    V853 无法烧录问题@whycan晕哥
    17
    9714
      wl17761275256 LV 5 最后由 wl17761275256 编辑
      硬件背景
      1、原理图参考官方双目开发板,电源管理使用 AXP2101。
      2、EMMC使用妙存-AT70B08G3S03F。上电测试EMMC_CLK是50MHz波形。
      烧录操作
      1、开机上电USB供电5V。
      2、使用PhoenixSuit.exe软件烧录固件。
      3、附图烧录
      4、附开机打印日志
      开机打印.txt
      打印到最后就没有了。一直停在这个位置
      CCC[2313]fes begin commit:4b419f21ba
      [2317]PMU: AXP21
      [2320]set pll start
      [2322]periph0 has been enabled
      [2325]set pll end
      [2327]board init ok
      [2329]beign to init dram
      [2331]DRAM use external ZQ!!
      [2334]chip id check OK
      [2336]DRAM_VCC set to 1500 mv
      [2339]trefi:7.8ms
      [2342][AUTO DEBUG] single rank and full DQ!
      [2346]trefi:7.8ms
      [2348][AUTO DEBUG] rank 0 row = 15
      [2352][AUTO DEBUG] rank 0 bank = 8
      [2355][AUTO DEBUG] rank 0 page size = 2 KB
      [2359]DRAM BOOT DRIVE INFO: V0.16
      [2362]DRAM CLK = 936 MHz
      [2364]DRAM Type = 3 (2:DDR2,3:DDR3)
      [2368]DRAMC ZQ value: 0x7b7bfb
      [2371]DRAM ODT value: 0x42.
      [2374]DRAM SIZE =512 M
      [2376]dram_tpr4:0x0
      [2380]DRAM simple test OK.
      [2382]rtc standby flag is 0x0, super standby flag is 0x0
      [2387]init dram ok
      U-Boot 2018.05 (Apr 25 2023 - 11:52:11 +0800) Allwinner Technology
      [04.899]CPU:   Allwinner Family
      [04.902]Model: sun8iw21
      I2C:   ready
      [04.928]DRAM:  512 MiB
      [04.932]Relocation Offset is: 1ced0000
      [04.956]secure enable bit: 0
      [04.959]PMU: AXP21
      [04.961]PMU: pmu_axp2101 found
      [04.964]BMU: AXP21
      [04.965]BMU: bmu_axp2101 found
      FDT ERROR:fdt_get_regulator_name:get property handle twi-supply error:FDT_ERR_INTERNAL
      [04.976]gpio_bias, pc_bias: 1800, pc_supply: not set
      [04.981]gpio_bias, pl_bias:   -1, pl_supply: not set
      [04.986]dcdc1_vol = 3300, onoff=1
      [04.990]dcdc2_vol = 900, onoff=1
      [04.993]dcdc5_vol = 0, onoff=0
      [04.996]aldo1_vol = 1800, onoff=1
      [05.000]aldo2_vol = 1800, onoff=1
      [05.003]aldo3_vol = 3300, onoff=1
      [05.007]aldo4_vol = 3300, onoff=1
      [05.010]bldo1_vol = 1800, onoff=1
      [05.014]bldo2_vol = 2800, onoff=1
      [05.017]dldo1_vol = 3300, onoff=1
      [05.021]dldo2_vol = 1200, onoff=1
      bias_name:pc_bias        bias_vol:1800
      bias_name:pi_bias        bias_vol:1800
      [05.031]bat_vol=36, ratio=0
      [05.033]safe_vol=3500, safe_ratio=1
      [05.037]CPU=900 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=24Mhz  MBus=300Mhz
      [05.043]gic: normal mode
      sunxi flash map init
      [05.047]flash init start
      [05.049]workmode = 16,storage type = 0
      try card 2
      set card number 2
      get card number 2
      [05.057][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
      [05.063][mmc]: get sdc_type fail and use default host:tm4.
