    T113-S3 Tina 5.0 系统 一直卡在 uboot LOGO 界面
    3568
      Swain LV 4 最后由 Swain 编辑
      [81]HELLO! BOOT0 is starting!
      [83]BOOT0 commit : 84b1541181
      [86]set pll start
      [88]fix vccio detect value:0xc0
      [95]periph0 has been enabled
      [98]set pll end
      [99][pmu]: bus read error
      [102]board init ok
      [104]enable_jtag
      [105]ZQ value = 0x30
      [107]get_pmu_exist() = -1
      [110]DRAM BOOT DRIVE INFO: V0.33
      [113]DRAM CLK = 792 MHz
      [115]DRAM Type = 3 (2:DDR2,3:DDR3)
      [118]DRAMC read ODT  off.
      [120]DRAM ODT value: 0x42.
      [123]ddr_efuse_type: 0xa
      [126]DRAM SIZE =128 M
      [128]dram_tpr4:0x0
      [130]PLL_DDR_CTRL_REG:0xf8004100
      [133]DRAM_CLK_REG:0xc0000000
      [136][TIMING DEBUG] MR2= 0x18
      [144]DRAM simple test OK.
      [146]rtc standby flag is 0x0, super standby flag is 0x0
      [151]dram size =128
      [154]card no is 2
      [155]sdcard 2 line count 4
      [158][mmc]: mmc driver ver 2021-05-21 14:47
      [167][mmc]: Wrong media type 0x0, but host sdc2, try mmc first
      [173][mmc]: ***Try MMC card 2***
      [197][mmc]: RMCA OK!
      [199][mmc]: mmc 2 bias 0
      [202][mmc]: MMC 5.1
      [204][mmc]: HSSDR52/SDR25 4 bit
      [207][mmc]: 50000000 Hz
      [209][mmc]: 3728 MB
      [211][mmc]: ***SD/MMC 2 init OK!!!***
      [302]Loading boot-pkg Succeed(index=0).
      [305]Entry_name        = u-boot
      [312]Entry_name        = optee
      [316]Entry_name        = dtb
      [319]tunning data addr:0x430003e8
      [322]Jump to second Boot.
      M/TC: OP-TEE version: 8b49ce62-dirty (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Fri Aug 12 08:24:15 UTC 2022 arm
      U-Boot 2018.07-g895f570-dirty (May 11 2023 - 11:34:42 +0800) Allwinner Technology
      [00.374]CPU:   Allwinner Family
      [00.377]Model: sun8iw20
      [00.379]DRAM:  128 MiB
      [00.383]Relocation Offset is: 04ec9000
      [00.409]secure enable bit: 0
      [00.422]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [00.428]gic: sec monitor mode
      sunxi flash map init
      [00.434]flash init start
      [00.436]workmode = 0,storage type = 2
      [00.439][mmc]: mmc driver ver uboot2018:2022-12-07 18:56:00
      [00.446][mmc]: SUNXI SDMMC Controller Version:0x50310
      [00.471][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 4
      [00.477]sunxi flash init ok
      [00.480]line:703 init_clocks
      [00.483]drv_disp_init
      [00.488]handle_num : 6
      [00.494]drv_disp_init finish
      [00.499]Loading Environment from SUNXI_FLASH... OK
      [00.513]boot_gui_init:start
      [00.515]set disp.dev2_output_type fail. using defval=0
      [00.592]set disp.fb0_rot_used fail. using defval=0
      [00.596]set disp.fb0_rot_degree fail. using defval=0
      [00.614]boot_gui_init:finish
      [00.621]bmp_name=bootlogo.bmp size 38454
      [00.634]Item0 (Map) magic is bad
      [00.637]the secure storage item0 copy0 magic is bad
      [00.645]Item0 (Map) magic is bad
      [00.648]the secure storage item0 copy1 magic is bad
      [00.653]Item0 (Map) magic is bad
      [00.656]usb burn from boot
      delay time 0
      weak:otg_phy_config
      [00.667]usb prepare ok
      [00.672]LCD open finish
      [00.970]overtime
      [00.973]do_burn_from_boot usb : no usb exist
      List file under ULI/factory
      root_partition is rootfs
      set root to /dev/mmcblk0p5
      [00.988]update part info
      [00.990]update bootcmd
      [00.994]change working_fdt 0x44888e70 to 0x44868e70
      [00.999][mmc]: no mmc-hs400-1_8v!
