    全志T113-s3使用ov5640加载insmod vin_v4l2.ko报错
    6
    7
    8702
      shz18877605430 LV 6 最后由 编辑
      全志T113-s3使用ov5640加载insmod vin_v4l2.ko报错,各位大佬救救急,搞了很久了,一直没有眉目。
      配置如下:
      board.dts
      /dts-v1/;
      /memreserve/ 0x41B00000 0x00100000;
      /* DSP used 1MB */
      /*/memreserve/ 0x42000000 0x00100000;*/
      #include "sun8iw20p1.dtsi"
      	model = "sun8iw20";
      	reg_vdd_cpu: vdd-cpu {
      		pwms = <&pwm 3 5000 0>;
      		regulator-name = "vdd_cpu";
      		regulator-ramp-delay = <25>;
      		regulator-always-on;
      		regulator-boot-on;
      	reg_usb1_vbus: usb1-vbus {
      		regulator-name = "usb1-vbus";
      		gpio = <&pio PB 3 GPIO_ACTIVE_HIGH>;
      		enable-active-high;
      &cpu0 {
      	cpu-supply = <&reg_vdd_cpu>;
      &pio {
      	sdc0_pins_a: sdc0@0 {
      				 "PF3", "PF4", "PF5";
      		allwinner,function = "sdc0";
      		allwinner,muxsel = <2>;
      		allwinner,drive = <3>;
      		allwinner,pull = <1>;
      		function = "sdc0";
      		drive-strength = <30>;
      		bias-pull-up;
      		power-source = <3300>;
      	sdc0_pins_b: sdc0@1 {
      		function = "sdc0";
      		bias-pull-up;
      		power-source = <1800>;
      	sdc0_pins_c: sdc0@2 {
      		function = "gpio_in";
      	/* TODO: add jtag pin */
      	sdc0_pins_d: sdc0@3 {
      		pins = "PF2", "PF4";
      		function = "uart0";
      		drive-strength = <10>;
      		bias-pull-up;
      	sdc0_pins_e: sdc0@4 {
      		pins = "PF0", "PF1", "PF3",
      			"PF5";
      		function = "jtag";
      		bias-pull-up;
      	sdc1_pins_a: sdc1@0 {
      		pins = "PG0", "PG1", "PG2",
      		       "PG3", "PG4", "PG5";
      		function = "sdc1";
      		bias-pull-up;
      	sdc1_pins_b: sdc1@1 {
      	sdc2_pins_a: sdc2@0 {
      				 "PC5", "PC6", "PC7";
      		allwinner,function = "sdc2";
      		allwinner,muxsel = <3>;
      		function = "sdc2";
      		bias-pull-up;
      	sdc2_pins_b: sdc2@1 {
      	wlan_pins_a:wlan@0 {
      		pins = "PG11";
      		function = "clk_fanout1";
              function = "uart0";
              bias-pull-up;
      		function = "uart1";
      		bias-pull-up;
      		pins = "PC0", "PC1";
      		function = "uart2";
      		bias-pull-up;
      	uart3_pins_a: uart3_pins@0 {  /* For awol nezha board */
      		pins = "PB6", "PB7";
      		function = "uart3";
      		muxsel = <7>;
      		bias-pull-up;
      	uart3_pins_b: uart3_pins@1 {  /* For awol nezha board */
      	twi0_pins_a: twi0@0 {
      		function = "twi0";
      	twi0_pins_b: twi0@1 {
      	twi1_pins_a: twi1@0 {
      		pins = "PB4", "PB5";
      		function = "twi1";
      	twi1_pins_b: twi1@1 {
          twi2_pins_a: twi2@0 {
              pins = "PE12", "PE13";
              function = "twi2";
          twi2_pins_b: twi2@1 {
      	twi3_pins_a: twi3@0 {
      		pins = "PE6", "PE7";
      		function = "twi3";
      	twi3_pins_b: twi3@1 {
      	dmic_pins_a: dmic@0 {
      		function = "dmic";
      		drive-strength = <20>;
      		bias-disable;
      	dmic_pins_b: dmic@1 {
      		function = "io_disabled";
      		bias-disable;
      	daudio0_pins_a: daudio0@0 {
      		function = "i2s0";
      		bias-disable;
      		bias-disable;
      	daudio1_pins_a: daudio1@0 {
      		function = "i2s1";
      		bias-disable;
      	daudio1_pins_b: daudio1_sleep@0 {
      		bias-disable;
      	daudio2_pins_a: daudio2@0 {
      		pins = "PF6", "PF3", "PF5";
      		function = "i2s2";
      		bias-disable;
      	daudio2_pins_b: daudio2@1 {
      		/* I2S_PIN: DOUT0 */
      		pins = "PF1";
      		function = "i2s2_dout";
      		bias-disable;
      	daudio2_pins_c: daudio2@2 {
      		/* I2S_PIN: DIN0 */
      		pins = "PF0";
      		function = "i2s2_din";
      		bias-disable;
      		pins = "PF6", "PF3", "PF5", "PF1", "PF0";
      		bias-disable;
      	spdif_pins_a: spdif@0 {
      		/* SPDIF_PIN: SPDIF_OUT */
      		pins = "PG18";
      		function = "spdif";
      		bias-disable;
      	spdif_pins_b: spdif_sleep@0 {
      		pins = "PG18";
      		bias-disable;
      	spi0_pins_a: spi0@0 {
      		function = "spi0";
      		muxsel = <2>;
      	spi0_pins_b: spi0@1 {
      		pins = "PC3", "PC7", "PC6";
      		function = "spi0";
      		muxsel = <2>;
      	spi0_pins_c: spi0@2 {
      		muxsel = <0>;
      	spi1_pins_a: spi1@0 {
      		function = "spi1";
      	spi1_pins_b: spi1@1 {
      		function = "spi1";
      	spi1_pins_c: spi1@2 {
      	ledc_pins_a: ledc@0 {
      		pins = "PG13";
      		function = "ledc";
      	ledc_pins_b: ledc@1 {
      		pins = "PG13";
      	pwm0_pin_a: pwm0@0 {
      		pins = "PD16";
      		function = "pwm0";
      		bias-pull-up;
      	pwm0_pin_b: pwm0@1 {
      		pins = "PD16";
      		bias-disable;
      	pwm2_pin_a: pwm2@0 {
      		pins = "PD18";
      		function = "pwm2";
      		bias-pull-up;
      	pwm2_pin_b: pwm2@1 {
      		pins = "PD18";
      		function = "gpio_out";
      	pwm7_pin_a: pwm7@0 {
      		pins = "PD22";
      		function = "pwm7";
      		bias-pull-up;
      	pwm7_pin_b: pwm7@1 {
      		pins = "PD22";
      	s_cir0_pins_a: s_cir@0 {
      		pins = "PB7";
      		function = "ir";
      		bias-pull-up;
      	s_cir0_pins_b: s_cir@1 {
      		pins = "PB7";
      	ir1_pins_a: ir1@0 {
      		pins = "PB0";
      		function = "ir";
      		bias-pull-up;
      	ir1_pins_b: ir1@1 {
      		pins = "PB0";
      &uart0 {
      	pinctrl-0 = <&uart0_pins_a>;
      	pinctrl-1 = <&uart0_pins_b>;
      	status = "disabled";
      &uart1 {
      	pinctrl-0 = <&uart1_pins_a>;
      	pinctrl-1 = <&uart1_pins_b>;
      &uart2 {
      	pinctrl-0 = <&uart2_pins_a>;
      	pinctrl-1 = <&uart2_pins_b>;
      /* for debug */
      &uart3 {
      	pinctrl-0 = <&uart3_pins_a>;
      	pinctrl-1 = <&uart3_pins_b>;
      /* for dsp debug
      &uart3 {
      &soc {
      	card0_boot_para@2 {
      		reg = <0x0 0x2 0x0 0x0>;
      		card_ctrl = <0x0>;
      		card_high_speed = <0x1>;
      		card_line = <0x4>;
      		pinctrl-0 = <&sdc0_pins_a>;
      	card2_boot_para@3 {
      		reg = <0x0 0x3 0x0 0x0>;
      		card_ctrl = <0x2>;
      		card_line = <0x4>;
      		pinctrl-0 = <&sdc2_pins_a>;
      		/*sdc_ex_dly_used = <0x2>;*/
      		sdc_io_1v8 = <0x1>;
      		/*sdc_type = "tm4";*/
      		sdc_ex_dly_used = <2>;
      		/*sdc_tm4_win_th = <8>;*/
      	rfkill: rfkill@0 {
      		chip_en;
      		power_en;
      		pinctrl-0 = <&wlan_pins_a>;
      		pinctrl-names = "default";
      		status        = "okay";
      		wlan: wlan@0 {
      			clock-names = "32k-fanout1";
      			wlan_busnum    = <0x1>;
      			/*interrupt-parent = <&pio>;
      			wakeup-source;
      		bt: bt@0 {
      			/*bt_power_num = <0x01>;*/
      			/*bt_io_vol = <3300000>;*/
      			/*bt_power_vol = <330000>;*/
      			bt_rst_n      = <&pio PG 15 GPIO_ACTIVE_LOW>;
      			status        = "okay";
      	btlpm: btlpm@0 {
      		uart_index  = <0x1>;
      		bt_wake     = <&pio PG 15 GPIO_ACTIVE_HIGH>;
      		bt_hostwake = <&pio PG 14 GPIO_ACTIVE_HIGH>;
      		status      = "okay";
      	addr_mgt: addr_mgt@0 {
      		type_addr_wifi = <0x0>;
      		type_addr_bt   = <0x0>;
      		type_addr_eth  = <0x0>;
      		status         = "okay";
      &sdc2 {
      	non-removable;
      	bus-width = <4>;
      	mmc-ddr-1_8v;
      	mmc-hs200-1_8v;
      	no-sdio;
      	no-sd;
      	ctl-spec-caps = <0x308>;
      	cap-mmc-highspeed;
      	sunxi-power-save-mode;
      	sunxi-dis-signal-vol-sw;
      	mmc-bootpart-noacc;
      	max-frequency = <150000000>;
      	/*emmc io vol 3.3v*/
      	/*emmc io vol 1.8v*/
      &sdc0 {
      	bus-width = <4>;
      	/*non-removable;*/
      	/*broken-cd;*/
      	/*cd-inverted;*/
      	/*data3-detect;*/
      	cd-used-24M;
      	cap-sd-highspeed;
      	/*sd-uhs-sdr50;*/
      	/*sd-uhs-ddr50;*/
      	/*sd-uhs-sdr104;*/
      	no-sdio;
      	no-mmc;
      	/*sunxi-dis-signal-vol-sw;*/
      	ctl-spec-caps = <0x8>;
      &sdc1 {
      	bus-width = <4>;
      	no-mmc;
      	no-sd;
      	cap-sd-highspeed;
      	/*sd-uhs-sdr12*/
      	/*sd-uhs-sdr25;*/
      	/*sd-uhs-sdr50;*/
      	/*sd-uhs-ddr50;*/
      	/*sd-uhs-sdr104;*/
      	/*sunxi-power-save-mode;*/
      	cap-sdio-irq;
      	keep-power-in-suspend;
      	ignore-pm-notify;
      tvd configuration
                             mode,mean enable)
      &tvd {
      	tvd_sw          = <1>;
      	tvd_interface   = <0>;
      	tvd_format      = <0>;
      	tvd_system      = <1>;
      	tvd_row         = <1>;
      	tvd_column      = <1>;
      	tvd_channel0_en = <1>;
      	tvd_channel1_en = <0>;
      	tvd_channel2_en = <0>;
      	tvd_channel3_en = <0>;
      	/*tvd_power0      = "dc1sw"*/
      	/*tvd_power1      = "eldo3"*/
      &tvd0 {
      /* Audio Driver modules */
      &sunxi_rpaf_dsp0 {
      &codec {
      	mic1gain 	= <0x1F>;
      	mic2gain 	= <0x1F>;
      	mic3gain 	= <0x1F>;
      	adcdrc_cfg 	= <0x0>;
      	adchpf_cfg 	= <0x1>;
      	dacdrc_cfg 	= <0x0>;
      	dachpf_cfg 	= <0x0>;
      	/* Volume about */
      	digital_vol 	= <0x00>;
      	lineout_vol 	= <0x1a>;
      	headphonegain	= <0x03>;
      	/* Pa enabled about */
      	pa_level 	= <0x01>;
      	pa_pwr_level 	= <0x01>;
      	pa_msleep_time 	= <0x78>;
      	/* gpio-spk	= <&pio PF 2 GPIO_ACTIVE_HIGH>;*/
      	/* CMA config about */
      	playback_cma	= <128>;
      	capture_cma	= <256>;
      	/* regulator about */
      &sndcodec {
      	hp_detect_case	= <0x00>;
      	jack_enable	= <0x01>;
      &dummy_cpudai {
      &dmic {
      &dmic_codec {
      &sounddmic {
       * tdm_config		0 --> pcm
       *			1 --> i2s
       * mclk_div		0 --> not output
       * pinctrl_used		0 --> I2S/PCM use for internal
      &daudio0 {
      	mclk_div 	= <0x01>;
      	frametype 	= <0x00>;
      	tdm_config 	= <0x01>;
      	sign_extend 	= <0x00>;
      	msb_lsb_first 	= <0x00>;
      	pcm_lrck_period = <0x80>;
      	slot_width_select = <0x20>;
      	pinctrl_used	= <0x0>;
      &sounddaudio0 {
      		/* sound-dai = <&ac108>; */
      &daudio1 {
      	mclk_div 	= <0x01>;
      	frametype 	= <0x00>;
      	pinctrl-0       = <&daudio1_pins_a>;
      	pinctrl-1       = <&daudio1_pins_b>;
      &sounddaudio1 {
      &daudio2 {
      	mclk_div 	= <0x01>;
      	frametype 	= <0x00>;
      	tx_data_mode 	= <0x00>;
      	rx_data_mode 	= <0x00>;
      	asrc_function_en  = <0x00>;
      	pinctrl_used	= <0x1>;
      	daudio_type	= <0x0>;
      &sounddaudio2 {
      &spdif {
      &soundspdif {
      &usbc0 {
      	device_type = "usbc0";
      	usb_port_type = <0x2>;
      	usb_detect_type = <0x1>;
      	usb_detect_mode = <0>;
      	usb_id_gpio = <&pio PB 8 GPIO_ACTIVE_HIGH>;
      	enable-active-high;
      	usb_det_vbus_gpio = <&pio PB 9 GPIO_ACTIVE_LOW>;
      	usb_wakeup_suspend = <0>;
      	usb_serial_unique = <0>;
      	rndis_wceis = <1>;
      &ehci0 {
      &ohci0 {
      &usbc1 {
      	device_type = "usbc1";
          usb_port_type = <0x01>;
      	usb_regulator_io = "nocare";
      &ehci1 {
      &ohci1 {
      &twi0 {
      	clock-frequency = <400000>;
      	pinctrl-0 = <&twi0_pins_a>;
      	pinctrl-1 = <&twi0_pins_b>;
      	eeprom@50 {
      		compatible = "atmel,24c16";
      		reg = <0x50>;
      &twi1 {
      	pinctrl-0 = <&twi1_pins_a>;
      	pinctrl-1 = <&twi1_pins_b>;
      &twi2 {
      	pinctrl-0 = <&twi2_pins_a>;
      	pinctrl-1 = <&twi2_pins_b>;
      	dmas = <&dma 45>, <&dma 45>;
      	dma-names = "tx", "rx";
      	/* pcf8574-usage:
      	 * pin set:
      	 * interrupt set:
      	/*pcf8574: gpio@38 {
      		compatible = "nxp,pcf8574";
      		reg = <0x38>;
      		gpio_base = <2020>;
      		gpio-controller;
      		#gpio-cells = <2>;
      		interrupt-controller;
      		#interrupt-cells = <2>;
      	ctp@38 {
                      compatible = "focaltech,fts";
                      reg = <0x38>;
      				interrupts = <PB 3 IRQ_TYPE_LEVEL_LOW>;
      				focaltech,reset-gpio = <&pio PB 2 GPIO_ACTIVE_HIGH>;
      				focaltech,irq-gpio = <&pio PB 3 IRQ_TYPE_LEVEL_LOW>;
      				focaltech,max-touch-number = <2>;
      				focaltech,display-coords = <0 0 800 480>;
      				focaltech,reg_vdd = <&reg_pio3_3>;
      				focaltech,reg_avdd = <&reg_pio3_3>;
      &twi3 {
      	pinctrl-0 = <&twi3_pins_a>;
      	pinctrl-1 = <&twi3_pins_b>;
      &gmac0 {
      	phy-mode = "rmii";
      	use_ephy25m = <0>;
      	pinctrl-0 = <&gmac_pins_a>;
      	pinctrl-1 = <&gmac_pins_b>;
      	phy-rst = <&pio PE 10 GPIO_ACTIVE_HIGH>;
      &spi0 {
      	pinctrl-1 = <&spi0_pins_c>;
      	spi_slave_mode = <0>;
      	spi0_cs_number = <1>;
          spi0_cs_bitmap = <1>;
      	spi-nand@0 {
      		compatible = "spi-nand";
      		spi-max-frequency=<100000000>;
      		reg = <0x0>;
      		spi-rx-bus-width=<0x04>;
      		spi-tx-bus-width=<0x04>;
      		status="okay";
      	spi-nor@0 {
      		compatible = "jedec,spi-nor";
      		spi-max-frequency=<30000000>;
      		reg = <0x0>;
      		spi-rx-bus-width=<0x01>;
      		spi-tx-bus-width=<0x01>;
      		status="disabled";
      &spi1 {
      	pinctrl-1 = <&spi1_pins_c>;
      	spi_board1@0 {
      		device_type = "spi_board1";
      		compatible = "rohm,dh2228fv";
      		reg = <0x0>;
      		spi-rx-bus-width = <0x4>;
      		spi-tx-bus-width = <0x4>;
      &ledc {
      	pinctrl-0 = <&ledc_pins_a>;
      	pinctrl-1 = <&ledc_pins_b>;
      	led_count = <3>;
      	output_mode = "GRB";
      	reset_ns = <84>;
      	t1h_ns = <800>;
      	t1l_ns = <320>;
      	t0h_ns = <300>;
      	t0l_ns = <800>;
      	wait_time0_ns = <84>;
      	wait_time1_ns = <84>;
      	wait_data_time_ns = <600000>;
      	status	= "okay";
      &keyboard0 {
      	key0 = <210 0x160>;
      	wakeup-source;
      disp init configuration
      set fbX_height to lcd_x)
                         in display.
      &disp {
      	disp_rotation_used		 = <1>;
      	degree0					 = <0>;
      	/*VCC-LCD*/
      	/*VCC-DSI*/
      	/*VCC-PD*/
      ;lcd0 configuration
      ;Pin setting for gpio:
      ;fsync setting, pulse to csi
      &lcd0 {
      	// 800 * 480 RGB LCD
      	lcd_used            = <1>;
      	lcd_backlight       = <50>;
      	lcd_if              = <0>;
      	lcd_x               = <800>;
      	lcd_y               = <480>;
      	lcd_width           = <108>;
      	lcd_height          = <65>;
      	lcd_dclk_freq       = <24>;
      	lcd_pwm_used        = <1>;
      	lcd_pwm_ch          = <9>;
      	lcd_pwm_pol         = <0>;
      	lcd_hbp             = <12>;
      	lcd_ht              = <816>;
      	lcd_hspw            = <4>;
      	lcd_vbp             = <12>;
      	lcd_vt              = <496>;
      	lcd_vspw            = <4>;
      	lcd_lvds_if         = <0>;
      	lcd_lvds_colordepth = <1>;
      	lcd_lvds_mode       = <0>;
      	lcd_frm             = <0>;
      	lcd_gamma_en        = <0>;
      	lcd_bright_curve_en = <0>;
      	lcd_cmap_en         = <0>;
      	deu_mode            = <0>;
      	lcdgamma4iep        = <22>;
      	smart_color         = <90>;
      	pinctrl-0 = <&rgb18_pins_a>;
      	pinctrl-1 = <&rgb18_pins_b>;
      &pwm0 {
      	pinctrl-0 = <&pwm0_pin_a>;
      	pinctrl-1 = <&pwm0_pin_b>;
      &pwm2 {
      	pinctrl-0 = <&pwm2_pin_a>;
      	pinctrl-1 = <&pwm2_pin_b>;
      &pwm7 {
      	pinctrl-0 = <&pwm7_pin_a>;
      	pinctrl-1 = <&pwm7_pin_b>;
      &rtp {
      	allwinner,ts-attached;
      &tpadc {
      	key_cnt = <5>;
      	key1 = <420 115>;
      	key2 = <870 114>;
      	key3 = <1290 119>;
      	key4 = <1630 373>;
      	key5 = <1950 28>;
      &gpadc {
      	channel_num = <1>;
      	channel_select = <0x01>;
      	channel_data_select = <0>;
      	channel_cld_select = <0x01>;
      	channel_chd_select = <0>;
      	channel0_compare_lowdata = <1600000>;
      	key_cnt = <5>;
      	key0_vol = <210>;
      	key0_val = <0x19c>;
      	key1_vol = <410>;
      	key1_val = <0x197>;
      	key2_vol = <590>;
      	key2_val = <158>;
      	key3_vol = <750>;
      	key3_val = <28>;
      	key4_vol = <880>;
      	key4_val = <28>;
      	wakeup-source;
      &s_cir0 {
      	pinctrl-0 = <&s_cir0_pins_a>;
      	pinctrl-1 = <&s_cir0_pins_b>;
      	ir_protocol_used		= <0>;
      	ir_addr_code0			= <0x0>;
      &ir1 {
      	pinctrl-0 = <&ir1_pins_a>;
      	pinctrl-1 = <&ir1_pins_b>;
      &vind0 {
      	csi_top = <378000000>;
      	csi_isp = <327000000>;
      	status = "okay"; /* enable twi and ver1 spi-nand max freq 30M */
      	actuator0: actuator@5809450 {
      		device_type = "actuator0";
      		actuator0_slave = <0x18>;
      		actuator0_af_pwdn = <>;
      	flash0: flash@5809460 {
      		device_type = "flash0";
      		flash0_type = <2>;
      		flash0_en = <>;
      		flash0_mode = <>;
      		flash0_flvdd = "";
      		flash0_flvdd_vol = <>;
      		device_id = <0>;
      	sensor0: sensor@5809470 {
      		device_type = "sensor0";
      		sensor0_mname = "ov5640";
      		sensor0_twi_cci_id = <2>;
      		sensor0_twi_addr = <0x78>;
      		sensor0_mclk_id = <0>;
      		sensor0_pos = "rear";
      		sensor0_isp_used = <0>;
      		sensor0_fmt = <0>;
      		sensor0_stby_mode = <0>;
      		sensor0_vflip = <0>;
      		sensor0_hflip = <0>;
      		sensor0_iovdd-supply = <>;
      		sensor0_iovdd_vol = <>;
      		sensor0_avdd-supply = <>;
      		sensor0_avdd_vol = <>;
      		sensor0_dvdd-supply = <>;
      		sensor0_dvdd_vol = <>;
      		sensor0_power_en = <>;
      		sensor0_reset = <>;
      		sensor0_pwdn = <>;
      		sensor0_sm_vs = <>;
      		flash_handle = <&flash0>;
      		act_handle = <&actuator0>;
      		device_id = <0>;
      		status  = "okay";
      	sensor1:sensor@5809480 {
      		device_type = "sensor1";
      		sensor1_mname = "ov5640";
      		sensor1_twi_cci_id = <1>;
      		sensor1_twi_addr = <0x6c>;
      		sensor1_mclk_id = <1>;
      		sensor1_pos = "front";
      		sensor1_isp_used = <0>;
      		sensor1_fmt = <0>;
      		sensor1_stby_mode = <0>;
      		sensor1_vflip = <0>;
      		sensor1_hflip = <0>;
      		sensor1_iovdd-supply = <>;
      		sensor1_iovdd_vol = <>;
      		sensor1_avdd-supply = <>;
      		sensor1_avdd_vol = <>;
      		sensor1_dvdd-supply = <>;
      		sensor1_dvdd_vol = <>;
      		sensor1_power_en = <>;
      	vinc0:vinc@5809000 {
      		vinc0_csi_sel = <0>;
      		vinc0_mipi_sel = <0xff>;
      		vinc0_isp_sel = <0>;
      		vinc0_isp_tx_ch = <0>;
      		vinc0_tdm_rx_sel = <0xff>;
      		vinc0_rear_sensor_sel = <0>;
      		vinc0_front_sensor_sel = <0>;
      		vinc0_sensor_list = <0>;
      	vinc1:vinc@5809200 {
      		vinc1_csi_sel = <0>;
      		vinc1_mipi_sel = <0xff>;
      		vinc1_isp_sel = <0>;
      		vinc1_isp_tx_ch = <1>;
      		vinc1_tdm_rx_sel = <0xff>;
      		vinc1_rear_sensor_sel = <0>;
      		vinc1_front_sensor_sel = <0>;
      		vinc1_sensor_list = <0>;
      sun8iw20p1.dtsi
       * Allwinner Technology CO., Ltd. sun8iw20p1 platform
       * modify base on juno.dts
      #include <dt-bindings/clock/sun8iw20-ccu.h>
      #include <dt-bindings/clock/sun8iw20-r-ccu.h>
      #include <dt-bindings/clock/sun8iw20-rtc.h>
      #include <dt-bindings/reset/sun8iw20-ccu.h>
      #include <dt-bindings/reset/sun8iw20-r-ccu.h>
      #include <dt-bindings/interrupt-controller/arm-gic.h>
      #include <dt-bindings/gpio/gpio.h>
      #include <dt-bindings/gpio/sun4i-gpio.h>
      #include <dt-bindings/thermal/thermal.h>
      #include <dt-bindings/power/r528-power.h>
      	model = "sun8iw20";
      	compatible = "allwinner,sun8iw20p1";
      	interrupt-parent = <&gic>;
      	#address-cells = <2>;
      	#size-cells = <2>;
      	aliases {
      		serial0 = &uart0;
      		serial1 = &uart1;
      		serial2 = &uart2;
      		serial3 = &uart3;
      		serial4 = &uart4;
      		serial5 = &uart5;
      		spi0 = &spi0;
      		spi1 = &spi1;
      		twi0 = &twi0;
      		twi1 = &twi1;
      		twi2 = &twi2;
      		twi3 = &twi3;
      		mmc0 = &sdc0;
      		mmc2 = &sdc2;
      		pwm = &pwm;
      		pwm0 = &pwm0;
      		pwm1 = &pwm1;
      		pwm2 = &pwm2;
      		pwm3 = &pwm3;
      		pwm4 = &pwm4;
      		pwm5 = &pwm5;
      		pwm6 = &pwm6;
      		pwm7 = &pwm7;
      		ir0 = &s_cir0;
      		ve0 = &ve;
      		tv0 = &tv0;
      		tvd = &tvd;
      		tvd0 = &tvd0;
      		share_space0 = &share_space0;
      	chosen {
      		bootargs = "earlyprintk=sunxi-uart,0x2500000 loglevel=8 initcall_debug=0 console=ttyS0 init=/init";
      		//bootargs = "loglevel=8 initcall_debug=0 console=ttyS0 init=/init";
      		linux,initrd-start = <0x0 0x0>;
      		linux,initrd-end = <0x0 0x0>;
      	firmware {
      		optee {
      			compatible = "linaro,optee-tz";
      			method = "smc";
      	cpus {
      		enable-method = "allwinner,sun8iw20p1";
      		#address-cells = <1>;
      		#size-cells = <0>;
      		cpu0: cpu@0 {
      			device_type = "cpu";
      			compatible = "arm,cortex-a7","arm,armv7";
      			reg = <0x0>;
      			enable-method = "psci";
      			clocks = <&ccu CLK_CPUX>;
      			dynamic-power-coefficient = <156>;
      			cpu-idle-states = <&CPU_SLEEP &CLUSTER_SLEEP>;
      			operating-points-v2 = <&cpu_opp_table>;
      			#cooling-cells = <2>;
      		cpu1: cpu@1 {
      			reg = <0x1>;
      		idle-states {
      			entry-method = "arm,psci";
      			CPU_SLEEP: cpu-sleep {
      				compatible = "arm,idle-state";
      				arm,psci-suspend-param = <0x0010000>;
      				entry-latency-us = <46>;
      				exit-latency-us = <59>;
      				min-residency-us = <3570>;
      				local-timer-stop;
      			CLUSTER_SLEEP: cluster-sleep {
      				arm,psci-suspend-param = <0x1010000>;
      				entry-latency-us = <47>;
      				exit-latency-us = <74>;
      				min-residency-us = <5000>;
      				local-timer-stop;
      	psci {
      		compatible = "arm,psci-1.0";
      		method = "smc";
      	dump_reg: dump_reg@20000 {
      		compatible = "allwinner,sunxi-dump-reg";
      		reg = <0x0 0x00020000 0x0 0x0004>;
      		/* 0x00020000: dump_reg test addr, 0x0004: dump_reg test size */
      	cpu_opp_table: cpu-opp-table {
      		compatible = "allwinner,sun50i-operating-points";
      		nvmem-cells = <&speedbin_efuse>, <&cpubin_efuse>;
      		nvmem-cell-names = "speed", "bin";
      		opp-shared;
      		opp@480000000 {
      			opp-hz = /bits/ 64 <480000000>;
      			clock-latency-ns = <244144>; /* 8 32k periods */
      			opp-microvolt-a0 = <900000>;
      			opp-microvolt-a1 = <900000>;
      			opp-microvolt-a2 = <900000>;
      			opp-microvolt-b0 = <950000>;
      			opp-supported-hw = <0x3>;
      		opp@720000000 {
      			opp-hz = /bits/ 64 <720000000>;
      		opp@912000000 {
      			opp-hz = /bits/ 64 <912000000>;
      			opp-microvolt-a0 = <950000>;
      		opp@1008000000 {
      			opp-hz = /bits/ 64 <1008000000>;
      			opp-microvolt-a0 = <1000000>;
      		opp@1104000000 {
      			opp-hz = /bits/ 64 <1104000000>;
      			opp-microvolt-a0 = <1050000>;
      			opp-microvolt-a1 = <950000>;
      			opp-microvolt-a2 = <950000>;
      		opp@1200000000 {
      			opp-hz = /bits/ 64 <1200000000>;
      			opp-microvolt-a0 = <1100000>;
      			opp-microvolt-a1 = <1000000>;
      			opp-microvolt-a2 = <1000000>;
      			opp-supported-hw = <0x1>;
      	dcxo24M: dcxo24M_clk {
      		#clock-cells = <0>;
      		compatible = "fixed-clock";
      		clock-frequency = <24000000>;
      		clock-output-names = "dcxo24M";
      	rc_16m: rc16m_clk {
      		#clock-cells = <0>;
      		clock-frequency = <16000000>;
      		clock-accuracy = <300000000>;
      		clock-output-names = "rc-16m";
      	ext_32k: ext32k_clk {
      		#clock-cells = <0>;
      		clock-frequency = <32768>;
      		clock-output-names = "ext-32k";
      	dram: dram {
      		compatible = "allwinner,dram";
      		clocks = <&ccu CLK_PLL_DDR0>;
      		clock-names = "pll_ddr";
      	memory@40000000 {
      		device_type = "memory";
      		reg = <0x00000000 0x40000000 0x00000000 0x20000000>;
      	share_space0: share_space@42100000 {
      		#size-cells = <1>;
      		deice_tpye = "share_space0";
      		/* dsp write addr and len */
      		/* arm write addr and len */
      		/* dsp log addr and len */
      		/* reserve */
      		reg = <	0x42100000 0x00001000
      			0x42101000 0x00001000
      			0x42102000 0x0000E000
      			0x00000000 0x00000000>;
      	gic: interrupt-controller@3020000 {
      		compatible = "arm,cortex-a15-gic", "arm,cortex-a9-gic";
      		#interrupt-cells = <3>;
      		#address-cells = <0>;
      		device_type = "gic";
      		reg = <0x0 0x03021000 0 0x1000>, /* GIC Dist */
      		      <0x0 0x03022000 0 0x2000>, /* GIC CPU */
      		      <0x0 0x03024000 0 0x2000>, /* GIC VCPU Control */
      		      <0x0 0x03026000 0 0x2000>; /* GIC VCPU */
      		interrupts = <GIC_PPI 9 0xf04>; /* GIC Maintenence IRQ */
      	timer_arch {
      		compatible = "arm,armv7-timer";
      		interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>,
      			     <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>,
      			     <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>,
      			     <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>;
      		arm,cpu-registers-not-fw-configured;
