    V853 编译MPP sample ,开发板运行报错
    • Q
      qlfylp LV 4 最后由 编辑
      使用大佬给的mpp 编译示例代码
      https://gitee.com/GloomyGhost/Yuzukilizard/tree/master/Software/sunxi-mpp
      开发板烧录出厂固件,运行自己编译的sample_virvi2vo出现报错:
      ISP_ERR]isp_sync_debug_info, line: 747,VIDIOC_VIN_ISP_GET_INFO error!
      运行结果:
      root@TinaLinux:/# ./sample_virvi2vo
      I0102 01:03:18.723946  1133 dup2SeldomUsedFd.c:20]          <dup2SeldomUsedFdInit> gFdLock init
      I0102 01:03:18.725167  1133 sample_virvi2vo.c:1013]         <main> sample_virvi2vo running!
      I0102 01:03:18.726318  1133 sample_virvi2vo.c:108]          <ParseCmdLine> sample_virvi2vo path:[./sample_virvi2vo], arg number is [1]
      I0102 01:03:18.726901  1133 sample_virvi2vo.c:208]          <loadSampleVIRVI2VOConfig> user not set config file. use default test parameter!
      I0102 01:03:18.727514  1133 mpi_sys.c:840]                  <AW_MPI_SYS_SetConf> kfctmpdir is [/tmp]
      >>>>>>>>>>>>>>>>>>>>>>>>>>>>> Media Process Platform<<<<<<<<<<<<<<<<<<<<<<<<<<<<
      modName : MPP-Platform
      tag   : V1.0 Release
      branch: v5-dev
      commit: 4eed413532ad87725895a8cb1ba75e22fc328233
      date  : 20170725
      author: jenkins
      iniparser: cannot open /etc/cedarx.conf
      iniparser: cannot open /vendor/etc/cedarx.conf
      I0102 01:03:18.732061  1133 mpi_sys.c:1280]                 <AW_MPI_SYS_Init> ISP init
      [ISP]>>>>>>>>>>>>>>>>>>>> ISP VERSION INFO <<<<<<<<<<<<<<<<<<<
      IPCORE: ISP600
      branch: libisp-dev
      commit: 14df8348718d093707641fea73eba7db962885f5
      date  : Thu Jul 14 15:40:38 2022 +0800
      I0102 01:03:18.733427  1133 mpi_sys.c:1282]                 <AW_MPI_SYS_Init> ISP init done
      INFO   : cedarc <VeInitialize:1185>: *** ic_version = 0x1302000023010,
      I0102 01:03:18.743707  1133 hwdisplay.c:84]                 <hw_display_init>
      I0102 01:03:18.744235  1133 hwdisplay.c:993]                <hwd_init> (hwd_init 993)
      I0102 01:03:18.744999  1133 hwdisplay.c:1048]               <hwd_init> ret[0][2,0]ch[0]lyl[0] init: enable[0], screenwin[0,0, 0x0], zorder[0], alpha[mode:0, value:0]
      I0102 01:03:18.746042  1133 alsa_interface.c:701]           <alsaOpenMixer> open mixer:hw:0
      I0102 01:03:18.811126  1133 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADC1 ADC2 swap
      I0102 01:03:18.811806  1133 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADC1 volume
      I0102 01:03:18.812022  1133 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADC2 volume
      I0102 01:03:18.812562  1133 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADCDRC
      I0102 01:03:18.812770  1133 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADCHPF
      I0102 01:03:18.813327  1133 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:DAC volume
      I0102 01:03:18.813496  1133 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:DACDRC
      I0102 01:03:18.814022  1133 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:DACHPF
      I0102 01:03:18.814205  1133 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEIN
      I0102 01:03:18.814854  1133 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEINL gain volume
      I0102 01:03:18.815436  1133 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEINR gain volume
      I0102 01:03:18.815982  1133 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEOUT
      I0102 01:03:18.816185  1133 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEOUT Output Select
