    D1s+XR819S(使用外部晶振24M)驱动INT加载失败问题求救
    • zznzzn
      zznzzn LV 6 最后由 xiaowenge 编辑
      平台: D1s+XR819S(使用外部晶振24M) TINA系统
      问题现象:
      1. xr819s驱动INT加载失败,主要异常
        [XRADIO_ERR] fw_record_read: Wait for wakeup:device is not responding.
      复现步骤:
      1. 给机器上电
      2. 等待机器启动完成
      3. 确认wifi是否正常,正常回到步骤1,异常发现xr819s驱动加载异常。
      详细log见(wifi_ng.txt)
      ------run profile file-----
      nodev   debugfs
      mount: mounting none on /sys/kernel/debug failed: Device or resource busy
      root@TinaLinux:/# dmesg
      Linux version 5.4.61 (victor@inone-server1) (riscv64-unknown-linux-gnu-gcc (C-SKY RISCV Tools V1.8.4 B20200702) 8.1.0, GNU ld (GNU Binutils) 2.32) #237 PREEMPT Mon Oct 10 07:46:01 UTC 2022
      Zone ranges:
        DMA32    [mem 0x0000000040000000-0x0000000043ffffff]
        Normal   empty
      Movable zone start for each node
      Early memory node ranges
        node   0: [mem 0x0000000040000000-0x0000000043ffffff]
      On node 0 totalpages: 16384
        DMA32 zone: 0 pages reserved
      elf_hwcap is 0x20112d
      pcpu-alloc: [0] 0
      Kernel command line: ubi.mtd=sys ubi.block=0,rootfs earlyprintk=sunxi-uart,0x02500400 clk_ignore_unused initcall_debug=0 console=ttyS1,115200 loglevel=0 root=/dev/ubiblock0_5 rootfstype=squashfs init=/pseudo_init partitions=mbr@ubi0_0:boot-resource@ubi0_1:env@ubi0_2:env-redund@ubi0_3:boot@ubi0_4:rootfs@ubi0_5:rootfs_data@ubi0_6:UDISK@ubi0_7: cma=0M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun20iw1p1 boot_type=5 androidboot.boot_type=5 gpt=1 uboot_message=2018.07-00012-g32210268-dirty(12/22/2022-17:28:48) mbr_offset=1556480 disp_reserve=921600,0x0000000042b71000 aw-ubi-spinand.ubootblks=24 androidboot.dramsize=64
      Sorting __ex_table...
      Memory: 57140K/65536K available (3804K kernel code, 445K rwdata, 1223K rodata, 132K init, 342K bss, 8396K reserved, 0K cma-reserved) rcu: Preemptible hierarchical RCU implementation.
              Tasks RCU enabled.
      rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
      Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      devtmpfs: initialized
      random: get_random_u32 called from 0xffffffe000157198 with crng_init=0
      clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      NET: Registered protocol family 16
      cpuidle: using governor menu
      rtc_ccu: sunxi ccu init OK
      clock: sunxi ccu init OK
      sun6i-dma 3002000.dma-controller: sunxi dma probed
      sunxi iommu: irq = 4
      SCSI subsystem initialized
      videodev: Linux video capture interface: v2.00
      Advanced Linux Sound Architecture Driver Initialized.
      pwm module init!