      		arm,no-tick-in-suspend;
      	pmu {
      		compatible = "arm,cortex-a7-pmu";
      		interrupts = <GIC_SPI 172 4>,
      			     <GIC_SPI 173 4>;
      	power: power-management@ff000000 {
      		compatible = "allwinner,r528-pmu", "syscon", "simple-mfd";
      		reg = <0x0 0x07001000 0x0 0x400>;
      		pd: power-controller {
      			compatible = "allwinner,r528-power-controller";
      			clocks = <&r_ccu CLK_R_PPU>;
      			clock-names = "ppu";
      			resets = <&r_ccu RST_R_PPU>;
      			reset-names = "ppu_rst";
      			#power-domain-cells = <1>;
      			#size-cells = <0>;
      			/* These power domains are grouped by VD_SYS */
      			pd_ve@R528_PD_VE {
      				reg = <R528_PD_VE>;
      	mmu_aw: iommu@2010000 {
      		compatible = "allwinner,sunxi-iommu";
      		reg = <0x0 0x02010000 0x0 0x1000>;
      		interrupts = <GIC_SPI 64 IRQ_TYPE_LEVEL_HIGH>;
      		interrupt-names = "iommu-irq";
      		clocks = <&ccu CLK_BUS_IOMMU>;
      		clock-names = "iommu";
      		#iommu-cells = <2>;
      	reg_pio1_8: pio-18 {
      		regulator-name = "pio-18";
      		regulator-min-microvolt = <1800000>;
      		regulator-max-microvolt = <1800000>;
      	reg_pio3_3: pio-33 {
      		regulator-name = "pio-33";
      	thermal-zones {
      		cpu_thermal_zone: cpu_thermal_zone {
      			polling-delay-passive = <500>;
      			polling-delay = <1000>;
      			thermal-sensors = <&ths 0>;
      			sustainable-power = <589>;
      			cpu_trips: trips {
      				cpu_threshold: trip-point@0 {
      					temperature = <70000>;
      					type = "passive";
      					hysteresis = <0>;
      				cpu_target: trip-point@1 {
      					temperature = <90000>;
      					type = "passive";
      					hysteresis = <0>;
      				cpu_crit: cpu_crit@0 {
      					temperature = <110000>;
      					type = "critical";
      					hysteresis = <0>;
      			cooling-maps {
      				map0 {
      					trip = <&cpu_target>;
      					cooling-device = <&cpu0
      					THERMAL_NO_LIMIT
      					THERMAL_NO_LIMIT>;
      					contribution = <1024>;
      	soc: soc@3000000 {
      		compatible = "simple-bus";
      		#size-cells = <2>;
      		ranges;
      		device_type = "soc";
      		sram_ctrl: sram_ctrl@3000000 {
      			compatible = "allwinner,sram_ctrl";
      			reg = <0x0 0x3000000 0 0x16C>;
      			soc_ver {
      				offset = <0x24>;
      				mask = <0x7>;
      				shift = <0>;
      				ver_a = <0x18590000>;
      				ver_b = <0x18590002>;
      				ver_d = <0x18590003>;
      			soc_id {
      				offset = <0x200>;
      				mask = <0x1>;
      				shift = <22>;
      			soc_bin {
      				offset = <0x0>;
      				mask = <0x3ff>;
      				shift = <0x0>;
      		rtc_ccu: rtc_ccu@7090000 {
      			compatible = "allwinner,sun8iw20-rtc-ccu";
      			device_type = "rtc-ccu";
      			reg = <0x0 0x07090000 0x0 0x320>;  /* The same as rtc */
      			#clock-cells = <1>;
      		ccu: ccu@2001000 {
      			compatible = "allwinner,sun8iw20-ccu";
      			reg = <0x0 0x02001000 0x0 0x1000>;
      			clocks = <&dcxo24M>, <&rtc_ccu CLK_OSC32K>, <&rtc_ccu CLK_IOSC>;
      			clock-names = "hosc", "losc", "iosc";
      			#clock-cells = <1>;
      			#reset-cells = <1>;
      		r_ccu: r_ccu@7010000 {
      			compatible = "allwinner,sun8iw20-r-ccu";
      			reg = <0x0 0x07010000 0x0 0x240>;
      			clocks = <&dcxo24M>, <&rtc_ccu CLK_OSC32K>, <&rtc_ccu CLK_IOSC>,
      				 <&ccu CLK_PLL_PERIPH0>;
      			clock-names = "hosc", "losc", "iosc", "pll-periph0";
      			#clock-cells = <1>;
      			#reset-cells = <1>;
      		rtc: rtc@7090000 {
      			compatible = "allwinner,sun8iw20-rtc";
      			device_type = "rtc";
      			wakeup-source;
      			interrupts = <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&r_ccu CLK_R_AHB_BUS_RTC>, <&rtc_ccu CLK_RTC_1K>, <&rtc_ccu CLK_RTC_SPI>;
      			clock-names = "r-ahb-rtc", "rtc-1k", "rtc-spi";
      			resets = <&r_ccu RST_R_AHB_BUS_RTC>;
      			gpr_cur_pos = <6>;
      		dma:dma-controller@3002000 {
      			compatible = "allwinner,sun8iw20-dma";
      			reg = <0x0 0x03002000 0x0 0x1000>;
      			interrupts = <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_DMA>, <&ccu CLK_MBUS_DMA>;
      			clock-names = "bus", "mbus";
      			dma-channels = <8>;
      			dma-requests = <48>;
      			resets = <&ccu RST_BUS_DMA>;
      			#dma-cells = <1>;
      		soc_timer0: timer@2050000 {
      			compatible = "allwinner,sun4i-a10-timer";
      			device_type = "soc_timer";
      			reg = <0x0 0x02050000 0x0 0xA0>;
      			interrupts = <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&dcxo24M>;
      		wdt: watchdog@20500A0 {
      			compatible = "allwinner,sun6i-a31-wdt";
      			reg = <0x0 0x020500A0 0x0 0x20>;  /* In Timers Spec */
      			interrupts = <GIC_SPI 63 IRQ_TYPE_LEVEL_HIGH>;  /* In GIC Spec */
      		mbus0: mbus-controller@3102000 {
      			compatible = "allwinner,sun8i-mbus";
      			reg = <0x0 0x03102000 0x0 0x1000>;  /* In SDRAM Controller Spec: DRAMC Common Register */
      			#mbus-cells = <1>;
      		pio: pinctrl@2000000 {
      			compatible = "allwinner,sun8iw20-pinctrl";
      			reg = <0x0 0x02000000 0x0 0x500>;
      			interrupts = <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>,  /* AW1859_GIC_Spec: GPIOB: 101-32=69 */
      				     <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>,
      				     <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>,
      				     <GIC_SPI 75 IRQ_TYPE_LEVEL_HIGH>,
      				     <GIC_SPI 77 IRQ_TYPE_LEVEL_HIGH>,
      				     <GIC_SPI 79 IRQ_TYPE_LEVEL_HIGH>;
      			device_type = "pio";
      			clocks = <&ccu CLK_APB0>, <&dcxo24M>, <&rtc_ccu CLK_OSC32K>;
      			clock-names = "apb", "hosc", "losc";
      			gpio-controller;
      			#gpio-cells = <3>;
      			#size-cells = <0>;
      			vcc-pf-supply = <&reg_pio1_8>;
      			vcc-pfo-supply = <&reg_pio3_3>;
      			test_pins_a: test_pins@0 {
      				allwinner,pins = "PB0", "PB1";
      				allwinner,function = "test";
      				allwinner,muxsel = <0x9>;
      				allwinner,drive = <1>;
      			test_pins_b: test_pins@1 {
      				allwinner,muxsel = <0xF>;
      			csi_mclk0_pins_a: csi_mclk0@0 {
      				pins = "PE3";
      				function = "csi0";
      			csi_mclk0_pins_b: csi_mclk0@1 {
      				pins = "PE3";
      			csi0_pins_a: csi0@0 {
      				pins = "PE2", "PE0", "PE1", "PE4", "PE5",
      						 "PE6", "PE7", "PE8", "PE9", "PE10", "PE11";
      				function = "ncsi0";
      			csi0_pins_b: csi0@1 {
      			lvds0_pins_a: lvds0@0 {
      				pins  = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9";
      				function = "lvds0";
      				bias-disable;
      			lvds0_pins_b: lvds0@1 {
      				bias-disable;
      			rgb24_pins_a: rgb24@0 {
      				pins = "PB2", "PB3", "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", \
      					"PB4", "PB5", "PD6", "PD7", "PD8", "PD9", "PD10", "PD11", \
      					"PB6", "PB7", "PD12", "PD13", "PD14", "PD15", "PD16", "PD17", \
      				function = "lcd0";
      				bias-disable;
      			rgb24_pins_b: rgb24@1 {
      				bias-disable;
      			rgb18_pins_a: rgb18@0 {
      				pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", \
      				function = "lcd0";
      				bias-disable;
      			rgb18_pins_b: rgb18@1 {
      				bias-disable;
      			dsi2lane_pins_a: dsi2lane@0 {
      				pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5";
      				function = "dsi";
      				bias-disable;
      			dsi2lane_pins_b: dsi2lane@1 {
      				bias-disable;
      			dsi4lane_pins_a: dsi4lane@0 {
      				function = "dsi";
      				bias-disable;
      			dsi4lane_pins_b: dsi4lane@1 {
      				bias-disable;
      		pinctrl_test: pinctrl_test@0 {
      			reg = <0x0 0x0 0x0 0x0>;
      			compatible = "allwinner,sunxi-pinctrl-test";
      			device_type = "pinctrl-test";
      			/* For pin state selecting test */
      			pinctrl-0 = <&test_pins_a>;
      			pinctrl-1 = <&test_pins_b>;
      			/* For pin basic_function/irq test */
      			test-gpios = <&pio PB 0 GPIO_ACTIVE_LOW>;
      			interrupts = <PB 1 IRQ_TYPE_LEVEL_HIGH>;
      		uart0: uart@2500000 {
      			device_type = "uart0";
      			reg = <0x0 0x02500000 0x0 0x400>;
      			interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>;
      			sunxi,uart-fifosize = <64>;
      			clocks = <&ccu CLK_BUS_UART0>;
      			clock-names = "uart0";
      			uart0_port = <0>;
      			uart0_type = <2>;
      		uart1: uart@2500400 {
      			device_type = "uart1";
      			reg = <0x0 0x02500400 0x0 0x400>;
      			sunxi,uart-fifosize = <256>;
      			clocks = <&ccu CLK_BUS_UART1>;
      			clock-names = "uart1";
      			uart1_port = <1>;
      			uart1_type = <4>;
      		uart2: uart@2500800 {
      			device_type = "uart2";
      			reg = <0x0 0x02500800 0x0 0x400>;
      			interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_UART2>;
      			clock-names = "uart2";
      			resets = <&ccu RST_BUS_UART2>;
      			uart2_port = <2>;
      			uart2_type = <4>;
      		uart3: uart@2500c00 {
      			device_type = "uart3";
      			reg = <0x0 0x02500c00 0x0 0x400>;
      			interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_UART3>;
      			clock-names = "uart3";
      			resets = <&ccu RST_BUS_UART3>;
      			uart3_port = <3>;
      			uart3_type = <4>;
      		uart4: uart@2501000 {
      			device_type = "uart4";
      			reg = <0x0 0x02501000 0x0 0x400>;
      			interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_UART4>;
      			clock-names = "uart4";
      			resets = <&ccu RST_BUS_UART4>;
      			uart4_port = <4>;
      			uart4_type = <2>;
      		uart5: uart@2501400 {
      			device_type = "uart5";
      			reg = <0x0 0x02501400 0x0 0x400>;
      			interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_UART5>;
      			clock-names = "uart5";
      			resets = <&ccu RST_BUS_UART5>;
      			uart5_port = <5>;
      			uart5_type = <2>;
      		cryptoengine: ce@03040000 {
      			compatible = "allwinner,sunxi-ce";
      			device_name = "ce";
      			reg = <0x0 0x03040000 0x0 0xa0>, /* non-secure space */
      			      <0x0 0x03040800 0x0 0xa0>; /* secure space */
      			interrupts = <GIC_SPI 52 IRQ_TYPE_EDGE_RISING>, /*non-secure*/
      				   <GIC_SPI 53 IRQ_TYPE_EDGE_RISING>; /* secure*/
      			clock-frequency = <400000000>; /* 400MHz */
      			clocks = <&ccu CLK_BUS_CE>, <&ccu CLK_CE>, <&ccu CLK_MBUS_CE>,
      					<&ccu CLK_PLL_PERIPH0_2X>;
      			clock-names = "bus_ce", "ce_clk", "mbus_ce", "pll_periph0_2x";
      			resets = <&ccu RST_BUS_CE>;
      		gmac0: eth@4500000 {
      			compatible = "allwinner,sunxi-gmac";
      			reg = <0x0 0x04500000 0x0 0x10000>,
      			      <0x0 0x03000030 0x0 0x4>;
      			interrupts = <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>;
      			interrupt-names = "gmacirq";
      			clocks = <&ccu CLK_BUS_EMAC0>, <&ccu CLK_EMAC0_25M>;
      			clock-names = "gmac", "ephy";
      			resets = <&ccu RST_BUS_EMAC0>;
      			device_type = "gmac0";
      			gmac-power0;
      			gmac-power1;
      			gmac-power2;
      		sdc2: sdmmc@4022000 {
      			device_type = "sdc2";
      			interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>;
      				 <&ccu CLK_PLL_PERIPH0_2X>,
      				 <&ccu CLK_MMC2>,
      				 <&ccu CLK_BUS_MMC2>;
      			resets = <&ccu RST_BUS_MMC2>;
      			reset-names = "rst";
      			pinctrl-1 = <&sdc2_pins_b>;
      			bus-width = <4>;
      			req-page-count = <2>;
      			cap-mmc-highspeed;
      			cap-cmd23;
      			mmc-cache-ctrl;
      			non-removable;
      			/*max-frequency = <200000000>;*/
      			max-frequency = <50000000>;
      			cap-erase;
      			mmc-high-capacity-erase-size;
      			no-sdio;
      			no-sd;
      			/*-- speed mode --*/
      			/*sm0: DS26_SDR12*/
      			/*sm1: HSSDR52_SDR25*/
      			/*sm2: HSDDR52_DDR50*/
      			/*sm3: HS200_SDR104*/
      			/*sm4: HS400*/
      			/*-- frequency point --*/
      			/*f0: CLK_400K*/
      			/*f1: CLK_25M*/
      			/*f2: CLK_50M*/
      			/*f3: CLK_100M*/
      			/*f4: CLK_150M*/
      			/*f5: CLK_200M*/
      			sdc_tm4_sm0_freq0 = <0>;
      			sdc_tm4_sm0_freq1 = <0>;
      			sdc_tm4_sm1_freq1 = <0>;
      			sdc_tm4_sm2_freq1 = <0>;
      			sdc_tm4_sm4_freq0_cmd = <0>;
      			sdc_tm4_sm4_freq1_cmd = <0>;
      			/*vmmc-supply = <&reg_3p3v>;*/
      			/*vqmc-supply = <&reg_3p3v>;*/
      			/*vdmc-supply = <&reg_3p3v>;*/
      			/*vmmc = "vcc-card";*/
      			/*vqmc = "";*/
      			/*vdmc = "";*/
      		sdc0: sdmmc@4020000 {
      			device_type = "sdc0";
      			reg = <0x0 0x04020000 0x0 0x1000>;
      			interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>;
      				 <&ccu CLK_MMC0>,
      				 <&ccu CLK_BUS_MMC0>;
      			resets = <&ccu RST_BUS_MMC0>;
      			pinctrl-names = "default","mmc_1v8","sleep","uart_jtag";
      			pinctrl-1 = <&sdc0_pins_b>;
      			pinctrl-2 = <&sdc0_pins_c>;
      			pinctrl-3 = <&sdc0_pins_d &sdc0_pins_e>;
      			bus-width = <4>;
      			/*non-removable;*/
      			/*broken-cd;*/
      			/*cd-inverted*/
      			/*cd-gpios = <&pio PF 6 GPIO_ACTIVE_LOW>;*/
      			/* vmmc-supply = <&reg_3p3v>;*/
      			/* vqmc-supply = <&reg_3p3v>;*/
      			/* vdmc-supply = <&reg_3p3v>;*/
      			/*vqmc = "";*/
      			/*vdmc = "";*/
      			cap-sd-highspeed;
      			cap-wait-while-busy;
      			no-sdio;
      			no-mmc;
      			/*sd-uhs-sdr50;*/
      			/*sd-uhs-ddr50;*/
      			/*cap-sdio-irq;*/
      			/*keep-power-in-suspend;*/
      			/*ignore-pm-notify;*/
      			/*sunxi-dly-400k = <1 0 0 0>; */
      			/*sunxi-dly-26M  = <1 0 0 0>;*/
      			/*sunxi-dly-52M  = <1 0 0 0>;*/
      			/*sunxi-dly-52M-ddr4  = <1 0 0 0>;*/
      			/*sunxi-dly-52M-ddr8  = <1 0 0 0>;*/
      			/*sunxi-dly-104M  = <1 0 0 0>;*/
      			/*sunxi-dly-208M  = <1 0 0 0>;*/
      			/*sunxi-dly-104M-ddr  = <1 0 0 0>;*/
      			/*sunxi-dly-208M-ddr  = <1 0 0 0>;*/
      		sdc1: sdmmc@4021000 {
      			device_type = "sdc1";
      			reg = <0x0 0x04021000 0x0 0x1000>;
      			interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>;
      				 <&ccu CLK_MMC1>,
      				 <&ccu CLK_BUS_MMC1>;
      			resets = <&ccu RST_BUS_MMC1>;
      			pinctrl-0 = <&sdc1_pins_a>;
      			pinctrl-1 = <&sdc1_pins_b>;
      			bus-width = <4>;
      			/*broken-cd;*/
      			/*cd-inverted*/
      			/*cd-gpios = <&pio PG 6 6 1 2 0>;*/
      			/*vqmc = "";*/
      			/*vdmc = "";*/
      			cap-sd-highspeed;
      			no-mmc;
      			/*sd-uhs-sdr50;*/
      			/*sd-uhs-ddr50;*/
      			/*sd-uhs-sdr104;*/
      			/*cap-sdio-irq;*/
      			/*sunxi-dly-400k = <1 0 0 0 0>; */
      			/*sunxi-dly-26M  = <1 0 0 0 0>;*/
      			/*sunxi-dly-52M  = <1 0 0 0 0>;*/
      			sunxi-dly-52M-ddr4  = <1 0 0 0 2>;
      			/*sunxi-dly-52M-ddr8  = <1 0 0 0 0>;*/
      			sunxi-dly-104M  = <1 0 0 0 1>;
      			/*sunxi-dly-208M  = <1 1 0 0 0>;*/
      			sunxi-dly-208M  = <1 0 0 0 1>;
      			/*sunxi-dly-104M-ddr  = <1 0 0 0 0>;*/
      			/*sunxi-dly-208M-ddr  = <1 0 0 0 0>;*/
      		tpadc: tpadc@2009c00 {
      			compatible = "allwinner,tp_key";
      			reg = <0x0 0x02009c00 0x0 0x400>;
      			interrupts = <GIC_SPI 78 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_TPADC>, <&ccu CLK_BUS_TPADC>;
      			clock-names = "mod", "bus";
      			clock-frequency = <1000000>;
      			resets = <&ccu RST_BUS_TPADC>;
      		rtp:rtp@2009c00 {
      			compatible = "allwinner,sun8i-ts";
      			interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>;
      		spi0: spi@4025000 {
      			#size-cells = <0>;
      			compatible = "allwinner,sun8i-spi";
      			device_type = "spi0";
      			reg = <0x0 0x04025000 0x0 0x1000>;
      			interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_PLL_PERIPH0>, <&ccu CLK_SPI0>, <&ccu CLK_BUS_SPI0>;
      			clock-names = "pll", "mod", "bus";
      			resets = <&ccu RST_BUS_SPI0>;
      			dmas = <&dma 22>, <&dma 22>;
      		spi1: spi@4026000 {
      			#size-cells = <0>;
      			device_type = "spi1";
      			reg = <0x0 0x04026000 0x0 0x1000>;
      			interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_PLL_PERIPH0>, <&ccu CLK_SPI1>, <&ccu CLK_BUS_SPI1>;
      			resets = <&ccu RST_BUS_SPI1>;
      			spi1_cs_number = <1>;
      			spi1_cs_bitmap = <1>;
      			dmas = <&dma 23>, <&dma 23>;
      		ve: ve@1c0e000 {
      			    compatible = "allwinner,sunxi-cedar-ve";
      			    reg = <0x0 0x01c0e000 0x0 0x1000>,
      				<0x0 0x03000000 0x0 0x10>,
      				<0x0 0x03001000 0x0 0x1000>;
      			    interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>;
      			    clocks = <&ccu CLK_BUS_VE>, <&ccu CLK_VE>, <&ccu CLK_MBUS_VE>;
      			    clock-names = "bus_ve", "ve", "mbus_ve";
      			    resets = <&ccu RST_BUS_VE>;
      			    power-domains = <&pd R528_PD_VE>;
      			    iommus = <&mmu_aw 0 1>;
      		twi0: twi@2502000{
      			#size-cells = <0>;
      			compatible = "allwinner,sun8i-twi";
      			device_type = "twi0";
      			reg = <0x0 0x02502000 0x0 0x400>;
      			interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_I2C0>;
      			resets = <&ccu RST_BUS_I2C0>;
      			clock-names = "bus";
      		twi1: twi@2502400{
      			#size-cells = <0>;
      			device_type = "twi1";
      			reg = <0x0 0x02502400 0x0 0x400>;
      			interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_I2C1>;
      			resets = <&ccu RST_BUS_I2C1>;
      			clock-frequency = <200000>;
      		twi2: twi@2502800{
      			#size-cells = <0>;
      			device_type = "twi2";
      			reg = <0x0 0x02502800 0x0 0x400>;
      			interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_I2C2>;
      			resets = <&ccu RST_BUS_I2C2>;
      			clock-frequency = <100000>;
      		twi3: twi@2502c00{
      			#size-cells = <0>;
      			device_type = "twi3";
      			reg = <0x0 0x02502c00 0x0 0x400>;
      			interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_I2C3>;
      			resets = <&ccu RST_BUS_I2C3>;
      		ledc: ledc@2008000 {
      			#size-cells = <0>;
      			interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>;
      			interrupt-names = "ledcirq";
      			dmas = <&dma 42>, <&dma 42>;
      			dma-names = "rx", "tx";
      			resets = <&ccu RST_BUS_LEDC>;
      			reset-names = "ledc_reset";
      			status = "disable";
      		pwm: pwm@2000c00 {
      			#pwm-cells = <0x3>;
      			compatible = "allwinner,sunxi-pwm";
      			reg = <0x0 0x02000c00 0x0 0x400>;
      			clocks = <&ccu CLK_BUS_PWM>;
      			resets = <&ccu RST_BUS_PWM>;
      			pwm-number = <8>;
      			pwm-base = <0x0>;
      			sunxi-pwms = <&pwm0>, <&pwm1>, <&pwm2>, <&pwm3>, <&pwm4>,
      				<&pwm5>, <&pwm6>, <&pwm7>;
      		pwm0: pwm0@2000c10 {
      			compatible = "allwinner,sunxi-pwm0";
      			reg = <0x0 0x02000c10 0x0 0x4>;
      			reg_base = <0x02000c00>;
      		pwm1: pwm1@2000c11 {
      			compatible = "allwinner,sunxi-pwm1";
      			reg = <0x0 0x02000c11 0x0 0x4>;
      		pwm2: pwm2@2000c12 {
      			compatible = "allwinner,sunxi-pwm2";
      			reg = <0x0 0x02000c12 0x0 0x4>;
      		pwm3: pwm3@2000c13 {
      			compatible = "allwinner,sunxi-pwm3";
      			reg = <0x0 0x02000c13 0x0 0x4>;
      		pwm4: pwm4@2000c14 {
      			compatible = "allwinner,sunxi-pwm4";
      			reg = <0x0 0x02000c14 0x0 0x4>;
      		pwm5: pwm5@2000c15 {
      			compatible = "allwinner,sunxi-pwm5";
      			reg = <0x0 0x02000c15 0x0 0x4>;
      		pwm6: pwm6@2000c16 {
      			compatible = "allwinner,sunxi-pwm6";
      			reg = <0x0 0x02000c16 0x0 0x4>;
      		pwm7: pwm7@2000c17 {
      			compatible = "allwinner,sunxi-pwm7";
      			reg = <0x0 0x02000c17 0x0 0x4>;
      		lcd_fb0: lcd_fb0@0 {
      			compatible = "allwinner,sunxi-lcd_fb0";
      			pinctrl-names = "active","sleep";
      		keyboard0: keyboard@2009800 {
      			compatible = "allwinner,keyboard_1350mv";
      			reg = <0x0 0x02009800 0x0 0x400>;
      			interrupts = <GIC_SPI 61 IRQ_TYPE_EDGE_RISING>;
      			clocks = <&ccu CLK_BUS_LRADC>;
      			clock-names = "mclk";
      			resets = <&ccu RST_BUS_LRADC>;
      			key_cnt = <5>;
      			key0 = <210 115>;
      			key1 = <410 114>;
      			key2 = <590 139>;
      			key3 = <750 28>;
      			key4 = <880 172>;
      			wakeup-source;
      		sid@3006000 {
      			compatible = "allwinner,sun8iw20p1-sid", "allwinner,sunxi-sid";
      			reg = <0x0 0x03006000 0 0x1000>;
      			#size-cells = <1>;
      			secure_status {
      				reg = <0x0 0>;
      				offset = <0xa0>;
      				size = <0x4>;
      			chipid {
      				reg = <0x0 0>;
      				offset = <0x200>;
      				size = <0x10>;
      			rotpk {
      				reg = <0x0 0>;
      				offset = <0x140>;
      				size = <0x4>;
      			speedbin_efuse: speedbin@00 {
      				reg = <0x00 4>;
      			cpubin_efuse: cpubin@28 {
      				reg = <0x28 4>;
      			ths_calib: calib@14 {
      				reg = <0x14 8>;
      		gpadc: gpadc@2009000 {
      			compatible = "allwinner,sunxi-gpadc";
      			reg = <0x0 0x02009000 0x0 0x400>;
      			interrupts = <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_GPADC>;
      			resets = <&ccu RST_BUS_GPADC>;
      		vind0: vind@5800800 {
      			#size-cells = <2>;
      			ranges;
      			device_id = <0>;
      			csi_top = <336000000>;
      				<0x0 0x05800000 0x0 0x800>;
      			clocks = <&ccu CLK_CSI_TOP>, <&ccu CLK_PLL_VIDEO1_2X>,
      				<&ccu CLK_CSI0_MCLK>, <&dcxo24M>, <&ccu CLK_PLL_VIDEO1>,
      				<&ccu CLK_BUS_CSI>, <&ccu CLK_MBUS_CSI>;
      					"csi_bus", "csi_mbus";
      			resets = <&ccu RST_BUS_CSI>;
      			reset-names = "csi_ret";
      			pinctrl-names = "mclk0-default", "mclk0-sleep";
      			pinctrl-0 = <&csi_mclk0_pins_a>;
      			pinctrl-1 = <&csi_mclk0_pins_b>;
      			csi0: csi@5801000{
      				reg = <0x0 0x05801000 0x0 0x1000>;
      				interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>;
      				pinctrl-0 = <&csi0_pins_a>;
      				pinctrl-1 = <&csi0_pins_b>;
      				device_id = <0>;
      				iommus = <&mmu_aw 1 1>;
      			isp0: isp@5809410 {
      				reg = <0x0 0x05809410 0x0 0x10>;
      				device_id = <0xfe>;
      			isp1: isp@5809420 {
      				reg = <0x0 0x05809420 0x0 0x10>;
      				device_id = <0xff>;
      			scaler0: scaler@5809430 {
      				reg = <0x0 0x05809430 0x0 0x10>;
      				device_id = <0xfe>;
      			scaler1: scaler@5809440 {
      				reg = <0x0 0x05809440 0x0 0x10>;
      				device_id = <0xff>;
      				reg = <0x0 0x05809450 0x0 0x10>;
      				reg = <0x0 0x05809460 0x0 0x10>;
      				flash0_type = <2>;
      				flash0_en = <>;
      				flash0_mode = <>;
      				flash0_flvdd = "";
      				device_id = <0>;
      				sensor0_fmt = <0>;
      				sensor0_reset = <&pio PE 9 GPIO_ACTIVE_LOW>;
      				sensor0_pwdn = <&pio PE 8 GPIO_ACTIVE_LOW>;
      				sensor0_sm_vs = <>;
      				device_id = <0>;
      			sensor1: sensor@5809480 {
      				reg = <0x0 0x05809480 0x0 0x10>;
      				sensor1_mname = "ov5647";
      				sensor1_twi_cci_id = <3>;
      				sensor1_fmt = <0>;
      				sensor1_sm_vs = <>;
      				flash_handle = <>;
      				act_handle = <>;
      				device_id = <1>;
      			vinc0: vinc@5809000 {
      				device_type = "vinc0";
      				interrupts = <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>;
      				device_id = <0>;
      			vinc1: vinc@5809200 {
      				device_type = "vinc1";
      				reg = <0x0 0x05809200 0x0 0x200>;
      				interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>;
      				vinc1_isp_sel = <1>;
      				device_id = <1>;
      		s_cir0: s_cir@7040000 {
      			compatible = "allwinner,s_cir";
      			reg = <0x0 0x07040000 0x0 0x400>;
      			interrupts = <GIC_SPI 151 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&r_ccu CLK_R_APB0_BUS_IRRX>, <&dcxo24M>, <&r_ccu CLK_R_APB0_IRRX>;
      			clock-names = "bus", "pclk", "mclk";
      			resets = <&r_ccu RST_R_APB0_BUS_IRRX>;
      		ir1: ir@2003000 {
      			compatible = "allwinner,irtx";
      			reg = <0x0 0x02003000 0x0 0x400>;
      			interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_IR_TX>, <&dcxo24M>, <&ccu CLK_IR_TX>;
      			resets = <&ccu RST_BUS_IR_TX>;
      		di: deinterlace@5400000 {
      			compatible = "allwinner,sunxi-deinterlace";
      			reg = <0x0 0x05400000 0x0 0x0000ffff>;
      			interrupts = <GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_DI>,
      				 <&ccu CLK_BUS_DI>,
      			clock-names = "clk_di",
      				      "pll_periph",
      				      "clk_bus_di";
      			resets = <&ccu RST_BUS_DI>;
      			reset-names = "rst_bus_di";
      			assigned-clocks = <&ccu CLK_DI>;
      			assigned-clock-parents = <&ccu CLK_PLL_PERIPH0_2X>;
      			assigned-clock-rates = <300000000>;
      			iommus = <&mmu_aw 4 1>;
      		g2d: g2d@5410000 {
      			compatible = "allwinner,sunxi-g2d";
      			reg = <0x0 0x05410000 0x0 0x3ffff>;
      			interrupts = <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_G2D>, <&ccu CLK_G2D>, <&ccu CLK_MBUS_G2D>;
