    T5实现一路uvc预览输出视频
    5371
    • F
      Flork LV 4 最后由 Flork 编辑
      我需要利用T5的usb0输出视频图像,脚本参考run_otg,应用层demo来自uvc-gadget,应用层启动指令为./uvc-gadget -i /root/images.jpg -f 1 -s 1 -r 1。
      在设备树中CONFIG_USB_F_UVC和CONFIG_USB_LIBCOMPOSITE都已经打开,接入Ubuntu之后也能识别出video设备,但是无法通过VLC或者cheese打开,想问下大佬们这是什么问题导致的,是应用层还是脚本的问题。几个打印信息的报错都找过,没能找到解决方法。。。
      在ubuntu中使用v4l-utils查看打印信息如下
      ❯ v4l2-ctl -d /dev/video0 --all
      Driver Info (not using libv4l2):
              Driver name   : uvcvideo
              Card type     : UVC Camera (1f3a:100d): UVC Cam
              Bus info      : usb-0000:02:03.0-1
              Driver version: 5.4.218
              Capabilities  : 0x84A00001
                      Video Capture
                      Metadata Capture
                      Streaming
                      Extended Pix Format
                      Device Capabilities
              Device Caps   : 0x04200001
                      Video Capture
                      Streaming
                      Extended Pix Format
      Priority: 2
      Video input : 0 (Camera 1: ok)
      Format Video Capture:
              Width/Height      : 1280/720
              Pixel Format      : 'MJPG'
              Field             : None
              Bytes per Line    : 0
              Size Image        : 460800
              Colorspace        : sRGB
              Transfer Function : Default (maps to sRGB)
              YCbCr/HSV Encoding: Default (maps to ITU-R 601)
              Quantization      : Default (maps to Full Range)
              Flags             :
      Crop Capability Video Capture:
              Bounds      : Left 0, Top 0, Width 1280, Height 720
              Default     : Left 0, Top 0, Width 1280, Height 720
              Pixel Aspect: 1/1
      Selection: crop_default, Left 0, Top 0, Width 1280, Height 720
      Selection: crop_bounds, Left 0, Top 0, Width 1280, Height 720
      Streaming Parameters Video Capture:
              Capabilities     : timeperframe
              Frames per second: 15.000 (15/1)
              Read buffers     : 0
                           brightness 0x00980900 (int)    : min=0 max=255 step=1 default=127 value=0
                        exposure_auto 0x009a0901 (menu)   : min=0 max=3 default=0 value=0
      VLC 报错日志
      main debug: looking for art finder module matching "any": 2 candidates
      v4l2 debug: opening device '/dev/video0'
      v4l2 error: cannot open device '/dev/video0': Operation not permitted
      main debug: no access_demux modules matched
      main debug: creating access: v4l2:///dev/video0
      main debug:  (path: /dev/video0)
      main debug: looking for access module matching "v4l2": 29 candidates
      main debug: no access modules matched
      Ubuntu dmesg在插入设备时候的信息
      [18491.358318] usb 1-1: new high-speed USB device number 23 using ehci-pci
      [18491.710832] usb 1-1: New USB device found, idVendor=1f3a, idProduct=100d, bcdDevice= 4.09
      [18491.710834] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
      [18491.710834] usb 1-1: Product: 123
      [18491.710835] usb 1-1: Manufacturer: Test
      [18491.710835] usb 1-1: SerialNumber: 20080411
      [18491.754885] uvcvideo: Found UVC 1.00 device 123(1f3a:100d)
      [18496.942618] uvcvideo: Failed to query (GET_INFO) UVC control 2 on unit 1: -110 (exp. 1).
      [18497.056143] uvcvideo: Failed to query (GET_INFO) UVC control 2 on unit 2: -32 (exp. 1).
      [18502.318681] uvcvideo: UVC non compliance - GET_DEF(PROBE) not supported. Enabling workaround.
      [18507.439217] uvcvideo: Failed to query (129) UVC probe control : -110 (exp. 26).
      [18507.439221] uvcvideo: Failed to initialize the device (-5).
