUASEC is not set
                                      # BR2_PACKAGE_LUASOCKET is not set
                                      # BR2_PACKAGE_LUASQL_SQLITE3 is not set
                                      # BR2_PACKAGE_LUASYSLOG is not set
                                      # BR2_PACKAGE_LUTOK is not set
                                      # luv needs a toolchain w/ NPTL, dynamic library, Lua <= 5.3
                                      # luvi needs LuaJIT
                                      # BR2_PACKAGE_LZLIB is not set
                                      # orbit needs a Lua 5.1 interpreter
                                      # BR2_PACKAGE_RINGS is not set
                                      # turbolua needs LuaJIT
                                      # BR2_PACKAGE_WSAPI is not set
                                      # BR2_PACKAGE_WSAPI_FCGI is not set
                                      # BR2_PACKAGE_WSAPI_XAVANTE is not set
                                      # BR2_PACKAGE_XAVANTE is not set
                                      # BR2_PACKAGE_MICROPYTHON is not set
                                      BR2_PACKAGE_HOST_MONO_ARCH_SUPPORTS=y
                                      BR2_PACKAGE_HOST_OPENJDK_BIN_ARCH_SUPPORTS=y
                                      # BR2_PACKAGE_PERL is not set
                                      # BR2_PACKAGE_PHP is not set
                                      # BR2_PACKAGE_PYTHON is not set
                                      # BR2_PACKAGE_PYTHON3 is not set
                                      # BR2_PACKAGE_QUICKJS is not set
                                      # BR2_PACKAGE_RUBY is not set
                                      # BR2_PACKAGE_TCL is not set
                                      # Libraries
                                      # Audio/Sound
                                      # BR2_PACKAGE_ALSA_LIB is not set
                                      # BR2_PACKAGE_ALURE is not set
                                      # BR2_PACKAGE_AUBIO is not set
                                      # BR2_PACKAGE_BCG729 is not set
                                      # BR2_PACKAGE_CAPS is not set
                                      # BR2_PACKAGE_LIBAO is not set
                                      # BR2_PACKAGE_LIBASPLIB is not set
                                      # BR2_PACKAGE_LIBBROADVOICE is not set
                                      # BR2_PACKAGE_LIBCDAUDIO is not set
                                      # BR2_PACKAGE_LIBCDDB is not set
                                      # BR2_PACKAGE_LIBCDIO is not set
                                      # BR2_PACKAGE_LIBCDIO_PARANOIA is not set
                                      # BR2_PACKAGE_LIBCODEC2 is not set
                                      # BR2_PACKAGE_LIBCUE is not set
                                      # BR2_PACKAGE_LIBCUEFILE is not set
                                      # BR2_PACKAGE_LIBEBUR128 is not set
                                      # BR2_PACKAGE_LIBG7221 is not set
                                      # BR2_PACKAGE_LIBGSM is not set
                                      # BR2_PACKAGE_LIBID3TAG is not set
                                      # BR2_PACKAGE_LIBILBC is not set
                                      # BR2_PACKAGE_LIBLO is not set
                                      # BR2_PACKAGE_LIBMAD is not set
                                      # BR2_PACKAGE_LIBMODPLUG is not set
                                      # BR2_PACKAGE_LIBMPD is not set
                                      # BR2_PACKAGE_LIBMPDCLIENT is not set
                                      # BR2_PACKAGE_LIBREPLAYGAIN is not set
                                      # BR2_PACKAGE_LIBSAMPLERATE is not set
                                      # BR2_PACKAGE_LIBSIDPLAY2 is not set
                                      # BR2_PACKAGE_LIBSILK is not set
                                      # BR2_PACKAGE_LIBSNDFILE is not set
                                      # BR2_PACKAGE_LIBSOUNDTOUCH is not set
                                      # BR2_PACKAGE_LIBSOXR is not set
                                      # BR2_PACKAGE_LIBVORBIS is not set
                                      # BR2_PACKAGE_MP4V2 is not set
                                      BR2_PACKAGE_OPENAL_ARCH_SUPPORTS=y
                                      # BR2_PACKAGE_OPENAL is not set
                                      # BR2_PACKAGE_OPENCORE_AMR is not set
                                      # BR2_PACKAGE_OPUS is not set
                                      # BR2_PACKAGE_OPUSFILE is not set
                                      # BR2_PACKAGE_PORTAUDIO is not set
                                      # BR2_PACKAGE_SBC is not set
                                      # BR2_PACKAGE_SPANDSP is not set
                                      # BR2_PACKAGE_SPEEX is not set
                                      # BR2_PACKAGE_SPEEXDSP is not set
                                      # BR2_PACKAGE_TAGLIB is not set
                                      # BR2_PACKAGE_TINYALSA is not set
                                      # BR2_PACKAGE_TREMOR is not set
                                      # BR2_PACKAGE_VO_AACENC is not set
                                      # Compression and decompression
                                      # BR2_PACKAGE_LIBARCHIVE is not set
                                      # BR2_PACKAGE_LIBMSPACK is not set
                                      # BR2_PACKAGE_LIBSQUISH is not set
                                      # BR2_PACKAGE_LIBZIP is not set
                                      # BR2_PACKAGE_LZ4 is not set
                                      # BR2_PACKAGE_LZO is not set
                                      # BR2_PACKAGE_MINIZIP is not set
                                      # BR2_PACKAGE_SNAPPY is not set
                                      # BR2_PACKAGE_SZIP is not set
                                      BR2_PACKAGE_ZLIB=y
                                      BR2_PACKAGE_LIBZLIB=y
                                      BR2_PACKAGE_HAS_ZLIB=y
                                      BR2_PACKAGE_PROVIDES_ZLIB="libzlib"
                                      BR2_PACKAGE_PROVIDES_HOST_ZLIB="host-libzlib"
                                      # BR2_PACKAGE_ZZIPLIB is not set
                                      # Crypto
                                      # BR2_PACKAGE_BEARSSL is not set
                                      # BR2_PACKAGE_BEECRYPT is not set
                                      BR2_PACKAGE_BOTAN_ARCH_SUPPORTS=y
                                      # BR2_PACKAGE_BOTAN is not set
                                      # BR2_PACKAGE_CA_CERTIFICATES is not set
                                      # BR2_PACKAGE_CRYPTODEV is not set
                                      # BR2_PACKAGE_GCR is not set
                                      # BR2_PACKAGE_GNUTLS is not set
                                      # BR2_PACKAGE_LIBARGON2 is not set
                                      # BR2_PACKAGE_LIBASSUAN is not set
                                      # BR2_PACKAGE_LIBGCRYPT is not set
                                      BR2_PACKAGE_LIBGPG_ERROR_ARCH_SUPPORTS=y
                                      # BR2_PACKAGE_LIBGPG_ERROR is not set
                                      BR2_PACKAGE_LIBGPG_ERROR_SYSCFG="riscv64-unknown-linux-gnu"
                                      # BR2_PACKAGE_LIBGPGME is not set
                                      # BR2_PACKAGE_LIBKCAPI is not set
                                      # BR2_PACKAGE_LIBKSBA is not set
                                      # BR2_PACKAGE_LIBMCRYPT is not set
                                      # BR2_PACKAGE_LIBMHASH is not set
                                      # BR2_PACKAGE_LIBNSS is not set
                                      # BR2_PACKAGE_LIBOLM is not set
                                      # BR2_PACKAGE_LIBP11 is not set
                                      # BR2_PACKAGE_LIBSCRYPT is not set
                                      # BR2_PACKAGE_LIBSECRET is not set
                                      # BR2_PACKAGE_LIBSHA1 is not set
                                      # BR2_PACKAGE_LIBSODIUM is not set
                                      # BR2_PACKAGE_LIBSSH is not set
                                      # BR2_PACKAGE_LIBSSH2 is not set
                                      # BR2_PACKAGE_LIBTOMCRYPT is not set
                                      # BR2_PACKAGE_LIBUECC is not set
                                      # BR2_PACKAGE_MBEDTLS is not set
                                      # BR2_PACKAGE_NETTLE is not set
                                      BR2_PACKAGE_LIBOPENSSL_ARCH_SUPPORTS=y
                                      # BR2_PACKAGE_OPENSSL is not set
                                      BR2_PACKAGE_PROVIDES_HOST_OPENSSL="host-libopenssl"
                                      # BR2_PACKAGE_PKCS11_HELPER is not set
                                      # BR2_PACKAGE_RHASH is not set
                                      # BR2_PACKAGE_TINYDTLS is not set
                                      # BR2_PACKAGE_TPM2_PKCS11 is not set
                                      # BR2_PACKAGE_TPM2_TSS is not set
                                      # BR2_PACKAGE_TROUSERS is not set
                                      # BR2_PACKAGE_USTREAM_SSL is not set
                                      # BR2_PACKAGE_WOLFSSL is not set
                                      # Database
                                      # BR2_PACKAGE_BERKELEYDB is not set
                                      # BR2_PACKAGE_GDBM is not set
                                      # BR2_PACKAGE_HIREDIS is not set
                                      # BR2_PACKAGE_KOMPEXSQLITE is not set
                                      # BR2_PACKAGE_LEVELDB is not set
                                      # BR2_PACKAGE_LIBGIT2 is not set
                                      # BR2_PACKAGE_LIBMDBX is not set
                                      # BR2_PACKAGE_LIBODB is not set
                                      # BR2_PACKAGE_MYSQL is not set
                                      # BR2_PACKAGE_POSTGRESQL is not set
                                      # BR2_PACKAGE_REDIS is not set
                                      # BR2_PACKAGE_ROCKSDB is not set
                                      # BR2_PACKAGE_SQLCIPHER is not set
                                      # BR2_PACKAGE_SQLITE is not set
                                      # BR2_PACKAGE_UNIXODBC is not set
                                      # Filesystem
                                      # BR2_PACKAGE_GAMIN is not set
                                      # BR2_PACKAGE_LIBCONFIG is not set
                                      # BR2_PACKAGE_LIBCONFUSE is not set
                                      BR2_PACKAGE_LIBFUSE=y
                                      # BR2_PACKAGE_LIBFUSE3 is not set
                                      # BR2_PACKAGE_LIBLOCKFILE is not set
                                      # BR2_PACKAGE_LIBNFS is not set
                                      # BR2_PACKAGE_LIBSYSFS is not set
                                      # BR2_PACKAGE_LOCKDEV is not set
                                      # BR2_PACKAGE_PHYSFS is not set
                                      # Graphics
                                      # BR2_PACKAGE_ASSIMP is not set
                                      # at-spi2-atk depends on X.org
                                      # at-spi2-core depends on X.org
                                      # BR2_PACKAGE_ATK is not set
                                      # BR2_PACKAGE_ATKMM is not set
                                      # BR2_PACKAGE_BULLET is not set
                                      # BR2_PACKAGE_CAIRO is not set
                                      # BR2_PACKAGE_CAIROMM is not set
                                      # chipmunk needs an OpenGL backend
                                      # BR2_PACKAGE_EXEMPI is not set
                                      # BR2_PACKAGE_EXIV2 is not set
                                      # BR2_PACKAGE_FONTCONFIG is not set
                                      BR2_PACKAGE_FREETYPE=y
                                      # BR2_PACKAGE_GD is not set
                                      # BR2_PACKAGE_GDK_PIXBUF is not set
                                      # BR2_PACKAGE_GIFLIB is not set
                                      # granite needs libgtk3 and a toolchain w/ wchar, threads
                                      # BR2_PACKAGE_GRAPHITE2 is not set
                                      # gtkmm3 needs libgtk3 and a toolchain w/ C++, wchar, threads, gcc >= 4.9
                                      # BR2_PACKAGE_HARFBUZZ is not set
                                      # BR2_PACKAGE_IJS is not set
                                      # BR2_PACKAGE_IMLIB2 is not set
                                      # irrlicht needs X11 and an OpenGL provider
                                      # BR2_PACKAGE_JASPER is not set
                                      # BR2_PACKAGE_JBIG2DEC is not set
                                      BR2_PACKAGE_JPEG=y
                                      BR2_PACKAGE_LIBJPEG=y
                                      # BR2_PACKAGE_JPEG_TURBO is not set
                                      BR2_PACKAGE_HAS_JPEG=y
                                      BR2_PACKAGE_PROVIDES_JPEG="libjpeg"
                                      # BR2_PACKAGE_KMSXX is not set
                                      # BR2_PACKAGE_LCMS2 is not set
                                      # BR2_PACKAGE_LENSFUN is not set
                                      # BR2_PACKAGE_LEPTONICA is not set
                                      # BR2_PACKAGE_LIBART is not set
                                      # BR2_PACKAGE_LIBDMTX is not set
                                      # BR2_PACKAGE_LIBDRM is not set
                                      # libepoxy needs an OpenGL and/or OpenGL EGL backend
                                      # BR2_PACKAGE_LIBEXIF is not set
                                      # libfm needs X.org and a toolchain w/ wchar, threads, C++, gcc >= 4.8
                                      # BR2_PACKAGE_LIBFM_EXTRA is not set
                                      # libfreeglut depends on X.org and needs an OpenGL backend
                                      # BR2_PACKAGE_LIBFREEIMAGE is not set
                                      # BR2_PACKAGE_LIBGEOTIFF is not set
                                      # libglew depends on X.org and needs an OpenGL backend
                                      # libglfw depends on X.org and needs an OpenGL backend
                                      # libglu needs an OpenGL backend
                                      # BR2_PACKAGE_LIBGTA is not set
                                      # libgtk3 needs an OpenGL or an OpenGL-EGL/wayland backend
                                      # BR2_PACKAGE_LIBMEDIAART is not set
                                      # BR2_PACKAGE_LIBMNG is not set
                                      BR2_PACKAGE_LIBPNG=y
                                      # BR2_PACKAGE_LIBQRENCODE is not set
                                      # BR2_PACKAGE_LIBRAW is not set
                                      # libsoil needs an OpenGL backend and a toolchain w/ dynamic library
                                      # BR2_PACKAGE_LIBSVG is not set
                                      # BR2_PACKAGE_LIBSVG_CAIRO is not set
                                      # BR2_PACKAGE_LIBSVGTINY is not set
                                      # BR2_PACKAGE_LIBVA is not set
                                      # BR2_PACKAGE_LIBVIPS is not set
                                      # libwpe needs a toolchain w/ C++, dynamic library and an OpenEGL-capable backend
                                      # BR2_PACKAGE_MENU_CACHE is not set
                                      # BR2_PACKAGE_OPENCV3 is not set
                                      # BR2_PACKAGE_OPENJPEG is not set
                                      # BR2_PACKAGE_PANGO is not set
                                      # BR2_PACKAGE_PANGOMM is not set
                                      # BR2_PACKAGE_PIPEWIRE is not set
                                      # BR2_PACKAGE_PIXMAN is not set
                                      # BR2_PACKAGE_POPPLER is not set
                                      # BR2_PACKAGE_TIFF is not set
                                      # BR2_PACKAGE_WAYLAND is not set
                                      # BR2_PACKAGE_WEBP is not set
                                      # wlroots needs udev, mesa3d w/ EGL and GLES support
                                      # BR2_PACKAGE_WOFF2 is not set
                                      # wpebackend-fdo needs a toolchain w/ C++, wchar, threads, dynamic library and an OpenEGL-capable Wayland backend
                                      # BR2_PACKAGE_ZBAR is not set
                                      # BR2_PACKAGE_ZXING_CPP is not set
                                      # Hardware handling
                                      # BR2_PACKAGE_ACSCCID is not set
                                      # BR2_PACKAGE_C_PERIPHERY is not set
                                      # BR2_PACKAGE_CCID is not set
                                      # BR2_PACKAGE_DTC is not set