      			clock-names = "bus", "g2d", "mbus_g2d";
      			resets = <&ccu RST_BUS_G2D>;
      			iommus = <&mmu_aw 3 1>;
      		disp: disp@5000000 {
      			compatible = "allwinner,sunxi-disp";
      			reg = <0x0 0x05000000 0x0 0x3fffff>,	/* de0 */
      			      <0x0 0x05460000 0x0 0xfff>,	/*display_if_top*/
      			      <0x0 0x05461000 0x0 0xfff>,	/* tcon-lcd0 */
      			      <0x0 0x05470000 0x0 0xfff>,	/* tcon-tv */
      			      <0x0 0x05450000 0x0 0x1fff>;	/* dsi0*/
      			interrupts = <GIC_SPI 90 IRQ_TYPE_LEVEL_HIGH>,/*tcon-lcd0*/
      				     <GIC_SPI 91 IRQ_TYPE_LEVEL_HIGH>,/*tcon-tv */
      				     <GIC_SPI 92 IRQ_TYPE_LEVEL_HIGH>;/*dsi*/
      			clocks = <&ccu CLK_DE0>,
      				 <&ccu CLK_DE0>,
      				 <&ccu CLK_BUS_DE0>,
      				 <&ccu CLK_BUS_DE0>,
      				 <&ccu CLK_BUS_DPSS_TOP0>,
      				 <&ccu CLK_MIPI_DSI>,
      				 <&ccu CLK_BUS_MIPI_DSI>,
      				 <&ccu CLK_TCON_LCD0>,
      				 <&ccu CLK_TCON_TV>,
      				 <&ccu CLK_BUS_TCON_LCD0>,
      				 <&ccu CLK_BUS_TCON_TV>,
      				 <&ccu CLK_BUS_MIPI_DSI>;
      			clock-names = "clk_de0",
      					"clk_de1",
      					"clk_bus_de0",
      					"clk_bus_de1",
      					"clk_bus_dpss_top0",
      					"clk_bus_dpss_top1",
      					"clk_mipi_dsi0",
      					"clk_bus_mipi_dsi0",
      					"clk_tcon0",
      					"clk_tcon1",/*tcon-tv actually*/
      					"clk_bus_tcon0",
      					"clk_bus_tcon1",/*tcon-tv actually*/
      					"clk_mipi_dsi0",
      					"clk_bus_mipi_dsi0";
      			resets = <&ccu RST_BUS_DE0>,
      				 <&ccu RST_BUS_DE0>,
      				 <&ccu RST_BUS_DPSS_TOP0>,
      				 <&ccu RST_BUS_MIPI_DSI>,
      				 <&ccu RST_BUS_TCON_LCD0>,
      				 <&ccu RST_BUS_TCON_TV>,
      				 <&ccu RST_BUS_LVDS0>;
      			reset-names = "rst_bus_de0",
      					"rst_bus_de1",
      					"rst_bus_dpss_top0",
      					"rst_bus_dpss_top1",
      					"rst_bus_mipi_dsi0",
      					"rst_bus_tcon0",
      					"rst_bus_tcon1",
      					"rst_bus_lvds0";
      			assigned-clocks = <&ccu CLK_DE0>,
      			<&ccu CLK_TCON_TV>;
      			assigned-clock-parents = <&ccu CLK_PLL_PERIPH0_2X>,
      			<&ccu CLK_PLL_VIDEO0_4X>,
      			<&ccu CLK_PLL_VIDEO1_4X>;
      			assigned-clock-rates = <300000000>,
      			<150000000>,
      			<0>,
      			<0>;
      			boot_disp = <0>;
      			boot_disp1 = <0>;
      			boot_disp2 = <0>;
      			fb_base = <0>;
      			iommus = <&mmu_aw 2 0>;
      		lcd0: lcd0@5461000 {
      			compatible = "allwinner,sunxi-lcd0";
      			reg = <0x0 0x05461000 0x0 0xfff>;
      		tv0: tv0@5600000 {
      			compatible = "allwinner,sunxi-tv";
      			reg = <0x0 0x05600000 0x0 0x3fff>,
      				<0x0 0x05604000 0x0 0x3fff>;
      			clocks = <&ccu CLK_BUS_TVE_TOP>,
      				 <&ccu CLK_TVE>,
      				 <&ccu CLK_BUS_TVE>;
      			clock-names = "clk_bus_tve_top",
      				      "clk_tve",
      				      "clk_bus_tve";
      			resets = <&ccu RST_BUS_TVE_TOP>,
      				 <&ccu RST_BUS_TVE>;
      			reset-names = "rst_bus_tve_top", "rst_bus_tve";
      			device_type = "tv0";
      		hwspinlock: hwspinlock@0x3005000 {
      			compatible = "allwinner,sunxi-hwspinlock";
      			reg = <0x0 0x3005000 0x0 0x1000>;
      			#hwlock-cells = <1>;
      			clocks = <&ccu CLK_BUS_SPINLOCK>;
      			clock-names = "clk_hwspinlock_bus";
      			resets = <&ccu RST_BUS_SPINLOCK>;
      			num-locks = <32>;
      		/* old msgbox in dts
      		msgbox: msgbox@3003000 {
      			compatible = "sunxi,msgbox-amp";
      			reg = <0x0 0x03003000 0x0 0x1000>,
      			      <0x0 0x01701000 0x0 0x1000>,
      			      <0x0 0x0601f000 0x0 0x1000>;
      			interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>,
      					<GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>,
      					<GIC_SPI 130 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_MSGBOX0>;
      			rpmsg_id = "sunxi,dsp-msgbox","sunxi,dsp-power-msgbox";
      			resets = <&ccu RST_BUS_MSGBOX0>;
      			msgbox_amp_counts = <3>;
      			msgbox_amp_local = <0>;
      			rpmsg_amp_remote-0 = <1>;
      			rpmsg_read_channel-0 = <1>;
      			rpmsg_write_channel-0 = <1>;
      			rpmsg_amp_remote-1 = <1>;
      			rpmsg_read_channel-1 = <0>;
      			rpmsg_write_channel-1 = <0>;
      			compatible = "allwinner,sun8iw20-msgbox";
      			#mbox-cells = <1>;
      			local_id = <0>;
      		hdmi: hdmi@5500000 {
      			compatible = "allwinner,sunxi-hdmi";
      			reg = <0x0 0x05500000 0x0 0xfffff>;
      			interrupts = <GIC_SPI 93 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_HDMI>,
      				<&ccu CLK_HDMI_24M>,
      				<&ccu CLK_HDMI_CEC>,
      				<&ccu CLK_TCON_TV>;
      			clock-names = "clk_bus_hdmi",
      					"clk_ddc",
      					"clk_cec",
      					"clk_tcon_tv";
      			resets = <&ccu RST_BUS_HDMI_SUB>,
      				<&ccu RST_BUS_HDMI_MAIN>;
      			reset-names = "rst_bus_sub",
      				      "rst_bus_main";
      			assigned-clocks = <&ccu CLK_HDMI_CEC>;
      			assigned-clock-parents = <&ccu CLK_HDMI_CEC_32K>;
      			assigned-clock-rates = <0>;
      		usbc0:usbc0@0 {
      			compatible = "allwinner,sunxi-otg-manager";
      			usb_port_type = <2>;
      			usb_detect_type = <1>;
      			usb_id_gpio;
      			usb_det_vbus_gpio;
      			usb_luns = <3>;
      			rndis_wceis = <1>;
      		udc:udc-controller@0x04100000 {
      			compatible = "allwinner,sunxi-udc";
      			reg = <0x0 0x04100000 0x0 0x1000>, /*udc base*/
      			      <0x0 0x00000000 0x0 0x100>; /*sram base*/
      			interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_OTG>;
      			clock-names = "bus_otg";
      			resets = <&ccu RST_BUS_OTG>, <&ccu RST_USB_PHY0>;
      			reset-names = "otg", "phy";
      		ehci0:ehci0-controller@0x04101000 {
      			compatible = "allwinner,sunxi-ehci0";
      			reg = <0x0 0x04101000 0x0 0xFFF>, /*hci0 base*/
      			      <0x0 0x00000000 0x0 0x100>, /*sram base*/
      			      <0x0 0x04100000 0x0 0x1000>; /*otg base*/
      			interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_EHCI0>;
      			clock-names = "bus_hci";
      			resets = <&ccu RST_BUS_EHCI0>, <&ccu RST_USB_PHY0>;
      			reset-names = "hci", "phy";
      			hci_ctrl_no = <0>;
      		ohci0:ohci0-controller@0x04101400 {
      			compatible = "allwinner,sunxi-ohci0";
      			reg = <0x0 0x04101400 0x0 0xFFF>, /*hci0 base*/
      			interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_OHCI0>, <&ccu CLK_USB_OHCI0>;
      			clock-names = "bus_hci", "ohci";
      			resets = <&ccu RST_BUS_OHCI0>, <&ccu RST_USB_PHY0>;
      			hci_ctrl_no = <0>;
      		usbc1:usbc1@0 {
      			status = "disable";
      		ehci1:ehci1-controller@0x04200000 {
      			compatible = "allwinner,sunxi-ehci1";
      			reg = <0x0 0x04200000 0x0 0xFFF>, /*ehci1 base*/
      			interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_EHCI1>;
      			resets = <&ccu RST_BUS_EHCI1>, <&ccu RST_USB_PHY1>;
      			hci_ctrl_no = <1>;
      			status = "disable";
      		ohci1:ohci1-controller@0x04200400 {
      			compatible = "allwinner,sunxi-ohci1";
      			reg = <0x0 0x04200400 0x0 0xFFF>, /*ohci1 base*/
      			interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_OHCI1>, <&ccu CLK_USB_OHCI1>;
      			resets = <&ccu RST_BUS_OHCI1>, <&ccu RST_USB_PHY1>;
      			hci_ctrl_no = <1>;
      			status = "disable";
      		/* codec addr: 0x02030000, the others is invalid to avoid build warining */
      		codec:codec@2030000 {
      			#sound-dai-cells = <0>;
      			compatible = "allwinner,sunxi-internal-codec";
      			reg = <0x0 0x02030000 0x0 0x34c>;
      			clocks = <&ccu CLK_PLL_AUDIO0>,
      				 <&ccu CLK_PLL_AUDIO1_DIV5>,
      				 <&ccu CLK_AUDIO_DAC>,
      				 <&ccu CLK_AUDIO_ADC>,
      				 <&ccu CLK_BUS_AUDIO_CODEC>;
      			clock-names = "pll_audio0", "pll_audio1_div5",
      				      "audio_clk_dac", "audio_clk_adc",
      				      "audio_clk_bus";
      			resets = <&ccu RST_BUS_AUDIO_CODEC>;
      			rx_sync_en  = <0x00>;
      			device_type = "codec";
      		dummy_cpudai:dummy_cpudai@203034c {
      			compatible = "allwinner,sunxi-dummy-cpudai";
      			reg = <0x0 0x0203034c 0x0 0x4>;
      			tx_fifo_size    = <128>;
      			rx_fifo_size    = <256>;
      			dac_txdata      = <0x02030020>;
      			adc_txdata      = <0x02030040>;
      			device_type = "cpudai";
      			dmas = <&dma 7>, <&dma 7>;
      		sndcodec:sound@2030340 {
      			compatible = "allwinner,sunxi-codec-machine";
      			reg = <0x0 0x02030340 0x0 0x4>;
      			interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>;
      			sunxi,audio-codec = <&codec>;
      			sunxi,cpudai-controller = <&dummy_cpudai>;
      			device_type = "sndcodec";
      		sunxi_rpaf_dsp0:rpaf-dsp@203034c {
      			compatible = "allwinner,rpaf-dsp0";
      			device_type = "sunxi_rpaf_dsp0";
      			dsp_id = <0x0>;
      		/* dmic addr: 0x02031000, the others is invalid to avoid build warining */
      		dmic:dmic@2031000{
      			compatible = "allwinner,sunxi-dmic";
      			reg = <0x0 0x02031000 0x0 0x50>;
      			clocks = <&ccu CLK_PLL_AUDIO0>, /* 98.304M / 90.3168M */
      				 <&ccu CLK_DMIC>,
      				 <&ccu CLK_BUS_DMIC>;
      			clock-names = "pll_audio", "dmic", "dmic_bus";
      			resets = <&ccu RST_BUS_DMIC>;
      			dmas		= <&dma 8>;
      			dma-names	= "rx";
      			interrupts	= <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>;
      			clk_parent	= <0x1>;
      			data_vol	= <0xB0>;
      			rx_chmap	= <0x76543210>;
      			device_type = "dmic";
      		dmic_codec:sound@2031050{
      			compatible = "dmic-codec";
      			reg = <0x0 0x02031050 0x0 0x4>;
      			num-channels = <8>;
      		sounddmic:sounddmic@2031060 {
      			reg = <0x0 0x02031060 0x0 0x4>;
      			compatible = "sunxi,simple-audio-card";
      			simple-audio-card,name = "snddmic";
      			simple-audio-card,capture_only;
      			simple-audio-card,cpu {
      				sound-dai = <&dmic>;
      				sound-dai = <&dmic_codec>;
      		/* daudio0 addr: 0x02032000, the others is invalid to avoid build warining */
      		daudio0:daudio@2032000 {
      			compatible = "allwinner,sunxi-daudio";
      			reg = <0x0 0x02032000 0x0 0xa0>;
      				 <&ccu CLK_I2S0>,
      				 <&ccu CLK_BUS_I2S0>;
      			clock-names = "pll_audio", "i2s0", "i2s0_bus";
      			resets = <&ccu RST_BUS_I2S0>;
      			dmas		= <&dma 3>, <&dma 3>;
      			interrupts	= <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>;
      			pinctrl_used		= <0x01>;
      			frametype		= <0x00>;
      			tdm_num			= <0x00>;
      			mclk_div		= <0x00>;
      			clk_parent		= <0x00>;
      			capture_cma		= <128>;
      			tx_num			= <4>;
      			tx_chmap1		= <0x76543210>;
      			tx_chmap0		= <0xFEDCBA98>;
      			rx_num			= <4>;
      			rx_chmap3		= <0x03020100>;
      			rx_chmap2		= <0x07060504>;
      			rx_chmap1		= <0x0B0A0908>;
      			rx_chmap0		= <0x0F0E0D0C>;
      			device_type = "daudio0";
      		sounddaudio0: sounddaudio0@20320a0 {
      			reg = <0x0 0x020320a0 0x0 0x4>;
      			simple-audio-card,name = "snddaudio0";
      				sound-dai = <&daudio0>;
      		/* daudio1 addr: 0x02033000, the others is invalid to avoid build warining */
      		daudio1:daudio@2033000 {
      			reg = <0x0 0x02033000 0x0 0xa0>;
      				 <&ccu CLK_I2S1>,
      				 <&ccu CLK_BUS_I2S1>;
      			clock-names = "pll_audio", "i2s1", "i2s1_bus";
      			resets = <&ccu RST_BUS_I2S1>;
      			dmas		= <&dma 4>, <&dma 4>;
      			interrupts	= <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>;
      			frametype		= <0x00>;
      			tdm_num			= <0x01>;
      			mclk_div		= <0x00>;
      			tx_num			= <4>;
      			rx_num			= <4>;
      			device_type = "daudio1";
      		sounddaudio1: sounddaudio1@20330a0 {
      			reg = <0x0 0x020330a0 0x0 0x4>;
      			simple-audio-card,name = "snddaudio1";
      				sound-dai = <&daudio1>;
      		/* daudio2 addr: 0x02034000, the others is invalid to avoid build warining */
      		daudio2:daudio@2034000 {
      			reg = <0x0 0x02034000 0x0 0xa0>;
      				 <&ccu CLK_I2S2>,
      				 <&ccu CLK_BUS_I2S2>,
      				 <&ccu CLK_PLL_AUDIO0_4X>,
      				 <&ccu CLK_I2S2_ASRC>;
      			resets = <&ccu RST_BUS_I2S2>;
      			dmas		= <&dma 5>, <&dma 5>;
      			interrupts	= <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>;
      			daudio_type		= <0x00>;
      			frametype		= <0x00>;
      			tdm_num			= <0x02>;
      			mclk_div		= <0x01>;
      			tx_num			= <4>;
      			rx_num			= <4>;
      			device_type = "daudio2";
      		sounddaudio2: sounddaudio2@20340a0 {
      			reg = <0x0 0x020340a0 0x0 0x4>;
      			simple-audio-card,name = "snddaudio2";
      				sound-dai = <&daudio2>;
      		hdmiaudio: hdmiaudio@20340a4 {
      			reg = <0x0 0x020340a4 0x0 0x4>;
      			compatible = "allwinner,sunxi-hdmiaudio";
      		/* spdif addr: 0x02036000, the others is invalid to avoid build warining */
      		spdif:spdif@2036000 {
      			compatible = "allwinner,sunxi-spdif";
      			reg = <0x0 0x02036000 0x0 0x58>;
      			clocks = <&ccu CLK_PLL_AUDIO0_4X>,	/* 90.3168M */
      				 <&ccu CLK_SPDIF_TX>,
      				 <&ccu CLK_BUS_SPDIF>,
      				 <&ccu CLK_PLL_AUDIO1>,         /* 98.304M */
      				 <&ccu CLK_SPDIF_RX>;
      			clock-names = "pll_audio0", "spdif", "spdif_bus",
      				      "pll_audio1", "pll_audio1_div5",
      				      "pll_periph", "spdif_rx";
      			resets = <&ccu RST_BUS_SPDIF>;
      			dmas		= <&dma 2>, <&dma 2>;
      			interrupts	= <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>;
      			clk_parent	= <0x1>;
      			rx_sync_en      = <0>;
      			device_type = "spdif";
      		soundspdif:soundspdif@203605c {
      			reg = <0x0 0x0203605c 0x0 0x4>;
      			simple-audio-card,name = "sndspdif";
      				 sound-dai = <&spdif>;
      				 /*snd-soc-dummy*/
      		ths: ths@02009400 {
      			compatible = "allwinner,sun8iw20p1-ths";
      			reg = <0x0 0x02009400 0x0 0x400>;
      			clocks = <&ccu CLK_BUS_THS>;
      			resets = <&ccu RST_BUS_THS>;
      			nvmem-cells = <&ths_calib>;
      			nvmem-cell-names = "calibration";
      			#thermal-sensor-cells = <1>;
      		tvd: tvd@05c00000 {
      			compatible = "allwinner,sunxi-tvd";
      			reg = <0x0 0x05c00000 0x0 0x00010000>;/*tvd_top*/
      			interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&ccu CLK_BUS_TVD_TOP>,
      			<&ccu CLK_MBUS_TVIN>;
      			clock-names = "clk_bus_tvd_top",
      			"clk_mbus_tvd";
      			resets = <&ccu RST_BUS_TVD_TOP>;
      			reset-names = "rst_bus_tvd_top";
      			tvd-number = <1>;
      			tvds = <&tvd0>;
      		tvd0: tvd0@05c01000 {
      			compatible = "allwinner,sunxi-tvd0";
      			reg = <0x0 0x05c01000 0x0 0x00010000>;
      			clocks = <&ccu CLK_TVD>,
      			<&ccu CLK_BUS_TVD>;
      			clock-names = "clk_tvd0","clk_bus_tvd0";
      			resets = <&ccu RST_BUS_TVD>;
      			reset-names = "rst_bus_tvd0";
      			assigned-clocks = <&ccu CLK_TVD>;
      			assigned-clock-parents = <&ccu CLK_PLL_VIDEO1>;
      			tvd_used = <1>;
      			tvd_if = <0>;
      config-5.4
      # Automatically generated file; DO NOT EDIT.
      # Linux/arm 5.4.61 Kernel Configuration
      CONFIG_CC_VERSION_TEXT="arm-openwrt-linux-muslgnueabi-gcc.bin (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) 6.4.1"
      CONFIG_CC_IS_GCC=y
      CONFIG_GCC_VERSION=60401
      CONFIG_CLANG_VERSION=0
      CONFIG_CC_CAN_LINK=y
      CONFIG_CC_HAS_ASM_GOTO=y
      CONFIG_IRQ_WORK=y
      CONFIG_BUILDTIME_EXTABLE_SORT=y
      # General setup
      CONFIG_INIT_ENV_ARG_LIMIT=32
      # CONFIG_COMPILE_TEST is not set
      CONFIG_LOCALVERSION=""
      # CONFIG_LOCALVERSION_AUTO is not set
      CONFIG_BUILD_SALT=""
      CONFIG_HAVE_KERNEL_GZIP=y
      CONFIG_HAVE_KERNEL_LZMA=y
      CONFIG_HAVE_KERNEL_XZ=y
      CONFIG_HAVE_KERNEL_LZO=y
      CONFIG_HAVE_KERNEL_LZ4=y
      CONFIG_KERNEL_GZIP=y
      # CONFIG_KERNEL_LZMA is not set
      # CONFIG_KERNEL_XZ is not set
      # CONFIG_KERNEL_LZO is not set
      # CONFIG_KERNEL_LZ4 is not set
      CONFIG_DEFAULT_HOSTNAME="(none)"
      # CONFIG_SWAP is not set
      CONFIG_SYSVIPC=y
      CONFIG_SYSVIPC_SYSCTL=y
      # CONFIG_POSIX_MQUEUE is not set
      CONFIG_CROSS_MEMORY_ATTACH=y
      # CONFIG_USELIB is not set
      # CONFIG_AUDIT is not set
      # IRQ subsystem
      CONFIG_GENERIC_IRQ_PROBE=y
      CONFIG_GENERIC_IRQ_SHOW=y
      CONFIG_GENERIC_IRQ_SHOW_LEVEL=y
      CONFIG_GENERIC_IRQ_EFFECTIVE_AFF_MASK=y
      CONFIG_GENERIC_IRQ_MIGRATION=y
      CONFIG_HARDIRQS_SW_RESEND=y
      CONFIG_GENERIC_IRQ_CHIP=y
      CONFIG_IRQ_DOMAIN=y
      CONFIG_IRQ_DOMAIN_HIERARCHY=y
      CONFIG_IRQ_MSI_IOMMU=y
      CONFIG_HANDLE_DOMAIN_IRQ=y
      CONFIG_IRQ_FORCED_THREADING=y
      CONFIG_SPARSE_IRQ=y
      # CONFIG_GENERIC_IRQ_DEBUGFS is not set
      # end of IRQ subsystem
      CONFIG_GENERIC_IRQ_MULTI_HANDLER=y
      CONFIG_ARCH_CLOCKSOURCE_DATA=y
      CONFIG_GENERIC_CLOCKEVENTS=y
      CONFIG_ARCH_HAS_TICK_BROADCAST=y
      CONFIG_GENERIC_CLOCKEVENTS_BROADCAST=y
      # Timers subsystem
      CONFIG_TICK_ONESHOT=y
      CONFIG_NO_HZ_COMMON=y
      # CONFIG_HZ_PERIODIC is not set
      CONFIG_NO_HZ_IDLE=y
      # CONFIG_NO_HZ_FULL is not set
      CONFIG_NO_HZ=y
      CONFIG_HIGH_RES_TIMERS=y
      # end of Timers subsystem
      # CONFIG_PREEMPT_NONE is not set
      # CONFIG_PREEMPT_VOLUNTARY is not set
      CONFIG_PREEMPT=y
      CONFIG_PREEMPT_COUNT=y
      CONFIG_PREEMPTION=y
      # CPU/Task time and stats accounting
      CONFIG_TICK_CPU_ACCOUNTING=y
      # CONFIG_VIRT_CPU_ACCOUNTING_GEN is not set
      # CONFIG_IRQ_TIME_ACCOUNTING is not set
      CONFIG_BSD_PROCESS_ACCT=y
      CONFIG_BSD_PROCESS_ACCT_V3=y
      # CONFIG_TASKSTATS is not set
      # CONFIG_PSI is not set
      # end of CPU/Task time and stats accounting
      CONFIG_CPU_ISOLATION=y
      # RCU Subsystem
      CONFIG_PREEMPT_RCU=y
      # CONFIG_RCU_EXPERT is not set
      CONFIG_SRCU=y
      CONFIG_TREE_SRCU=y
      CONFIG_TASKS_RCU=y
      CONFIG_RCU_STALL_COMMON=y
      CONFIG_RCU_NEED_SEGCBLIST=y
      # end of RCU Subsystem
      CONFIG_IKCONFIG=y
      CONFIG_IKCONFIG_PROC=y
      # CONFIG_IKHEADERS is not set
      CONFIG_LOG_BUF_SHIFT=20
      CONFIG_LOG_CPU_MAX_BUF_SHIFT=12
      CONFIG_PRINTK_SAFE_LOG_BUF_SHIFT=13
      CONFIG_GENERIC_SCHED_CLOCK=y
      # Scheduler features
      # end of Scheduler features
      # CONFIG_CGROUPS is not set
      # CONFIG_NAMESPACES is not set
      # CONFIG_CHECKPOINT_RESTORE is not set
      # CONFIG_SCHED_AUTOGROUP is not set
      # CONFIG_SYSFS_DEPRECATED is not set
      # CONFIG_RELAY is not set
      # CONFIG_BLK_DEV_INITRD is not set
      # CONFIG_CC_OPTIMIZE_FOR_PERFORMANCE is not set
      CONFIG_CC_OPTIMIZE_FOR_SIZE=y
      CONFIG_SYSCTL=y
      CONFIG_HAVE_UID16=y
      CONFIG_BPF=y
      CONFIG_EXPERT=y
      CONFIG_UID16=y
      CONFIG_MULTIUSER=y
      # CONFIG_SGETMASK_SYSCALL is not set
      # CONFIG_SYSFS_SYSCALL is not set
      # CONFIG_SYSCTL_SYSCALL is not set
      # CONFIG_FHANDLE is not set
      CONFIG_POSIX_TIMERS=y
      CONFIG_PRINTK=y
      CONFIG_PRINTK_NMI=y
      CONFIG_BUG=y
      # CONFIG_ELF_CORE is not set
      CONFIG_BASE_FULL=y
      CONFIG_FUTEX=y
      CONFIG_FUTEX_PI=y
      CONFIG_EPOLL=y
      CONFIG_SIGNALFD=y
      CONFIG_TIMERFD=y
      CONFIG_EVENTFD=y
      CONFIG_SHMEM=y
      # CONFIG_AIO is not set
      CONFIG_IO_URING=y
      CONFIG_ADVISE_SYSCALLS=y
      CONFIG_MEMBARRIER=y
      CONFIG_KALLSYMS=y
      # CONFIG_KALLSYMS_ALL is not set
      CONFIG_KALLSYMS_BASE_RELATIVE=y
      # CONFIG_BPF_SYSCALL is not set
      # CONFIG_USERFAULTFD is not set
      CONFIG_ARCH_HAS_MEMBARRIER_SYNC_CORE=y
      CONFIG_RSEQ=y
      # CONFIG_DEBUG_RSEQ is not set
      CONFIG_EMBEDDED=y
      CONFIG_HAVE_PERF_EVENTS=y
      CONFIG_PERF_USE_VMALLOC=y
      # CONFIG_PC104 is not set
      # Kernel Performance Events And Counters
      CONFIG_PERF_EVENTS=y
      # CONFIG_DEBUG_PERF_USE_VMALLOC is not set
      # end of Kernel Performance Events And Counters
      CONFIG_VM_EVENT_COUNTERS=y
      # CONFIG_SLUB_DEBUG is not set
      # CONFIG_COMPAT_BRK is not set
      # CONFIG_SLAB is not set
      CONFIG_SLUB=y
      # CONFIG_SLOB is not set
      CONFIG_SLAB_MERGE_DEFAULT=y
      # CONFIG_SLAB_FREELIST_RANDOM is not set
      # CONFIG_SLAB_FREELIST_HARDENED is not set
      # CONFIG_SHUFFLE_PAGE_ALLOCATOR is not set
      CONFIG_SLUB_CPU_PARTIAL=y
      # CONFIG_PROFILING is not set
      # end of General setup
      CONFIG_ARM=y
      CONFIG_ARM_HAS_SG_CHAIN=y
      CONFIG_ARM_DMA_USE_IOMMU=y
      CONFIG_ARM_DMA_IOMMU_ALIGNMENT=8
      CONFIG_SYS_SUPPORTS_APM_EMULATION=y
      CONFIG_HAVE_PROC_CPU=y
      CONFIG_STACKTRACE_SUPPORT=y
      CONFIG_LOCKDEP_SUPPORT=y
      CONFIG_TRACE_IRQFLAGS_SUPPORT=y
      CONFIG_FIX_EARLYCON_MEM=y
      CONFIG_GENERIC_HWEIGHT=y
      CONFIG_GENERIC_CALIBRATE_DELAY=y
      CONFIG_ARCH_SUPPORTS_UPROBES=y
      CONFIG_ARM_PATCH_PHYS_VIRT=y
      CONFIG_GENERIC_BUG=y
      CONFIG_PGTABLE_LEVELS=2
      # System Type
      CONFIG_MMU=y
      CONFIG_ARCH_MMAP_RND_BITS_MIN=8
      CONFIG_ARCH_MMAP_RND_BITS_MAX=16
      CONFIG_ARCH_MULTIPLATFORM=y
      # CONFIG_ARCH_EBSA110 is not set
      # CONFIG_ARCH_EP93XX is not set
      # CONFIG_ARCH_FOOTBRIDGE is not set
      # CONFIG_ARCH_IOP32X is not set
      # CONFIG_ARCH_IXP4XX is not set
      # CONFIG_ARCH_DOVE is not set
      # CONFIG_ARCH_PXA is not set
      # CONFIG_ARCH_RPC is not set
      # CONFIG_ARCH_SA1100 is not set
      # CONFIG_ARCH_S3C24XX is not set
      # CONFIG_ARCH_OMAP1 is not set
      # Multiple platform selection
      # CPU Core family selection
      # CONFIG_ARCH_MULTI_V6 is not set
      CONFIG_ARCH_MULTI_V7=y
      CONFIG_ARCH_MULTI_V6_V7=y
      # end of Multiple platform selection
      # CONFIG_ARCH_VIRT is not set
      # CONFIG_ARCH_ACTIONS is not set
      # CONFIG_ARCH_ALPINE is not set
      # CONFIG_ARCH_ARTPEC is not set
      # CONFIG_ARCH_ASPEED is not set
      # CONFIG_ARCH_AT91 is not set
      # CONFIG_ARCH_BCM is not set
      # CONFIG_ARCH_BERLIN is not set
      # CONFIG_ARCH_DIGICOLOR is not set
      # CONFIG_ARCH_EXYNOS is not set
      # CONFIG_ARCH_HIGHBANK is not set
      # CONFIG_ARCH_HISI is not set
      # CONFIG_ARCH_MXC is not set
      # CONFIG_ARCH_KEYSTONE is not set
      # CONFIG_ARCH_MEDIATEK is not set
      # CONFIG_ARCH_MESON is not set
      # CONFIG_ARCH_MILBEAUT is not set
      # CONFIG_ARCH_MMP is not set
      # CONFIG_ARCH_MVEBU is not set
      # CONFIG_ARCH_NPCM is not set
      # TI OMAP/AM/DM/DRA Family
      # CONFIG_ARCH_OMAP3 is not set
      # CONFIG_ARCH_OMAP4 is not set
      # CONFIG_SOC_OMAP5 is not set
      # CONFIG_SOC_AM33XX is not set
      # CONFIG_SOC_AM43XX is not set
      # CONFIG_SOC_DRA7XX is not set
      # end of TI OMAP/AM/DM/DRA Family
      # CONFIG_ARCH_SIRF is not set
      # CONFIG_ARCH_QCOM is not set
      # CONFIG_ARCH_RDA is not set
      # CONFIG_ARCH_REALVIEW is not set
      # CONFIG_ARCH_ROCKCHIP is not set
      # CONFIG_ARCH_S5PV210 is not set
      # CONFIG_ARCH_RENESAS is not set
      # CONFIG_ARCH_SOCFPGA is not set
      # CONFIG_PLAT_SPEAR is not set
      # CONFIG_ARCH_STI is not set
      # CONFIG_ARCH_STM32 is not set
      CONFIG_ARCH_SUNXI=y
      # CONFIG_MACH_SUN4I is not set
      # CONFIG_MACH_SUN5I is not set
      # CONFIG_MACH_SUN6I is not set
      # CONFIG_MACH_SUN7I is not set
      # CONFIG_MACH_SUN8I is not set
      # CONFIG_MACH_SUN9I is not set
      CONFIG_ARCH_SUN8I=y
      # CONFIG_ARCH_SUN8IW15 is not set
      CONFIG_ARCH_SUN8IW20=y
      # CONFIG_FPGA_V4_PLATFORM is not set
      # CONFIG_FPGA_V7_PLATFORM is not set
      CONFIG_EVB_PLATFORM=y
      CONFIG_SUNXI_SOC_NAME="sun8iw20"
      # CONFIG_ARCH_TANGO is not set
      # CONFIG_ARCH_TEGRA is not set
      # CONFIG_ARCH_UNIPHIER is not set
      # CONFIG_ARCH_U8500 is not set
      # CONFIG_ARCH_VEXPRESS is not set
      # CONFIG_ARCH_WM8850 is not set
      # CONFIG_ARCH_ZX is not set
      # CONFIG_ARCH_ZYNQ is not set
      # Processor Type
      CONFIG_CPU_V7=y
      CONFIG_CPU_THUMB_CAPABLE=y
      CONFIG_CPU_32v6K=y
      CONFIG_CPU_32v7=y
      CONFIG_CPU_ABRT_EV7=y
      CONFIG_CPU_PABRT_V7=y
      CONFIG_CPU_CACHE_V7=y
      CONFIG_CPU_CACHE_VIPT=y
      CONFIG_CPU_COPY_V6=y
      CONFIG_CPU_TLB_V7=y
      CONFIG_CPU_HAS_ASID=y
      CONFIG_CPU_CP15=y
      CONFIG_CPU_CP15_MMU=y
      # Processor Features
      # CONFIG_ARM_LPAE is not set
      CONFIG_ARM_THUMB=y
      # CONFIG_ARM_THUMBEE is not set
      CONFIG_ARM_VIRT_EXT=y
      CONFIG_SWP_EMULATE=y
      # CONFIG_CPU_ICACHE_DISABLE is not set
      # CONFIG_CPU_ICACHE_MISMATCH_WORKAROUND is not set
      # CONFIG_CPU_BPREDICT_DISABLE is not set
      CONFIG_CPU_SPECTRE=y
      CONFIG_HARDEN_BRANCH_PREDICTOR=y
      CONFIG_KUSER_HELPERS=y
      # CONFIG_VDSO is not set
      CONFIG_OUTER_CACHE=y
      CONFIG_OUTER_CACHE_SYNC=y
      CONFIG_MIGHT_HAVE_CACHE_L2X0=y
      CONFIG_CACHE_L2X0=y
      # CONFIG_CACHE_L2X0_PMU is not set
