    Yuzukilizard V851S autostart settings
    3963
      sergpenshin LV 4 最后由 编辑
      Hi.
      would tell me please (show an example) how to configure the system so that the required executable file is launched at system startup.
      whycan 1 条回复 最后回复 回复 引用 分享 1
        whycan晕哥 LV 9 @sergpenshin 最后由 编辑
        @sergpenshin
        add some command at the end of target/allwinner/{target-board}/busybox-init-base-files/etc/init.d/rc.final
        在此文件的最后添加需要开机执行的命令: target/allwinner/{target-board}/busybox-init-base-files/etc/init.d/rc.final
        S 1 条回复 最后回复 回复 引用 分享 1
          sergpenshin LV 4 @whycan 最后由 编辑
          @whycan
          Thank you. Yes indeed, in this way it works.
          But can it be done as Init Scripts?
          I tried to create a script in init.d
          #!/bin/sh /etc/rc.common
          # Example script
          # Copyright (C) 2007 OpenWrt.org
          START=41
          STOP=15
          start()
          echo start
          my_example
          stop()
          echo stop
          killall my_example
          Further
          /etc/init.d/my_example enable
          Then I made a reboot - but my_example did not start.
          At the same time, the script itself is working, if execute
          /etc/init.d/my_example start
          everything works. Apparently I did something wrong. Please help me find the error!
          V 1 条回复 最后回复 回复 引用 分享 1
          • V
            vejoker LV 5 @sergpenshin 最后由 编辑
            @sergpenshin
            Rename my_example to S99my_example, then run /etc/init.d/S99my_example enable, and try rebooting
            重命名 my_example 为 S99my_example
            然后 reboot 重启试试
