    请问 A133 + RTL8723DS 为何进入了测试模式?根本不能正常工作。
    rtl8723ds a133
      memory LV 7 最后由 编辑
      root@dragonboard:~# insmod /lib/modules/4.9.170/8723ds.ko && mkdir /etc/wifi/wpa
      _supplicant/sockets -p && touch /etc/wifi/wpa_supplicant/wpa_supplicant.conf &&
      wpa_supplicant -iwlan0 -D nl80211 -c/etc/wifi/wpa_supplicant/wpa_supplicant.conf
       -d   -B
      [   60.874406] RTW: module init start
      [   60.878260] RTW: rtl8723ds v5.6.8_34158.20190625_COEX20190530-3030
      [   60.885207] RTW: build time: Mar 21 2023 20:38:21
      [   60.890499] RTW: rtl8723ds BT-Coex version = COEX20190530-3030
      [   60.890703] RTW: rtw_inetaddr_notifier_register
      [   60.902284] RTW: == SDIO Card Info ==
      [   60.906434] RTW:   clock: 50000000 Hz
      [   60.910551] RTW:   timing spec: sd high-speed
      [   60.915461] RTW:   sd3_bus_mode: FALSE
      [   60.919673] RTW: ================
      [   60.923399] RTW: CHIP TYPE: RTL8723D
      [   60.927771] RTW: rtw_hal_config_rftype RF_Type is 0 TotalTxPath is 1
      [   60.934957] RTW: Chip Version Info: CHIP_8723D_Normal_Chip_TSMC_D_CUT_1T1R_RomVer(0)
      [   60.945965] RTW: SetHwReg: bMacPwrCtrlOn=1
      [   60.950934] RTW: sdio_power_on_check: val_mix:0x0002063f, res:0x0002063f
      [   60.958468] RTW: sdio_power_on_check: 0x100 the result of cmd52 and cmd53 is the same.
      [   60.967452] RTW: sdio_power_on_check: 0x1B8 test Pass.
      [   60.973292] RTW: _InitPowerOn_8723DS: Test Mode
      [   60.978414] RTW: _InitPowerOn_8723DS: LDO Mode
      [   60.983435] RTW: ReadAdapterInfo8723DS, 0x4e=0x82
      [   60.988785] RTW: EEPROM type is E-FUSE
      [   60.993265] RTW: hal_EfuseSwitchToBank: Efuse switch bank to 0
      [   61.019611] RTW: hal_ReadEFuse_WiFi: data end at address=0x9b
      [   61.026110] RTW: HW EFUSE
      [   61.029079] RTW: 0x000: 29 81 00 7C  E1 88 07 00  A0 04 EC 35  12 C0 A3 D8
      [   61.037164] RTW: 0x010: 28 28 28 28  28 28 28 28  28 28 28 02  FF FF FF FF
      [   61.045260] RTW: 0x020: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      [   61.053345] RTW: 0x030: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      [   61.061419] RTW: 0x040: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      [   61.069499] RTW: 0x050: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      [   61.077570] RTW: 0x060: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      [   61.085683] RTW: 0x070: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      [   61.093758] RTW: 0x080: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      [   61.101834] RTW: 0x090: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      [   61.109897] RTW: 0x0A0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      [   61.117959] RTW: 0x0B0: FF FF FF FF  FF FF FF FF  20 32 24 00  00 00 FF FF
      [   61.126067] RTW: 0x0C0: FF 29 20 11  00 00 00 FF  00 FF 11 FF  FF FF FF FF
      [   61.134139] RTW: 0x0D0: 3E 10 01 12  23 FF FF FF  20 04 4C 02  23 D7 21 02
      [   61.142215] RTW: 0x0E0: 0C 00 22 04  00 08 00 32  FF 21 02 0C  00 22 2A 01
      [   61.150277] RTW: 0x0F0: 01 00 00 00  00 00 00 00  00 00 00 00  02 00 FF FF
      [   61.158344] RTW: 0x100: 00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
      [   61.166452] RTW: 0x110: 00 EB 00 6E  01 00 00 00  00 FF 94 A4  08 D8 22 0A
      [   61.174533] RTW: 0x120: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      [   61.182604] RTW: 0x130: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      [   61.190683] RTW: 0x140: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      [   61.198754] RTW: 0x150: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      [   61.206867] RTW: 0x160: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      [   61.214931] RTW: 0x170: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      [   61.223013] RTW: 0x180: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      [   61.231085] RTW: 0x190: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      [   61.239158] RTW: 0x1A0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      [   61.247259] RTW: 0x1B0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      [   61.255341] RTW: 0x1C0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      [   61.263417] RTW: 0x1D0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      [   61.271493] RTW: 0x1E0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
      [   61.279563] RTW: 0x1F0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
        https://mangopi.org/_media/fn-link_fg6223asrd_datasheet_v2.1_20210728.pdf
        注意模块第七脚的电平。
        M 1 条回复 最后回复 回复 引用 分享 0
          memory LV 7 @whycan 最后由 编辑
          @whycan
          还真是的,RTL8723DS模组6、7引脚还真都接上拉了,把电阻干掉就正常了。