      G2D: rcq version initialized.major:252
      sun8iw20-pinctrl pio: initialized sunXi PIO driver
      NET: Registered protocol family 2
      tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
      TCP established hash table entries: 512 (order: 0, 4096 bytes, linear)
      TCP bind hash table entries: 512 (order: 0, 4096 bytes, linear)
      TCP: Hash tables configured (established 512 bind 512)
      UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
      UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
      sun8iw20-pinctrl pio: pio supply vcc-pc not found, using dummy regulator
      sunxi_spi_resource_get()2438 - [spi0] SPI MASTER MODE
      sunxi_spi_resource_get()2485 - sample_mode:1 sample_delay:26
      sunxi_spi_clk_init()2527 - [spi0] mclk 100000000
      sunxi_spi_probe()2964 - [spi0]: driver probe succeed, base ffffffd004058000, irq 31
      io scheduler kyber registered
      [DISP]disp_module_init
      [DISP] parser_disp_init_para,line:1407:
      of_property_read fb0_width fail
      [DISP] disp_init,line:2331:
      display_fb_request,fb_id:0
      Freeing logo buffer memory: 900K
      [DISP] lcd_clk_config,line:774:
      disp 0, clk: pll(480000000),clk(480000000),dclk(80000000) dsi_rate(80000000)
           clk real:pll(480000000),clk(480000000),dclk(120000000) dsi_rate(150000000)
      sun8iw20-pinctrl pio: pio supply vcc-pd not found, using dummy regulator
      [DISP]disp_module_init finish
      sunxi_sid_init()563 - insmod ok
      sun8iw20-pinctrl pio: pio supply vcc-pg not found, using dummy regulator
      uart uart1: uart1 supply uart not found, using dummy regulator
      uart1: ttyS1 at MMIO 0x2500400 (irq = 19, base_baud = 1500000) is a SUNXI
      sw_console_setup()1807 - console setup baud 115200 parity n bits 8, flow n
      printk: console [ttyS1] enabled
      uart uart3: uart3 supply uart not found, using dummy regulator
      uart3: ttyS3 at MMIO 0x2500c00 (irq = 21, base_baud = 1500000) is a SUNXI
      sun8iw20-pinctrl pio: pio supply vcc-pb not found, using dummy regulator
      uart uart5: uart5 supply uart not found, using dummy regulator
      uart5: ttyS5 at MMIO 0x2501400 (irq = 23, base_baud = 1500000) is a SUNXI
      misc dump reg init
      sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
      sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
      sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=131 assert=1
      sun8iw20-pinctrl pio: pio supply vcc-pe not found, using dummy regulator
      sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
      sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
      sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
      sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
      sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=210 assert=0
      [ADDR_MGT] addr_mgt_probe: module version: v1.0.11
      sunxi-spinand: AW SPINand MTD Layer Version: 2.3 20211223
      sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.10 20200306
      sunxi-spinand-phy: not detect any munufacture from id table
      sunxi-spinand-phy: get spi-nand Model from fdt fail
      sunxi-spinand-phy: get phy info from fdt fail
      sunxi-spinand-phy: not detect munufacture from fdt
      sunxi-spinand-phy: detect munufacture from id table: Mxic
      sunxi-spinand-phy: detect spinand id: ffff12c2 ffffffff
      sunxi-spinand-phy: ========== arch info ==========
      sunxi-spinand-phy: Model:               MX35LF1GE4AB
      sunxi-spinand-phy: Munufacture:         Mxic
      sunxi-spinand-phy: DieCntPerChip:       1
      sunxi-spinand-phy: BlkCntPerDie:        1024
      sunxi-spinand-phy: PageCntPerBlk:       64
      sunxi-spinand-phy: SectCntPerPage:      4
      sunxi-spinand-phy: OobSizePerPage:      64
      sunxi-spinand-phy: BadBlockFlag:        0x1
      sunxi-spinand-phy: OperationOpt:        0x7
      sunxi-spinand-phy: MaxEraseTimes:       65000
      sunxi-spinand-phy: EccFlag:             0x2
      sunxi-spinand-phy: EccType:             4
      sunxi-spinand-phy: EccProtectedType:    3
      sunxi-spinand-phy: ========================================
      sunxi-spinand-phy:
      sunxi-spinand-phy: ========== physical info ==========
      sunxi-spinand-phy: TotalSize:    128 M
      sunxi-spinand-phy: SectorSize:   512 B
      sunxi-spinand-phy: PageSize:     2 K
      sunxi-spinand-phy: BlockSize:    128 K
      sunxi-spinand-phy: OOBSize:      64 B
      sunxi-spinand-phy:
      sunxi-spinand-phy: ========== logical info ==========
      sunxi-spinand-phy: PageSize:     4 K
      sunxi-spinand-phy: BlockSize:    256 K
      sunxi-spinand-phy: OOBSize:      128 B
      sunxi-spinand-phy: block lock register: 0x00
      sunxi-spinand-phy: feature register: 0x11
      sunxi-spinand-phy: sunxi physic nand init end
      Creating 4 MTD partitions on "sunxi_mtd_nand":
      0x000000000000-0x000000100000 : "boot0"
      0x000000100000-0x000000400000 : "uboot"
      random: fast init done
      0x000000400000-0x000000500000 : "secure_storage"
      0x000000500000-0x000008000000 : "sys"
      sunxi-ehci: EHCI SUNXI driver
      [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xffffffe0005c0948, 0x:ffffffd004074000, irq_no:31
      hub 1-0:1.0: USB hub found
      hub 1-0:1.0: 1 port detected
      sunxi-ohci: OHCI SUNXI driver
      [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xffffffe0005c0d10
      hub 2-0:1.0: USB hub found
      hub 2-0:1.0: 1 port detected
      sunxi-rtc 7090000.rtc: errata__fix_alarm_day_reg_default_value(): ALARM0_DAY_REG=0, set it to 1
      sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:00:03 UTC (3)
      i2c /dev entries driver
      sunxi cedar version 1.1
      VE: install start!!!