                                      # BR2_PACKAGE_HACKRF is not set
                                      # BR2_PACKAGE_HIDAPI is not set
                                      # BR2_PACKAGE_JITTERENTROPY_LIBRARY is not set
                                      # BR2_PACKAGE_LCDAPI is not set
                                      # BR2_PACKAGE_LET_ME_CREATE is not set
                                      # BR2_PACKAGE_LIBAIO is not set
                                      # BR2_PACKAGE_LIBATASMART is not set
                                      # BR2_PACKAGE_LIBBLOCKDEV is not set
                                      # BR2_PACKAGE_LIBCEC is not set
                                      # BR2_PACKAGE_LIBFREEFARE is not set
                                      # BR2_PACKAGE_LIBFTDI is not set
                                      # BR2_PACKAGE_LIBFTDI1 is not set
                                      # BR2_PACKAGE_LIBGPHOTO2 is not set
                                      # BR2_PACKAGE_LIBGPIOD is not set
                                      # BR2_PACKAGE_LIBGUDEV is not set
                                      # BR2_PACKAGE_LIBHID is not set
                                      # BR2_PACKAGE_LIBIIO is not set
                                      # BR2_PACKAGE_LIBINPUT is not set
                                      # BR2_PACKAGE_LIBIQRF is not set
                                      # BR2_PACKAGE_LIBLLCP is not set
                                      # BR2_PACKAGE_LIBMBIM is not set
                                      # BR2_PACKAGE_LIBNFC is not set
                                      # BR2_PACKAGE_LIBPCIACCESS is not set
                                      # BR2_PACKAGE_LIBPHIDGET is not set
                                      # BR2_PACKAGE_LIBPRI is not set
                                      # BR2_PACKAGE_LIBQMI is not set
                                      # BR2_PACKAGE_LIBRAW1394 is not set
                                      # BR2_PACKAGE_LIBRTLSDR is not set
                                      # BR2_PACKAGE_LIBSERIAL is not set
                                      # BR2_PACKAGE_LIBSERIALPORT is not set
                                      # BR2_PACKAGE_LIBSIGROK is not set
                                      # BR2_PACKAGE_LIBSIGROKDECODE is not set
                                      # BR2_PACKAGE_LIBSOC is not set
                                      # BR2_PACKAGE_LIBSS7 is not set
                                      # BR2_PACKAGE_LIBUSB is not set
                                      # BR2_PACKAGE_LIBUSBGX is not set
                                      # BR2_PACKAGE_LIBV4L is not set
                                      # BR2_PACKAGE_LIBXKBCOMMON is not set
                                      # BR2_PACKAGE_MTDEV is not set
                                      # BR2_PACKAGE_NEARDAL is not set
                                      # BR2_PACKAGE_OWFS is not set
                                      # BR2_PACKAGE_PCSC_LITE is not set
                                      BR2_PACKAGE_TSLIB=y
                                      # BR2_PACKAGE_UHD is not set
                                      # BR2_PACKAGE_URG is not set
                                      # Javascript
                                      # BR2_PACKAGE_ANGULARJS is not set
                                      # BR2_PACKAGE_BOOTSTRAP is not set
                                      # BR2_PACKAGE_CHARTJS is not set
                                      # BR2_PACKAGE_DATATABLES is not set
                                      # BR2_PACKAGE_DUKTAPE is not set
                                      # BR2_PACKAGE_EXPLORERCANVAS is not set
                                      # BR2_PACKAGE_FLOT is not set
                                      # BR2_PACKAGE_JQUERY is not set
                                      # BR2_PACKAGE_JSMIN is not set
                                      # BR2_PACKAGE_JSON_JAVASCRIPT is not set
                                      # BR2_PACKAGE_JSZIP is not set
                                      # BR2_PACKAGE_OPENLAYERS is not set
                                      # BR2_PACKAGE_POPPERJS is not set
                                      BR2_PACKAGE_SPIDERMONKEY_ARCH_SUPPORTS=y
                                      # BR2_PACKAGE_SPIDERMONKEY is not set
                                      # BR2_PACKAGE_VUEJS is not set
                                      # JSON/XML
                                      # BR2_PACKAGE_BENEJSON is not set
                                      # BR2_PACKAGE_CJSON is not set
                                      # BR2_PACKAGE_EXPAT is not set
                                      # BR2_PACKAGE_JANSSON is not set
                                      # BR2_PACKAGE_JOSE is not set
                                      # BR2_PACKAGE_JSMN is not set
                                      # BR2_PACKAGE_JSON_C is not set
                                      # BR2_PACKAGE_JSON_FOR_MODERN_CPP is not set
                                      # BR2_PACKAGE_JSON_GLIB is not set
                                      # BR2_PACKAGE_JSONCPP is not set
                                      # BR2_PACKAGE_LIBBSON is not set
                                      # BR2_PACKAGE_LIBFASTJSON is not set
                                      # BR2_PACKAGE_LIBJSON is not set
                                      # BR2_PACKAGE_LIBROXML is not set
                                      # BR2_PACKAGE_LIBUCL is not set
                                      # BR2_PACKAGE_LIBXML2 is not set
                                      # BR2_PACKAGE_LIBXMLPP is not set
                                      # BR2_PACKAGE_LIBXMLRPC is not set
                                      # BR2_PACKAGE_LIBXSLT is not set
                                      # BR2_PACKAGE_LIBYAML is not set
                                      # BR2_PACKAGE_MXML is not set
                                      # BR2_PACKAGE_PUGIXML is not set
                                      # BR2_PACKAGE_RAPIDJSON is not set
                                      # BR2_PACKAGE_RAPIDXML is not set
                                      # BR2_PACKAGE_RAPTOR is not set
                                      # BR2_PACKAGE_TINYXML is not set
                                      # BR2_PACKAGE_TINYXML2 is not set
                                      # BR2_PACKAGE_VALIJSON is not set
                                      # BR2_PACKAGE_XERCES is not set
                                      # BR2_PACKAGE_YAJL is not set
                                      # BR2_PACKAGE_YAML_CPP is not set
                                      # Logging
                                      # BR2_PACKAGE_GLOG is not set
                                      # BR2_PACKAGE_LIBLOG4C_LOCALTIME is not set
                                      # BR2_PACKAGE_LIBLOGGING is not set
                                      # BR2_PACKAGE_LOG4CPLUS is not set
                                      # BR2_PACKAGE_LOG4CPP is not set
                                      # BR2_PACKAGE_LOG4CXX is not set
                                      # BR2_PACKAGE_OPENTRACING_CPP is not set
                                      # BR2_PACKAGE_SPDLOG is not set
                                      # BR2_PACKAGE_ZLOG is not set
                                      # Multimedia
                                      # BR2_PACKAGE_BITSTREAM is not set
                                      # BR2_PACKAGE_DAV1D is not set
                                      # BR2_PACKAGE_KVAZAAR is not set
                                      # BR2_PACKAGE_LIBAACS is not set
                                      # BR2_PACKAGE_LIBASS is not set
                                      # BR2_PACKAGE_LIBBDPLUS is not set
                                      # BR2_PACKAGE_LIBBLURAY is not set
                                      BR2_PACKAGE_LIBCAMERA_ARCH_SUPPORTS=y
                                      # BR2_PACKAGE_LIBCAMERA is not set
                                      # BR2_PACKAGE_LIBDCADEC is not set
                                      # BR2_PACKAGE_LIBDVBCSA is not set
                                      # BR2_PACKAGE_LIBDVBPSI is not set
                                      # BR2_PACKAGE_LIBDVBSI is not set
                                      # BR2_PACKAGE_LIBDVDCSS is not set
                                      # BR2_PACKAGE_LIBDVDNAV is not set
                                      # BR2_PACKAGE_LIBDVDREAD is not set
                                      # BR2_PACKAGE_LIBEBML is not set
                                      # BR2_PACKAGE_LIBHDHOMERUN is not set
                                      # BR2_PACKAGE_LIBMATROSKA is not set
                                      # BR2_PACKAGE_LIBMMS is not set
                                      # BR2_PACKAGE_LIBMPEG2 is not set
                                      # BR2_PACKAGE_LIBOGG is not set
                                      # BR2_PACKAGE_LIBOPUSENC is not set
                                      # BR2_PACKAGE_LIBTHEORA is not set
                                      # BR2_PACKAGE_LIBUDFREAD is not set
                                      # BR2_PACKAGE_LIBVPX is not set
                                      # BR2_PACKAGE_LIBYUV is not set
                                      # BR2_PACKAGE_LIVE555 is not set
                                      # BR2_PACKAGE_MEDIASTREAMER is not set
                                      # BR2_PACKAGE_X264 is not set
                                      # BR2_PACKAGE_X265 is not set
                                      # Networking
                                      # BR2_PACKAGE_AGENTPP is not set
                                      # BR2_PACKAGE_AZMQ is not set
                                      # BR2_PACKAGE_AZURE_IOT_SDK_C is not set
                                      # BR2_PACKAGE_BATMAN_ADV is not set
                                      # BR2_PACKAGE_BELLE_SIP is not set
                                      # BR2_PACKAGE_C_ARES is not set
                                      # BR2_PACKAGE_CGIC is not set
                                      # BR2_PACKAGE_CPPZMQ is not set
                                      # BR2_PACKAGE_CURLPP is not set
                                      # BR2_PACKAGE_CZMQ is not set
                                      # BR2_PACKAGE_DAQ is not set
                                      # BR2_PACKAGE_DAVICI is not set
                                      # BR2_PACKAGE_ENET is not set
                                      # BR2_PACKAGE_FILEMQ is not set
                                      # BR2_PACKAGE_FLICKCURL is not set
                                      # BR2_PACKAGE_FREERADIUS_CLIENT is not set
                                      # BR2_PACKAGE_GENSIO is not set
                                      # BR2_PACKAGE_GEOIP is not set
                                      # BR2_PACKAGE_GLIB_NETWORKING is not set
                                      # BR2_PACKAGE_GRPC is not set
                                      # BR2_PACKAGE_GSSDP is not set
                                      # BR2_PACKAGE_GUPNP is not set
                                      # BR2_PACKAGE_GUPNP_AV is not set
                                      # BR2_PACKAGE_GUPNP_DLNA is not set
                                      # BR2_PACKAGE_IBRCOMMON is not set
                                      # BR2_PACKAGE_IBRDTN is not set
                                      # BR2_PACKAGE_LIBCGI is not set
                                      # BR2_PACKAGE_LIBCGICC is not set
                                      # BR2_PACKAGE_LIBCOAP is not set
                                      # BR2_PACKAGE_LIBCPPRESTSDK is not set
                                      # BR2_PACKAGE_LIBCURL is not set
                                      # BR2_PACKAGE_LIBDNET is not set
                                      # BR2_PACKAGE_LIBEXOSIP2 is not set
                                      # BR2_PACKAGE_LIBFCGI is not set
                                      # BR2_PACKAGE_LIBGSASL is not set
                                      # BR2_PACKAGE_LIBHTP is not set
                                      # BR2_PACKAGE_LIBHTTPPARSER is not set
                                      # BR2_PACKAGE_LIBHTTPSERVER is not set
                                      # BR2_PACKAGE_LIBIDN is not set
                                      # BR2_PACKAGE_LIBIDN2 is not set
                                      # BR2_PACKAGE_LIBISCSI is not set
                                      # BR2_PACKAGE_LIBKRB5 is not set
                                      # BR2_PACKAGE_LIBLDNS is not set
                                      # BR2_PACKAGE_LIBMAXMINDDB is not set
                                      # BR2_PACKAGE_LIBMBUS is not set
                                      # BR2_PACKAGE_LIBMEMCACHED is not set
                                      # BR2_PACKAGE_LIBMICROHTTPD is not set
                                      # BR2_PACKAGE_LIBMINIUPNPC is not set
                                      # BR2_PACKAGE_LIBMNL is not set
                                      # BR2_PACKAGE_LIBMODBUS is not set
                                      # BR2_PACKAGE_LIBMODSECURITY is not set
                                      # BR2_PACKAGE_LIBNATPMP is not set
                                      # BR2_PACKAGE_LIBNDP is not set
                                      # BR2_PACKAGE_LIBNET is not set
                                      # BR2_PACKAGE_LIBNETCONF2 is not set
                                      # BR2_PACKAGE_LIBNETFILTER_ACCT is not set
                                      # BR2_PACKAGE_LIBNETFILTER_CONNTRACK is not set
                                      # BR2_PACKAGE_LIBNETFILTER_CTHELPER is not set
                                      # BR2_PACKAGE_LIBNETFILTER_CTTIMEOUT is not set
                                      # BR2_PACKAGE_LIBNETFILTER_LOG is not set
                                      # BR2_PACKAGE_LIBNETFILTER_QUEUE is not set
                                      # BR2_PACKAGE_LIBNFNETLINK is not set
                                      # BR2_PACKAGE_LIBNFTNL is not set
                                      # BR2_PACKAGE_LIBNICE is not set
                                      # BR2_PACKAGE_LIBNIDS is not set
                                      # BR2_PACKAGE_LIBNL is not set
                                      # BR2_PACKAGE_LIBNPUPNP is not set
                                      # BR2_PACKAGE_LIBOAUTH is not set
                                      # BR2_PACKAGE_LIBOPING is not set
                                      # BR2_PACKAGE_LIBOSIP2 is not set
                                      # BR2_PACKAGE_LIBPAGEKITE is not set
                                      # BR2_PACKAGE_LIBPCAP is not set
                                      # BR2_PACKAGE_LIBPJSIP is not set
                                      # BR2_PACKAGE_LIBRELP is not set
                                      # BR2_PACKAGE_LIBRSYNC is not set
                                      # BR2_PACKAGE_LIBSHAIRPLAY is not set
                                      # BR2_PACKAGE_LIBSHOUT is not set
                                      # BR2_PACKAGE_LIBSOCKETCAN is not set
                                      # BR2_PACKAGE_LIBSOUP is not set
                                      # BR2_PACKAGE_LIBSRTP is not set
                                      # BR2_PACKAGE_LIBSTROPHE is not set
                                      # BR2_PACKAGE_LIBTELNET is not set
                                      # BR2_PACKAGE_LIBTIRPC is not set
                                      # BR2_PACKAGE_LIBTORRENT is not set
                                      # BR2_PACKAGE_LIBTORRENT_RASTERBAR is not set
                                      # BR2_PACKAGE_LIBUEV is not set
                                      # BR2_PACKAGE_LIBUHTTPD is not set
                                      # BR2_PACKAGE_LIBUPNP is not set
                                      # BR2_PACKAGE_LIBUPNPP is not set
                                      # BR2_PACKAGE_LIBURIPARSER is not set
                                      # BR2_PACKAGE_LIBUWSC is not set
                                      # BR2_PACKAGE_LIBVNCSERVER is not set
                                      # BR2_PACKAGE_LIBWEBSOCK is not set
                                      # BR2_PACKAGE_LIBWEBSOCKETS is not set
                                      # BR2_PACKAGE_LIBYANG is not set
                                      # BR2_PACKAGE_LKSCTP_TOOLS is not set
                                      # BR2_PACKAGE_MBUFFER is not set
                                      # BR2_PACKAGE_MONGOOSE is not set
                                      # BR2_PACKAGE_NANOMSG is not set
                                      # BR2_PACKAGE_NEON is not set
                                      # BR2_PACKAGE_NETOPEER2 is not set
                                      # BR2_PACKAGE_NGHTTP2 is not set
                                      # BR2_PACKAGE_NORM is not set
                                      # BR2_PACKAGE_NSS_MYHOSTNAME is not set
                                      # BR2_PACKAGE_NSS_PAM_LDAPD is not set
                                      # BR2_PACKAGE_OMNIORB is not set
                                      # BR2_PACKAGE_OPEN62541 is not set
                                      # BR2_PACKAGE_OPENLDAP is not set
                                      # BR2_PACKAGE_OPENMPI is not set
                                      # BR2_PACKAGE_OPENPGM is not set