      I0102 01:03:18.816871  1133 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEOUT volume
      I0102 01:03:18.817492  1133 alsa_interface.c:756]           <alsaOpenMixer> set playback vol_val to value: 27
      I0102 01:03:18.818067  1133 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC1
      I0102 01:03:18.818730  1133 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC1 Input Select
      I0102 01:03:18.819352  1133 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC1 gain volume
      I0102 01:03:18.819902  1133 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC2
      I0102 01:03:18.820447  1133 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC2 Input Select
      I0102 01:03:18.820995  1133 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC2 gain volume
      I0102 01:03:18.821593  1133 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:SPK
      I0102 01:03:18.822623  1133 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:digital volume
      I0102 01:03:18.823215  1133 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:rx sync mode
      I0102 01:03:18.824096  1133 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:tx hub mode
      I0102 01:03:18.824821  1133 hwdisplay.c:1248]               <hwd_get_disp_type> Current the  disp_type:0x1  tv_mode:0x0
      I0102 01:03:18.845957  1133 sample_virvi2vo.c:390]          <CreateVIPP2VOLink> Vipp dev[0] vir_chn[0]
      [ISP]video device name is vin_video0
      [ISP]open video device[0], detect isp0 success!
      I0102 01:03:18.847557  1133 media_debug.c:45]               <getDictByConfPath> MPP_DEDIA_DEBUG_FILE_PATH=(null)
      I0102 01:03:18.848756  1133 videoInputHw.c:942]             <videoInputHw_SetChnAttr> ViCh[0] update width:480(480), height:270(272)
      [ISP]video0 fd[10] ve_online_en=0, dma_buf_num=0
      [ISP]open isp device[0] success!
      [ISP_WARN]open /mnt/extsd/isp0_1920_1088_20_ctx_saved.bin failed, err:No such file or directory.
      [ISP]prefer isp config: [gc2053_mipi], 1920x1088, 20, 0, 0
      [ISP]find gc2053_mipi_1920_1088_20_0 [gc2053_mipi_isp600_20220511_164617_vlc4_day] isp config
      I0102 01:03:19.138206  1133 mpi_vi.c:1018]                  <AW_MPI_VI_CreateVirChn> we allow to create virChn[0] in disable status of vipp[0]
      I0102 01:03:19.139041  1133 VideoVirVi_Component.c:1160]    <VideoViComponentInit> VideoVirvi component Init! thread_id[0xb6b48d50]
      I0102 01:03:19.173482  1136 videoInputHw.c:4787]            <VideoInputHw_CapThread> loop VideoInputHw_CapThread vipp_id = 0, buf_num=5.
      I0102 01:03:19.364667  1133 hwdisplay.c:1121]               <hwd_layer_request_hlay> hlay:0, zorder=0, cnt:2
      I0102 01:03:19.364933  1133 mpi_vo.c:1038]                  <AW_MPI_VO_SetVideoLayerAttr> ch[0]lyl[0]:dispRect changed, [0, 0, 320x240]->[0, 0, 480x800]
      I0102 01:03:19.365089  1133 hwdisplay.c:409]                <hwd_layer_set_rect> ch[0]lyl[0]: screen_win[0,0, 480x800]
      I0102 01:03:19.365897  1133 sample_virvi2vo.c:507]          <CreateVIPP2VOLink> create vo channel[0] success!
      I0102 01:03:19.382664  1133 sample_virvi2vo.c:384]          <CreateVIPP2VOLink> do not need create link for idx[1]
      [ISP_ERR]isp_stat_process_buffer, line: 268,AEWB: stats error, skipping buffer.
      [ISP_WARN]gc2053_mipi get sensor_temp failed: Invalid argument (22).
      [ISP_ERR]isp_sync_debug_info, line: 747,VIDIOC_VIN_ISP_GET_INFO error!