      [05.070][mmc]: Is not Boot mode!
      [05.072][mmc]: SUNXI SDMMC Controller Version:0x50400
      [05.083][mmc]: ************Try SD card 2************
      [05.089][mmc]: mmc 2 cmd timeout 100 status 100
      [05.093][mmc]: smc 2 err, cmd 8,  RTO
      [05.096][mmc]: mmc 2 close bus gating and reset
      [05.101][mmc]: mmc 2 cmd timeout 100 status 100
      [05.105][mmc]: smc 2 err, cmd 55,  RTO
      [05.109][mmc]: mmc 2 close bus gating and reset
      [05.113][mmc]: ************Try MMC card 2************
      [05.136][mmc]: mmc 2 cmd timeout 100 status 100
      [05.140][mmc]: smc 2 err, cmd 8,  RTO
      [05.144][mmc]: mmc 2 close bus gating and reset
      [05.149][mmc]: mmc 2 cmd timeout 100 status 100
      [05.153][mmc]: smc 2 err, cmd 55,  RTO
      [05.156][mmc]: mmc 2 close bus gating and reset
      [05.172][mmc]: gen_tuning_blk_bus8: total blk 10
      [05.176][mmc]: gen_tuning_blk_bus4: total blk 6
      [05.181][mmc]: Using 8 bit tuning now
      [05.185][mmc]: write_tuning_try_freq: write ok
      [05.189][mmc]: Pattern compare ok
      [05.192][mmc]: Write tuning pattern ok
      [05.195][mmc]: ================== HSSDR52_SDR25...
      [05.200][mmc]: skip freq 400000
      [05.203][mmc]: skip freq 25000000
      [05.206][mmc]: freq: 2-50000000-64-4
      [05.355][mmc]: [0-53|54] [61-63|3]
      [05.358][mmc]: ================== HSDDR52_DDR50...
      [05.362][mmc]: skip freq 400000
      [05.365][mmc]: freq: 1-25000000-64-4
      [05.507][mmc]: freq: 2-50000000-64-4
      [05.598][mmc]: [0-50|51] [62-63|2]
      [05.602][mmc]: [0-30|31] [32-50|19] [62-63|2]
      [05.606][mmc]: DS26/SDR12: 0xffffffff 0xffffffff
      [05.610][mmc]: HSSDR52/SDR25: 0xff1bffff 0xffffffff
      [05.615][mmc]: HSDDR52/DDR50: 0xff0f19ff 0xffffffff
      [05.619][mmc]: HS200/SDR104: 0xffffffff 0xffffffff
      [05.624][mmc]: HS400: 0xffffffff 0xffffffff
      [05.628][mmc]: HS400: 0xffffffff 0xffffffff
      [05.632][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 8
      [05.638]line:724 init_clocks
      [05.641]init_clocks:finish
      [05.644]Loading Environment from SUNXI_FLASH... OK
      [05.648]try to burn key
      [05.651]out of usb burn from boot: not need burn key
      sunxi work mode=0x10
      run usb efex
      delay time 2500
      weak:otg_phy_config
      usb init ok
      set address 0x9
      set address 0x9 ok
        YuzukiHD LV 2 最后由 编辑
        烧录进去了但是没能启动,检查下是不是引导到其他存储器了比如插了tf卡,另外检查下PC的配置是否配置了启动顺序
        W 1 条回复 最后回复 回复 引用 分享 0
          wl17761275256 LV 5 @YuzuKiHD 最后由 编辑
          @yuzukihd
          1、板子上面只有EMMC,没有TF卡和Flash其他的。
          2、PC的启动顺序,我确认下。但是我用开发板插上USB是可以烧录看到进度条的。
            whycan晕哥 LV 9 @wl17761275256 最后由 编辑
            @wl17761275256
            固件是OK的吗?