      • F
        Flork LV 4 最后由 编辑
        uvc脚本如下
        #!/bin/sh
        # now using this scripts
        # MODULES_DIR="/lib/modules/`uname -r`"
        #insmod $MODULES_DIR/sunxi_usb_udc.ko
        #insmod $MODULES_DIR/sunxi_usbc.ko
        mount -t configfs none /sys/kernel/config
        mkdir /sys/kernel/config/usb_gadget/g1
        echo "0x1f3a" > /sys/kernel/config/usb_gadget/g1/idVendor
        echo "0x100f" > /sys/kernel/config/usb_gadget/g1/idProduct
        mkdir /sys/kernel/config/usb_gadget/g1/strings/0x409
        echo "20080411" > /sys/kernel/config/usb_gadget/g1/strings/0x409/serialnumber
        echo "Test" > /sys/kernel/config/usb_gadget/g1/strings/0x409/manufacturer
        mkdir /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0
        mkdir -p /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streaming/mjpeg/m/720p
        echo 1280 > /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streaming/mjpeg/m/720p/wWidth
        echo 720 > /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streaming/mjpeg/m/720p/wHeight
        echo 333333 > /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streaming/mjpeg/m/720p/dwFrameInterval
        echo 333333 > /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streaming/mjpeg/m/720p/dwDefaultFrameInterval
        echo 442368000 > /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streaming/mjpeg/m/720p/dwMinBitRate
        echo 442368000 > /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streaming/mjpeg/m/720p/dwMaxBitRate
        echo 1843200 > /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streaming/mjpeg/m/720p/dwMaxVideoFrameBufferSize
        mkdir /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streaming/header/h
        ln -s /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streaming/mjpeg/m/ /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streaming/header/h/
        ln -s /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streaming/header/h/ /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streaming/class/fs
        ln -s /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streaming/header/h/ /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streaming/class/hs
        mkdir /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/control/header/h
        ln -s /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/control/header/h/ /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/control/class/fs/
        ln -s /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/control/header/h/ /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/control/class/ss/
        mkdir /sys/kernel/config/usb_gadget/g1/functions/ffs.adb
        mkdir /sys/kernel/config/usb_gadget/g1/configs/c.1
        echo 0xc0 > /sys/kernel/config/usb_gadget/g1/configs/c.1/bmAttributes
        echo 500 > /sys/kernel/config/usb_gadget/g1/configs/c.1/MaxPower
        mkdir /sys/kernel/config/usb_gadget/g1/configs/c.1/strings/0x409
        mkdir /sys/kernel/config/usb_gadget/g1/functions/mass_storage.usb0
        ln -s /sys/kernel/config/usb_gadget/g1/functions/mass_storage.usb0/ /sys/kernel/config/usb_gadget/g1/configs/c.1/mass_storage.usb0
        mkdir /dev/usb-ffs
        mkdir /dev/usb-ffs/adb
        mount -o uid=2000,gid=2000 -t functionfs adb /dev/usb-ffs/adb/
        udc=`ls /sys/class/udc`
        isudc=0
        start(){
            while [ 1 ]
            do
                sleep 1
                otg_role=`cat /sys/devices/platform/soc/usbc0/otg_role`
                if [ "$otg_role" = "usb_device" ]
                then
                    if [ $isudc == 0 ]
                    then
                        echo $udc > /sys/kernel/config/usb_gadget/g1/UDC
                        isudc=1
                    fi
                    isudc=0
                fi
            done
        start &
        echo > /sys/kernel/config/usb_gadget/g1/UDC
        echo 0x100d > /sys/kernel/config/usb_gadget/g1/idProduct
        rm /sys/kernel/config/usb_gadget/g1/configs/c.1/mass_storage.usb0
        rm /sys/kernel/config/usb_gadget/g1/configs/c.1/uvc.usb0
        ln -s /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/ /sys/kernel/config/usb_gadget/g1/configs/c.1/uvc.usb0
        ls /sys/class/udc | xargs echo > /sys/kernel/config/usb_gadget/g1/UDC
        • F
          插入usb后板子的打印
          [  142.870690] android_work: sent uevent USB_STATE=CONNECTED
          [  143.444380] nf_conntrack: default automatic helper assignment has been turned off for security reasons and CT-based  firewall rule not found. Use the iptables CT target to attach helpers instead.