      I0102 01:03:19.589001  1137 video_render_linux.cpp:224]     <vr4l_init> mDisplayFormat[0x11], new CedarXNativeRenderer
      W0102 01:03:19.589246  1137 CedarXNativeRenderer.cpp:161]   <CedarXNativeRenderer> bufHeight[272]!=display_height[270]
      I0102 01:03:19.589389  1137 CedarXNativeRenderer.cpp:176]   <CedarXNativeRenderer> hwc disp fmt[0x63], color space:260
      I0102 01:03:19.589508  1137 hwdisplay.c:240]                <hwd_layer_set_src> x: 0, y: 0, width: 0x1e0, height: 0x10e
      I0102 01:03:19.589613  1137 hwdisplay.c:247]                <hwd_layer_set_src> width: 0x1e000000000, height: 0x10e00000000
      I0102 01:03:19.589718  1137 hwdisplay.c:367]                <hwd_layer_set_src> set fb.format 99 77, color_space 260 end, size0[480x272], size1[240x136]
      I0102 01:03:19.589875  1137 sample_virvi2vo.c:63]           <SampleVIRVI2VO_VOCallbackWrapper> VO callback: VO Layer[0] chn[0] event:257
      I0102 01:03:19.590001  1137 sample_virvi2vo.c:75]           <SampleVIRVI2VO_VOCallbackWrapper> vo layer[0] report video display size[480x270]
      I0102 01:03:19.590707  1137 VideoRender_Component.c:2318]   <VideoRender_ComponentThread> init video_render, param: displayRect[0,0][480x270], bufSize[480x272], vdecColorFormat[0x5]
      I0102 01:03:19.591332  1137 mpi_vo.c:508]                   <VideoRenderEventHandler> KeyFrameDecoded, pts[226784391]us
      I0102 01:03:19.603273  1137 sample_virvi2vo.c:63]           <SampleVIRVI2VO_VOCallbackWrapper> VO callback: VO Layer[0] chn[0] event:258
      I0102 01:03:19.603833  1137 sample_virvi2vo.c:80]           <SampleVIRVI2VO_VOCallbackWrapper> vo layer[0] report rendering start
      [ISP]video device name is vin_video12
      [ISP]open video device[12], detect isp0 success!
      [ISP]---------   LDCI Video12 Init OK   ---------
      [ISP]--------- LDCI Video12 Streamon OK ---------
      ^CI0102 01:03:21.801733  1133 sample_virvi2vo.c:310]        <handle_exit> user want to exit!
      I0102 01:03:21.826665  1137 VideoRender_Component.c:1750]   <VideoRender_ComponentThread> VideoLayer[0]: release [2]used inputFrame!
      I0102 01:03:21.928916  1135 VideoVirVi_Component.c:1206]    <Vi_ComponentThread> vipp[0]virChn[0]:begin to wait using frame return
      I0102 01:03:21.929676  1133 VideoVirVi_Component.c:1056]    <VideoViComponentDeInit> VideoVirvi component exited!
      [ISP]save isp_ctx to /mnt/extsd/isp0_1920_1088_20_ctx_saved.bin success, data_len:24512!!!
      [ISP]--------- LDCI Video12 Stream Off ---------
      [ISP]---------  LDCI Video12 Exit OK   ---------
      [ISP_ERR]isp_get_ev_lv_adj, line: 1439,isp0 device is NULL!
      I0102 01:03:22.022270  1133 sample_virvi2vo.c:598]          <DestroyVIPP2VOLink> do not need destroy link for idx[1]
      I0102 01:03:22.042642  1133 alsa_interface.c:790]           <alsaCloseMixer> close mixer
      I0102 01:03:22.043055  1133 hwdisplay.c:1062]               <hwd_exit> (hwd_exit 1062)
      I0102 01:03:22.434626  1133 sample_virvi2vo.c:1114]         <main> ./sample_virvi2vo test result: success
      I0102 01:03:22.435249  1133 dup2SeldomUsedFd.c:30]          <dup2SeldomUsedFdExit> gFdLock destroy
      运行官方的实例程序,运行结果:
      root@TinaLinux:/# sample_virvi2vo
      I0102 01:06:04.542054  1138 dup2SeldomUsedFd.c:20]          <dup2SeldomUsedFdInit> gFdLock init
      I0102 01:06:04.631996  1138 sample_virvi2vo.c:1017]         <main> sample_virvi2vo running!