            W 3 条回复 最后回复 回复 引用 分享 0
              wl17761275256 LV 5 @whycan 最后由 编辑
              @whycan 在 V853 无法烧录问题@whycan晕哥 中说:
              @wl17761275256
              固件是OK的吗?
              固件在开发板上下载过
                @whycan
                目前用同样的固件可以烧到开发板上,在自己做的板子上面就是烧不进去。没有下一步了。目前的打印就是这样。
                  @whycan
                  晕哥,还有什么手段没有呀。坐等支持呀。
                    whycan晕哥 LV 9 @wl17761275256 最后由 whycan 编辑
                    @wl17761275256
                    对比一下开发板的日志。
                    然后把cpu/dram/sdc2的clk都降下来试一试。
                    • Referenced by  W wl17761275256
                    • I
                      igbt70 LV 4 最后由 whycan 编辑
                      正常开发板打印log
                      [54]BOOT0 commit : 4b419f21ba
                      [58]PMU: AXP21
                      [61]set pll start
                      [62]periph0 has been enabled
                      [65]set pll end
                      [67]board init ok
                      [69]DRAM use external ZQ!!
                      [71]chip id check OK
                      [74]DRAM_VCC set to 1500 mv
                      [76]DRAM BOOT DRIVE INFO: V0.16
                      [79]DRAM CLK = 936 MHz
                      [81]DRAM Type = 3 (2:DDR2,3:DDR3)
                      [84]DRAMC ZQ value: 0x7b7bfb
                      [87]DRAM ODT value: 0x42.
                      [91]DRAM SIZE =512 M
                      [93]dram_tpr4:0x0
                      [99]DRAM simple test OK.
                      [101]rtc standby flag is 0x0, super standby flag is 0x0
                      [106]dram size =512
                      [109]audio:avcc calibration
                      [112]card no is 2
                      [113]sdcard 2 line count 8
                      [116][mmc]: mmc driver ver 2021-12-27 10:07
                      [125][mmc]: Wrong media type 0x0, but host sdc2, try mmc first
                      [131][mmc]: ***Try MMC card 2***
                      [146][mmc]: RMCA OK!
                      [148][mmc]: bias 100
                      [150][mmc]: mmc 2 bias 100
                      [153][mmc]: MMC 5.1
                      [155][mmc]: HSSDR52/SDR25 8 bit
                      [158][mmc]: 50000000 Hz
                      [161][mmc]: 7400 MB
                      [162][mmc]: ***SD/MMC 2 init OK!!!***
                      [215]Loading boot-pkg Succeed(index=0).
                      [219]Entry_name        = optee
                      [222]Entry_name        = u-boot
                      [229]Entry_name        = dtb
                      [232]tunning data addr:0x430003e8
                      [235]Jump to second Boot.
                      [00.406]CPU:   Allwinner Family
                      [00.409]Model: sun8iw21
                      I2C:   ready
                      [00.435]DRAM:  512 MiB
                      [00.439]Relocation Offset is: 1ced0000
                      [00.463]secure enable bit: 0
                      [00.478]PMU: AXP21
                      [00.480]BMU: AXP21
                      [00.504]CPU=900 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=24Mhz  MBus=300Mhz
                      [00.510]gic: sec monitor mode
                      [00.515]flash init start
                      [00.517]workmode = 0,storage type = 2
                      [00.520][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
                      [00.526][mmc]: get sdc_type fail and use default host:tm4.
                      [00.533][mmc]: SUNXI SDMMC Controller Version:0x50400
                      [00.560][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 8
                      [00.567]sunxi flash init ok
                      [00.570]line:724 init_clocks
                      [00.573]drv_disp_init
                      request pwm success, pwm9:pwm9:0x2000c00.
