    T113 Tina Linux 禁用 OPTEE 启动
      柚木 鉉 LV 9 最后由 WhycanService 编辑
      1. 在 device/config/chips/t113/configs/<aaa>/ 新建一个 boot_package.cfg
      写入以下内容
      [package]
      item=u-boot, u-boot.fex
      item=dtb,    sunxi.fex
      1. 找到 lichee/linux-5.4/arch/arm/boot/dts/sun8iw20p1.dtsi 中的 psci 节点把他删了
      psci {
      	compatible = "arm,psci-1.0";
      	method = "smc";
      1. 打开 lichee/linux-5.4/arch/arm/mach-sunxi/platsmp.c 文件,在末尾加入下列内容
      static int sun8i_t113_smp_boot_secondary(unsigned int cpu,
      				    struct task_struct *idle)
          u32 reg;
          void __iomem *cpucfg_membase = ioremap(0x09010000, 0x10);
          void __iomem *cpuexec_membase[] = {ioremap(0x070005C4, 0x10),ioremap(0x070005C8, 0x10)};
      	if (cpu != 1)
      	spin_lock(&cpu_lock);
      	writel(__pa_symbol(secondary_startup),	cpuexec_membase[cpu]);
      	reg = readl(cpucfg_membase);
      	writel(reg | BIT(cpu), cpucfg_membase);
      	spin_unlock(&cpu_lock);
      static const struct smp_operations sun8i_t113_smp_ops __initconst = {
      	.smp_boot_secondary	= sun8i_t113_smp_boot_secondary,
      CPU_METHOD_OF_DECLARE(sun8i_t113_smp, "allwinner,sun8iw20p1", &sun8i_t113_smp_ops);
      • tigger
        tigger LV 7 最后由 编辑
        OPTEE 用来干嘛的呢?
        • Referenced by  L liangzhicheng