      # CONFIG_PL310_ERRATA_588369 is not set
      # CONFIG_PL310_ERRATA_727915 is not set
      # CONFIG_PL310_ERRATA_753970 is not set
      # CONFIG_PL310_ERRATA_769419 is not set
      CONFIG_ARM_L1_CACHE_SHIFT_6=y
      CONFIG_ARM_L1_CACHE_SHIFT=6
      CONFIG_ARM_DMA_MEM_BUFFERABLE=y
      CONFIG_ARM_HEAVY_MB=y
      CONFIG_DEBUG_ALIGN_RODATA=y
      # CONFIG_ARM_ERRATA_430973 is not set
      CONFIG_ARM_ERRATA_643719=y
      # CONFIG_ARM_ERRATA_720789 is not set
      # CONFIG_ARM_ERRATA_754322 is not set
      # CONFIG_ARM_ERRATA_754327 is not set
      # CONFIG_ARM_ERRATA_764369 is not set
      # CONFIG_ARM_ERRATA_775420 is not set
      # CONFIG_ARM_ERRATA_798181 is not set
      # CONFIG_ARM_ERRATA_773022 is not set
      # CONFIG_ARM_ERRATA_818325_852422 is not set
      # CONFIG_ARM_ERRATA_821420 is not set
      # CONFIG_ARM_ERRATA_825619 is not set
      # CONFIG_ARM_ERRATA_857271 is not set
      # CONFIG_ARM_ERRATA_852421 is not set
      # CONFIG_ARM_ERRATA_852423 is not set
      # CONFIG_ARM_ERRATA_857272 is not set
      # end of System Type
      # Bus support
      # CONFIG_ARM_ERRATA_814220 is not set
      # end of Bus support
      # Kernel Features
      CONFIG_HAVE_SMP=y
      CONFIG_SMP=y
      CONFIG_SMP_ON_UP=y
      CONFIG_ARM_CPU_TOPOLOGY=y
      CONFIG_SCHED_MC=y
      # CONFIG_SCHED_SMT is not set
      CONFIG_HAVE_ARM_ARCH_TIMER=y
      # CONFIG_MCPM is not set
      # CONFIG_BIG_LITTLE is not set
      CONFIG_VMSPLIT_3G=y
      # CONFIG_VMSPLIT_3G_OPT is not set
      # CONFIG_VMSPLIT_2G is not set
      # CONFIG_VMSPLIT_1G is not set
      CONFIG_PAGE_OFFSET=0xC0000000
      CONFIG_NR_CPUS=2
      CONFIG_HOTPLUG_CPU=y
      CONFIG_ARM_PSCI=y
      CONFIG_ARCH_NR_GPIO=416
      CONFIG_HZ_FIXED=0
      CONFIG_HZ_100=y
      # CONFIG_HZ_200 is not set
      # CONFIG_HZ_250 is not set
      # CONFIG_HZ_300 is not set
      # CONFIG_HZ_500 is not set
      # CONFIG_HZ_1000 is not set
      CONFIG_HZ=100
      CONFIG_SCHED_HRTICK=y
      # CONFIG_THUMB2_KERNEL is not set
      CONFIG_ARM_PATCH_IDIV=y
      CONFIG_AEABI=y
      CONFIG_OABI_COMPAT=y
      CONFIG_HAVE_ARCH_PFN_VALID=y
      # CONFIG_HIGHMEM is not set
      CONFIG_CPU_SW_DOMAIN_PAN=y
      CONFIG_ARCH_WANT_GENERAL_HUGETLB=y
      # CONFIG_ARM_MODULE_PLTS is not set
      CONFIG_FORCE_MAX_ZONEORDER=11
      CONFIG_ALIGNMENT_TRAP=y
      # CONFIG_UACCESS_WITH_MEMCPY is not set
      # CONFIG_SECCOMP is not set
      # CONFIG_PARAVIRT is not set
      # CONFIG_PARAVIRT_TIME_ACCOUNTING is not set
      # CONFIG_XEN is not set
      # end of Kernel Features
      # Boot options
      CONFIG_USE_OF=y
      # CONFIG_ATAGS is not set
      CONFIG_ZBOOT_ROM_TEXT=0
      CONFIG_ZBOOT_ROM_BSS=0
      # CONFIG_ARM_APPENDED_DTB is not set
      CONFIG_CMDLINE="loglevel=8 initcall_debug=1 console=ttyS0 init=/init"
      # CONFIG_KEXEC is not set
      # CONFIG_CRASH_DUMP is not set
      CONFIG_AUTO_ZRELADDR=y
      # CONFIG_EFI is not set
      # end of Boot options
      # CPU Power Management
      # CPU Frequency scaling
      # CONFIG_CPU_FREQ is not set
      # end of CPU Frequency scaling
      # CPU Idle
      # CONFIG_CPU_IDLE is not set
      # end of CPU Idle
      # end of CPU Power Management
      # Floating point emulation
      # At least one emulation must be selected
      # CONFIG_FPE_NWFPE is not set
      # CONFIG_FPE_FASTFPE is not set
      CONFIG_VFP=y
      CONFIG_VFPv3=y
      CONFIG_NEON=y
      CONFIG_KERNEL_MODE_NEON=y
      # end of Floating point emulation
      # Power management options
      CONFIG_SUSPEND=y
      CONFIG_SUSPEND_FREEZER=y
      # CONFIG_SUSPEND_SKIP_SYNC is not set
      CONFIG_PM_SLEEP=y
      CONFIG_PM_SLEEP_SMP=y
      # CONFIG_PM_AUTOSLEEP is not set
      CONFIG_PM_WAKELOCKS=y
      CONFIG_PM_WAKELOCKS_LIMIT=100
      CONFIG_PM_WAKELOCKS_GC=y
      CONFIG_PM=y
      CONFIG_PM_DEBUG=y
      CONFIG_PM_ADVANCED_DEBUG=y
      CONFIG_PM_SLEEP_DEBUG=y
      # CONFIG_APM_EMULATION is not set
      CONFIG_PM_CLK=y
      CONFIG_PM_GENERIC_DOMAINS=y
      CONFIG_WQ_POWER_EFFICIENT_DEFAULT=y
      CONFIG_PM_GENERIC_DOMAINS_SLEEP=y
      CONFIG_PM_GENERIC_DOMAINS_OF=y
      CONFIG_CPU_PM=y
      CONFIG_ARCH_SUSPEND_POSSIBLE=y
      CONFIG_ARM_CPU_SUSPEND=y
      CONFIG_ARCH_HIBERNATION_POSSIBLE=y
      # end of Power management options
      # Firmware Drivers
      # CONFIG_FIRMWARE_MEMMAP is not set
      # CONFIG_FW_CFG_SYSFS is not set
      # CONFIG_QCOM_SCM is not set
      # CONFIG_TRUSTED_FOUNDATIONS is not set
      CONFIG_HAVE_ARM_SMCCC=y
      CONFIG_ARM_PSCI_FW=y
      # CONFIG_GOOGLE_FIRMWARE is not set
      # Tegra firmware driver
      # end of Tegra firmware driver
      # end of Firmware Drivers
      # CONFIG_ARM_CRYPTO is not set
      # CONFIG_VIRTUALIZATION is not set
      # General architecture-dependent options
      CONFIG_HAVE_OPROFILE=y
      # CONFIG_KPROBES is not set
      CONFIG_JUMP_LABEL=y
      # CONFIG_STATIC_KEYS_SELFTEST is not set
      CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS=y
      CONFIG_ARCH_USE_BUILTIN_BSWAP=y
      CONFIG_HAVE_KPROBES=y
      CONFIG_HAVE_KRETPROBES=y
      CONFIG_HAVE_OPTPROBES=y
      CONFIG_HAVE_NMI=y
      CONFIG_HAVE_ARCH_TRACEHOOK=y
      CONFIG_HAVE_DMA_CONTIGUOUS=y
      CONFIG_GENERIC_SMP_IDLE_THREAD=y
      CONFIG_GENERIC_IDLE_POLL_SETUP=y
      CONFIG_ARCH_HAS_FORTIFY_SOURCE=y
      CONFIG_ARCH_HAS_KEEPINITRD=y
      CONFIG_ARCH_HAS_SET_MEMORY=y
      CONFIG_HAVE_ARCH_THREAD_STRUCT_WHITELIST=y
      CONFIG_ARCH_32BIT_OFF_T=y
      CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y
      CONFIG_HAVE_RSEQ=y
      CONFIG_HAVE_CLK=y
      CONFIG_HAVE_HW_BREAKPOINT=y
      CONFIG_HAVE_PERF_REGS=y
      CONFIG_HAVE_PERF_USER_STACK_DUMP=y
      CONFIG_HAVE_ARCH_JUMP_LABEL=y
      CONFIG_ARCH_WANT_IPC_PARSE_VERSION=y
      CONFIG_HAVE_STACKPROTECTOR=y
      CONFIG_CC_HAS_STACKPROTECTOR_NONE=y
      CONFIG_STACKPROTECTOR=y
      CONFIG_STACKPROTECTOR_STRONG=y
      CONFIG_LTO_NONE=y
      CONFIG_HAVE_CONTEXT_TRACKING=y
      CONFIG_HAVE_VIRT_CPU_ACCOUNTING_GEN=y
      CONFIG_HAVE_IRQ_TIME_ACCOUNTING=y
      CONFIG_HAVE_MOD_ARCH_SPECIFIC=y
      CONFIG_MODULES_USE_ELF_REL=y
      CONFIG_ARCH_HAS_ELF_RANDOMIZE=y
      CONFIG_HAVE_ARCH_MMAP_RND_BITS=y
      CONFIG_HAVE_EXIT_THREAD=y
      CONFIG_ARCH_MMAP_RND_BITS=8
      CONFIG_ARCH_WANT_DEFAULT_TOPDOWN_MMAP_LAYOUT=y
      CONFIG_HAVE_COPY_THREAD_TLS=y
      CONFIG_CLONE_BACKWARDS=y
      CONFIG_OLD_SIGSUSPEND3=y
      CONFIG_OLD_SIGACTION=y
      CONFIG_64BIT_TIME=y
      CONFIG_COMPAT_32BIT_TIME=y
      CONFIG_ARCH_OPTIONAL_KERNEL_RWX=y
      CONFIG_ARCH_OPTIONAL_KERNEL_RWX_DEFAULT=y
      CONFIG_ARCH_HAS_STRICT_KERNEL_RWX=y
      CONFIG_STRICT_KERNEL_RWX=y
      CONFIG_ARCH_HAS_STRICT_MODULE_RWX=y
      CONFIG_STRICT_MODULE_RWX=y
      CONFIG_ARCH_HAS_PHYS_TO_DMA=y
      CONFIG_REFCOUNT_FULL=y
      # CONFIG_LOCK_EVENT_COUNTS is not set
      # GCOV-based kernel profiling
      # CONFIG_GCOV_KERNEL is not set
      CONFIG_ARCH_HAS_GCOV_PROFILE_ALL=y
      # end of GCOV-based kernel profiling
      CONFIG_PLUGIN_HOSTCC=""
      CONFIG_HAVE_GCC_PLUGINS=y
      # end of General architecture-dependent options
      CONFIG_RT_MUTEXES=y
      CONFIG_BASE_SMALL=0
      CONFIG_MODULES=y
      # CONFIG_MODULE_FORCE_LOAD is not set
      CONFIG_MODULE_UNLOAD=y
      # CONFIG_MODULE_FORCE_UNLOAD is not set
      # CONFIG_MODVERSIONS is not set
      # CONFIG_MODULE_SRCVERSION_ALL is not set
      # CONFIG_MODULE_SIG is not set
      # CONFIG_MODULE_COMPRESS is not set
      # CONFIG_MODULE_ALLOW_MISSING_NAMESPACE_IMPORTS is not set
      # CONFIG_UNUSED_SYMBOLS is not set
      # CONFIG_TRIM_UNUSED_KSYMS is not set
      CONFIG_MODULES_TREE_LOOKUP=y
      CONFIG_BLOCK=y
      CONFIG_BLK_SCSI_REQUEST=y
      # CONFIG_BLK_DEV_BSG is not set
      # CONFIG_BLK_DEV_BSGLIB is not set
      # CONFIG_BLK_DEV_INTEGRITY is not set
      # CONFIG_BLK_DEV_ZONED is not set
      # CONFIG_BLK_CMDLINE_PARSER is not set
      # CONFIG_BLK_WBT is not set
      CONFIG_BLK_DEBUG_FS=y
      # CONFIG_BLK_SED_OPAL is not set
      # CONFIG_BLK_INLINE_ENCRYPTION is not set
      # Partition Types
      # CONFIG_PARTITION_ADVANCED is not set
      CONFIG_MSDOS_PARTITION=y
      CONFIG_EFI_PARTITION=y
      # end of Partition Types
      CONFIG_BLK_PM=y
      # IO Schedulers
      CONFIG_MQ_IOSCHED_DEADLINE=y
      CONFIG_MQ_IOSCHED_KYBER=y
      # CONFIG_IOSCHED_BFQ is not set
      # end of IO Schedulers
      CONFIG_ASN1=y
      CONFIG_UNINLINE_SPIN_UNLOCK=y
      CONFIG_ARCH_SUPPORTS_ATOMIC_RMW=y
      CONFIG_MUTEX_SPIN_ON_OWNER=y
      CONFIG_RWSEM_SPIN_ON_OWNER=y
      CONFIG_LOCK_SPIN_ON_OWNER=y
      # CONFIG_GKI_HIDDEN_DRM_CONFIGS is not set
      # CONFIG_GKI_HIDDEN_REGMAP_CONFIGS is not set
      # CONFIG_GKI_HIDDEN_CRYPTO_CONFIGS is not set
      # CONFIG_GKI_HIDDEN_SND_CONFIGS is not set
      # CONFIG_GKI_HIDDEN_SND_SOC_CONFIGS is not set
      # CONFIG_GKI_HIDDEN_MMC_CONFIGS is not set
      # CONFIG_GKI_HIDDEN_GPIO_CONFIGS is not set
      # CONFIG_GKI_HIDDEN_QCOM_CONFIGS is not set
      # CONFIG_GKI_HIDDEN_MEDIA_CONFIGS is not set
      # CONFIG_GKI_HIDDEN_VIRTUAL_CONFIGS is not set
      # CONFIG_GKI_LEGACY_WEXT_ALLCONFIG is not set
      # CONFIG_GKI_HIDDEN_USB_CONFIGS is not set
      # CONFIG_GKI_HIDDEN_SOC_BUS_CONFIGS is not set
      # CONFIG_GKI_HIDDEN_RPMSG_CONFIGS is not set
      # CONFIG_GKI_HIDDEN_GPU_CONFIGS is not set
      # CONFIG_GKI_HIDDEN_IRQ_CONFIGS is not set
      # CONFIG_GKI_HIDDEN_HYPERVISOR_CONFIGS is not set
      # CONFIG_GKI_HACKS_TO_FIX is not set
      # CONFIG_GKI_OPT_FEATURES is not set
      CONFIG_FREEZER=y
      # Executable file formats
      CONFIG_BINFMT_ELF=y
      # CONFIG_BINFMT_ELF_FDPIC is not set
      CONFIG_ELFCORE=y
      CONFIG_BINFMT_SCRIPT=y
      CONFIG_ARCH_HAS_BINFMT_FLAT=y
      # CONFIG_BINFMT_FLAT is not set
      CONFIG_BINFMT_FLAT_ARGVP_ENVP_ON_STACK=y
      # CONFIG_BINFMT_MISC is not set
      CONFIG_COREDUMP=y
      # end of Executable file formats
      # Memory Management options
      CONFIG_FLATMEM=y
      CONFIG_FLAT_NODE_MEM_MAP=y
      CONFIG_ARCH_KEEP_MEMBLOCK=y
      CONFIG_MEMORY_ISOLATION=y
      CONFIG_SPLIT_PTLOCK_CPUS=4
      CONFIG_COMPACTION=y
      CONFIG_MIGRATION=y
      CONFIG_CONTIG_ALLOC=y
      # CONFIG_KSM is not set
      CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
      # CONFIG_CLEANCACHE is not set
      CONFIG_CMA=y
      # CONFIG_CMA_DEBUG is not set
      # CONFIG_CMA_DEBUGFS is not set
      CONFIG_CMA_AREAS=7
      # CONFIG_ZPOOL is not set
      # CONFIG_ZBUD is not set
      # CONFIG_ZSMALLOC is not set
      CONFIG_GENERIC_EARLY_IOREMAP=y
      # CONFIG_IDLE_PAGE_TRACKING is not set
      CONFIG_FRAME_VECTOR=y
      # CONFIG_PERCPU_STATS is not set
      # CONFIG_GUP_BENCHMARK is not set
      # end of Memory Management options
      CONFIG_NET=y
      # Networking options
      CONFIG_PACKET=y
      # CONFIG_PACKET_DIAG is not set
      CONFIG_UNIX=y
      CONFIG_UNIX_SCM=y
      # CONFIG_UNIX_DIAG is not set
      # CONFIG_TLS is not set
      # CONFIG_XFRM_USER is not set
      # CONFIG_NET_KEY is not set
      CONFIG_INET=y
      CONFIG_IP_MULTICAST=y
      CONFIG_IP_ADVANCED_ROUTER=y
      # CONFIG_IP_FIB_TRIE_STATS is not set
      CONFIG_IP_MULTIPLE_TABLES=y
      CONFIG_IP_ROUTE_MULTIPATH=y
      CONFIG_IP_ROUTE_VERBOSE=y
      # CONFIG_IP_PNP is not set
      # CONFIG_NET_IPIP is not set
      # CONFIG_NET_IPGRE_DEMUX is not set
      CONFIG_IP_MROUTE_COMMON=y
      CONFIG_IP_MROUTE=y
      CONFIG_IP_MROUTE_MULTIPLE_TABLES=y
      # CONFIG_IP_PIMSM_V1 is not set
      # CONFIG_IP_PIMSM_V2 is not set
      CONFIG_SYN_COOKIES=y
      # CONFIG_NET_IPVTI is not set
      # CONFIG_NET_FOU is not set
      # CONFIG_INET_AH is not set
      # CONFIG_INET_ESP is not set
      # CONFIG_INET_IPCOMP is not set
      # CONFIG_INET_DIAG is not set
      CONFIG_TCP_CONG_ADVANCED=y
      # CONFIG_TCP_CONG_BIC is not set
      CONFIG_TCP_CONG_CUBIC=y
      # CONFIG_TCP_CONG_WESTWOOD is not set
      # CONFIG_TCP_CONG_HTCP is not set
      # CONFIG_TCP_CONG_HSTCP is not set
      # CONFIG_TCP_CONG_HYBLA is not set
      # CONFIG_TCP_CONG_VEGAS is not set
      # CONFIG_TCP_CONG_NV is not set
      # CONFIG_TCP_CONG_SCALABLE is not set
      # CONFIG_TCP_CONG_LP is not set
      # CONFIG_TCP_CONG_VENO is not set
      # CONFIG_TCP_CONG_YEAH is not set
      # CONFIG_TCP_CONG_ILLINOIS is not set
      # CONFIG_TCP_CONG_DCTCP is not set
      # CONFIG_TCP_CONG_CDG is not set
      # CONFIG_TCP_CONG_BBR is not set
      CONFIG_DEFAULT_CUBIC=y
      # CONFIG_DEFAULT_RENO is not set
      CONFIG_DEFAULT_TCP_CONG="cubic"
      # CONFIG_TCP_MD5SIG is not set
      CONFIG_IPV6=y
      # CONFIG_IPV6_ROUTER_PREF is not set
      # CONFIG_IPV6_OPTIMISTIC_DAD is not set
      # CONFIG_INET6_AH is not set
      # CONFIG_INET6_ESP is not set
      # CONFIG_INET6_IPCOMP is not set
      # CONFIG_IPV6_MIP6 is not set
      # CONFIG_IPV6_VTI is not set
      # CONFIG_IPV6_SIT is not set
      # CONFIG_IPV6_TUNNEL is not set
      CONFIG_IPV6_MULTIPLE_TABLES=y
      CONFIG_IPV6_SUBTREES=y
      CONFIG_IPV6_MROUTE=y
      # CONFIG_IPV6_MROUTE_MULTIPLE_TABLES is not set
      # CONFIG_IPV6_PIMSM_V2 is not set
      # CONFIG_IPV6_SEG6_LWTUNNEL is not set
      # CONFIG_IPV6_SEG6_HMAC is not set
      # CONFIG_NETWORK_SECMARK is not set
      # CONFIG_NETWORK_PHY_TIMESTAMPING is not set
      # CONFIG_NETFILTER is not set
      # CONFIG_BPFILTER is not set
      # CONFIG_IP_DCCP is not set
      # CONFIG_IP_SCTP is not set
      # CONFIG_RDS is not set
      # CONFIG_TIPC is not set
      # CONFIG_ATM is not set
      # CONFIG_L2TP is not set
      CONFIG_STP=y
      CONFIG_BRIDGE=y
      CONFIG_BRIDGE_IGMP_SNOOPING=y
      CONFIG_HAVE_NET_DSA=y
      # CONFIG_NET_DSA is not set
      # CONFIG_VLAN_8021Q is not set
      # CONFIG_DECNET is not set
      CONFIG_LLC=y
      # CONFIG_LLC2 is not set
      # CONFIG_ATALK is not set
      # CONFIG_X25 is not set
      # CONFIG_LAPB is not set
      # CONFIG_PHONET is not set
      # CONFIG_6LOWPAN is not set
      # CONFIG_IEEE802154 is not set
      CONFIG_NET_SCHED=y
      # Queueing/Scheduling
      # CONFIG_NET_SCH_CBQ is not set
      # CONFIG_NET_SCH_HTB is not set
      # CONFIG_NET_SCH_HFSC is not set
      # CONFIG_NET_SCH_PRIO is not set
      # CONFIG_NET_SCH_MULTIQ is not set
      # CONFIG_NET_SCH_RED is not set
      # CONFIG_NET_SCH_SFB is not set
      # CONFIG_NET_SCH_SFQ is not set
      # CONFIG_NET_SCH_TEQL is not set
      # CONFIG_NET_SCH_TBF is not set
      # CONFIG_NET_SCH_CBS is not set
      # CONFIG_NET_SCH_ETF is not set
      # CONFIG_NET_SCH_TAPRIO is not set
      # CONFIG_NET_SCH_GRED is not set
      # CONFIG_NET_SCH_DSMARK is not set
      # CONFIG_NET_SCH_NETEM is not set
      # CONFIG_NET_SCH_DRR is not set
      # CONFIG_NET_SCH_MQPRIO is not set
      # CONFIG_NET_SCH_SKBPRIO is not set
      # CONFIG_NET_SCH_CHOKE is not set
      # CONFIG_NET_SCH_QFQ is not set
      # CONFIG_NET_SCH_CODEL is not set
      CONFIG_NET_SCH_FQ_CODEL=y
      # CONFIG_NET_SCH_CAKE is not set
      # CONFIG_NET_SCH_FQ is not set
      # CONFIG_NET_SCH_HHF is not set
      # CONFIG_NET_SCH_PIE is not set
      # CONFIG_NET_SCH_PLUG is not set
      # CONFIG_NET_SCH_DEFAULT is not set
      # Classification
      # CONFIG_NET_CLS_BASIC is not set
      # CONFIG_NET_CLS_TCINDEX is not set
      # CONFIG_NET_CLS_ROUTE4 is not set
      # CONFIG_NET_CLS_FW is not set
      # CONFIG_NET_CLS_U32 is not set
      # CONFIG_NET_CLS_RSVP is not set
      # CONFIG_NET_CLS_RSVP6 is not set
      # CONFIG_NET_CLS_FLOW is not set
      # CONFIG_NET_CLS_BPF is not set
      # CONFIG_NET_CLS_FLOWER is not set
      # CONFIG_NET_CLS_MATCHALL is not set
      # CONFIG_NET_EMATCH is not set
      # CONFIG_NET_CLS_ACT is not set
      CONFIG_NET_SCH_FIFO=y
      # CONFIG_DCB is not set
      # CONFIG_DNS_RESOLVER is not set
      # CONFIG_BATMAN_ADV is not set
      # CONFIG_OPENVSWITCH is not set
      # CONFIG_VSOCKETS is not set
      # CONFIG_NETLINK_DIAG is not set
      # CONFIG_MPLS is not set
      # CONFIG_NET_NSH is not set
      # CONFIG_HSR is not set
      # CONFIG_NET_SWITCHDEV is not set
      # CONFIG_NET_L3_MASTER_DEV is not set
      # CONFIG_NET_NCSI is not set
      CONFIG_RPS=y
      CONFIG_RFS_ACCEL=y
      CONFIG_XPS=y
      CONFIG_NET_RX_BUSY_POLL=y
      CONFIG_BQL=y
      # CONFIG_BPF_JIT is not set
      CONFIG_NET_FLOW_LIMIT=y
      # Network testing
      # CONFIG_NET_PKTGEN is not set
      # end of Network testing
      # end of Networking options
      # CONFIG_HAMRADIO is not set
      # CONFIG_CAN is not set
      CONFIG_BT=y
      CONFIG_BT_BREDR=y
      CONFIG_BT_RFCOMM=y
      CONFIG_BT_RFCOMM_TTY=y
      # CONFIG_BT_BNEP is not set
      # CONFIG_BT_HIDP is not set
      # CONFIG_BT_HS is not set
      # CONFIG_BT_LE is not set
      # CONFIG_BT_LEDS is not set
      # CONFIG_BT_SELFTEST is not set
      CONFIG_BT_DEBUGFS=y
      # Bluetooth device drivers
      # CONFIG_BT_HCIBTUSB is not set
      CONFIG_BT_HCIUART_RTL3WIRE=y
      # CONFIG_BT_HCIBTSDIO is not set
      CONFIG_BT_HCIUART=y
      CONFIG_BT_HCIUART_H4=y
      CONFIG_BT_HCIUART_BCSP=y
      # CONFIG_BT_HCIUART_ATH3K is not set
      # CONFIG_BT_HCIUART_INTEL is not set
      # CONFIG_BT_HCIUART_AG6XX is not set
      # CONFIG_BT_HCIBCM203X is not set
      # CONFIG_BT_HCIBPA10X is not set
      # CONFIG_BT_HCIBFUSB is not set
      # CONFIG_BT_HCIVHCI is not set
      # CONFIG_BCM_BT_LPM is not set
      CONFIG_RTL_BT_LPM=y
      # CONFIG_XR_BT_LPM is not set
      # CONFIG_BT_MRVL is not set
      # CONFIG_BT_MTKSDIO is not set
      # end of Bluetooth device drivers
      # CONFIG_AF_RXRPC is not set
      # CONFIG_AF_KCM is not set
      CONFIG_FIB_RULES=y
      CONFIG_WIRELESS=y
      CONFIG_CFG80211=y
      # CONFIG_NL80211_TESTMODE is not set
      # CONFIG_CFG80211_DEVELOPER_WARNINGS is not set
      CONFIG_CFG80211_CERTIFICATION_ONUS=y
      # CONFIG_CFG80211_REQUIRE_SIGNED_REGDB is not set
      # CONFIG_CFG80211_REG_CELLULAR_HINTS is not set
      # CONFIG_CFG80211_REG_RELAX_NO_IR is not set
      CONFIG_CFG80211_DEFAULT_PS=y
      # CONFIG_CFG80211_DEBUGFS is not set
      CONFIG_CFG80211_CRDA_SUPPORT=y
      # CONFIG_CFG80211_WEXT is not set
      # CONFIG_MAC80211 is not set
      CONFIG_MAC80211_STA_HASH_MAX_SIZE=0
      # CONFIG_WIMAX is not set
      # CONFIG_RFKILL is not set
      # CONFIG_NET_9P is not set
      # CONFIG_CAIF is not set
      # CONFIG_CEPH_LIB is not set
      # CONFIG_NFC is not set
      # CONFIG_PSAMPLE is not set
      # CONFIG_NET_IFE is not set
      # CONFIG_LWTUNNEL is not set
      # CONFIG_FAILOVER is not set
      CONFIG_HAVE_EBPF_JIT=y
      # Device Drivers
      CONFIG_HAVE_PCI=y
      # CONFIG_PCI is not set
      # CONFIG_PCCARD is not set
      # Generic Driver Options
      # CONFIG_UEVENT_HELPER is not set
      CONFIG_DEVTMPFS=y
      CONFIG_DEVTMPFS_MOUNT=y
      CONFIG_STANDALONE=y
      CONFIG_PREVENT_FIRMWARE_BUILD=y
      # Firmware loader
      CONFIG_FW_LOADER=y
      CONFIG_EXTRA_FIRMWARE=""
      # CONFIG_FW_LOADER_USER_HELPER is not set
      # CONFIG_FW_LOADER_COMPRESS is not set
      CONFIG_FW_CACHE=y
      # end of Firmware loader
      CONFIG_ALLOW_DEV_COREDUMP=y
      # CONFIG_DEBUG_DRIVER is not set
      # CONFIG_DEBUG_DEVRES is not set
      # CONFIG_DEBUG_TEST_DRIVER_REMOVE is not set
      # CONFIG_TEST_ASYNC_DRIVER_PROBE is not set
      CONFIG_GENERIC_CPU_AUTOPROBE=y
      CONFIG_REGMAP=y
      CONFIG_REGMAP_I2C=y
      CONFIG_REGMAP_SPI=y
      CONFIG_REGMAP_MMIO=y
      CONFIG_DMA_SHARED_BUFFER=y
      # CONFIG_DMA_FENCE_TRACE is not set
      CONFIG_GENERIC_ARCH_TOPOLOGY=y
      # end of Generic Driver Options
      # Bus devices
      # CONFIG_BRCMSTB_GISB_ARB is not set
      # CONFIG_MOXTET is not set
      # CONFIG_SIMPLE_PM_BUS is not set
      # CONFIG_SUN50I_DE2_BUS is not set
      # CONFIG_SUNXI_RSB is not set
      CONFIG_SUNXI_MBUS=y
      # CONFIG_SUNXI_NSI is not set
      # CONFIG_VEXPRESS_CONFIG is not set
      # end of Bus devices
      # CONFIG_CONNECTOR is not set
      # CONFIG_GNSS is not set
      CONFIG_MTD=y
      # CONFIG_MTD_TESTS is not set
      # CONFIG_MTD_REDBOOT_PARTS is not set
      # CONFIG_MTD_CMDLINE_PARTS is not set
      # CONFIG_MTD_AFS_PARTS is not set
      CONFIG_MTD_OF_PARTS=y
      # CONFIG_MTD_AR7_PARTS is not set
      # CONFIG_MTD_SUNXI_PARTS is not set
      # Partition parsers
      # end of Partition parsers
      # User Modules And Translation Layers
      CONFIG_MTD_BLKDEVS=y
      # CONFIG_MTD_CHAR is not set
      CONFIG_MTD_BLOCK=y
      # CONFIG_FTL is not set
      # CONFIG_NFTL is not set
      # CONFIG_INFTL is not set
      # CONFIG_RFD_FTL is not set
      # CONFIG_SSFDC is not set
      # CONFIG_SM_FTL is not set
      # CONFIG_MTD_OOPS is not set
      # CONFIG_MTD_PARTITIONED_MASTER is not set
      # RAM/ROM/Flash chip drivers
      # CONFIG_MTD_CFI is not set
      # CONFIG_MTD_JEDECPROBE is not set
      CONFIG_MTD_MAP_BANK_WIDTH_1=y
      CONFIG_MTD_MAP_BANK_WIDTH_2=y
      CONFIG_MTD_MAP_BANK_WIDTH_4=y
      CONFIG_MTD_CFI_I1=y
      CONFIG_MTD_CFI_I2=y
      # CONFIG_MTD_RAM is not set
      # CONFIG_MTD_ROM is not set
      # CONFIG_MTD_ABSENT is not set
      # end of RAM/ROM/Flash chip drivers
      # Mapping drivers for chip access
      # CONFIG_MTD_COMPLEX_MAPPINGS is not set
      # CONFIG_MTD_PLATRAM is not set
      # end of Mapping drivers for chip access
      # Self-contained MTD device drivers
      # CONFIG_MTD_DATAFLASH is not set
      # CONFIG_MTD_MCHP23K256 is not set
      # CONFIG_MTD_SST25L is not set
      # CONFIG_MTD_SLRAM is not set
      # CONFIG_MTD_PHRAM is not set
      # CONFIG_MTD_MTDRAM is not set
      # CONFIG_MTD_BLOCK2MTD is not set
      # Disk-On-Chip Device Drivers
      # CONFIG_MTD_DOCG3 is not set
      # end of Self-contained MTD device drivers
      # CONFIG_MTD_ONENAND is not set
      # CONFIG_MTD_RAW_NAND is not set
      # CONFIG_MTD_SPI_NAND is not set
      # sunxi-nand
      CONFIG_AW_MTD_SPINAND=y
      # CONFIG_AW_MTD_RAWNAND is not set
      CONFIG_AW_SPINAND_PHYSICAL_LAYER=y
      CONFIG_AW_SPINAND_SECURE_STORAGE=y
      # CONFIG_AW_SPINAND_PSTORE_MTD_PART is not set
      # CONFIG_AW_SPINAND_ENABLE_PHY_CRC16 is not set
      CONFIG_AW_SPINAND_SIMULATE_MULTIPLANE=y
      # CONFIG_AW_MTD_SPINAND_OOB_RAW_SPARE is not set
      # end of sunxi-nand
      # LPDDR & LPDDR2 PCM memory drivers
      # CONFIG_MTD_LPDDR is not set
      # CONFIG_MTD_LPDDR2_NVM is not set
      # end of LPDDR & LPDDR2 PCM memory drivers
      # CONFIG_MTD_SPI_NOR is not set
      CONFIG_MTD_UBI=y
      CONFIG_MTD_UBI_WL_THRESHOLD=4096
      CONFIG_MTD_UBI_BEB_LIMIT=40
      # CONFIG_MTD_UBI_FASTMAP is not set
      # CONFIG_MTD_UBI_GLUEBI is not set
      CONFIG_MTD_UBI_BLOCK=y
      CONFIG_MTD_UBI_BLOCK_MAX_ACTIVE_WORKS=4
      # CONFIG_MTD_HYPERBUS is not set
      CONFIG_DTC=y
      CONFIG_OF=y
      # CONFIG_OF_UNITTEST is not set
      CONFIG_OF_FLATTREE=y
      CONFIG_OF_EARLY_FLATTREE=y
      CONFIG_OF_KOBJ=y
      CONFIG_OF_ADDRESS=y
      CONFIG_OF_IRQ=y
      CONFIG_OF_NET=y
      CONFIG_OF_MDIO=y
      CONFIG_OF_RESERVED_MEM=y
      # CONFIG_OF_OVERLAY is not set
      CONFIG_ARCH_MIGHT_HAVE_PC_PARPORT=y
      # CONFIG_PARPORT is not set
      CONFIG_BLK_DEV=y
      # CONFIG_BLK_DEV_NULL_BLK is not set
      # CONFIG_BLK_DEV_LOOP is not set
      # CONFIG_BLK_DEV_DRBD is not set
      # CONFIG_BLK_DEV_NBD is not set
      # CONFIG_BLK_DEV_RAM is not set
      # CONFIG_CDROM_PKTCDVD is not set
      # CONFIG_ATA_OVER_ETH is not set
      # CONFIG_BLK_DEV_RBD is not set
      # NVME Support
      # CONFIG_NVME_FC is not set
      # CONFIG_NVME_TARGET is not set
      # end of NVME Support
      # Misc devices
      # CONFIG_AD525X_DPOT is not set
      # CONFIG_DUMMY_IRQ is not set
      # CONFIG_ICS932S401 is not set
      # CONFIG_ENCLOSURE_SERVICES is not set
      # CONFIG_APDS9802ALS is not set
      # CONFIG_ISL29003 is not set
      # CONFIG_ISL29020 is not set
      # CONFIG_SENSORS_TSL2550 is not set
      # CONFIG_SENSORS_BH1770 is not set
      # CONFIG_SENSORS_APDS990X is not set
      # CONFIG_HMC6352 is not set
      # CONFIG_DS1682 is not set
      # CONFIG_LATTICE_ECP3_CONFIG is not set
      # CONFIG_SRAM is not set
      # CONFIG_XILINX_SDFEC is not set
      # CONFIG_PVPANIC is not set
      # CONFIG_HISI_HIKEY_USB is not set
      # CONFIG_SUNXI_DIRECT_GPIO is not set
      # CONFIG_C2PORT is not set
      # EEPROM support
      # CONFIG_EEPROM_AT24 is not set
      # CONFIG_EEPROM_AT25 is not set
      # CONFIG_EEPROM_LEGACY is not set
      # CONFIG_EEPROM_MAX6875 is not set
      # CONFIG_EEPROM_93CX6 is not set
      # CONFIG_EEPROM_93XX46 is not set
      # CONFIG_EEPROM_IDT_89HPESX is not set
      # CONFIG_EEPROM_EE1004 is not set
      # end of EEPROM support
      # Texas Instruments shared transport line discipline
      # CONFIG_TI_ST is not set