                                      # BR2_PACKAGE_OPENZWAVE is not set
                                      # BR2_PACKAGE_ORTP is not set
                                      # BR2_PACKAGE_PAHO_MQTT_C is not set
                                      # BR2_PACKAGE_PAHO_MQTT_CPP is not set
                                      # BR2_PACKAGE_PISTACHE is not set
                                      # BR2_PACKAGE_QDECODER is not set
                                      # BR2_PACKAGE_QPID_PROTON is not set
                                      # BR2_PACKAGE_RABBITMQ_C is not set
                                      # BR2_PACKAGE_RESIPROCATE is not set
                                      # BR2_PACKAGE_RESTCLIENT_CPP is not set
                                      # BR2_PACKAGE_RTMPDUMP is not set
                                      # BR2_PACKAGE_SLIRP is not set
                                      # BR2_PACKAGE_SNMPPP is not set
                                      # BR2_PACKAGE_SOFIA_SIP is not set
                                      # BR2_PACKAGE_SYSREPO is not set
                                      # BR2_PACKAGE_THRIFT is not set
                                      # BR2_PACKAGE_USBREDIR is not set
                                      # BR2_PACKAGE_WAMPCC is not set
                                      # BR2_PACKAGE_WEBSOCKETPP is not set
                                      # BR2_PACKAGE_ZEROMQ is not set
                                      # BR2_PACKAGE_ZMQPP is not set
                                      # BR2_PACKAGE_ZYRE is not set
                                      # Other
                                      # BR2_PACKAGE_APR is not set
                                      # BR2_PACKAGE_APR_UTIL is not set
                                      # BR2_PACKAGE_ARMADILLO is not set
                                      # BR2_PACKAGE_ATF is not set
                                      # BR2_PACKAGE_AVRO_C is not set
                                      # BR2_PACKAGE_BCTOOLBOX is not set
                                      # BR2_PACKAGE_BELR is not set
                                      # BR2_PACKAGE_BOOST is not set
                                      # BR2_PACKAGE_C_CAPNPROTO is not set
                                      # BR2_PACKAGE_CAPNPROTO is not set
                                      # BR2_PACKAGE_CCTZ is not set
                                      # BR2_PACKAGE_CEREAL is not set
                                      # BR2_PACKAGE_CLAPACK is not set
                                      # BR2_PACKAGE_CMOCKA is not set
                                      # BR2_PACKAGE_CPPCMS is not set
                                      # BR2_PACKAGE_CRACKLIB is not set
                                      # BR2_PACKAGE_DAWGDIC is not set
                                      # BR2_PACKAGE_DING_LIBS is not set
                                      # BR2_PACKAGE_EIGEN is not set
                                      # BR2_PACKAGE_ELFUTILS is not set
                                      # BR2_PACKAGE_ELL is not set
                                      # BR2_PACKAGE_FFTW is not set
                                      # BR2_PACKAGE_FLANN is not set
                                      # BR2_PACKAGE_FLATBUFFERS is not set
                                      # BR2_PACKAGE_FLATCC is not set
                                      # BR2_PACKAGE_GCONF is not set
                                      # BR2_PACKAGE_GFLAGS is not set
                                      # BR2_PACKAGE_GLI is not set
                                      # BR2_PACKAGE_GLIBMM is not set
                                      # BR2_PACKAGE_GLM is not set
                                      # BR2_PACKAGE_GMP is not set
                                      BR2_PACKAGE_GOBJECT_INTROSPECTION_ARCH_SUPPORTS=y
                                      # gobject-introspection needs python3
                                      # BR2_PACKAGE_GSL is not set
                                      # BR2_PACKAGE_GTEST is not set
                                      BR2_PACKAGE_JEMALLOC_ARCH_SUPPORTS=y
                                      # BR2_PACKAGE_JEMALLOC is not set
                                      # BR2_PACKAGE_LAPACK is not set
                                      BR2_PACKAGE_LIBABSEIL_CPP_ARCH_SUPPORTS=y
                                      # BR2_PACKAGE_LIBABSEIL_CPP is not set
                                      # BR2_PACKAGE_LIBARGTABLE2 is not set
                                      # BR2_PACKAGE_LIBAVL is not set
                                      # BR2_PACKAGE_LIBB64 is not set
                                      # BR2_PACKAGE_LIBBACKTRACE is not set
                                      BR2_PACKAGE_LIBBSD_ARCH_SUPPORTS=y
                                      # BR2_PACKAGE_LIBBSD is not set
                                      # BR2_PACKAGE_LIBBYTESIZE is not set
                                      # BR2_PACKAGE_LIBCAP is not set
                                      # BR2_PACKAGE_LIBCAP_NG is not set
                                      # BR2_PACKAGE_LIBCGROUP is not set
                                      # BR2_PACKAGE_LIBCORRECT is not set
                                      # BR2_PACKAGE_LIBCROSSGUID is not set
                                      # BR2_PACKAGE_LIBCSV is not set
                                      # BR2_PACKAGE_LIBDAEMON is not set
                                      # BR2_PACKAGE_LIBEE is not set
                                      # BR2_PACKAGE_LIBEV is not set
                                      # BR2_PACKAGE_LIBEVDEV is not set
                                      # BR2_PACKAGE_LIBEVENT is not set
                                      # BR2_PACKAGE_LIBFFI is not set
                                      # BR2_PACKAGE_LIBGEE is not set
                                      # BR2_PACKAGE_LIBGEOS is not set
                                      # BR2_PACKAGE_LIBGLIB2 is not set
                                      # BR2_PACKAGE_LIBGLOB is not set
                                      # BR2_PACKAGE_LIBICAL is not set
                                      # BR2_PACKAGE_LIBITE is not set
                                      # BR2_PACKAGE_LIBLINEAR is not set
                                      # BR2_PACKAGE_LIBLOKI is not set
                                      # BR2_PACKAGE_LIBNPTH is not set
                                      BR2_PACKAGE_LIBNSPR_ARCH_SUPPORT=y
                                      # BR2_PACKAGE_LIBNSPR is not set
                                      # BR2_PACKAGE_LIBPFM4 is not set
                                      # BR2_PACKAGE_LIBPLIST is not set
                                      # BR2_PACKAGE_LIBPTHREAD_STUBS is not set
                                      # BR2_PACKAGE_LIBPTHSEM is not set
                                      # BR2_PACKAGE_LIBPWQUALITY is not set
                                      # BR2_PACKAGE_LIBSIGC is not set
                                      BR2_PACKAGE_LIBSIGSEGV_ARCH_SUPPORTS=y
                                      # BR2_PACKAGE_LIBSIGSEGV is not set
                                      # BR2_PACKAGE_LIBSPATIALINDEX is not set
                                      # BR2_PACKAGE_LIBTASN1 is not set
                                      # BR2_PACKAGE_LIBTOMMATH is not set
                                      # BR2_PACKAGE_LIBTPL is not set
                                      # BR2_PACKAGE_LIBUBOX is not set
                                      # BR2_PACKAGE_LIBUCI is not set
                                      BR2_PACKAGE_LIBURCU_ARCH_SUPPORTS=y
                                      # BR2_PACKAGE_LIBURCU is not set
                                      # BR2_PACKAGE_LIBUV is not set
                                      # BR2_PACKAGE_LIGHTNING is not set
                                      # BR2_PACKAGE_LINUX_PAM is not set
                                      # BR2_PACKAGE_LIQUID_DSP is not set
                                      # BR2_PACKAGE_LTTNG_LIBUST is not set
                                      # BR2_PACKAGE_MATIO is not set
                                      # BR2_PACKAGE_MPC is not set
                                      # BR2_PACKAGE_MPDECIMAL is not set
                                      # BR2_PACKAGE_MPFR is not set
                                      # BR2_PACKAGE_MPIR is not set
                                      # BR2_PACKAGE_MSGPACK is not set
                                      # BR2_PACKAGE_ORC is not set
                                      # BR2_PACKAGE_P11_KIT is not set
                                      BR2_PACKAGE_POCO_ARCH_SUPPORTS=y
                                      # BR2_PACKAGE_POCO is not set
                                      BR2_PACKAGE_PROTOBUF_ARCH_SUPPORTS=y
                                      # BR2_PACKAGE_PROTOBUF is not set
                                      # BR2_PACKAGE_PROTOBUF_C is not set
                                      # BR2_PACKAGE_QHULL is not set
                                      # BR2_PACKAGE_QLIBC is not set
                                      # BR2_PACKAGE_RIEMANN_C_CLIENT is not set
                                      # BR2_PACKAGE_SHAPELIB is not set
                                      # BR2_PACKAGE_SKALIBS is not set
                                      # BR2_PACKAGE_SPHINXBASE is not set
                                      # BR2_PACKAGE_TINYCBOR is not set
                                      # BR2_PACKAGE_UVW is not set
                                      # BR2_PACKAGE_XAPIAN is not set
                                      # Security
                                      # BR2_PACKAGE_LIBAPPARMOR is not set
                                      # BR2_PACKAGE_LIBSELINUX is not set
                                      # BR2_PACKAGE_LIBSEPOL is not set
                                      # BR2_PACKAGE_SAFECLIB is not set
                                      # Text and terminal handling
                                      # BR2_PACKAGE_AUGEAS is not set
                                      # BR2_PACKAGE_ENCHANT is not set
                                      # BR2_PACKAGE_FMT is not set
                                      # BR2_PACKAGE_FSTRCMP is not set
                                      # BR2_PACKAGE_ICU is not set
                                      # BR2_PACKAGE_INIH is not set
                                      # BR2_PACKAGE_LIBCLI is not set
                                      # BR2_PACKAGE_LIBEDIT is not set
                                      # BR2_PACKAGE_LIBENCA is not set
                                      # BR2_PACKAGE_LIBESTR is not set
                                      # BR2_PACKAGE_LIBFRIBIDI is not set
                                      # BR2_PACKAGE_LIBUNISTRING is not set
                                      BR2_PACKAGE_LINENOISE=y
                                      # BR2_PACKAGE_NCURSES is not set
                                      # BR2_PACKAGE_NEWT is not set
                                      # BR2_PACKAGE_ONIGURUMA is not set
                                      # BR2_PACKAGE_PCRE is not set
                                      BR2_PACKAGE_PCRE2=y
                                      BR2_PACKAGE_PCRE2_16=y
                                      # BR2_PACKAGE_PCRE2_32 is not set
                                      # BR2_PACKAGE_POPT is not set
                                      # BR2_PACKAGE_RE2 is not set
                                      # BR2_PACKAGE_READLINE is not set
                                      # BR2_PACKAGE_SLANG is not set
                                      # BR2_PACKAGE_TCLAP is not set
                                      # BR2_PACKAGE_UTF8PROC is not set
                                      # Mail
                                      # BR2_PACKAGE_DOVECOT is not set
                                      # BR2_PACKAGE_EXIM is not set
                                      # BR2_PACKAGE_FETCHMAIL is not set
                                      # BR2_PACKAGE_HEIRLOOM_MAILX is not set
                                      # BR2_PACKAGE_LIBESMTP is not set
                                      # BR2_PACKAGE_MSMTP is not set
                                      # BR2_PACKAGE_MUTT is not set
                                      # Miscellaneous
                                      # BR2_PACKAGE_AESPIPE is not set
                                      # BR2_PACKAGE_BC is not set
                                      BR2_PACKAGE_BITCOIN_ARCH_SUPPORTS=y
                                      # BR2_PACKAGE_BITCOIN is not set
                                      # BR2_PACKAGE_CLAMAV is not set
                                      # BR2_PACKAGE_COLLECTD is not set
                                      # BR2_PACKAGE_COLLECTL is not set
                                      # domoticz needs lua 5.3 and a toolchain w/ C++, gcc >= 4.8, NPTL, wchar, dynamic library
                                      # BR2_PACKAGE_EMPTY is not set
                                      # BR2_PACKAGE_GNURADIO is not set
                                      # BR2_PACKAGE_GOOGLEFONTDIRECTORY is not set
                                      # gqrx needs a toolchain w/ C++, threads, wchar, dynamic library
                                      # BR2_PACKAGE_GQRX is not set
                                      # BR2_PACKAGE_GSETTINGS_DESKTOP_SCHEMAS is not set
                                      # BR2_PACKAGE_HAVEGED is not set
                                      # BR2_PACKAGE_LINUX_SYSCALL_SUPPORT is not set
                                      # BR2_PACKAGE_MCRYPT is not set
                                      # BR2_PACKAGE_MOBILE_BROADBAND_PROVIDER_INFO is not set
                                      # BR2_PACKAGE_NETDATA is not set
                                      # BR2_PACKAGE_PROJ is not set
                                      # BR2_PACKAGE_QPDF is not set
                                      # BR2_PACKAGE_SHARED_MIME_INFO is not set
                                      # BR2_PACKAGE_SUNWAIT is not set
                                      # BR2_PACKAGE_TASKD is not set
                                      # BR2_PACKAGE_XUTIL_UTIL_MACROS is not set
                                      # Networking applications
                                      # BR2_PACKAGE_AIRCRACK_NG is not set
                                      # BR2_PACKAGE_AOETOOLS is not set
                                      # BR2_PACKAGE_APACHE is not set
                                      # BR2_PACKAGE_ARGUS is not set
                                      # BR2_PACKAGE_ARP_SCAN is not set
                                      # BR2_PACKAGE_ARPTABLES is not set
                                      # BR2_PACKAGE_ASTERISK is not set
                                      # BR2_PACKAGE_ATFTP is not set
                                      # BR2_PACKAGE_AVAHI is not set
                                      # BR2_PACKAGE_AXEL is not set
                                      # BR2_PACKAGE_BABELD is not set
                                      # BR2_PACKAGE_BANDWIDTHD is not set
                                      # BR2_PACKAGE_BATCTL is not set
                                      # BR2_PACKAGE_BCUSDK is not set
                                      # BR2_PACKAGE_BIND is not set
                                      # BR2_PACKAGE_BIRD is not set
                                      # BR2_PACKAGE_BLUEZ5_UTILS is not set
                                      # BR2_PACKAGE_BMON is not set
                                      # BR2_PACKAGE_BOINC is not set
                                      # BR2_PACKAGE_BRCM_PATCHRAM_PLUS is not set
                                      # BR2_PACKAGE_BRIDGE_UTILS is not set
                                      # BR2_PACKAGE_BWM_NG is not set
                                      # BR2_PACKAGE_C_ICAP is not set
                                      # BR2_PACKAGE_CAN_UTILS is not set
                                      # BR2_PACKAGE_CANNELLONI is not set
                                      # BR2_PACKAGE_CASYNC is not set
                                      # BR2_PACKAGE_CHRONY is not set
                                      # BR2_PACKAGE_CIVETWEB is not set
                                      # BR2_PACKAGE_CONNMAN is not set
                                      # connman-gtk needs libgtk3 and a glibc or uClibc toolchain w/ wchar, threads, resolver, dynamic library
                                      # BR2_PACKAGE_CONNTRACK_TOOLS is not set
                                      # BR2_PACKAGE_CORKSCREW is not set
                                      # BR2_PACKAGE_CRDA is not set
                                      # BR2_PACKAGE_CTORRENT is not set
                                      # BR2_PACKAGE_CUPS is not set
                                      # BR2_PACKAGE_DANTE is not set
                                      # BR2_PACKAGE_DARKHTTPD is not set
                                      # BR2_PACKAGE_DEHYDRATED is not set
                                      # BR2_PACKAGE_DHCPCD is not set
                                      # BR2_PACKAGE_DHCPDUMP is not set
                                      # BR2_PACKAGE_DNSMASQ is not set
                                      # BR2_PACKAGE_DRBD_UTILS is not set
                                      # BR2_PACKAGE_DROPBEAR is not set
