    f1c100s tina 烧录到sdnand/tf卡 出错, 请问是什么原因?
    3522
      memory LV 7 最后由 编辑
      [0]beign to init dram
      [23]init dram ok
      U-Boot 2014.07 (Feb 21 2023 - 22:13:47) Allwinner Technology
      uboot commit : f1592db8c49aaedd6895f7e0f90caa123f0a3d5a
      i2c_init: by cpux
      [I2C-DEBUG]:i2c_set_clock() 354
      [I2C-ERROR]:twi_send_clk_9pulse() 136 SDA is still Stuck Low, failed.
      i2c_init ok
      [2.859]pmbus:   ready
      axp: get node[/soc/pmu0] error
      axp_probe error
      [2.865]PMU: cpux 720 Mhz,AXI=720 Mhz
      PLL6=600 Mhz,AHB1=200 Mhz, APB1=100Mhz
      DRAM:  32 MiB
      [2.875]fdt addr: 0x809e6ee0
      [2.877]gd->fdt_size: 0xc7c0
      Relocation Offset is: 01520000
      int sunxi_dma_init---
      irq enable
      [2.945]flash init start
      workmode = 16,storage type = 3
      try card 1
      [2.951][mmc]: mmc driver ver 2018-12-27 9:21:00
      SUNXI SD/MMC: 1
      [2.966][mmc]: ************Try SD card 1************
      [mmc]: mmc 1 cmd 8 timeout, err 100
      [mmc]: smc 1 err, cmd 8,  RTO
      [mmc]: mmc 1 close bus gating and reset
      [mmc]: mmc 1 mmc cmd 8 err 0x00000100
      [2.984][mmc]: mmc send if cond failed
      [mmc]: mmc 1 cmd 55 timeout, err 100
      [mmc]: smc 1 err, cmd 55,  RTO
      [mmc]: mmc 1 mmc cmd 55 err 0x00000100
      [3.002][mmc]: send app cmd failed
      [3.005][mmc]: ************Try MMC card 1************
      [mmc]: mmc 1 cmd 1 timeout, err 100
      [mmc]: smc 1 err, cmd 1,  RTO
      [mmc]: mmc 1 mmc cmd 1 err 0x00000100
      [3.026][mmc]: read op condition failed
      [3.030][mmc]: mmc send op cond failed
      Card did not respond to voltage select!
      [3.037][mmc]: ************SD/MMC 1 init error!!!************
      [3.042][mmc]: mmc_init_boot: mmc int fail
      [3.046][mmc]: mmc_init: mmc init fail, err -17
      MMC init failed
      try card 0
      [3.053][mmc]: mmc driver ver 2018-12-27 9:21:00
      SUNXI SD/MMC: 1, SUNXI SD/MMC: 0
      [3.268][mmc]: mmc 0 update clk failed
      [3.271][mmc]: [mmc]: mmc 0 update clock failed
      [3.276][mmc]: mmc 0 Found fatal err,so no send cmd
      [3.280][mmc]: go idle failed
      [3.283][mmc]: mmc go idle error
      [3.286][mmc]: mmc_init_boot: mmc int fail
      [3.290][mmc]: mmc_init: mmc init fail, err -1
      MMC init failed
      not found SDC
      try emmc fail
      [3.298]NAND_UbootProbe start...
      [3.301]NB1 : enter phy init
      [3.304]nand_physic_init
      [3.307]nand0: get node offset error
      [3.310]init nctri NAND PIORequest error!
      [3.314]nand_physic_init, init nctri error
      [3.317]nand_physic_init init_parameter error
      [3.322]nand_physic_init error -1
      [3.325]SpiNandHwInit: Start Nand Hardware initializing Nov  4 2018 13:15:18.....
      [3.332]uboot: nand version: 3 6019 20181104 1256
      [3.343]request spi gpio  ok!
      irq enable
      [3.349]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x81db89b4
      [3.356]request general tx dma channel ok!
      [3.360]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x81db89d4
      [3.368]request general rx dma channel ok!
      _change_spic_clk: 0x01c05024=0x1009
      _change_spic_clk_v1: mclk=0xc8
      _change_spic_clk: 0x01c05024=0x1004
      [3.383]SPI nand ID: ffffffff ffffffff
      [3.387]SPI nand ID: ffffffff ffffffff
      [3.390]_SearchNandArchi fail
      [3.393][ERR]SpiNandHwInit: SCN_AnalyzeNandSystem() failed!
      [3.398]SpiNandHwInit: End Nand Hardware initializing ..... FAIL!