      [01.002][mmc]: delete mmc-hs200-1_8v from dtb
      [01.006][mmc]: get max-frequency ok 50000000 Hz
      [01.031]update dts
      [01.240]no vendor_boot partition is found
      ERROR: reserving fdt memory region failed (addr=41900000 size=200000)
      ERROR: reserving fdt memory region failed (addr=41c00000 size=400000)
      ERROR: reserving fdt memory region failed (addr=41b00000 size=100000)
      ERROR: reserving fdt memory region failed (addr=44913000 size=7e9000)
      [01.278]Starting kernel ...
      [01.281][mmc]: mmc exit start
      [01.300][mmc]: mmc 2 exit ok
      [    0.000000] Linux version 5.4.61 (yuanzf@yuanzf-PC) (arm-linux-gnueabi-gcc (Linaro GCC 5.3-2016.05) 5.3.1 20160412, GNU ld (Linaro_Binutils-2016.05) 2.25.0 Linaro 2016_02) #1 SMP PREEMPT Thu May 11 09:57:03 CST 2023
      [    0.000000] percpu: Embedded 15 pages/cpu s30912 r8192 d22336 u61440
      [    0.000000] pcpu-alloc: s30912 r8192 d22336 u61440 alloc=15*4096
      [    0.000000] Kernel command line: earlyprintk= clk_ignore_unused initcall_debug=0 console=ttyS3,115200 loglevel=8 root=/dev/mmcblk0p5 init=/init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:private@mmcblk0p6:UDISK@mmcblk0p7 cma=4M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.hardware=sun8iw20p1 boot_type=2 androidboot.boot_type=2 gpt=1 uboot_message=2018.07-g895f570-dirty(05/11/2023-11:34:42) disp_reserve=8294400,0x44913000 androidboot.dramsize=128
      [    0.000000] Memory: 98288K/131072K available (7168K kernel code, 418K rwdata, 2508K rodata, 1024K init, 171K bss, 28688K reserved, 4096K cma-reserved)
      [    0.000000] random: get_random_bytes called from start_kernel+0x24c/0x3cc with crng_init=0
      [    0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
      [    0.008026] Switching to timer-based delay loop, resolution 41ns
      [    0.014211] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
      [    0.023958] Console: colour dummy device 80x30
      [    0.028429] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      [    0.038792] pid_max: default: 32768 minimum: 301
      [    0.043565] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.050886] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.059247] CPU: Testing write buffer coherency: ok
      [    0.064517] /cpus/cpu@0 missing clock-frequency property
      [    0.069853] /cpus/cpu@1 missing clock-frequency property
      [    0.075225] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      [    0.081498] Setting up static identity map for 0x40100000 - 0x40100060
      [    0.088184] rcu: Hierarchical SRCU implementation.
      [    0.093309] BOOTEVENT:        93.299874: ON
      [    0.097708] smp: Bringing up secondary CPUs ...
      [    0.103542] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      [    0.103694] smp: Brought up 1 node, 2 CPUs
      [    0.113513] SMP: Total of 2 processors activated (96.00 BogoMIPS).
      [    0.119693] CPU: All CPU(s) started in SVC mode.