      # end of Texas Instruments shared transport line discipline
      # CONFIG_SENSORS_LIS3_SPI is not set
      # CONFIG_SENSORS_LIS3_I2C is not set
      # CONFIG_ALTERA_STAPL is not set
      # Intel MIC & related support
      # Intel MIC Bus Driver
      # SCIF Bus Driver
      # VOP Bus Driver
      # CONFIG_VOP_BUS is not set
      # Intel MIC Host Driver
      # Intel MIC Card Driver
      # SCIF Driver
      # Intel MIC Coprocessor State Management (COSM) Drivers
      # VOP Driver
      # end of Intel MIC & related support
      # CONFIG_ECHO is not set
      # CONFIG_MISC_RTSX_USB is not set
      CONFIG_SUNXI_RFKILL=y
      CONFIG_SUNXI_ADDR_MGT=y
      # CONFIG_SUNXI_BOOTEVENT is not set
      # sunxi Gorilla ESL platform
      # CONFIG_SUNXI_GORILLA is not set
      # end of sunxi Gorilla ESL platform
      # CONFIG_SUNXI_MIPSLOADER is not set
      # CONFIG_SUNXI_TVUTILS is not set
      # end of Misc devices
      # SCSI device support
      CONFIG_SCSI_MOD=y
      # CONFIG_RAID_ATTRS is not set
      CONFIG_SCSI=y
      CONFIG_SCSI_DMA=y
      CONFIG_SCSI_PROC_FS=y
      # SCSI support type (disk, tape, CD-ROM)
      CONFIG_BLK_DEV_SD=y
      # CONFIG_CHR_DEV_ST is not set
      # CONFIG_BLK_DEV_SR is not set
      # CONFIG_CHR_DEV_SG is not set
      # CONFIG_CHR_DEV_SCH is not set
      # CONFIG_SCSI_CONSTANTS is not set
      # CONFIG_SCSI_LOGGING is not set
      # CONFIG_SCSI_SCAN_ASYNC is not set
      # SCSI Transports
      # CONFIG_SCSI_SPI_ATTRS is not set
      # CONFIG_SCSI_FC_ATTRS is not set
      # CONFIG_SCSI_ISCSI_ATTRS is not set
      # CONFIG_SCSI_SAS_ATTRS is not set
      # CONFIG_SCSI_SAS_LIBSAS is not set
      # CONFIG_SCSI_SRP_ATTRS is not set
      # end of SCSI Transports
      CONFIG_SCSI_LOWLEVEL=y
      # CONFIG_ISCSI_TCP is not set
      # CONFIG_ISCSI_BOOT_SYSFS is not set
      # CONFIG_SCSI_UFSHCD is not set
      # CONFIG_SCSI_DEBUG is not set
      # CONFIG_SCSI_DH is not set
      # end of SCSI device support
      # CONFIG_ATA is not set
      # CONFIG_MD is not set
      # CONFIG_TARGET_CORE is not set
      CONFIG_NETDEVICES=y
      CONFIG_MII=m
      CONFIG_NET_CORE=y
      # CONFIG_BONDING is not set
      # CONFIG_DUMMY is not set
      # CONFIG_EQUALIZER is not set
      # CONFIG_NET_TEAM is not set
      # CONFIG_MACVLAN is not set
      # CONFIG_IPVLAN is not set
      # CONFIG_VXLAN is not set
      # CONFIG_GENEVE is not set
      # CONFIG_GTP is not set
      # CONFIG_MACSEC is not set
      # CONFIG_NETCONSOLE is not set
      # CONFIG_TUN is not set
      # CONFIG_TUN_VNET_CROSS_LE is not set
      # CONFIG_VETH is not set
      # CONFIG_NLMON is not set
      # CAIF transport drivers
      # Distributed Switch Architecture drivers
      # end of Distributed Switch Architecture drivers
      CONFIG_ETHERNET=y
      # CONFIG_NET_VENDOR_ALACRITECH is not set
      CONFIG_NET_VENDOR_ALLWINNER=y
      # CONFIG_SUN4I_EMAC is not set
      CONFIG_SUNXI_GMAC=m
      CONFIG_SUNXI_EXT_PHY=y
      # CONFIG_ALTERA_TSE is not set
      # CONFIG_NET_VENDOR_AMAZON is not set
      # CONFIG_NET_VENDOR_AQUANTIA is not set
      # CONFIG_NET_VENDOR_ARC is not set
      # CONFIG_NET_VENDOR_AURORA is not set
      # CONFIG_NET_VENDOR_BROADCOM is not set
      # CONFIG_NET_VENDOR_CADENCE is not set
      # CONFIG_NET_VENDOR_CAVIUM is not set
      # CONFIG_NET_VENDOR_CIRRUS is not set
      # CONFIG_NET_VENDOR_CORTINA is not set
      # CONFIG_DM9000 is not set
      # CONFIG_DNET is not set
      # CONFIG_NET_VENDOR_EZCHIP is not set
      # CONFIG_NET_VENDOR_FARADAY is not set
      # CONFIG_NET_VENDOR_GOOGLE is not set
      # CONFIG_NET_VENDOR_HISILICON is not set
      # CONFIG_NET_VENDOR_HUAWEI is not set
      # CONFIG_NET_VENDOR_INTEL is not set
      # CONFIG_NET_VENDOR_MARVELL is not set
      # CONFIG_NET_VENDOR_MELLANOX is not set
      # CONFIG_NET_VENDOR_MICREL is not set
      # CONFIG_NET_VENDOR_MICROCHIP is not set
      # CONFIG_NET_VENDOR_MICROSEMI is not set
      # CONFIG_NET_VENDOR_NATSEMI is not set
      # CONFIG_NET_VENDOR_NETRONOME is not set
      # CONFIG_NET_VENDOR_NI is not set
      # CONFIG_ETHOC is not set
      # CONFIG_NET_VENDOR_PENSANDO is not set
      # CONFIG_NET_VENDOR_QUALCOMM is not set
      # CONFIG_NET_VENDOR_RENESAS is not set
      # CONFIG_NET_VENDOR_ROCKER is not set
      # CONFIG_NET_VENDOR_SAMSUNG is not set
      # CONFIG_NET_VENDOR_SEEQ is not set
      # CONFIG_NET_VENDOR_SOLARFLARE is not set
      # CONFIG_NET_VENDOR_SMSC is not set
      # CONFIG_NET_VENDOR_SOCIONEXT is not set
      # CONFIG_NET_VENDOR_STMICRO is not set
      # CONFIG_NET_VENDOR_SYNOPSYS is not set
      # CONFIG_NET_VENDOR_VIA is not set
      # CONFIG_NET_VENDOR_WIZNET is not set
      # CONFIG_NET_VENDOR_XILINX is not set
      CONFIG_MDIO_DEVICE=y
      CONFIG_MDIO_BUS=y
      # CONFIG_MDIO_BCM_UNIMAC is not set
      # CONFIG_MDIO_BITBANG is not set
      # CONFIG_MDIO_BUS_MUX_GPIO is not set
      # CONFIG_MDIO_BUS_MUX_MMIOREG is not set
      # CONFIG_MDIO_BUS_MUX_MULTIPLEXER is not set
      # CONFIG_MDIO_HISI_FEMAC is not set
      # CONFIG_MDIO_MSCC_MIIM is not set
      # CONFIG_MDIO_SUN4I is not set
      CONFIG_PHYLIB=y
      CONFIG_SWPHY=y
      # CONFIG_LED_TRIGGER_PHY is not set
      # MII PHY device drivers
      # CONFIG_ADIN_PHY is not set
      # CONFIG_AMD_PHY is not set
      # CONFIG_AQUANTIA_PHY is not set
      # CONFIG_AX88796B_PHY is not set
      # CONFIG_AT803X_PHY is not set
      # CONFIG_BCM7XXX_PHY is not set
      # CONFIG_BCM87XX_PHY is not set
      # CONFIG_BROADCOM_PHY is not set
      # CONFIG_CICADA_PHY is not set
      # CONFIG_CORTINA_PHY is not set
      # CONFIG_DAVICOM_PHY is not set
      # CONFIG_DP83822_PHY is not set
      # CONFIG_DP83TC811_PHY is not set
      # CONFIG_DP83848_PHY is not set
      # CONFIG_DP83867_PHY is not set
      CONFIG_FIXED_PHY=y
      # CONFIG_ICPLUS_PHY is not set
      # CONFIG_INTEL_XWAY_PHY is not set
      # CONFIG_LSI_ET1011C_PHY is not set
      # CONFIG_LXT_PHY is not set
      # CONFIG_MARVELL_PHY is not set
      # CONFIG_MARVELL_10G_PHY is not set
      # CONFIG_MICREL_PHY is not set
      # CONFIG_MICROCHIP_PHY is not set
      # CONFIG_MICROCHIP_T1_PHY is not set
      # CONFIG_MICROSEMI_PHY is not set
      # CONFIG_NATIONAL_PHY is not set
      # CONFIG_NXP_TJA11XX_PHY is not set
      # CONFIG_QSEMI_PHY is not set
      CONFIG_REALTEK_PHY=y
      # CONFIG_RENESAS_PHY is not set
      # CONFIG_ROCKCHIP_PHY is not set
      # CONFIG_RTL8363_NB is not set
      # CONFIG_SMSC_PHY is not set
      # CONFIG_STE10XP is not set
      # CONFIG_TERANETICS_PHY is not set
      # CONFIG_VITESSE_PHY is not set
      # CONFIG_XILINX_GMII2RGMII is not set
      # CONFIG_MICREL_KS8995MA is not set
      # CONFIG_PPP is not set
      # CONFIG_SLIP is not set
      # CONFIG_USB_NET_DRIVERS is not set
      CONFIG_WLAN=y
      # CONFIG_WIRELESS_WDS is not set
      # CONFIG_WLAN_VENDOR_ADMTEK is not set
      # CONFIG_WLAN_VENDOR_ATH is not set
      # CONFIG_WLAN_VENDOR_ATMEL is not set
      # CONFIG_WLAN_VENDOR_BROADCOM is not set
      # CONFIG_WLAN_VENDOR_CISCO is not set
      # CONFIG_WLAN_VENDOR_INTEL is not set
      # CONFIG_WLAN_VENDOR_INTERSIL is not set
      # CONFIG_WLAN_VENDOR_MARVELL is not set
      # CONFIG_WLAN_VENDOR_MEDIATEK is not set
      # CONFIG_WLAN_VENDOR_RALINK is not set
      # CONFIG_WLAN_VENDOR_REALTEK is not set
      # CONFIG_WLAN_VENDOR_RSI is not set
      # CONFIG_WLAN_VENDOR_ST is not set
      # CONFIG_WLAN_VENDOR_TI is not set
      # CONFIG_WLAN_VENDOR_ZYDAS is not set
      # CONFIG_WLAN_VENDOR_QUANTENNA is not set
      # CONFIG_XR829_WLAN is not set
      # CONFIG_XR819S_WLAN is not set
      # CONFIG_SPARD_WLAN_SUPPORT is not set
      # CONFIG_BCMDHD is not set
      # CONFIG_AIC_WLAN_SUPPORT is not set
      CONFIG_RTL8723DS=m
      # CONFIG_USB_NET_RNDIS_WLAN is not set
      # CONFIG_VIRT_WIFI is not set
      # Enable WiMAX (Networking options) to see the WiMAX drivers
      # CONFIG_WAN is not set
      # CONFIG_NETDEVSIM is not set
      # CONFIG_NET_FAILOVER is not set
      # CONFIG_ISDN is not set
      # CONFIG_NVM is not set
      # Input device support
      CONFIG_INPUT=y
      # CONFIG_INPUT_LEDS is not set
      # CONFIG_INPUT_FF_MEMLESS is not set
      # CONFIG_INPUT_POLLDEV is not set
      # CONFIG_INPUT_SPARSEKMAP is not set
      # CONFIG_INPUT_MATRIXKMAP is not set
      # Userland interfaces
      # CONFIG_INPUT_MOUSEDEV is not set
      # CONFIG_INPUT_JOYDEV is not set
      CONFIG_INPUT_EVDEV=y
      # CONFIG_INPUT_EVBUG is not set
      CONFIG_INPUT_SENSORINIT=y
      # Input Device Drivers
      CONFIG_INPUT_KEYBOARD=y
      # CONFIG_KEYBOARD_ADP5588 is not set
      # CONFIG_KEYBOARD_ADP5589 is not set
      # CONFIG_KEYBOARD_ATKBD is not set
      # CONFIG_KEYBOARD_QT1050 is not set
      # CONFIG_KEYBOARD_QT1070 is not set
      # CONFIG_KEYBOARD_QT2160 is not set
      # CONFIG_KEYBOARD_DLINK_DIR685 is not set
      # CONFIG_KEYBOARD_LKKBD is not set
      # CONFIG_KEYBOARD_GPIO is not set
      # CONFIG_KEYBOARD_GPIO_POLLED is not set
      # CONFIG_KEYBOARD_TCA6416 is not set
      # CONFIG_KEYBOARD_TCA8418 is not set
      # CONFIG_KEYBOARD_MATRIX is not set
      # CONFIG_KEYBOARD_LM8323 is not set
      # CONFIG_KEYBOARD_LM8333 is not set
      # CONFIG_KEYBOARD_MAX7359 is not set
      # CONFIG_KEYBOARD_MCS is not set
      # CONFIG_KEYBOARD_MPR121 is not set
      # CONFIG_KEYBOARD_NEWTON is not set
      # CONFIG_KEYBOARD_OPENCORES is not set
      # CONFIG_KEYBOARD_SAMSUNG is not set
      # CONFIG_KEYBOARD_STOWAWAY is not set
      # CONFIG_KEYBOARD_SUNKBD is not set
      # CONFIG_KEYBOARD_SUN4I_LRADC is not set
      # CONFIG_KEYBOARD_OMAP4 is not set
      # CONFIG_KEYBOARD_TM2_TOUCHKEY is not set
      # CONFIG_KEYBOARD_XTKBD is not set
      # CONFIG_KEYBOARD_CAP11XX is not set
      # CONFIG_KEYBOARD_BCM is not set
      # CONFIG_KEYBOARD_SUNXI is not set
      # CONFIG_KEYBOARD_TPKEY is not set
      # CONFIG_INPUT_MOUSE is not set
      # CONFIG_INPUT_JOYSTICK is not set
      # CONFIG_INPUT_TABLET is not set
      CONFIG_INPUT_TOUCHSCREEN=y
      CONFIG_TOUCHSCREEN_PROPERTIES=y
      # CONFIG_TOUCHSCREEN_ADS7846 is not set
      # CONFIG_TOUCHSCREEN_AD7877 is not set
      # CONFIG_TOUCHSCREEN_AD7879 is not set
      # CONFIG_TOUCHSCREEN_AR1021_I2C is not set
      # CONFIG_TOUCHSCREEN_ATMEL_MXT is not set
      # CONFIG_TOUCHSCREEN_AUO_PIXCIR is not set
      # CONFIG_TOUCHSCREEN_BU21013 is not set
      # CONFIG_TOUCHSCREEN_BU21029 is not set
      # CONFIG_TOUCHSCREEN_CHIPONE_ICN8318 is not set
      # CONFIG_TOUCHSCREEN_CY8CTMG110 is not set
      # CONFIG_TOUCHSCREEN_CYTTSP_CORE is not set
      # CONFIG_TOUCHSCREEN_CYTTSP4_CORE is not set
      # CONFIG_TOUCHSCREEN_DYNAPRO is not set
      # CONFIG_TOUCHSCREEN_HAMPSHIRE is not set
      # CONFIG_TOUCHSCREEN_EETI is not set
      # CONFIG_TOUCHSCREEN_EGALAX is not set
      # CONFIG_TOUCHSCREEN_EGALAX_SERIAL is not set
      # CONFIG_TOUCHSCREEN_EXC3000 is not set
      # CONFIG_TOUCHSCREEN_FUJITSU is not set
      # CONFIG_TOUCHSCREEN_GOODIX is not set
      # CONFIG_TOUCHSCREEN_HIDEEP is not set
      # CONFIG_TOUCHSCREEN_ILI210X is not set
      # CONFIG_TOUCHSCREEN_S6SY761 is not set
      # CONFIG_TOUCHSCREEN_GUNZE is not set
      # CONFIG_TOUCHSCREEN_EKTF2127 is not set
      # CONFIG_TOUCHSCREEN_ELAN is not set
      # CONFIG_TOUCHSCREEN_ELO is not set
      # CONFIG_TOUCHSCREEN_WACOM_W8001 is not set
      # CONFIG_TOUCHSCREEN_WACOM_I2C is not set
      # CONFIG_TOUCHSCREEN_MAX11801 is not set
      # CONFIG_TOUCHSCREEN_MCS5000 is not set
      # CONFIG_TOUCHSCREEN_MMS114 is not set
      # CONFIG_TOUCHSCREEN_MELFAS_MIP4 is not set
      # CONFIG_TOUCHSCREEN_MTOUCH is not set
      # CONFIG_TOUCHSCREEN_IMX6UL_TSC is not set
      # CONFIG_TOUCHSCREEN_INEXIO is not set
      # CONFIG_TOUCHSCREEN_MK712 is not set
      # CONFIG_TOUCHSCREEN_PENMOUNT is not set
      # CONFIG_TOUCHSCREEN_EDT_FT5X06 is not set
      # CONFIG_TOUCHSCREEN_TOUCHRIGHT is not set
      # CONFIG_TOUCHSCREEN_TOUCHWIN is not set
      # CONFIG_TOUCHSCREEN_PIXCIR is not set
      # CONFIG_TOUCHSCREEN_WDT87XX_I2C is not set
      # CONFIG_TOUCHSCREEN_USB_COMPOSITE is not set
      # CONFIG_TOUCHSCREEN_TOUCHIT213 is not set
      # CONFIG_TOUCHSCREEN_TSC_SERIO is not set
      # CONFIG_TOUCHSCREEN_TSC2004 is not set
      # CONFIG_TOUCHSCREEN_TSC2005 is not set
      # CONFIG_TOUCHSCREEN_TSC2007 is not set
      # CONFIG_TOUCHSCREEN_RM_TS is not set
      # CONFIG_TOUCHSCREEN_SILEAD is not set
      # CONFIG_TOUCHSCREEN_SIS_I2C is not set
      # CONFIG_TOUCHSCREEN_ST1232 is not set
      # CONFIG_TOUCHSCREEN_STMFTS is not set
      # CONFIG_TOUCHSCREEN_SUN4I is not set
      # CONFIG_TOUCHSCREEN_SUNXI is not set
      # CONFIG_TOUCHSCREEN_SUR40 is not set
      # CONFIG_TOUCHSCREEN_SURFACE3_SPI is not set
      # CONFIG_TOUCHSCREEN_SX8654 is not set
      # CONFIG_TOUCHSCREEN_TPS6507X is not set
      # CONFIG_TOUCHSCREEN_ZET6223 is not set
      # CONFIG_TOUCHSCREEN_ZFORCE is not set
      # CONFIG_TOUCHSCREEN_ROHM_BU21023 is not set
      # CONFIG_TOUCHSCREEN_IQS5XX is not set
      CONFIG_TOUCHSCREEN_GSLX680NEW=m
      CONFIG_TOUCHSCREEN_GT9XXNEW_TS=m
      # CONFIG_TOUCHSCREEN_GT9XXNEWDUP_TS is not set
      CONFIG_TOUCHSCREEN_FTS=y
      # CONFIG_INPUT_MISC is not set
      # CONFIG_RMI4_CORE is not set
      CONFIG_INPUT_SENSOR=y
      # CONFIG_SENSORS_SC7A20 is not set
      # CONFIG_SENSORS_MIR3DA is not set
      # CONFIG_STK3X1X is not set
      # CONFIG_SUNXI_TPADC is not set
      CONFIG_SUNXI_GPADC=m
      # Hardware I/O ports
      # CONFIG_SERIO is not set
      # CONFIG_GAMEPORT is not set
      # end of Hardware I/O ports
      # end of Input device support
      # Character devices
      CONFIG_TTY=y
      # CONFIG_VT is not set
      CONFIG_UNIX98_PTYS=y
      # CONFIG_LEGACY_PTYS is not set
      # CONFIG_SERIAL_NONSTANDARD is not set
      # CONFIG_N_GSM is not set
      # CONFIG_TRACE_SINK is not set
      # CONFIG_NULL_TTY is not set
      # CONFIG_LDISC_AUTOLOAD is not set
      # CONFIG_DEVMEM is not set
      # CONFIG_DEVKMEM is not set
      # Serial drivers
      # CONFIG_SERIAL_8250 is not set
      # Non-8250 serial port support
      # CONFIG_SERIAL_EARLYCON_ARM_SEMIHOST is not set
      # CONFIG_SERIAL_SAMSUNG is not set
      # CONFIG_SERIAL_MAX3100 is not set
      # CONFIG_SERIAL_MAX310X is not set
      # CONFIG_SERIAL_UARTLITE is not set
      CONFIG_SERIAL_CORE=y
      CONFIG_SERIAL_CORE_CONSOLE=y
      # CONFIG_SERIAL_SIFIVE is not set
      # CONFIG_SERIAL_SCCNXP is not set
      # CONFIG_SERIAL_SC16IS7XX is not set
      # CONFIG_SERIAL_BCM63XX is not set
      # CONFIG_SERIAL_ALTERA_JTAGUART is not set
      # CONFIG_SERIAL_ALTERA_UART is not set
      # CONFIG_SERIAL_IFX6X60 is not set
      # CONFIG_SERIAL_XILINX_PS_UART is not set
      # CONFIG_SERIAL_ARC is not set
      # CONFIG_SERIAL_FSL_LPUART is not set
      # CONFIG_SERIAL_FSL_LINFLEXUART is not set
      # CONFIG_SERIAL_CONEXANT_DIGICOLOR is not set
      # CONFIG_SERIAL_ST_ASC is not set
      # CONFIG_SERIAL_SPRD is not set
      CONFIG_SERIAL_SUNXI=y
      # CONFIG_SERIAL_SUNXI_DMA is not set
      CONFIG_SERIAL_SUNXI_CONSOLE=y
      # CONFIG_SERIAL_SUNXI_EARLYCON is not set
      # end of Serial drivers
      # CONFIG_SERIAL_DEV_BUS is not set
      # CONFIG_TTY_PRINTK is not set
      # CONFIG_HVC_DCC is not set
      # CONFIG_IPMI_HANDLER is not set
      # CONFIG_IPMB_DEVICE_INTERFACE is not set
      # CONFIG_HW_RANDOM is not set
      # CONFIG_RAW_DRIVER is not set
      # CONFIG_TCG_TPM is not set
      # CONFIG_XILLYBUS is not set
      # CONFIG_SUNXI_BS83B16C is not set
      # end of Character devices
      # CONFIG_RANDOM_TRUST_BOOTLOADER is not set
      CONFIG_DUMP_REG=y
      CONFIG_DUMP_REG_MISC=y
      CONFIG_SUNXI_G2D=y
      CONFIG_SUNXI_G2D_MIXER=y
      CONFIG_SUNXI_G2D_ROTATE=y
      CONFIG_SUNXI_SYNCFENCE=y
      # CONFIG_SUNXI_DI is not set
      # CONFIG_SUNXI_STANDBY_DEBUG is not set
      # CONFIG_SUNXI_SYS_INFO is not set
      # CONFIG_SUNXI_SMC is not set
      # I2C support
      CONFIG_I2C=y
      CONFIG_I2C_BOARDINFO=y
      # CONFIG_I2C_COMPAT is not set
      CONFIG_I2C_CHARDEV=y
      # CONFIG_I2C_MUX is not set
      # CONFIG_I2C_HELPER_AUTO is not set
      # CONFIG_I2C_SMBUS is not set
      # I2C Algorithms
      # CONFIG_I2C_ALGOBIT is not set
      # CONFIG_I2C_ALGOPCF is not set
      # CONFIG_I2C_ALGOPCA is not set
      # end of I2C Algorithms
      # I2C Hardware Bus support
      # I2C system bus drivers (mostly embedded / system-on-chip)
      # CONFIG_I2C_CBUS_GPIO is not set
      # CONFIG_I2C_DESIGNWARE_PLATFORM is not set
      # CONFIG_I2C_EMEV2 is not set
      # CONFIG_I2C_GPIO is not set
      # CONFIG_I2C_MV64XXX is not set
      # CONFIG_I2C_OCORES is not set
      CONFIG_I2C_SUNXI=y
      # CONFIG_I2C_PCA_PLATFORM is not set
      # CONFIG_I2C_RK3X is not set
      # CONFIG_I2C_SIMTEC is not set
      # CONFIG_I2C_XILINX is not set
      # External I2C/SMBus adapter drivers
      # CONFIG_I2C_DIOLAN_U2C is not set
      # CONFIG_I2C_PARPORT_LIGHT is not set
      # CONFIG_I2C_ROBOTFUZZ_OSIF is not set
      # CONFIG_I2C_TAOS_EVM is not set
      # CONFIG_I2C_TINY_USB is not set
      # Other I2C/SMBus bus drivers
      # end of I2C Hardware Bus support
      # CONFIG_I2C_STUB is not set
      CONFIG_I2C_SLAVE=y
      # CONFIG_I2C_SLAVE_EEPROM is not set
      # CONFIG_I2C_DEBUG_CORE is not set
      # CONFIG_I2C_DEBUG_ALGO is not set
      # CONFIG_I2C_DEBUG_BUS is not set
      # end of I2C support
      # CONFIG_I3C is not set
      CONFIG_SPI=y
      # CONFIG_SPI_DEBUG is not set
      CONFIG_SPI_MASTER=y
      # CONFIG_SPI_MEM is not set
      # SPI Master Controller Drivers
      # CONFIG_SPI_ALTERA is not set
      # CONFIG_SPI_AXI_SPI_ENGINE is not set
      # CONFIG_SPI_BITBANG is not set
      # CONFIG_SPI_CADENCE is not set
      # CONFIG_SPI_DESIGNWARE is not set
      # CONFIG_SPI_NXP_FLEXSPI is not set
      # CONFIG_SPI_GPIO is not set
      # CONFIG_SPI_FSL_SPI is not set
      # CONFIG_SPI_OC_TINY is not set
      # CONFIG_SPI_ROCKCHIP is not set
      # CONFIG_SPI_SC18IS602 is not set
      # CONFIG_SPI_SIFIVE is not set
      # CONFIG_SPI_SUN4I is not set
      # CONFIG_SPI_SUN6I is not set
      # CONFIG_SPI_MXIC is not set
      CONFIG_SPI_SUNXI=y
      # CONFIG_SPI_XCOMM is not set
      # CONFIG_SPI_XILINX is not set
      # CONFIG_SPI_ZYNQMP_GQSPI is not set
      # SPI Protocol Masters
      CONFIG_SPI_SPIDEV=y
      # CONFIG_SPI_LOOPBACK_TEST is not set
      # CONFIG_SPI_TLE62X0 is not set
      # CONFIG_SPI_SLAVE is not set
      # CONFIG_SPMI is not set
      # CONFIG_HSI is not set
      # CONFIG_PPS is not set
      # PTP clock support
      # CONFIG_PTP_1588_CLOCK is not set
      # Enable PHYLIB and NETWORK_PHY_TIMESTAMPING to see the additional clocks.
      # end of PTP clock support
      CONFIG_PINCTRL=y
      CONFIG_PINMUX=y
      CONFIG_PINCONF=y
      CONFIG_GENERIC_PINCONF=y
      # CONFIG_DEBUG_PINCTRL is not set
      # CONFIG_PINCTRL_AMD is not set
      # CONFIG_PINCTRL_MCP23S08 is not set
      # CONFIG_PINCTRL_SINGLE is not set
      # CONFIG_PINCTRL_SX150X is not set
      # CONFIG_PINCTRL_STMFX is not set
      # CONFIG_PINCTRL_OCELOT is not set
      # Allwinner SOC PINCTRL DRIVER
      CONFIG_PINCTRL_SUNXI=y
      # CONFIG_PINCTRL_SUNXI_DEBUGFS is not set
      # CONFIG_PINCTRL_SUNXI_TEST is not set
      # CONFIG_PINCTRL_SUN8IW15P1 is not set
      # CONFIG_PINCTRL_SUN8IW15P1_R is not set
      CONFIG_PINCTRL_SUN8IW20=y
      # CONFIG_PINCTRL_SUN50IW9 is not set
      # CONFIG_PINCTRL_SUN50IW9_R is not set
      # CONFIG_PINCTRL_SUN50IW10P1 is not set
      # CONFIG_PINCTRL_SUN50IW10P1_R is not set
      # CONFIG_PINCTRL_SUN50IW12 is not set
      # CONFIG_PINCTRL_SUN50IW12_R is not set
      # CONFIG_PINCTRL_SUN55IW3 is not set
      # CONFIG_PINCTRL_SUN55IW3_R is not set
      # CONFIG_PINCTRL_SUN4I_A10 is not set
      # CONFIG_PINCTRL_SUN5I is not set
      # CONFIG_PINCTRL_SUN6I_A31 is not set
      # CONFIG_PINCTRL_SUN6I_A31_R is not set
      # CONFIG_PINCTRL_SUN8I_A23 is not set
      # CONFIG_PINCTRL_SUN8I_A33 is not set
      # CONFIG_PINCTRL_SUN8I_A83T is not set
      # CONFIG_PINCTRL_SUN8I_A83T_R is not set
      # CONFIG_PINCTRL_SUN8I_A23_R is not set
      # CONFIG_PINCTRL_SUN8I_H3 is not set
      # CONFIG_PINCTRL_SUN8I_H3_R is not set
      # CONFIG_PINCTRL_SUN8I_V3S is not set
      # CONFIG_PINCTRL_SUN9I_A80 is not set
      # CONFIG_PINCTRL_SUN9I_A80_R is not set
      # CONFIG_PINCTRL_SUN50I_A64 is not set
      # CONFIG_PINCTRL_SUN50I_A64_R is not set
      # CONFIG_PINCTRL_SUN50I_A100 is not set
      # CONFIG_PINCTRL_SUN50I_A100_R is not set
      # CONFIG_PINCTRL_SUN50I_H5 is not set
      # CONFIG_PINCTRL_SUN50I_H6 is not set
      # CONFIG_PINCTRL_SUN50I_H6_R is not set
      # end of Allwinner SOC PINCTRL DRIVER
      CONFIG_ARCH_HAVE_CUSTOM_GPIO_H=y
      CONFIG_GPIOLIB=y
      CONFIG_GPIOLIB_FASTPATH_LIMIT=512
      CONFIG_OF_GPIO=y
      # CONFIG_DEBUG_GPIO is not set
      CONFIG_GPIO_SYSFS=y
      # Memory mapped GPIO drivers
      # CONFIG_GPIO_74XX_MMIO is not set
      # CONFIG_GPIO_ALTERA is not set
      # CONFIG_GPIO_SUNXI is not set
      # CONFIG_GPIO_CADENCE is not set
      # CONFIG_GPIO_DWAPB is not set
      # CONFIG_GPIO_FTGPIO010 is not set
      # CONFIG_GPIO_GENERIC_PLATFORM is not set
      # CONFIG_GPIO_GRGPIO is not set
      # CONFIG_GPIO_HLWD is not set
      # CONFIG_GPIO_MB86S7X is not set
      # CONFIG_GPIO_MPC8XXX is not set
      # CONFIG_GPIO_SAMA5D2_PIOBU is not set
      # CONFIG_GPIO_SYSCON is not set
      # CONFIG_GPIO_XILINX is not set
      # CONFIG_GPIO_ZEVIO is not set
      # CONFIG_GPIO_AMD_FCH is not set
      # end of Memory mapped GPIO drivers
      # I2C GPIO expanders
      # CONFIG_GPIO_ADP5588 is not set
      # CONFIG_GPIO_ADNP is not set
      # CONFIG_GPIO_BS83B16C is not set
      # CONFIG_GPIO_GW_PLD is not set
      # CONFIG_GPIO_MAX7300 is not set
      # CONFIG_GPIO_MAX732X is not set
      # CONFIG_GPIO_PCA953X is not set
      # CONFIG_GPIO_PCF857X is not set
      # CONFIG_GPIO_TPIC2810 is not set
      # end of I2C GPIO expanders
      # MFD GPIO expanders
      # CONFIG_HTC_EGPIO is not set
      # end of MFD GPIO expanders
      # SPI GPIO expanders
      # CONFIG_GPIO_74X164 is not set
      # CONFIG_GPIO_MAX3191X is not set
      # CONFIG_GPIO_MAX7301 is not set
      # CONFIG_GPIO_MC33880 is not set
      # CONFIG_GPIO_PISOSR is not set
      # CONFIG_GPIO_XRA1403 is not set
      # end of SPI GPIO expanders
      # USB GPIO expanders
      # end of USB GPIO expanders
      # CONFIG_GPIO_MOCKUP is not set
      # CONFIG_W1 is not set
      # CONFIG_POWER_AVS is not set
      # CONFIG_POWER_RESET is not set
      CONFIG_POWER_SUPPLY=y
      # CONFIG_POWER_SUPPLY_DEBUG is not set
      CONFIG_POWER_SUPPLY_HWMON=y
      # CONFIG_PDA_POWER is not set
      # CONFIG_TEST_POWER is not set
      # CONFIG_CHARGER_ADP5061 is not set
      # CONFIG_BATTERY_DS2780 is not set
      # CONFIG_BATTERY_DS2781 is not set
      # CONFIG_BATTERY_DS2782 is not set
      # CONFIG_BATTERY_SBS is not set
      # CONFIG_CHARGER_SBS is not set
      # CONFIG_BATTERY_BQ27XXX is not set
      # CONFIG_BATTERY_MAX17040 is not set
      # CONFIG_BATTERY_MAX17042 is not set
      # CONFIG_CHARGER_MAX8903 is not set
      # CONFIG_CHARGER_LP8727 is not set
      # CONFIG_CHARGER_GPIO is not set
      # CONFIG_CHARGER_MANAGER is not set
      # CONFIG_CHARGER_LT3651 is not set
      # CONFIG_CHARGER_DETECTOR_MAX14656 is not set
      # CONFIG_CHARGER_BQ2415X is not set
      # CONFIG_CHARGER_BQ24257 is not set
      # CONFIG_CHARGER_BQ24735 is not set
      # CONFIG_CHARGER_BQ25890 is not set
      # CONFIG_CHARGER_SMB347 is not set
      # CONFIG_BATTERY_GAUGE_LTC2941 is not set
      # CONFIG_CHARGER_RT9455 is not set
      # CONFIG_CHARGER_UCS1002 is not set
      CONFIG_HWMON=y
      # CONFIG_HWMON_DEBUG_CHIP is not set
      # Native drivers
      # CONFIG_SENSORS_AD7314 is not set
      # CONFIG_SENSORS_AD7414 is not set
      # CONFIG_SENSORS_AD7418 is not set
      # CONFIG_SENSORS_ADM1021 is not set
      # CONFIG_SENSORS_ADM1025 is not set
      # CONFIG_SENSORS_ADM1026 is not set
      # CONFIG_SENSORS_ADM1029 is not set
      # CONFIG_SENSORS_ADM1031 is not set
      # CONFIG_SENSORS_ADM9240 is not set
      # CONFIG_SENSORS_ADT7310 is not set
      # CONFIG_SENSORS_ADT7410 is not set
      # CONFIG_SENSORS_ADT7411 is not set
      # CONFIG_SENSORS_ADT7462 is not set
      # CONFIG_SENSORS_ADT7470 is not set
      # CONFIG_SENSORS_ADT7475 is not set
      # CONFIG_SENSORS_AS370 is not set
      # CONFIG_SENSORS_ASC7621 is not set
      # CONFIG_SENSORS_ASPEED is not set
      # CONFIG_SENSORS_ATXP1 is not set
      # CONFIG_SENSORS_DS620 is not set
      # CONFIG_SENSORS_DS1621 is not set
      # CONFIG_SENSORS_F71805F is not set