      VE: cedar-ve the get irq is 6
      VE: ve_debug_proc_info:(____ptrval____), data:(____ptrval____), lock:(____ptrval____)
      VE: install end!!!
      VE: sunxi_cedar_probe
      sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40)
      sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 52, RTO !!
      ashmem: initialized
      exFAT: Version 1.3.0
      sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 5, RTO !!
      sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [AUDIOCODEC][sunxi_codec_parse_params][2437]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
      [AUDIOCODEC][sunxi_codec_parse_params][2473]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
      [AUDIOCODEC][sunxi_internal_codec_probe][2634]:codec probe finished
      debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
      input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input0
      [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
      Segment Routing with IPv6
      i2c-gpio soc@3000000:i2c-gpio@4: using lines 141 (SDA) and 140 (SCL)
      [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xffffffe0005c01b8, 0x:ffffffd0040ee000, irq_no:2e
      [sunxi-ehci0]: Not init ehci0
      [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xffffffe0005c0580
      [sunxi-ohci0]: Not init ohci0
      Authentication OK
      ubi0: attaching mtd3
      random: crng init done
      ubi0: scanning is finished
      ubi0: attached mtd3 (name "sys", size 123 MiB)
      ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
      ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
      ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
      ubi0: user volume: 8, internal volumes: 1, max. volumes count: 128
      ubi0: max/mean erase counter: 4/1, WL threshold: 4096, image sequence number: 0
      ubi0: available PEBs: 0, total reserved PEBs: 492, PEBs reserved for bad PEB handling: 20
      ubi0: background thread "ubi_bgt0d" started, PID 60
      block ubiblock0_5: created from ubi0:5(rootfs)
      otg manager soc@3000000:usbc0@0: soc@3000000:usbc0@0 supply usbc not found, using dummy regulator
      ALSA device list:
        #0: audiocodec
      alloc_fd: slot 0 not NULL!
      VFS: Mounted root (squashfs filesystem) readonly on device 254:0.
      devtmpfs: mounted
      Freeing unused kernel memory: 132K
      This architecture does not have kernel memory protection.