      [3.404]NB1 : nand phy init fail
      [3.407]NB1 : enter phy Exit
      nand release dma:81db89b4
      nand release dma:0
      sunxi dma exit
      [3.415]NAND_UbootProbe end: 0xffffffff
      try nand fail
      flash size =0x4000 sectors
      sunxi spinor is initing...int sunxi_dma_init---
      irq enable
      sunxi_dma_install_int ok
      OK
      spinor id:0xffffff
      spi_freq = 40000000
      spinor id is ffffff
      try nor successed
      read mbr copy[0] failed
      read mbr copy[1] failed
      read mbr copy[2] failed
      read mbr copy[3] failed
      [3.449]flash init end
      [3.451]try to burn key
      [3.454]inter uboot shell
      work mode=0x10
      run usb efex
      delay time 2500
      usb init ok
      set address 0xa
      SUNXI_EFEX_ERASE_TAG
      erase_flag = 0x1
      FEX_CMD_fes_verify_status
      FEX_CMD_fes_verify last err=0
        memory LV 7 最后由 编辑
        [23]init dram ok
        i2c_init: by cpux
        i2c_init ok
        [2.854]pmbus:   ready
        axp_probe error
        [2.861]PMU: cpux 720 Mhz,AXI=720 Mhz
        DRAM:  32 MiB
        [2.870]fdt addr: 0x809e6ee0
        [2.872]gd->fdt_size: 0xc7c0
        irq enable
        [2.940]flash init start
        try card 1
        [2.946][mmc]: mmc driver ver 2018-12-27 9:21:00
        SUNXI SD/MMC: 1
        [2.961][mmc]: ************Try SD card 1************
        [2.979][mmc]: mmc send if cond failed
        [2.996][mmc]: send app cmd failed
        [2.999][mmc]: ************Try MMC card 1************
        [3.021][mmc]: read op condition failed
        [3.025][mmc]: mmc send op cond failed
        [3.032][mmc]: ************SD/MMC 1 init error!!!************
        [3.037][mmc]: mmc_init_boot: mmc int fail
        [3.041][mmc]: mmc_init: mmc init fail, err -17
        MMC init failed
        try card 0
        [3.048][mmc]: mmc driver ver 2018-12-27 9:21:00
        [3.066][mmc]: ************Try SD card 0************
        [3.086][mmc]: host caps: 0x27
        [3.088][mmc]: MID 22 PSN 7634e19e
        [3.091][mmc]: PNM MK    -- 0x4d-4b-20-20-20
        [3.095][mmc]: PRV 0.6
        [3.097][mmc]: MDT m-1 y-2023
        [3.100][mmc]: user capacity  : 118 MB
        [3.104][mmc]: cache size 0 KB
        [3.106][mmc]: cache ctl 0
        [3.109][mmc]: SD/MMC 0 init OK!!!
        [3.112][mmc]: End mmc_init_boot
        [3.124]flash init end
        [3.126]try to burn key
        [3.129]inter uboot shell
        work mode=0x10
        run usb efex
        delay time 2500
        irq enable
        usb init ok
        set address 0x2
        erase_flag = 0x1
        the 0 mbr table is ok
        the 1 mbr table is ok
        the 2 mbr table is ok
        the 3 mbr table is ok
        total mbr part 8
        part[0] name      :bootlogo
        part[0] classname :DISK
        part[0] addrlo    :0x2000
        part[0] lenlo     :0x400
        part[0] user_type :32768
        part[0] keydata   :0
        part[0] ro        :0
        part[1] name      :env
        part[1] classname :DISK
        part[1] addrlo    :0x2400
        part[1] lenlo     :0x200
        part[1] user_type :32768
        part[1] keydata   :0
        part[1] ro        :0
        part[2] name      :boot
        part[2] classname :DISK
        part[2] addrlo    :0x2600
        part[2] lenlo     :0x4000
        part[2] user_type :32768
        part[2] keydata   :0
        part[2] ro        :0
        part[3] name      :rootfs
        part[3] classname :DISK
        part[3] addrlo    :0x6600
        part[3] lenlo     :0xc800
        part[3] user_type :32768
        part[3] keydata   :0
        part[3] ro        :0
        part[4] name      :rootfs_data
        part[4] classname :DISK
        part[4] addrlo    :0x12e00
        part[4] lenlo     :0xc800
        part[4] user_type :32768
        part[4] keydata   :0
        part[4] ro        :0
        part[5] name      :misc
        part[5] classname :DISK
        part[5] addrlo    :0x1f600
        part[5] lenlo     :0x200
        part[5] user_type :32768
        part[5] keydata   :0
        part[5] ro        :0
        part[6] name      :private
        part[6] classname :DISK
        part[6] addrlo    :0x1f800
        part[6] lenlo     :0x200
        part[6] user_type :32768
        part[6] keydata   :0
        part[6] ro        :0
        part[7] name      :UDISK
        part[7] classname :DISK
        part[7] addrlo    :0x1fa00
        part[7] lenlo     :0x0
        part[7] user_type :33024
        part[7] keydata   :0
        part[7] ro        :0
        total part: 9
