    R128 SDK 0.7 /bin/bash: line 4: @set: command not found
    A Series
      柚木 鉉 LV 9 最后由 YuzukiTsuru 编辑
      cd /home/yuzuki/WorkSpace/R128-FreeRTOS/lichee/rtos/ && TERM=xterm-color CONFIG_=CONFIG_ PROJECT_DIR=/home/yuzuki/WorkSpace/R128-FreeRTOS/lichee/rtos kconfig-mconf Kconfig
      components/aw/camera_preview/Kconfig:1:warning: leading whitespace ignored
      drivers/drv/bluetooth/driver/controller/Kconfig:7:warning: defaults for choice values not supported
      *** End of the configuration.
      *** Execute 'make' to start the build or try 'make help'.
      make mkconfig
      if [ ! -f /home/yuzuki/WorkSpace/R128-FreeRTOS/lichee/rtos/.dbuild/..//include/generated/r128s2_pro_c906/autoconf.h ]; then \
              @set -e; set -o pipefail; mkdir -p /home/yuzuki/WorkSpace/R128-FreeRTOS/lichee/rtos/.dbuild/..//include/generated/r128s2_pro_c906; \
              @set -e; set -o pipefail; /home/yuzuki/WorkSpace/R128-FreeRTOS/lichee/rtos/.dbuild/../.dbuild/scripts/mkconfig/mkconfig /home/yuzuki/WorkSpace/R128-FreeRTOS/lichee/rtos/ > /home/yuzuki/WorkSpace/R128-FreeRTOS/lichee/rtos/.dbuild/..//include/generated/r128s2_pro_c906/autoconf.h; \
      else \
              @set -e; set -o pipefail; /home/yuzuki/WorkSpace/R128-FreeRTOS/lichee/rtos/.dbuild/../.dbuild/scripts/mkconfig/mkconfig /home/yuzuki/WorkSpace/R128-FreeRTOS/lichee/rtos/ > /home/yuzuki/WorkSpace/R128-FreeRTOS/lichee/rtos/.dbuild/..//include/generated/r128s2_pro_c906/autoconf.h.tmp; \
              diff /home/yuzuki/WorkSpace/R128-FreeRTOS/lichee/rtos/.dbuild/..//include/generated/r128s2_pro_c906/autoconf.h /home/yuzuki/WorkSpace/R128-FreeRTOS/lichee/rtos/.dbuild/..//include/generated/r128s2_pro_c906/autoconf.h.tmp  &>/dev/null; \
              if [ $? -ne 0 ]; then \
                      cp /home/yuzuki/WorkSpace/R128-FreeRTOS/lichee/rtos/.dbuild/..//include/generated/r128s2_pro_c906/autoconf.h.tmp /home/yuzuki/WorkSpace/R128-FreeRTOS/lichee/rtos/.dbuild/..//include/generated/r128s2_pro_c906/autoconf.h; \
                      rm /home/yuzuki/WorkSpace/R128-FreeRTOS/lichee/rtos/.dbuild/..//include/generated/r128s2_pro_c906/autoconf.h.tmp; \
              fi; \
      fi \
      else \
              fi; \
      fi \
      修改:lichee/rtos/.dbuild/dbuild.mk,把 $(DBUILD_ROOT).dbuild/scripts/mkconfig/mkconfig$(OS_EXT) 前的 $(Q) 去了
      .PHONY: mkconfig
      mkconfig: $(DBUILD_ROOT).dbuild/scripts/mkconfig/mkconfig$(OS_EXT)
      ifeq ($(DBUILD_OS), WIN32)
      	if [ ! -f $(CONFIG_HEADER_PATH)/$(CONFIG_HEADER_NAME) ]; then \
      		$(Q)mkdir -p $(CONFIG_HEADER_PATH); \
      		$(Q)$(DBUILD_ROOT).dbuild/scripts/mkconfig/mkconfig$(OS_EXT) $(subst \,\\,$(shell cygpath -w $(PROJECT_DIR)/)) > $(CONFIG_HEADER_PATH)/$(CONFIG_HEADER_NAME); \
      	else \
      		$(DBUILD_ROOT).dbuild/scripts/mkconfig/mkconfig$(OS_EXT) $(subst \,\\,$(shell cygpath -w $(PROJECT_DIR)/)) > $(CONFIG_HEADER_PATH)/$(CONFIG_HEADER_NAME).tmp; \
      		diff $(CONFIG_HEADER_PATH)/$(CONFIG_HEADER_NAME) $(CONFIG_HEADER_PATH)/$(CONFIG_HEADER_NAME).tmp  &>/dev/null; \
      		if [ $$? -ne 0 ]; then \
      			cp $(CONFIG_HEADER_PATH)/$(CONFIG_HEADER_NAME).tmp $(CONFIG_HEADER_PATH)/$(CONFIG_HEADER_NAME); \
      			rm $(CONFIG_HEADER_PATH)/$(CONFIG_HEADER_NAME).tmp; \
      		fi; \
      	fi \
      		$(Q)$(DBUILD_ROOT).dbuild/scripts/mkconfig/mkconfig$(OS_EXT) $(PROJECT_DIR)/ > $(CONFIG_HEADER_PATH)/$(CONFIG_HEADER_NAME); \
      	else \
      		$(DBUILD_ROOT).dbuild/scripts/mkconfig/mkconfig$(OS_EXT) $(PROJECT_DIR)/ > $(CONFIG_HEADER_PATH)/$(CONFIG_HEADER_NAME).tmp; \
      		fi; \
      	fi \
      endif
        sw123456 LV 3 最后由 编辑
        去掉了可以吗,win下编译怎么弄。
          WhycanService LV 8 @sw123456 最后由 编辑
          @sw123456 win下用cygwin也一样的