      # CONFIG_SENSORS_F71882FG is not set
      # CONFIG_SENSORS_F75375S is not set
      # CONFIG_SENSORS_GL518SM is not set
      # CONFIG_SENSORS_GL520SM is not set
      # CONFIG_SENSORS_G760A is not set
      # CONFIG_SENSORS_G762 is not set
      # CONFIG_SENSORS_GPIO_FAN is not set
      # CONFIG_SENSORS_HIH6130 is not set
      # CONFIG_SENSORS_IT87 is not set
      # CONFIG_SENSORS_JC42 is not set
      # CONFIG_SENSORS_POWR1220 is not set
      # CONFIG_SENSORS_LINEAGE is not set
      # CONFIG_SENSORS_LTC2945 is not set
      # CONFIG_SENSORS_LTC2990 is not set
      # CONFIG_SENSORS_LTC4151 is not set
      # CONFIG_SENSORS_LTC4215 is not set
      # CONFIG_SENSORS_LTC4222 is not set
      # CONFIG_SENSORS_LTC4245 is not set
      # CONFIG_SENSORS_LTC4260 is not set
      # CONFIG_SENSORS_LTC4261 is not set
      # CONFIG_SENSORS_MAX1111 is not set
      # CONFIG_SENSORS_MAX16065 is not set
      # CONFIG_SENSORS_MAX1619 is not set
      # CONFIG_SENSORS_MAX1668 is not set
      # CONFIG_SENSORS_MAX197 is not set
      # CONFIG_SENSORS_MAX31722 is not set
      # CONFIG_SENSORS_MAX6621 is not set
      # CONFIG_SENSORS_MAX6639 is not set
      # CONFIG_SENSORS_MAX6642 is not set
      # CONFIG_SENSORS_MAX6650 is not set
      # CONFIG_SENSORS_MAX6697 is not set
      # CONFIG_SENSORS_MAX31790 is not set
      # CONFIG_SENSORS_MCP3021 is not set
      # CONFIG_SENSORS_TC654 is not set
      # CONFIG_SENSORS_ADCXX is not set
      # CONFIG_SENSORS_LM63 is not set
      # CONFIG_SENSORS_LM70 is not set
      # CONFIG_SENSORS_LM73 is not set
      # CONFIG_SENSORS_LM75 is not set
      # CONFIG_SENSORS_LM77 is not set
      # CONFIG_SENSORS_LM78 is not set
      # CONFIG_SENSORS_LM80 is not set
      # CONFIG_SENSORS_LM83 is not set
      # CONFIG_SENSORS_LM85 is not set
      # CONFIG_SENSORS_LM87 is not set
      # CONFIG_SENSORS_LM90 is not set
      # CONFIG_SENSORS_LM92 is not set
      # CONFIG_SENSORS_LM93 is not set
      # CONFIG_SENSORS_LM95234 is not set
      # CONFIG_SENSORS_LM95241 is not set
      # CONFIG_SENSORS_LM95245 is not set
      # CONFIG_SENSORS_PC87360 is not set
      # CONFIG_SENSORS_PC87427 is not set
      # CONFIG_SENSORS_NTC_THERMISTOR is not set
      # CONFIG_SENSORS_NCT6683 is not set
      # CONFIG_SENSORS_NCT6775 is not set
      # CONFIG_SENSORS_NCT7802 is not set
      # CONFIG_SENSORS_NCT7904 is not set
      # CONFIG_SENSORS_NPCM7XX is not set
      # CONFIG_SENSORS_OCC_P8_I2C is not set
      # CONFIG_SENSORS_PCF8591 is not set
      # CONFIG_PMBUS is not set
      # CONFIG_SENSORS_PWM_FAN is not set
      # CONFIG_SENSORS_SHT15 is not set
      # CONFIG_SENSORS_SHT21 is not set
      # CONFIG_SENSORS_SHT3x is not set
      # CONFIG_SENSORS_SHTC1 is not set
      # CONFIG_SENSORS_DME1737 is not set
      # CONFIG_SENSORS_EMC1403 is not set
      # CONFIG_SENSORS_EMC2103 is not set
      # CONFIG_SENSORS_EMC6W201 is not set
      # CONFIG_SENSORS_SMSC47M1 is not set
      # CONFIG_SENSORS_SMSC47M192 is not set
      # CONFIG_SENSORS_SMSC47B397 is not set
      # CONFIG_SENSORS_STTS751 is not set
      # CONFIG_SENSORS_SMM665 is not set
      # CONFIG_SENSORS_ADC128D818 is not set
      # CONFIG_SENSORS_ADS7828 is not set
      # CONFIG_SENSORS_ADS7871 is not set
      # CONFIG_SENSORS_AMC6821 is not set
      # CONFIG_SENSORS_INA209 is not set
      # CONFIG_SENSORS_INA2XX is not set
      # CONFIG_SENSORS_INA3221 is not set
      # CONFIG_SENSORS_TC74 is not set
      # CONFIG_SENSORS_THMC50 is not set
      # CONFIG_SENSORS_TMP102 is not set
      # CONFIG_SENSORS_TMP103 is not set
      # CONFIG_SENSORS_TMP108 is not set
      # CONFIG_SENSORS_TMP401 is not set
      # CONFIG_SENSORS_TMP421 is not set
      # CONFIG_SENSORS_VT1211 is not set
      # CONFIG_SENSORS_W83773G is not set
      # CONFIG_SENSORS_W83781D is not set
      # CONFIG_SENSORS_W83791D is not set
      # CONFIG_SENSORS_W83792D is not set
      # CONFIG_SENSORS_W83793 is not set
      # CONFIG_SENSORS_W83795 is not set
      # CONFIG_SENSORS_W83L785TS is not set
      # CONFIG_SENSORS_W83L786NG is not set
      # CONFIG_SENSORS_W83627HF is not set
      # CONFIG_SENSORS_W83627EHF is not set
      # CONFIG_THERMAL is not set
      # CONFIG_WATCHDOG is not set
      CONFIG_SSB_POSSIBLE=y
      # CONFIG_SSB is not set
      CONFIG_BCMA_POSSIBLE=y
      # CONFIG_BCMA is not set
      # Multifunction device drivers
      # CONFIG_MFD_ACX00 is not set
      # CONFIG_MFD_ACT8945A is not set
      # CONFIG_MFD_SUN4I_GPADC is not set
      # CONFIG_MFD_AS3711 is not set
      # CONFIG_MFD_AS3722 is not set
      # CONFIG_PMIC_ADP5520 is not set
      # CONFIG_MFD_AAT2870_CORE is not set
      # CONFIG_MFD_ATMEL_FLEXCOM is not set
      # CONFIG_MFD_ATMEL_HLCDC is not set
      # CONFIG_MFD_BCM590XX is not set
      # CONFIG_MFD_BD9571MWV is not set
      # CONFIG_MFD_AXP2101_I2C is not set
      # CONFIG_MFD_AXP20X_I2C is not set
      # CONFIG_MFD_MADERA is not set
      # CONFIG_MFD_ASIC3 is not set
      # CONFIG_PMIC_DA903X is not set
      # CONFIG_MFD_DA9052_SPI is not set
      # CONFIG_MFD_DA9052_I2C is not set
      # CONFIG_MFD_DA9055 is not set
      # CONFIG_MFD_DA9062 is not set
      # CONFIG_MFD_DA9063 is not set
      # CONFIG_MFD_DA9150 is not set
      # CONFIG_MFD_DLN2 is not set
      # CONFIG_MFD_MC13XXX_SPI is not set
      # CONFIG_MFD_MC13XXX_I2C is not set
      # CONFIG_MFD_HI6421_PMIC is not set
      # CONFIG_HTC_PASIC3 is not set
      # CONFIG_HTC_I2CPLD is not set
      # CONFIG_MFD_KEMPLD is not set
      # CONFIG_MFD_88PM800 is not set
      # CONFIG_MFD_88PM805 is not set
      # CONFIG_MFD_88PM860X is not set
      # CONFIG_MFD_MAX14577 is not set
      # CONFIG_MFD_MAX77620 is not set
      # CONFIG_MFD_MAX77650 is not set
      # CONFIG_MFD_MAX77686 is not set
      # CONFIG_MFD_MAX77693 is not set
      # CONFIG_MFD_MAX77843 is not set
      # CONFIG_MFD_MAX8907 is not set
      # CONFIG_MFD_MAX8925 is not set
      # CONFIG_MFD_MAX8997 is not set
      # CONFIG_MFD_MAX8998 is not set
      # CONFIG_MFD_MT6397 is not set
      # CONFIG_MFD_MENF21BMC is not set
      # CONFIG_EZX_PCAP is not set
      # CONFIG_MFD_CPCAP is not set
      # CONFIG_MFD_VIPERBOARD is not set
      # CONFIG_MFD_RETU is not set
      # CONFIG_MFD_PCF50633 is not set
      # CONFIG_MFD_PM8XXX is not set
      # CONFIG_MFD_RT5033 is not set
      # CONFIG_MFD_RC5T583 is not set
      # CONFIG_MFD_RK808 is not set
      # CONFIG_MFD_RN5T618 is not set
      # CONFIG_MFD_SEC_CORE is not set
      # CONFIG_MFD_SI476X_CORE is not set
      # CONFIG_MFD_SM501 is not set
      # CONFIG_MFD_SKY81452 is not set
      # CONFIG_MFD_SMSC is not set
      # CONFIG_ABX500_CORE is not set
      # CONFIG_MFD_STMPE is not set
      # CONFIG_MFD_SUN6I_PRCM is not set
      CONFIG_MFD_SYSCON=y
      # CONFIG_MFD_TI_AM335X_TSCADC is not set
      # CONFIG_MFD_LP3943 is not set
      # CONFIG_MFD_LP8788 is not set
      # CONFIG_MFD_TI_LMU is not set
      # CONFIG_MFD_PALMAS is not set
      # CONFIG_TPS6105X is not set
      # CONFIG_TPS65010 is not set
      # CONFIG_TPS6507X is not set
      # CONFIG_MFD_TPS65086 is not set
      # CONFIG_MFD_TPS65090 is not set
      # CONFIG_MFD_TPS65217 is not set
      # CONFIG_MFD_TI_LP873X is not set
      # CONFIG_MFD_TI_LP87565 is not set
      # CONFIG_MFD_TPS65218 is not set
      # CONFIG_MFD_TPS6586X is not set
      # CONFIG_MFD_TPS65910 is not set
      # CONFIG_MFD_TPS65912_I2C is not set
      # CONFIG_MFD_TPS65912_SPI is not set
      # CONFIG_MFD_TPS80031 is not set
      # CONFIG_TWL4030_CORE is not set
      # CONFIG_TWL6040_CORE is not set
      # CONFIG_MFD_WL1273_CORE is not set
      # CONFIG_MFD_LM3533 is not set
      # CONFIG_MFD_TC3589X is not set
      # CONFIG_MFD_T7L66XB is not set
      # CONFIG_MFD_TC6387XB is not set
      # CONFIG_MFD_TC6393XB is not set
      # CONFIG_MFD_TQMX86 is not set
      # CONFIG_MFD_LOCHNAGAR is not set
      # CONFIG_MFD_ARIZONA_I2C is not set
      # CONFIG_MFD_ARIZONA_SPI is not set
      # CONFIG_MFD_WM8400 is not set
      # CONFIG_MFD_WM831X_I2C is not set
      # CONFIG_MFD_WM831X_SPI is not set
      # CONFIG_MFD_WM8350_I2C is not set
      # CONFIG_MFD_WM8994 is not set
      # CONFIG_MFD_ROHM_BD718XX is not set
      # CONFIG_MFD_ROHM_BD70528 is not set
      # CONFIG_MFD_STPMIC1 is not set
      # CONFIG_MFD_STMFX is not set
      # end of Multifunction device drivers
      CONFIG_REGULATOR=y
      # CONFIG_REGULATOR_DEBUG is not set
      CONFIG_REGULATOR_FIXED_VOLTAGE=y
      # CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set
      # CONFIG_REGULATOR_USERSPACE_CONSUMER is not set
      # CONFIG_REGULATOR_88PG86X is not set
      # CONFIG_REGULATOR_ACT8865 is not set
      # CONFIG_REGULATOR_AD5398 is not set
      # CONFIG_REGULATOR_ANATOP is not set
      # CONFIG_SUNXI_REGULATOR_PWM is not set
      # CONFIG_REGULATOR_DA9210 is not set
      # CONFIG_REGULATOR_DA9211 is not set
      # CONFIG_REGULATOR_FAN53555 is not set
      # CONFIG_REGULATOR_GPIO is not set
      # CONFIG_REGULATOR_ISL9305 is not set
      # CONFIG_REGULATOR_ISL6271A is not set
      # CONFIG_REGULATOR_LP3971 is not set
      # CONFIG_REGULATOR_LP3972 is not set
      # CONFIG_REGULATOR_LP872X is not set
      # CONFIG_REGULATOR_LP8755 is not set
      # CONFIG_REGULATOR_LTC3589 is not set
      # CONFIG_REGULATOR_LTC3676 is not set
      # CONFIG_REGULATOR_MAX1586 is not set
      # CONFIG_REGULATOR_MAX8649 is not set
      # CONFIG_REGULATOR_MAX8660 is not set
      # CONFIG_REGULATOR_MAX8952 is not set
      # CONFIG_REGULATOR_MCP16502 is not set
      # CONFIG_REGULATOR_MT6311 is not set
      # CONFIG_REGULATOR_PFUZE100 is not set
      # CONFIG_REGULATOR_PV88060 is not set
      # CONFIG_REGULATOR_PV88080 is not set
      # CONFIG_REGULATOR_PV88090 is not set
      # CONFIG_REGULATOR_PWM is not set
      # CONFIG_REGULATOR_SLG51000 is not set
      # CONFIG_REGULATOR_SY8106A is not set
      # CONFIG_REGULATOR_SY8824X is not set
      # CONFIG_REGULATOR_TPS51632 is not set
      # CONFIG_REGULATOR_TPS62360 is not set
      # CONFIG_REGULATOR_TPS65023 is not set
      # CONFIG_REGULATOR_TPS6507X is not set
      # CONFIG_REGULATOR_TPS65132 is not set
      # CONFIG_REGULATOR_TPS6524X is not set
      # CONFIG_REGULATOR_VCTRL is not set
      CONFIG_RC_CORE=y
      CONFIG_RC_MAP=y
      CONFIG_LIRC=y
      CONFIG_RC_DECODERS=y
      # CONFIG_IR_NEC_DECODER is not set
      # CONFIG_IR_RC5_DECODER is not set
      # CONFIG_IR_RC6_DECODER is not set
      # CONFIG_IR_JVC_DECODER is not set
      # CONFIG_IR_SONY_DECODER is not set
      # CONFIG_IR_SANYO_DECODER is not set
      # CONFIG_IR_SHARP_DECODER is not set
      # CONFIG_IR_MCE_KBD_DECODER is not set
      # CONFIG_IR_XMP_DECODER is not set
      # CONFIG_IR_IMON_DECODER is not set
      # CONFIG_IR_RCMM_DECODER is not set
      CONFIG_RC_DEVICES=y
      # CONFIG_RC_ATI_REMOTE is not set
      # CONFIG_IR_HIX5HD2 is not set
      # CONFIG_IR_IMON is not set
      # CONFIG_IR_IMON_RAW is not set
      # CONFIG_IR_MCEUSB is not set
      # CONFIG_IR_REDRAT3 is not set
      # CONFIG_IR_SPI is not set
      # CONFIG_IR_STREAMZAP is not set
      # CONFIG_IR_IGORPLUGUSB is not set
      # CONFIG_IR_IGUANA is not set
      # CONFIG_IR_TTUSBIR is not set
      # CONFIG_RC_LOOPBACK is not set
      # CONFIG_IR_GPIO_CIR is not set
      # CONFIG_IR_GPIO_TX is not set
      # CONFIG_IR_PWM_TX is not set
      # CONFIG_IR_SUNXI is not set
      # CONFIG_IR_RX_SUNXI is not set
      # CONFIG_IR_TX_SUNXI is not set
      # CONFIG_IR_SERIAL is not set
      # CONFIG_IR_SIR is not set
      # CONFIG_RC_XBOX_DVD is not set
      CONFIG_MEDIA_SUPPORT=y
      # Multimedia core support
      CONFIG_MEDIA_CAMERA_SUPPORT=y
      # CONFIG_MEDIA_ANALOG_TV_SUPPORT is not set
      # CONFIG_MEDIA_DIGITAL_TV_SUPPORT is not set
      # CONFIG_MEDIA_RADIO_SUPPORT is not set
      # CONFIG_MEDIA_SDR_SUPPORT is not set
      # CONFIG_MEDIA_CEC_SUPPORT is not set
      CONFIG_MEDIA_CONTROLLER=y
      CONFIG_VIDEO_DEV=y
      CONFIG_VIDEO_V4L2_SUBDEV_API=y
      CONFIG_VIDEO_V4L2=y
      CONFIG_VIDEO_V4L2_I2C=y
      # CONFIG_VIDEO_ADV_DEBUG is not set
      # CONFIG_VIDEO_FIXED_MINOR_RANGES is not set
      CONFIG_V4L2_MEM2MEM_DEV=m
      # Media drivers
      CONFIG_MEDIA_USB_SUPPORT=y
      # Webcam devices
      CONFIG_USB_VIDEO_CLASS=y
      CONFIG_USB_VIDEO_CLASS_INPUT_EVDEV=y
      # CONFIG_USB_GSPCA is not set
      # CONFIG_USB_PWC is not set
      # CONFIG_VIDEO_CPIA2 is not set
      # CONFIG_USB_ZR364XX is not set
      # CONFIG_USB_STKWEBCAM is not set
      # CONFIG_USB_S2255 is not set
      # CONFIG_VIDEO_USBTV is not set
      # Webcam, TV (analog/digital) USB devices
      # CONFIG_VIDEO_EM28XX is not set
      CONFIG_V4L_PLATFORM_DRIVERS=y
      # CONFIG_VIDEO_CADENCE is not set
      # CONFIG_VIDEO_ASPEED is not set
      # CONFIG_VIDEO_MUX is not set
      # CONFIG_VIDEO_XILINX is not set
      # CONFIG_VIDEO_SUN4I_CSI is not set
      # CONFIG_VIDEO_SUN6I_CSI is not set
      # CONFIG_VIDEO_SUNXI_TVD is not set
      CONFIG_SUNXI_PLATFORM_DRIVERS=y
      CONFIG_VIDEO_SUNXI_VIN=m
      CONFIG_CSI_VIN=m
      # CONFIG_ENABLE_SENSOR_FLIP_OPTION is not set
      CONFIG_CSI_CCI=m
      # CONFIG_CCI is not set
      CONFIG_CCI_TO_TWI=y
      # CONFIG_FLASH is not set
      # CONFIG_ACTUATOR is not set
      # CONFIG_SENSOR_LIST is not set
      # CONFIG_BUF_AUTO_UPDATE is not set
      # CONFIG_VIN_LOG is not set
      # CONFIG_PIPELINE_RESET is not set
      # CONFIG_MULTI_FRAME is not set
      # CONFIG_SUPPORT_ISP_TDM is not set
      # CONFIG_DISPPLAY_SYNC is not set
      # CONFIG_VIN_IOMMU is not set
      # CONFIG_D3D is not set
      CONFIG_WDR=y
      # CONFIG_WDR_COMPRESS_EN is not set
      # CONFIG_SAME_I2C is not set
      # sensor driver select
      # CONFIG_SENSOR_RN6854M is not set
      # CONFIG_SENSOR_NVP6158C is not set
      # CONFIG_SENSOR_GC030A is not set
      # CONFIG_SENSOR_GC2385 is not set
      # CONFIG_SENSOR_GC5025 is not set
      # CONFIG_SENSOR_IMX278 is not set
      # CONFIG_SENSOR_IMX278_2LANE is not set
      # CONFIG_SENSOR_IMX386 is not set
      # CONFIG_SENSOR_IMX386_2LANE is not set
      CONFIG_SENSOR_OV5640=m
      # CONFIG_SENSOR_OV2775 is not set
      # CONFIG_SENSOR_GC2145 is not set
      # CONFIG_SENSOR_GC0310 is not set
      # CONFIG_SENSOR_GC2355 is not set
      # CONFIG_SENSOR_GC5024 is not set
      # CONFIG_SENSOR_GC5035 is not set
      # CONFIG_SENSOR_GC2590 is not set
      # CONFIG_SENSOR_SP5409 is not set
      # CONFIG_SENSOR_IMX214 is not set
      # CONFIG_SENSOR_IMX219 is not set
      # CONFIG_SENSOR_IMX274_SLVDS is not set
      # CONFIG_SENSOR_IMX291_DVP is not set
      # CONFIG_SENSOR_IMX291 is not set
      # CONFIG_SENSOR_IMX317 is not set
      # CONFIG_SENSOR_IMX335 is not set
      # CONFIG_SENSOR_IMX326 is not set
      # CONFIG_SENSOR_IMX477 is not set
      # CONFIG_SENSOR_OV2710 is not set
      # CONFIG_SENSOR_OV2718 is not set
      # CONFIG_SENSOR_AR0238 is not set
      # CONFIG_SENSOR_OV8858_R2A_4LANE is not set
      # CONFIG_SENSOR_OV2680 is not set
      # CONFIG_SENSOR_S5K3H5XA is not set
      # CONFIG_SENSOR_AR0238_HISPI is not set
      # CONFIG_SENSOR_NVP6134 is not set
      # CONFIG_SENSOR_NVP6324 is not set
      # CONFIG_SENSOR_TP9950 is not set
      # CONFIG_SENSOR_SC2232 is not set
      # CONFIG_SENSOR_GC02M2 is not set
      # end of sensor driver select
      # CONFIG_SENSOR_POWER is not set
      CONFIG_V4L_MEM2MEM_DRIVERS=y
      CONFIG_VIDEO_MEM2MEM_DEINTERLACE=m
      CONFIG_VIDEO_SH_VEU=m
      # CONFIG_V4L_TEST_DRIVERS is not set
      # Supported MMC/SDIO adapters
      # CONFIG_CYPRESS_FIRMWARE is not set
      CONFIG_VIDEOBUF2_CORE=y
      CONFIG_VIDEOBUF2_V4L2=y
      CONFIG_VIDEOBUF2_MEMOPS=y
      CONFIG_VIDEOBUF2_DMA_CONTIG=m
      CONFIG_VIDEOBUF2_VMALLOC=y
      # Media ancillary drivers (tuners, sensors, i2c, spi, frontends)
      # CONFIG_MEDIA_SUBDRV_AUTOSELECT is not set
      # CONFIG_VIDEO_IR_I2C is not set
      # I2C Encoders, decoders, sensors and other helper chips
      # Audio decoders, processors and mixers
      # CONFIG_VIDEO_TVAUDIO is not set
      # CONFIG_VIDEO_TDA7432 is not set
      # CONFIG_VIDEO_TDA9840 is not set
      # CONFIG_VIDEO_TDA1997X is not set
      # CONFIG_VIDEO_TEA6415C is not set
      # CONFIG_VIDEO_TEA6420 is not set
      # CONFIG_VIDEO_MSP3400 is not set
      # CONFIG_VIDEO_CS3308 is not set
      # CONFIG_VIDEO_CS5345 is not set
      # CONFIG_VIDEO_CS53L32A is not set
      # CONFIG_VIDEO_TLV320AIC23B is not set
      # CONFIG_VIDEO_UDA1342 is not set
      # CONFIG_VIDEO_WM8775 is not set
      # CONFIG_VIDEO_WM8739 is not set
      # CONFIG_VIDEO_VP27SMPX is not set
      # CONFIG_VIDEO_SONY_BTF_MPX is not set
      # RDS decoders
      # CONFIG_VIDEO_SAA6588 is not set
      # Video decoders
      # CONFIG_VIDEO_ADV7180 is not set
      # CONFIG_VIDEO_ADV7183 is not set
      # CONFIG_VIDEO_ADV748X is not set
      # CONFIG_VIDEO_ADV7604 is not set
      # CONFIG_VIDEO_ADV7842 is not set
      # CONFIG_VIDEO_BT819 is not set
      # CONFIG_VIDEO_BT856 is not set
      # CONFIG_VIDEO_BT866 is not set
      # CONFIG_VIDEO_KS0127 is not set
      # CONFIG_VIDEO_ML86V7667 is not set
      # CONFIG_VIDEO_SAA7110 is not set
      # CONFIG_VIDEO_SAA711X is not set
      # CONFIG_VIDEO_TC358743 is not set
      # CONFIG_VIDEO_TVP514X is not set
      # CONFIG_VIDEO_TVP5150 is not set
      # CONFIG_VIDEO_TVP7002 is not set
      # CONFIG_VIDEO_TW2804 is not set
      # CONFIG_VIDEO_TW9903 is not set
      # CONFIG_VIDEO_TW9906 is not set
      # CONFIG_VIDEO_TW9910 is not set
      # CONFIG_VIDEO_VPX3220 is not set
      # Video and audio decoders
      # CONFIG_VIDEO_SAA717X is not set
      # CONFIG_VIDEO_CX25840 is not set
      # Video encoders
      # CONFIG_VIDEO_SAA7127 is not set
      # CONFIG_VIDEO_SAA7185 is not set
      # CONFIG_VIDEO_ADV7170 is not set
      # CONFIG_VIDEO_ADV7175 is not set
      # CONFIG_VIDEO_ADV7343 is not set
      # CONFIG_VIDEO_ADV7393 is not set
      # CONFIG_VIDEO_ADV7511 is not set
      # CONFIG_VIDEO_AD9389B is not set
      # CONFIG_VIDEO_AK881X is not set
      # CONFIG_VIDEO_THS8200 is not set
      # Camera sensor devices
      # CONFIG_VIDEO_IMX258 is not set
      # CONFIG_VIDEO_IMX274 is not set
      # CONFIG_VIDEO_IMX319 is not set
      # CONFIG_VIDEO_IMX355 is not set
      # CONFIG_VIDEO_OV2640 is not set
      # CONFIG_VIDEO_OV2659 is not set
      # CONFIG_VIDEO_OV2680 is not set
      # CONFIG_VIDEO_OV2685 is not set
      # CONFIG_VIDEO_OV5640 is not set
      # CONFIG_VIDEO_OV5645 is not set
      # CONFIG_VIDEO_OV5647 is not set
      # CONFIG_VIDEO_OV6650 is not set
      # CONFIG_VIDEO_OV5670 is not set
      # CONFIG_VIDEO_OV5675 is not set
      # CONFIG_VIDEO_OV5695 is not set
      # CONFIG_VIDEO_OV7251 is not set
      # CONFIG_VIDEO_OV772X is not set
      # CONFIG_VIDEO_OV7640 is not set
      # CONFIG_VIDEO_OV7670 is not set
      # CONFIG_VIDEO_OV7740 is not set
      # CONFIG_VIDEO_OV8856 is not set
      # CONFIG_VIDEO_OV9640 is not set
      # CONFIG_VIDEO_OV9650 is not set
      # CONFIG_VIDEO_OV13858 is not set
      # CONFIG_VIDEO_VS6624 is not set
      # CONFIG_VIDEO_MT9M001 is not set
      # CONFIG_VIDEO_MT9M032 is not set
      # CONFIG_VIDEO_MT9M111 is not set
      # CONFIG_VIDEO_MT9P031 is not set
      # CONFIG_VIDEO_MT9T001 is not set
      # CONFIG_VIDEO_MT9T112 is not set
      # CONFIG_VIDEO_MT9V011 is not set
      # CONFIG_VIDEO_MT9V032 is not set
      # CONFIG_VIDEO_MT9V111 is not set
      # CONFIG_VIDEO_SR030PC30 is not set
      # CONFIG_VIDEO_NOON010PC30 is not set
      # CONFIG_VIDEO_M5MOLS is not set
      # CONFIG_VIDEO_RJ54N1 is not set
      # CONFIG_VIDEO_S5K6AA is not set
      # CONFIG_VIDEO_S5K6A3 is not set
      # CONFIG_VIDEO_S5K4ECGX is not set
      # CONFIG_VIDEO_S5K5BAF is not set
      # CONFIG_VIDEO_SMIAPP is not set
      # CONFIG_VIDEO_ET8EK8 is not set
      # CONFIG_VIDEO_S5C73M3 is not set
      # Lens drivers
      # CONFIG_VIDEO_AD5820 is not set
      # CONFIG_VIDEO_AK7375 is not set
      # CONFIG_VIDEO_DW9714 is not set
      # CONFIG_VIDEO_DW9807_VCM is not set
      # Flash devices
      # CONFIG_VIDEO_ADP1653 is not set
      # CONFIG_VIDEO_LM3560 is not set
      # CONFIG_VIDEO_LM3646 is not set
      # Video improvement chips
      # CONFIG_VIDEO_UPD64031A is not set
      # CONFIG_VIDEO_UPD64083 is not set
      # Audio/Video compression chips
      # CONFIG_VIDEO_SAA6752HS is not set
      # SDR tuner chips
      # Miscellaneous helper chips
      # CONFIG_VIDEO_THS7303 is not set
      # CONFIG_VIDEO_M52790 is not set
      # CONFIG_VIDEO_I2C is not set
      # CONFIG_VIDEO_ST_MIPID02 is not set
      # end of I2C Encoders, decoders, sensors and other helper chips
      # SPI helper chips
      # CONFIG_VIDEO_GS1662 is not set
      # end of SPI helper chips
      # Media SPI Adapters
      # end of Media SPI Adapters
      # Customise DVB Frontends
      # Tools to develop new frontends
      # end of Customise DVB Frontends
      CONFIG_VIDEO_ENCODER_DECODER_SUNXI=y
      # CONFIG_VIDEO_GOOGLE_DECODER_SUNXI is not set
      # Graphics support
      # CONFIG_IMX_IPUV3_CORE is not set
      # CONFIG_DRM is not set
      # CONFIG_DRM_DP_CEC is not set
      # ARM devices
      # end of ARM devices
      # ACP (Audio CoProcessor) Configuration
      # end of ACP (Audio CoProcessor) Configuration
      # Frame buffer Devices
      CONFIG_FB_CMDLINE=y
      CONFIG_FB=y
      # CONFIG_FIRMWARE_EDID is not set
      # CONFIG_FB_FOREIGN_ENDIAN is not set
      # CONFIG_FB_MODE_HELPERS is not set
      # CONFIG_FB_TILEBLITTING is not set
      # Frame buffer hardware drivers
      # CONFIG_FB_OPENCORES is not set
      # CONFIG_FB_S1D13XXX is not set
      # CONFIG_FB_SMSCUFX is not set
      # CONFIG_FB_UDL is not set
      # CONFIG_FB_IBM_GXT4500 is not set
      # CONFIG_FB_VIRTUAL is not set
      # CONFIG_FB_METRONOME is not set
      # CONFIG_FB_SIMPLE is not set
      # CONFIG_FB_SSD1307 is not set
      # Video support for sunxi
      # CONFIG_FB_CONSOLE_SUNXI is not set
      CONFIG_DISP2_SUNXI=y
      CONFIG_SUNXI_DISP2_FB_DISABLE_ROTATE=y
      # CONFIG_SUNXI_DISP2_FB_ROTATION_SUPPORT is not set
      # CONFIG_SUNXI_DISP2_FB_HW_ROTATION_SUPPORT is not set
      # CONFIG_SUNXI_DISP2_FB_DECOMPRESS_LZMA is not set
      # CONFIG_HDMI_DISP2_SUNXI is not set
      # CONFIG_HDMI2_DISP2_SUNXI is not set
      # CONFIG_HDMI_EP952_DISP2_SUNXI is not set
      # CONFIG_TV_DISP2_SUNXI is not set
      # CONFIG_VDPO_DISP2_SUNXI is not set
      # CONFIG_EDP_DISP2_SUNXI is not set
      # CONFIG_DISP2_SUNXI_BOOT_COLORBAR is not set
      # CONFIG_DISP2_SUNXI_DEBUG is not set
      # CONFIG_DISP2_SUNXI_COMPOSER is not set
      # CONFIG_DISP2_LCD_ESD_DETECT is not set
      # CONFIG_LCD_FB is not set
      # CONFIG_LCD_FB_ENABLE_DEFERRED_IO is not set
      # LCD panels select
      # CONFIG_LCD_SUPPORT_GG1P4062UTSW is not set
      # CONFIG_LCD_SUPPORT_DX0960BE40A1 is not set
      # CONFIG_LCD_SUPPORT_TFT720X1280 is not set
      # CONFIG_LCD_SUPPORT_FD055HD003S is not set
      # CONFIG_LCD_SUPPORT_HE0801A068 is not set
      # CONFIG_LCD_SUPPORT_ILI9341 is not set
      # CONFIG_LCD_SUPPORT_LH219WQ1 is not set
      # CONFIG_LCD_SUPPORT_LS029B3SX02 is not set
      # CONFIG_LCD_SUPPORT_LT070ME05000 is not set
      # CONFIG_LCD_SUPPORT_S6D7AA0X01 is not set
      # CONFIG_LCD_SUPPORT_T27P06 is not set
      # CONFIG_LCD_SUPPORT_TFT720x1280 is not set
      # CONFIG_LCD_SUPPORT_WTQ05027D01 is not set
      # CONFIG_LCD_SUPPORT_H245QBN02 is not set
      # CONFIG_LCD_SUPPORT_ST7789V is not set
      # CONFIG_LCD_SUPPORT_ST7796S is not set
      # CONFIG_LCD_SUPPORT_ST7701S is not set
      # CONFIG_LCD_SUPPORT_T30P106 is not set
      # CONFIG_LCD_SUPPORT_TO20T20000 is not set
      # CONFIG_LCD_SUPPORT_FRD450H40014 is not set
      # CONFIG_LCD_SUPPORT_S2003T46G is not set
      # CONFIG_LCD_SUPPORT_WILLIAMLCD is not set
      # CONFIG_LCD_SUPPORT_LQ101R1SX03 is not set
      # CONFIG_LCD_SUPPORT_INET_DSI_PANEL is not set
      # CONFIG_LCD_SUPPORT_WTL096601G03 is not set
      # CONFIG_LCD_SUPPORT_RT13QV005D is not set
      # CONFIG_LCD_SUPPORT_ST7789V_CPU is not set
      # CONFIG_LCD_SUPPORT_CC08021801_310_800X1280 is not set
      # CONFIG_LCD_SUPPORT_JD9366AB_3 is not set
      # CONFIG_LCD_SUPPORT_TFT08006 is not set
      CONFIG_LCD_SUPPORT_BP101WX1_206=y
      CONFIG_LCD_SUPPORT_FX070=y
      CONFIG_LCD_SUPPORT_K101IM2QA04=y
      CONFIG_LCD_SUPPORT_K101_IM2BYL02_L_800X1280=y
      CONFIG_LCD_SUPPORT_K080_IM2HYL802R_800X1280=y
      # CONFIG_LCD_SUPPORT_NT35510_MIPI is not set
      # CONFIG_LCD_SUPPORT_ST7701S_3SPI is not set
      # CONFIG_LCD_SUPPORT_D395T9375V0 is not set
      # end of LCD panels select
      # Display engine feature select
      CONFIG_DISP2_SUNXI_SUPPORT_SMBL=y
      CONFIG_DISP2_SUNXI_SUPPORT_ENAHNCE=y
      CONFIG_DISP2_SUNXI_DEVICE_OFF_ON_RELEASE=y
      # end of Display engine feature select