      [    0.124852] devtmpfs: initialized
      [    0.141845] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
      [    0.150070] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.159972] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
      [    0.167110] pinctrl core: initialized pinctrl subsystem
      [    0.173765] NET: Registered protocol family 16
      [    0.180067] DMA: preallocated 256 KiB pool for atomic coherent allocations
      [    0.223577] rtc_ccu: sunxi ccu init OK
      [    0.230028] ccu: sunxi ccu init OK
      [    0.234076] r_ccu: sunxi ccu init OK
      [    0.281610] sun6i-dma 3002000.dma-controller: sunxi dma probed
      [    0.290211] iommu: Default domain type: Translated
      [    0.295357] sunxi iommu: irq = 24
      [    0.299923] SCSI subsystem initialized
      [    0.304093] usbcore: registered new interface driver usbfs
      [    0.309719] usbcore: registered new interface driver hub
      [    0.315172] usbcore: registered new device driver usb
      [    0.320506] mc: Linux media interface: v0.10
      [    0.324884] videodev: Linux video capture interface: v2.00
      [    0.331504] Advanced Linux Sound Architecture Driver Initialized.
      [    0.338336] Bluetooth: Core ver 2.22
      [    0.342055] NET: Registered protocol family 31
      [    0.346531] Bluetooth: HCI device and connection manager initialized
      [    0.353019] Bluetooth: HCI socket layer initialized
      [    0.357905] Bluetooth: L2CAP socket layer initialized
      [    0.363001] Bluetooth: SCO socket layer initialized
      [    0.368166] pwm module init!
      [    0.372629] g2d 5410000.g2d: Adding to iommu group 0
      [    0.378098] G2D: rcq version initialized.major:250
      [    0.383628] input: sunxi-keyboard as /devices/virtual/input/input0
      [    0.391303] clocksource: Switched to clocksource arch_sys_counter
      [    0.406728] sun8iw20-pinctrl pio: initialized sunXi PIO driver
      [    0.426796] thermal_sys: Registered thermal governor 'step_wise'
      [    0.426804] thermal_sys: Registered thermal governor 'user_space'
      [    0.433437] NET: Registered protocol family 2
      [    0.444702] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
      [    0.453133] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.460796] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
      [    0.467930] TCP: Hash tables configured (established 1024 bind 1024)
      [    0.474443] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    0.480989] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    0.488198] NET: Registered protocol family 1
      [    0.495130] Initialise system trusted keyrings
      [    0.499762] workingset: timestamp_bits=30 max_order=15 bucket_order=0
      [    0.517060] squashfs: version 4.0 (2009/01/31) Phillip Lougher
      [    0.523244] ntfs: driver 2.1.32 [Flags: R/W].
      [    0.527930] fuse: init (API version 7.31)
      [    0.562883] NET: Registered protocol family 38
      [    0.567338] Key type asymmetric registered
      [    0.571510] Asymmetric key parser 'x509' registered
      [    0.576505] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
      [    0.583920] io scheduler mq-deadline registered
      [    0.588463] io scheduler kyber registered
      [    0.592570] atomic64_test: passed
      [    0.597422] [DISP]disp_module_init
      [    0.601474] disp 5000000.disp: Adding to iommu group 0
      [    0.607277] [DISP] disp_init,line:2331:
      [    0.607282] smooth display screen:0 type:1 mode:4
      [    0.632367] display_fb_request,fb_id:0
      [    0.657339] disp_al_manager_apply ouput_type:1
      [    0.662002] [DISP]disp_module_init finish
      [    0.662057] [DISP] lcd_clk_config,line:777:
      [    0.662070] disp 0, clk: pll(888000000),clk(888000000),dclk(148000000) dsi_rate(148000000)
      [    0.662070]      clk real:pll(888000000),clk(888000000),dclk(222000000) dsi_rate(150000000)
      [    0.667652] sunxi_sid_init()783 - insmod ok
      [    0.692020] pwm-regulator: supplied by regulator-dummy
      [    0.698759] sun8iw20-pinctrl pio: pio supply vcc-pg not found, using dummy regulator
      [    0.707191] uart uart3: uart3 supply uart not found, using dummy regulator
      [    0.714485] uart3: ttyS3 at MMIO 0x2500c00 (irq = 34, base_baud = 1500000) is a SUNXI
      [    0.722452] sw_console_setup()1831 - console setup baud 115200 parity n bits 8, flow n
        0.730426] printk: console [ttyS3] enabled
      [    0.730426] printk: console [ttyS3] enabled
      [    0.739357] printk: bootconsole [earlycon0] disabled
      [    0.751023] misc dump reg init
      [    0.755059] deinterlace 5400000.deinterlace: Adding to iommu group 0
      [    0.762727] deinterlace 5400000.deinterlace: version[1.0.0], ip=0x110