                                      # BR2_PACKAGE_EASYFRAMES is not set
                                      # BR2_PACKAGE_EBTABLES is not set
                                      # ejabberd needs erlang, toolchain w/ C++
                                      # BR2_PACKAGE_ETHTOOL is not set
                                      # BR2_PACKAGE_FAIFA is not set
                                      # BR2_PACKAGE_FASTD is not set
                                      # BR2_PACKAGE_FCGIWRAP is not set
                                      # BR2_PACKAGE_FPING is not set
                                      # BR2_PACKAGE_FREESWITCH is not set
                                      # BR2_PACKAGE_FRR is not set
                                      # BR2_PACKAGE_GERBERA is not set
                                      # BR2_PACKAGE_GESFTPSERVER is not set
                                      # BR2_PACKAGE_GLOOX is not set
                                      # BR2_PACKAGE_GLORYTUN is not set
                                      # gupnp-tools needs libgtk3
                                      # BR2_PACKAGE_HANS is not set
                                      BR2_PACKAGE_HAPROXY_ARCH_SUPPORTS=y
                                      # BR2_PACKAGE_HAPROXY is not set
                                      # BR2_PACKAGE_HIAWATHA is not set
                                      # BR2_PACKAGE_HOSTAPD is not set
                                      # BR2_PACKAGE_HTPDATE is not set
                                      # BR2_PACKAGE_HTTPING is not set
                                      # BR2_PACKAGE_I2PD is not set
                                      # BR2_PACKAGE_IBRDTN_TOOLS is not set
                                      # BR2_PACKAGE_IBRDTND is not set
                                      # BR2_PACKAGE_IFMETRIC is not set
                                      # BR2_PACKAGE_IFTOP is not set
                                      BR2_PACKAGE_IFUPDOWN_SCRIPTS=y
                                      # BR2_PACKAGE_IGD2_FOR_LINUX is not set
                                      # BR2_PACKAGE_IGH_ETHERCAT is not set
                                      # BR2_PACKAGE_IGMPPROXY is not set
                                      # BR2_PACKAGE_INADYN is not set
                                      # BR2_PACKAGE_IODINE is not set
                                      # BR2_PACKAGE_IPERF is not set
                                      # BR2_PACKAGE_IPERF3 is not set
                                      # BR2_PACKAGE_IPROUTE2 is not set
                                      # BR2_PACKAGE_IPSET is not set
                                      # BR2_PACKAGE_IPTABLES is not set
                                      # BR2_PACKAGE_IPTRAF_NG is not set
                                      # BR2_PACKAGE_IPUTILS is not set
                                      # BR2_PACKAGE_IRSSI is not set
                                      # BR2_PACKAGE_IW is not set
                                      # BR2_PACKAGE_IWD is not set
                                      # BR2_PACKAGE_JANUS_GATEWAY is not set
                                      # BR2_PACKAGE_KEEPALIVED is not set
                                      # BR2_PACKAGE_KISMET is not set
                                      # BR2_PACKAGE_KNOCK is not set
                                      # BR2_PACKAGE_LEAFNODE2 is not set
                                      # BR2_PACKAGE_LFT is not set
                                      # BR2_PACKAGE_LFTP is not set
                                      # BR2_PACKAGE_LIGHTTPD is not set
                                      # BR2_PACKAGE_LINKNX is not set
                                      # BR2_PACKAGE_LINKS is not set
                                      # BR2_PACKAGE_LINPHONE is not set
                                      # BR2_PACKAGE_LINUX_ZIGBEE is not set
                                      # BR2_PACKAGE_LINUXPTP is not set
                                      # BR2_PACKAGE_LLDPD is not set
                                      # BR2_PACKAGE_LRZSZ is not set
                                      # BR2_PACKAGE_LYNX is not set
                                      # BR2_PACKAGE_MACCHANGER is not set
                                      # BR2_PACKAGE_MEMCACHED is not set
                                      # BR2_PACKAGE_MII_DIAG is not set
                                      # BR2_PACKAGE_MINI_SNMPD is not set
                                      # BR2_PACKAGE_MINIDLNA is not set
                                      # BR2_PACKAGE_MINISSDPD is not set
                                      BR2_PACKAGE_MJPG_STREAMER=y
                                      # BR2_PACKAGE_MODEM_MANAGER is not set
                                      BR2_PACKAGE_MONGREL2_LIBC_SUPPORTS=y
                                      # BR2_PACKAGE_MONGREL2 is not set
                                      # BR2_PACKAGE_MONKEY is not set
                                      # BR2_PACKAGE_MOSH is not set
                                      # BR2_PACKAGE_MOSQUITTO is not set
                                      # BR2_PACKAGE_MROUTED is not set
                                      # BR2_PACKAGE_MRP is not set
                                      # BR2_PACKAGE_MTR is not set
                                      # BR2_PACKAGE_NBD is not set
                                      # BR2_PACKAGE_NCFTP is not set
                                      # BR2_PACKAGE_NDISC6 is not set
                                      # BR2_PACKAGE_NETATALK is not set
                                      # BR2_PACKAGE_NETCALC is not set
                                      # BR2_PACKAGE_NETPLUG is not set
                                      # BR2_PACKAGE_NETSNMP is not set
                                      # BR2_PACKAGE_NETSTAT_NAT is not set
                                      # BR2_PACKAGE_NETWORK_MANAGER is not set
                                      # BR2_PACKAGE_NFACCT is not set
                                      # BR2_PACKAGE_NFTABLES is not set
                                      # BR2_PACKAGE_NGINX is not set
                                      # BR2_PACKAGE_NGIRCD is not set
                                      # BR2_PACKAGE_NGREP is not set
                                      # BR2_PACKAGE_NLOAD is not set
                                      # BR2_PACKAGE_NMAP is not set
                                      # BR2_PACKAGE_NOIP is not set
                                      # BR2_PACKAGE_NTP is not set
                                      # BR2_PACKAGE_NUTTCP is not set
                                      # BR2_PACKAGE_ODHCP6C is not set
                                      # BR2_PACKAGE_ODHCPLOC is not set
                                      # BR2_PACKAGE_OLSR is not set
                                      # BR2_PACKAGE_OPEN_LLDP is not set
                                      # BR2_PACKAGE_OPEN_PLC_UTILS is not set
                                      # BR2_PACKAGE_OPENNTPD is not set
                                      # BR2_PACKAGE_OPENOBEX is not set
                                      # BR2_PACKAGE_OPENRESOLV is not set
                                      # BR2_PACKAGE_OPENSSH is not set
                                      # BR2_PACKAGE_OPENSWAN is not set
                                      # BR2_PACKAGE_OPENVPN is not set
                                      # BR2_PACKAGE_P910ND is not set
                                      # BR2_PACKAGE_PARPROUTED is not set
                                      # BR2_PACKAGE_PHIDGETWEBSERVICE is not set
                                      # BR2_PACKAGE_PHYTOOL is not set
                                      # BR2_PACKAGE_PIMD is not set
                                      # BR2_PACKAGE_PIXIEWPS is not set
                                      # BR2_PACKAGE_POUND is not set
                                      # BR2_PACKAGE_PPPD is not set
                                      # BR2_PACKAGE_PPTP_LINUX is not set
                                      # BR2_PACKAGE_PRIVOXY is not set
                                      # BR2_PACKAGE_PROFTPD is not set
                                      # prosody needs a Lua <= 5.3
                                      # BR2_PACKAGE_PROXYCHAINS_NG is not set
                                      # BR2_PACKAGE_PTPD is not set
                                      # BR2_PACKAGE_PTPD2 is not set
                                      # BR2_PACKAGE_PURE_FTPD is not set
                                      # BR2_PACKAGE_PUTTY is not set
                                      # BR2_PACKAGE_QUAGGA is not set
                                      # rabbitmq-server needs erlang
                                      # BR2_PACKAGE_RADVD is not set
                                      # BR2_PACKAGE_REAVER is not set
                                      # BR2_PACKAGE_REDIR is not set
                                      # BR2_PACKAGE_RP_PPPOE is not set
                                      # BR2_PACKAGE_RPCBIND is not set
                                      # BR2_PACKAGE_RSH_REDONE is not set
                                      # BR2_PACKAGE_RSYNC is not set
                                      # BR2_PACKAGE_RTORRENT is not set
                                      # BR2_PACKAGE_RTPTOOLS is not set
                                      # BR2_PACKAGE_RYGEL is not set
                                      # BR2_PACKAGE_S6_DNS is not set
                                      # BR2_PACKAGE_S6_NETWORKING is not set
                                      # BR2_PACKAGE_SAMBA4 is not set
                                      # BR2_PACKAGE_SCONESERVER is not set
                                      # BR2_PACKAGE_SER2NET is not set
                                      # BR2_PACKAGE_SHADOWSOCKS_LIBEV is not set
                                      # BR2_PACKAGE_SHAIRPORT_SYNC is not set
                                      # BR2_PACKAGE_SHELLINABOX is not set
                                      # BR2_PACKAGE_SMCROUTE is not set
                                      # BR2_PACKAGE_SNGREP is not set
                                      # BR2_PACKAGE_SNORT is not set
                                      # BR2_PACKAGE_SOCAT is not set
                                      # BR2_PACKAGE_SOCKETCAND is not set
                                      # BR2_PACKAGE_SOFTETHER is not set
                                      # BR2_PACKAGE_SPAWN_FCGI is not set
                                      # BR2_PACKAGE_SPICE_PROTOCOL is not set
                                      # BR2_PACKAGE_SQUID is not set
                                      # BR2_PACKAGE_SSDP_RESPONDER is not set
                                      # BR2_PACKAGE_SSHGUARD is not set
                                      # BR2_PACKAGE_SSHPASS is not set
                                      # BR2_PACKAGE_SSLH is not set
                                      # BR2_PACKAGE_STRONGSWAN is not set
                                      # BR2_PACKAGE_STUNNEL is not set
                                      # BR2_PACKAGE_TCPDUMP is not set
                                      # BR2_PACKAGE_TCPING is not set
                                      # BR2_PACKAGE_TCPREPLAY is not set
                                      # BR2_PACKAGE_THTTPD is not set
                                      # BR2_PACKAGE_TINC is not set
                                      # BR2_PACKAGE_TINYPROXY is not set
                                      # BR2_PACKAGE_TINYSSH is not set
                                      # BR2_PACKAGE_TOR is not set
                                      # BR2_PACKAGE_TRACEROUTE is not set
                                      # BR2_PACKAGE_TRANSMISSION is not set
                                      # BR2_PACKAGE_TUNCTL is not set
                                      # BR2_PACKAGE_TVHEADEND is not set
                                      # BR2_PACKAGE_UACME is not set
                                      # BR2_PACKAGE_UDPCAST is not set
                                      # BR2_PACKAGE_UFTP is not set
                                      # BR2_PACKAGE_UHTTPD is not set
                                      # BR2_PACKAGE_ULOGD is not set
                                      # BR2_PACKAGE_UNBOUND is not set
                                      # BR2_PACKAGE_UREDIR is not set
                                      # BR2_PACKAGE_USHARE is not set
                                      # BR2_PACKAGE_USSP_PUSH is not set
                                      # BR2_PACKAGE_VDE2 is not set
                                      # BR2_PACKAGE_VDR is not set
                                      # BR2_PACKAGE_VNSTAT is not set
                                      # BR2_PACKAGE_VPNC is not set
                                      # BR2_PACKAGE_VSFTPD is not set
                                      # BR2_PACKAGE_VTUN is not set
                                      # BR2_PACKAGE_WAVEMON is not set
                                      # BR2_PACKAGE_WIREGUARD_LINUX_COMPAT is not set
                                      # BR2_PACKAGE_WIREGUARD_TOOLS is not set
                                      # BR2_PACKAGE_WIRELESS_REGDB is not set
                                      # BR2_PACKAGE_WIRELESS_TOOLS is not set
                                      # BR2_PACKAGE_WIRESHARK is not set
                                      # BR2_PACKAGE_WPA_SUPPLICANT is not set
                                      # BR2_PACKAGE_WPAN_TOOLS is not set
                                      # BR2_PACKAGE_XINETD is not set
                                      # BR2_PACKAGE_XL2TP is not set
                                      # BR2_PACKAGE_XTABLES_ADDONS is not set
                                      # BR2_PACKAGE_ZNC is not set
                                      # Package managers
                                      # Please note:
                                      # - Buildroot does *not* generate binary packages,
                                      # - Buildroot does *not* install any package database.
                                      # It is up to you to provide those by yourself if you
                                      # want to use any of those package managers.
                                      # See the manual:
                                      # http://buildroot.org/manual.html#faq-no-binary-packages
                                      # BR2_PACKAGE_OPKG is not set
                                      # Real-Time
                                      # BR2_PACKAGE_XENOMAI is not set
                                      # Security
                                      # BR2_PACKAGE_APPARMOR is not set
                                      # BR2_PACKAGE_CHECKPOLICY is not set
                                      # BR2_PACKAGE_IMA_EVM_UTILS is not set
                                      # BR2_PACKAGE_OPTEE_BENCHMARK is not set
                                      # BR2_PACKAGE_OPTEE_CLIENT is not set
                                      # BR2_PACKAGE_PAXTEST is not set
                                      # BR2_PACKAGE_REFPOLICY is not set
                                      # BR2_PACKAGE_RESTORECOND is not set
                                      # BR2_PACKAGE_SELINUX_PYTHON is not set
                                      # BR2_PACKAGE_SEMODULE_UTILS is not set
                                      # setools needs python3
                                      BR2_PACKAGE_URANDOM_SCRIPTS=y
                                      # Shell and utilities
                                      # Shells
                                      # BR2_PACKAGE_MKSH is not set
                                      # BR2_PACKAGE_ZSH is not set
                                      # Utilities
                                      # BR2_PACKAGE_AT is not set
                                      # BR2_PACKAGE_CCRYPT is not set
                                      # BR2_PACKAGE_DIALOG is not set
                                      # BR2_PACKAGE_DTACH is not set
                                      # BR2_PACKAGE_EASY_RSA is not set
                                      # BR2_PACKAGE_FILE is not set
                                      # BR2_PACKAGE_GNUPG is not set
                                      # BR2_PACKAGE_GNUPG2 is not set
                                      # BR2_PACKAGE_INOTIFY_TOOLS is not set
                                      # BR2_PACKAGE_LOCKFILE_PROGS is not set
                                      # BR2_PACKAGE_LOGROTATE is not set
                                      # BR2_PACKAGE_LOGSURFER is not set
                                      # BR2_PACKAGE_PDMENU is not set
                                      # BR2_PACKAGE_PINENTRY is not set
                                      # BR2_PACKAGE_QPRINT is not set
                                      # BR2_PACKAGE_RANGER is not set
                                      # BR2_PACKAGE_RTTY is not set
                                      # BR2_PACKAGE_SCREEN is not set
                                      # BR2_PACKAGE_SUDO is not set
                                      # BR2_PACKAGE_TINI is not set
                                      # BR2_PACKAGE_TMUX is not set
                                      # BR2_PACKAGE_TTYD is not set
                                      # BR2_PACKAGE_XMLSTARLET is not set
                                      # BR2_PACKAGE_XXHASH is not set