                      [00.587]drv_disp_init finish
                      [00.591]Loading Environment from SUNXI_FLASH... OK
                      [00.602]boot_gui_init:start
                      [00.605]set disp.dev2_output_type fail. using defval=0
                      [00.610][ICN6202 TO LVDS] LINE:0146-->lcd_open_flow:
                      [00.615][ICN6202 TO LVDS] LINE:0146-->lcd_open_flow:
                      [00.620][ICN6202 TO LVDS] LINE:0167-->lcd_power_on:
                      [00.637]boot_gui_init:finish
                      54 bytes read in 0 ms
                      [00.646]bmp_name=bootlogo.bmp size 38454
                      [00.651][ICN6202 TO LVDS] LINE:0146-->lcd_open_flow:
                      [00.655][ICN6202 TO LVDS] LINE:0575-->lcd_panel_init:
                      [00.821][ICN6202 TO LVDS] LINE:0620-->lcd_panel_init:initialization:icn6202 init reg from mipi
                      38454 bytes read in 192 ms (195.3 KiB/s)
                      [00.862]Item0 (Map) magic is bad
                      [00.865]the secure storage item0 copy0 magic is bad
                      [00.882]Item0 (Map) magic is bad
                      [00.884]the secure storage item0 copy1 magic is bad
                      [00.889]Item0 (Map) magic is bad
                      [00.892]out of usb burn from boot: not need burn key
                      root_partition is rootfs
                      set root to /dev/mmcblk0p4
                      [00.901]update part info
                      [00.904]update bootcmd
                      [00.906]change working_fdt 0x5de8fe70 to 0x5de6fe70
                      [00.913][mmc]: delete mmc-hs400-1_8v from dtb
                      [00.917][mmc]: delete mmc-hs200-1_8v from dtb
                      [00.921][mmc]: get max-frequency ok 50000000 Hz
                      [00.934]The storage not support sample function
                      [00.941]## error: update_fdt_dram_para : FDT_ERR_NOTFOUND
                      [00.950][ICN6202 TO LVDS] LINE:0146-->lcd_open_flow:
                      [00.955]update dts
                      [00.959][ICN6202 TO LVDS] LINE:0146-->lcd_open_flow:
                      [00.964][ICN6202 TO LVDS] LINE:0203-->lcd_bl_open:
                      [00.971][ICN6202 TO LVDS] LINE:0146-->lcd_open_flow:
                      [00.975][ICN6202 TO LVDS] LINE:0146-->lcd_open_flow:
                      [00.980]LCD open finish
                      [02.052]no vendor_boot partition is found
                      Android's image name: v853-vision
                      [02.101]Starting kernel ...
                      [02.104][mmc]: mmc exit start
                      [02.122][mmc]: mmc 2 exit ok
                        whycan晕哥 LV 9 @igbt70 最后由 编辑
                        @igbt70
                        能启动boot0 和 uboot,不能启动linux,你觉得可能是什么问题呢?
                        I 1 条回复 最后回复 回复 引用 分享 0
                        • I
                          igbt70 LV 4 @whycan 最后由 编辑
                          @whycan 你看最前面的,这是正常的可以打印到这里,不正常的干脆都进入不了linux 这段
                            @igbt70
                            对啊,大概说明sdc2低速是可以的,所以检查eMMC电源波纹,电压电流,布线,干扰等,软件上面修改 board.dts给sdc2降低clk。
                            • I
                              @whycan
                              不正常的是这个LOG,没有这个啊board.dts ?
