    Allwinner Mass production start card making tutorial
    6
    11
    10717
    • BedRock
      BedRock LV 6 最后由 BedRock 编辑
      Regarding the Allwinner startup card, there are two ways to make it.
      Allwinner provides a variety of tools and methods for user firmware burning.This article introduces the production method of mass production startup card.
      1.Use Allwinner PhoenixCard Tool
      Tool download link:https://www.aw-ol.com/downloads?cat=5
      We find "PhoenixCardv4.2.7.7z" and click to download, and get a "PhoenixCardv4.2.7.7z.7z" file,and use an unzip tool to unzip it.We open the application PhoenixCard.exe.
      67c4cacc-9c07-4a5d-8999-ffb88da57d44-1630028958446_E219DA31-A44D-4894-9200-7E0D46CC0CB0.png
      The application interface is as follows:
      9d8c0d2b-cff8-434d-9919-98661007a520-lALPD3IrvxdmX2vNAs3NA5I_914_717.png 43053fd5-c6e0-4b13-a938-9e2f33e93000-image.png
      If you insert an SD card into your computer, the software interface is as follows.
      Now,you can choose the firmware that needs mass production.Follow the steps on the way to select and download.
      After clicking download, just wait for the end of the burning process.The following message will be output in the message bar:
      • cube_work
        cube_work LV 5 最后由 编辑
        six six six
        • BedRock
          BedRock LV 6 最后由 编辑
          2. Use the dd command in Linux
          The dd command is a standard command for linux to burn images.
          Insert the SD card in your computer, check the SD card mount directory, and cancel the mount.
          df -h
          Filesystem                 Size  Used Avail Use% Mounted on
          udev                        32G  4.0K   32G   1% /dev
          tmpfs                      6.3G   35M  6.3G   1% /run
          /dev/sda1                   83G   20G   59G  26% /
          /dev/sdc                  30.2G  4.0K 30.2G   0% /media/SDCARD
          umount /dev/sdc
          Find the img that needs to be downloaded.
          sudo dd if=tina_d1-nezha_card0.img of=/dev/sdc bs=4M
          U 1 条回复 最后回复 回复 引用 分享 0
            a1147991965 LV 4 最后由 编辑
            bedrock
            Forever Di God
            • U
              uuuuid LV 6 最后由 whycan 编辑
              yong zhege mingling kongpa buxing ba ?
              英译汉 =>
              用 这个 命令 恐怕 不行 吧?
              BedRock 1 条回复 最后回复 回复 引用 分享 0
              • BedRock
                BedRock LV 6 @uuuuid 最后由 编辑
                @uuuuid 🤒 🤒 why?
                tigger 1 条回复 最后回复 回复 引用 分享 0
                • tigger
                  tigger LV 7 @BedRock 最后由 whycan 编辑
                  @bedrock 确实不行,只能用 PhoenixCard.exe 烧。
                  • BedRock
                    BedRock LV 6 @tigger 最后由 编辑
                    @tigger 用cardimg 也不行吗?需要打包成cardimg
                      DOT小文哥 LV 8 最后由 编辑
                      hi~Everybody, there is english discussion zone, please use english.
                      • U
                        uuuuid LV 6 @BedRock 最后由 编辑
                        @bedrock
                        how to build tina_d1-nezha_card0.img ?
                        • BedRock
                          @uuuuid
                          Specify the parameters for the pack -d
                          pack -d card0
                          Unfortunately, the card packaging tool is still not perfect.
                          • Moved from RISC-V(English) by  xiaowenge xiaowenge