      [    0.772413] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
      [    0.776249] Freeing logo buffer memory: 8100K
      [    0.779656] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
      [    0.791942] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
      [    0.799338] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
      [    0.805893] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
      [    0.812839] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
      [    0.820544] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=111 assert=1
      [    0.828493] sun8iw20-pinctrl pio: pio supply vcc-pd not found, using dummy regulator
      [    0.837390] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
      [    0.845501] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
      [    0.853179] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
      [    0.859929] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
      [    0.867461] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=110 assert=0
      [    0.876876] libphy: Fixed MDIO Bus: probed
      [    0.881481] CAN device driver interface
      [    0.886352] usbcore: registered new interface driver asix
      [    0.892566] usbcore: registered new interface driver ax88179_178a
      [    0.899429] usbcore: registered new interface driver cdc_ether
      [    0.906059] usbcore: registered new interface driver net1080
      [    0.912489] usbcore: registered new interface driver cdc_subset
      [    0.919155] usbcore: registered new interface driver zaurus
      [    0.925523] usbcore: registered new interface driver cdc_ncm
      [    0.931874] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [    0.939173] sunxi-ehci: EHCI SUNXI driver
      [    0.944070] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [    0.950991] sunxi-ohci: OHCI SUNXI driver
      [    0.956142] usbcore: registered new interface driver uas
      [    0.962203] usbcore: registered new interface driver usb-storage
      [    0.968964] usbcore: registered new interface driver ums-alauda
      [    0.975680] usbcore: registered new interface driver ums-cypress
      [    0.982475] usbcore: registered new interface driver ums-datafab
      [    0.989272] usbcore: registered new interface driver ums_eneub6250
      [    0.996248] usbcore: registered new interface driver ums-freecom
      [    1.003031] usbcore: registered new interface driver ums-isd200
      [    1.009713] usbcore: registered new interface driver ums-jumpshot
      [    1.016583] usbcore: registered new interface driver ums-karma
      [    1.023182] usbcore: registered new interface driver ums-onetouch
      [    1.030053] usbcore: registered new interface driver ums-realtek
      [    1.036830] usbcore: registered new interface driver ums-sddr09
      [    1.043525] usbcore: registered new interface driver ums-sddr55
      [    1.050202] usbcore: registered new interface driver ums-usbat
      [    1.056911] usbcore: registered new interface driver option
      [    1.063207] usbserial: USB Serial support registered for GSM modem (1-port)
      [    1.071986] sunxi_gpadc_init,2151, success
      [    1.076871] sunxi_gpadc_setup: get channel scan data failed
      [    1.083408] input: sunxi-gpadc0 as /devices/virtual/input/input1
      [    1.091173] sunxi-rtc 7090000.rtc: errata__fix_alarm_day_reg_default_value(): ALARM0_DAY_REG=0, set it to 1
      [    1.102477] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      [    1.113272] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      [    1.124525] sunxi-rtc 7090000.rtc: registered as rtc0
      [    1.130213] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      [    1.140852] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:00:02 UTC (2)
      [    1.149744] sunxi-rtc 7090000.rtc: sunxi rtc probed
      [    1.155713] i2c /dev entries driver
      [    1.159834] IR NEC protocol handler initialized
      [    1.164968] IR RC5(x/sz) protocol handler initialized
      [    1.171009] sun8iw20-pinctrl pio: pio supply vcc-pb not found, using dummy regulator
      [    1.180007] sunxi-rc-recv 7040000.s_cir: sunxi_irrx_resource_get: get ir protocol failed
      [    1.189199] Registered IR keymap rc_map_sunxi
      [    1.194251] rc rc0: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0
      [    1.202945] input: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0/s_cir_rx
      [    1.215169] usbcore: registered new interface driver uvcvideo
      [    1.221645] USB Video Class driver (1.1.1)
      [    1.226245] gspca_main: v2.14.0 registered
      [    1.230815] sunxi cedar version 1.1
      [    1.234948] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
      [    1.241246] VE: sunxi_cedar_probe power-domain init!!!