                              [2317]PMU: AXP21
                              [2320]set pll start
                              [2325]set pll end
                              [2327]board init ok
                              [2339]trefi:7.8ms
                              [2346]trefi:7.8ms
                              [2376]dram_tpr4:0x0
                              [2387]init dram ok
                              I2C:   ready
                              [04.959]PMU: AXP21
                              [04.964]BMU: AXP21
                              try card 2
                              set card number 2
                              get card number 2
                              run usb efex
                              delay time 2500
                              weak:otg_phy_config
                              usb init ok
                              set address 0x9
                              set address 0x9 ok
                              • I
                                igbt70 LV 4 最后由 编辑
                                @whycan
                                先给你看看这是正常的log ,后面是不正常的log ,我推测uboot 发指令进入到copy 镜像到ddr 失败了,很是奇怪
                                这是正常的log
                                [07.037][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 8
                                [07.044]line:724 init_clocks
                                [07.047]init_clocks:finish
                                [07.049]Loading Environment from SUNXI_FLASH... OK
                                [07.054]try to burn key
                                [07.056]out of usb burn from boot: not need burn key
                                run usb efex
                                delay time 2500
                                weak:otg_phy_config
                                usb init ok
                                set address 0x7f
                                set address 0x7f ok
                                set address 0x1
                                set address 0x1 ok
                                SUNXI_EFEX_ERASE_TAG
                                erase_flag = 0x12
                                origin_erase_flag = 0x1
                                FEX_CMD_fes_verify_status
                                FEX_CMD_fes_verify last err=0
                                the 0 mbr table is ok
                                the 1 mbr table is ok
                                the 2 mbr table is ok
                                the 3 mbr table is ok
                                total mbr part 7
                                part[0] classname :DISK
                                part[0] addrlo    :0x2000
                                part[0] lenlo     :0x1780
                                part[0] user_type :32768
                                part[0] keydata   :0
                                part[0] ro        :0
                                part[1] name      :env
                                part[1] classname :DISK
                                part[1] addrlo    :0x3780
                                part[1] lenlo     :0x3f0
                                part[1] user_type :32768
                                part[1] keydata   :0
                                part[1] ro        :0
                                part[2] name      :boot
                                part[2] classname :DISK
                                part[2] addrlo    :0x3b70
                                part[2] lenlo     :0x6270
                                part[2] user_type :32768
                                part[2] keydata   :0
                                part[2] ro        :0
                                part[3] name      :rootfs
                                part[3] classname :DISK
                                part[3] addrlo    :0x9de0
                                part[3] lenlo     :0xb130
                                part[3] user_type :32768
                                part[3] keydata   :0
                                part[3] ro        :0
                                part[4] name      :rootfs_data
                                part[4] classname :DISK
                                part[4] addrlo    :0x14f10
                                part[4] lenlo     :0x2760
                                part[4] user_type :32768
                                part[4] keydata   :0
                                part[4] ro        :0
                                不正常的log
                                U-Boot 2018.05-g3a34d5f-config-dirty (Mar 30 2023 - 04:23:39 -0400) Allwinner Technology
                                [05.464]CPU:   Allwinner Family
                                [05.466]Model: sun8iw21
                                I2C:   ready
                                [05.492]DRAM:  512 MiB
                                [05.496]Relocation Offset is: 1ceef000
                                [05.517]secure enable bit: 0
                                [05.520]PMU: AXP21
                                [05.522]PMU: pmu_axp2101 found
                                [05.525]BMU: AXP21
                                [05.526]BMU: bmu_axp2101 found
                                [05.537]gpio_bias, pc_bias: 1800, pc_supply: not set
                                [05.542]gpio_bias, pl_bias:   -1, pl_supply: not set
                                [05.547]dcdc1_vol = 3300, onoff=1
                                [05.551]dcdc2_vol = 900, onoff=1
                                [05.554]dcdc5_vol = 0, onoff=0
                                [05.557]aldo1_vol = 1800, onoff=1
                                [05.561]aldo2_vol = 1800, onoff=1
                                [05.564]aldo3_vol = 3300, onoff=1
                                [05.568]aldo4_vol = 3300, onoff=1
                                [05.571]bldo1_vol = 1800, onoff=1
                                [05.575]bldo2_vol = 2800, onoff=1
                                [05.578]dldo1_vol = 3300, onoff=1
                                [05.582]dldo2_vol = 1200, onoff=1
                                [05.592]bat_vol=35, ratio=0
                                [05.594]safe_vol=3500, safe_ratio=1
                                [05.598]CPU=900 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=24Mhz  MBus=300Mhz
                                [05.604]gic: normal mode
                                [05.608]flash init start
                                [05.610]workmode = 16,storage type = 0
                                try card 2
                                set card number 2
                                get card number 2
                                [05.618][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
                                [05.623][mmc]: get sdc_type fail and use default host:tm4.
