    D1s调试rtp,触控屏,电阻屏出现open consoledevice: No such file or directory
    10445
      lingeasy LV 5 最后由 编辑
      在调试D1s的RTP屏幕时,使用getevent可以看到相关的event,手按在上面大概要1秒以上才会出现数据,而且更新的也比较慢。
      在使用TSLIB_TSDEVICE=/dev/input/event0 ts_test,提示“open consoledevice: No such file or directory”和“KDSETMODE: Bad file descriptor”,求大神提点一下,问题出现在哪里了。
      root@TinaLinux:/# getevent
      add device 1: /dev/input/event2
      add device 2: /dev/input/event1
        name:     "audiocodec sunxi Audio Jack"
      add device 3: /dev/input/event0
      poll 4, returned 1
      /dev/input/event0: 0003 0000 00000511
      poll 4, returned 1
      /dev/input/event0: 0003 0001 00000837
      poll 4, returned 1
      /dev/input/event0: 0001 014a 00000001
      poll 4, returned 1
      /dev/input/event0: 0000 0000 00000000
      poll 4, returned 1
      /dev/input/event0: 0003 0000 00000523
      poll 4, returned 1
      poll 4, returned 1
      /dev/input/event0: 0003 0000 00000512
      poll 4, returned 1
      /dev/input/event0: 0003 0001 00000838
      poll 4, returned 1
      poll 4, returned 1
      /dev/input/event0: 0001 014a 00000000
      poll 4, returned 1
      poll 4, returned 1
      /dev/input/event0: 0003 0000 000009c9
      poll 4, returned 1
      /dev/input/event0: 0003 0001 0000091c
      poll 4, returned 1
      poll 4, returned 1
      poll 4, returned 1
      poll 4, returned 1
      ^Z[2]+  Stopped                    getevent
      root@TinaLinux:/#
      root@TinaLinux:/# TSLIB_TSDEVICE=/dev/input/event0 ts_test
        whycan晕哥 LV 9 @lingeasy 最后由 编辑
        @lingeasy
        cat /proc/interrupts
        看下中断的增加速度
        L 3 条回复 最后回复 回复 引用 分享 0
          lingeasy LV 5 @whycan 最后由 编辑
          @whycan
          root@TinaLinux:/# cat /proc/interrupts
                     CPU0
            2:         10  SiFive PLIC  78  sun4i-ts
            4:          0  SiFive PLIC  80  2010000.iommu
            6:          0  SiFive PLIC  82  cedar_dev
            8:          0  SiFive PLIC 160  7090000.rtc
           21:        134  SiFive PLIC  21  uart3
           29:          0  SiFive PLIC 105  5410000.g2d
           30:      57816  SiFive PLIC 106  dispaly
           31:      17714  SiFive PLIC  31  spi0
           36:          6  SiFive PLIC  36  ledcirq
           41:          0  SiFive PLIC  41  audio jack irq
           45:        103  SiFive PLIC  45  sunxi_usb_udc
           49:          0  SiFive PLIC  49  ehci_hcd:usb1
           50:          0  SiFive PLIC  50  ohci_hcd:usb2
           56:          0  SiFive PLIC  56  mmc0
           62:          0  SiFive PLIC  62  4500000.eth
           66:       4117  SiFive PLIC  66  3002000.dma-controller
           73:          0  SiFive PLIC  73  sunxi-gpadc
           75:          0  SiFive PLIC  75  timer@2050000
          177:          1  sunxi_pio_edge 134  4020000.sdmmc cd
          看了一下,如上。
            @whycan 这个错误提示是哪里出问题了
              @lingeasy
              TSLIB_FBDEVICE=/dev/fb0 TSLIB_TSDEVICE=/dev/input/event0 ts_calibrate
              参考这个: Linux 执行 ts_test ts_calibrate 都提示 No such file or directory, 求教
                @whycan 还是相同的提示,是不是配置哪里少了?