                                      # BR2_PACKAGE_YTREE is not set
                                      # System tools
                                      # BR2_PACKAGE_ACL is not set
                                      # BR2_PACKAGE_ANDROID_TOOLS is not set
                                      # BR2_PACKAGE_ATOP is not set
                                      # BR2_PACKAGE_ATTR is not set
                                      # BR2_PACKAGE_BUBBLEWRAP is not set
                                      # BR2_PACKAGE_CGROUPFS_MOUNT is not set
                                      # circus needs Python 3 and a toolchain w/ C++, threads
                                      # BR2_PACKAGE_CPULOAD is not set
                                      # BR2_PACKAGE_DAEMON is not set
                                      # BR2_PACKAGE_DC3DD is not set
                                      # BR2_PACKAGE_DDRESCUE is not set
                                      # BR2_PACKAGE_DOCKER_COMPOSE is not set
                                      # BR2_PACKAGE_EARLYOOM is not set
                                      # BR2_PACKAGE_EMLOG is not set
                                      # BR2_PACKAGE_FTOP is not set
                                      # BR2_PACKAGE_GETENT is not set
                                      # BR2_PACKAGE_GKRELLM is not set
                                      # BR2_PACKAGE_HTOP is not set
                                      # BR2_PACKAGE_IBM_SW_TPM2 is not set
                                      BR2_PACKAGE_INITSCRIPTS=y
                                      # iotop depends on python or python3
                                      # BR2_PACKAGE_IPRUTILS is not set
                                      # BR2_PACKAGE_IRQBALANCE is not set
                                      # BR2_PACKAGE_KEYUTILS is not set
                                      BR2_PACKAGE_KMOD=y
                                      # BR2_PACKAGE_LIBOSTREE is not set
                                      # BR2_PACKAGE_LXC is not set
                                      # BR2_PACKAGE_MFOC is not set
                                      # BR2_PACKAGE_MONIT is not set
                                      # BR2_PACKAGE_MULTIPATH_TOOLS is not set
                                      # BR2_PACKAGE_NCDU is not set
                                      # netifrc needs openrc as init system
                                      # BR2_PACKAGE_NUT is not set
                                      # pamtester depends on linux-pam
                                      # BR2_PACKAGE_POLKIT is not set
                                      # BR2_PACKAGE_PROCRANK_LINUX is not set
                                      # BR2_PACKAGE_PWGEN is not set
                                      # BR2_PACKAGE_QUOTA is not set
                                      # BR2_PACKAGE_QUOTATOOL is not set
                                      # BR2_PACKAGE_RAUC is not set
                                      # BR2_PACKAGE_S6 is not set
                                      # BR2_PACKAGE_S6_LINUX_INIT is not set
                                      # BR2_PACKAGE_S6_LINUX_UTILS is not set
                                      # BR2_PACKAGE_S6_PORTABLE_UTILS is not set
                                      # BR2_PACKAGE_S6_RC is not set
                                      # BR2_PACKAGE_SCRUB is not set
                                      # BR2_PACKAGE_SCRYPT is not set
                                      # sdbusplus needs systemd and a toolchain w/ C++, gcc >= 7
                                      # BR2_PACKAGE_SMACK is not set
                                      # supervisor needs a python interpreter
                                      # BR2_PACKAGE_SWUPDATE is not set
                                      BR2_PACKAGE_SYSTEMD_ARCH_SUPPORTS=y
                                      # BR2_PACKAGE_TPM_TOOLS is not set
                                      # BR2_PACKAGE_TPM2_ABRMD is not set
                                      # BR2_PACKAGE_TPM2_TOOLS is not set
                                      # BR2_PACKAGE_TPM2_TOTP is not set
                                      # BR2_PACKAGE_UNSCD is not set
                                      BR2_PACKAGE_UTIL_LINUX=y
                                      BR2_PACKAGE_UTIL_LINUX_LIBS=y
                                      BR2_PACKAGE_UTIL_LINUX_LIBBLKID=y
                                      # BR2_PACKAGE_UTIL_LINUX_LIBFDISK is not set
                                      # BR2_PACKAGE_UTIL_LINUX_LIBMOUNT is not set
                                      # BR2_PACKAGE_UTIL_LINUX_LIBSMARTCOLS is not set
                                      BR2_PACKAGE_UTIL_LINUX_LIBUUID=y
                                      # BR2_PACKAGE_UTIL_LINUX_BINARIES is not set
                                      # BR2_PACKAGE_UTIL_LINUX_AGETTY is not set
                                      # BR2_PACKAGE_UTIL_LINUX_BFS is not set
                                      # BR2_PACKAGE_UTIL_LINUX_CAL is not set
                                      # BR2_PACKAGE_UTIL_LINUX_CHFN_CHSH is not set
                                      # BR2_PACKAGE_UTIL_LINUX_CHMEM is not set
                                      # BR2_PACKAGE_UTIL_LINUX_CRAMFS is not set
                                      # BR2_PACKAGE_UTIL_LINUX_EJECT is not set
                                      # BR2_PACKAGE_UTIL_LINUX_FALLOCATE is not set
                                      # BR2_PACKAGE_UTIL_LINUX_FDFORMAT is not set
                                      # BR2_PACKAGE_UTIL_LINUX_FSCK is not set
                                      # BR2_PACKAGE_UTIL_LINUX_HARDLINK is not set
                                      # BR2_PACKAGE_UTIL_LINUX_HWCLOCK is not set
                                      # BR2_PACKAGE_UTIL_LINUX_IPCRM is not set
                                      # BR2_PACKAGE_UTIL_LINUX_IPCS is not set
                                      # BR2_PACKAGE_UTIL_LINUX_KILL is not set
                                      # BR2_PACKAGE_UTIL_LINUX_LAST is not set
                                      # BR2_PACKAGE_UTIL_LINUX_LINE is not set
                                      # BR2_PACKAGE_UTIL_LINUX_LOGGER is not set
                                      # BR2_PACKAGE_UTIL_LINUX_LOGIN is not set
                                      # BR2_PACKAGE_UTIL_LINUX_LOSETUP is not set
                                      # BR2_PACKAGE_UTIL_LINUX_LSLOGINS is not set
                                      # BR2_PACKAGE_UTIL_LINUX_LSMEM is not set
                                      # BR2_PACKAGE_UTIL_LINUX_MESG is not set
                                      # BR2_PACKAGE_UTIL_LINUX_MINIX is not set
                                      # BR2_PACKAGE_UTIL_LINUX_MORE is not set
                                      # BR2_PACKAGE_UTIL_LINUX_MOUNT is not set
                                      # BR2_PACKAGE_UTIL_LINUX_MOUNTPOINT is not set
                                      # BR2_PACKAGE_UTIL_LINUX_NEWGRP is not set
                                      # BR2_PACKAGE_UTIL_LINUX_NOLOGIN is not set
                                      # BR2_PACKAGE_UTIL_LINUX_NSENTER is not set
                                      # BR2_PACKAGE_UTIL_LINUX_PG is not set
                                      # BR2_PACKAGE_UTIL_LINUX_PARTX is not set
                                      # BR2_PACKAGE_UTIL_LINUX_PIVOT_ROOT is not set
                                      # BR2_PACKAGE_UTIL_LINUX_RAW is not set
                                      # BR2_PACKAGE_UTIL_LINUX_RENAME is not set
                                      # BR2_PACKAGE_UTIL_LINUX_RFKILL is not set
                                      # BR2_PACKAGE_UTIL_LINUX_RUNUSER is not set
                                      # BR2_PACKAGE_UTIL_LINUX_SCHEDUTILS is not set
                                      # BR2_PACKAGE_UTIL_LINUX_SETPRIV is not set
                                      # BR2_PACKAGE_UTIL_LINUX_SETTERM is not set
                                      # BR2_PACKAGE_UTIL_LINUX_SU is not set
                                      # BR2_PACKAGE_UTIL_LINUX_SULOGIN is not set
                                      # BR2_PACKAGE_UTIL_LINUX_SWITCH_ROOT is not set
                                      # BR2_PACKAGE_UTIL_LINUX_TUNELP is not set
                                      # BR2_PACKAGE_UTIL_LINUX_UL is not set
                                      # BR2_PACKAGE_UTIL_LINUX_UNSHARE is not set
                                      # BR2_PACKAGE_UTIL_LINUX_UTMPDUMP is not set
                                      BR2_PACKAGE_UTIL_LINUX_UUIDD=y
                                      # BR2_PACKAGE_UTIL_LINUX_VIPW is not set
                                      # BR2_PACKAGE_UTIL_LINUX_WALL is not set
                                      # BR2_PACKAGE_UTIL_LINUX_WIPEFS is not set
                                      # BR2_PACKAGE_UTIL_LINUX_WDCTL is not set
                                      # BR2_PACKAGE_UTIL_LINUX_WRITE is not set
                                      # BR2_PACKAGE_UTIL_LINUX_ZRAMCTL is not set
                                      # BR2_PACKAGE_WATCHDOG is not set
                                      # BR2_PACKAGE_XDG_DBUS_PROXY is not set
                                      # Text editors and viewers
                                      # BR2_PACKAGE_ED is not set
                                      # BR2_PACKAGE_JOE is not set
                                      # BR2_PACKAGE_MC is not set
                                      # BR2_PACKAGE_MG is not set
                                      # BR2_PACKAGE_MOST is not set
                                      # BR2_PACKAGE_NANO is not set
                                      # BR2_PACKAGE_UEMACS is not set
                                      # Filesystem images
                                      # BR2_TARGET_ROOTFS_AXFS is not set
                                      # BR2_TARGET_ROOTFS_BTRFS is not set
                                      # BR2_TARGET_ROOTFS_CLOOP is not set
                                      # BR2_TARGET_ROOTFS_CPIO is not set
                                      # BR2_TARGET_ROOTFS_CRAMFS is not set
                                      # BR2_TARGET_ROOTFS_EROFS is not set
                                      BR2_TARGET_ROOTFS_EXT2=y
                                      # BR2_TARGET_ROOTFS_EXT2_2r0 is not set
                                      # BR2_TARGET_ROOTFS_EXT2_2r1 is not set
                                      # BR2_TARGET_ROOTFS_EXT2_3 is not set
                                      BR2_TARGET_ROOTFS_EXT2_4=y
                                      BR2_TARGET_ROOTFS_EXT2_GEN=4
                                      BR2_TARGET_ROOTFS_EXT2_REV=1
                                      BR2_TARGET_ROOTFS_EXT2_LABEL="rootfs"
                                      BR2_TARGET_ROOTFS_EXT2_SIZE="130M"
                                      BR2_TARGET_ROOTFS_EXT2_INODES=0
                                      BR2_TARGET_ROOTFS_EXT2_RESBLKS=5
                                      BR2_TARGET_ROOTFS_EXT2_MKFS_OPTIONS="-O ^64bit"
                                      BR2_TARGET_ROOTFS_EXT2_NONE=y
                                      # BR2_TARGET_ROOTFS_EXT2_GZIP is not set
                                      # BR2_TARGET_ROOTFS_EXT2_BZIP2 is not set
                                      # BR2_TARGET_ROOTFS_EXT2_LZ4 is not set
                                      # BR2_TARGET_ROOTFS_EXT2_LZMA is not set
                                      # BR2_TARGET_ROOTFS_EXT2_LZO is not set
                                      # BR2_TARGET_ROOTFS_EXT2_XZ is not set
                                      # BR2_TARGET_ROOTFS_F2FS is not set
                                      # BR2_TARGET_ROOTFS_INITRAMFS is not set
                                      # BR2_TARGET_ROOTFS_JFFS2 is not set
                                      # BR2_TARGET_ROOTFS_ROMFS is not set
                                      # BR2_TARGET_ROOTFS_SQUASHFS is not set
                                      BR2_TARGET_ROOTFS_TAR=y
                                      BR2_TARGET_ROOTFS_TAR_NONE=y
                                      # BR2_TARGET_ROOTFS_TAR_GZIP is not set
                                      # BR2_TARGET_ROOTFS_TAR_BZIP2 is not set
                                      # BR2_TARGET_ROOTFS_TAR_LZ4 is not set
                                      # BR2_TARGET_ROOTFS_TAR_LZMA is not set
                                      # BR2_TARGET_ROOTFS_TAR_LZO is not set
                                      # BR2_TARGET_ROOTFS_TAR_XZ is not set
                                      BR2_TARGET_ROOTFS_TAR_OPTIONS=""
                                      # BR2_TARGET_ROOTFS_UBI is not set
                                      # BR2_TARGET_ROOTFS_UBIFS is not set
                                      # BR2_TARGET_ROOTFS_YAFFS2 is not set
                                      # Bootloaders
                                      # BR2_TARGET_BAREBOX is not set
                                      BR2_TARGET_OPENSBI=y
                                      BR2_TARGET_OPENSBI_PLAT="thead/c910"
                                      # BR2_TARGET_OPENSBI_LINUX_PAYLOAD is not set
                                      BR2_TARGET_UBOOT=y
                                      BR2_TARGET_UBOOT_BUILD_SYSTEM_KCONFIG=y
                                      # BR2_TARGET_UBOOT_BUILD_SYSTEM_LEGACY is not set
                                      # BR2_TARGET_UBOOT_LATEST_VERSION is not set
                                      # BR2_TARGET_UBOOT_CUSTOM_VERSION is not set
                                      # BR2_TARGET_UBOOT_CUSTOM_TARBALL is not set
                                      BR2_TARGET_UBOOT_CUSTOM_GIT=y
                                      # BR2_TARGET_UBOOT_CUSTOM_HG is not set
                                      # BR2_TARGET_UBOOT_CUSTOM_SVN is not set
                                      BR2_TARGET_UBOOT_CUSTOM_REPO_URL="https://gitee.com/weidongshan/NezaD1-u-boot-2018.git"
                                      BR2_TARGET_UBOOT_CUSTOM_REPO_VERSION="origin/master"
                                      BR2_TARGET_UBOOT_VERSION="origin/master"
                                      BR2_TARGET_UBOOT_PATCH=""
                                      BR2_TARGET_UBOOT_USE_DEFCONFIG=y
                                      # BR2_TARGET_UBOOT_USE_CUSTOM_CONFIG is not set
                                      BR2_TARGET_UBOOT_BOARD_DEFCONFIG="sun20iw1p1"
                                      BR2_TARGET_UBOOT_CONFIG_FRAGMENT_FILES=""
                                      BR2_TARGET_UBOOT_NEEDS_DTC=y
                                      BR2_TARGET_UBOOT_NEEDS_PYTHON=y
                                      # BR2_TARGET_UBOOT_NEEDS_PYTHON2 is not set
                                      BR2_TARGET_UBOOT_NEEDS_PYTHON3=y
                                      BR2_TARGET_UBOOT_NEEDS_PYLIBFDT=y
                                      # BR2_TARGET_UBOOT_NEEDS_PYELFTOOLS is not set
                                      BR2_TARGET_UBOOT_NEEDS_OPENSSL=y
                                      # BR2_TARGET_UBOOT_NEEDS_LZOP is not set
                                      BR2_TARGET_UBOOT_NEEDS_OPENSBI=y
                                      # U-Boot binary format
                                      # BR2_TARGET_UBOOT_FORMAT_AIS is not set
                                      # BR2_TARGET_UBOOT_FORMAT_BIN is not set
                                      # BR2_TARGET_UBOOT_FORMAT_DTB_BIN is not set
                                      # BR2_TARGET_UBOOT_FORMAT_NAND_BIN is not set
                                      # BR2_TARGET_UBOOT_FORMAT_ELF is not set
                                      # BR2_TARGET_UBOOT_FORMAT_IMG is not set
                                      # BR2_TARGET_UBOOT_FORMAT_DTB_IMG is not set
                                      # BR2_TARGET_UBOOT_FORMAT_IMX is not set
                                      # BR2_TARGET_UBOOT_FORMAT_DTB_IMX is not set
                                      # BR2_TARGET_UBOOT_FORMAT_ITB is not set
                                      BR2_TARGET_UBOOT_FORMAT_CUSTOM=y
                                      BR2_TARGET_UBOOT_FORMAT_CUSTOM_NAME="u-boot-sun20iw1p1.bin"
                                      # BR2_TARGET_UBOOT_SPL is not set
                                      BR2_TARGET_UBOOT_CUSTOM_DTS_PATH=""
                                      BR2_TARGET_UBOOT_CUSTOM_MAKEOPTS=""
                                      # Host utilities
                                      # BR2_PACKAGE_HOST_ABOOTIMG is not set
                                      # BR2_PACKAGE_HOST_AESPIPE is not set
                                      # BR2_PACKAGE_HOST_ANDROID_TOOLS is not set
                                      # BR2_PACKAGE_HOST_ASN1C is not set
                                      # BR2_PACKAGE_HOST_BABELTRACE2 is not set
                                      # BR2_PACKAGE_HOST_BTRFS_PROGS is not set
                                      # BR2_PACKAGE_HOST_CHECKPOLICY is not set
                                      # BR2_PACKAGE_HOST_CHECKSEC is not set
                                      # BR2_PACKAGE_HOST_CMAKE is not set
                                      # BR2_PACKAGE_HOST_CRAMFS is not set
                                      # BR2_PACKAGE_HOST_CRYPTSETUP is not set
                                      # BR2_PACKAGE_HOST_DBUS_PYTHON is not set
                                      # BR2_PACKAGE_HOST_DFU_UTIL is not set