      [    1.247006] VE: install start!!!
      [    1.247006]
      [    1.252574] VE: cedar-ve the get irq is 40
      [    1.252574]
      [    1.259072] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval)
      [    1.259072]
      [    1.268330] VE: install end!!!
      [    1.268330]
      [    1.273419] VE: sunxi_cedar_probe
      [    1.278497] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
      [    1.287659] Bluetooth: HCI UART driver ver 2.3
      [    1.292681] Bluetooth: HCI UART protocol H4 registered
      [    1.300522] sun8iw20-pinctrl pio: pio supply vcc-pc not found, using dummy regulator
      [    1.309487] sunxi-mmc 4022000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40)
      [    1.319358] sunxi-mmc 4022000.sdmmc: ***ctl-spec-caps*** 308
      [    1.325769] sunxi-mmc 4022000.sdmmc: No vmmc regulator found
      [    1.332108] sunxi-mmc 4022000.sdmmc: No vqmmc regulator found
      [    1.338523] sunxi-mmc 4022000.sdmmc: No vdmmc regulator found
      [    1.344958] sunxi-mmc 4022000.sdmmc: No vd33sw regulator found
      [    1.351478] sunxi-mmc 4022000.sdmmc: No vd18sw regulator found
      [    1.357996] sunxi-mmc 4022000.sdmmc: No vq33sw regulator found
      [    1.364523] sunxi-mmc 4022000.sdmmc: No vq18sw regulator found
      [    1.371060] sunxi-mmc 4022000.sdmmc: Cann't get pin bias hs pinstate,check if needed
      [    1.380662] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.404456] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.428650] sunxi-mmc 4022000.sdmmc: detmode:alway in(non removable)
      [    1.435812] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.448714] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40)
      [    1.458612] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
      [    1.459649] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.464826] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
      [    1.477735] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.482745] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
      [    1.500735] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
      [    1.507175] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
      [    1.513721] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
      [    1.520236] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
      [    1.526774] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.526851] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.538379] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
      [    1.556961] sunxi-mmc 4020000.sdmmc: Got CD GPIO
      [    1.562182] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.571730] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.584959] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
      [    1.598597] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.605112] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.633431] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
      [    1.634226] random: fast init done
      [    1.643192] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
      [    1.647033] sunxi-mmc 4020000.sdmmc: detmode:gpio polling
      [    1.656683] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
      [    1.663297] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40)
      [    1.672752] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
      [    1.682175] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    1.692136] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
      [    1.709107] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
      [    1.709200] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
      [    1.727046] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
      [    1.738827] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
      [    1.738836] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing MMC-HS(SDR20) dt B
      [    1.757122] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing MMC-DDR52 dt B
      [    1.761321] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
      [    1.774935] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
      [    1.781489] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
      [    1.788013] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
      [    1.794571] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
      [    1.794581] mmc0: new DDR MMC card at address 0001
      [    1.801129] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
      [    1.807810] mmcblk0: mmc0:0001 4FTE4R 3.64 GiB
      [    1.820715] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.831920] mmcblk0rpmb: mmc0:0001 4FTE4R partition 3 512 KiB, chardev (243:0)
      [    1.832147] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [    1.848942]  mmcblk0: p1 p2 p3 p4 p5 p6 p7
      [    1.860322] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.884640] sunxi-mmc 4021000.sdmmc: detmode:manually by software
      [    1.892345] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 52, RTO !!
