    D1 执行 jpegdecodedemo 炸了,请问是怎么回事呢?
    d1 jpegdecodedemo
    4711
      memory LV 7 最后由 编辑
      root@TinaLinux:/opt# jpegdecodedemo /tmp/1652337446.jpg 1 nv12
      * This program shows how to decode a jpeg picture to yuv or rgb data
      main line70 : 11111111111111111111111111111111111
      main line83 : 11111111111111111111111111111111111
      tag   : tina3.5
      branch: tina-dev
      WARNING: cedarc <getSocIdString:1117>: cannot open /dev/sunxi_soc_info, it maybe ok!
      INFO   : cedarc <VeInitialize:1307>: *** ic_version = 0x1301000010210,
      WARNING: cedarc <AddVDPlugin:1574>: 1117 get local path: /usr/lib/
      WARNING: cedarc <AddVDPlugin:1584>:  1117 load so: /usr/lib/libaw_aacdec.so
      WARNING: cedarc <AddVDPluginSingle:1424>: Invalid plugin, CedarPluginVDInit not found.
      WARNING: cedarc <AddVDPlugin:1584>:  1117 load so: /usr/lib/libaw_alacdec.so
      WARNING: cedarc <AddVDPlugin:1584>:  1117 load so: /usr/lib/libaw_amrdec.so
      WARNING: cedarc <AddVDPlugin:1584>:  1117 load so: /usr/lib/libaw_apedec.so
      WARNING: cedarc <AddVDPlugin:1584>:  1117 load so: /usr/lib/libaw_atrcdec.so
      WARNING: cedarc <AddVDPlugin:1584>:  1117 load so: /usr/lib/libaw_dsddec.so
      WARNING: cedarc <AddVDPlugin:1584>:  1117 load so: /usr/lib/libaw_flacdec.so
      WARNING: cedarc <AddVDPlugin:1584>:  1117 load so: /usr/lib/libaw_g729dec.so
      WARNING: cedarc <AddVDPlugin:1584>:  1117 load so: /usr/lib/libaw_mp3dec.so
      WARNING: cedarc <AddVDPlugin:1584>:  1117 load so: /usr/lib/libaw_oggdec.so
      WARNING: cedarc <AddVDPlugin:1584>:  1117 load so: /usr/lib/libaw_opusdec.so
      WARNING: cedarc <AddVDPlugin:1584>:  1117 load so: /usr/lib/libaw_radec.so
      WARNING: cedarc <AddVDPlugin:1584>:  1117 load so: /usr/lib/libaw_siprdec.so
      WARNING: cedarc <AddVDPlugin:1584>:  1117 load so: /usr/lib/libaw_wavdec.so
      WARNING: cedarc <AddVDPlugin:1584>:  1117 load so: /usr/lib/libawh264.so
      INFO   : cedarc <CedarPluginVDInit:79>: register h264 decoder success!
      WARNING: cedarc <AddVDPlugin:1584>:  1117 load so: /usr/lib/libawh265.so
      INFO   : cedarc <CedarPluginVDInit:85>: register h265 decoder success!
      WARNING: cedarc <AddVDPlugin:1584>:  1117 load so: /usr/lib/libawmjpeg.so
      INFO   : cedarc <CedarPluginVDInit:84>: register mjpeg decoder success!
      WARNING: cedarc <AddVDPlugin:1584>:  1117 load so: /usr/lib/libawmpeg2.so
      INFO   : cedarc <CedarPluginVDInit:86>: register mpeg2 decoder success!
      WARNING: cedarc <AddVDPlugin:1584>:  1117 load so: /usr/lib/libawmpeg4base.so
      WARNING: cedarc <AddVDPlugin:1584>:  1117 load so: /usr/lib/libawmpeg4dx.so
      INFO   : cedarc <CedarPluginVDInit:92>: register mpeg4dx decoder success!
      WARNING: cedarc <AddVDPlugin:1584>:  1117 load so: /usr/lib/libawmpeg4h263.so
      INFO   : cedarc <CedarPluginVDInit:79>: register mpeg4H263 decoder success!
      WARNING: cedarc <AddVDPlugin:1584>:  1117 load so: /usr/lib/libawmpeg4normal.so
      INFO   : cedarc <CedarPluginVDInit:90>: register mpeg4Normal decoder success!
      WARNING: cedarc <AddVDPlugin:1584>:  1117 load so: /usr/lib/libawrecorder.so
      WARNING: cedarc <AddVDPlugin:1584>:  1117 load so: /usr/lib/libawwmv3.so
      INFO   : cedarc <CedarPluginVDInit:74>: register vc1 decoder success!
      main line87 : 11111111111111111111111111111111111
      main line95 : 11111111111111111111111111111111111
      main line98 : 11111111111111111111111111111111111
      main line118 : 11111111111111111111111111111111111
      main line136 : 11111111111111111111111111111111111
      srcBuf = 0xb4cb8008,srcBufLen = 27286594[47563.997123] VE: VE real_freq=576000000
      [47563.997123]
      JpegDecoderSetDataSource end
      main line146 : 11111111111111111111111111111111111
      INFO   : cedarc <log_set_level:43>: Set log level to 5 from /vendor/etc/cedarc.conf
      ERROR  : cedarc <DebugCheckConfig:301>: now cedarc log level:5
      WARNING: cedarc <RequestVideoStreamBuffer:1274>: request stream buffer fail,                  0 bytes valid data in SBM[0], total buffer size is 2097152 bytes.
      main line149 : 11111111111111111111111111111111111
      JpegDecoderGetFrame fail
        whycan晕哥 LV 9 @memory 最后由 编辑
        @memory
        分辨率太大了,xy都缩小一半试一试。
        M 1 条回复 最后回复 回复 引用 分享 0
          memory LV 7 @whycan 最后由 编辑
          @whycan
          搞定了,谢谢。
          B 1 条回复 最后回复 回复 引用 分享 0
          • B
            barsonsss LV 3 @memory 最后由 编辑
            @memory 我也遇到了这个情况,
            请问您是怎么解决的呢