      I0102 01:06:04.632490  1138 sample_virvi2vo.c:108]          <ParseCmdLine> sample_virvi2vo path:[sample_virvi2vo], arg number is [1]
      I0102 01:06:04.632623  1138 sample_virvi2vo.c:208]          <loadSampleVIRVI2VOConfig> user not set config file. use default test parameter!
      I0102 01:06:04.632779  1138 mpi_sys.c:840]                  <AW_MPI_SYS_SetConf> kfctmpdir is [/tmp]
      tag   : V1.0 Release
      branch: v5-dev
      date  : 20170725
      author: jenkins
      I0102 01:06:04.686075  1138 mpi_sys.c:1280]                 <AW_MPI_SYS_Init> ISP init
      IPCORE: ISP600
      branch: libisp-dev
      commit: c154641862e08383b2fe850864fd334ead24d538
      date  : Tue May 31 15:09:49 2022 +0800
      I0102 01:06:04.687489  1138 mpi_sys.c:1282]                 <AW_MPI_SYS_Init> ISP init done
      INFO   : cedarc <VeInitialize:1183>: *** ic_version = 0x1302000023010,
      I0102 01:06:04.738570  1138 hwdisplay.c:84]                 <hw_display_init>
      I0102 01:06:04.738799  1138 hwdisplay.c:993]                <hwd_init> (hwd_init 993)
      I0102 01:06:04.738983  1138 hwdisplay.c:1048]               <hwd_init> ret[0][2,0]ch[2]lyl[0] init: enable[0], screenwin[0,0, 0x0], zorder[0], alpha[mode:0, value:0]
      I0102 01:06:04.739522  1138 alsa_interface.c:679]           <alsaOpenMixer> open mixer:hw:0
      I0102 01:06:04.745839  1138 alsa_interface.c:714]           <alsaOpenMixer> alsa_elem:ADC1 ADC2 swap
      I0102 01:06:04.746406  1138 alsa_interface.c:714]           <alsaOpenMixer> alsa_elem:ADC1 volume
      I0102 01:06:04.746612  1138 alsa_interface.c:714]           <alsaOpenMixer> alsa_elem:ADC2 volume
      I0102 01:06:04.746761  1138 alsa_interface.c:714]           <alsaOpenMixer> alsa_elem:ADCDRC
      I0102 01:06:04.746891  1138 alsa_interface.c:714]           <alsaOpenMixer> alsa_elem:ADCHPF
      I0102 01:06:04.747460  1138 alsa_interface.c:714]           <alsaOpenMixer> alsa_elem:DAC volume
      I0102 01:06:04.747625  1138 alsa_interface.c:714]           <alsaOpenMixer> alsa_elem:DACDRC
      I0102 01:06:04.748160  1138 alsa_interface.c:714]           <alsaOpenMixer> alsa_elem:DACHPF
      I0102 01:06:04.748326  1138 alsa_interface.c:714]           <alsaOpenMixer> alsa_elem:LINEIN
      I0102 01:06:04.748972  1138 alsa_interface.c:714]           <alsaOpenMixer> alsa_elem:LINEINL gain volume
      I0102 01:06:04.749522  1138 alsa_interface.c:714]           <alsaOpenMixer> alsa_elem:LINEINR gain volume
      I0102 01:06:04.750062  1138 alsa_interface.c:714]           <alsaOpenMixer> alsa_elem:LINEOUT
      I0102 01:06:04.750948  1138 alsa_interface.c:714]           <alsaOpenMixer> alsa_elem:LINEOUT Output Select
      I0102 01:06:04.751540  1138 alsa_interface.c:714]           <alsaOpenMixer> alsa_elem:LINEOUT volume