      [    1.899467] usbcore: registered new interface driver usbhid
      [    1.905724] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 52, RTO !!
      [    1.912644] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.921332] usbhid: USB HID core driver
      [    1.927355] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.928477] exFAT: Version 1.3.0
      [    1.942133] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
      [    1.944180] sunxi-msgbox 3003000.msgbox: sunxi msgbox driver probe ...
      [    1.951316] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
      [    1.958010] sunxi-msgbox 3003000.msgbox: sunxi msgbox driver init ok...
      [    1.965293] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
      [    1.972025] rpmsg_tty_init: Sunxi rpmsg tty driver will init
      [    1.979528] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
      [    1.984869] rpmsg_tty_init: Sunxi rpmsg tty driver init ok
      [    1.991624] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    2.000726] [AUDIOCODEC][sunxi_codec_parse_params][2437]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
      [    2.000726]
      [    2.025854] [AUDIOCODEC][sunxi_codec_parse_params][2473]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
      [    2.026383] [AUDIOCODEC][sunxi_internal_codec_probe][2634]:codec probe finished
      [    2.046140] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
      [    2.055932] [SNDCODEC][sunxi_card_init][583]:card init finished
      [    2.063140] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
      [    2.074245] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input3
      [    2.086364] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
      [    2.095233] NET: Registered protocol family 10
      [    2.101205] Segment Routing with IPv6
      [    2.105361] [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
      [    2.111422] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
      [    2.121208] NET: Registered protocol family 17
      [    2.126494] NET: Registered protocol family 15
      [    2.131568] can: controller area network core (rev 20170425 abi 9)
      [    2.138569] NET: Registered protocol family 29
      [    2.143571] can: raw protocol (rev 20170425)
      [    2.148342] can: broadcast manager protocol (rev 20170425 t)
      [    2.154683] can: netlink gateway (rev 20190810) max_hops=1
      [    2.161358] Bluetooth: RFCOMM TTY layer initialized
      [    2.166826] Bluetooth: RFCOMM socket layer initialized
      [    2.172647] Bluetooth: RFCOMM ver 1.11
      [    2.177601] Registering SWP/SWPB emulation handler
      [    2.183413] Loading compiled-in X.509 certificates
      [    2.207233] sunxi-i2c 2502c00.twi: 2502c00.twi supply twi not found, using dummy regulator
      [    2.217349] sunxi-i2c 2502c00.twi: probe success
      [    2.223916] sunxi-thermal 2009400.ths: sun8iw20 cp version:15
      [    2.234217] platform 2000c13.pwm3: pinctrl_get failed
      [    2.239921] platform 2000c13.pwm3: pinctrl_get failed
      [    2.245639] cpu cpu0: _set_opp_voltage: failed to set voltage (950000 950000 950000 mV): -19
      [    2.255125] platform 2000c13.pwm3: pinctrl_get failed
      [    2.260811] platform 2000c13.pwm3: pinctrl_get failed
      [    2.266476] cpu cpu0: _set_opp_voltage: failed to set voltage (950000 950000 950000 mV): -19
      [    2.275929] cpufreq: __target_index: Failed to change cpu frequency: -19
      [    2.285027] get drvvbus-en is fail, 22
      [    2.289228] get ehci0-controller wakeup-source is fail.
      [    2.295243] sunxi ehci0-controller don't init wakeup source
      [    2.301506] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0c894b8, 0x:c88cd000, irq_no:36
      [    2.313475] [sunxi-ehci0]: Not init ehci0
      [    2.318436] get drvvbus-en is fail, 22
      [    2.322655] get ohci0-controller wakeup-source is fail.