        mbr 0, 2000, 8000
        bootlogo 1, 400, 8000
        env 2, 200, 8000
        boot 3, 4000, 8000
        rootfs 4, c800, 8000
        rootfs_data 5, c800, 8000
        misc 6, 200, 8000
        private 7, 200, 8000
        UDISK 8, 0, 8100
        do need erase flash
        sunxi_sprite_erase_flash, erase_flag=1
        private part exist
        the 0 mbr table is bad
        the 1 mbr table is bad
        the 2 mbr table is bad
        the 3 mbr table is bad
        the mbr on flash is bad
        card0 download boot0
        erase boot0, size:32k, write 0x00
        erase env part
        [6.664][mmc]: mmc_mmc_erase: sd card don't support erase
        erase prat's head from sector 0x2400 to 0x2600
        erase boot part
        [6.730][mmc]: mmc_mmc_erase: sd card don't support erase
        erase prat's head from sector 0x2600 to 0x6600
        erase rootfs part
        [8.776][mmc]: mmc_mmc_erase: sd card don't support erase
        erase prat's head from sector 0x6600 to 0xa600
        erase part's tail from sector 0xee00 to 0xfe00
        erase rootfs_data part
        [12.173][mmc]: mmc_mmc_erase: sd card don't support erase
        erase prat's head from sector 0x12e00 to 0x16e00
        erase part's tail from sector 0x1b600 to 0x1c600
        erase misc part
        [15.370][mmc]: mmc_mmc_erase: sd card don't support erase
        erase prat's head from sector 0x1f600 to 0x1f800
        erase private part
        [15.445][mmc]: mmc_mmc_erase: sd card don't support erase
        erase prat's head from sector 0x1f800 to 0x1fa00
        erase UDISK part
        sunxi_sprite_mmc_phyerase: @nr is 0, erase from @from to end
        [15.516][mmc]: mmc_mmc_erase: sd card don't support erase
        erase prat's head from sector 0x1fa00 to 0x23a00
        card erase all
        SUNXI_EFEX_MBR_TAG
        mbr size = 0x10000
        begin to write standard mbr
        successed to write standard mbr
        sunxi_sprite_verify_mbr_from_flash
        total mbr part 8
        part[0] keydata   :0
        part[0] ro        :0
        part[1] name      :env
        part[1] keydata   :0
        part[1] ro        :0
        part[2] name      :boot
        part[2] keydata   :0
        part[2] ro        :0
        part[3] keydata   :0
        part[3] ro        :0
        part[4] keydata   :0
        part[4] ro        :0
        part[5] name      :misc
        part[5] keydata   :0
        part[5] ro        :0
        part[6] keydata   :0
        part[6] ro        :0
        part[7] name      :UDISK
        part[7] lenlo     :0x0
        part[7] keydata   :0
        part[7] ro        :0
        FEX_CMD_fes_verify_value, start 0x2000, size high 0x0:low 0x4b036
        FEX_CMD_fes_verify_value 0x60b4446e
        FEX_CMD_fes_verify_value, start 0x2400, size high 0x0:low 0x20000
        FEX_CMD_fes_verify_value 0xd0d646c3
        FEX_CMD_fes_verify_value, start 0x2600, size high 0x0:low 0x264a10
        FEX_CMD_fes_verify_value 0xf5d8bccd
        FEX_CMD_fes_verify_value, start 0x6600, size high 0x0:low 0x5e5000
        FEX_CMD_fes_verify_value 0xbef15eb
        bootfile_mode=4
        SUNXI_EFEX_BOOT1_TAG
        boot1 size = 0xbc000
        uboot_pkg magic 0x89119800
        uboot size = 0xbc000
        storage type = 1
        mmc down uboot
        bootfile_mode=4
        SUNXI_EFEX_BOOT0_TAG
        boot0 size = 0x8000
        production_media:1!
        [25.429][mmc]: write mmc info ok
        dram para[0] = ea00018e
        dram para[1] = 6f6f6275
        dram para[2] = 74
        dram para[3] = a7698bf5
        dram para[4] = 4000
        dram para[5] = a4000
        dram para[6] = a4000
        dram para[7] = 2e302e33
        dram para[8] = 30
        dram para[9] = 2e302e31
        dram para[10] = 30
        dram para[11] = 80800000
        dram para[12] = 80000000
        dram para[13] = 0
        dram para[14] = 0
        dram para[15] = 0
        dram para[16] = 0
        dram para[17] = 0
        dram para[18] = 0
        dram para[19] = 0
        dram para[20] = 0
        dram para[21] = 0
        dram para[22] = 0
        dram para[23] = 0
        dram para[24] = 0
        dram para[25] = 0
        dram para[26] = 0
        dram para[27] = 0
        dram para[28] = 0
        dram para[29] = 0
        dram para[30] = 0
        dram para[31] = 0
        storage type = 1
        正常是这样的.
          WhycanService LV 8 最后由 编辑
          两个mmc都初始化错误了
          M 1 条回复 最后回复 回复 引用 分享 0
            memory LV 7 @WhycanService 最后由 编辑
            @whycanservice
            搞定了,同事在sd nand的电源上面接了一个MOS管。😂