                root@TinaLinux:/# TSLIB_FBDEVICE=/dev/fb0 TSLIB_TSDEVICE=/dev/input/event0 ts_calibrate
                  @lingeasy
                  https://blog.csdn.net/qq_21792169/article/details/50408577
                  TSLIB_CONSOLEDEVICE=/dev/tty1 TSLIB_FBDEVICE=/dev/fb0 TSLIB_TSDEVICE=/dev/input/event0 ts_calibrate
                    @whycan 增加完成以后又提示“Couldnt load module input” 和“No raw modules loaded”。
                    root@TinaLinux:/# export TSLIB_TSDEVICE=/dev/event0
                    root@TinaLinux:/# export TSLIB_CALIBFILE=/etc/pointercal
                    root@TinaLinux:/# export TSLIB_CONFFILE=/etc/ts.conf
                    root@TinaLinux:/# export TSLIB_PLUGINDIR=/lib/ts/
                    root@TinaLinux:/# export TSLIB_CONSOLEDEVICE=/dev/ttyS3
                    root@TinaLinux:/# export TSLIB_FBDEVICE=/dev/fb0
                    root@TinaLinux:/# TSLIB_CONSOLEDEVICE=/dev/ttyS3 TSLIB_FBDEVICE=/dev/fb0 TSLIB_T
                    No raw modules loaded.
                    ts_config: Success
                    ts_setup: Success
                    ts.conf内容如下:
                    # Uncomment if you wish to use the one-wire linux input layer S70/A70...
                    # module_raw one_wire_ts_input
                    # Uncomment if you wish to use the linux input layer event interface
                    module_raw input
                    # Uncomment if you're using a Sharp Zaurus SL-5500/SL-5000d
                    # module_raw collie
                    # Uncomment if you're using a Sharp Zaurus SL-C700/C750/C760/C860
                    # module_raw corgi
                    # Uncomment if you're using a device with a UCB1200/1300/1400 TS interface
                    # module_raw ucb1x00
                    # Uncomment if you're using an HP iPaq h3600 or similar
                    # module_raw h3600
                    # Uncomment if you're using a Hitachi Webpad
                    # module_raw mk712
                    # Uncomment if you're using an IBM Arctic II
                    # module_raw arctic2
                    module pthres pmin=1
                    module variance delta=30
                    module dejitter delta=100
                    module linear
                      @lingeasy 在 D1s调试rtp,触控屏,电阻屏出现open consoledevice: No such file or directory 中说:
                      ts.conf
                      这个文件完整路径是什么呢?
                        @whycan 是路径不对😵 改了一下“SLIB_PLUGINDIR=/usr/lib/ts”,目前是正常了,配置如下:
                        #! /bin/sh
                        export TSLIB_PLUGINDIR=/usr/lib/ts
                        export TSLIB_CONSOLEDEVICE=none
                        export TSLIB_TSDEVICE=/dev/input/event0
                        1d02be74-7a36-47cc-9a1b-930480b6c8ed-5491663775_100255822278_rbby3dabbe4pe985r049hamj_0.jpg
                          @whycan 使用ts_test的时候,非常不跟手,需要配置哪些呀🙏 🙏 大神指点
                            @lingeasy
                            芯片自带的RTP吗?
                            L 2 条回复 最后回复 回复 引用 分享 0
                              @whycan 用的是d1s哪吒开发板上的rtp功能。
                                @whycan 已经解决了,看到在别一个帖子里面的说明
                                修改“lichee/linux-5.4/drivers/input/touchscreen/sun4i-ts.c”文件中相关内容
                                【原内容】
                                	writel(ADC_CLK_SEL(0) | ADC_CLK_DIV(2) | FS_DIV(7) | T_ACQ(63),
                                	       ts->base + TP_CTRL0);
                                	if (of_device_is_compatible(np, "allwinner,sun8i-ts"))
                                		writel(ADC_FIRST_DLY(0x1) | ADC_FIRST_DLY_MODE(0x1)
                                			| ADC_CLK_DIV(0x2) | FS_DIV(2) | T_ACQ(5),
                                【修改后】
                                		writel(ADC_FIRST_DLY(0xf) | ADC_FIRST_DLY_MODE(0x1)
                                			| ADC_CLK_DIV(0x2) | FS_DIV(6) | T_ACQ(63),
                                whycan 1 条回复 最后回复 回复 引用 分享 1
                                  @lingeasy
                                  谢谢分享!