      [    2.328624] sunxi ohci0-controller don't init wakeup source
      [    2.334889] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0c89768
      [    2.344525] [sunxi-ohci0]: Not init ohci0
      [    2.349463] get drvvbus-en is fail, 22
      [    2.353681] get ehci1-controller wakeup-source is fail.
      [    2.359637] sunxi ehci1-controller don't init wakeup source
      [    2.365887] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0c89a18, 0x:c88e9000, irq_no:38
      [    2.378166] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
      [    2.390755] platform 2000c13.pwm3: pinctrl_get failed
      [    2.396523] platform 2000c13.pwm3: pinctrl_get failed
      [    2.402223] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
      [    2.409468] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
      [    2.419121] cpu cpu0: _set_opp_voltage: failed to set voltage (950000 950000 950000 mV): -19
      [    2.428634] platform 2000c13.pwm3: pinctrl_get failed
      [    2.434375] platform 2000c13.pwm3: pinctrl_get failed
      [    2.440018] cpu cpu0: _set_opp_voltage: failed to set voltage (950000 950000 950000 mV): -19
      [    2.449565] cpufreq: __target_index: Failed to change cpu frequency: -19
      [    2.457306] sunxi-ehci 4200000.ehci1-controller: irq 56, io mem 0x04200000
      [    2.491324] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
      [    2.499110] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [    2.508727] hub 1-0:1.0: USB hub found
      [    2.513020] hub 1-0:1.0: 1 port detected
      [    2.518434] get drvvbus-en is fail, 22
      [    2.522668] get ohci1-controller wakeup-source is fail.
      [    2.528655] sunxi ohci1-controller don't init wakeup source
      [    2.534933] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0c89cc8
      [    2.544840] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
      [    2.557173] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
      [    2.564455] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
      [    2.574382] sunxi-ohci 4200400.ohci1-controller: irq 57, io mem 0x04200400
      [    2.656286] hub 2-0:1.0: USB hub found
      [    2.660575] hub 2-0:1.0: 1 port detected
      [    2.667319] otg manager soc@3000000:usbc0@0: soc@3000000:usbc0@0 supply usbc not found, using dummy regulator
      [    2.678928] sun8iw20-pinctrl pio: pio supply vcc-pe not found, using dummy regulator
      [    2.691789] cfg80211: Loading compiled-in X.509 certificates for regulatory database
      [    2.703296] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
      [    2.710767] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
      [    2.711421] clk: Not disabling unused clocks
      [    2.720444] cfg80211: failed to load regulatory.db
      [    2.725182] ALSA device list:
      [    2.733852]   #0: audiocodec
      [    2.737074] alloc_fd: slot 0 not NULL!
      [    2.745879] VFS: Mounted root (squashfs filesystem) readonly on device 179:5.
