    reboot 命令为什么不能重新启动?
    6
    7
    5894
    • U
      ubuntu LV 7 最后由 编辑
      root@TinaLinux:/#
      root@TinaLinux:/# /etc/init.d/rcK: line 7: /etc/init.d/S01app: not found
      Not defined "stop" functions!!!
      Stopping telnetd: FAIL
      cat: can't open '/sys/class/sunxi_info/sys_info': No such file or directory
      Stopping network: FAIL
      stop...
      Stopping logging: OK
      Unload mpp modules
      rmmod: can't unload module 'sunxi_eise': No such file or directory
      rmmod: can't unload module 'sunxi_aio': No such file or directory
      rmmod: can't unload module 'vin_v4l2': No such file or directory
      rmmod: can't unload module 'imx386_mipi': No such file or directory
      rmmod: can't unload module 'vin_io': No such file or directory
      rmmod: can't unload module 'videobuf2_v4l2': No such file or directory
      rmmod: can't unload module 'videobuf2_dma_contig': No such file or directory
      rmmod: can't unload module 'videobuf2_memops': No such file or directory
      rmmod: can't unload module 'videobuf2_core': No such file or directory
      can't run '/sbin/swapoff': No such file or directory
      [ 1964.322835] ffs_data_put(): freeing
      [ 1964.335387] [EXFAT] trying to unmount...
      [ 1964.339937] [EXFAT] unmounted successfully
      [ 1964.345819] UBIFS (ubi0:7): un-mount UBI device 0
      [ 1964.351114] UBIFS (ubi0:7): background thread "ubifs_bgt0_7" stops
      umount: devtmpfs busy - remounted read-only
      The system is going down NOW!
      Sent SIGTERM to all processes
      Requesting system reboot
      [ 1966.365810] [ohci1-controller]: ohci shutdown start
      [ 1966.371318] [ohci1-controller]: ohci shutdown end
      [ 1966.376680] [ehci1-controller]: ehci shutdown start
      [ 1966.382664] [ehci1-controller]: ehci shutdown end
      [ 1966.388370] sunxi_ohci_hcd_shutdown, ohci0-controller is disable, need not shutdown
      [ 1966.397002] sunxi_ehci_hcd_shutdown, ehci0-controller is disable, need not shutdown
      [ 1967.424711] reboot: Restarting system
      [ 1968.428877] Reboot failed -- System halted
      whycan M 2 条回复 最后回复 回复 引用 分享 0
        whycan晕哥 LV 9 @ubuntu 最后由 编辑
        @ubuntu
        reboot 依赖看门狗,试一试把看门狗开起来。
        F 1 条回复 最后回复 回复 引用 分享 0
          memory LV 7 @ubuntu 最后由 编辑
          @ubuntu
          是的,要开狗。
          U 1 条回复 最后回复 回复 引用 分享 0
          • U
            ubuntu LV 7 @memory 最后由 编辑
            @memory @whycan 谢谢两位,开看门狗之后正常了。
              zx2125 LV 2 最后由 编辑
              我用的T3,我写了的0x01c20c94这个寄存器为什么不起作用呢
              X 1 条回复 最后回复 回复 引用 分享 0
              • F
                fantiming LV 1 @whycan 最后由 编辑
                @whycan 如何用shell指令开启看门狗
                • X
                  xiandaozhang LV 3 @zx2125 最后由 编辑
                  @zx2125 有的依赖于32.768晶振,看看晶振振了没