                                      # BR2_PACKAGE_HOST_DOS2UNIX is not set
                                      # BR2_PACKAGE_HOST_DOSFSTOOLS is not set
                                      # BR2_PACKAGE_HOST_DOXYGEN is not set
                                      BR2_PACKAGE_HOST_DTC=y
                                      BR2_PACKAGE_HOST_E2FSPROGS=y
                                      # BR2_PACKAGE_HOST_E2TOOLS is not set
                                      # BR2_PACKAGE_HOST_ENVIRONMENT_SETUP is not set
                                      # BR2_PACKAGE_HOST_EROFS_UTILS is not set
                                      BR2_PACKAGE_HOST_EUDEV=y
                                      # BR2_PACKAGE_HOST_EXFATPROGS is not set
                                      # BR2_PACKAGE_HOST_F2FS_TOOLS is not set
                                      # BR2_PACKAGE_HOST_FAKETIME is not set
                                      # BR2_PACKAGE_HOST_FATCAT is not set
                                      # BR2_PACKAGE_HOST_FWUP is not set
                                      # BR2_PACKAGE_HOST_GENEXT2FS is not set
                                      BR2_PACKAGE_HOST_GENIMAGE=y
                                      # BR2_PACKAGE_HOST_GENPART is not set
                                      # BR2_PACKAGE_HOST_GNUPG is not set
                                      BR2_PACKAGE_HOST_GO_HOST_ARCH_SUPPORTS=y
                                      BR2_PACKAGE_HOST_GO_BOOTSTRAP_ARCH_SUPPORTS=y
                                      BR2_PACKAGE_HOST_GOOGLE_BREAKPAD_ARCH_SUPPORTS=y
                                      # BR2_PACKAGE_HOST_GPTFDISK is not set
                                      # BR2_PACKAGE_HOST_IMAGEMAGICK is not set
                                      # BR2_PACKAGE_HOST_IMX_MKIMAGE is not set
                                      # BR2_PACKAGE_HOST_JQ is not set
                                      # BR2_PACKAGE_HOST_JSMIN is not set
                                      BR2_PACKAGE_HOST_KMOD=y
                                      # BR2_PACKAGE_HOST_KMOD_GZ is not set
                                      # BR2_PACKAGE_HOST_KMOD_XZ is not set
                                      # BR2_PACKAGE_HOST_LIBP11 is not set
                                      # BR2_PACKAGE_HOST_LPC3250LOADER is not set
                                      # BR2_PACKAGE_HOST_LTTNG_BABELTRACE is not set
                                      # BR2_PACKAGE_HOST_MENDER_ARTIFACT is not set
                                      # BR2_PACKAGE_HOST_MESON_TOOLS is not set
                                      # BR2_PACKAGE_HOST_MKPASSWD is not set
                                      # BR2_PACKAGE_HOST_MTD is not set
                                      # BR2_PACKAGE_HOST_MTOOLS is not set
                                      # BR2_PACKAGE_HOST_ODB is not set
                                      # BR2_PACKAGE_HOST_OPENOCD is not set
                                      # BR2_PACKAGE_HOST_OPKG_UTILS is not set
                                      # BR2_PACKAGE_HOST_PARTED is not set
                                      BR2_PACKAGE_HOST_PATCHELF=y
                                      # BR2_PACKAGE_HOST_PIGZ is not set
                                      # BR2_PACKAGE_HOST_PKGCONF is not set
                                      # BR2_PACKAGE_HOST_PWGEN is not set
                                      # BR2_PACKAGE_HOST_PYTHON is not set
                                      # BR2_PACKAGE_HOST_PYTHON_CYTHON is not set
                                      # BR2_PACKAGE_HOST_PYTHON_LXML is not set
                                      # BR2_PACKAGE_HOST_PYTHON_SIX is not set
                                      # BR2_PACKAGE_HOST_PYTHON_XLRD is not set
                                      # BR2_PACKAGE_HOST_PYTHON3 is not set
                                      BR2_PACKAGE_HOST_QEMU_ARCH_SUPPORTS=y
                                      BR2_PACKAGE_HOST_QEMU_SYSTEM_ARCH_SUPPORTS=y
                                      BR2_PACKAGE_HOST_QEMU_USER_ARCH_SUPPORTS=y
                                      # BR2_PACKAGE_HOST_QEMU is not set
                                      # BR2_PACKAGE_HOST_QORIQ_RCW is not set
                                      # BR2_PACKAGE_HOST_RAUC is not set
                                      BR2_PACKAGE_HOST_RUSTC_ARCH_SUPPORTS=y
                                      BR2_PACKAGE_HOST_RUSTC_ARCH="riscv64"
                                      # BR2_PACKAGE_HOST_RUSTC is not set
                                      BR2_PACKAGE_PROVIDES_HOST_RUSTC="host-rust-bin"
                                      # BR2_PACKAGE_HOST_SAM_BA is not set
                                      # BR2_PACKAGE_HOST_SDBUSPLUS is not set
                                      # BR2_PACKAGE_HOST_SENTRY_CLI is not set
                                      # BR2_PACKAGE_HOST_SQUASHFS is not set
                                      # BR2_PACKAGE_HOST_SWIG is not set
                                      BR2_PACKAGE_HOST_UBOOT_TOOLS=y
                                      # BR2_PACKAGE_HOST_UBOOT_TOOLS_FIT_SUPPORT is not set
                                      # BR2_PACKAGE_HOST_UBOOT_TOOLS_ENVIMAGE is not set
                                      BR2_PACKAGE_HOST_UBOOT_TOOLS_BOOT_SCRIPT=y
                                      BR2_PACKAGE_HOST_UBOOT_TOOLS_BOOT_SCRIPT_SOURCE="board/sifive/hifive-unleashed/boot.cmd"
                                      BR2_PACKAGE_HOST_UTIL_LINUX=y
                                      # BR2_PACKAGE_HOST_UTP_COM is not set
                                      # BR2_PACKAGE_HOST_VBOOT_UTILS is not set
                                      # BR2_PACKAGE_HOST_XORRISO is not set
                                      # BR2_PACKAGE_HOST_ZIP is not set
                                      # BR2_PACKAGE_HOST_ZSTD is not set
                                      # Legacy config options
                                      # Legacy options removed in 2021.02
                                      # BR2_PACKAGE_MPD_AUDIOFILE is not set
                                      # BR2_PACKAGE_AUDIOFILE is not set
                                      # BR2_BINUTILS_VERSION_2_33_X is not set
                                      # BR2_PACKAGE_LIBUPNP18 is not set
                                      # BR2_PACKAGE_BOA is not set
                                      # BR2_PACKAGE_LINUX_FIRMWARE_IMX_SDMA is not set
                                      # BR2_GDB_VERSION_8_2 is not set
                                      # BR2_PACKAGE_HOST_RCW is not set
                                      # BR2_KERNEL_HEADERS_5_9 is not set
                                      # BR2_KERNEL_HEADERS_5_8 is not set
                                      # BR2_powerpc_601 is not set
                                      # BR2_PACKAGE_TI_SGX_LIBGBM is not set
                                      # BR2_PACKAGE_IPSEC_TOOLS is not set
                                      # Legacy options removed in 2020.11
                                      # BR2_PACKAGE_OPENCV is not set
                                      # BR2_PACKAGE_LIBCROCO is not set
                                      # BR2_PACKAGE_BELLAGIO is not set
                                      # BR2_PACKAGE_SYSTEMD_JOURNAL_GATEWAY is not set
                                      # BR2_TARGET_UBOOT_BOOT_SCRIPT is not set
                                      # BR2_TARGET_UBOOT_ENVIMAGE is not set
                                      # BR2_PACKAGE_KISMET_CLIENT is not set
                                      # BR2_PACKAGE_KISMET_DRONE is not set
                                      # BR2_GCC_VERSION_7_X is not set
                                      # BR2_PACKAGE_GST1_VALIDATE is not set
                                      # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_YADIF is not set
                                      # BR2_PACKAGE_GQVIEW is not set
                                      # BR2_PACKAGE_WESTON_IMX is not set
                                      # BR2_KERNEL_HEADERS_5_7 is not set
                                      # BR2_PACKAGE_TINYHTTPD is not set
                                      # BR2_PACKAGE_XSERVER_XORG_SERVER_AIGLX is not set
                                      # BR2_PACKAGE_AMD_CATALYST is not set
                                      # BR2_PACKAGE_NVIDIA_TEGRA23 is not set
                                      # BR2_GDB_VERSION_8_1 is not set
                                      # Legacy options removed in 2020.08
                                      # BR2_TOOLCHAIN_EXTERNAL_CODESOURCERY_AMD64 is not set
                                      # BR2_KERNEL_HEADERS_5_6 is not set
                                      # BR2_KERNEL_HEADERS_5_5 is not set
                                      # BR2_BINUTILS_VERSION_2_31_X is not set
                                      # BR2_PACKAGE_KODI_PERIPHERAL_STEAMCONTROLLER is not set
                                      # Legacy options removed in 2020.05
                                      # BR2_PACKAGE_WIRINGPI is not set
                                      # BR2_PACKAGE_PYTHON_PYCRYPTO is not set
                                      # BR2_PACKAGE_MTDEV2TUIO is not set
                                      # BR2_PACKAGE_EZXML is not set
                                      # BR2_PACKAGE_COLLECTD_LVM is not set
                                      # BR2_PACKAGE_PYTHON_PYASN is not set
                                      # BR2_PACKAGE_PYTHON_PYASN_MODULES is not set
                                      # BR2_PACKAGE_LINUX_FIRMWARE_ATHEROS_10K_QCA6174 is not set
                                      # BR2_PACKAGE_QT5CANVAS3D is not set
                                      # BR2_PACKAGE_KODI_LIBTHEORA is not set
                                      # BR2_PACKAGE_CEGUI06 is not set
                                      # BR2_GCC_VERSION_5_X is not set
                                      # Legacy options removed in 2020.02
                                      # BR2_PACKAGE_JAMVM is not set
                                      # BR2_PACKAGE_CLASSPATH is not set
                                      # BR2_PACKAGE_QT5_VERSION_5_6 is not set
                                      # BR2_PACKAGE_CURL is not set
                                      # BR2_PACKAGE_GSTREAMER is not set
                                      # BR2_PACKAGE_NVIDIA_TEGRA23_BINARIES_GSTREAMER_PLUGINS is not set
                                      # BR2_PACKAGE_NVIDIA_TEGRA23_BINARIES_NV_SAMPLE_APPS is not set
                                      # BR2_PACKAGE_FREERDP_GSTREAMER is not set
                                      # BR2_PACKAGE_OPENCV3_WITH_GSTREAMER is not set
                                      # BR2_PACKAGE_OPENCV_WITH_GSTREAMER is not set
                                      # BR2_PACKAGE_LIBPLAYER is not set
                                      # BR2_GCC_VERSION_OR1K is not set
                                      # BR2_PACKAGE_BLUEZ_UTILS is not set
                                      # BR2_PACKAGE_GADGETFS_TEST is not set
                                      # BR2_PACKAGE_FIS is not set
                                      BR2_PACKAGE_REFPOLICY_POLICY_VERSION=""
                                      # BR2_PACKAGE_CELT051 is not set
                                      # BR2_PACKAGE_WIREGUARD is not set
                                      # BR2_PACKAGE_PERL_NET_PING is not set
                                      # BR2_PACKAGE_PERL_MIME_BASE64 is not set
                                      # BR2_PACKAGE_PERL_DIGEST_MD5 is not set
                                      # BR2_PACKAGE_ERLANG_P1_ICONV is not set
                                      # BR2_KERNEL_HEADERS_5_3 is not set
                                      # BR2_PACKAGE_PYTHON_SCAPY3K is not set
                                      # BR2_BINUTILS_VERSION_2_30_X is not set
                                      # BR2_PACKAGE_RPI_USERLAND_START_VCFILED is not set
                                      # Legacy options removed in 2019.11
                                      # BR2_PACKAGE_OPENVMTOOLS_PROCPS is not set
                                      # BR2_PACKAGE_ALLJOYN is not set
                                      # BR2_PACKAGE_ALLJOYN_BASE is not set
                                      # BR2_PACKAGE_ALLJOYN_BASE_CONTROLPANEL is not set
                                      # BR2_PACKAGE_ALLJOYN_BASE_NOTIFICATION is not set
                                      # BR2_PACKAGE_ALLJOYN_BASE_ONBOARDING is not set
                                      # BR2_PACKAGE_ALLJOYN_TCL_BASE is not set
                                      # BR2_PACKAGE_ALLJOYN_TCL is not set
                                      BR2_TOOLCHAIN_EXTRA_EXTERNAL_LIBS=""
                                      # BR2_PACKAGE_PYTHON_PYSNMP_APPS is not set
                                      # BR2_KERNEL_HEADERS_5_2 is not set
                                      # BR2_TARGET_RISCV_PK is not set
                                      # BR2_PACKAGE_SQLITE_STAT3 is not set
                                      # BR2_KERNEL_HEADERS_5_1 is not set
                                      # BR2_PACKAGE_DEVMEM2 is not set
                                      # BR2_PACKAGE_USTR is not set
                                      # BR2_PACKAGE_KODI_SCREENSAVER_PLANESTATE is not set
                                      # BR2_PACKAGE_KODI_VISUALISATION_WAVEFORHUE is not set
                                      # BR2_PACKAGE_KODI_AUDIODECODER_OPUS is not set
                                      # BR2_PACKAGE_MESA3D_OSMESA is not set
                                      # BR2_PACKAGE_HOSTAPD_DRIVER_RTW is not set
                                      # BR2_PACKAGE_WPA_SUPPLICANT_DBUS_NEW is not set
                                      # BR2_PACKAGE_WPA_SUPPLICANT_DBUS_OLD is not set
                                      # Legacy options removed in 2019.08
                                      # BR2_TARGET_TS4800_MBRBOOT is not set
                                      # BR2_PACKAGE_LIBAMCODEC is not set
                                      # BR2_PACKAGE_ODROID_SCRIPTS is not set
                                      # BR2_PACKAGE_ODROID_MALI is not set
                                      # BR2_PACKAGE_KODI_PLATFORM_AML is not set
                                      # BR2_GCC_VERSION_6_X is not set
                                      # BR2_GCC_VERSION_4_9_X is not set
                                      # BR2_GDB_VERSION_7_12 is not set
                                      # BR2_PACKAGE_XAPP_MKFONTDIR is not set
                                      # BR2_GDB_VERSION_8_0 is not set
                                      # BR2_KERNEL_HEADERS_4_20 is not set
                                      # BR2_KERNEL_HEADERS_5_0 is not set
                                      # Legacy options removed in 2019.05
                                      # BR2_CSKY_DSP is not set
                                      # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_COMPOSITOR is not set
                                      # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_IQA is not set
                                      # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_OPENCV is not set
                                      # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_STEREO is not set
                                      # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_VCD is not set
                                      # BR2_PACKAGE_LUNIT is not set
                                      # BR2_PACKAGE_FFMPEG_FFSERVER is not set
                                      # BR2_PACKAGE_LIBUMP is not set
                                      # BR2_PACKAGE_SUNXI_MALI is not set
                                      # BR2_BINUTILS_VERSION_2_29_X is not set
                                      # BR2_BINUTILS_VERSION_2_28_X is not set
                                      # BR2_PACKAGE_GST_PLUGINS_BAD_PLUGIN_APEXSINK is not set
                                      # Legacy options removed in 2019.02
                                      # BR2_PACKAGE_QT is not set
                                      # BR2_PACKAGE_QTUIO is not set
                                      # BR2_PACKAGE_PINENTRY_QT4 is not set
                                      # BR2_PACKAGE_POPPLER_QT is not set
                                      # BR2_PACKAGE_OPENCV3_WITH_QT is not set
                                      # BR2_PACKAGE_OPENCV_WITH_QT is not set
                                      # BR2_PACKAGE_AMD_CATALYST_CCCLE is not set
                                      # BR2_PACKAGE_SDL_QTOPIA is not set
                                      # BR2_PACKAGE_PYTHON_PYQT is not set
                                      # BR2_PACKAGE_LUACRYPTO is not set
                                      # BR2_PACKAGE_TN5250 is not set
                                      # BR2_PACKAGE_BOOST_SIGNALS is not set
                                      # BR2_PACKAGE_FFTW_PRECISION_SINGLE is not set
                                      # BR2_PACKAGE_FFTW_PRECISION_DOUBLE is not set
                                      # BR2_PACKAGE_FFTW_PRECISION_LONG_DOUBLE is not set
                                      # BR2_PACKAGE_LUA_5_2 is not set
                                      # BR2_TARGET_GENERIC_PASSWD_MD5 is not set