      [    2.755987] Freeing unused kernel memory: 1024K
      [    2.801568] Kernel init done
      [    2.804793] Run /init as init process
      [    2.891404] usb 1-1: new high-speed USB device number 2 using sunxi-ehci
      [    3.094569] hub 1-1:1.0: USB hub found
      [    3.099239] hub 1-1:1.0: 4 ports detected
      [    3.505135] init: Console is alive
      [    3.509201] init: - watchdog -
      [    3.513505] init: - preinit -
      [    3.762819] kmodloader: loading kernel modules from /etc/modules-boot.d/*
      [    3.771100] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
      [    4.137805] random: jshn: uninitialized urandom read (4 bytes read)
      [    4.162608] random: jshn: uninitialized urandom read (4 bytes read)
      /dev/by-name/UDISK already format by ext4
      [    4.523306] mount_root: loading kmods from internal overlay
      [    4.539308] kmodloader: loading kernel modules from //etc/modules-boot.d/*
      [    4.547161] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
      [    4.596035] block: attempting to load /etc/config/fstab
      e2fsck 1.45.6 (20-Mar-2020)
      /dev/by-name/UDISK: clean, 35/228928 files, 34356/914660 blocks
      [    4.967301] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts:
      [    4.967768] random: procd: uninitialized urandom read (4 bytes read)
      [    4.984615] block: extroot: UUID mismatch (root: eef28811-39e41115-4ad4edcc-f7d79513, overlay: 0d3ca24a-ca5093d3-1ae52b9c-25239031)
      [    5.003680] mount_root: unable to create loop device
      [    5.010593] mount_root: no usable overlay filesystem found, using tmpfs overlay
      [    6.240784] procd: - early -
      [    6.241380]
      [    6.241380] insmod_device_driver
      [    6.241380]
      [    6.244281] procd: - watchdog -
      [    6.251222] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
      [    6.471088] procd: - watchdog -
      [    6.502329] procd: - ubus -
      [    6.581736] random: ubusd: uninitialized urandom read (4 bytes read)
      [    6.591866] random: ubusd: uninitialized urandom read (4 bytes read)
      [    6.599474] random: ubusd: uninitialized urandom read (4 bytes read)
      [    6.609493] procd: - init -
      [    6.990466] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      [    7.506993] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
      [    7.617092] kmodloader: loading kernel modules from /etc/modules.d/*
      [    7.784071] ======== XRADIO WIFI OPEN ========
      [    7.792960] [XRADIO] Driver Label:XR_V02.16.85_P2P_HT40_01.31
      [    7.799746] [XRADIO] Allocated hw_priv @ (ptrval)
      [    7.838006] [ADDR_MGT] get_addr_by_name: t->addr:
      [    7.891453] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
      [    7.919721] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
      [    8.219636] file system registered
      [    8.407880] configfs-gadget 4100000.udc-controller: failed to start g1: -19
      [    8.753783] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    8.770477] [XRADIO] Detect SDIO card 1
      [    8.782672] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [    8.809423] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    8.867745] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    8.903628] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    8.943014] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [    8.972969] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [    9.017331] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
      [    9.043645] mmc2: new high speed SDIO card at address 0001
      [    9.063486] read descriptors
      [    9.066779] read strings
      [    9.095370] [SBUS] XRadio Device:sdio clk=50000000
      [    9.111877] [XRADIO] XRADIO_HW_REV 1.0 detected.
      [    9.352001] [XRADIO] xradio_update_dpllctrl: DPLL_CTRL Sync=0x01400000.
      [    9.459433] [XRADIO] Bootloader complete
      [    9.564703] [XRADIO] Firmware completed.
      [    9.571664] [WSM] Firmware Label:XR_C09.08.52.73_DBG_02.122 2GHZ HT40 May 18 2021 13:36:09
      [    9.589272] [XRADIO] Firmware Startup Done.
      [    9.594421] [XRADIO_WRN] enable Multi-Rx!
      [    9.602812] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
      [    9.618779] kmodloader: done loading kernel modules from /etc/modules.d/*
      kmodloader done
      [   10.529710] random: crng init done
      [   10.533523] random: 4 urandom warning(s) missed due to ratelimiting
      [   11.178245] ieee80211_do_open: vif_type=2, p2p=0, ch=3, addr=dc:44:6d:7e:7b:8f
      [   11.186515] [STA] !!!xradio_vif_setup: id=0, type=2, p2p=0, addr=dc:44:6d:7e:7b:8f
      [   11.202944] [AP_WRN] BSS_CHANGED_ASSOC but driver is unjoined.
        WhycanService LV 8 最后由 编辑
        默认屏幕是bootlog,卡在软件升级了
        S 1 条回复 最后回复 回复 引用 分享 0
          Swain LV 4 @WhycanService 最后由 编辑
          @whycanservice 没有在升级,已经升级完了,现在我基本把所有外设都关闭了,还是进不去系统
            WhycanService LV 8 @Swain 最后由 编辑
            @swain 考虑是否是终端tty绑定错误,可以试试adb能不能用