                                [05.630][mmc]: Is not Boot mode!
                                [05.633][mmc]: SUNXI SDMMC Controller Version:0x50400
                                [05.644][mmc]: ************Try SD card 2************
                                [05.649][mmc]: mmc 2 cmd timeout 100 status 100
                                [05.653][mmc]: smc 2 err, cmd 8,  RTO
                                [05.657][mmc]: mmc 2 close bus gating and reset
                                [05.662][mmc]: mmc 2 cmd timeout 100 status 100
                                [05.666][mmc]: smc 2 err, cmd 55,  RTO
                                [05.669][mmc]: mmc 2 close bus gating and reset
                                [05.674][mmc]: ************Try MMC card 2************
                                [05.697][mmc]: mmc 2 cmd timeout 100 status 100
                                [05.701][mmc]: smc 2 err, cmd 8,  RTO
                                [05.704][mmc]: mmc 2 close bus gating and reset
                                [05.709][mmc]: mmc 2 cmd timeout 100 status 100
                                [05.714][mmc]: smc 2 err, cmd 55,  RTO
                                [05.717][mmc]: mmc 2 close bus gating and reset
                                [05.733][mmc]: gen_tuning_blk_bus8: total blk 10
                                [05.737][mmc]: gen_tuning_blk_bus4: total blk 6
                                [05.741][mmc]: Using 8 bit tuning now
                                [05.745][mmc]: write_tuning_try_freq: write ok
                                [05.750][mmc]: Pattern compare ok
                                [05.753][mmc]: Write tuning pattern ok
                                [05.756][mmc]: ================== HSSDR52_SDR25...
                                [05.761][mmc]: skip freq 400000
                                [05.763][mmc]: skip freq 25000000
                                [05.766][mmc]: freq: 2-50000000-64-4
                                [05.915][mmc]: [0-53|54] [61-63|3]
                                [05.918][mmc]: ================== HSDDR52_DDR50...
                                [05.923][mmc]: skip freq 400000
                                [05.926][mmc]: freq: 1-25000000-64-4
                                [06.067][mmc]: freq: 2-50000000-64-4
                                [06.158][mmc]: [0-50|51] [62-63|2]
                                [06.161][mmc]: [0-30|31] [32-50|19] [62-63|2]
                                [06.165][mmc]: DS26/SDR12: 0xffffffff 0xffffffff
                                [06.169][mmc]: HSSDR52/SDR25: 0xff1bffff 0xffffffff
                                [06.174][mmc]: HSDDR52/DDR50: 0xff0f19ff 0xffffffff
                                [06.178][mmc]: HS200/SDR104: 0xffffffff 0xffffffff
                                [06.183][mmc]: HS400: 0xffffffff 0xffffffff
                                [06.187][mmc]: HS400: 0xffffffff 0xffffffff
                                [06.191][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 8
                                [06.197]line:724 init_clocks
                                [06.201]init_clocks:finish
                                [06.203]Loading Environment from SUNXI_FLASH... OK
                                [06.207]try to burn key
                                [06.210]out of usb burn from boot: not need burn key
                                run usb efex
                                delay time 2500
                                weak:otg_phy_config
                                usb init ok
                                set address 0x70
                                set address 0x70 ok
                                set address 0x71
                                set address 0x71 ok
                                set address 0x72
                                set address 0x72 ok
                                  @igbt70
                                  这是烧录的log,还是启动的log呢?
                                  • I
                                    @whycan
                                    烧录的log
                                      lee2333 LV 3 最后由 编辑
                                      楼主的问题解决了吗,我也是有这样的问题