                                      # Legacy options removed in 2018.11
                                      # BR2_TARGET_XLOADER is not set
                                      # BR2_PACKAGE_TIDSP_BINARIES is not set
                                      # BR2_PACKAGE_DSP_TOOLS is not set
                                      # BR2_PACKAGE_GST_DSP is not set
                                      # BR2_PACKAGE_BOOTUTILS is not set
                                      # BR2_PACKAGE_EXPEDITE is not set
                                      # BR2_PACKAGE_MESA3D_OPENGL_TEXTURE_FLOAT is not set
                                      # BR2_KERNEL_HEADERS_4_10 is not set
                                      # BR2_KERNEL_HEADERS_4_11 is not set
                                      # BR2_KERNEL_HEADERS_4_12 is not set
                                      # BR2_KERNEL_HEADERS_4_13 is not set
                                      # BR2_KERNEL_HEADERS_4_15 is not set
                                      # BR2_KERNEL_HEADERS_4_17 is not set
                                      # BR2_PACKAGE_LIBNFTNL_XML is not set
                                      # BR2_KERNEL_HEADERS_3_2 is not set
                                      # BR2_KERNEL_HEADERS_4_1 is not set
                                      # BR2_KERNEL_HEADERS_4_16 is not set
                                      # BR2_KERNEL_HEADERS_4_18 is not set
                                      # Legacy options removed in 2018.08
                                      # BR2_PACKAGE_DOCKER_ENGINE_STATIC_CLIENT is not set
                                      # BR2_PACKAGE_XPROTO_APPLEWMPROTO is not set
                                      # BR2_PACKAGE_XPROTO_BIGREQSPROTO is not set
                                      # BR2_PACKAGE_XPROTO_COMPOSITEPROTO is not set
                                      # BR2_PACKAGE_XPROTO_DAMAGEPROTO is not set
                                      # BR2_PACKAGE_XPROTO_DMXPROTO is not set
                                      # BR2_PACKAGE_XPROTO_DRI2PROTO is not set
                                      # BR2_PACKAGE_XPROTO_DRI3PROTO is not set
                                      # BR2_PACKAGE_XPROTO_FIXESPROTO is not set
                                      # BR2_PACKAGE_XPROTO_FONTCACHEPROTO is not set
                                      # BR2_PACKAGE_XPROTO_FONTSPROTO is not set
                                      # BR2_PACKAGE_XPROTO_GLPROTO is not set
                                      # BR2_PACKAGE_XPROTO_INPUTPROTO is not set
                                      # BR2_PACKAGE_XPROTO_KBPROTO is not set
                                      # BR2_PACKAGE_XPROTO_PRESENTPROTO is not set
                                      # BR2_PACKAGE_XPROTO_RANDRPROTO is not set
                                      # BR2_PACKAGE_XPROTO_RECORDPROTO is not set
                                      # BR2_PACKAGE_XPROTO_RENDERPROTO is not set
                                      # BR2_PACKAGE_XPROTO_RESOURCEPROTO is not set
                                      # BR2_PACKAGE_XPROTO_SCRNSAVERPROTO is not set
                                      # BR2_PACKAGE_XPROTO_VIDEOPROTO is not set
                                      # BR2_PACKAGE_XPROTO_WINDOWSWMPROTO is not set
                                      # BR2_PACKAGE_XPROTO_XCMISCPROTO is not set
                                      # BR2_PACKAGE_XPROTO_XEXTPROTO is not set
                                      # BR2_PACKAGE_XPROTO_XF86BIGFONTPROTO is not set
                                      # BR2_PACKAGE_XPROTO_XF86DGAPROTO is not set
                                      # BR2_PACKAGE_XPROTO_XF86DRIPROTO is not set
                                      # BR2_PACKAGE_XPROTO_XF86VIDMODEPROTO is not set
                                      # BR2_PACKAGE_XPROTO_XINERAMAPROTO is not set
                                      # BR2_PACKAGE_XPROTO_XPROTO is not set
                                      # BR2_PACKAGE_XPROTO_XPROXYMANAGEMENTPROTOCOL is not set
                                      # BR2_PACKAGE_GST1_PLUGINS_BAD_LIB_OPENGL_OPENGL is not set
                                      # BR2_PACKAGE_GST1_PLUGINS_BAD_LIB_OPENGL_GLES2 is not set
                                      # BR2_PACKAGE_GST1_PLUGINS_BAD_LIB_OPENGL_GLX is not set
                                      # BR2_PACKAGE_GST1_PLUGINS_BAD_LIB_OPENGL_EGL is not set
                                      # BR2_PACKAGE_GST1_PLUGINS_BAD_LIB_OPENGL_X11 is not set
                                      # BR2_PACKAGE_GST1_PLUGINS_BAD_LIB_OPENGL_WAYLAND is not set
                                      # BR2_PACKAGE_GST1_PLUGINS_BAD_LIB_OPENGL_DISPMANX is not set
                                      # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_AUDIOMIXER is not set
                                      # BR2_PACKAGE_GST1_PLUGINS_UGLY_PLUGIN_LAME is not set
                                      # BR2_PACKAGE_GST1_PLUGINS_UGLY_PLUGIN_MPG123 is not set
                                      # BR2_GDB_VERSION_7_11 is not set
                                      # BR2_GDB_VERSION_7_10 is not set
                                      # Legacy options removed in 2018.05
                                      # BR2_PACKAGE_MEDIAART_BACKEND_NONE is not set
                                      # BR2_PACKAGE_MEDIAART_BACKEND_GDK_PIXBUF is not set
                                      # BR2_PACKAGE_TI_SGX_AM335X is not set
                                      # BR2_PACKAGE_TI_SGX_AM437X is not set
                                      # BR2_PACKAGE_TI_SGX_AM4430 is not set
                                      # BR2_PACKAGE_TI_SGX_AM5430 is not set
                                      # BR2_PACKAGE_JANUS_AUDIO_BRIDGE is not set
                                      # BR2_PACKAGE_JANUS_ECHO_TEST is not set
                                      # BR2_PACKAGE_JANUS_RECORDPLAY is not set
                                      # BR2_PACKAGE_JANUS_SIP_GATEWAY is not set
                                      # BR2_PACKAGE_JANUS_STREAMING is not set
                                      # BR2_PACKAGE_JANUS_TEXT_ROOM is not set
                                      # BR2_PACKAGE_JANUS_VIDEO_CALL is not set
                                      # BR2_PACKAGE_JANUS_VIDEO_ROOM is not set
                                      # BR2_PACKAGE_JANUS_MQTT is not set
                                      # BR2_PACKAGE_JANUS_RABBITMQ is not set
                                      # BR2_PACKAGE_JANUS_REST is not set
                                      # BR2_PACKAGE_JANUS_UNIX_SOCKETS is not set
                                      # BR2_PACKAGE_JANUS_WEBSOCKETS is not set
                                      # BR2_PACKAGE_IPSEC_SECCTX_DISABLE is not set
                                      # BR2_PACKAGE_IPSEC_SECCTX_ENABLE is not set
                                      # BR2_PACKAGE_IPSEC_SECCTX_KERNEL is not set
                                      # BR2_PACKAGE_LIBTFDI_CPP is not set
                                      # BR2_PACKAGE_JQUERY_UI_THEME_BLACK_TIE is not set
                                      # BR2_PACKAGE_JQUERY_UI_THEME_BLITZER is not set
                                      # BR2_PACKAGE_JQUERY_UI_THEME_CUPERTINO is not set
                                      # BR2_PACKAGE_JQUERY_UI_THEME_DARK_HIVE is not set
                                      # BR2_PACKAGE_JQUERY_UI_THEME_DOT_LUV is not set
                                      # BR2_PACKAGE_JQUERY_UI_THEME_EGGPLANT is not set
                                      # BR2_PACKAGE_JQUERY_UI_THEME_EXCITE_BIKE is not set
                                      # BR2_PACKAGE_JQUERY_UI_THEME_FLICK is not set
                                      # BR2_PACKAGE_JQUERY_UI_THEME_HOT_SNEAKS is not set
                                      # BR2_PACKAGE_JQUERY_UI_THEME_HUMANITY is not set
                                      # BR2_PACKAGE_JQUERY_UI_THEME_LE_FROG is not set
                                      # BR2_PACKAGE_JQUERY_UI_THEME_MINT_CHOC is not set
                                      # BR2_PACKAGE_JQUERY_UI_THEME_OVERCAST is not set
                                      # BR2_PACKAGE_JQUERY_UI_THEME_PEPPER_GRINDER is not set
                                      # BR2_PACKAGE_JQUERY_UI_THEME_REDMOND is not set
                                      # BR2_PACKAGE_JQUERY_UI_THEME_SMOOTHNESS is not set
                                      # BR2_PACKAGE_JQUERY_UI_THEME_SOUTH_STREET is not set
                                      # BR2_PACKAGE_JQUERY_UI_THEME_START is not set
                                      # BR2_PACKAGE_JQUERY_UI_THEME_SUNNY is not set
                                      # BR2_PACKAGE_JQUERY_UI_THEME_SWANKY_PURSE is not set
                                      # BR2_PACKAGE_JQUERY_UI_THEME_TRONTASTIC is not set
                                      # BR2_PACKAGE_JQUERY_UI_THEME_UI_DARKNESS is not set
                                      # BR2_PACKAGE_JQUERY_UI_THEME_UI_LIGHTNESS is not set
                                      # BR2_PACKAGE_JQUERY_UI_THEME_VADER is not set
                                      # BR2_PACKAGE_BLUEZ5_PLUGINS_HEALTH is not set
                                      # BR2_PACKAGE_BLUEZ5_PLUGINS_MIDI is not set
                                      # BR2_PACKAGE_BLUEZ5_PLUGINS_NFC is not set
                                      # BR2_PACKAGE_BLUEZ5_PLUGINS_SAP is not set
                                      # BR2_PACKAGE_BLUEZ5_PLUGINS_SIXAXIS is not set
                                      # BR2_PACKAGE_TRANSMISSION_REMOTE is not set
                                      # BR2_PACKAGE_LIBKCAPI_APPS is not set
                                      # BR2_PACKAGE_MPLAYER is not set
                                      # BR2_PACKAGE_MPLAYER_MPLAYER is not set
                                      # BR2_PACKAGE_MPLAYER_MENCODER is not set
                                      # BR2_PACKAGE_LIBPLAYER_MPLAYER is not set
                                      # BR2_PACKAGE_IQVLINUX is not set
                                      # BR2_BINFMT_FLAT_SEP_DATA is not set
                                      # BR2_bfin is not set
                                      # BR2_PACKAGE_KODI_ADSP_BASIC is not set
                                      # BR2_PACKAGE_KODI_ADSP_FREESURROUND is not set
                                      # Legacy options removed in 2018.02
                                      # BR2_KERNEL_HEADERS_3_4 is not set
                                      # BR2_KERNEL_HEADERS_3_10 is not set
                                      # BR2_KERNEL_HEADERS_3_12 is not set
                                      # BR2_BINUTILS_VERSION_2_27_X is not set
                                      # BR2_PACKAGE_EEPROG is not set
                                      # BR2_PACKAGE_GNUPG2_GPGV2 is not set
                                      # BR2_PACKAGE_IMX_GPU_VIV_APITRACE is not set
                                      # BR2_PACKAGE_IMX_GPU_VIV_G2D is not set
                                      # Legacy options removed in 2017.11
                                      # BR2_PACKAGE_RFKILL is not set
                                      # BR2_PACKAGE_UTIL_LINUX_RESET is not set
                                      # BR2_PACKAGE_POLICYCOREUTILS_AUDIT2ALLOW is not set
                                      # BR2_PACKAGE_POLICYCOREUTILS_RESTORECOND is not set
                                      # BR2_PACKAGE_SEPOLGEN is not set
                                      # BR2_PACKAGE_OPENOBEX_BLUEZ is not set
                                      # BR2_PACKAGE_OPENOBEX_LIBUSB is not set
                                      # BR2_PACKAGE_OPENOBEX_APPS is not set
                                      # BR2_PACKAGE_OPENOBEX_SYSLOG is not set
                                      # BR2_PACKAGE_OPENOBEX_DUMP is not set
                                      # BR2_PACKAGE_AICCU is not set
                                      # BR2_PACKAGE_UTIL_LINUX_LOGIN_UTILS is not set
                                      # Legacy options removed in 2017.08
                                      # BR2_TARGET_GRUB is not set
                                      # BR2_PACKAGE_SIMICSFS is not set
                                      # BR2_BINUTILS_VERSION_2_26_X is not set
                                      BR2_XTENSA_OVERLAY_DIR=""
                                      BR2_XTENSA_CUSTOM_NAME=""
                                      # BR2_PACKAGE_HOST_MKE2IMG is not set
                                      BR2_TARGET_ROOTFS_EXT2_BLOCKS=0
                                      BR2_TARGET_ROOTFS_EXT2_EXTRA_INODES=0
                                      # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_CDXAPARSE is not set
                                      # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_DATAURISRC is not set
                                      # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_DCCP is not set
                                      # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_HDVPARSE is not set
                                      # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_MVE is not set
                                      # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_NUVDEMUX is not set
                                      # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_PATCHDETECT is not set
                                      # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_SDI is not set
                                      # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_TTA is not set
                                      # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_VIDEOMEASURE is not set
                                      # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_APEXSINK is not set
                                      # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_SDL is not set
                                      # BR2_PACKAGE_GST1_PLUGINS_UGLY_PLUGIN_MAD is not set
                                      # BR2_STRIP_none is not set
                                      # BR2_PACKAGE_BEECRYPT_CPP is not set
                                      # BR2_PACKAGE_SPICE_CLIENT is not set
                                      # BR2_PACKAGE_SPICE_GUI is not set
                                      # BR2_PACKAGE_SPICE_TUNNEL is not set
                                      # BR2_PACKAGE_INPUT_TOOLS is not set
                                      # BR2_PACKAGE_INPUT_TOOLS_INPUTATTACH is not set
                                      # BR2_PACKAGE_INPUT_TOOLS_JSCAL is not set
                                      # BR2_PACKAGE_INPUT_TOOLS_JSTEST is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_CODESOURCERY_SH is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_CODESOURCERY_X86 is not set
                                      # BR2_GCC_VERSION_4_8_X is not set
                                      # Legacy options removed in 2017.05
                                      # BR2_PACKAGE_SUNXI_MALI_R2P4 is not set
                                      # BR2_PACKAGE_NODEJS_MODULES_COFFEESCRIPT is not set
                                      # BR2_PACKAGE_NODEJS_MODULES_EXPRESS is not set
                                      # BR2_PACKAGE_BLUEZ5_UTILS_GATTTOOL is not set
                                      # BR2_PACKAGE_OPENOCD_FT2XXX is not set
                                      # BR2_PACKAGE_KODI_RTMPDUMP is not set
                                      # BR2_PACKAGE_KODI_VISUALISATION_FOUNTAIN is not set
                                      # BR2_PACKAGE_PORTMAP is not set
                                      # BR2_BINUTILS_VERSION_2_25_X is not set
                                      # BR2_TOOLCHAIN_BUILDROOT_INET_RPC is not set
                                      BR2_TARGET_ROOTFS_EXT2_EXTRA_BLOCKS=0
                                      # BR2_PACKAGE_SYSTEMD_KDBUS is not set
                                      # BR2_PACKAGE_POLARSSL is not set
                                      # BR2_NBD_CLIENT is not set
                                      # BR2_NBD_SERVER is not set
                                      # BR2_PACKAGE_GMOCK is not set
                                      # BR2_KERNEL_HEADERS_4_8 is not set
                                      # BR2_KERNEL_HEADERS_3_18 is not set
                                      # BR2_GLIBC_VERSION_2_22 is not set
                                      # Legacy options removed in 2017.02
                                      # BR2_PACKAGE_PERL_DB_FILE is not set
                                      # BR2_KERNEL_HEADERS_4_7 is not set
                                      # BR2_KERNEL_HEADERS_4_6 is not set
                                      # BR2_KERNEL_HEADERS_4_5 is not set
                                      # BR2_KERNEL_HEADERS_3_14 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_MUSL_CROSS is not set
                                      # BR2_UCLIBC_INSTALL_TEST_SUITE is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_BLACKFIN_UCLINUX is not set
                                      # BR2_PACKAGE_MAKEDEVS is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_ARAGO_ARMV7A is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_ARAGO_ARMV5TE is not set
                                      # BR2_PACKAGE_SNOWBALL_HDMISERVICE is not set
                                      # BR2_PACKAGE_SNOWBALL_INIT is not set