          [  143.698733] configfs-gadget gadget: high-speed config #1: c
          [  143.704992] configfs-gadget gadget: uvc_function_set_alt(0, 0)
          [  143.711516] configfs-gadget gadget: reset UVC Control
          [  143.717185] configfs-gadget gadget: uvc_function_set_alt(1, 0)
          [  143.723808] configfs-gadget gadget: uvc_function_set_alt(1, 0)
          [  143.730450] android_work: sent uevent USB_STATE=CONFIGURED
          [  148.773269] handle_ep0: ep0 setup end
          [  148.816828] handle_ep0: ep0 setup end
          [  148.838899] configfs-gadget gadget: uvc_function_set_alt(1, 0)
          [  153.874769] handle_ep0: ep0 setup end
          [  153.936786] handle_ep0: ep0 setup end
          [  158.963752] handle_ep0: ep0 setup end
          [  159.054766] handle_ep0: ep0 setup end
          [  584.116224] ERR: Operation not supported
          • F
            Flork LV 4 最后由 编辑
            lsusb的输出如下
            ❯ sudo lsusb -v -d 1f3a:100d
            Bus 001 Device 023: ID 1f3a:100d Onda (unverified)
            Device Descriptor:
              bLength                18
              bDescriptorType         1
              bcdUSB               2.00
              bDeviceClass            0 (Defined at Interface level)
              bDeviceSubClass         0
              bDeviceProtocol         0
              bMaxPacketSize0        64
              idVendor           0x1f3a Onda (unverified)
              idProduct          0x100d
              bcdDevice            4.09
              iManufacturer           1 Test
              iProduct                2 123
              iSerial                 3 20080411
              bNumConfigurations      1
              Configuration Descriptor:
                bLength                 9
                bDescriptorType         2
                wTotalLength          175
                bNumInterfaces          2
                bConfigurationValue     1
                iConfiguration          4
                bmAttributes         0xc0
                  Self Powered
                MaxPower              500mA
                Interface Association:
                  bLength                 8
                  bDescriptorType        11
                  bFirstInterface         0
                  bInterfaceCount         2
                  bFunctionClass         14 Video
                  bFunctionSubClass       3 Video Interface Collection
                  bFunctionProtocol       0
                  iFunction               5 UVC Camera
                Interface Descriptor:
                  bLength                 9
                  bDescriptorType         4
                  bInterfaceNumber        0
                  bAlternateSetting       0
                  bNumEndpoints           1
                  bInterfaceClass        14 Video
                  bInterfaceSubClass      1 Video Control
                  bInterfaceProtocol      0
                  iInterface              5 UVC Camera
                  VideoControl Interface Descriptor:
                    bLength                13
                    bDescriptorType        36
                    bDescriptorSubtype      1 (HEADER)
                    bcdUVC               1.00
                    wTotalLength           51
                    dwClockFrequency       48.000000MHz
                    bInCollection           1
                    baInterfaceNr( 0)       1
                    bLength                18
                    bDescriptorType        36
                    bDescriptorSubtype      2 (INPUT_TERMINAL)
                    bTerminalID             1
                    wTerminalType      0x0201 Camera Sensor
                    bAssocTerminal          0
                    iTerminal               0
                    wObjectiveFocalLengthMin      0
                    wObjectiveFocalLengthMax      0
                    wOcularFocalLength            0
                    bControlSize                  3
                    bmControls           0x00000002
                      Auto-Exposure Mode
                    bLength                11
                    bDescriptorType        36
                    bDescriptorSubtype      5 (PROCESSING_UNIT)
                  Warning: Descriptor too short
                    bUnitID                 2
                    bSourceID               1
                    wMaxMultiplier      16384
                    bControlSize            2
                    bmControls     0x00000001
                      Brightness
                    iProcessing             0
                    bmVideoStandards     0x 9
                      None
                      SECAM - 625/50
                    bLength                 9
                    bDescriptorType        36
                    bDescriptorSubtype      3 (OUTPUT_TERMINAL)
                    bTerminalID             3
                    wTerminalType      0x0101 USB Streaming
                    bAssocTerminal          0
                    bSourceID               2