      I0102 01:06:04.752098  1138 alsa_interface.c:734]           <alsaOpenMixer> set playback vol_val to value: 27
      I0102 01:06:04.752645  1138 alsa_interface.c:714]           <alsaOpenMixer> alsa_elem:MIC1
      I0102 01:06:04.753192  1138 alsa_interface.c:714]           <alsaOpenMixer> alsa_elem:MIC1 Input Select
      I0102 01:06:04.753727  1138 alsa_interface.c:714]           <alsaOpenMixer> alsa_elem:MIC1 gain volume
      I0102 01:06:04.754256  1138 alsa_interface.c:714]           <alsaOpenMixer> alsa_elem:MIC2
      I0102 01:06:04.754950  1138 alsa_interface.c:714]           <alsaOpenMixer> alsa_elem:MIC2 Input Select
      I0102 01:06:04.755498  1138 alsa_interface.c:714]           <alsaOpenMixer> alsa_elem:MIC2 gain volume
      I0102 01:06:04.756371  1138 alsa_interface.c:714]           <alsaOpenMixer> alsa_elem:SPK
      I0102 01:06:04.757207  1138 alsa_interface.c:714]           <alsaOpenMixer> alsa_elem:digital volume
      I0102 01:06:04.757790  1138 alsa_interface.c:714]           <alsaOpenMixer> alsa_elem:rx sync mode
      I0102 01:06:04.758879  1138 alsa_interface.c:714]           <alsaOpenMixer> alsa_elem:tx hub mode
      I0102 01:06:04.759770  1138 hwdisplay.c:1248]               <hwd_get_disp_type> Current the  disp_type:0x0  tv_mode:0x0
      I0102 01:06:04.780900  1138 mpi_vo.c:837]                   <AW_MPI_VO_SetPubAttr> vo interface changed, [0x0, 0x1]->[0x40, 0x1]
      I0102 01:06:04.781430  1138 hwdisplay.c:1486]               <hwd_switch_vo_device> Current the  disp_type:0x0  tv_mode:0x0
      I0102 01:06:05.317599  1138 sample_virvi2vo.c:394]          <CreateVIPP2VOLink> Vipp dev[0] vir_chn[0]
      I0102 01:06:05.319120  1138 videoInputHw.c:942]             <videoInputHw_SetChnAttr> ViCh[0] update width:1920(1920), height:1080(1088)
      [ISP]get isp_ctx from /mnt/extsd/isp0_1920_1088_20_ctx_saved.bin success!!!
      I0102 01:06:05.605578  1138 mpi_vi.c:1018]                  <AW_MPI_VI_CreateVirChn> we allow to create virChn[0] in disable status of vipp[0]
      I0102 01:06:05.606430  1138 VideoVirVi_Component.c:1141]    <VideoViComponentInit> VideoVirvi component Init! thread_id[0xb6b9dd50]
      I0102 01:06:05.654176  1141 videoInputHw.c:4785]            <VideoInputHw_CapThread> loop VideoInputHw_CapThread vipp_id = 0, buf_num=5.
      I0102 01:06:05.844675  1138 hwdisplay.c:1121]               <hwd_layer_request_hlay> hlay:0, zorder=0, cnt:2
      I0102 01:06:05.844949  1138 mpi_vo.c:1038]                  <AW_MPI_VO_SetVideoLayerAttr> ch[0]lyl[0]:dispRect changed, [0, 0, 320x240]->[0, 0, 1280x720]
      I0102 01:06:05.845105  1138 hwdisplay.c:409]                <hwd_layer_set_rect> ch[0]lyl[0]: screen_win[0,0, 1280x720]
      I0102 01:06:05.845876  1138 sample_virvi2vo.c:511]          <CreateVIPP2VOLink> create vo channel[0] success!
