    v853 mboot编译失败
      cruise33 LV 6 最后由 编辑
      xxxx@server:~/workspace/tina-v85x_1.1$ mboot
      v853_vision v853 v853-vision
      build_boot platform:sun8iw21p1 o_option:uboot
      grep: /home/data1/xxxx/workspace/tina-v85x_1.1/lichee/brandy-2.0/spl/Makefile: No such file or directory
      Prepare toolchain ...
      build for sun8iw21p1_defconfig ...
      cat: .tmp_config_from_defconfig.o.md5sum: No such file or directory
      md5sum: .config: No such file or directory
        CLEAN   scripts/basic
        HOSTCC  scripts/basic/fixdep
        HOSTCC  scripts/kconfig/conf.o
        YACC    scripts/kconfig/zconf.tab.c
      /bin/sh: 1: bison: not found
      scripts/Makefile.lib:228: recipe for target 'scripts/kconfig/zconf.tab.c' failed
      make[1]: *** [scripts/kconfig/zconf.tab.c] Error 127
      Makefile:547: recipe for target 'sun8iw21p1_defconfig' failed
      make: *** [sun8iw21p1_defconfig] Error 2
      muboot stop for build error in brandy, Please check!
      这是V1.1版本的SDK,不确定之前V1.0是否就有这个问题
      • DAIZEBIN
        DAIZEBIN LV 7 @cruise33 最后由 编辑
        @cruise33 这个是你服务器没安装好需要的包
        试一下执行 sudo apt-get install bison,之后在make
          cruise33 LV 6 @DAIZEBIN 最后由 编辑
          @daizebin 安装后可以编译了。
          但报了新的问题
          arch/arm/cpu/armv7/built-in.o: In function `cleanup_before_linux_select':
          /home/data1/xxxx/workspace/tina-v853/lichee/brandy-2.0/u-boot-2018/arch/arm/cpu/armv7/cpu.c:43: undefined reference to `dcache_disable'
          /home/data1/xxxx/workspace/tina-v853/lichee/brandy-2.0/u-boot-2018/arch/arm/cpu/armv7/cpu.c:58: undefined reference to `icache_disable'
          /home/data1/xxxx/workspace/tina-v853/lichee/brandy-2.0/u-boot-2018/arch/arm/cpu/armv7/cpu.c:64: undefined reference to `icache_disable'
          /home/data1/xxxx/workspace/tina-v853/lichee/brandy-2.0/u-boot-2018/arch/arm/cpu/armv7/cpu.c:69: undefined reference to `icache_enable'
          arch/arm/mach-sunxi/built-in.o: In function `enable_caches':
          /home/data1/xxxx/workspace/tina-v853/lichee/brandy-2.0/u-boot-2018/arch/arm/mach-sunxi/board.c:170: undefined reference to `dcache_enable'
          cmd/built-in.o: In function `do_sprite_test':
          /home/data1/xxxx/workspace/tina-v853/lichee/brandy-2.0/u-boot-2018/cmd/sunxi_sprite.c:74: undefined reference to `dcache_disable'
          ./../tools/toolchain/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabi/bin/arm-linux-gnueabi-ld.bfd: BFD (Linaro_Binutils-2017.11) 2.28.2.20170706 assertion fail /home/tcwg-buildslave/workspace/tcwg-make-release/builder_arch/amd64/label/tcwg-x86_64-build/target/arm-linux-gnueabi/snapshots/binutils-gdb.git~users~linaro~binutils-2_28-branch/bfd/elf32-arm.c:9514
          Makefile:1496: recipe for target 'u-boot' failed
          make: *** [u-boot] Error 1