                    iTerminal               0
                  Endpoint Descriptor:
                    bLength                 7
                    bDescriptorType         5
                    bEndpointAddress     0x84  EP 4 IN
                    bmAttributes            3
                      Transfer Type            Interrupt
                      Synch Type               None
                      Usage Type               Data
                    wMaxPacketSize     0x0010  1x 16 bytes
                    bInterval               8
                  bLength                 9
                  bDescriptorType         4
                  bInterfaceNumber        1
                  bAlternateSetting       0
                  bNumEndpoints           0
                  bInterfaceSubClass      2 Video Streaming
                  iInterface              6 Video Streaming
                  VideoStreaming Interface Descriptor:
                    bLength                            14
                    bDescriptorType                    36
                    bDescriptorSubtype                  1 (INPUT_HEADER)
                    bNumFormats                         1
                    wTotalLength                       61
                    bEndPointAddress                  131
                    bmInfo                              0
                    bTerminalLink                       3
                    bStillCaptureMethod                 0
                    bTriggerSupport                     0
                    bTriggerUsage                       0
                    bControlSize                        1
                    bmaControls( 0)                    11
                    bLength                            11
                    bDescriptorType                    36
                    bDescriptorSubtype                  6 (FORMAT_MJPEG)
                    bFormatIndex                        1
                    bNumFrameDescriptors                1
                    bFlags                              0
                      Fixed-size samples: No
                    bDefaultFrameIndex                  1
                    bAspectRatioX                       0
                    bAspectRatioY                       0
                    bmInterlaceFlags                 0x00
                      Interlaced stream or variable: No
                      Fields per frame: 1 fields
                      Field 1 first: No
                      Field pattern: Field 1 only
                      bCopyProtect                      0
                    bLength                            30
                    bDescriptorType                    36
                    bDescriptorSubtype                  7 (FRAME_MJPEG)
                    bFrameIndex                         1
                    bmCapabilities                   0x00
                      Still image unsupported
                    wWidth                           1280
                    wHeight                           720
                    dwMinBitRate                442368000
                    dwMaxBitRate                442368000
                    dwMaxVideoFrameBufferSize     1843200
                    dwDefaultFrameInterval         333333
                    bFrameIntervalType                  1
                    dwFrameInterval( 0)            333333
                    bLength                             6
                    bDescriptorType                    36
                    bDescriptorSubtype                 13 (COLORFORMAT)
                    bColorPrimaries                     1 (BT.709,sRGB)
                    bTransferCharacteristics            1 (BT.709)
                    bMatrixCoefficients                 4 (SMPTE 170M (BT.601))
                  bLength                 9
                  bDescriptorType         4
                  bInterfaceNumber        1
                  bAlternateSetting       1
                  bNumEndpoints           1
                    bLength                 7
                    bDescriptorType         5
                    bEndpointAddress     0x83  EP 3 IN
                    bmAttributes            5
                      Transfer Type            Isochronous
                      Synch Type               Asynchronous
                      Usage Type               Data
                    wMaxPacketSize     0x0400  1x 1024 bytes
                    bInterval               1
            Device Qualifier (for other device speed):
              bLength                10
              bDescriptorType         6
              bcdUSB               2.00
              bDeviceSubClass         0
              bDeviceProtocol         0
              bMaxPacketSize0        64
            Device Status:     0x0001
              Self Powered
              DOT小文哥 LV 8 最后由 编辑
              emmmm 论坛玩T5芯片的人比较少,大家都不熟悉,插不上手😧
              F 1 条回复 最后回复 回复 引用 分享 0
              • F
                Flork LV 4 @xiaowenge 最后由 编辑
                @xiaowenge
                好吧~谢谢