      # end of Video support for sunxi
      # end of Frame buffer Devices
      # Backlight & LCD device support
      # CONFIG_LCD_CLASS_DEVICE is not set
      # CONFIG_BACKLIGHT_CLASS_DEVICE is not set
      # end of Backlight & LCD device support
      # CONFIG_LOGO is not set
      # end of Graphics support
      CONFIG_SOUND=y
      CONFIG_SND=y
      CONFIG_SND_TIMER=y
      CONFIG_SND_PCM=y
      CONFIG_SND_DMAENGINE_PCM=y
      CONFIG_SND_JACK=y
      CONFIG_SND_JACK_INPUT_DEV=y
      # CONFIG_SND_MIXER_OSS is not set
      CONFIG_SND_PCM_TIMER=y
      # CONFIG_SND_HRTIMER is not set
      # CONFIG_SND_DYNAMIC_MINORS is not set
      # CONFIG_SND_SUPPORT_OLD_API is not set
      # CONFIG_SND_PROC_FS is not set
      # CONFIG_SND_VERBOSE_PRINTK is not set
      # CONFIG_SND_DEBUG is not set
      # CONFIG_SND_SEQUENCER is not set
      CONFIG_SND_DRIVERS=y
      # CONFIG_SND_DUMMY is not set
      # CONFIG_SND_ALOOP is not set
      # CONFIG_SND_MTPAV is not set
      # CONFIG_SND_SERIAL_U16550 is not set
      # CONFIG_SND_MPU401 is not set
      # HD-Audio
      # end of HD-Audio
      CONFIG_SND_HDA_PREALLOC_SIZE=64
      # CONFIG_SND_ARM is not set
      # CONFIG_SND_SPI is not set
      CONFIG_SND_USB=y
      # CONFIG_SND_USB_AUDIO is not set
      # CONFIG_SND_USB_UA101 is not set
      # CONFIG_SND_USB_CAIAQ is not set
      # CONFIG_SND_USB_6FIRE is not set
      # CONFIG_SND_USB_HIFACE is not set
      # CONFIG_SND_BCD2000 is not set
      # CONFIG_SND_USB_POD is not set
      # CONFIG_SND_USB_PODHD is not set
      # CONFIG_SND_USB_TONEPORT is not set
      # CONFIG_SND_USB_VARIAX is not set
      CONFIG_SND_SOC=y
      CONFIG_SND_SOC_GENERIC_DMAENGINE_PCM=y
      # CONFIG_SND_SOC_AMD_ACP is not set
      # CONFIG_SND_ATMEL_SOC is not set
      # CONFIG_SND_DESIGNWARE_I2S is not set
      # SoC Audio for Freescale CPUs
      # Common SoC Audio options for Freescale CPUs:
      # CONFIG_SND_SOC_FSL_ASRC is not set
      # CONFIG_SND_SOC_FSL_SAI is not set
      # CONFIG_SND_SOC_FSL_AUDMIX is not set
      # CONFIG_SND_SOC_FSL_SSI is not set
      # CONFIG_SND_SOC_FSL_SPDIF is not set
      # CONFIG_SND_SOC_FSL_ESAI is not set
      # CONFIG_SND_SOC_FSL_MICFIL is not set
      # CONFIG_SND_SOC_IMX_AUDMUX is not set
      # end of SoC Audio for Freescale CPUs
      # CONFIG_SND_I2S_HI6210_I2S is not set
      # CONFIG_SND_I2S_HI3660_I2S is not set
      # CONFIG_SND_SOC_IMG is not set
      # CONFIG_SND_SOC_MTK_BTCVSD is not set
      # CONFIG_SND_SOC_SOF_TOPLEVEL is not set
      # STMicroelectronics STM32 SOC audio support
      # end of STMicroelectronics STM32 SOC audio support
      CONFIG_SND_SUNXI_SOC=y
      CONFIG_SND_SUNXI_SOC_CPUDAI=y
      CONFIG_SND_SUN8IW20_CODEC=y
      # Allwinner SoC Audio support
      CONFIG_SND_SUNXI_SOC_SUN8IW20_CODEC=y
      CONFIG_SND_SUNXI_SOC_SIMPLE_CARD=y
      CONFIG_SND_SUNXI_SOC_DAUDIO=y
      # CONFIG_SND_SUNXI_SOC_DAUDIO_ASRC is not set
      # CONFIG_SND_SUNXI_SOC_SUNXI_HDMIAUDIO is not set
      CONFIG_SND_SUNXI_SOC_SPDIF=y
      # CONFIG_SND_SUNXI_SOC_SPDIF_RX_IEC61937 is not set
      CONFIG_SND_SUNXI_SOC_DMIC=y
      # CONFIG_SUNXI_AUDIO_DEBUG is not set
      # CONFIG_SUNXI_RX_SYNC is not set
      # end of Allwinner SoC Audio support
      # CONFIG_SND_SUNXI_RPAF is not set
      # Allwinner SoC Audio support V2
      # CONFIG_SND_SOC_SUNXI_SPDIF is not set
      # CONFIG_SND_SOC_SUNXI_DMIC is not set
      # CONFIG_SND_SOC_SUNXI_DAUDIO is not set
      # CONFIG_SND_SOC_SUNXI_COMPONENTS is not set
      # end of Allwinner SoC Audio support V2
      # CONFIG_SND_SOC_XILINX_I2S is not set
      # CONFIG_SND_SOC_XILINX_AUDIO_FORMATTER is not set
      # CONFIG_SND_SOC_XILINX_SPDIF is not set
      # CONFIG_SND_SOC_XTFPGA_I2S is not set
      # CONFIG_ZX_TDM is not set
      CONFIG_SND_SOC_I2C_AND_SPI=y
      # CODEC drivers
      # CONFIG_SND_SOC_AC97_CODEC is not set
      # CONFIG_SND_SOC_ADAU1701 is not set
      # CONFIG_SND_SOC_ADAU1761_I2C is not set
      # CONFIG_SND_SOC_ADAU1761_SPI is not set
      # CONFIG_SND_SOC_ADAU7002 is not set
      # CONFIG_SND_SOC_AK4104 is not set
      # CONFIG_SND_SOC_AK4118 is not set
      # CONFIG_SND_SOC_AK4458 is not set
      # CONFIG_SND_SOC_AK4554 is not set
      # CONFIG_SND_SOC_AK4613 is not set
      # CONFIG_SND_SOC_AK4642 is not set
      # CONFIG_SND_SOC_AK5386 is not set
      # CONFIG_SND_SOC_AK5558 is not set
      # CONFIG_SND_SOC_ALC5623 is not set
      # CONFIG_SND_SOC_BD28623 is not set
      # CONFIG_SND_SOC_BT_SCO is not set
      # CONFIG_SND_SOC_CS35L32 is not set
      # CONFIG_SND_SOC_CS35L33 is not set
      # CONFIG_SND_SOC_CS35L34 is not set
      # CONFIG_SND_SOC_CS35L35 is not set
      # CONFIG_SND_SOC_CS35L36 is not set
      # CONFIG_SND_SOC_CS42L42 is not set
      # CONFIG_SND_SOC_CS42L51_I2C is not set
      # CONFIG_SND_SOC_CS42L52 is not set
      # CONFIG_SND_SOC_CS42L56 is not set
      # CONFIG_SND_SOC_CS42L73 is not set
      # CONFIG_SND_SOC_CS4265 is not set
      # CONFIG_SND_SOC_CS4270 is not set
      # CONFIG_SND_SOC_CS4271_I2C is not set
      # CONFIG_SND_SOC_CS4271_SPI is not set
      # CONFIG_SND_SOC_CS42XX8_I2C is not set
      # CONFIG_SND_SOC_CS43130 is not set
      # CONFIG_SND_SOC_CS4341 is not set
      # CONFIG_SND_SOC_CS4349 is not set
      # CONFIG_SND_SOC_CS53L30 is not set
      # CONFIG_SND_SOC_CX2072X is not set
      CONFIG_SND_SOC_DMIC=y
      # CONFIG_SND_SOC_ES7134 is not set
      # CONFIG_SND_SOC_ES7241 is not set
      # CONFIG_SND_SOC_ES8316 is not set
      # CONFIG_SND_SOC_ES8328_I2C is not set
      # CONFIG_SND_SOC_ES8328_SPI is not set
      # CONFIG_SND_SOC_GTM601 is not set
      # CONFIG_SND_SOC_INNO_RK3036 is not set
      # CONFIG_SND_SOC_MAX98088 is not set
      # CONFIG_SND_SOC_MAX98357A is not set
      # CONFIG_SND_SOC_MAX98504 is not set
      # CONFIG_SND_SOC_MAX9867 is not set
      # CONFIG_SND_SOC_MAX98927 is not set
      # CONFIG_SND_SOC_MAX98373 is not set
      # CONFIG_SND_SOC_MAX9860 is not set
      # CONFIG_SND_SOC_MSM8916_WCD_DIGITAL is not set
      # CONFIG_SND_SOC_PCM1681 is not set
      # CONFIG_SND_SOC_PCM1789_I2C is not set
      # CONFIG_SND_SOC_PCM179X_I2C is not set
      # CONFIG_SND_SOC_PCM179X_SPI is not set
      # CONFIG_SND_SOC_PCM186X_I2C is not set
      # CONFIG_SND_SOC_PCM186X_SPI is not set
      # CONFIG_SND_SOC_PCM3060_I2C is not set
      # CONFIG_SND_SOC_PCM3060_SPI is not set
      # CONFIG_SND_SOC_PCM3168A_I2C is not set
      # CONFIG_SND_SOC_PCM3168A_SPI is not set
      # CONFIG_SND_SOC_PCM512x_I2C is not set
      # CONFIG_SND_SOC_PCM512x_SPI is not set
      # CONFIG_SND_SOC_RK3328 is not set
      # CONFIG_SND_SOC_RT5616 is not set
      # CONFIG_SND_SOC_RT5631 is not set
      # CONFIG_SND_SOC_SGTL5000 is not set
      # CONFIG_SND_SOC_SIMPLE_AMPLIFIER is not set
      # CONFIG_SND_SOC_SIRF_AUDIO_CODEC is not set
      # CONFIG_SND_SOC_SPDIF is not set
      # CONFIG_SND_SOC_SSM2305 is not set
      # CONFIG_SND_SOC_SSM2602_SPI is not set
      # CONFIG_SND_SOC_SSM2602_I2C is not set
      # CONFIG_SND_SOC_SSM4567 is not set
      # CONFIG_SND_SOC_STA32X is not set
      # CONFIG_SND_SOC_STA350 is not set
      # CONFIG_SND_SOC_STI_SAS is not set
      # CONFIG_SND_SOC_TAS2552 is not set
      # CONFIG_SND_SOC_TAS5086 is not set
      # CONFIG_SND_SOC_TAS571X is not set
      # CONFIG_SND_SOC_TAS5720 is not set
      # CONFIG_SND_SOC_TAS6424 is not set
      # CONFIG_SND_SOC_TDA7419 is not set
      # CONFIG_SND_SOC_TFA9879 is not set
      # CONFIG_SND_SOC_TLV320AIC23_I2C is not set
      # CONFIG_SND_SOC_TLV320AIC23_SPI is not set
      # CONFIG_SND_SOC_TLV320AIC31XX is not set
      # CONFIG_SND_SOC_TLV320AIC32X4_I2C is not set
      # CONFIG_SND_SOC_TLV320AIC32X4_SPI is not set
      # CONFIG_SND_SOC_TLV320AIC3X is not set
      # CONFIG_SND_SOC_TS3A227E is not set
      # CONFIG_SND_SOC_TSCS42XX is not set
      # CONFIG_SND_SOC_TSCS454 is not set
      # CONFIG_SND_SOC_UDA1334 is not set
      # CONFIG_SND_SOC_WM8510 is not set
      # CONFIG_SND_SOC_WM8523 is not set
      # CONFIG_SND_SOC_WM8524 is not set
      # CONFIG_SND_SOC_WM8580 is not set
      # CONFIG_SND_SOC_WM8711 is not set
      # CONFIG_SND_SOC_WM8728 is not set
      # CONFIG_SND_SOC_WM8731 is not set
      # CONFIG_SND_SOC_WM8737 is not set
      # CONFIG_SND_SOC_WM8741 is not set
      # CONFIG_SND_SOC_WM8750 is not set
      # CONFIG_SND_SOC_WM8753 is not set
      # CONFIG_SND_SOC_WM8770 is not set
      # CONFIG_SND_SOC_WM8776 is not set
      # CONFIG_SND_SOC_WM8782 is not set
      # CONFIG_SND_SOC_WM8804_I2C is not set
      # CONFIG_SND_SOC_WM8804_SPI is not set
      # CONFIG_SND_SOC_WM8903 is not set
      # CONFIG_SND_SOC_WM8904 is not set
      # CONFIG_SND_SOC_WM8960 is not set
      # CONFIG_SND_SOC_WM8962 is not set
      # CONFIG_SND_SOC_WM8974 is not set
      # CONFIG_SND_SOC_WM8978 is not set
      # CONFIG_SND_SOC_WM8985 is not set
      # CONFIG_SND_SOC_ZX_AUD96P22 is not set
      # CONFIG_SND_SOC_MAX9759 is not set
      # CONFIG_SND_SOC_MT6351 is not set
      # CONFIG_SND_SOC_MT6358 is not set
      # CONFIG_SND_SOC_NAU8540 is not set
      # CONFIG_SND_SOC_NAU8810 is not set
      # CONFIG_SND_SOC_NAU8822 is not set
      # CONFIG_SND_SOC_NAU8824 is not set
      # CONFIG_SND_SOC_TPA6130A2 is not set
      # CONFIG_SND_SOC_AC107 is not set
      # CONFIG_SND_SOC_AC108 is not set
      # CONFIG_SND_SOC_TD100 is not set
      # end of CODEC drivers
      CONFIG_SND_SIMPLE_CARD_UTILS=y
      # CONFIG_SND_SIMPLE_CARD is not set
      # CONFIG_SND_AUDIO_GRAPH_CARD is not set
      # HID support
      # CONFIG_HID is not set
      # USB HID support
      # CONFIG_USB_HID is not set
      # CONFIG_HID_PID is not set
      # USB HID Boot Protocol drivers
      # CONFIG_USB_KBD is not set
      # CONFIG_USB_MOUSE is not set
      # end of USB HID Boot Protocol drivers
      # end of USB HID support
      # I2C HID support
      # CONFIG_I2C_HID is not set
      # end of I2C HID support
      # end of HID support
      CONFIG_USB_OHCI_LITTLE_ENDIAN=y
      CONFIG_USB_SUPPORT=y
      CONFIG_USB_COMMON=y
      # CONFIG_USB_LED_TRIG is not set
      # CONFIG_USB_ULPI_BUS is not set
      # CONFIG_USB_CONN_GPIO is not set
      CONFIG_USB_ARCH_HAS_HCD=y
      CONFIG_USB=y
      # CONFIG_USB_ANNOUNCE_NEW_DEVICES is not set
      # Miscellaneous USB options
      CONFIG_USB_DEFAULT_PERSIST=y
      # CONFIG_USB_DYNAMIC_MINORS is not set
      # CONFIG_USB_OTG is not set
      # CONFIG_USB_OTG_WHITELIST is not set
      # CONFIG_USB_OTG_BLACKLIST_HUB is not set
      # CONFIG_USB_LEDS_TRIGGER_USBPORT is not set
      CONFIG_USB_AUTOSUSPEND_DELAY=2
      # CONFIG_USB_MON is not set
      # USB Host Controller Drivers
      # CONFIG_USB_C67X00_HCD is not set
      # CONFIG_USB_XHCI_HCD is not set
      CONFIG_USB_EHCI_HCD=y
      CONFIG_USB_EHCI_ROOT_HUB_TT=y
      CONFIG_USB_EHCI_TT_NEWSCHED=y
      # CONFIG_USB_EHCI_FSL is not set
      CONFIG_USB_EHCI_HCD_SUNXI=y
      # CONFIG_USB_EHCI_HCD_PLATFORM is not set
      # CONFIG_USB_OXU210HP_HCD is not set
      # CONFIG_USB_ISP116X_HCD is not set
      # CONFIG_USB_FOTG210_HCD is not set
      # CONFIG_USB_MAX3421_HCD is not set
      CONFIG_USB_OHCI_HCD=y
      CONFIG_USB_OHCI_HCD_SUNXI=y
      # CONFIG_USB_OHCI_HCD_PLATFORM is not set
      # CONFIG_USB_SL811_HCD is not set
      # CONFIG_USB_R8A66597_HCD is not set
      # CONFIG_USB_HCD_TEST_MODE is not set
      CONFIG_USB_SUNXI_HCD=y
      CONFIG_USB_SUNXI_HCI=y
      CONFIG_USB_SUNXI_EHCI0=y
      CONFIG_USB_SUNXI_EHCI1=y
      CONFIG_USB_SUNXI_OHCI0=y
      CONFIG_USB_SUNXI_OHCI1=y
      # USB Device Class drivers
      # CONFIG_USB_ACM is not set
      # CONFIG_USB_PRINTER is not set
      # CONFIG_USB_WDM is not set
      # CONFIG_USB_TMC is not set
      # NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may
      # also be needed; see USB_STORAGE Help for more info
      CONFIG_USB_STORAGE=m
      # CONFIG_USB_STORAGE_DEBUG is not set
      # CONFIG_USB_STORAGE_REALTEK is not set
      # CONFIG_USB_STORAGE_DATAFAB is not set
      # CONFIG_USB_STORAGE_FREECOM is not set
      # CONFIG_USB_STORAGE_ISD200 is not set
      # CONFIG_USB_STORAGE_USBAT is not set
      # CONFIG_USB_STORAGE_SDDR09 is not set
      # CONFIG_USB_STORAGE_SDDR55 is not set
      # CONFIG_USB_STORAGE_JUMPSHOT is not set
      # CONFIG_USB_STORAGE_ALAUDA is not set
      # CONFIG_USB_STORAGE_ONETOUCH is not set
      # CONFIG_USB_STORAGE_KARMA is not set
      # CONFIG_USB_STORAGE_CYPRESS_ATACB is not set
      # CONFIG_USB_STORAGE_ENE_UB6250 is not set
      # CONFIG_USB_UAS is not set
      # USB Imaging devices
      # CONFIG_USB_MDC800 is not set
      # CONFIG_USB_MICROTEK is not set
      # CONFIG_USBIP_CORE is not set
      # CONFIG_USB_CDNS3 is not set
      # CONFIG_USB_MUSB_HDRC is not set
      # CONFIG_USB_DWC3 is not set
      # CONFIG_USB_DWC2 is not set
      # CONFIG_USB_CHIPIDEA is not set
      # CONFIG_USB_ISP1760 is not set
      # USB port drivers
      # CONFIG_USB_SERIAL is not set
      # USB Miscellaneous drivers
      # CONFIG_USB_EMI62 is not set
      # CONFIG_USB_EMI26 is not set
      # CONFIG_USB_ADUTUX is not set
      # CONFIG_USB_SEVSEG is not set
      # CONFIG_USB_LEGOTOWER is not set
      # CONFIG_USB_LCD is not set
      # CONFIG_USB_CYPRESS_CY7C63 is not set
      # CONFIG_USB_CYTHERM is not set
      # CONFIG_USB_IDMOUSE is not set
      # CONFIG_USB_FTDI_ELAN is not set
      # CONFIG_USB_APPLEDISPLAY is not set
      # CONFIG_USB_SISUSBVGA is not set
      # CONFIG_USB_LD is not set
      # CONFIG_USB_TRANCEVIBRATOR is not set
      # CONFIG_USB_IOWARRIOR is not set
      # CONFIG_USB_TEST is not set
      # CONFIG_USB_EHSET_TEST_FIXTURE is not set
      # CONFIG_USB_ISIGHTFW is not set
      # CONFIG_USB_YUREX is not set
      # CONFIG_USB_EZUSB_FX2 is not set
      # CONFIG_USB_HUB_USB251XB is not set
      # CONFIG_USB_HSIC_USB3503 is not set
      # CONFIG_USB_HSIC_USB4604 is not set
      # CONFIG_USB_LINK_LAYER_TEST is not set
      # USB Physical Layer drivers
      # CONFIG_NOP_USB_XCEIV is not set
      # CONFIG_USB_GPIO_VBUS is not set
      # CONFIG_USB_ISP1301 is not set
      # CONFIG_USB_ULPI is not set
      # end of USB Physical Layer drivers
      CONFIG_USB_GADGET=y
      # CONFIG_USB_GADGET_DEBUG is not set
      # CONFIG_USB_GADGET_DEBUG_FILES is not set
      # CONFIG_USB_GADGET_DEBUG_FS is not set
      CONFIG_USB_GADGET_VBUS_DRAW=2
      CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=2
      # CONFIG_U_SERIAL_CONSOLE is not set
      # USB Peripheral Controller
      # CONFIG_USB_FUSB300 is not set
      # CONFIG_USB_FOTG210_UDC is not set
      # CONFIG_USB_GR_UDC is not set
      # CONFIG_USB_R8A66597 is not set
      # CONFIG_USB_PXA27X is not set
      # CONFIG_USB_MV_UDC is not set
      # CONFIG_USB_MV_U3D is not set
      # CONFIG_USB_SNP_UDC_PLAT is not set
      # CONFIG_USB_M66592 is not set
      # CONFIG_USB_BDC_UDC is not set
      # CONFIG_USB_NET2272 is not set
      CONFIG_USB_SUNXI_UDC0=y
      # CONFIG_USB_GADGET_XILINX is not set
      # CONFIG_USB_DUMMY_HCD is not set
      # end of USB Peripheral Controller
      CONFIG_USB_LIBCOMPOSITE=y
      CONFIG_USB_U_SERIAL=y
      CONFIG_USB_F_SERIAL=y
      CONFIG_USB_F_FS=y
      CONFIG_USB_CONFIGFS=y
      CONFIG_USB_CONFIGFS_UEVENT=y
      CONFIG_USB_CONFIGFS_SERIAL=y
      # CONFIG_USB_CONFIGFS_ACM is not set
      # CONFIG_USB_CONFIGFS_OBEX is not set
      # CONFIG_USB_CONFIGFS_NCM is not set
      # CONFIG_USB_CONFIGFS_ECM is not set
      # CONFIG_USB_CONFIGFS_ECM_SUBSET is not set
      # CONFIG_USB_CONFIGFS_RNDIS is not set
      # CONFIG_USB_CONFIGFS_EEM is not set
      # CONFIG_USB_CONFIGFS_MASS_STORAGE is not set
      # CONFIG_USB_CONFIGFS_F_LB_SS is not set
      CONFIG_USB_CONFIGFS_F_FS=y
      # CONFIG_USB_CONFIGFS_F_AUDIO_SRC is not set
      # CONFIG_USB_CONFIGFS_F_UAC1 is not set
      # CONFIG_USB_CONFIGFS_F_UAC1_LEGACY is not set
      # CONFIG_USB_CONFIGFS_F_UAC2 is not set
      # CONFIG_USB_CONFIGFS_F_MIDI is not set
      # CONFIG_USB_CONFIGFS_F_HID is not set
      # CONFIG_USB_CONFIGFS_F_UVC is not set
      # CONFIG_USB_CONFIGFS_F_PRINTER is not set
      CONFIG_USB_SUNXI_USB=y
      CONFIG_USB_SUNXI_USB_MANAGER=y
      # CONFIG_USB_SUNXI_USB_DEBUG is not set
      CONFIG_USB_SUNXI_USB_ADB=y
      CONFIG_TYPEC=y
      # CONFIG_TYPEC_TCPM is not set
      # CONFIG_TYPEC_UCSI is not set
      # CONFIG_TYPEC_TPS6598X is not set
      # USB Type-C Multiplexer/DeMultiplexer Switch support
      # CONFIG_TYPEC_MUX_PI3USB30532 is not set
      # end of USB Type-C Multiplexer/DeMultiplexer Switch support
      # USB Type-C Alternate Mode drivers
      # CONFIG_TYPEC_DP_ALTMODE is not set
      # end of USB Type-C Alternate Mode drivers
      CONFIG_USB_ROLE_SWITCH=y
      CONFIG_MMC=y
      CONFIG_PWRSEQ_EMMC=y
      CONFIG_PWRSEQ_SIMPLE=y
      CONFIG_MMC_BLOCK=y
      CONFIG_MMC_BLOCK_MINORS=8
      # CONFIG_SDIO_UART is not set
      # CONFIG_MMC_TEST is not set
      # MMC/SD/SDIO Host Controller Drivers
      # CONFIG_MMC_DEBUG is not set
      # CONFIG_MMC_SDHCI is not set
      # CONFIG_MMC_SPI is not set
      # CONFIG_MMC_DW is not set
      # CONFIG_MMC_VUB300 is not set
      # CONFIG_MMC_USHC is not set
      # CONFIG_MMC_USDHI6ROL0 is not set
      CONFIG_MMC_SUNXI=y
      CONFIG_MMC_SUNXI_V4P1X=y
      CONFIG_MMC_SUNXI_V4P00X=y
      CONFIG_MMC_SUNXI_V4P10X=y
      CONFIG_MMC_SUNXI_V4P5X=y
      CONFIG_MMC_SUNXI_V5P3X=y
      # CONFIG_MMC_CQHCI is not set
      # CONFIG_MMC_HSQ is not set
      # CONFIG_MMC_MTK is not set
      # CONFIG_MEMSTICK is not set
      CONFIG_NEW_LEDS=y
      CONFIG_LEDS_CLASS=y
      # CONFIG_LEDS_CLASS_FLASH is not set
      # CONFIG_LEDS_BRIGHTNESS_HW_CHANGED is not set
      # LED drivers
      # CONFIG_LEDS_AN30259A is not set
      # CONFIG_LEDS_BCM6328 is not set
      # CONFIG_LEDS_BCM6358 is not set
      # CONFIG_LEDS_CR0014114 is not set
      # CONFIG_LEDS_LM3530 is not set
      # CONFIG_LEDS_LM3532 is not set
      # CONFIG_LEDS_LM3642 is not set
      # CONFIG_LEDS_LM3692X is not set
      # CONFIG_LEDS_PCA9532 is not set
      # CONFIG_LEDS_GPIO is not set
      # CONFIG_LEDS_LP3944 is not set
      # CONFIG_LEDS_LP3952 is not set
      # CONFIG_LEDS_LP5521 is not set
      # CONFIG_LEDS_LP5523 is not set
      # CONFIG_LEDS_LP5562 is not set
      # CONFIG_LEDS_LP8501 is not set
      # CONFIG_LEDS_LP8860 is not set
      # CONFIG_LEDS_PCA955X is not set
      # CONFIG_LEDS_PCA963X is not set
      # CONFIG_LEDS_DAC124S085 is not set
      # CONFIG_LEDS_PWM is not set
      # CONFIG_LEDS_REGULATOR is not set
      # CONFIG_LEDS_BD2802 is not set
      # CONFIG_LEDS_LT3593 is not set
      # CONFIG_LEDS_TCA6507 is not set
      # CONFIG_LEDS_TLC591XX is not set
      # CONFIG_LEDS_LM355x is not set
      # CONFIG_LEDS_IS31FL319X is not set
      # CONFIG_LEDS_IS31FL32XX is not set
      # LED driver for blink(1) USB RGB LED is under Special HID drivers (HID_THINGM)
      # CONFIG_LEDS_BLINKM is not set
      # CONFIG_LEDS_SYSCON is not set
      # CONFIG_LEDS_MLXREG is not set
      # CONFIG_LEDS_USER is not set
      # CONFIG_LEDS_SPI_BYTE is not set
      # CONFIG_LEDS_TI_LMU_COMMON is not set
      CONFIG_LEDS_SUNXI=y
      # CONFIG_MATRIX_LEDS_SUNXI is not set
      # LED Triggers
      CONFIG_LEDS_TRIGGERS=y
      CONFIG_LEDS_TRIGGER_TIMER=y
      # CONFIG_LEDS_TRIGGER_ONESHOT is not set
      # CONFIG_LEDS_TRIGGER_MTD is not set
      # CONFIG_LEDS_TRIGGER_HEARTBEAT is not set
      # CONFIG_LEDS_TRIGGER_BACKLIGHT is not set
      # CONFIG_LEDS_TRIGGER_CPU is not set
      # CONFIG_LEDS_TRIGGER_ACTIVITY is not set
      # CONFIG_LEDS_TRIGGER_GPIO is not set
      CONFIG_LEDS_TRIGGER_DEFAULT_ON=y
      # iptables trigger is under Netfilter config (LED target)
      # CONFIG_LEDS_TRIGGER_TRANSIENT is not set
      # CONFIG_LEDS_TRIGGER_CAMERA is not set
      # CONFIG_LEDS_TRIGGER_PANIC is not set
      CONFIG_LEDS_TRIGGER_NETDEV=y
      # CONFIG_LEDS_TRIGGER_PATTERN is not set
      # CONFIG_LEDS_TRIGGER_AUDIO is not set
      # CONFIG_ACCESSIBILITY is not set
      # CONFIG_INFINIBAND is not set
      CONFIG_EDAC_ATOMIC_SCRUB=y
      CONFIG_EDAC_SUPPORT=y
      CONFIG_RTC_LIB=y
      # CONFIG_RTC_CLASS is not set
      CONFIG_DMADEVICES=y
      # CONFIG_DMADEVICES_DEBUG is not set
      # DMA Devices
      CONFIG_DMA_ENGINE=y
      CONFIG_DMA_VIRTUAL_CHANNELS=y
      CONFIG_DMA_OF=y
      # CONFIG_ALTERA_MSGDMA is not set
      CONFIG_DMA_SUN6I=y
      # CONFIG_DW_AXI_DMAC is not set
      # CONFIG_FSL_EDMA is not set
      # CONFIG_FSL_QDMA is not set
      # CONFIG_INTEL_IDMA64 is not set
      # CONFIG_NBPFAXI_DMA is not set
      # CONFIG_QCOM_HIDMA_MGMT is not set
      # CONFIG_QCOM_HIDMA is not set
      # CONFIG_DW_DMAC is not set
      # DMA Clients
      # CONFIG_ASYNC_TX_DMA is not set
      # CONFIG_DMATEST is not set
      # DMABUF options
      CONFIG_SYNC_FILE=y
      CONFIG_SW_SYNC=y
      CONFIG_UDMABUF=y
      CONFIG_DMABUF_SELFTESTS=y
      # end of DMABUF options
      # CONFIG_AUXDISPLAY is not set
      # CONFIG_UIO is not set
      # CONFIG_VFIO is not set
      # CONFIG_VIRT_DRIVERS is not set
      # CONFIG_VIRTIO_MENU is not set
      # Microsoft Hyper-V guest support
      # end of Microsoft Hyper-V guest support
      # CONFIG_GREYBUS is not set
      CONFIG_STAGING=y
      # CONFIG_PRISM2_USB is not set
      # CONFIG_COMEDI is not set
      # CONFIG_RTLLIB is not set
      # CONFIG_RTL8723BS is not set
      # CONFIG_R8712U is not set
      # CONFIG_R8188EU is not set
      # Speakup console speech
      # end of Speakup console speech
      # CONFIG_STAGING_MEDIA is not set
      # Android
      # CONFIG_ASHMEM is not set
      # CONFIG_ANDROID_TIMED_OUTPUT is not set
      CONFIG_ION=y
      CONFIG_ION_SYSTEM_HEAP=y
      CONFIG_ION_CMA_HEAP=y
      # end of Android
      # CONFIG_STAGING_BOARD is not set
      # CONFIG_LTE_GDM724X is not set
      # CONFIG_GS_FPGABOOT is not set
      # CONFIG_UNISYSSPAR is not set
      # CONFIG_COMMON_CLK_XLNX_CLKWZRD is not set
      # CONFIG_FB_TFT is not set
      # CONFIG_WILC1000_SDIO is not set
      # CONFIG_WILC1000_SPI is not set
      # CONFIG_MOST is not set
      # CONFIG_KS7010 is not set
      # CONFIG_PI433 is not set
      # Gasket devices
      # end of Gasket devices
      # CONFIG_XIL_AXIS_FIFO is not set
      # CONFIG_FIELDBUS_DEV is not set
      # CONFIG_USB_WUSB_CBAF is not set
      # CONFIG_UWB is not set
      CONFIG_EXFAT_FS=y
      CONFIG_EXFAT_DONT_MOUNT_VFAT=y
      CONFIG_EXFAT_DISCARD=y
      CONFIG_EXFAT_DELAYED_SYNC=y
      CONFIG_EXFAT_KERNEL_DEBUG=y
      CONFIG_EXFAT_DEBUG_MSG=y
      CONFIG_EXFAT_DEFAULT_CODEPAGE=437
      CONFIG_EXFAT_DEFAULT_IOCHARSET="utf8"
      # CONFIG_GOLDFISH is not set
      # CONFIG_MFD_CROS_EC is not set
      # CONFIG_CHROME_PLATFORMS is not set
      # CONFIG_MELLANOX_PLATFORM is not set
      CONFIG_CLKDEV_LOOKUP=y
      CONFIG_HAVE_CLK_PREPARE=y
      CONFIG_COMMON_CLK=y
      # Common Clock Framework
      # CONFIG_COMMON_CLK_DEBUG is not set
      # CONFIG_CLK_HSDK is not set
      # CONFIG_COMMON_CLK_MAX9485 is not set
      # CONFIG_COMMON_CLK_SI5341 is not set
      # CONFIG_COMMON_CLK_SI5351 is not set
      # CONFIG_COMMON_CLK_SI514 is not set
      # CONFIG_COMMON_CLK_SI544 is not set
      # CONFIG_COMMON_CLK_SI570 is not set
      # CONFIG_COMMON_CLK_CDCE706 is not set
      # CONFIG_COMMON_CLK_CDCE925 is not set
      # CONFIG_COMMON_CLK_CS2000_CP is not set
      # CONFIG_CLK_QORIQ is not set
      # CONFIG_COMMON_CLK_PWM is not set
      # CONFIG_COMMON_CLK_VC5 is not set
      # CONFIG_COMMON_CLK_FIXED_MMIO is not set
      CONFIG_CLK_SUNXI=y
      # CONFIG_CLK_SUNXI_CLOCKS is not set
      # CONFIG_CLK_SUNXI_DDR is not set
      # CONFIG_CLK_SUNXI_PRCM_SUN6I is not set
      # CONFIG_CLK_SUNXI_PRCM_SUN8I is not set
      # CONFIG_CLK_SUNXI_PRCM_SUN9I is not set
      CONFIG_SUNXI_CCU=y
      CONFIG_SUN8IW20_CCU=y
      CONFIG_SUN8IW20_R_CCU=y
      # CONFIG_SUN8I_A83T_CCU is not set
      # CONFIG_SUN8I_DE2_CCU is not set
      # CONFIG_SUN8I_R_CCU is not set
      CONFIG_SUNXI_RTC_CCU=y
      # end of Common Clock Framework
      # CONFIG_HWSPINLOCK is not set
      # CONFIG_HWSPINLOCK_SUNXI is not set
      # Clock Source drivers
      CONFIG_TIMER_OF=y
      CONFIG_TIMER_PROBE=y
      CONFIG_CLKSRC_MMIO=y
      CONFIG_SUN4I_TIMER=y
      # CONFIG_SUN50I_TIMER is not set
      # CONFIG_SUNXI_TIMER is not set
      # CONFIG_SUNXI_TIMER_TEST is not set
      CONFIG_ARM_ARCH_TIMER=y
      # CONFIG_ARM_ARCH_TIMER_EVTSTREAM is not set
      # CONFIG_MTK_TIMER is not set
      # end of Clock Source drivers
      # CONFIG_MAILBOX is not set
      CONFIG_IOMMU_IOVA=y
      CONFIG_IOMMU_API=y
      # CONFIG_IOMMU_LIMIT_IOVA_ALIGNMENT is not set
      CONFIG_IOMMU_SUPPORT=y
      # Generic IOMMU Pagetable Support
      # CONFIG_IOMMU_IO_PGTABLE_LPAE is not set
      # CONFIG_IOMMU_IO_PGTABLE_ARMV7S is not set