                                      # BR2_GDB_VERSION_7_9 is not set
                                      # Legacy options removed in 2016.11
                                      # BR2_PACKAGE_PHP_SAPI_CLI_CGI is not set
                                      # BR2_PACKAGE_PHP_SAPI_CLI_FPM is not set
                                      # BR2_PACKAGE_WVSTREAMS is not set
                                      # BR2_PACKAGE_WVDIAL is not set
                                      # BR2_PACKAGE_WEBKITGTK24 is not set
                                      # BR2_PACKAGE_TORSMO is not set
                                      # BR2_PACKAGE_SSTRIP is not set
                                      # BR2_KERNEL_HEADERS_4_3 is not set
                                      # BR2_KERNEL_HEADERS_4_2 is not set
                                      # BR2_PACKAGE_KODI_ADDON_XVDR is not set
                                      # BR2_PACKAGE_IPKG is not set
                                      # BR2_GCC_VERSION_4_7_X is not set
                                      # BR2_BINUTILS_VERSION_2_24_X is not set
                                      # BR2_PACKAGE_WESTON_RPI is not set
                                      # BR2_LINUX_KERNEL_TOOL_CPUPOWER is not set
                                      # BR2_LINUX_KERNEL_TOOL_PERF is not set
                                      # BR2_LINUX_KERNEL_TOOL_SELFTESTS is not set
                                      # BR2_GCC_VERSION_4_8_ARC is not set
                                      # BR2_KERNEL_HEADERS_4_0 is not set
                                      # BR2_KERNEL_HEADERS_3_19 is not set
                                      # BR2_PACKAGE_LIBEVAS_GENERIC_LOADERS is not set
                                      # BR2_PACKAGE_ELEMENTARY is not set
                                      # BR2_LINUX_KERNEL_CUSTOM_LOCAL is not set
                                      # Legacy options removed in 2016.08
                                      # BR2_PACKAGE_EFL_JP2K is not set
                                      # BR2_PACKAGE_SYSTEMD_COMPAT is not set
                                      # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_LIVEADDER is not set
                                      # BR2_PACKAGE_LIBFSLVPUWRAP is not set
                                      # BR2_PACKAGE_LIBFSLPARSER is not set
                                      # BR2_PACKAGE_LIBFSLCODEC is not set
                                      # BR2_PACKAGE_UBOOT_TOOLS_MKIMAGE_FIT_SIGNATURE_SUPPORT is not set
                                      # BR2_PTHREADS_OLD is not set
                                      # BR2_BINUTILS_VERSION_2_23_X is not set
                                      # BR2_TOOLCHAIN_BUILDROOT_EGLIBC is not set
                                      # BR2_GDB_VERSION_7_8 is not set
                                      # Legacy options removed in 2016.05
                                      # BR2_PACKAGE_OPENVPN_CRYPTO_POLARSSL is not set
                                      # BR2_PACKAGE_NGINX_HTTP_SPDY_MODULE is not set
                                      # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_RTP is not set
                                      # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_MPG123 is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_CODESOURCERY_POWERPC is not set
                                      # BR2_TOOLCHAIN_EXTERNAL_CODESOURCERY_POWERPC_E500V2 is not set
                                      # BR2_x86_i386 is not set
                                      # BR2_PACKAGE_QT5QUICK1 is not set
                                      BR2_TARGET_UBOOT_CUSTOM_PATCH_DIR=""
                                      # BR2_PACKAGE_XDRIVER_XF86_INPUT_VOID is not set
                                      # BR2_KERNEL_HEADERS_3_17 is not set
                                      # BR2_GDB_VERSION_7_7 is not set
                                      # BR2_PACKAGE_FOOMATIC_FILTERS is not set
                                      # BR2_PACKAGE_SAMBA is not set
                                      # BR2_PACKAGE_KODI_WAVPACK is not set
                                      # BR2_PACKAGE_KODI_RSXS is not set
                                      # BR2_PACKAGE_KODI_GOOM is not set
                                      # BR2_PACKAGE_SYSTEMD_ALL_EXTRAS is not set
                                      # BR2_GCC_VERSION_4_5_X is not set
                                      # BR2_PACKAGE_SQLITE_READLINE is not set
                                      # Legacy options removed in 2016.02
                                      # BR2_PACKAGE_DOVECOT_BZIP2 is not set
                                      # BR2_PACKAGE_DOVECOT_ZLIB is not set
                                      # BR2_PACKAGE_E2FSPROGS_FINDFS is not set
                                      # BR2_PACKAGE_OPENPOWERLINK_DEBUG_LEVEL is not set
                                      # BR2_PACKAGE_OPENPOWERLINK_KERNEL_MODULE is not set
                                      # BR2_PACKAGE_OPENPOWERLINK_LIBPCAP is not set
                                      # BR2_LINUX_KERNEL_SAME_AS_HEADERS is not set
                                      # BR2_PACKAGE_CUPS_PDFTOPS is not set
                                      # BR2_KERNEL_HEADERS_3_16 is not set
                                      # BR2_PACKAGE_PYTHON_PYXML is not set
                                      # BR2_ENABLE_SSP is not set
                                      # BR2_PACKAGE_DIRECTFB_CLE266 is not set
                                      # BR2_PACKAGE_DIRECTFB_UNICHROME is not set
                                      # BR2_PACKAGE_LIBELEMENTARY is not set
                                      # BR2_PACKAGE_LIBEINA is not set
                                      # BR2_PACKAGE_LIBEET is not set
                                      # BR2_PACKAGE_LIBEVAS is not set
                                      # BR2_PACKAGE_LIBECORE is not set
                                      # BR2_PACKAGE_LIBEDBUS is not set
                                      # BR2_PACKAGE_LIBEFREET is not set
                                      # BR2_PACKAGE_LIBEIO is not set
                                      # BR2_PACKAGE_LIBEMBRYO is not set
                                      # BR2_PACKAGE_LIBEDJE is not set
                                      # BR2_PACKAGE_LIBETHUMB is not set
                                      # BR2_PACKAGE_INFOZIP is not set
                                      # BR2_BR2_PACKAGE_NODEJS_0_10_X is not set
                                      # BR2_BR2_PACKAGE_NODEJS_0_12_X is not set
                                      # BR2_BR2_PACKAGE_NODEJS_4_X is not set
                                      # Legacy options removed in 2015.11
                                      # BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_REAL is not set
                                      # BR2_PACKAGE_MEDIA_CTL is not set
                                      # BR2_PACKAGE_SCHIFRA is not set
                                      # BR2_PACKAGE_ZXING is not set
                                      # BR2_PACKAGE_BLACKBOX is not set
                                      # BR2_KERNEL_HEADERS_3_0 is not set
                                      # BR2_KERNEL_HEADERS_3_11 is not set
                                      # BR2_KERNEL_HEADERS_3_13 is not set
                                      # BR2_KERNEL_HEADERS_3_15 is not set
                                      # BR2_PACKAGE_DIRECTFB_EXAMPLES_ANDI is not set
                                      # BR2_PACKAGE_DIRECTFB_EXAMPLES_BLTLOAD is not set
                                      # BR2_PACKAGE_DIRECTFB_EXAMPLES_CPULOAD is not set
                                      # BR2_PACKAGE_DIRECTFB_EXAMPLES_DATABUFFER is not set
                                      # BR2_PACKAGE_DIRECTFB_EXAMPLES_DIOLOAD is not set
                                      # BR2_PACKAGE_DIRECTFB_EXAMPLES_DOK is not set
                                      # BR2_PACKAGE_DIRECTFB_EXAMPLES_DRIVERTEST is not set
                                      # BR2_PACKAGE_DIRECTFB_EXAMPLES_FIRE is not set
                                      # BR2_PACKAGE_DIRECTFB_EXAMPLES_FLIP is not set
                                      # BR2_PACKAGE_DIRECTFB_EXAMPLES_FONTS is not set
                                      # BR2_PACKAGE_DIRECTFB_EXAMPLES_INPUT is not set
                                      # BR2_PACKAGE_DIRECTFB_EXAMPLES_JOYSTICK is not set
                                      # BR2_PACKAGE_DIRECTFB_EXAMPLES_KNUCKLES is not set
                                      # BR2_PACKAGE_DIRECTFB_EXAMPLES_LAYER is not set
                                      # BR2_PACKAGE_DIRECTFB_EXAMPLES_MATRIX is not set
                                      # BR2_PACKAGE_DIRECTFB_EXAMPLES_MATRIX_WATER is not set
                                      # BR2_PACKAGE_DIRECTFB_EXAMPLES_NEO is not set
                                      # BR2_PACKAGE_DIRECTFB_EXAMPLES_NETLOAD is not set
                                      # BR2_PACKAGE_DIRECTFB_EXAMPLES_PALETTE is not set
                                      # BR2_PACKAGE_DIRECTFB_EXAMPLES_PARTICLE is not set
                                      # BR2_PACKAGE_DIRECTFB_EXAMPLES_PORTER is not set
                                      # BR2_PACKAGE_DIRECTFB_EXAMPLES_STRESS is not set
                                      # BR2_PACKAGE_DIRECTFB_EXAMPLES_TEXTURE is not set
                                      # BR2_PACKAGE_DIRECTFB_EXAMPLES_VIDEO is not set
                                      # BR2_PACKAGE_DIRECTFB_EXAMPLES_VIDEO_PARTICLE is not set
                                      # BR2_PACKAGE_DIRECTFB_EXAMPLES_WINDOW is not set
                                      # BR2_PACKAGE_KOBS_NG is not set
                                      # BR2_PACKAGE_SAWMAN is not set
                                      # BR2_PACKAGE_DIVINE is not set
                                      # Legacy options removed in 2015.08
                                      # BR2_PACKAGE_KODI_PVR_ADDONS is not set
                                      # BR2_BINUTILS_VERSION_2_23_2 is not set
                                      # BR2_BINUTILS_VERSION_2_24 is not set
                                      # BR2_BINUTILS_VERSION_2_25 is not set
                                      # BR2_PACKAGE_PERF is not set
                                      # BR2_BINUTILS_VERSION_2_22 is not set
                                      # BR2_PACKAGE_GPU_VIV_BIN_MX6Q is not set
                                      # BR2_TARGET_UBOOT_NETWORK is not set
                                      再从 tina sdk 替换三个文件就可以了:
                                      cp /opt/D1/tina_d1_open/lichee/brandy-2.0/u-boot-2018/u-boot-sun20iw1p1.bin output/images/u-boot-sun20iw1p1.bin
                                      cp /opt/D1/tina_d1_open/lichee/linux-5.4/arch/riscv/boot/dts/sunxi/board.dtb output/images/board.dtb
                                      cp /opt/D1/tina_d1_open/lichee/linux-5.4/arch/riscv/boot/Image output/images/Image
                                      • tigger
                                        tigger LV 7 最后由 编辑
                                        https://forum.qt.io/topic/52556/performance-issues-with-simple-test-on-qt5-vs-qt4-on-arm-device-without-gpu
                                        找了几行 Qt widgets 刷新率测试的代码试一试。
                                        • tigger
                                          tigger LV 7 最后由 编辑
                                          # /tmp/sda/qt_fps_test -platform linuxfb
                                          time: 135.000000 fps: 7.407407
                                          time: 147.000000 fps: 6.802721
                                          time: 175.000000 fps: 5.714286
                                          time: 176.000000 fps: 5.681818
                                          time: 179.000000 fps: 5.586592
                                          啊这,全屏画线这刷新率有点低。
                                          • tigger
                                            tigger LV 7 最后由 编辑
                                            qt_fps.zip
                                            用 Qt widgets 的 FillRect() 矩形填充,屏幕会上下撕裂,不知道啥原因。
                                            BedRock 1 条回复 最后回复 回复 引用 分享 0
                                            • R
                                              rstg00po54 LV 3 最后由 编辑
                                              [图片]
                                              为啥我的弄完是这个样子
                                              • R
                                                我的麻雀板子用这个屏幕是花屏啊大佬
                                                • BedRock
                                                  BedRock LV 6 @tigger 最后由 编辑
                                                  @tigger 想起来是不是需要double buffer😀
                                                    a1147991965 LV 4 最后由 编辑
                                                    大佬你UBOOT卡死的时候是怎么解决的,是改了UBOOT设备树里面的时序参数吗?
                                                    • mangogeek
                                                      mangogeek LV 8 @a1147991965 最后由 编辑
                                                      @a1147991965 当时记得有一个限制,就是spw不得小于等于3,否则卡住。你具体检查下hspw,vspw
                                                        a1147991965 LV 4 @mangogeek 最后由 编辑
                                                        @mangogeek 这个限制是驱动代码限制的嘛?
                                                        mangogeek 1 条回复 最后回复 回复 引用 分享 1
                                                        • mangogeek
                                                          @a1147991965 还没细查
                                                            Abinly LV 1 最后由 编辑
                                                            转接板,有没有多余的可以挂淘宝上卖呢。单独去打样有点贵。
                                                              woallf LV 2 @mangogeek 最后由 编辑
                                                              @mangogeek 请教大佬,这块5.0的屏幕,我买了同款。现在想移植到一块新板子上,请问可否指导一下,i2c命令的详细数据,或者可否告知内核驱动的文件?
                                                              whycan 1 条回复 最后回复 回复 引用 分享 1
        whycan晕哥 LV 9 @woallf 最后由 whycan 编辑
        @woallf
        这里有逻辑分析仪抓到的数据: https://bbs.aw-ol.com/topic/263/share/15
        这里有i2c数据生成软件: https://bbs.aw-ol.com/topic/263/share/35
        W W 2 条回复 最后回复 回复 引用 分享 1
        woallf LV 2 @whycan 最后由 编辑
        @whycan 感谢,我参照这俩进行了处理,test模式也起不来,所以就想跟您确认一下。如果你们在i2c参数上没有做特殊处理,那可能是我i2c的实现逻辑(FPGA)有问题,感谢!
        • T
        ttg2577 LV 5 @tigger 最后由 编辑
        • T
        ttg2577 LV 5 @mangogeek 最后由 编辑
        @mangogeek 大佬,你就只改了设备树吗,为什么我改完屏幕背光都不亮?
        aozima 1 条回复 最后回复 回复 引用 分享 1
        • aozima
        aozima LV 7 @ttg2577 最后由 编辑
        @ttg2577 这个屏的背光是上电自动亮的啊。
        是不是线接反了?还是屏背光坏了?
        T 1 条回复 最后回复 回复 引用 分享 0
        • T
        ttg2577 LV 5 @aozima 最后由 编辑
        @aozima 不知道啊,就只是上电的一瞬间亮一下,然后就黑屏了,按背光按键也没用。
        Y 1 条回复 最后回复 回复 引用 分享 0
        wjp2547532 LV 6 @whycan 最后由 编辑
        @whycan 晕哥,这个屏我买了一个5.0寸的,麻雀开发板只改设备树里的屏参和mipi配置就可以么
        whycan晕哥 LV 9 @wjp2547532 最后由 编辑
        @wjp2547532
        屏幕是哪里的呢?
        W 2 条回复 最后回复 回复 引用 分享 0
        @whycan https://item.taobao.com/item.htm?id=623507778498
        @wjp2547532
        对,在 nezha 板级文件上面改 dts 即可。
        W 1 条回复 最后回复 回复 引用 分享 0
        @whycan 好的晕哥,多谢多谢
        yexinglizi LV 2 @ttg2577 最后由 编辑
        @ttg2577 在 使用D1-H驱动树莓派DSI屏幕 中说:
        你后来屏幕正常吗,我买了一块也是上点瞬间亮一下就黑屏
        didiao LV 4 最后由 编辑
        只需要修改设备树就行吗,驱动都不用更改?
        &lcd0 {
        lcd_used            = <1>;
        lcd_driver_name     = "tft08006";
        lcd_backlight       = <100>;
        lcd_if              = <4>;
        lcd_x               = <800>;
        //lcd_y               = <1280>;
        lcd_y               = <480>;
        lcd_width           = <52>;
        lcd_height          = <52>;
        //lcd_dclk_freq       = <70>;
        lcd_dclk_freq       = <26>;
        lcd_pwm_used        = <1>;
        lcd_pwm_ch          = <2>;
        lcd_pwm_freq        = <1000>;
        lcd_pwm_pol         = <0>;
        lcd_pwm_max_limit   = <255>;
        // lcd_hbp             = <32>;
        // lcd_ht              = <868>;
        // lcd_hspw            = <4>;
        // lcd_vbp             = <12>;
        // //lcd_vt              = <1311>;
        // lcd_vt              = <500>;
        // lcd_vspw            = <4>;
        lcd_ht              = <857>;
        lcd_hbp             = <40>;
        lcd_hspw            = <4>;
        lcd_vt              = <528>;
        lcd_vbp             = <31>;
        //lcd_vt              = <1311>;
        lcd_vspw            = <4>;
        lcd_dsi_if          = <0>;
        //lcd_dsi_lane        = <4>;
        lcd_dsi_lane        = <1>;
        lcd_lvds_if         = <0>;
        lcd_lvds_colordepth = <0>;
        lcd_lvds_mode       = <0>;
        lcd_frm             = <0>;
        lcd_hv_clk_phase    = <0>;
        lcd_hv_sync_polarity= <0>;
        lcd_gamma_en        = <0>;
        lcd_bright_curve_en = <0>;
        lcd_cmap_en         = <0>;
        lcd_fsync_en        = <0>;
        lcd_fsync_act_time  = <1000>;
        lcd_fsync_dis_time  = <1000>;
        lcd_fsync_pol       = <0>;
        deu_mode            = <0>;
        lcdgamma4iep        = <22>;
        smart_color         = <90>;
        修改完成后,屏幕还是不亮
        zxdplay LV 4 @tigger 最后由 编辑
        @tigger 33fps 有没有用到G2D加速
        joe115200 LV 2 最后由 编辑
        对接的FB接口吗