      I0102 01:06:05.862427  1138 sample_virvi2vo.c:388]          <CreateVIPP2VOLink> do not need create link for idx[1]
      I0102 01:06:06.069447  1142 video_render_linux.cpp:224]     <vr4l_init> mDisplayFormat[0x11], new CedarXNativeRenderer
      I0102 01:06:06.069705  1142 CedarXNativeRenderer.cpp:176]   <CedarXNativeRenderer> hwc disp fmt[0x63], color space:260
      I0102 01:06:06.069852  1142 hwdisplay.c:240]                <hwd_layer_set_src> x: 0, y: 0, width: 0x780, height: 0x440
      I0102 01:06:06.069967  1142 hwdisplay.c:247]                <hwd_layer_set_src> width: 0x78000000000, height: 0x44000000000
      I0102 01:06:06.070076  1142 hwdisplay.c:367]                <hwd_layer_set_src> set fb.format 99 77, color_space 260 end, size0[1920x1088], size1[960x544]
      I0102 01:06:06.070214  1142 sample_virvi2vo.c:63]           <SampleVIRVI2VO_VOCallbackWrapper> VO callback: VO Layer[0] chn[0] event:257
      I0102 01:06:06.070337  1142 sample_virvi2vo.c:75]           <SampleVIRVI2VO_VOCallbackWrapper> vo layer[0] report video display size[1920x1088]
      I0102 01:06:06.070448  1142 VideoRender_Component.c:2318]   <VideoRender_ComponentThread> init video_render, param: displayRect[0,0][1920x1088], bufSize[1920x1088], vdecColorFormat[0x5]
      I0102 01:06:06.070550  1142 mpi_vo.c:508]                   <VideoRenderEventHandler> KeyFrameDecoded, pts[393264784]us
      I0102 01:06:06.082078  1142 sample_virvi2vo.c:63]           <SampleVIRVI2VO_VOCallbackWrapper> VO callback: VO Layer[0] chn[0] event:258
      I0102 01:06:06.082635  1142 sample_virvi2vo.c:80]           <SampleVIRVI2VO_VOCallbackWrapper> vo layer[0] report rendering start
      ^CI0102 01:06:09.403068  1138 sample_virvi2vo.c:310]        <handle_exit> user want to exit!
      I0102 01:06:09.427467  1142 VideoRender_Component.c:1750]   <VideoRender_ComponentThread> VideoLayer[0]: release [2]used inputFrame!
      I0102 01:06:09.534250  1140 VideoVirVi_Component.c:1187]    <Vi_ComponentThread> vipp[0]virChn[0]:begin to wait using frame return
      I0102 01:06:09.535093  1138 VideoVirVi_Component.c:1037]    <VideoViComponentDeInit> VideoVirvi component exited!
      [ISP_ERR]isp_get_ev_lv_adj, line: 1435,isp0 device is NULL!
      I0102 01:06:09.610904  1138 sample_virvi2vo.c:602]          <DestroyVIPP2VOLink> do not need destroy link for idx[1]
      I0102 01:06:09.631278  1138 alsa_interface.c:768]           <alsaCloseMixer> close mixer
      I0102 01:06:09.631685  1138 hwdisplay.c:1062]               <hwd_exit> (hwd_exit 1062)
      I0102 01:06:10.024622  1138 sample_virvi2vo.c:1314]         <main> sample_virvi2vo test result: success
      I0102 01:06:10.025248  1138 dup2SeldomUsedFd.c:30]          <dup2SeldomUsedFdExit> gFdLock destroy
      这个报错,我在运行自己其他的示例程序也会出现,但是它好像不影响运行的结果,但是这也是不正常的吧,我尝试修改了一部分代码,但是我不知道是什么地方导致了这个错误的发生,萌新求助,感谢大佬!
      F 1 条回复 最后回复 回复 引用 分享 1
      • F
        forever18 LV 3 @qlfylp 最后由 编辑
        @qlfylp 请问问题解决了吗,我也是这个问题
          Monster LV 2 最后由 编辑
          顶顶顶DINGDINGDING