      Run /pseudo_init as init process
      UBIFS (ubi0:6): Mounting in unauthenticated mode
      UBIFS (ubi0:6): background thread "ubifs_bgt0_6" started, PID 85
      UBIFS (ubi0:6): recovery needed
      UBIFS (ubi0:6): recovery completed
      UBIFS (ubi0:6): UBIFS: mounted UBI device 0, volume 6, name "rootfs_data"
      UBIFS (ubi0:6): LEB size: 258048 bytes (252 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
      UBIFS (ubi0:6): FS size: 70705152 bytes (67 MiB, 274 LEBs), journal size 3612672 bytes (3 MiB, 14 LEBs)
      UBIFS (ubi0:6): reserved for root: 3339578 bytes (3261 KiB)
      UBIFS (ubi0:6): media format: w5/r0 (latest is w5/r0), UUID 6F06728E-F9EE-4F79-8337-A20F7745B8A1, small LPT model
      UBIFS (ubi0:7): Mounting in unauthenticated mode
      UBIFS (ubi0:7): background thread "ubifs_bgt0_7" started, PID 115
      UBIFS (ubi0:7): recovery needed
      UBIFS (ubi0:7): recovery completed
      UBIFS (ubi0:7): UBIFS: mounted UBI device 0, volume 7, name "UDISK"
      UBIFS (ubi0:7): LEB size: 258048 bytes (252 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
      UBIFS (ubi0:7): FS size: 2580480 bytes (2 MiB, 10 LEBs), journal size 1806337 bytes (1 MiB, 5 LEBs)
      UBIFS (ubi0:7): reserved for root: 121882 bytes (119 KiB)
      UBIFS (ubi0:7): media format: w5/r0 (latest is w5/r0), UUID 5B4008FC-7440-4B25-B0AA-BEF8B944333D, small LPT model
      insmod_device_driver
      sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
      ======== XRADIO WIFI OPEN ========
      [XRADIO] Driver Label:XR_V02.25.82   Aug 19 2022 07:55:11
      [XRADIO] Allocated hw_priv @ 000000001e8f7730
      sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
      sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
      [XRADIO] Detect SDIO card 1
      sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
      mmc0: new high speed SDIO card at address 0001
      [SBUS] XRadio Device:sdio clk=50000000
      [XRADIO] XRADIO_HW_REV 1.1 detected.
      [XRADIO] Bootloader complete
      [XRADIO] Firmware completed.
      [WSM] Firmware Label:R0-XR_C07.08.52.65_02.65 Mar  5 2021 11:45:46
      [WSM] Efuse Flag=0x91, MAC Addr=80:74:84:02:25:93
      [XRADIO] Firmware Startup Done.
      mac80211_register_hw signal_type CFG80211_SIGNAL_TYPE_MBM
      ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
      [BH_ERR] Device cannot wakeup in 2000ms.
      ------------[ cut here ]------------
      WARNING: CPU: 0 PID: 121 at drivers/net/wireless/xr819s/wlan/bh.c:878 0xffffffdf80611720
      Modules linked in: xr819s
      CPU: 0 PID: 121 Comm: xradio_bh Not tainted 5.4.61 #237
      sepc: ffffffdf80611720 ra : ffffffdf80611720 sp : ffffffe0018ebd90
       gp : ffffffe000579dec tp : ffffffe00258c000 t0 : ffffffe00058db58
       t1 : 0000000000000063 t2 : 0000000000000002 s0 : ffffffe001849ee0
       s1 : ffffffdf8063fd3d a0 : 0000000000000028 a1 : 0000000000000000
       a2 : 0000000000000000 a3 : ffffffe00051cc00 a4 : 0000000000000000
       a5 : 0000000000000000 a6 : 0000000000000004 a7 : 0000000000000028
       s2 : 0000000000000001 s3 : 0000000000000000 s4 : 0000000000000000
       s5 : ffffffe0018ebe08 s6 : 0000000000001000 s7 : ffffffe00051fa90
       s8 : ffffffe00184a530 s9 : 0000000000000fff s10: ffffffe0018ebe00
       s11: 0000000000000002 t3 : ffffffffffffffff t4 : ffffffe00051be08
       t5 : 0000000000000001 t6 : ffffffe00058db58
      sstatus: 0000000200000120 sbadaddr: 0000000000000000 scause: 0000000000000003
      ---[ end trace 0515eeb33a71b7fa ]---
      [BH_ERR] Fatal error, exitting code=879.