      # end of Generic IOMMU Pagetable Support
      # CONFIG_IOMMU_DEBUGFS is not set
      # CONFIG_IOMMU_DEFAULT_PASSTHROUGH is not set
      CONFIG_OF_IOMMU=y
      CONFIG_IOMMU_DMA=y
      # CONFIG_ARM_SMMU is not set
      CONFIG_SUNXI_IOMMU=y
      CONFIG_SUNXI_IOMMU_DEBUG=y
      CONFIG_SUNXI_IOMMU_TESTS=y
      # Remoteproc drivers
      # CONFIG_REMOTEPROC is not set
      # end of Remoteproc drivers
      # Rpmsg drivers
      # CONFIG_RPMSG_SUNXI_AMP is not set
      # CONFIG_RPMSG_DSP_STANDBY is not set
      # CONFIG_RPMSG_VIRTIO is not set
      # CONFIG_RPMSG_SUNXI_TTY is not set
      # CONFIG_RPMSG_SUNXI_CLIENT_SAMPLE is not set
      # end of Rpmsg drivers
      # Rpbuf drivers
      # CONFIG_RPBUF_DEV is not set
      # Service
      # CONFIG_RPBUF_SERVICE_RPMSG is not set
      # Controller
      # CONFIG_RPBUF_CONTROLLER_SUNXI is not set
      # Sample
      # CONFIG_RPBUF_SAMPLE_SUNXI is not set
      # end of Rpbuf drivers
      # CONFIG_SOUNDWIRE is not set
      # SOC (System On Chip) specific Drivers
      # Amlogic SoC drivers
      # end of Amlogic SoC drivers
      # Aspeed SoC drivers
      # end of Aspeed SoC drivers
      # Broadcom SoC drivers
      # CONFIG_SOC_BRCMSTB is not set
      # end of Broadcom SoC drivers
      # NXP/Freescale QorIQ SoC drivers
      # end of NXP/Freescale QorIQ SoC drivers
      # i.MX SoC drivers
      # end of i.MX SoC drivers
      # Qualcomm SoC drivers
      # end of Qualcomm SoC drivers
      # CONFIG_SUNXI_SRAM is not set
      CONFIG_SUNXI_PM_DOMAINS=y
      # CONFIG_SUNXI_POWER_DOMAIN_TEST is not set
      CONFIG_SUNXI_SID=y
      # CONFIG_SUNXI_RISCV_SUSPEND is not set
      # CONFIG_PM_TRACE_NVMEM is not set
      # CONFIG_SOC_TI is not set
      # Xilinx SoC drivers
      # CONFIG_XILINX_VCU is not set
      # end of Xilinx SoC drivers
      # end of SOC (System On Chip) specific Drivers
      # CONFIG_PM_DEVFREQ is not set
      # CONFIG_EXTCON is not set
      # CONFIG_MEMORY is not set
      # CONFIG_IIO is not set
      CONFIG_PWM=y
      CONFIG_PWM_SYSFS=y
      # CONFIG_PWM_FSL_FTM is not set
      # CONFIG_PWM_PCA9685 is not set
      # CONFIG_PWM_SUN4I is not set
      CONFIG_PWM_SUNXI_GROUP=y
      # CONFIG_DSP_DEBUG is not set
      # IRQ chip support
      CONFIG_IRQCHIP=y
      CONFIG_ARM_GIC=y
      CONFIG_ARM_GIC_MAX_NR=1
      # CONFIG_AL_FIC is not set
      # CONFIG_SUNXI_WAKEUPGEN is not set
      # CONFIG_SUN8I_NMI is not set
      # end of IRQ chip support
      # CONFIG_IPACK_BUS is not set
      CONFIG_ARCH_HAS_RESET_CONTROLLER=y
      CONFIG_RESET_CONTROLLER=y
      CONFIG_RESET_SIMPLE=y
      CONFIG_RESET_SUNXI=y
      # CONFIG_RESET_TI_SYSCON is not set
      # PHY Subsystem
      # CONFIG_GENERIC_PHY is not set
      # CONFIG_PHY_SUN6I_MIPI_DPHY is not set
      # CONFIG_PHY_SUN9I_USB is not set
      # CONFIG_BCM_KONA_USB2_PHY is not set
      # CONFIG_PHY_CADENCE_DP is not set
      # CONFIG_PHY_CADENCE_DPHY is not set
      # CONFIG_PHY_CADENCE_SIERRA is not set
      # CONFIG_PHY_FSL_IMX8MQ_USB is not set
      # CONFIG_PHY_MIXEL_MIPI_DPHY is not set
      # CONFIG_PHY_PXA_28NM_HSIC is not set
      # CONFIG_PHY_PXA_28NM_USB2 is not set
      # CONFIG_PHY_MAPPHONE_MDM6600 is not set
      # CONFIG_PHY_OCELOT_SERDES is not set
      # end of PHY Subsystem
      # CONFIG_POWERCAP is not set
      # CONFIG_MCB is not set
      # Performance monitor support
      # CONFIG_ARM_CCI_PMU is not set
      # CONFIG_ARM_CCN is not set
      # CONFIG_ARM_PMU is not set
      # end of Performance monitor support
      # CONFIG_RAS is not set
      # Android
      CONFIG_ANDROID=y
      # CONFIG_ANDROID_BINDER_IPC is not set
      # end of Android
      # CONFIG_DAX is not set
      CONFIG_NVMEM=y
      CONFIG_NVMEM_SYSFS=y
      # CONFIG_NVMEM_SUNXI_SID is not set
      # HW tracing support
      # CONFIG_STM is not set
      # CONFIG_INTEL_TH is not set
      # end of HW tracing support
      # CONFIG_FPGA is not set
      # CONFIG_FSI is not set
      # CONFIG_TEE is not set
      CONFIG_PM_OPP=y
      # CONFIG_SIOX is not set
      # CONFIG_SLIMBUS is not set
      # CONFIG_INTERCONNECT is not set
      # CONFIG_COUNTER is not set
      # end of Device Drivers
      # File systems
      CONFIG_DCACHE_WORD_ACCESS=y
      # CONFIG_VALIDATE_FS_PARSER is not set
      # CONFIG_EXT2_FS is not set
      # CONFIG_EXT3_FS is not set
      # CONFIG_EXT4_FS is not set
      # CONFIG_REISERFS_FS is not set
      # CONFIG_JFS_FS is not set
      # CONFIG_XFS_FS is not set
      # CONFIG_GFS2_FS is not set
      # CONFIG_OCFS2_FS is not set
      # CONFIG_BTRFS_FS is not set
      # CONFIG_NILFS2_FS is not set
      # CONFIG_F2FS_FS is not set
      CONFIG_FS_POSIX_ACL=y
      CONFIG_EXPORTFS=y
      # CONFIG_EXPORTFS_BLOCK_OPS is not set
      CONFIG_FILE_LOCKING=y
      CONFIG_MANDATORY_FILE_LOCKING=y
      # CONFIG_FS_ENCRYPTION is not set
      # CONFIG_FS_VERITY is not set
      CONFIG_FSNOTIFY=y
      CONFIG_DNOTIFY=y
      CONFIG_INOTIFY_USER=y
      # CONFIG_FANOTIFY is not set
      # CONFIG_QUOTA is not set
      # CONFIG_AUTOFS4_FS is not set
      # CONFIG_AUTOFS_FS is not set
      # CONFIG_FUSE_FS is not set
      CONFIG_OVERLAY_FS=y
      # CONFIG_OVERLAY_FS_REDIRECT_DIR is not set
      CONFIG_OVERLAY_FS_REDIRECT_ALWAYS_FOLLOW=y
      # CONFIG_OVERLAY_FS_INDEX is not set
      # CONFIG_OVERLAY_FS_XINO_AUTO is not set
      # CONFIG_OVERLAY_FS_METACOPY is not set
      # CONFIG_INCREMENTAL_FS is not set
      # Caches
      # CONFIG_FSCACHE is not set
      # end of Caches
      # CD-ROM/DVD Filesystems
      # CONFIG_ISO9660_FS is not set
      # CONFIG_UDF_FS is not set
      # end of CD-ROM/DVD Filesystems
      # DOS/FAT/NT Filesystems
      CONFIG_FAT_FS=y
      # CONFIG_MSDOS_FS is not set
      CONFIG_VFAT_FS=y
      CONFIG_FAT_DEFAULT_CODEPAGE=437
      CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
      CONFIG_FAT_DEFAULT_UTF8=y
      CONFIG_NTFS_FS=y
      # CONFIG_NTFS_DEBUG is not set
      CONFIG_NTFS_RW=y
      # end of DOS/FAT/NT Filesystems
      # Pseudo filesystems
      CONFIG_PROC_FS=y
      CONFIG_PROC_SYSCTL=y
      # CONFIG_PROC_PAGE_MONITOR is not set
      # CONFIG_PROC_CHILDREN is not set
      CONFIG_KERNFS=y
      CONFIG_SYSFS=y
      CONFIG_TMPFS=y
      CONFIG_TMPFS_POSIX_ACL=y
      CONFIG_TMPFS_XATTR=y
      CONFIG_MEMFD_CREATE=y
      CONFIG_CONFIGFS_FS=y
      # end of Pseudo filesystems
      CONFIG_MISC_FILESYSTEMS=y
      # CONFIG_ORANGEFS_FS is not set
      # CONFIG_ADFS_FS is not set
      # CONFIG_AFFS_FS is not set
      # CONFIG_ECRYPT_FS is not set
      # CONFIG_HFS_FS is not set
      # CONFIG_HFSPLUS_FS is not set
      # CONFIG_BEFS_FS is not set
      # CONFIG_BFS_FS is not set
      # CONFIG_EFS_FS is not set
      # CONFIG_JFFS2_FS is not set
      CONFIG_UBIFS_FS=y
      CONFIG_UBIFS_FS_ADVANCED_COMPR=y
      # CONFIG_UBIFS_FS_LZO is not set
      # CONFIG_UBIFS_FS_ZLIB is not set
      # CONFIG_UBIFS_FS_ZSTD is not set
      # CONFIG_UBIFS_ATIME_SUPPORT is not set
      CONFIG_UBIFS_FS_XATTR=y
      CONFIG_UBIFS_FS_SECURITY=y
      # CONFIG_UBIFS_FS_AUTHENTICATION is not set
      # CONFIG_CRAMFS is not set
      CONFIG_SQUASHFS=y
      # CONFIG_SQUASHFS_FILE_CACHE is not set
      CONFIG_SQUASHFS_FILE_DIRECT=y
      # CONFIG_SQUASHFS_DECOMP_SINGLE is not set
      # CONFIG_SQUASHFS_DECOMP_MULTI is not set
      CONFIG_SQUASHFS_DECOMP_MULTI_PERCPU=y
      # CONFIG_SQUASHFS_XATTR is not set
      CONFIG_SQUASHFS_ZLIB=y
      # CONFIG_SQUASHFS_LZ4 is not set
      # CONFIG_SQUASHFS_LZO is not set
      # CONFIG_SQUASHFS_XZ is not set
      # CONFIG_SQUASHFS_ZSTD is not set
      # CONFIG_SQUASHFS_4K_DEVBLK_SIZE is not set
      # CONFIG_SQUASHFS_EMBEDDED is not set
      CONFIG_SQUASHFS_FRAGMENT_CACHE_SIZE=3
      # CONFIG_VXFS_FS is not set
      # CONFIG_MINIX_FS is not set
      # CONFIG_OMFS_FS is not set
      # CONFIG_HPFS_FS is not set
      # CONFIG_QNX4FS_FS is not set
      # CONFIG_QNX6FS_FS is not set
      # CONFIG_ROMFS_FS is not set
      # CONFIG_PSTORE is not set
      # CONFIG_SYSV_FS is not set
      # CONFIG_UFS_FS is not set
      # CONFIG_EROFS_FS is not set
      # CONFIG_NETWORK_FILESYSTEMS is not set
      CONFIG_NLS=y
      CONFIG_NLS_DEFAULT="iso8859-1"
      CONFIG_NLS_CODEPAGE_437=y
      # CONFIG_NLS_CODEPAGE_737 is not set
      # CONFIG_NLS_CODEPAGE_775 is not set
      # CONFIG_NLS_CODEPAGE_850 is not set
      # CONFIG_NLS_CODEPAGE_852 is not set
      # CONFIG_NLS_CODEPAGE_855 is not set
      # CONFIG_NLS_CODEPAGE_857 is not set
      # CONFIG_NLS_CODEPAGE_860 is not set
      # CONFIG_NLS_CODEPAGE_861 is not set
      # CONFIG_NLS_CODEPAGE_862 is not set
      # CONFIG_NLS_CODEPAGE_863 is not set
      # CONFIG_NLS_CODEPAGE_864 is not set
      # CONFIG_NLS_CODEPAGE_865 is not set
      # CONFIG_NLS_CODEPAGE_866 is not set
      # CONFIG_NLS_CODEPAGE_869 is not set
      # CONFIG_NLS_CODEPAGE_936 is not set
      # CONFIG_NLS_CODEPAGE_950 is not set
      # CONFIG_NLS_CODEPAGE_932 is not set
      # CONFIG_NLS_CODEPAGE_949 is not set
      # CONFIG_NLS_CODEPAGE_874 is not set
      # CONFIG_NLS_ISO8859_8 is not set
      # CONFIG_NLS_CODEPAGE_1250 is not set
      # CONFIG_NLS_CODEPAGE_1251 is not set
      # CONFIG_NLS_ASCII is not set
      CONFIG_NLS_ISO8859_1=y
      # CONFIG_NLS_ISO8859_2 is not set
      # CONFIG_NLS_ISO8859_3 is not set
      # CONFIG_NLS_ISO8859_4 is not set
      # CONFIG_NLS_ISO8859_5 is not set
      # CONFIG_NLS_ISO8859_6 is not set
      # CONFIG_NLS_ISO8859_7 is not set
      # CONFIG_NLS_ISO8859_9 is not set
      # CONFIG_NLS_ISO8859_13 is not set
      # CONFIG_NLS_ISO8859_14 is not set
      # CONFIG_NLS_ISO8859_15 is not set
      # CONFIG_NLS_KOI8_R is not set
      # CONFIG_NLS_KOI8_U is not set
      # CONFIG_NLS_MAC_ROMAN is not set
      # CONFIG_NLS_MAC_CELTIC is not set
      # CONFIG_NLS_MAC_CENTEURO is not set
      # CONFIG_NLS_MAC_CROATIAN is not set
      # CONFIG_NLS_MAC_CYRILLIC is not set
      # CONFIG_NLS_MAC_GAELIC is not set
      # CONFIG_NLS_MAC_GREEK is not set
      # CONFIG_NLS_MAC_ICELAND is not set
      # CONFIG_NLS_MAC_INUIT is not set
      # CONFIG_NLS_MAC_ROMANIAN is not set
      # CONFIG_NLS_MAC_TURKISH is not set
      # CONFIG_NLS_UTF8 is not set
      # CONFIG_DLM is not set
      # CONFIG_UNICODE is not set
      # end of File systems
      # Security options
      CONFIG_KEYS=y
      # CONFIG_KEYS_REQUEST_CACHE is not set
      # CONFIG_PERSISTENT_KEYRINGS is not set
      # CONFIG_BIG_KEYS is not set
      # CONFIG_ENCRYPTED_KEYS is not set
      # CONFIG_KEY_DH_OPERATIONS is not set
      # CONFIG_SECURITY_DMESG_RESTRICT is not set
      # CONFIG_SECURITY is not set
      # CONFIG_SECURITYFS is not set
      CONFIG_HAVE_HARDENED_USERCOPY_ALLOCATOR=y
      # CONFIG_HARDENED_USERCOPY is not set
      # CONFIG_FORTIFY_SOURCE is not set
      # CONFIG_STATIC_USERMODEHELPER is not set
      CONFIG_DEFAULT_SECURITY_DAC=y
      CONFIG_LSM="lockdown,yama,loadpin,safesetid,integrity"
      # Kernel hardening options
      # Memory initialization
      CONFIG_INIT_STACK_NONE=y
      # CONFIG_INIT_ON_ALLOC_DEFAULT_ON is not set
      # CONFIG_INIT_ON_FREE_DEFAULT_ON is not set
      # end of Memory initialization
      # end of Kernel hardening options
      # end of Security options
      CONFIG_CRYPTO=y
      # Crypto core or helper
      CONFIG_CRYPTO_ALGAPI=y
      CONFIG_CRYPTO_ALGAPI2=y
      CONFIG_CRYPTO_AEAD=y
      CONFIG_CRYPTO_AEAD2=y
      CONFIG_CRYPTO_BLKCIPHER=y
      CONFIG_CRYPTO_BLKCIPHER2=y
      CONFIG_CRYPTO_HASH=y
      CONFIG_CRYPTO_HASH2=y
      CONFIG_CRYPTO_RNG=y
      CONFIG_CRYPTO_RNG2=y
      CONFIG_CRYPTO_RNG_DEFAULT=y
      CONFIG_CRYPTO_AKCIPHER2=y
      CONFIG_CRYPTO_AKCIPHER=y
      CONFIG_CRYPTO_KPP2=y
      CONFIG_CRYPTO_KPP=y
      CONFIG_CRYPTO_ACOMP2=y
      CONFIG_CRYPTO_MANAGER=y
      CONFIG_CRYPTO_MANAGER2=y
      # CONFIG_CRYPTO_USER is not set
      CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y
      CONFIG_CRYPTO_NULL=y
      CONFIG_CRYPTO_NULL2=y
      # CONFIG_CRYPTO_PCRYPT is not set
      # CONFIG_CRYPTO_CRYPTD is not set
      # CONFIG_CRYPTO_AUTHENC is not set
      # CONFIG_CRYPTO_TEST is not set
      # Public-key cryptography
      CONFIG_CRYPTO_RSA=y
      # CONFIG_CRYPTO_DH is not set
      CONFIG_CRYPTO_ECC=y
      CONFIG_CRYPTO_ECDH=y
      # CONFIG_CRYPTO_ECRDSA is not set
      # Authenticated Encryption with Associated Data
      CONFIG_CRYPTO_CCM=y
      # CONFIG_CRYPTO_GCM is not set
      # CONFIG_CRYPTO_CHACHA20POLY1305 is not set
      # CONFIG_CRYPTO_AEGIS128 is not set
      CONFIG_CRYPTO_SEQIV=y
      # CONFIG_CRYPTO_ECHAINIV is not set
      # Block modes
      # CONFIG_CRYPTO_CBC is not set
      # CONFIG_CRYPTO_CFB is not set
      CONFIG_CRYPTO_CTR=y
      # CONFIG_CRYPTO_CTS is not set
      CONFIG_CRYPTO_ECB=y
      # CONFIG_CRYPTO_LRW is not set
      # CONFIG_CRYPTO_OFB is not set
      # CONFIG_CRYPTO_PCBC is not set
      # CONFIG_CRYPTO_XTS is not set
      # CONFIG_CRYPTO_KEYWRAP is not set
      # CONFIG_CRYPTO_ADIANTUM is not set
      # CONFIG_CRYPTO_ESSIV is not set
      # Hash modes
      CONFIG_CRYPTO_CMAC=y
      CONFIG_CRYPTO_HMAC=y
      # CONFIG_CRYPTO_XCBC is not set
      # CONFIG_CRYPTO_VMAC is not set
      # Digest
      CONFIG_CRYPTO_CRC32C=y
      # CONFIG_CRYPTO_CRC32 is not set
      # CONFIG_CRYPTO_XXHASH is not set
      # CONFIG_CRYPTO_CRCT10DIF is not set
      # CONFIG_CRYPTO_GHASH is not set
      # CONFIG_CRYPTO_POLY1305 is not set
      # CONFIG_CRYPTO_MD4 is not set
      # CONFIG_CRYPTO_MD5 is not set
      # CONFIG_CRYPTO_MICHAEL_MIC is not set
      # CONFIG_CRYPTO_RMD128 is not set
      # CONFIG_CRYPTO_RMD160 is not set
      # CONFIG_CRYPTO_RMD256 is not set
      # CONFIG_CRYPTO_RMD320 is not set
      # CONFIG_CRYPTO_SHA1 is not set
      CONFIG_CRYPTO_LIB_SHA256=y
      CONFIG_CRYPTO_SHA256=y
      # CONFIG_CRYPTO_SHA512 is not set
      # CONFIG_CRYPTO_SHA3 is not set
      # CONFIG_CRYPTO_SM3 is not set
      # CONFIG_CRYPTO_STREEBOG is not set
      # CONFIG_CRYPTO_TGR192 is not set
      # CONFIG_CRYPTO_WP512 is not set
      # Ciphers
      CONFIG_CRYPTO_LIB_AES=y
      CONFIG_CRYPTO_AES=y
      # CONFIG_CRYPTO_AES_TI is not set
      # CONFIG_CRYPTO_ANUBIS is not set
      CONFIG_CRYPTO_LIB_ARC4=y
      CONFIG_CRYPTO_ARC4=y
      # CONFIG_CRYPTO_BLOWFISH is not set
      # CONFIG_CRYPTO_CAMELLIA is not set
      # CONFIG_CRYPTO_CAST5 is not set
      # CONFIG_CRYPTO_CAST6 is not set
      # CONFIG_CRYPTO_DES is not set
      # CONFIG_CRYPTO_FCRYPT is not set
      # CONFIG_CRYPTO_KHAZAD is not set
      # CONFIG_CRYPTO_SALSA20 is not set
      # CONFIG_CRYPTO_CHACHA20 is not set
      # CONFIG_CRYPTO_SEED is not set
      # CONFIG_CRYPTO_SERPENT is not set
      # CONFIG_CRYPTO_SM4 is not set
      # CONFIG_CRYPTO_TEA is not set
      # CONFIG_CRYPTO_TWOFISH is not set
      # Compression
      CONFIG_CRYPTO_DEFLATE=y
      CONFIG_CRYPTO_LZO=y
      # CONFIG_CRYPTO_842 is not set
      # CONFIG_CRYPTO_LZ4 is not set
      # CONFIG_CRYPTO_LZ4HC is not set
      # CONFIG_CRYPTO_ZSTD is not set
      # Random Number Generation
      # CONFIG_CRYPTO_ANSI_CPRNG is not set
      CONFIG_CRYPTO_DRBG_MENU=y
      CONFIG_CRYPTO_DRBG_HMAC=y
      # CONFIG_CRYPTO_DRBG_HASH is not set
      # CONFIG_CRYPTO_DRBG_CTR is not set
      CONFIG_CRYPTO_DRBG=y
      CONFIG_CRYPTO_JITTERENTROPY=y
      # CONFIG_CRYPTO_USER_API_HASH is not set
      # CONFIG_CRYPTO_USER_API_SKCIPHER is not set
      # CONFIG_CRYPTO_USER_API_RNG is not set
      # CONFIG_CRYPTO_USER_API_AEAD is not set
      CONFIG_CRYPTO_HASH_INFO=y
      CONFIG_CRYPTO_HW=y
      # CONFIG_CRYPTO_DEV_ATMEL_ECC is not set
      # CONFIG_CRYPTO_DEV_ATMEL_SHA204A is not set
      # CONFIG_CRYPTO_DEV_SAFEXCEL is not set
      # CONFIG_CRYPTO_DEV_CCREE is not set
      # Support for Allwinner Sunxi CryptoEngine
      # Choose one according to the actual usage
      # CONFIG_CRYPTO_DEV_SUNXI is not set
      # CONFIG_CRYPTO_DEV_SUNXI_IOCTL is not set
      # end of Support for Allwinner Sunxi CryptoEngine
      # CONFIG_ASYMMETRIC_KEY_TYPE is not set
      # Certificates for signature checking
      # CONFIG_SYSTEM_BLACKLIST_KEYRING is not set
      # end of Certificates for signature checking
      # Library routines
      # CONFIG_PACKING is not set
      CONFIG_BITREVERSE=y
      CONFIG_HAVE_ARCH_BITREVERSE=y
      CONFIG_GENERIC_STRNCPY_FROM_USER=y
      CONFIG_GENERIC_STRNLEN_USER=y
      CONFIG_GENERIC_NET_UTILS=y
      # CONFIG_CORDIC is not set
      CONFIG_RATIONAL=y
      CONFIG_GENERIC_PCI_IOMAP=y
      CONFIG_ARCH_USE_CMPXCHG_LOCKREF=y
      # CONFIG_CRC_CCITT is not set
      CONFIG_CRC16=y
      # CONFIG_CRC_T10DIF is not set
      # CONFIG_CRC_ITU_T is not set
      CONFIG_CRC32=y
      # CONFIG_CRC32_SELFTEST is not set
      # CONFIG_CRC32_SLICEBY8 is not set
      # CONFIG_CRC32_SLICEBY4 is not set
      CONFIG_CRC32_SARWATE=y
      # CONFIG_CRC32_BIT is not set
      # CONFIG_CRC64 is not set
      # CONFIG_CRC4 is not set
      # CONFIG_CRC7 is not set
      # CONFIG_LIBCRC32C is not set
      # CONFIG_CRC8 is not set
      # CONFIG_RANDOM32_SELFTEST is not set
      CONFIG_ZLIB_INFLATE=y
      CONFIG_ZLIB_DEFLATE=y
      CONFIG_LZO_COMPRESS=y
      CONFIG_LZO_DECOMPRESS=y
      # CONFIG_XZ_DEC is not set
      CONFIG_GENERIC_ALLOCATOR=y
      CONFIG_ASSOCIATIVE_ARRAY=y
      CONFIG_HAS_IOMEM=y
      CONFIG_HAS_IOPORT_MAP=y
      CONFIG_HAS_DMA=y
      CONFIG_NEED_SG_DMA_LENGTH=y
      CONFIG_NEED_DMA_MAP_STATE=y
      CONFIG_DMA_DECLARE_COHERENT=y
      CONFIG_ARCH_HAS_SETUP_DMA_OPS=y
      CONFIG_ARCH_HAS_TEARDOWN_DMA_OPS=y
      CONFIG_DMA_REMAP=y
      CONFIG_DMA_CMA=y
      # Default contiguous memory area size:
      CONFIG_CMA_SIZE_MBYTES=16
      CONFIG_CMA_SIZE_SEL_MBYTES=y
      # CONFIG_CMA_SIZE_SEL_PERCENTAGE is not set
      # CONFIG_CMA_SIZE_SEL_MIN is not set
      # CONFIG_CMA_SIZE_SEL_MAX is not set
      CONFIG_CMA_ALIGNMENT=8
      # CONFIG_DMA_API_DEBUG is not set
      CONFIG_SGL_ALLOC=y
      CONFIG_CPU_RMAP=y
      CONFIG_DQL=y
      CONFIG_NLATTR=y
      CONFIG_CLZ_TAB=y
      # CONFIG_IRQ_POLL is not set
      CONFIG_MPILIB=y
      CONFIG_LIBFDT=y
      CONFIG_GENERIC_GETTIMEOFDAY=y
      CONFIG_SG_POOL=y
      CONFIG_SBITMAP=y
      # CONFIG_STRING_SELFTEST is not set
      # end of Library routines
      # Kernel hacking
      # printk and dmesg options
      CONFIG_PRINTK_TIME=y
      # CONFIG_PRINTK_CALLER is not set
      CONFIG_CONSOLE_LOGLEVEL_DEFAULT=7
      CONFIG_CONSOLE_LOGLEVEL_QUIET=4
      CONFIG_MESSAGE_LOGLEVEL_DEFAULT=4
      # CONFIG_BOOT_PRINTK_DELAY is not set
      # CONFIG_DYNAMIC_DEBUG is not set
      # CONFIG_DYNAMIC_DEBUG_CORE is not set
      # end of printk and dmesg options
      # Compile-time checks and compiler options
      # CONFIG_DEBUG_INFO is not set
      CONFIG_ENABLE_MUST_CHECK=y
      CONFIG_FRAME_WARN=2048
      # CONFIG_STRIP_ASM_SYMS is not set
      # CONFIG_READABLE_ASM is not set
      CONFIG_DEBUG_FS=y
      # CONFIG_HEADERS_INSTALL is not set
      CONFIG_OPTIMIZE_INLINING=y
      # CONFIG_DEBUG_SECTION_MISMATCH is not set
      CONFIG_SECTION_MISMATCH_WARN_ONLY=y
      # CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set
      # end of Compile-time checks and compiler options
      # CONFIG_MAGIC_SYSRQ is not set
      CONFIG_DEBUG_KERNEL=y
      CONFIG_DEBUG_MISC=y
      # Memory Debugging
      # CONFIG_PAGE_EXTENSION is not set
      # CONFIG_DEBUG_PAGEALLOC is not set
      # CONFIG_PAGE_OWNER is not set
      # CONFIG_PAGE_POISONING is not set
      # CONFIG_DEBUG_RODATA_TEST is not set
      # CONFIG_DEBUG_OBJECTS is not set
      # CONFIG_SLUB_STATS is not set
      CONFIG_HAVE_DEBUG_KMEMLEAK=y
      # CONFIG_DEBUG_KMEMLEAK is not set
      # CONFIG_DEBUG_STACK_USAGE is not set
      # CONFIG_DEBUG_VM is not set
      CONFIG_ARCH_HAS_DEBUG_VIRTUAL=y
      # CONFIG_DEBUG_VIRTUAL is not set
      # CONFIG_DEBUG_MEMORY_INIT is not set
      # CONFIG_DEBUG_PER_CPU_MAPS is not set
      CONFIG_CC_HAS_KASAN_GENERIC=y
      CONFIG_KASAN_STACK=1
      # end of Memory Debugging
      CONFIG_ARCH_HAS_KCOV=y
      CONFIG_CC_HAS_SANCOV_TRACE_PC=y
      # CONFIG_KCOV is not set
      # CONFIG_DEBUG_SHIRQ is not set
      # Debug Lockups and Hangs
      # CONFIG_SOFTLOCKUP_DETECTOR is not set
      # CONFIG_DETECT_HUNG_TASK is not set
      # CONFIG_WQ_WATCHDOG is not set
      # end of Debug Lockups and Hangs
      # CONFIG_PANIC_ON_OOPS is not set
      CONFIG_PANIC_ON_OOPS_VALUE=0
      CONFIG_PANIC_TIMEOUT=0
      # CONFIG_SCHED_DEBUG is not set
      # CONFIG_SCHEDSTATS is not set
      # CONFIG_SCHED_STACK_END_CHECK is not set
      # CONFIG_DEBUG_TIMEKEEPING is not set
      # CONFIG_DEBUG_PREEMPT is not set
      # Lock Debugging (spinlocks, mutexes, etc...)
      CONFIG_LOCK_DEBUGGING_SUPPORT=y
      # CONFIG_PROVE_LOCKING is not set
      # CONFIG_LOCK_STAT is not set
      # CONFIG_DEBUG_RT_MUTEXES is not set
      # CONFIG_DEBUG_SPINLOCK is not set
      CONFIG_DEBUG_MUTEXES=y
      # CONFIG_DEBUG_WW_MUTEX_SLOWPATH is not set
      # CONFIG_DEBUG_RWSEMS is not set
      # CONFIG_DEBUG_LOCK_ALLOC is not set
      # CONFIG_DEBUG_ATOMIC_SLEEP is not set
      # CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set
      # CONFIG_LOCK_TORTURE_TEST is not set
      # CONFIG_WW_MUTEX_SELFTEST is not set
      # end of Lock Debugging (spinlocks, mutexes, etc...)
      # CONFIG_STACKTRACE is not set
      # CONFIG_WARN_ALL_UNSEEDED_RANDOM is not set
      # CONFIG_DEBUG_KOBJECT is not set
      # CONFIG_DEBUG_BUGVERBOSE is not set
      # CONFIG_DEBUG_LIST is not set
      # CONFIG_DEBUG_PLIST is not set
      # CONFIG_DEBUG_SG is not set
      # CONFIG_DEBUG_NOTIFIERS is not set
      # CONFIG_DEBUG_CREDENTIALS is not set
      # RCU Debugging
      # CONFIG_RCU_PERF_TEST is not set
      # CONFIG_RCU_TORTURE_TEST is not set
      CONFIG_RCU_CPU_STALL_TIMEOUT=20
      # CONFIG_RCU_TRACE is not set
      # CONFIG_RCU_EQS_DEBUG is not set
      # end of RCU Debugging
      # CONFIG_DEBUG_WQ_FORCE_RR_CPU is not set
      # CONFIG_DEBUG_BLOCK_EXT_DEVT is not set
      # CONFIG_CPU_HOTPLUG_STATE_CONTROL is not set
      # CONFIG_NOTIFIER_ERROR_INJECTION is not set
      # CONFIG_FAULT_INJECTION is not set
      # CONFIG_LATENCYTOP is not set
      CONFIG_HAVE_FUNCTION_TRACER=y
      CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y
      CONFIG_HAVE_DYNAMIC_FTRACE=y
      CONFIG_HAVE_DYNAMIC_FTRACE_WITH_REGS=y
      CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y
      CONFIG_HAVE_SYSCALL_TRACEPOINTS=y
      CONFIG_HAVE_C_RECORDMCOUNT=y
      CONFIG_TRACING_SUPPORT=y
      # CONFIG_FTRACE is not set
      # CONFIG_RUNTIME_TESTING_MENU is not set
      # CONFIG_MEMTEST is not set
      # CONFIG_BUG_ON_DATA_CORRUPTION is not set
      # CONFIG_SAMPLES is not set
      CONFIG_HAVE_ARCH_KGDB=y
      # CONFIG_KGDB is not set
      # CONFIG_UBSAN is not set
      CONFIG_UBSAN_ALIGNMENT=y
      CONFIG_ARCH_HAS_DEVMEM_IS_ALLOWED=y
      # CONFIG_ARM_PTDUMP_DEBUGFS is not set
      # CONFIG_DEBUG_WX is not set
      # CONFIG_UNWINDER_FRAME_POINTER is not set
      CONFIG_UNWINDER_ARM=y
      CONFIG_ARM_UNWIND=y
      # CONFIG_DEBUG_USER is not set
      CONFIG_DEBUG_LL=y
      # CONFIG_DEBUG_SUNXI_UART0 is not set
      # CONFIG_DEBUG_SUNXI_UART1 is not set
      # CONFIG_DEBUG_SUNXI_UART2 is not set
      # CONFIG_DEBUG_ICEDCC is not set
      # CONFIG_DEBUG_SEMIHOSTING is not set
      CONFIG_DEBUG_LL_UART_8250=y
      # CONFIG_DEBUG_LL_UART_PL01X is not set
      CONFIG_DEBUG_LL_INCLUDE="debug/8250.S"
      CONFIG_DEBUG_UART_PHYS=0x02500C00
      CONFIG_DEBUG_UART_VIRT=0xf2500C00
      CONFIG_DEBUG_UART_8250_SHIFT=2
      # CONFIG_DEBUG_UART_8250_WORD is not set
      # CONFIG_DEBUG_UART_8250_PALMCHIP is not set
      # CONFIG_DEBUG_UART_8250_FLOW_CONTROL is not set
      # CONFIG_DEBUG_UNCOMPRESS is not set
      CONFIG_UNCOMPRESS_INCLUDE="debug/uncompress.h"
      CONFIG_EARLY_PRINTK=y
      # CONFIG_PID_IN_CONTEXTIDR is not set
      # CONFIG_SUNXI_DUMP is not set
      # CONFIG_CORESIGHT is not set
      # end of Kernel hacking
      加载顺序:
      insmod videobuf2-memops.ko
      insmod videobuf2-dma-contig.ko
      insmod videobuf2-vmalloc.ko
      insmod vin_io.ko
      insmod ov5640.ko
      insmod vin_v4l2.ko
      错误日志(能识别到ov5640):
      • Q
        qq1844641696 LV 2 最后由 编辑
        请问您解决了吗?我也是差不多这个问题
        S 1 条回复 最后回复 回复 引用 分享 1
          shz18877605430 LV 6 @qq1844641696 最后由 编辑
          @qq1844641696 在 全志T113-s3使用ov5640加载insmod vin_v4l2.ko报错 中说:
          请问您解决了吗?我也是差不多这个问题
          没有哦
          H 1 条回复 最后回复 回复 引用 分享 1
            HGB13717358664 LV 2 最后由 编辑
            我也遇到这个问题,
              WhycanService LV 8 最后由 编辑
              D1-H (MQ-Pro)驱动 OV5640 摄像头
              https://bbs.aw-ol.com/topic/4017/share/1
                zhanweixin LV 5 最后由 编辑
                请问大伙解决该问题了吗?
                  honghu886 LV 4 @shz18877605430 最后由 编辑
                  @shz18877605430 报错是使用呢CSI 不是MIPI-CSIS