      [XRADIO] fw_record addr=0x7fb3dae6
      [XRADIO_ERR] fw_record_read:unkown record=0x7fb3dae6
      [XRADIO] --FW_RECORD_READ START--
      [XRADIO] Current SCHED=0
      [XRADIO] 0x00,0x00,0x00,0x00 0x00,0x00,0x00,0x00
      [XRADIO] Current cmds=0
      [XRADIO] 0x0000,0x0000,0x0000,0x0000
      [XRADIO] Current frames=0
      [XRADIO] 0x00000000,0x00000000,0x00000000,0x00000000
      [XRADIO] Current Fiqs=0
      [XRADIO] Current PC=0x00000000
      [XRADIO] Current Timer=0
      [XRADIO] --FW_RECORD_READ END--
      [WSM_ERR] ***CMD timeout!>>> 0x0009 (820), cmd_ptr=00000000405ef7e2, buf_use=0,bh_state=879
      WARNING: CPU: 0 PID: 122 at drivers/net/wireless/xr819s/wlan/sta.c:1920 0xffffffdf806189a8
      CPU: 0 PID: 122 Comm: wpa_supplicant Tainted: G        W         5.4.61 #237
      sepc: ffffffdf806189a8 ra : ffffffdf806189a2 sp : ffffffe00180baa0
       gp : ffffffe000579dec tp : ffffffe0026ac000 t0 : ffffffe00058ec40
       t1 : 0000000000000063 t2 : 0000000000000000 s0 : ffffffe001849ee0
       s1 : 0000000000000001 a0 : ffffffffffffff92 a1 : 0000000000000003
       a2 : 0000000000000001 a3 : ffffffe00184a530 a4 : 0000000000000000
       a5 : 0000000000000000 a6 : 0000000000000004 a7 : 000000000000005b
       s2 : ffffffdf8063fd3a s3 : ffffffe00184f740 s4 : ffffffe001800000
       s5 : ffffffe001848900 s6 : 0000000000000000 s7 : 0000000000000000
       s8 : 0000000000000000 s9 : 0000000000000007 s10: 00000000000de3f0
       s11: 0000000000000000 t3 : ffffffffffffffff t4 : ffffffe00051be08
       t5 : 0000000000000001 t6 : ffffffe00058ec3b
      ---[ end trace 0515eeb33a71b7fb ]---
      WARNING: CPU: 0 PID: 122 at drivers/net/wireless/xr819s/wlan/sta.c:168 0xffffffdf80618ba0
      sepc: ffffffdf80618ba0 ra : ffffffdf80618b9c sp : ffffffe00180bb20
       t1 : ffffffe00008e06e t2 : 0000000000000000 s0 : 0000000000000001
       s1 : ffffffe00184a3b0 a0 : 0000000000000001 a1 : 0000000000000050
       a2 : 00000000000003fc a3 : 000000000000bf0c a4 : 0000000000000000
       a5 : 0000000000000000 a6 : ffffffe003fa24e0 a7 : 00000000000051f3
       s2 : ffffffdf806422d0 s3 : ffffffdf8063fd3a s4 : ffffffe001800000
      ---[ end trace 0515eeb33a71b7fc ]---
      [STA_ERR] xradio_start, xradio_setup_mac failed(1)
      file system registered
      configfs-gadget 4100000.udc-controller: failed to start g1: -19
      read descriptors
      read strings
      sunxi_set_cur_vol_work()489 WARN: get power supply failed
      android_work: sent uevent USB_STATE=CONNECTED
      configfs-gadget gadget: high-speed config #1: c
      android_work: sent uevent USB_STATE=CONFIGURED
      [WSM_ERR] wsm_upper_restart
      [WSM_WRN] Wait for scan complete!
      [WSM_WRN] wsm_upper_restart schedule restart_work!
      [XRADIO] xradio_restart_work
      [XRADIO] xradio_core_reinit 992!
      [WSM_ERR] bh_error=1, wsm_unlock_tx is unsafe
      sunxi-rfkill soc@3000000:rfkill@0: wlan power off success
      [XRADIO] Remove SDIO card 1
      sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 7, RTO !!
      mmc0: card 0001 removed
      [XRADIO] xradio_core_reinit:Firmware Startup Done.
      ieee80211 phy0: Hardware restart was requested
      [XRADIO] xradio_core_reinit end!
      rmmod_device_driver
      rmmod_device_driver()222 WARN: get power supply failed
      android_work: sent uevent USB_STATE=DISCONNECTED
      [SNDCODEC][sunxi_card_hw_params][620]:stream_flag: 0
      wifi_ng.txt
        whycan晕哥 LV 9 @zznzzn 最后由 编辑
        @zznzzn
        wlan_regon 使能引脚拉高了吗?
          WhycanService LV 8 最后由 编辑
